I use android_M6.0.1_2.0.0_source BSP to develop my product.
Android: android-6.0.1_r22
Kernel: Linux/arm 4.1.15
The kernel config file is ".config"
The log message is "log2.txt"
In this enviornment, linux kernel will run to dead.
When I use "Linux/arm 3.14.52 Kernel" will no this problem.
Original Attachment has been moved to: .config.zip
Original Attachment has been moved to: log2.txt.zip
Hi Aress
there are no specific errors related to security, so this may be
caused by build or programming issues. Please try fresh build
and program using MFG Tools
Hi Aress
unfortunately there is no such support for Android secure boot as for LInux,
suggest to elevate this through local fae channel.
Hi Igor,
Thanks for your reply and suggestion. I will retry another way.
Aress.
