Content originally posted in LPCWare by Hansi on Fri Jul 11 06:45:33 MST 2014 Hi!
Today I installed LPCXpresso v7.2.0 [Build 153] [2014-05-19] on my Debian machine (Debian sid, latest updates, 64 bit, kernel 3.12-1-amd64). When starting LPCXpresso, it asks for the path of the workspace and then crashes.
The Java stacktrace and the core dump showed that a segfault occured in or during loading of .../lpcxpresso/bin/libdna.so (some cloud based software activation service https://www.softworkz.com/).
Simply deleting (or renaming) .../lpcxpresso/bin/libdna.so solved the problem.
This post should just help if somebody has a similar problem.
