We are designing a platform of the surveillance system using iMX6. During nights we need to get monochrome video from color stream. Does anyone know whether IPU can convert color video to monochrome using such as "color space conversion"?
Color stream will be provided in YUV format.
I'd appreciate any responses.
Hi Michal !
Thank you for the information.
But, the issue seems not to have been solved.
Am I correct?
Tetsuo
Hi Tetsuo
I am afraid no sense to make color space conversion
since ipu does not support monochrome output (monochrome lcds).
Color space conversion can be used to produce YUV 400 (monochrome)
output, also one can just use Y component as it contains black and white
data.
Hi Igor.
Thank you for the advice and sorry for my poor explanation.
Our input is a color camera and we would like to generate a gray-scale stream from the color stream before we compress it.
I think "IC" block in IPU has "color conversion" feature and we can use it for our purpose.
I'd appreciate your feedback.
Tetsuo
Hi Tetsuo
one can develop necessary conversion using examples on
https://community.freescale.com/docs/DOC-94961
Hi Igor !
The site would be a good help for our colleagues.
Tetsuo
