LPCXpresso Pro Flash size limited to 8K
shahabuddinmoha
I am using LPC Xpresso 8.1.4_606 with a Pro license installed.
It used to work fine, all of a sudden its not allowing to flash more than 8K image size.
I have tried debugging using FAQs, the csript works fine and COMSPEC is also set correctly.
FYI, I have version 7.5.0_254 installed as well (free version).
Attached log.
Shahab
Original Attachment has been moved to: NXPLPCXpresso_license_issue.zip
lpcxpresso_supp
You cannot have both a Free activation and Pro activation at the same time on a single machine. All installations of LPCXpresso IDE on a single machine share the same license. I suspect that by trying to use both Free and Pro, you have corrupted your license files.
I suggest that you delete (or rename) your license folder - details in the FAQWhere is my license file stored?
Then reactivate using your Pro Edition activation code - details in the FAQ Activating LPCXpresso Pro Edition
Once
LPCXpresso Support
