K64 Temperature Sensor associated with ADC
JHinkle
Senior Contributor I
I'm embarrassed to ask but I can't find how to access the internal temperature sensor of the K64.
The documentation says the PN diode is attached to one of the ADC pins but that's it.
Where can I find which ADC channel has access to the temperature sensor?
Thanks.
Joe
JHinkle
Found it.
Sorry for the question.
egoodii
Senior Contributor III
Details about particulars for any specific chip are in section 3 of the reference manuals.  You should find a 'channel assignment' table in the analog section with this detail -- I expect you will find temp-sense on AD26.
I hope you have read my post about how to use this input.
JHinkle
Found it.
