hello all,
i am installing the S32 ds for arm V1.2,when i
use offline activation,it said:"Invalid offline response!"
what's the problem?and the xml was generated by nxp.com.
hello all,
Hello Paul,
Some activation codes now can not used , you can use the activation code
Stanislav offerd : (S32DS Fails to Install )
37D6-B186-B306-B6AA
i just test it on my side , install S32DS for offline mode , it succeeded .
Also please refer to this guide to install S32DS for offline mode :
HOWTO: Activate S32 Design Studio
Hope it helps
Alice
Hello Alice,
I have just tried the activation code you supplied with the same results. The installer fails with “Invalid offline response, ResponseType”. I have logged in as the Administrator and it produces the same result. At this point I do not know what else I can do. I hope you can help. There may be some Java or Microsoft update that is preventing the installation. There is not much I can do about this because our IT group has complete control on what updates are pushed on our machines. We are pretty locked down here in terms of computer configurations/settings.
Paul Zak
It's taken me 1 week to install S32DS. Always the same error in the log file (3 PCs, 3 networks):
Install Uninstaller: S32 Design Studio for ARM v1.2(Install All Uninstaller Components)
Status: ERROR
Additional Notes: ERROR - Error writing LaunchAnywhere components (Access Denied)
Eventually I used my colleague's license key and the install worked first time. It looks as though there was a problem with my license key.
Thank you all for your reports!
We have published hot fix that should fix the offline activation problem.
Could you possibly check this link:
S32 Design Studio Offline activation issue hot fix
Stan
Can you please add the entitlement ID you are using. You can get this from your web portal on SW Licensing & Support site.
Go to order history and look for the entitlement ID, must be named S32DS-IDE-ARM_XXXXX
Check this video on how to access to your licensing portal.
How to access software products and licenses|NXP
