Interfacing of TSOP SENSOR with LPC1769 EA baseboard
Content originally posted in LPCWare by kuldip rajput on Sun Apr 05 22:03:58 MST 2015
Hello Sir,
       I want to interface  TSOP SENSOR FOR OBJECT DETECTION on the LPC1769 EA baseboard with the help of expansion connector. May I know the procedure for interfacing an external peripheral on EA baseboard through the GPIO. I am unable to get the EA baseboard schematic for finding the pin configuration on the expansion connector.
May I know how to connect the pins of expansion connector with the LPC1769 controller stamp.
would any body please help me regarding this issue.
Content originally posted in LPCWare by cfb on Sun Apr 05 23:58:18 MST 2015
After you register your board with Embedded Artists you can login and download the schematic from here:
http://www.embeddedartists.com/products/lpcxpresso/xpr_base.php
