GPU STATE DUMP(DMA appears to be stuck at this address)
ifzhao
01:06:42GPU[0](ChipModel=0x2000 ChipRevision=0x5108):
01:06:43**************************
01:06:43***   GPU STATE DUMP   ***
01:06:43  axi      = 0x00000023
01:06:43  idle     = 0x7FFFFFF2
01:06:43    FE not idle
01:06:43    PE not idle
01:06:43    SH not idle
01:06:43  DMA appears to be stuck at this address:
01:06:43    0x06E3A030
01:06:43  dmaLow   = 0x00000000
01:06:43  dmaHigh  = 0x00000000
01:06:43set_voltage: uv 1275000, min 725000, max 1300000
01:06:43reg is 0000+++
01:06:43set_voltage: uv 1275000, min 725000, max 1450000
01:06:43set reg1 ++++++
01:06:43  dmaState = 0x00000904
01:06:43    command state       = 4 (PAR_ADR1_ST)
01:06:43    command DMA state   = 1 (CMD_START_ST)
01:06:43    command fetch state = 2 (FET_VALID_ST)
01:06:43    DMA request state   = 0 (REQ_IDLE_ST)
01:06:43    cal state           = 0 (CAL_IDLE_ST)
01:06:43    VE request state    = 0 (VER_IDLE_ST)
01:06:43  Debug registers of pipe[0]:
01:06:43    RA debug registers:
01:06:43      [0x00] 0x00000000
01:06:43      [0x01] 0x00000000
01:06:43      [0x02] 0x00000000
01:06:43      [0x03] 0x00000000
01:06:43      [0x04] 0x0BDF0000
01:06:43      [0x05] 0x5174A800
01:06:43      [0x06] 0x898A8000
01:06:43      [0x07] 0x00000000
01:06:43      [0x08] 0x00000000
01:06:43      [0x09] 0x00000000
01:06:43      [0x0A] 0x00000000
01:06:43      [0x0B] 0x00000000
01:06:43      [0x0C] 0x12344321
01:06:43      [0x0D] 0x12344321
01:06:43      [0x0E] 0x12344321
01:06:43      [0x0F] 0x12344321
01:06:43      signature = 0x12344321 (1 read attempt(s))
01:06:43    TX debug registers:
01:06:43      [0x04] 0x00000000
01:06:43      [0x05] 0x00000000
01:06:43      [0x06] 0x00000000
01:06:43      [0x0C] 0x00000000
01:06:43      [0x0D] 0x00000000
01:06:43      [0x0E] 0x00000000
01:06:43      [0x0F] 0x00000000
01:06:43      failed to obtain the signature (read 0x00000000).
01:06:43    FE debug registers:
01:06:43      [0x00] 0x06E3A250
01:06:43      [0x01] 0x6AEE3000
01:06:43      [0x02] 0x6AEE3000
01:06:43      [0x03] 0x00000256
01:06:43      [0x04] 0x0B783FFC
01:06:43      [0x05] 0x0000000C
01:06:43      [0x06] 0x50509571
01:06:43      [0x07] 0x00007445
01:06:43      [0x08] 0x0000000C
01:06:43      [0x0D] 0xA1750004
01:06:43      [0x0E] 0x000000A0
01:06:43      [0x0F] 0xBABEF00D
01:06:43      signature = 0xBABEF00D (1 read attempt(s))
01:06:43    PE debug registers:
01:06:43      [0x04] 0xA0000000
01:06:43      [0x05] 0xABC00000
01:06:43      [0x06] 0xBC000000
01:06:43      [0x07] 0xCDE00000
01:06:43      [0x08] 0xD04041C0
01:06:43      [0x09] 0x484041C0
01:06:43      [0x0A] 0x0D862086
01:06:43      [0x0C] 0xBABEF00D
01:06:43      [0x0D] 0xBABEF00D
01:06:43      [0x0E] 0xBABEF00D
01:06:43    DE debug registers:
01:06:43    SH debug registers:
01:06:43      [0x00] 0x0037EACB
01:06:43      [0x01] 0x595F000B
01:06:43      [0x02] 0x0001FF04
01:06:43      [0x03] 0x00080AA9
01:06:43      [0x05] 0x0032C2D0
01:06:43      [0x06] 0x0032A2CE
01:06:43      [0x07] 0x66471B5A
01:06:43      [0x08] 0x02AD88B6
01:06:43      [0x09] 0x07B71C85
01:06:43      [0x0A] 0x00720B30
01:06:43      [0x0B] 0x00257B6D
01:06:43      [0x0D] 0x0AF05473
01:06:43      [0x0E] 0x15EAA9F8
01:06:43      [0x0F] 0xDEADBEEF
01:06:43      signature = 0xDEADBEEF (1 read attempt(s))
01:06:43    PA debug registers:
01:06:43      [0x00] 0x800003FF
01:06:43      [0x01] 0x642800FF
01:06:43      [0x02] 0x00000871
01:06:43      [0x09] 0x0000AAAA
01:06:43      [0x0A] 0x0000AAAA
01:06:43      [0x0B] 0x0000AAAA
01:06:43      [0x0C] 0x0000AAAA
01:06:43      [0x0D] 0x0000AAAA
01:06:43      [0x0E] 0x0000AAAA
01:06:43      [0x0F] 0x0000AAAA
01:06:43      signature = 0x0000AAAA (1 read attempt(s))
01:06:43    SE debug registers:
01:06:43      [0x00] 0x00000003
01:06:43      [0x01] 0x00000003
01:06:43      [0x02] 0x00000003
01:06:43      [0x03] 0x00000003
01:06:43      [0x04] 0x00000003
01:06:43      [0x05] 0x00000003
01:06:43      [0x06] 0x00000003
01:06:43      [0x07] 0x00000003
01:06:43      [0x08] 0x00000003
01:06:43      [0x09] 0x00000003
01:06:43      [0x0A] 0x00000003
01:06:43      [0x0B] 0x00000003
01:06:43      [0x0C] 0x00000003
01:06:43      [0x0D] 0x00000003
01:06:43      [0x0E] 0x00000003
01:06:43      [0x0F] 0x00000003
01:06:43      failed to obtain the signature (read 0x00000003).
01:06:43    MC debug registers:
01:06:43      [0x04] 0x12345678
01:06:43      [0x05] 0x12345678
01:06:43      [0x06] 0x12345678
01:06:43      [0x07] 0x12345678
01:06:43      [0x08] 0x12345678
01:06:43      [0x09] 0x12345678
01:06:43      [0x0A] 0x12345678
01:06:43      [0x0B] 0x12345678
01:06:43      [0x0C] 0x12345678
01:06:43      [0x0D] 0x12345678
01:06:43      [0x0E] 0x12345678
01:06:43      [0x0F] 0x12345678
01:06:43      signature = 0x12345678 (1 read attempt(s))
01:06:43    HI debug registers:
01:06:43      [0x03] 0xAAAAAAAA
01:06:43      [0x04] 0xAAAAAAAA
01:06:43      [0x05] 0xAAAAAAAA
01:06:43      [0x06] 0xAAAAAAAA
01:06:43      [0x07] 0xAAAAAAAA
01:06:43      [0x08] 0xAAAAAAAA
01:06:43      [0x09] 0xAAAAAAAA
01:06:43      [0x0A] 0xAAAAAAAA
01:06:43      [0x0B] 0xAAAAAAAA
01:06:43      [0x0C] 0xAAAAAAAA
01:06:43      [0x0D] 0xAAAAAAAA
01:06:43      [0x0E] 0xAAAAAAAA
01:06:43      [0x0F] 0xAAAAAAAA
01:06:43      signature = 0xAAAAAAAA (1 read attempt(s))
01:06:43    Other Registers:
01:06:43      [0x0040] 0x1703229A
01:06:43      [0x0044] 0x0ECE030E
01:06:43      [0x004C] 0x0ECE030E
01:06:43      [0x0050] 0x01E8F826
01:06:43      [0x0054] 0x01E8F826
01:06:43      [0x0058] 0x1703229A
01:06:43      [0x005C] 0x046E5E34
01:06:43      [0x0060] 0x046E5E34
01:06:43      [0x043C] 0x00000000
01:06:43      [0x0440] 0x00000000
01:06:43      [0x0444] 0x00000000
01:06:43      [0x0414] 0x3C000000
01:06:43  Debug registers of pipe[1]:
01:06:43      [0x0D] 0xA1C4BC02
01:06:43      [0x0E] 0x000000A1
01:06:44      failed to obtain the signature (read 0x00000003).
01:06:44    MC debug registers:
01:06:44      [0x00] 0x00000000
01:06:44      [0x01] 0x00000000
01:06:44      [0x02] 0x00000000
01:06:44      [0x03] 0x00000000
01:06:44      [0x04] 0x12345678
01:06:44      [0x05] 0x12345678
01:06:44      [0x06] 0x12345678
01:06:44      [0x07] 0x12345678
01:06:44      [0x08] 0x12345678
01:06:44      [0x09] 0x12345678
01:06:44      [0x0A] 0x12345678
01:06:44      [0x0B] 0x12345678
01:06:44      [0x0C] 0x12345678
01:06:44      [0x0D] 0x12345678
01:06:44      [0x0E] 0x12345678
01:06:44      [0x0F] 0x12345678
01:06:44      signature = 0x12345678 (1 read attempt(s))
01:06:44    HI debug registers:
01:06:44      [0x03] 0xAAAAAAAA
01:06:44      [0x04] 0xAAAAAAAA
01:06:44      [0x05] 0xAAAAAAAA
01:06:44      [0x06] 0xAAAAAAAA
01:06:44      [0x07] 0xAAAAAAAA
01:06:44      [0x08] 0xAAAAAAAA
01:06:44      [0x09] 0xAAAAAAAA
01:06:44      [0x0A] 0xAAAAAAAA
01:06:44      [0x0B] 0xAAAAAAAA
01:06:44      [0x0C] 0xAAAAAAAA
01:06:44      [0x0D] 0xAAAAAAAA
01:06:44      [0x0E] 0xAAAAAAAA
01:06:44      [0x0F] 0xAAAAAAAA
01:06:44      signature = 0xAAAAAAAA (1 read attempt(s))
01:06:44    Other Registers:
01:06:44      [0x0040] 0x16B4E252
01:06:44      [0x0044] 0x0ECD91F0
01:06:44      [0x004C] 0x0ECD91F0
01:06:44      [0x0050] 0x01E8E9F7
01:06:44      [0x0054] 0x01E8E9F7
01:06:44      [0x0058] 0x16B4E252
01:06:44      [0x005C] 0x04601D72
01:06:44      [0x0060] 0x04601D72
01:06:44      [0x043C] 0x00000000
01:06:44      [0x0440] 0x00000000
01:06:44      [0x0444] 0x00000000
01:06:44      [0x0414] 0x3C000000
01:06:44[<c0056144>] (unwind_backtrace+0x0/0x138) from [<c04cf088>] (gckOS_DumpCallStack+0x8/0x10)
01:06:44[<c04cf088>] (gckOS_DumpCallStack+0x8/0x10) from [<c04e1d6c>] (gckHARDWARE_DumpGPUState+0x4b8/0x6a0)
01:06:44[<c04e1d6c>] (gckHARDWARE_DumpGPUState+0x4b8/0x6a0) from [<c04ce028>] (gckOS_Broadcast+0x38/0xe8)
01:06:44[<c04ce028>] (gckOS_Broadcast+0x38/0xe8) from [<c04d1c14>] (gckKERNEL_Dispatch+0x1020/0x1228)
01:06:44[<c04d1c14>] (gckKERNEL_Dispatch+0x1020/0x1228) from [<c04ca3e0>] (drv_ioctl+0x120/0x270)
01:06:44[<c04ca3e0>] (drv_ioctl+0x120/0x270) from [<c0144d2c>] (do_vfs_ioctl+0x7c/0x290)
01:06:44[<c0144d2c>] (do_vfs_ioctl+0x7c/0x290) from [<c0144f78>] (sys_ioctl+0x38/0x5c)
01:06:44[<c0144f78>] (sys_ioctl+0x38/0x5c) from [<c004e9c0>] (ret_fast_syscall+0x0/0x30)
以上是在IMX6dual平台上(Android 4.3的系统,linux 2.6),安装安兔兔进行3D测试的时候,画面卡住,然后出现这样的log。参考了社区内的相关博文,去调整DMA和fbmem、GPU电压(PMU_REG_CORE[REG1_TARG])均没有效果。
试着打开CONFIG_MX6_VPU_352M,也没有收获。不知道各位有什么建议??十分感谢~
The above logging is got while doing 3d graphic test with AnTuTu app. The video halts,the picture stays still, but the system is alive as the console is still available. And after referring to several similar blog in the community, I tried the DMA/fbmem/GPU voltage supply, but failed. Also I open the config CONFIG_MX6_VPU_352M, it didn't work for me.
Could you everybody kindly give me some advice? Or some solutions to optimize the GPU ? Many thanks ~~
Labels (2)
Hi If
it is highly recommended to move to latests android versions as
many bugs were fixed since 4.3 release, just for reference please look
at attached Release Notes Table 9. New features
ifzhao
It's very kind of u. However it'd be tough to update the whole system to one of upper grade.
I'd like to know which patch could be of use to my problem.
Thanks all the same.
qiang_li-mpu_se
Hi Zhao, you can update the GPU only based on JB4.3 release.
GPU upgrade to latest p13 for JB4.3_1.1.1 release
ifzhao
Thanks very much, I'd try your idea.
