Can't work freertos demo with LPCxpresso ide
Content originally posted in LPCWare by nxpuser1 on Tue Mar 10 06:36:53 MST 2015
I am new at LPCxpresso,
I use freertos in my project. I dawnload to below file to debug first programme. But I can't run to programme because ıt give me error that .axf file cannot be occured ? How can I fix it?
projects' link: http://www.freertos.org/FreeRTOS-Plus/FreeRTOS_Plus_IO/Demo_Applications/LPCXpresso_LPC1769/NXP_LPC1...
Content originally posted in LPCWare by nxpuser1 on Fri Mar 13 08:23:12 MST 2015
I did your ini file solution and problem is fixed.
Thanks for your support.
Content originally posted in LPCWare by lpcxpresso-support on Fri Mar 13 07:36:05 MST 2015
I have been able to reproduce your problem, but setting my language to Turkish. We will investigate what is happening.
In the meantime, you should be able to fix this on your system by setting your language to English. You can do this by editing <install>\lpcxpresso\lpcxpresso.ini
and adding the following lines to the end of this file:
-Dorg.osgi.framework.language=en
-Duser.language=en
-Duser.country=EN
Content originally posted in LPCWare by nxpuser1 on Fri Mar 13 05:37:06 MST 2015
I use windows7, 64bits, Windows response
C:\Users\Egitim5>set
ALLUSERSPROFILE=C:\ProgramData
AMDAPPSDKROOT=C:\Program Files (x86)\AMD APP\
APPDATA=C:\Users\Egitim5\AppData\Roaming
CommonProgramFiles=C:\Program Files\Common Files
CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
CommonProgramW6432=C:\Program Files\Common Files
COMPUTERNAME=EGITIM5-HP
ComSpec=C:\Windows\system32\cmd.exe
FP_NO_HOST_CHECK=NO
HOMEDRIVE=C:
HOMEPATH=\Users\Egitim5
KMP_DUPLICATE_LIB_OK=TRUE
LOCALAPPDATA=C:\Users\Egitim5\AppData\Local
LOGONSERVER=\\EGITIM5-HP
MKL_SERIAL=YES
NUMBER_OF_PROCESSORS=4
OnlineServices=Online Services
OS=Windows_NT
Path=C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\HP SimplePass 20
11\;C:\Program Files\Broadcom\Broadcom 802.11\Driver;;C:\Program Files (x86)\AMD
APP\bin\x86_64;C:\Program Files (x86)\AMD APP\bin\x86;C:\Program Files\Common F
iles\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft
Shared\Windows Live;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\
Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Windows Live\Sha
red;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files
\WIDCOMM\Bluetooth Software\;C:\Program Files\WIDCOMM\Bluetooth Software\syswow6
4;C:\Program Files\Broadcom\WHL\;C:\Program Files\Broadcom\WHL\syswow64;C:\Progr
am Files\Broadcom\WHL\SysWow64\;C:\Program Files\Broadcom\WHL\SysWow64\syswow64;
C:\Program Files (x86)\Intel\Services\IPT\;C:\Program Files (x86)\Microchip\MPLA
B C32 Suite\bin;C:\Program Files (x86)\HI-TECH Software\PICC\9.83\bin;C:\Program
Files (x86)\Microchip\xc16\v1.21\bin;c:\Program Files (x86)\Microsoft SQL Serve
r\100\Tools\Binn\;c:\Program Files\Microsoft SQL Server\100\Tools\Binn\;c:\Progr
am Files\Microsoft SQL Server\100\DTS\Binn\
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
PCBRAND=Pavilion
Platform=MCD
PROCESSOR_ARCHITECTURE=AMD64
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 42 Stepping 7, GenuineIntel
PROCESSOR_LEVEL=6
PROCESSOR_REVISION=2a07
ProgramData=C:\ProgramData
PROMPT=$P$G
PSModulePath=C:\Windows\system32\WindowsPowerShell\v1.0\Modules\
PUBLIC=C:\Users\Public
SESSIONNAME=Console
SystemDrive=C:
SystemRoot=C:\Windows
TEMP=C:\Users\Egitim5\AppData\Local\Temp
TMP=C:\Users\Egitim5\AppData\Local\Temp
USERDOMAIN=Egitim5-HP
USERNAME=Egitim5
USERPROFILE=C:\Users\Egitim5
windir=C:\Windows
windows_tracing_flags=3
windows_tracing_logfile=C:\BVTBin\Tests\installpackage\csilogfile.log
IDE :
*** Date: 13 Mart 2015 Cuma 14:35:46 Doğu Avrupa Standart Saati
*** Platform Details:
*** System properties:
applicationXMI=org.eclipse.ui.workbench/LegacyIDE.e4xmi
awt.toolkit=sun.awt.windows.WToolkit
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
-launcher
C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\lpcxpresso.exe
-name
Lpcxpresso
--launcher.library
C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\\plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.1.200.v20140603-1326\eclipse_1603.dll
-startup
C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\\plugins/org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar
--launcher.overrideVmargs
-vm
C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\bin\client\jvm.dll
eclipse.home.location=file:/C:/nxp/LPCXpresso_7.6.2_326/lpcxpresso/
eclipse.launcher=C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\lpcxpresso.exe
eclipse.launcher.name=Lpcxpresso
eclipse.p2.data.area=@config.dir/../p2
eclipse.p2.profile=DefaultProfile
eclipse.product=com.crt.lpcxpresso.brand.product
eclipse.startTime=1426239422881
eclipse.stateSaveDelayInterval=30000
eclipse.vm=C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\bin\client\jvm.dll
eclipse.vmargs=-Dosgi.requiredJavaVersion=1.7
-Xms128m
-Xmx512m
-XX:MaxPermSize=256M
-Djava.class.path=C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\\plugins/org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar
equinox.use.ds=true
file.encoding=Cp1254
file.encoding.pkg=sun.io
file.separator=\
gosh.args=--nointeractive
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.version=51.0
java.endorsed.dirs=C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\lib\endorsed
java.ext.dirs=C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\lib\ext;C:\Windows\Sun\Java\lib\ext
java.home=C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre
java.io.tmpdir=C:\Users\Egitim5\AppData\Local\Temp\
java.library.path=C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:/nxp/LPCXpresso_7.6.2_326/lpcxpresso/jre/bin/client;C:/nxp/LPCXpresso_7.6.2_326/lpcxpresso/jre/bin;C:/nxp/LPCXpresso_7.6.2_326/lpcxpresso/jre/lib/i386;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\HP SimplePass 2011\;C:\Program Files\Broadcom\Broadcom 802.11\Driver;;C:\Program Files (x86)\AMD APP\bin\x86_64;C:\Program Files (x86)\AMD APP\bin\x86;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Windows Live\Shared;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files\WIDCOMM\Bluetooth Software\;C:\Program Files\WIDCOMM\Bluetooth Software\syswow64;C:\Program Files\Broadcom\WHL\;C:\Program Files\Broadcom\WHL\syswow64;C:\Program Files\Broadcom\WHL\SysWow64\;C:\Program Files\Broadcom\WHL\SysWow64\syswow64;C:\Program Files (x86)\Intel\Services\IPT\;C:\Program Files (x86)\Microchip\MPLAB C32 Suite\bin;C:\Program Files (x86)\HI-TECH Software\PICC\9.83\bin;C:\Program Files (x86)\Microchip\xc16\v1.21\bin;c:\Program Files (x86)\Microsoft SQL Server\100\Tools\Binn\;c:\Program Files\Microsoft SQL Server\100\Tools\Binn\;c:\Program Files\Microsoft SQL Server\100\DTS\Binn\;C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso;;.
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.7.0_71-b14
java.specification.name=Java Platform API Specification
java.specification.vendor=Oracle Corporation
java.specification.version=1.7
java.vendor=Oracle Corporation
java.vendor.url=http://java.oracle.com/
java.vendor.url.bug=http://bugreport.sun.com/bugreport/
java.version=1.7.0_71
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Oracle Corporation
java.vm.specification.version=1.7
java.vm.vendor=Oracle Corporation
java.vm.version=24.71-b01
line.separator=
org.eclipse.cdt.debug.ui.debuggerActive=false
org.eclipse.debug.ui.breakpoints.toggleFactoriesUsed=true
org.eclipse.equinox.launcher.splash.location=c:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\configuration\org.eclipse.equinox.launcher\com.crt.lpcxpresso.brand_7.4.1.201502020932\splash.bmp
org.eclipse.equinox.simpleconfigurator.configUrl=file:org.eclipse.equinox.simpleconfigurator/bundles.info
org.eclipse.update.reconcile=false
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSGi/Minimum-1.1,OSGi/Minimum-1.2,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,JavaSE-1.6,JavaSE-1.7
org.osgi.framework.language=tr
org.osgi.framework.os.name=Windows7
org.osgi.framework.os.version=6.1.0
org.osgi.framework.processor=x86
org.osgi.framework.system.capabilities=osgi.ee; osgi.ee="OSGi/Minimum"; version:List<Version>="1.0, 1.1, 1.2",osgi.ee; osgi.ee="JRE"; version:List<Version>="1.0, 1.1",osgi.ee; osgi.ee="JavaSE"; version:List<Version>="1.0, 1.1, 1.2, 1.3, 1.4, 1.5, 1.6, 1.7"
org.osgi.framework.system.packages=javax.accessibility,javax.activation,javax.activity,javax.annotation,javax.annotation.processing,javax.crypto,javax.crypto.interfaces,javax.crypto.spec,javax.imageio,javax.imageio.event,javax.imageio.metadata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap,javax.lang.model,javax.lang.model.element,javax.lang.model.type,javax.lang.model.util,javax.management,javax.management.loading,javax.management.modelmbean,javax.management.monitor,javax.management.openmbean,javax.management.relation,javax.management.remote,javax.management.remote.rmi,javax.management.timer,javax.naming,javax.naming.directory,javax.naming.event,javax.naming.ldap,javax.naming.spi,javax.net,javax.net.ssl,javax.print,javax.print.attribute,javax.print.attribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.rmi.ssl,javax.script,javax.security.auth,javax.security.auth.callback,javax.security.auth.kerberos,javax.security.auth.login,javax.security.auth.spi,javax.security.auth.x500,javax.security.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi,javax.swing,javax.swing.border,javax.swing.colorchooser,javax.swing.event,javax.swing.filechooser,javax.swing.plaf,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.nimbus,javax.swing.plaf.synth,javax.swing.table,javax.swing.text,javax.swing.text.html,javax.swing.text.html.parser,javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.tools,javax.transaction,javax.transaction.xa,javax.xml,javax.xml.bind,javax.xml.bind.annotation,javax.xml.bind.annotation.adapters,javax.xml.bind.attachment,javax.xml.bind.helpers,javax.xml.bind.util,javax.xml.crypto,javax.xml.crypto.dom,javax.xml.crypto.dsig,javax.xml.crypto.dsig.dom,javax.xml.crypto.dsig.keyinfo,javax.xml.crypto.dsig.spec,javax.xml.datatype,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,javax.xml.stream,javax.xml.stream.events,javax.xml.stream.util,javax.xml.transform,javax.xml.transform.dom,javax.xml.transform.sax,javax.xml.transform.stax,javax.xml.transform.stream,javax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax.xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,javax.xml.ws.spi,javax.xml.ws.spi.http,javax.xml.ws.wsaddressing,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNaming.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.omg.PortableServer,org.omg.PortableServer.CurrentPackage,org.omg.PortableServer.POAManagerPackage,org.omg.PortableServer.POAPackage,org.omg.PortableServer.portable,org.omg.PortableServer.ServantLocatorPackage,org.omg.SendingContext,org.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.css,org.w3c.dom.events,org.w3c.dom.html,org.w3c.dom.ls,org.w3c.dom.ranges,org.w3c.dom.stylesheets,org.w3c.dom.traversal,org.w3c.dom.views,org.w3c.dom.xpath,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.uuid=806c6981-64c9-0014-1923-c7caabcbe0d5
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.8.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=x86
os.name=Windows 7
os.version=6.1
osgi.arch=x86
osgi.bundles=reference:file:org.eclipse.osgi.compatibility.state_1.0.1.v20140709-1414.jar,reference:file:org.eclipse.equinox.simpleconfigurator_1.1.0.v20131217-1203.jar@1:start
osgi.bundles.defaultStartLevel=4
osgi.compatibility.bootdelegation=true
osgi.configuration.area=file:/C:/nxp/LPCXpresso_7.6.2_326/lpcxpresso/configuration/
osgi.configuration.area.default=null
osgi.framework=file:/c:/nxp/LPCXpresso_7.6.2_326/lpcxpresso/plugins/org.eclipse.osgi_3.10.1.v20140909-1633.jar
osgi.framework.extensions=reference:file:org.eclipse.osgi.compatibility.state_1.0.1.v20140709-1414.jar
osgi.framework.shape=jar
osgi.framework.useSystemProperties=true
osgi.frameworkClassPath=., file:c:/nxp/LPCXpresso_7.6.2_326/lpcxpresso/plugins/org.eclipse.osgi.compatibility.state_1.0.1.v20140709-1414.jar
osgi.install.area=file:/C:/nxp/LPCXpresso_7.6.2_326/lpcxpresso/
osgi.instance.area=file:/C:/Users/Egitim5/Documents/LPCXpresso_7.6.2_326/workspace/
osgi.instance.area.default=file:/C:/Users/Egitim5/Documents/LPCXpresso_7.6.2_326/workspace/
osgi.logfile=C:\Users\Egitim5\Documents\LPCXpresso_7.6.2_326\workspace\.metadata\.log
osgi.nl=tr_TR
osgi.os=win32
osgi.splashLocation=c:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\configuration\org.eclipse.equinox.launcher\com.crt.lpcxpresso.brand_7.4.1.201502020932\splash.bmp
osgi.splashPath=platform:/base/plugins/com.crt.lpcxpresso.brand
osgi.syspath=c:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\plugins
osgi.tracefile=C:\Users\Egitim5\Documents\LPCXpresso_7.6.2_326\workspace\.metadata\trace.log
osgi.user.area=null
osgi.user.area.default=null
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\lib\resources.jar;C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\lib\rt.jar;C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\lib\sunrsasign.jar;C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\lib\jsse.jar;C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\lib\jce.jar;C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\lib\charsets.jar;C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\lib\jfr.jar;C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\classes
sun.boot.library.path=C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium_pro+mmx pentium_pro pentium+mmx pentium i486 i386 i86
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1254
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 1
user.country=TR
user.dir=C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso
user.home=C:\Users\Egitim5
user.language=tr
user.name=Egitim5
user.script=
user.timezone=Europe/Athens
user.variant=
*** Features:
com.crt.lpcxpresso.feature (7.4.1.201502020932) "LPCXpresso Product Definition"
org.eclipse.cdt (8.5.0.201409172108) "Eclipse C/C++ Development Tools"
org.eclipse.cdt.gdb (8.5.0.201409172108) "GDB Common"
org.eclipse.cvs (1.4.100.v20140925-0400) "Eclipse CVS Client"
org.eclipse.emf.common (2.10.1.v20140901-1043) "EMF Common"
org.eclipse.emf.ecore (2.10.1.v20140901-1043) "EMF Ecore"
org.eclipse.help (2.0.102.v20140925-0400) "Help System Base"
org.eclipse.platform (4.4.0.v20140925-0400) "Eclipse Platform"
org.eclipse.rcp (4.4.0.v20140925-0400) "Eclipse RCP"
*** Plug-in Registry:
com.crt.advproject (7.4.1.201502020932) "Advanced Project Support" [Active]
com.crt.config (7.4.1.201502020932) "Target Configuration" [Active]
com.crt.ctrlcenter (7.4.1.201502020932) "Project Configuration" [Active]
com.crt.debugcommon (7.4.1.201502020932) "Debug Common" [Active]
com.crt.debugmgr (7.4.1.201502020932) "Debug Manager" [Starting]
com.crt.docs (7.4.1.201502020932) "LPCXpresso Documentation" [Resolved]
com.crt.docs.rsguide (7.4.1.201502020932) "LPCXpresso Guide" [Resolved]
com.crt.dsfdebug (7.4.1.201502020932) "DSF Debug Support" [Active]
com.crt.dsfswv (7.4.1.201502020932) "Red Trace+" [Starting]
com.crt.etmetb (7.4.1.201502020932) "Instruction Trace Support" [Starting]
com.crt.lite (7.4.1.201502020932) "Develop Perspective" [Active]
com.crt.lpcxpresso.brand (7.4.1.201502020932) "LPCXpresso Product Definition" [Active]
com.crt.quickstart (7.4.1.201502020932) "Quickstart Panel" [Active]
com.crt.redstate (7.4.1.201502020932) "RedState" [Starting]
com.crt.utils (7.4.1.201502020932) "LPCXpresso Utilities" [Active]
com.crt.vendor.arm.generic (7.4.1.201502020932) "Generic ARM Support" [Starting]
com.crt.vendor.nxp.a7 (7.4.1.201502020932) "NXP LPC2000 Support" [Active]
com.crt.vendor.nxp.generic (7.4.1.201502020932) "NXP Generic Core Support" [Active]
com.crt.vendor.nxp.lpc11 (7.4.1.201502020932) "NXP LPC1100 Support" [Active]
com.crt.vendor.nxp.lpc13 (7.4.1.201502020932) "NXP LPC1300 Support" [Active]
com.crt.vendor.nxp.lpc17 (7.4.1.201502020932) "NXP LPC1700 Support" [Active]
com.crt.vendor.nxp.lpc18 (7.4.1.201502020932) "NXP LPC1800 Support" [Active]
com.crt.vendor.nxp.lpc29 (7.4.1.201502020932) "NXP LPC2900 Support" [Active]
com.crt.vendor.nxp.lpc31 (7.4.1.201502020932) "NXP LPC3000 Support" [Active]
com.crt.vendor.nxp.lpc43 (7.4.1.201502020932) "NXP LPC4000 Support" [Active]
com.crt.vendor.nxp.niobe (7.4.1.201502020932) "NXP LPC5xxxx Series Support" [Active]
com.ibm.icu (52.1.0.v201404241930) "International Components for Unicode for Java (ICU4J)" [Active]
com.jcraft.jsch (0.1.50.v201403120620) "JSch" [Resolved]
com.nxp.gnudocs (7.4.1.201502020932) "GNU Help Documents Provider" [Starting]
com.nxp.symbolbrowser (7.4.1.201502020932) "Symbol Viewer" [Active]
com.sun.el (2.2.0.v201303151357) "Javax Expression Language Reference Implementation Bundle" [Resolved]
javax.annotation (1.2.0.v201401042248) "javax.annotation Bundle" [Resolved]
javax.el (2.2.0.v201303151357) "Javax Expression Language Bundle" [Resolved]
javax.inject (1.0.0.v20091030) "Atinject Dependency Injection Annotations" [Resolved]
javax.servlet (3.0.0.v201112011016) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.2.0.v201112011158) "JSP API Bundle" [Resolved]
javax.xml (1.3.4.v201005080400) "JAXP XML" [Resolved]
org.apache.ant (1.9.2.v201404171502) "Apache Ant" [Resolved]
org.apache.batik.css (1.7.0.v201011041433) "Apache Batik CSS" [Resolved]
org.apache.batik.util (1.7.0.v201011041433) "Apache Batik Utilities" [Resolved]
org.apache.batik.util.gui (1.7.0.v200903091627) "Apache Batik GUI Utilities" [Resolved]
org.apache.commons.codec (1.6.0.v201305230611) "Apache Commons Codec Plug-in" [Resolved]
org.apache.commons.logging (1.1.1.v201101211721) "Apache Commons Logging Plug-in" [Resolved]
org.apache.felix.gogo.command (0.10.0.v201209301215) "Apache Felix Gogo Command" [Active]
org.apache.felix.gogo.runtime (0.10.0.v201209301036) "Apache Felix Gogo Runtime" [Active]
org.apache.felix.gogo.shell (0.10.0.v201212101605) "Apache Felix Gogo Shell" [Active]
org.apache.httpcomponents.httpclient (4.2.6.v201311072007) "Apache HttpComponents HttpClient OSGi bundle" [Resolved]
org.apache.httpcomponents.httpcore (4.2.5.v201311072007) "Apache HttpComponents HttpCore" [Resolved]
org.apache.jasper.glassfish (2.2.2.v201205150955) "JSP 2.2 implementation from Glassfish" [Resolved]
org.apache.lucene.analysis (3.5.0.v20120725-1805) "Apache Lucene Analysis" [Resolved]
org.apache.lucene.core (3.5.0.v20120725-1805) "Apache Lucene Core" [Resolved]
org.eclipse.ant.core (3.3.0.v20140518-0042) "Ant Build Tool Core" [Starting]
org.eclipse.cdt (8.5.0.201409172108) "Eclipse C/C++ Development Tools" [Starting]
org.eclipse.cdt.codan.checkers (3.2.0.201409172108) "Codan Checkers" [Active]
org.eclipse.cdt.codan.checkers.ui (3.2.0.201409172108) "Codan Checkers UI" [Active]
org.eclipse.cdt.codan.core (3.2.0.201409172108) "Code Analysis Core" [Active]
org.eclipse.cdt.codan.core.cxx (3.2.0.201409172108) "Code Analysis Core for C/C++" [Active]
org.eclipse.cdt.codan.ui (3.2.0.201409172108) "Code Analysis UI" [Active]
org.eclipse.cdt.codan.ui.cxx (3.2.0.201409172108) "Codan Analysis UI for C/C++" [Active]
org.eclipse.cdt.core (5.8.0.201409172108) "C/C++ Development Tools Core" [Active]
org.eclipse.cdt.core.native (5.7.0.201409172108) "C/C++ Development Tools Core Native Utilities" [Active]
org.eclipse.cdt.core.win32 (5.4.0.201409172108) "C/C++ Development Tools Core Native Utilities for Windows" [Resolved]
org.eclipse.cdt.core.win32.x86 (5.3.0.201409172108) "C/C++ Development Tools Core Native Utilities for Windows (x86)" [Resolved]
org.eclipse.cdt.debug.core (7.5.0.201409172108) "C/C++ Development Tools Debug Model" [Active]
org.eclipse.cdt.debug.gdbjtag (7.0.0.201409172108) "Eclipse GDB Hardware Debugging Plug-in" [Resolved]
org.eclipse.cdt.debug.gdbjtag.core (8.4.0.201409172108) "Eclipse GDB Hardware Debug Core Plug-in" [Starting]
org.eclipse.cdt.debug.gdbjtag.ui (7.1.0.201409172108) "Eclipse GDB Hardware Debug UI Plug-in" [Starting]
org.eclipse.cdt.debug.mi.core (7.3.0.201409172108) "C/C++ Development Tools GDB/MI CDI Debugger Core" [Active]
org.eclipse.cdt.debug.mi.ui (6.2.0.201409172108) "C/C++ Development Tools GDB/MI CDI Debugger UI" [Active]
org.eclipse.cdt.debug.ui (7.5.0.201409172108) "C/C++ Development Tools Debugger UI" [Active]
org.eclipse.cdt.debug.ui.memory.memorybrowser (1.3.0.201409172108) "Memory Browser" [Starting]
org.eclipse.cdt.debug.ui.memory.search (1.3.0.201409172108) "Memory Search" [Starting]
org.eclipse.cdt.debug.ui.memory.traditional (1.2.1.201409172108) "Traditional Memory Rendering" [Starting]
org.eclipse.cdt.debug.ui.memory.transport (2.1.0.201409172108) "Memory Transport Plug-in" [Starting]
org.eclipse.cdt.doc.user (5.3.0.201409172108) "C/C++ Development User Guide" [Starting]
org.eclipse.cdt.dsf (2.5.0.201409172108) "Debug Services Framework Core" [Active]
org.eclipse.cdt.dsf.gdb (4.5.0.201409172108) "GDB DSF Debugger Integration Core" [Active]
org.eclipse.cdt.dsf.gdb.ui (2.4.0.201409172108) "GDB DSF Debugger Integration UI" [Active]
org.eclipse.cdt.dsf.ui (2.4.100.201409172108) "Debugger Services Framework UI" [Active]
org.eclipse.cdt.gdb (7.0.0.201409172108) "GDB Common" [Starting]
org.eclipse.cdt.gdb.ui (7.0.0.201409172108) "GDB UI Common" [Starting]
org.eclipse.cdt.launch (7.1.0.201409172108) "C/C++ Development Tools Launching Support" [Active]
org.eclipse.cdt.make.core (7.3.0.201409172108) "C/C++ Standard make Build Core" [Active]
org.eclipse.cdt.make.ui (7.2.0.201409172108) "C/C++ Standard make Build UI" [Active]
org.eclipse.cdt.managedbuilder.core (8.3.0.201409172108) "CDT Build System Core" [Active]
org.eclipse.cdt.managedbuilder.gnu.ui (8.3.0.201409172108) "GNU Managed Build Definitions" [Active]
org.eclipse.cdt.managedbuilder.ui (8.2.2.201409172108) "C/C++ Managed Builder UI" [Active]
org.eclipse.cdt.ui (5.8.1.201409172108) "C/C++ Development Tools UI" [Active]
org.eclipse.compare (3.5.501.v20140817-1445) "Compare Support" [Active]
org.eclipse.compare.core (3.5.400.v20130903-0736) "Core Compare Support" [Active]
org.eclipse.compare.win32 (1.0.200.v20130514-1224) "Compare Support for Word" [Starting]
org.eclipse.core.commands (3.6.100.v20140528-1422) "Commands" [Resolved]
org.eclipse.core.contenttype (3.4.200.v20140207-1251) "Eclipse Content Mechanism" [Active]
org.eclipse.core.databinding (1.4.2.v20140729-1044) "JFace Data Binding" [Starting]
org.eclipse.core.databinding.beans (1.2.200.v20140214-0004) "JFace Data Binding for JavaBeans" [Resolved]
org.eclipse.core.databinding.observable (1.4.1.v20140210-1835) "JFace Data Binding Observables" [Active]
org.eclipse.core.databinding.property (1.4.200.v20140214-0004) "JFace Data Binding Properties" [Starting]
org.eclipse.core.expressions (3.4.600.v20140128-0851) "Expression Language" [Active]
org.eclipse.core.externaltools (1.0.300.v20140219-0051) "External Tools Headless Support" [Active]
org.eclipse.core.filebuffers (3.5.400.v20140127-1516) "File Buffers" [Active]
org.eclipse.core.filesystem (1.4.100.v20140514-1614) "Core File Systems" [Active]
org.eclipse.core.filesystem.java7 (1.0.0.v20140429-1531) "Core File System for Java 7 and newer" [Resolved]
org.eclipse.core.filesystem.win32.x86 (1.4.0.v20140124-1940) "Core File System for Windows" [Resolved]
org.eclipse.core.jobs (3.6.0.v20140424-0053) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.net (1.2.200.v20140124-2013) "Internet Connection Management" [Active]
org.eclipse.core.net.win32.x86 (1.0.100.v20140124-2013) "Proxy for Windows" [Resolved]
org.eclipse.core.resources (3.9.1.v20140825-1431) "Core Resource Management" [Active]
org.eclipse.core.resources.win32.x86 (3.5.100.v20140124-1940) "Core Resource Management Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.10.0.v20140318-2214) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.2.200.v20140128-0851) "Core Runtime Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.registry (3.5.300.v20140128-0851) "Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.2.800.v20130819-1716) "Core Variables" [Active]
org.eclipse.cvs (1.4.100.v20140925-0400) "Eclipse CVS Client" [Starting]
org.eclipse.debug.core (3.9.1.v20140805-1629) "Debug Core" [Active]
org.eclipse.debug.ui (3.10.1.v20140822-1408) "Debug UI" [Active]
org.eclipse.draw2d (3.9.101.201408150207) "Graphical Editing Framework Draw2d" [Starting]
org.eclipse.e4.core.commands (0.10.2.v20140424-2344) "Eclipse e4 core commands" [Active]
org.eclipse.e4.core.contexts (1.3.100.v20140407-1019) "Eclipse Contexts" [Active]
org.eclipse.e4.core.di (1.4.0.v20140414-1837) "Eclipse Dependency Injection" [Active]
org.eclipse.e4.core.di.extensions (0.12.0.v20140417-2033) "Eclipse Dependency Injection Extensions" [Active]
org.eclipse.e4.core.services (1.2.1.v20140808-1251) "Eclipse Application Services" [Active]
org.eclipse.e4.ui.bindings (0.10.200.v20140424-2042) "Eclipse Bindings Support" [Active]
org.eclipse.e4.ui.css.core (0.10.100.v20140424-2042) "Eclipse CSS Core Support" [Resolved]
org.eclipse.e4.ui.css.swt (0.11.101.v20140818-1343) "Eclipse CSS SWT Support" [Active]
org.eclipse.e4.ui.css.swt.theme (0.9.300.v20140424-2042) "Eclipse CSS SWT Theme Support" [Active]
org.eclipse.e4.ui.di (1.0.0.v20140328-2112) "Eclipse UI Dependency Injection" [Active]
org.eclipse.e4.ui.model.workbench (1.1.0.v20140512-1820) "Eclipse Workbench Model" [Active]
org.eclipse.e4.ui.services (1.1.0.v20140328-1925) "Eclipse UI Application Services" [Active]
org.eclipse.e4.ui.widgets (1.0.0.v20140514-1823) "Eclipse UI Custom widgets" [Resolved]
org.eclipse.e4.ui.workbench (1.2.1.v20140901-1244) "Eclipse e4 Workbench" [Active]
org.eclipse.e4.ui.workbench.addons.swt (1.1.1.v20140903-0821) "Eclipse e4 Workbench Add-ons" [Active]
org.eclipse.e4.ui.workbench.renderers.swt (0.12.1.v20140903-1023) "Eclipse e4 Workbench SWT Renderer" [Active]
org.eclipse.e4.ui.workbench.swt (0.12.100.v20140530-1436) "Eclipse e4 Workbench SWT" [Active]
org.eclipse.e4.ui.workbench3 (0.12.0.v20140227-2118) "Bundle for Workbench APIs available in e4" [Resolved]
org.eclipse.ecf (3.4.0.v20140827-1444) "ECF Core API" [Starting]
org.eclipse.ecf.filetransfer (5.0.0.v20140827-1444) "ECF Filetransfer API" [Starting]
org.eclipse.ecf.identity (3.4.0.v20140827-1444) "ECF Identity Core API" [Starting]
org.eclipse.ecf.provider.filetransfer (3.2.200.v20140827-1444) "ECF Filetransfer Provider" [Starting]
org.eclipse.ecf.provider.filetransfer.httpclient4 (1.0.800.v20140827-1444) "ECF HttpComponents Filetransfer Provider" [Starting]
org.eclipse.ecf.provider.filetransfer.httpclient4.ssl (1.0.0.v20140827-1444) "ECF HttpComponents Filetransfer Provider" [Resolved]
org.eclipse.ecf.provider.filetransfer.ssl (1.0.0.v20140827-1444) "ECF Filetransfer Provider" [Resolved]
org.eclipse.ecf.ssl (1.1.0.v20140827-1444) "ECF Core API" [Resolved]
org.eclipse.emf.common (2.10.1.v20140901-1043) "EMF Common" [Active]
org.eclipse.emf.ecore (2.10.1.v20140901-1043) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.10.0.v20140901-1043) "EMF Change Model" [Starting]
org.eclipse.emf.ecore.xmi (2.10.1.v20140901-1043) "EMF XML/XMI Persistence" [Active]
org.eclipse.equinox.app (1.3.200.v20130910-1609) "Equinox Application Container" [Active]
org.eclipse.equinox.bidi (0.10.0.v20130327-1442) "Bidirectional Text Support" [Starting]
org.eclipse.equinox.common (3.6.200.v20130402-1505) "Common Eclipse Runtime" [Active]
org.eclipse.equinox.concurrent (1.1.0.v20130327-1442) "Equinox Concurrent API" [Starting]
org.eclipse.equinox.console (1.1.0.v20140131-1639) "Console plug-in" [Active]
org.eclipse.equinox.ds (1.4.200.v20131126-2331) "Declarative Services" [Active]
org.eclipse.equinox.event (1.3.100.v20140115-1647) "Event Admin" [Active]
org.eclipse.equinox.frameworkadmin (2.0.100.v20131209-2144) "Equinox Framework Admin" [Starting]
org.eclipse.equinox.frameworkadmin.equinox (1.0.500.v20131211-1531) "Equinox Framework Admin for Equinox" [Starting]
org.eclipse.equinox.http.jetty (3.0.200.v20131021-1843) "Jetty Http Service" [Starting]
org.eclipse.equinox.http.registry (1.1.300.v20130402-1529) "Http Service Registry Extensions" [Resolved]
org.eclipse.equinox.http.servlet (1.1.500.v20140318-1755) "Http Services Servlet" [Starting]
org.eclipse.equinox.jsp.jasper (1.0.400.v20130327-1442) "Jasper Jsp Support Bundle" [Starting]
org.eclipse.equinox.jsp.jasper.registry (1.0.300.v20130327-1442) "Jasper Jsp Registry Support Plug-in" [Starting]
org.eclipse.equinox.launcher (1.3.0.v20140415-2008) "Equinox Launcher" [Resolved]
org.eclipse.equinox.launcher.win32.win32.x86 (1.1.200.v20140603-1326) "Equinox Launcher Win32 X86 Fragment" [Resolved]
org.eclipse.equinox.p2.artifact.repository (1.1.300.v20131211-1531) "Equinox Provisioning Artifact Repository Support" [Starting]
org.eclipse.equinox.p2.console (1.0.300.v20131113-1212) "Equinox Provisioning Console" [Starting]
org.eclipse.equinox.p2.core (2.3.0.v20131211-1531) "Equinox Provisioning Core" [Active]
org.eclipse.equinox.p2.director (2.3.100.v20140224-1921) "Equinox Provisioning Director" [Starting]
org.eclipse.equinox.p2.director.app (1.0.300.v20140228-1829) "Equinox Provisioning Director Application" [Starting]
org.eclipse.equinox.p2.directorywatcher (1.1.0.v20131211-1531) "Equinox Provisioning Directory Watcher" [Active]
org.eclipse.equinox.p2.engine (2.3.0.v20140506-1720) "Equinox Provisioning Engine" [Active]
org.eclipse.equinox.p2.extensionlocation (1.2.100.v20131119-0908) "Equinox Provisioning Extension Location Repository Support" [Starting]
org.eclipse.equinox.p2.garbagecollector (1.0.200.v20131115-1210) "Equinox Provisioning Garbage Collector" [Starting]
org.eclipse.equinox.p2.jarprocessor (1.0.300.v20131211-1531) "Equinox Provisioning JAR Processor" [Resolved]
org.eclipse.equinox.p2.metadata (2.2.0.v20131211-1531) "Equinox Provisioning Metadata" [Active]
org.eclipse.equinox.p2.metadata.repository (1.2.100.v20131209-2144) "Equinox Provisioning Metadata Repository" [Active]
org.eclipse.equinox.p2.operations (2.4.0.v20131119-0908) "Equinox Provisioning Operations API" [Active]
org.eclipse.equinox.p2.publisher (1.3.0.v20140911-0143) "Equinox Provisioning Publisher Infrastructure" [Starting]
org.eclipse.equinox.p2.publisher.eclipse (1.1.200.v20140414-0825) "Equinox Provisioning Publisher for Eclipse" [Starting]
org.eclipse.equinox.p2.ql (2.0.100.v20131211-1531) "Equinox Provisioning p2 query language" [Starting]
org.eclipse.equinox.p2.reconciler.dropins (1.1.200.v20131119-0908) "Equinox Provisioning Drop-in" [Active]
org.eclipse.equinox.p2.repository (2.3.0.v20131211-1531) "Equinox Provisioning Repository" [Active]
org.eclipse.equinox.p2.repository.tools (2.1.0.v20131211-1531) "Equinox Provisioning Repository Tools" [Starting]
org.eclipse.equinox.p2.touchpoint.eclipse (2.1.200.v20140512-1650) "Equinox Provisioning Eclipse Touchpoint" [Starting]
org.eclipse.equinox.p2.touchpoint.natives (1.1.100.v20140523-0116) "Equinox Provisioning Native Touchpoint" [Starting]
org.eclipse.equinox.p2.transport.ecf (1.1.0.v20140408-1354) "Equinox Provisioning ECF based Transport" [Starting]
org.eclipse.equinox.p2.ui (2.3.0.v20140404-1657) "Equinox Provisioning UI Support" [Active]
org.eclipse.equinox.p2.ui.importexport (1.1.0.v20131210-1027) "Equinox Provisioning Import and Export" [Starting]
org.eclipse.equinox.p2.ui.sdk (1.0.300.v20140407-1803) "Equinox Provisioning Platform Update Support" [Active]
org.eclipse.equinox.p2.ui.sdk.scheduler (1.2.0.v20140422-1847) "Equinox Provisioning Platform Automatic Update Support" [Active]
org.eclipse.equinox.p2.updatechecker (1.1.200.v20131119-0908) "Equinox Provisioning Update Checker" [Active]
org.eclipse.equinox.p2.updatesite (1.0.400.v20131211-1531) "Equinox Provisioning Legacy Update Site Support" [Starting]
org.eclipse.equinox.preferences (3.5.200.v20140224-1527) "Eclipse Preferences Mechanism" [Active]
org.eclipse.equinox.registry (3.5.400.v20140428-1507) "Extension Registry Support" [Active]
org.eclipse.equinox.security (1.2.0.v20130424-1801) "Equinox Java Authentication and Authorization Service (JAAS)" [Active]
org.eclipse.equinox.security.ui (1.1.200.v20130626-2037) "Equinox Security Default UI" [Starting]
org.eclipse.equinox.security.win32.x86 (1.0.300.v20130327-1442) "Windows Data Protection services integration" [Resolved]
org.eclipse.equinox.simpleconfigurator (1.1.0.v20131217-1203) "Simple Configurator" [Active]
org.eclipse.equinox.simpleconfigurator.manipulator (2.0.0.v20131217-1203) "Simple Configurator Manipulator" [Starting]
org.eclipse.equinox.util (1.0.500.v20130404-1337) "Equinox Util Bundle" [Active]
org.eclipse.gef (3.9.100.201408150207) "Graphical Editing Framework GEF" [Starting]
org.eclipse.help (3.6.0.v20130326-1254) "Help System Core" [Active]
org.eclipse.help.base (4.0.200.v20140925-0400) "Help System Base" [Starting]
org.eclipse.help.ui (4.0.100.v20140401-0608) "Help System UI" [Starting]
org.eclipse.help.webapp (3.6.300.v20140407-1855) "Help System Webapp" [Starting]
org.eclipse.jetty.continuation (8.1.14.v20131031) "Jetty :: Continuation" [Resolved]
org.eclipse.jetty.http (8.1.14.v20131031) "Jetty :: Http Utility" [Resolved]
org.eclipse.jetty.io (8.1.14.v20131031) "Jetty :: IO Utility" [Resolved]
org.eclipse.jetty.security (8.1.14.v20131031) "Jetty :: Security" [Resolved]
org.eclipse.jetty.server (8.1.14.v20131031) "Jetty :: Server Core" [Resolved]
org.eclipse.jetty.servlet (8.1.14.v20131031) "Jetty :: Servlet Handling" [Resolved]
org.eclipse.jetty.util (8.1.14.v20131031) "Jetty :: Utilities" [Resolved]
org.eclipse.jface (3.10.1.v20140813-1009) "JFace" [Active]
org.eclipse.jface.databinding (1.6.200.v20140528-1422) "JFace Data Binding for SWT and JFace" [Resolved]
org.eclipse.jface.text (3.9.1.v20140827-1810) "JFace Text" [Resolved]
org.eclipse.jsch.core (1.1.500.v20131112-1442) "JSch Core" [Starting]
org.eclipse.jsch.ui (1.1.500.v20131112-1442) "JSch UI" [Starting]
org.eclipse.ltk.core.refactoring (3.6.101.v20140817-1500) "Refactoring Core" [Active]
org.eclipse.ltk.ui.refactoring (3.7.100.v20140324-1358) "Refactoring UI" [Active]
org.eclipse.osgi (3.10.1.v20140909-1633) "OSGi System Bundle" [Active]
org.eclipse.osgi.compatibility.state (1.0.1.v20140709-1414) "Equinox State and Resolver Compatibility Fragment" [Resolved]
org.eclipse.osgi.services (3.4.0.v20140312-2051) "OSGi Release 4.2.0 Services" [Resolved]
org.eclipse.osgi.util (3.3.0.v20131023-1243) "OSGi Release 4.2.0 Utility Classes" [Resolved]
org.eclipse.platform (4.4.0.v20140925-0400) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.user (4.4.1.v20140829-1306) "Eclipse Workbench User Guide" [Resolved]
org.eclipse.rcp (4.3.100.v20140925-0400) "Eclipse RCP" [Starting]
org.eclipse.search (3.9.100.v20140226-1637) "Search Support" [Active]
org.eclipse.swt (3.103.1.v20140903-1938) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.103.1.v20140903-1947) "Standard Widget Toolkit for Windows" [Resolved]
org.eclipse.team.core (3.7.0.v20130514-1224) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.3.600.v20131112-1442) "CVS Team Provider Core" [Starting]
org.eclipse.team.cvs.ssh2 (3.2.400.v20131112-1442) "CVS SSH2" [Starting]
org.eclipse.team.cvs.ui (3.3.600.v20130514-1224) "CVS Team Provider UI" [Starting]
org.eclipse.team.ui (3.7.100.v20130710-1213) "Team Support UI" [Starting]
org.eclipse.text (3.5.300.v20130515-1451) "Text" [Resolved]
org.eclipse.ui (3.106.0.v20140812-1751) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.4.200.v20131003-1453) "Browser Support" [Active]
org.eclipse.ui.cheatsheets (3.4.200.v20131227-1524) "Cheat Sheets" [Starting]
org.eclipse.ui.console (3.5.300.v20140424-1437) "Console" [Active]
org.eclipse.ui.editors (3.8.200.v20140401-1310) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.2.300.v20140327-1949) "External Tools" [Active]
org.eclipse.ui.forms (3.6.100.v20140422-1825) "Eclipse Forms" [Active]
org.eclipse.ui.ide (3.10.1.v20140828-0944) "Eclipse IDE UI" [Active]
org.eclipse.ui.ide.application (1.0.500.v20140514-2033) "Eclipse IDE UI Application" [Resolved]
org.eclipse.ui.intro (3.4.200.v20130326-1254) "Welcome Framework" [Starting]
org.eclipse.ui.intro.universal (3.2.700.v20130904-1701) "Universal Welcome" [Starting]
org.eclipse.ui.navigator (3.5.401.v20140724-1117) "Common Navigator View" [Active]
org.eclipse.ui.navigator.resources (3.4.700.v20140407-1004) "Navigator Workbench Components" [Active]
org.eclipse.ui.net (1.2.200.v20120807-0927) "Internet Connection Management UI" [Active]
org.eclipse.ui.themes (1.0.1.v20140819-1717) "Eclipse SDK Themes" [Active]
org.eclipse.ui.views (3.7.0.v20140408-0703) "Views" [Active]
org.eclipse.ui.views.properties.tabbed (3.6.0.v20140519-0906) "Tabbed Properties View" [Starting]
org.eclipse.ui.win32 (3.2.400.v20140423-2207) "Eclipse UI Win32 Enhancements" [Resolved]
org.eclipse.ui.workbench (3.106.1.v20140827-1737) "Eclipse Workbench" [Active]
org.eclipse.ui.workbench.texteditor (3.9.0.v20140411-1521) "Text Editor Framework" [Active]
org.eclipse.update.configurator (3.3.300.v20140518-1928) "Install/Update Configurator" [Active]
org.sat4j.core (2.3.5.v201308161310) "SAT4J Core" [Resolved]
org.sat4j.pb (2.3.5.v201404071733) "SAT4J Pseudo" [Resolved]
org.w3c.css.sac (1.3.1.v200903091627) "W3C CSS SAC" [Resolved]
org.w3c.dom.events (3.0.0.draft20060413_v201105210656) "W3C DOM Level 3 Events" [Resolved]
org.w3c.dom.smil (1.0.0.v200806040011) "W3C SMIL DOM" [Resolved]
org.w3c.dom.svg (1.1.0.v201011041433) "W3C SVG DOM" [Resolved]
*** User Preferences:
#Fri Mar 13 14:35:49 EET 2015
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.keep_imple_if_on_one_line=false
/bundle_defaults/org.eclipse.debug.ui/org.eclpise.debug.ui.memory.dynamicLoad=true
/bundle_defaults/org.eclipse.core.resources/refresh.enabled=false
/bundle_defaults/org.eclipse.ui.editors/revisionRulerShowRevision=false
/bundle_defaults/org.eclipse.ui.editors/showEnclosedIdeographicSpaces=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.wait_for_build=always
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_empty_lines=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enum.enabled=false
/bundle_defaults/org.eclipse.cdt.ui/c_numbers=0,0,0
/bundle_defaults/org.eclipse.core.net/proxyData/SOCKS/port=-1
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_i2c.com.crt.advproject.projecttype.exe.1156213048/com.crt.advproject.config.exe.debug.1628265668=com.crt.advproject.gas.exe.debug.233328306\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.712719831\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.395675803\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1148277983\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1628265668\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1824689233\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.771600061\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.debug.core/org.eclipse.cdt.debug.corecDebug.default_variable_format=0
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.CappingDisable=false
/bundle_defaults/org.eclipse.cdt.ui/content_assist_default_argument_display_arguments=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_before_else_in_if_statement=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.lineSplit=80
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.build_before_launch=true
/bundle_defaults/com.crt.debugcommon/showJtagConfig=false
/bundle_defaults/org.eclipse.cdt.core/indexer/indexAllFiles=true
/bundle_defaults/org.eclipse.ui.editors/lineNumberRuler=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_can.com.crt.advproject.projecttype.exe.1549120935/com.crt.advproject.config.exe.debug.1793298790=com.crt.advproject.link.exe.debug.1086263632\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.301086546\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.1802943088\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.2001482070\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1607471089\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1793298790\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1898004798\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/com.crt.dsfdebug/restartDisabled=false
/bundle_defaults/com.crt.debugcommon/overrideSemihosting=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.overloadedOperator.enabled=false
/bundle_defaults/com.crt.debugcommon/stuboutput=server
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.detail_pane_word_wrap=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_closing_brace_in_block=insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.method.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enumerator.color=0,0,192
/bundle_defaults/org.eclipse.cdt.ui/content_assist_autoinsert=true
/bundle_defaults/org.eclipse.debug.ui/Console.wrap=false
/bundle_defaults/org.eclipse.ui.editors/changeIndicationInOverviewRuler=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/lpc_board_nxp_lpcxpresso_1769.com.crt.advproject.projecttype.lib.1078462419/com.crt.advproject.config.lib.release.207171896=com.crt.advproject.config.lib.release.207171896\=rcState\\\=-1\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.release.47261584\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.ar.lib.release.2088203039\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.release.129627712\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.release.845687461\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.release.24618102\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.overrideIndicatorColor=180,207,205
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_conditional_expression=34
/bundle_defaults/org.eclipse.cdt.ui/scalability.semanticHighlight=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_i2c.com.crt.advproject.projecttype.exe.1156213048/com.crt.advproject.config.exe.release.447110820=com.crt.advproject.gcc.exe.release.228429012\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.794665935\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.2065030373\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.107787932\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.303648522\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1909782007\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.error.color=255,0,0
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_default_inactive=false
@org.eclipse.cdt.ui=5.8.1.201409172108
/bundle_defaults/org.eclipse.cdt.ui/org.eclipse.cdt.internal.ui.text.doctools.doxygen.recognizedTag=127,159,191
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enabled=true
/bundle_defaults/com.crt.debugcommon/cmsisdap_multi_swd=false
/bundle_defaults/org.eclipse.ui.ide/MARKER_LIMITS_VALUE=100
/bundle_defaults/org.eclipse.ui.editors/spellingEngine=
/bundle_defaults/org.eclipse.ui.ide/IMPORT_FILES_AND_FOLDERS_TYPE=
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_method_declaration_parameters=do not insert
/bundle_defaults/org.eclipse.ui.ide/CLOSE_UNRELATED_PROJECTS=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enumerator.strikethrough=false
/bundle_defaults/org.eclipse.ui.editors/showErrorInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_method_invocation_arguments=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_bracket=do not insert
/instance/org.eclipse.cdt.ui/useAnnotationsPrefPage=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.namespace.italic=false
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleWrapLines=false
/bundle_defaults/org.eclipse.ui.editors/showTaskInNextPrevDropdownToolbarAction=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSISv2p00_LPC17xx.com.crt.advproject.projecttype.lib.1193160240/com.crt.advproject.config.lib.debug.1814355025=com.crt.advproject.toolchain.lib.debug.1548108302\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.1814355025\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.1004026908\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.1199056603\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.2004041978\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.1604093373\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_enabled=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS-CORE_LPC407x_8x.com.crt.advproject.projecttype.lib.1117785161/com.crt.advproject.config.lib.debug.1588975745=com.crt.advproject.toolchain.lib.debug.328928775\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.1588975745\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.775312103\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.221963309\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.1338608115\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.1509436562\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.class.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enum.bold=false
/bundle_defaults/org.eclipse.cdt.ui/spelling_ignore_sentence=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_closing_angle_bracket_in_template_arguments=insert
/bundle_defaults/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_DIALOG=true
/bundle_defaults/org.eclipse.cdt.core/indexer/useHeuristicIncludeResolution=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroDefinition.strikethrough=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_closing_paren_in_cast=insert
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_CORE_LPC8xx.com.crt.advproject.projecttype.lib.1939000741/com.crt.advproject.config.lib.debug.971437645=com.crt.advproject.cpp.lib.debug.919233593\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.971437645\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.659785245\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.65527192\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.397544059\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.597267139\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk.scheduler/schedule=on-startup
/bundle_defaults/org.eclipse.ui.editors/warningIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.warning.overview=true
/bundle_defaults/org.eclipse.ui/LINK_NAVIGATOR_TO_EDITOR=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_CORE_LPC11Uxx.com.crt.advproject.projecttype.lib.1741498279/com.crt.advproject.config.lib.debug.1849963468=com.crt.advproject.ar.lib.debug.2069571765\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.546768532\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.1398100781\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.255055000\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.1207749252\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.1849963468\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.defaultAsciiCodePage=CP1252
/bundle_defaults/com.crt.utils/wizardHome=
/bundle_defaults/org.eclipse.cdt.ui/content_assist_current_file_search_scope=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.overrideIndicatorInVerticalRuler=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.class.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/org.eclipse.cdt.ui.editor.showSegments=false
/bundle_defaults/org.eclipse.ui.workbench/REUSE_DIRTY_EDITORS=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/lwip_tcpecho_freertos.com.crt.advproject.projecttype.exe.1420589482/com.crt.advproject.config.exe.debug.590435786=com.crt.advproject.link.cpp.exe.debug.1900712405\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1420949215\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1982606965\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1047653261\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.590435786\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.800053964\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1759785151\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.workbench/perspectiveBarVisible=true
/bundle_defaults/org.eclipse.cdt.ui/spelling_ignore_upper=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_LPC18xx_DriverLib.com.crt.advproject.projecttype.lib.2008270429/com.crt.advproject.config.lib.debug.558990107=com.crt.advproject.ar.lib.debug.2089549182\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.315045615\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.410362843\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.1064384326\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.641404760\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.558990107\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/secondaryIPTextStyle=NONE
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariable.italic=false
/bundle_defaults/org.eclipse.ui.workbench/OPEN_PERSPECTIVE_MODE=0
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.test.prefix=
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_timer.com.crt.advproject.projecttype.exe.1309499312/com.crt.advproject.config.exe.release.2130611758=com.crt.advproject.toolchain.exe.release.371298027\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.788026692\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1944172024\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.215350013\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1560242080\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.557206652\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.debug.ui/Console.width=80
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.systemWithoutExtension=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style angle_brackets\="true" blank_line_before\="false" keep_together\="true" order\="2" relative_path\="false"/>
/bundle_defaults/org.eclipse.ui.editors/printMarginColor=176,180,185
/bundle_defaults/org.eclipse.ui.editors/linked.focus.color=50,70,120
/bundle_defaults/org.eclipse.cdt.ui/forwardDeclare.namespaceElements=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/lpc_chip_175x_6x.com.crt.advproject.projecttype.lib.1977998334/com.crt.advproject.config.lib.release.748848757=com.crt.advproject.gas.lib.release.1568034180\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.release.1757629049\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.release.748848757\=rcState\\\=-1\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.release.1488485948\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.lib.release.474949157\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.release.199714480\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/com.crt.dsfdebug/debuggerPathFix=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_base_types=do not insert
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.field.prefix=
/bundle_defaults/org.eclipse.cdt.ui/autoIndent=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/usbd_lib_hid_mouse.com.crt.advproject.projecttype.exe.1164772426/com.crt.advproject.config.exe.release.682907672=com.crt.advproject.link.cpp.exe.release.1811715833\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.918384092\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1175370789\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.1615735383\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.775007655\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1088698866\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/c_string_italic=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_declaration_compare_to_template_header=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_uart_rb.com.crt.advproject.projecttype.exe.1950633819/com.crt.advproject.config.exe.debug.1365584524=com.crt.advproject.toolchain.exe.debug.1113849227\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.1843758335\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1334949695\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.38449263\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.386306012\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.47576862\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1365584524\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/filteredSearchResultIndicationColor=237,237,252
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.error.ruler=true
/bundle_defaults/org.eclipse.debug.ui/Breakpoints.detail.orientation=Variables.detail.orientation.underneath
/bundle_defaults/org.eclipse.ui.editors/currentIPColor=198,219,174
@org.eclipse.core.net=1.2.200.v20140124-2013
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.warning.textstyle=SQUIGGLES
/bundle_defaults/org.eclipse.cdt.ui/scalability.enableAll=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.consoleBackground=255,255,255
/bundle_defaults/org.eclipse.cdt.ui/c_numbers_bold=false
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.UseSingleLine=true
/bundle_defaults/org.eclipse.ui.workbench/DISABLE_DIALOG_FONT=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_block=end_of_line
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.test.capitalization=0
/bundle_defaults/org.eclipse.ui.editors/linked.slave.overviewruler=false
/bundle_defaults/org.eclipse.cdt.dsf.gdb/defaultStopAtMain=true
/bundle_defaults/org.eclipse.ui.editors/indexResultIndicationInVerticalRuler=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/freertos_blinky.com.crt.advproject.projecttype.exe.1693076455/com.crt.advproject.config.exe.debug.897255787=com.crt.advproject.link.exe.debug.1302659769\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1225049255\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.24640360\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.272389732\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.897255787\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.51313821\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.475703418\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_angle_bracket_in_template_arguments=do not insert
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.occurrenceIndicationInOverviewRuler=true
/bundle_defaults/com.crt.debugcommon/debuggerInit=
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.function.bold=true
@org.eclipse.cdt.dsf.ui=2.4.100.201409172108
/bundle_defaults/org.eclipse.ui.editors/taskIndicationHighlighting=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.field.capitalization=4
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_binary_operator=insert
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.source.suffix=.cpp
/bundle_defaults/org.eclipse.cdt.ui/asm_label_italic=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.ExpressionView+org.eclipse.debug.ui.ShowDetailPaneAction=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/usbd_lib_hid_keyboard.com.crt.advproject.projecttype.exe.944853395/com.crt.advproject.config.exe.debug.234199146=com.crt.advproject.config.exe.debug.234199146\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1056025160\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1144847496\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1535204238\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.47077161\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.1096740313\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1947046434\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/isChangeGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/secondaryIPHighlight=true
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.variable.prefix=
/bundle_defaults/org.eclipse.ui.editors/linked.slave.navigation.dropdown=false
/bundle_defaults/org.eclipse.ui.editors/showLeadingIdeographicSpaces=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.continuation_indentation_for_array_initializer=2
/bundle_defaults/org.eclipse.cdt.debug.core/org.eclipse.cdt.debug.corecDebug.default_expression_format=0
/instance/org.eclipse.cdt.dsf.ui/useAnnotationsPrefPage=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.functionDeclaration.enabled=true
/bundle_defaults/org.eclipse.cdt.ui/content_assist_prefix_completion=true
/bundle_defaults/com.crt.debugcommon/redlink_server_shutdown=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_semicolon_in_for=insert
/bundle_defaults/org.eclipse.cdt.core/build.all.configs.enabled=false
/bundle_defaults/org.eclipse.cdt.core/indexer/skipImplicitReferences=false
/bundle_defaults/com.crt.debugcommon/debuggerTimeout=10
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.maxIndexDBCacheSizeMB=64
/bundle_defaults/org.eclipse.ui/presentationFactoryId=org.eclipse.ui.presentations.default
/bundle_defaults/org.eclipse.ui.editors/Accessibility.UseSaturatedColors=false
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Accessibility.UseCustomCarets=true
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.RemovedLinesRegex=
/bundle_defaults/org.eclipse.cdt.core/includes.endExportsPattern=IWYU\\s+(pragma\:?\\s+)?end_exports?
/bundle_defaults/org.eclipse.cdt.dsf.gdb/org.eclipse.cdt.dsf.gdb.useRtti=true
/bundle_defaults/org.eclipse.ui.editors/spellingEnabled=true
/bundle_defaults/org.eclipse.cdt.dsf.gdb/defaultNonStop=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.typedef.enabled=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_for=do not insert
/bundle_defaults/org.eclipse.debug.ui/Console.lowWaterMark=80000
/bundle_defaults/org.eclipse.ui.editors/showLeadingSpaces=true
/bundle_defaults/org.eclipse.ui.editors/linked.target.color=170,185,220
/bundle_defaults/org.eclipse.ui.ide/BOOKMARKS_LIMIT=100
/bundle_defaults/org.eclipse.ui.editors/isIndexResultGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.dsf.gdb/org.eclipse.cdt.dsf.gdb.aggressiveBpFilter=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.externalSDK.enabled=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.warning.GoToPreviousNavigationTarget=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_assignment_operator=insert
/instance/org.eclipse.cdt.managedbuilder.core/properties/lpcusblib_KeyboardHost.com.crt.advproject.projecttype.exe.1776494588/com.crt.advproject.config.exe.debug.332576409=com.crt.advproject.cpp.exe.debug.1763337745\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1794156581\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.547450235\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.39850578\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.578710282\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.153195668\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.332576409\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.changedDebugElement=255,0,0
@org.eclipse.debug.core=3.9.1.v20140805-1629
/bundle_defaults/org.eclipse.ui.editors/showInfoInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.cdt.ui/pp_default_italic=false
/bundle_defaults/org.eclipse.ui.editors/spellingIndication=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.problem.color=224,0,0
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_unary_operator=do not insert
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.PathFilter=
/bundle_defaults/org.eclipse.ui.editors/isFilteredSearchResultGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.methodDeclaration.strikethrough=false
/bundle_defaults/org.eclipse.ui.editors/bookmarkIndicationColor=34,164,99
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_while=insert
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.other=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style blank_line_before\="true" keep_together\="true" order\="3"/>
/bundle_defaults/com.crt.debugcommon/LPC-Link\ (WinUSB)\ or\ RDB-Link=true
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_default_structures=false
/bundle_defaults/org.eclipse.cdt.ui/c_multi_line_comment_italic=false
/bundle_defaults/org.eclipse.ui.editors/hyperlinkKeyModifierMask=262144
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.overloadedOperator.underline=false
/bundle_defaults/org.eclipse.ui.editors/isDeletionGoToNextNavigationTarget=false
/instance/org.eclipse.ui.ide/platformState=1426237440991
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.max_history_size=10
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_colon_in_labeled_statement=do not insert
/bundle_defaults/com.crt.debugcommon/redlink_boot_state=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_statements_compare_to_block=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.activate_debug_view=true
@org.eclipse.ui.browser=3.4.200.v20131003-1453
/bundle_defaults/org.eclipse.ui/DOCK_PERSPECTIVE_BAR=topLeft
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_blinky.com.crt.advproject.projecttype.exe.424940172/com.crt.advproject.config.exe.release.835156494=com.crt.advproject.gcc.exe.release.1591236150\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.release.1645349510\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.298607713\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.543793768\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.318297782\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1446495013\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.release.835156494\=rcState\\\=-1\\r\\nrebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_parenthesized_expression=do not insert
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.error.text=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_catch=insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.label.enabled=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_ritimer.com.crt.advproject.projecttype.exe.749237195/com.crt.advproject.config.exe.release.1763634750=com.crt.advproject.gas.exe.release.936462419\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.189745666\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1063923478\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1679678845\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.1550794809\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1411309420\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.workbench/REUSE_OPEN_EDITORS=8
/bundle_defaults/org.eclipse.cdt.ui/markOverloadedOperatorsOccurrences=false
/bundle_defaults/org.eclipse.ui.editors/linked.slave.highlight=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.join_wrapped_lines=true
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.source.capitalization=0
/instance/org.eclipse.cdt.managedbuilder.core/properties/iperf_server.com.crt.advproject.projecttype.exe.1230739403/com.crt.advproject.config.exe.debug.1512339721=com.crt.advproject.toolchain.exe.debug.380405632\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.387641087\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.463030857\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.51870270\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.472993163\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.762089801\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1512339721\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/forwardDeclare.externalVariables=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_exception_specification=do not insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroSubstitution.strikethrough=false
/bundle_defaults/org.eclipse.debug.core/org.eclipse.debug.core.PREF_BREAKPOINT_MANAGER_ENABLED_STATE=true
/bundle_defaults/org.eclipse.ui.editors/overviewRuler=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.namespace.enabled=false
/bundle_defaults/org.eclipse.ui.editors/additionIndicationColor=188,188,222
/bundle_defaults/org.eclipse.cdt.ui/c_string=42,0,255
/bundle_defaults/org.eclipse.debug.ui/Registers.detail.orientation=Variables.detail.orientation.underneath
/bundle_defaults/org.eclipse.cdt.ui/organizeIncludes.allowPartnerIndirectInclusion=true
/bundle_defaults/org.eclipse.ui.editors/com.crt.etmetb.marker.profile.pref.high=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.isOccurrenceGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.templateParameter.bold=true
/bundle_defaults/org.eclipse.cdt.debug.core/org.eclipse.cdt.debug.corecDebug.default_register_format=0
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroSubstitution.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.function.strikethrough=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.writeOccurrenceIndicationColor=240,216,168
/bundle_defaults/org.eclipse.ui.ide/EXIT_PROMPT_ON_CLOSE_LAST_WINDOW=true
/bundle_defaults/org.eclipse.ui.editors/printMargin=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_ssp.com.crt.advproject.projecttype.exe.2073917783/com.crt.advproject.config.exe.debug.132243330=com.crt.advproject.config.exe.debug.132243330\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1276505785\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1415199486\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.670756160\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.2080663046\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1855615787\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.425397908\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.constant.wordDelimiter=_
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_template_arguments=insert
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.errorColor=255,0,0
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.taskTags=TODO,FIXME,XXX
/bundle_defaults/org.eclipse.ui.editors/isSpellingGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.ui/spelling_problems_threshold=100
/bundle_defaults/org.eclipse.cdt.ui/content_assist_default_argument_display_parameters_with_default_argument=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariable.color=0,0,0
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.codeReaderCache=64
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariableDeclaration.italic=false
/bundle_defaults/org.eclipse.ui.editors/revisionAnnotationIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.partner=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style angle_brackets\="false" blank_line_before\="true" keep_together\="true" order\="0" relative_path\="false"/>
/bundle_defaults/org.eclipse.cdt.ui/subWordNavigation=true
/bundle_defaults/org.eclipse.debug.ui/DEBUG.consoleOpenOnOut=true
/bundle_defaults/org.eclipse.cdt.ui/asm_directive=127,0,85
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.error.NextPrevDropdownToolbar=true
/bundle_defaults/org.eclipse.cdt.ui/org.eclipse.cdt.ui.editor.linkToEditor=false
/bundle_defaults/org.eclipse.ui.editors/linked.slave.navigation.next=false
/bundle_defaults/org.eclipse.ui.editors/isErrorGoToPreviousNavigationTarget=true
/configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_DIALOG=true
/bundle_defaults/org.eclipse.ui.editors/linked.focus.navigation.previous=false
/bundle_defaults/org.eclipse.cdt.ui/content_assist_parameters_background=255,255,255
/instance/org.eclipse.debug.core//org.eclipse.debug.core.PREFERRED_DELEGATES/org.eclipse.cdt.launch.applicationLaunchType=org.eclipse.cdt.dsf.gdb.launch.localCLaunch,debug,;org.eclipse.cdt.cdi.launch.localCLaunch,run,;
/bundle_defaults/org.eclipse.cdt.ui/asm_directive_italic=false
/bundle_defaults/org.eclipse.core.net/nonProxiedHosts=localhost|127.0.0.1
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_before_while_in_do_statement=do not insert
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.external=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style angle_brackets\="false" blank_line_before\="false" keep_together\="false" relative_path\="false"/>
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.reuse_editor=true
/bundle_defaults/org.eclipse.ui.ide/IMPORT_FILES_AND_FOLDERS_MODE=prompt
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.codeBytesColor=96,0,0
/bundle_defaults/org.eclipse.cdt.core/indexer/indexAllHeaderVersions=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.functionDeclaration.strikethrough=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_CORE_LPC13Uxx.com.crt.advproject.projecttype.lib.273512484/com.crt.advproject.config.lib.debug.673940478=com.crt.advproject.gas.lib.debug.198052387\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.847974778\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.2129923167\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.673940478\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.2123539662\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.1540782685\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.class.italic=false
/bundle_defaults/org.eclipse.ui.editors/breakpointIndicationInOverviewRuler=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_access_specifier_extra_spaces=0
/bundle_defaults/org.eclipse.ui.editors/showSearchResultInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.templateParameter.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/includes.partnerFileSuffixes=test,unittest
/bundle_defaults/org.eclipse.ui/SHOW_OPEN_ON_PERSPECTIVE_BAR=true
/bundle_defaults/org.eclipse.cdt.ui/pp_default_bold=false
/bundle_defaults/org.eclipse.ui.editors/spellingIndicationHighlighting=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.overrideIndicatorInOverviewRuler=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.namespace.underline=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.outColor=0,0,0
/bundle_defaults/org.eclipse.core.resources/description.applyfilestatepolicy=true
/bundle_defaults/org.eclipse.ui.editors/taskTextStyle=SQUIGGLES
/bundle_defaults/com.crt.debugcommon/redlink_kill_exit=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_bracket=do not insert
/bundle_defaults/org.eclipse.ui.ide/SYSTEM_EXPLORER=explorer /E,/select\=${selected_resource_loc}
/bundle_defaults/com.crt.debugcommon/displayAsyncErrors=true
/bundle_defaults/org.eclipse.ui.editors/infoIndicationColor=244,200,45
/bundle_defaults/com.crt.utils/quickstart.navstate=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroDefinition.enabled=false
/bundle_defaults/org.eclipse.ui.editors/filteredSearchResultTextStyle=SQUIGGLES
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.comment.never_indent_line_comments_on_first_column=true
/bundle_defaults/org.eclipse.ui.editors/quickdiff.nowarn.before.switch=
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_array_initializer=end_of_line
/bundle_defaults/org.eclipse.ui.editors/hoverReplaceMode=0
/bundle_defaults/org.eclipse.cdt.core/indexer/skipReferences=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.skip_breakpoints_during_run_to_line=false
/bundle_defaults/org.eclipse.cdt.dsf.ui/stackFrameLimit=10
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.keep_empty_array_initializer_on_one_line=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_before_identifier_in_function_declaration=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_colon_in_conditional=insert
/instance/org.eclipse.core.net/org.eclipse.core.net.hasMigrated=true
/bundle_defaults/org.eclipse.cdt.ui/content_assist_parameters_foreground=0,0,0
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.problem.italic=false
/bundle_defaults/org.eclipse.ui.editors/linked.exit.verticalruler=false
/bundle_defaults/com.crt.debugcommon/genericImageXP=LPCXpressoWIN.enc
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.tabulation.size=4
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticField.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.externalSDK.bold=true
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.endAddress=0x10000000000000000
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.typedef.color=0,80,50
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_between_empty_parens_in_method_declaration=do not insert
/bundle_defaults/com.crt.debugcommon/redlink_experimental=false
/bundle_defaults/org.eclipse.ui.editors/linked.target.navigation.dropdown=false
/bundle_defaults/org.eclipse.ui.editors/isIndexResultGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/showWhitespaceCharacters=false
/bundle_defaults/com.crt.utils/directories.bin=C\:\\nxp\\LPCXpresso_7.6.2_326\\lpcxpresso\\bin;C\:\\nxp\\LPCXpresso_7.6.2_326\\lpcxpresso\\msys\\bin;C\:\\nxp\\LPCXpresso_7.6.2_326\\lpcxpresso\\tools\\bin;
/bundle_defaults/com.crt.debugcommon/CMSIS-DAP=true
/bundle_defaults/org.eclipse.cdt.ui/org.eclipse.cdt.ui.editor.CUChildren=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_between_empty_braces_in_array_initializer=do not insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.functionDeclaration.color=0,0,0
/bundle_defaults/org.eclipse.ui.editors/indexResultIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.cdt.ui/smartPaste=true
/bundle_defaults/org.eclipse.ui/ENABLE_DETACHED_VIEWS=true
/bundle_defaults/org.eclipse.ui.editors/bookmarkIndicationInVerticalRuler=true
/bundle_defaults/org.eclipse.debug.ui/org.eclispe.debug.ui.memory.preBufferSize=20
/bundle_defaults/com.crt.advproject/multicoreslavetemplate=arm-none-eabi-objcopy --target elf32-littlearm --verbose --strip-all --redefine-sym %3$s\=%3$s%4$s --keep-symbol %3$s%4$s %2$s"%1$s" "%1$s.o"
/bundle_defaults/org.eclipse.ui.editors/taskIndicationInVerticalRuler=true
/bundle_defaults/org.eclipse.debug.ui/Modules.detail.orientation=Variables.detail.orientation.underneath
/bundle_defaults/org.eclipse.ui.workbench/TEXT_DIRECTION=
/bundle_defaults/org.eclipse.cdt.ui/content_assist_proposals_background=255,255,255
/bundle_defaults/org.eclipse.cdt.ui/organizeIncludes.headerSubstitution=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<maps>\r\n<map cpp_only\="false" name\="GCC C Header Substitution">\r\n<unconditional_substitution_map>\r\n<mapping key\="&lt;asm/errno.h&gt;" value\="&lt;errno.h&gt;"/>\r\n<mapping key\="&lt;asm/errno-base.h&gt;" value\="&lt;errno.h&gt;"/>\r\n<mapping key\="&lt;asm/ioctls.h&gt;" value\="&lt;sys/ioctl.h&gt;"/>\r\n<mapping key\="&lt;asm/posix_types_32.h&gt;" value\="&lt;asm/posix_types.h&gt;"/>\r\n<mapping key\="&lt;asm/posix_types_64.h&gt;" value\="&lt;asm/posix_types.h&gt;"/>\r\n<mapping key\="&lt;asm/ptrace-abi.h&gt;" value\="&lt;asm/ptrace.h&gt;"/>\r\n<mapping key\="&lt;asm/socket.h&gt;" value\="&lt;sys/socket.h&gt;"/>\r\n<mapping key\="&lt;asm/unistd.h&gt;" value\="&lt;syscall.h&gt;"/>\r\n<mapping key\="&lt;asm/unistd_32.h&gt;" value\="&lt;syscall.h&gt;"/>\r\n<mapping key\="&lt;asm/unistd_64.h&gt;" value\="&lt;syscall.h&gt;"/>\r\n<mapping key\="&lt;bits/a.out.h&gt;" value\="&lt;a.out.h&gt;"/>\r\n<mapping key\="&lt;bits/byteswap.h&gt;" value\="&lt;byteswap.h&gt;"/>\r\n<mapping key\="&lt;bits/cmathcalls.h&gt;" value\="&lt;complex.h&gt;"/>\r\n<mapping key\="&lt;bits/confname.h&gt;" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="&lt;bits/dirent.h&gt;" value\="&lt;dirent.h&gt;"/>\r\n<mapping key\="&lt;bits/dlfcn.h&gt;" value\="&lt;dlfcn.h&gt;"/>\r\n<mapping key\="&lt;bits/elfclass.h&gt;" value\="&lt;link.h&gt;"/>\r\n<mapping key\="&lt;bits/endian.h&gt;" value\="&lt;endian.h&gt;"/>\r\n<mapping key\="&lt;bits/environments.h&gt;" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="&lt;bits/errno.h&gt;" value\="&lt;errno.h&gt;"/>\r\n<mapping key\="&lt;bits/error.h&gt;" value\="&lt;error.h&gt;"/>\r\n<mapping key\="&lt;bits/fcntl.h&gt;" value\="&lt;fcntl.h&gt;"/>\r\n<mapping key\="&lt;bits/fcntl-linux.h&gt;" value\="&lt;fcntl.h&gt;"/>\r\n<mapping key\="&lt;bits/fcntl2.h&gt;" value\="&lt;fcntl.h&gt;"/>\r\n<mapping key\="&lt;bits/fenv.h&gt;" value\="&lt;fenv.h&gt;"/>\r\n<mapping key\="&lt;bits/fenvinline.h&gt;" value\="&lt;fenv.h&gt;"/>\r\n<mapping key\="&lt;bits/huge_val.h&gt;" value\="&lt;math.h&gt;"/>\r\n<mapping key\="&lt;bits/huge_valf.h&gt;" value\="&lt;math.h&gt;"/>\r\n<mapping key\="&lt;bits/huge_vall.h&gt;" value\="&lt;math.h&gt;"/>\r\n<mapping key\="&lt;bits/in.h&gt;" value\="&lt;netinet/in.h&gt;"/>\r\n<mapping key\="&lt;bits/inf.h&gt;" value\="&lt;math.h&gt;"/>\r\n<mapping key\="&lt;bits/ioctl-types.h&gt;" value\="&lt;sys/ioctl.h&gt;"/>\r\n<mapping key\="&lt;bits/ioctls.h&gt;" value\="&lt;sys/ioctl.h&gt;"/>\r\n<mapping key\="&lt;bits/ipc.h&gt;" value\="&lt;sys/ipc.h&gt;"/>\r\n<mapping key\="&lt;bits/ipctypes.h&gt;" value\="&lt;sys/ipc.h&gt;"/>\r\n<mapping key\="&lt;bits/libio-ldbl.h&gt;" value\="&lt;libio.h&gt;"/>\r\n<mapping key\="&lt;bits/link.h&gt;" value\="&lt;link.h&gt;"/>\r\n<mapping key\="&lt;bits/locale.h&gt;" value\="&lt;locale.h&gt;"/>\r\n<mapping key\="&lt;bits/mathcalls.h&gt;" value\="&lt;math.h&gt;"/>\r\n<mapping key\="&lt;bits/mathdef.h&gt;" value\="&lt;math.h&gt;"/>\r\n<mapping key\="&lt;bits/mathinline.h&gt;" value\="&lt;math.h&gt;"/>\r\n<mapping key\="&lt;bits/mman.h&gt;" value\="&lt;sys/mman.h&gt;"/>\r\n<mapping key\="&lt;bits/monetary-ldbl.h&gt;" value\="&lt;monetary.h&gt;"/>\r\n<mapping key\="&lt;bits/mqueue.h&gt;" value\="&lt;mqueue.h&gt;"/>\r\n<mapping key\="&lt;bits/mqueue2.h&gt;" value\="&lt;mqueue.h&gt;"/>\r\n<mapping key\="&lt;bits/msq.h&gt;" value\="&lt;sys/msg.h&gt;"/>\r\n<mapping key\="&lt;bits/nan.h&gt;" value\="&lt;math.h&gt;"/>\r\n<mapping key\="&lt;bits/netdb.h&gt;" value\="&lt;netdb.h&gt;"/>\r\n<mapping key\="&lt;bits/poll.h&gt;" value\="&lt;poll.h&gt;"/>\r\n<mapping key\="&lt;bits/posix_opt.h&gt;" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="&lt;bits/posix1_lim.h&gt;" value\="&lt;limits.h&gt;"/>\r\n<mapping key\="&lt;bits/posix2_lim.h&gt;" value\="&lt;limits.h&gt;"/>\r\n<mapping key\="&lt;bits/predefs.h&gt;" value\="&lt;features.h&gt;"/>\r\n<mapping key\="&lt;bits/printf-ldbl.h&gt;" value\="&lt;printf.h&gt;"/>\r\n<mapping key\="&lt;bits/pthreadtypes.h&gt;" value\="&lt;pthread.h&gt;"/>\r\n<mapping key\="&lt;bits/resource.h&gt;" value\="&lt;sys/resource.h&gt;"/>\r\n<mapping key\="&lt;bits/sched.h&gt;" value\="&lt;sched.h&gt;"/>\r\n<mapping key\="&lt;bits/select.h&gt;" value\="&lt;sys/select.h&gt;"/>\r\n<mapping key\="&lt;bits/sem.h&gt;" value\="&lt;sys/sem.h&gt;"/>\r\n<mapping key\="&lt;bits/semaphore.h&gt;" value\="&lt;semaphore.h&gt;"/>\r\n<mapping key\="&lt;bits/setjmp.h&gt;" value\="&lt;setjmp.h&gt;"/>\r\n<mapping key\="&lt;bits/shm.h&gt;" value\="&lt;sys/shm.h&gt;"/>\r\n<mapping key\="&lt;bits/sigaction.h&gt;" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="&lt;bits/sigcontext.h&gt;" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="&lt;bits/siginfo.h&gt;" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="&lt;bits/signum.h&gt;" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="&lt;bits/sigset.h&gt;" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="&lt;bits/sigstack.h&gt;" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="&lt;bits/sigthread.h&gt;" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="&lt;bits/sockaddr.h&gt;" value\="&lt;sys/un.h&gt;"/>\r\n<mapping key\="&lt;bits/socket.h&gt;" value\="&lt;sys/socket.h&gt;"/>\r\n<mapping key\="&lt;bits/stab.def&gt;" value\="&lt;stab.h&gt;"/>\r\n<mapping key\="&lt;bits/stat.h&gt;" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="&lt;bits/statfs.h&gt;" value\="&lt;sys/statfs.h&gt;"/>\r\n<mapping key\="&lt;bits/statvfs.h&gt;" value\="&lt;sys/statvfs.h&gt;"/>\r\n<mapping key\="&lt;bits/stdio.h&gt;" value\="&lt;stdio.h&gt;"/>\r\n<mapping key\="&lt;bits/stdio_lim.h&gt;" value\="&lt;stdio.h&gt;"/>\r\n<mapping key\="&lt;bits/stdio-ldbl.h&gt;" value\="&lt;stdio.h&gt;"/>\r\n<mapping key\="&lt;bits/stdio-lock.h&gt;" value\="&lt;libio.h&gt;"/>\r\n<mapping key\="&lt;bits/stdio2.h&gt;" value\="&lt;stdio.h&gt;"/>\r\n<mapping key\="&lt;bits/stdlib.h&gt;" value\="&lt;stdlib.h&gt;"/>\r\n<mapping key\="&lt;bits/stdlib-ldbl.h&gt;" value\="&lt;stdlib.h&gt;"/>\r\n<mapping key\="&lt;bits/string.h&gt;" value\="&lt;string.h&gt;"/>\r\n<mapping key\="&lt;bits/string2.h&gt;" value\="&lt;string.h&gt;"/>\r\n<mapping key\="&lt;bits/string3.h&gt;" value\="&lt;string.h&gt;"/>\r\n<mapping key\="&lt;bits/stropts.h&gt;" value\="&lt;stropts.h&gt;"/>\r\n<mapping key\="&lt;bits/sys_errlist.h&gt;" value\="&lt;stdio.h&gt;"/>\r\n<mapping key\="&lt;bits/syscall.h&gt;" value\="&lt;syscall.h&gt;"/>\r\n<mapping key\="&lt;bits/syslog.h&gt;" value\="&lt;syslog.h&gt;"/>\r\n<mapping key\="&lt;bits/syslog-ldbl.h&gt;" value\="&lt;syslog.h&gt;"/>\r\n<mapping key\="&lt;bits/syslog-path.h&gt;" value\="&lt;syslog.h&gt;"/>\r\n<mapping key\="&lt;bits/termios.h&gt;" value\="&lt;termios.h&gt;"/>\r\n<mapping key\="&lt;bits/time.h&gt;" value\="&lt;sys/time.h&gt;"/>\r\n<mapping key\="&lt;bits/types.h&gt;" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="&lt;bits/uio.h&gt;" value\="&lt;sys/uio.h&gt;"/>\r\n<mapping key\="&lt;bits/unistd.h&gt;" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="&lt;bits/ustat.h&gt;" value\="&lt;ustat.h&gt;"/>\r\n<mapping key\="&lt;bits/utmp.h&gt;" value\="&lt;utmp.h&gt;"/>\r\n<mapping key\="&lt;bits/utmpx.h&gt;" value\="&lt;utmpx.h&gt;"/>\r\n<mapping key\="&lt;bits/utsname.h&gt;" value\="&lt;sys/utsname.h&gt;"/>\r\n<mapping key\="&lt;bits/waitflags.h&gt;" value\="&lt;sys/wait.h&gt;"/>\r\n<mapping key\="&lt;bits/waitstatus.h&gt;" value\="&lt;sys/wait.h&gt;"/>\r\n<mapping key\="&lt;bits/wchar.h&gt;" value\="&lt;wchar.h&gt;"/>\r\n<mapping key\="&lt;bits/wchar-ldbl.h&gt;" value\="&lt;wchar.h&gt;"/>\r\n<mapping key\="&lt;bits/wchar2.h&gt;" value\="&lt;wchar.h&gt;"/>\r\n<mapping key\="&lt;bits/xopen_lim.h&gt;" value\="&lt;limits.h&gt;"/>\r\n<mapping key\="&lt;bits/xtitypes.h&gt;" value\="&lt;stropts.h&gt;"/>\r\n<mapping key\="&lt;linux/errno.h&gt;" value\="&lt;errno.h&gt;"/>\r\n<mapping key\="&lt;linux/limits.h&gt;" value\="&lt;limits.h&gt;"/>\r\n<mapping key\="&lt;linux/socket.h&gt;" value\="&lt;sys/socket.h&gt;"/>\r\n<mapping key\="&lt;sys/poll.h&gt;" value\="&lt;poll.h&gt;"/>\r\n<mapping key\="&lt;sys/syscall.h&gt;" value\="&lt;syscall.h&gt;"/>\r\n<mapping key\="&lt;sys/syslog.h&gt;" value\="&lt;syslog.h&gt;"/>\r\n<mapping key\="&lt;sys/ucontext.h&gt;" value\="&lt;ucontext.h&gt;"/>\r\n<mapping key\="&lt;sys/ustat.h&gt;" value\="&lt;ustat.h&gt;"/>\r\n<mapping key\="&lt;wait.h&gt;" value\="&lt;sys/wait.h&gt;"/>\r\n</unconditional_substitution_map>\r\n<optional_substitution_map/>\r\n</map>\r\n<map cpp_only\="true" name\="GCC C++ Header Substitution">\r\n<unconditional_substitution_map>\r\n<mapping key\="&lt;auto_ptr.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;backward/auto_ptr.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;backward/binders.h&gt;" value\="&lt;functional&gt;"/>\r\n<mapping key\="&lt;backward/hash_fun.h&gt;" value\="&lt;hash_map&gt;"/>\r\n<mapping key\="&lt;backward/hash_fun.h&gt;" value\="&lt;hash_set&gt;"/>\r\n<mapping key\="&lt;backward/hashtable.h&gt;" value\="&lt;hash_map&gt;"/>\r\n<mapping key\="&lt;backward/hashtable.h&gt;" value\="&lt;hash_set&gt;"/>\r\n<mapping key\="&lt;backward/strstream&gt;" value\="&lt;strstream&gt;"/>\r\n<mapping key\="&lt;binders.h&gt;" value\="&lt;functional&gt;"/>\r\n<mapping key\="&lt;bits/algorithmfwd.h&gt;" value\="&lt;algorithm&gt;"/>\r\n<mapping key\="&lt;bits/allocator.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;bits/atomic_word.h&gt;" value\="&lt;ext/atomicity.h&gt;"/>\r\n<mapping key\="&lt;bits/basic_file.h&gt;" value\="&lt;fstream&gt;"/>\r\n<mapping key\="&lt;bits/basic_ios.h&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;bits/basic_string.h&gt;" value\="&lt;string&gt;"/>\r\n<mapping key\="&lt;bits/basic_string.tcc&gt;" value\="&lt;string&gt;"/>\r\n<mapping key\="&lt;bits/boost_concept_check.h&gt;" value\="&lt;bits/concept_check.h&gt;"/>\r\n<mapping key\="&lt;bits/boost_sp_shared_count.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;bits/c++allocator.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;bits/c++config.h&gt;" value\="&lt;cstddef&gt;"/>\r\n<mapping key\="&lt;bits/c++io.h&gt;" value\="&lt;ext/stdio_sync_filebuf.h&gt;"/>\r\n<mapping key\="&lt;bits/char_traits.h&gt;" value\="&lt;string&gt;"/>\r\n<mapping key\="&lt;bits/cmath.tcc&gt;" value\="&lt;cmath&gt;"/>\r\n<mapping key\="&lt;bits/codecvt.h&gt;" value\="&lt;fstream&gt;"/>\r\n<mapping key\="&lt;bits/codecvt.h&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/ctype_base.h&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/ctype_base.h&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;bits/ctype_inline.h&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/ctype_inline.h&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;bits/cxxabi_tweaks.h&gt;" value\="&lt;cxxabi.h&gt;"/>\r\n<mapping key\="&lt;bits/deque.tcc&gt;" value\="&lt;deque&gt;"/>\r\n<mapping key\="&lt;bits/exception_defines.h&gt;" value\="&lt;exception&gt;"/>\r\n<mapping key\="&lt;bits/fstream.tcc&gt;" value\="&lt;fstream&gt;"/>\r\n<mapping key\="&lt;bits/functexcept.h&gt;" value\="&lt;algorithm&gt;"/>\r\n<mapping key\="&lt;bits/functional_hash.h&gt;" value\="&lt;unordered_map&gt;"/>\r\n<mapping key\="&lt;bits/gslice.h&gt;" value\="&lt;valarray&gt;"/>\r\n<mapping key\="&lt;bits/gslice_array.h&gt;" value\="&lt;valarray&gt;"/>\r\n<mapping key\="&lt;bits/hashtable.h&gt;" value\="&lt;unordered_map&gt;"/>\r\n<mapping key\="&lt;bits/hashtable.h&gt;" value\="&lt;unordered_set&gt;"/>\r\n<mapping key\="&lt;bits/indirect_array.h&gt;" value\="&lt;valarray&gt;"/>\r\n<mapping key\="&lt;bits/ios_base.h&gt;" value\="&lt;iostream&gt;"/>\r\n<mapping key\="&lt;bits/ios_base.h&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;bits/ios_base.h&gt;" value\="&lt;iomanip&gt;"/>\r\n<mapping key\="&lt;bits/istream.tcc&gt;" value\="&lt;istream&gt;"/>\r\n<mapping key\="&lt;bits/list.tcc&gt;" value\="&lt;list&gt;"/>\r\n<mapping key\="&lt;bits/locale_classes.h&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/locale_classes.h&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;bits/locale_classes.tcc&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/locale_classes.tcc&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;bits/locale_facets.h&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/locale_facets.h&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;bits/locale_facets.tcc&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/locale_facets.tcc&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;bits/locale_facets_nonio.h&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/locale_facets_nonio.tcc&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/localefwd.h&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/mask_array.h&gt;" value\="&lt;valarray&gt;"/>\r\n<mapping key\="&lt;bits/messages_members.h&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/move.h&gt;" value\="&lt;algorithm&gt;"/>\r\n<mapping key\="&lt;bits/ostream.tcc&gt;" value\="&lt;ostream&gt;"/>\r\n<mapping key\="&lt;bits/ostream_insert.h&gt;" value\="&lt;ostream&gt;"/>\r\n<mapping key\="&lt;bits/postypes.h&gt;" value\="&lt;iostream&gt;"/>\r\n<mapping key\="&lt;bits/postypes.h&gt;" value\="&lt;string&gt;"/>\r\n<mapping key\="&lt;bits/shared_ptr.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;bits/slice_array.h&gt;" value\="&lt;valarray&gt;"/>\r\n<mapping key\="&lt;bits/sstream.tcc&gt;" value\="&lt;sstream&gt;"/>\r\n<mapping key\="&lt;bits/stl_algo.h&gt;" value\="&lt;algorithm&gt;"/>\r\n<mapping key\="&lt;bits/stl_algobase.h&gt;" value\="&lt;algorithm&gt;"/>\r\n<mapping key\="&lt;bits/stl_bvector.h&gt;" value\="&lt;vector&gt;"/>\r\n<mapping key\="&lt;bits/stl_construct.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;bits/stl_deque.h&gt;" value\="&lt;deque&gt;"/>\r\n<mapping key\="&lt;bits/stl_function.h&gt;" value\="&lt;functional&gt;"/>\r\n<mapping key\="&lt;bits/stl_heap.h&gt;" value\="&lt;queue&gt;"/>\r\n<mapping key\="&lt;bits/stl_iterator.h&gt;" value\="&lt;iterator&gt;"/>\r\n<mapping key\="&lt;bits/stl_iterator_base_funcs.h&gt;" value\="&lt;iterator&gt;"/>\r\n<mapping key\="&lt;bits/stl_iterator_base_types.h&gt;" value\="&lt;iterator&gt;"/>\r\n<mapping key\="&lt;bits/stl_list.h&gt;" value\="&lt;list&gt;"/>\r\n<mapping key\="&lt;bits/stl_map.h&gt;" value\="&lt;map&gt;"/>\r\n<mapping key\="&lt;bits/stl_move.h&gt;" value\="&lt;algorithm&gt;"/>\r\n<mapping key\="&lt;bits/stl_multimap.h&gt;" value\="&lt;map&gt;"/>\r\n<mapping key\="&lt;bits/stl_multiset.h&gt;" value\="&lt;set&gt;"/>\r\n<mapping key\="&lt;bits/stl_numeric.h&gt;" value\="&lt;numeric&gt;"/>\r\n<mapping key\="&lt;bits/stl_pair.h&gt;" value\="&lt;utility&gt;"/>\r\n<mapping key\="&lt;bits/stl_pair.h&gt;" value\="&lt;tr1/utility&gt;"/>\r\n<mapping key\="&lt;bits/stl_queue.h&gt;" value\="&lt;queue&gt;"/>\r\n<mapping key\="&lt;bits/stl_raw_storage_iter.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;bits/stl_relops.h&gt;" value\="&lt;utility&gt;"/>\r\n<mapping key\="&lt;bits/stl_set.h&gt;" value\="&lt;set&gt;"/>\r\n<mapping key\="&lt;bits/stl_stack.h&gt;" value\="&lt;stack&gt;"/>\r\n<mapping key\="&lt;bits/stl_tempbuf.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;bits/stl_tree.h&gt;" value\="&lt;map&gt;"/>\r\n<mapping key\="&lt;bits/stl_tree.h&gt;" value\="&lt;set&gt;"/>\r\n<mapping key\="&lt;bits/stl_uninitialized.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;bits/stl_vector.h&gt;" value\="&lt;vector&gt;"/>\r\n<mapping key\="&lt;bits/stream_iterator.h&gt;" value\="&lt;iterator&gt;"/>\r\n<mapping key\="&lt;bits/streambuf.tcc&gt;" value\="&lt;streambuf&gt;"/>\r\n<mapping key\="&lt;bits/streambuf_iterator.h&gt;" value\="&lt;iterator&gt;"/>\r\n<mapping key\="&lt;bits/streambuf_iterator.h&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;bits/stringfwd.h&gt;" value\="&lt;string&gt;"/>\r\n<mapping key\="&lt;bits/unique_ptr.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;bits/valarray_after.h&gt;" value\="&lt;valarray&gt;"/>\r\n<mapping key\="&lt;bits/valarray_array.h&gt;" value\="&lt;valarray&gt;"/>\r\n<mapping key\="&lt;bits/valarray_array.tcc&gt;" value\="&lt;valarray&gt;"/>\r\n<mapping key\="&lt;bits/valarray_before.h&gt;" value\="&lt;valarray&gt;"/>\r\n<mapping key\="&lt;bits/vector.tcc&gt;" value\="&lt;vector&gt;"/>\r\n<mapping key\="&lt;debug/safe_iterator.tcc&gt;" value\="&lt;debug/safe_iterator.h&gt;"/>\r\n<mapping key\="&lt;exception_defines.h&gt;" value\="&lt;exception&gt;"/>\r\n<mapping key\="&lt;ext/algorithm&gt;" value\="&lt;algorithm&gt;"/>\r\n<mapping key\="&lt;ext/functional&gt;" value\="&lt;functional&gt;"/>\r\n<mapping key\="&lt;ext/hash_map&gt;" value\="&lt;hash_map&gt;"/>\r\n<mapping key\="&lt;ext/hash_set&gt;" value\="&lt;hash_set&gt;"/>\r\n<mapping key\="&lt;ext/numeric&gt;" value\="&lt;numeric&gt;"/>\r\n<mapping key\="&lt;ext/slist&gt;" value\="&lt;slist&gt;"/>\r\n<mapping key\="&lt;ext/sso_string_base.h&gt;" value\="&lt;string&gt;"/>\r\n<mapping key\="&lt;ext/vstring.h&gt;" value\="&lt;string&gt;"/>\r\n<mapping key\="&lt;ext/vstring.tcc&gt;" value\="&lt;string&gt;"/>\r\n<mapping key\="&lt;ext/vstring_fwd.h&gt;" value\="&lt;string&gt;"/>\r\n<mapping key\="&lt;hash_fun.h&gt;" value\="&lt;hash_map&gt;"/>\r\n<mapping key\="&lt;hash_fun.h&gt;" value\="&lt;hash_set&gt;"/>\r\n<mapping key\="&lt;hashtable.h&gt;" value\="&lt;hash_map&gt;"/>\r\n<mapping key\="&lt;hashtable.h&gt;" value\="&lt;hash_set&gt;"/>\r\n<mapping key\="&lt;tr1/bessel_function.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/beta_function.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/ell_integral.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/exp_integral.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/gamma.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/hypergeometric.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/legendre_function.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/modified_bessel_func.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/poly_hermite.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/poly_laguerre.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/riemann_zeta.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1_impl/array&gt;" value\="&lt;array&gt;"/>\r\n<mapping key\="&lt;tr1_impl/array&gt;" value\="&lt;tr1/array&gt;"/>\r\n<mapping key\="&lt;tr1_impl/boost_shared_ptr.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;tr1_impl/boost_shared_ptr.h&gt;" value\="&lt;tr1/memory&gt;"/>\r\n<mapping key\="&lt;tr1_impl/boost_sp_counted_base.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;tr1_impl/boost_sp_counted_base.h&gt;" value\="&lt;tr1/memory&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cctype&gt;" value\="&lt;cctype&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cctype&gt;" value\="&lt;tr1/cctype&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cfenv&gt;" value\="&lt;cfenv&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cfenv&gt;" value\="&lt;tr1/cfenv&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cinttypes&gt;" value\="&lt;cinttypes&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cinttypes&gt;" value\="&lt;tr1/cinttypes&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cmath&gt;" value\="&lt;cmath&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cmath&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1_impl/complex&gt;" value\="&lt;complex&gt;"/>\r\n<mapping key\="&lt;tr1_impl/complex&gt;" value\="&lt;tr1/complex&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cstdint&gt;" value\="&lt;cstdint&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cstdint&gt;" value\="&lt;tr1/cstdint&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cstdio&gt;" value\="&lt;cstdio&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cstdio&gt;" value\="&lt;tr1/cstdio&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cstdlib&gt;" value\="&lt;cstdlib&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cstdlib&gt;" value\="&lt;tr1/cstdlib&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cwchar&gt;" value\="&lt;cwchar&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cwchar&gt;" value\="&lt;tr1/cwchar&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cwctype&gt;" value\="&lt;cwctype&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cwctype&gt;" value\="&lt;tr1/cwctype&gt;"/>\r\n<mapping key\="&lt;tr1_impl/functional&gt;" value\="&lt;functional&gt;"/>\r\n<mapping key\="&lt;tr1_impl/functional&gt;" value\="&lt;tr1/functional&gt;"/>\r\n<mapping key\="&lt;tr1_impl/functional_hash.h&gt;" value\="&lt;tr1/functional_hash.h&gt;"/>\r\n<mapping key\="&lt;tr1_impl/hashtable&gt;" value\="&lt;tr1/hashtable.h&gt;"/>\r\n<mapping key\="&lt;tr1_impl/random&gt;" value\="&lt;random&gt;"/>\r\n<mapping key\="&lt;tr1_impl/random&gt;" value\="&lt;tr1/random&gt;"/>\r\n<mapping key\="&lt;tr1_impl/random.tcc&gt;" value\="&lt;random&gt;"/>\r\n<mapping key\="&lt;tr1_impl/random.tcc&gt;" value\="&lt;tr1/random&gt;"/>\r\n<mapping key\="&lt;tr1_impl/regex&gt;" value\="&lt;regex&gt;"/>\r\n<mapping key\="&lt;tr1_impl/regex&gt;" value\="&lt;tr1/regex&gt;"/>\r\n<mapping key\="&lt;tr1_impl/type_traits&gt;" value\="&lt;tr1/type_traits&gt;"/>\r\n<mapping key\="&lt;tr1_impl/type_traits&gt;" value\="&lt;type_traits&gt;"/>\r\n<mapping key\="&lt;tr1_impl/unordered_map&gt;" value\="&lt;tr1/unordered_map&gt;"/>\r\n<mapping key\="&lt;tr1_impl/unordered_map&gt;" value\="&lt;unordered_map&gt;"/>\r\n<mapping key\="&lt;tr1_impl/unordered_set&gt;" value\="&lt;tr1/unordered_set&gt;"/>\r\n<mapping key\="&lt;tr1_impl/unordered_set&gt;" value\="&lt;unordered_set&gt;"/>\r\n<mapping key\="&lt;tr1_impl/utility&gt;" value\="&lt;tr1/utility&gt;"/>\r\n<mapping key\="&lt;tr1_impl/utility&gt;" value\="&lt;utility&gt;"/>\r\n</unconditional_substitution_map>\r\n<optional_substitution_map>\r\n<mapping key\="&lt;assert.h&gt;" value\="&lt;cassert&gt;"/>\r\n<mapping key\="&lt;complex.h&gt;" value\="&lt;ccomplex&gt;"/>\r\n<mapping key\="&lt;ctype.h&gt;" value\="&lt;cctype&gt;"/>\r\n<mapping key\="&lt;errno.h&gt;" value\="&lt;cerrno&gt;"/>\r\n<mapping key\="&lt;fenv.h&gt;" value\="&lt;cfenv&gt;"/>\r\n<mapping key\="&lt;float.h&gt;" value\="&lt;cfloat&gt;"/>\r\n<mapping key\="&lt;inttypes.h&gt;" value\="&lt;cinttypes&gt;"/>\r\n<mapping key\="&lt;ios&gt;" value\="&lt;iostream&gt;"/>\r\n<mapping key\="&lt;ios&gt;" value\="&lt;istream&gt;"/>\r\n<mapping key\="&lt;ios&gt;" value\="&lt;ostream&gt;"/>\r\n<mapping key\="&lt;iosfwd&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;iosfwd&gt;" value\="&lt;streambuf&gt;"/>\r\n<mapping key\="&lt;iso646.h&gt;" value\="&lt;ciso646&gt;"/>\r\n<mapping key\="&lt;istream&gt;" value\="&lt;iostream&gt;"/>\r\n<mapping key\="&lt;istream&gt;" value\="&lt;fstream&gt;"/>\r\n<mapping key\="&lt;istream&gt;" value\="&lt;sstream&gt;"/>\r\n<mapping key\="&lt;limits.h&gt;" value\="&lt;climits&gt;"/>\r\n<mapping key\="&lt;locale.h&gt;" value\="&lt;clocale&gt;"/>\r\n<mapping key\="&lt;math.h&gt;" value\="&lt;cmath&gt;"/>\r\n<mapping key\="&lt;ostream&gt;" value\="&lt;iostream&gt;"/>\r\n<mapping key\="&lt;ostream&gt;" value\="&lt;fstream&gt;"/>\r\n<mapping key\="&lt;ostream&gt;" value\="&lt;istream&gt;"/>\r\n<mapping key\="&lt;ostream&gt;" value\="&lt;sstream&gt;"/>\r\n<mapping key\="&lt;setjmp.h&gt;" value\="&lt;csetjmp&gt;"/>\r\n<mapping key\="&lt;signal.h&gt;" value\="&lt;csignal&gt;"/>\r\n<mapping key\="&lt;stdarg.h&gt;" value\="&lt;cstdarg&gt;"/>\r\n<mapping key\="&lt;stdbool.h&gt;" value\="&lt;cstdbool&gt;"/>\r\n<mapping key\="&lt;stddef.h&gt;" value\="&lt;cstddef&gt;"/>\r\n<mapping key\="&lt;stdint.h&gt;" value\="&lt;cstdint&gt;"/>\r\n<mapping key\="&lt;stdio.h&gt;" value\="&lt;cstdio&gt;"/>\r\n<mapping key\="&lt;stdlib.h&gt;" value\="&lt;cstdlib&gt;"/>\r\n<mapping key\="&lt;streambuf&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;string.h&gt;" value\="&lt;cstring&gt;"/>\r\n<mapping key\="&lt;tgmath.h&gt;" value\="&lt;ctgmath&gt;"/>\r\n<mapping key\="&lt;time.h&gt;" value\="&lt;ctime&gt;"/>\r\n<mapping key\="&lt;wchar.h&gt;" value\="&lt;cwchar&gt;"/>\r\n<mapping key\="&lt;wctype.h&gt;" value\="&lt;cwctype&gt;"/>\r\n</optional_substitution_map>\r\n</map>\r\n</maps>
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.number_of_empty_lines_to_preserve=1
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.LaunchLastIfNotLaunchable=true
/bundle_defaults/org.eclipse.ui.workbench/SHOW_MEMORY_MONITOR=false
/bundle_defaults/org.eclipse.cdt.ui/forwardDeclare.templates=false
/bundle_defaults/org.eclipse.cdt.ui/matchingBracketsColor=170,170,170
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_colon_in_base_clause=insert
/bundle_defaults/org.eclipse.ui.editors/quickdiff.quickDiff=true
/bundle_defaults/com.crt.utils/extendedToolsSupport=false
/bundle_defaults/org.eclipse.core.resources/refresh.lightweight.enabled=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.getter.suffix=
/bundle_defaults/org.eclipse.ui.editors/linked.slave.color=180,215,255
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticField.underline=false
/bundle_defaults/org.eclipse.ui.ide/TASKS_FILTERS_MIGRATE=false
/bundle_defaults/org.eclipse.core.net/proxyData/HTTP/hasAuth=false
/bundle_defaults/org.eclipse.cdt.dsf.gdb/tracesEnable=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.overloadedOperator.bold=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_semicolon=do not insert
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.pcHistorySize=4
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.reset_memory_block=org.eclipse.debug.uiresetMemoryBlock.visible
/bundle_defaults/org.eclipse.ui.editors/filteredSearchResultIndication=false
/bundle_defaults/org.eclipse.ui.workbench/KEYS_PREFERENCE_SELECTED_TAB=0
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.overrideIndicatorHighlighting=false
/bundle_defaults/org.eclipse.ui.editors/showAdditionInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.put_empty_statement_on_new_line=true
/bundle_defaults/org.eclipse.ui.workbench/ENABLED_DECORATORS=
/bundle_defaults/org.eclipse.ui.workbench/LAYOUT_DIRECTION=0
/bundle_defaults/org.eclipse.cdt.ui/hoverModifiers=org.eclipse.cdt.ui.BestMatchHover;0;org.eclipse.cdt.ui.CSourceHover;Shift
/bundle_defaults/org.eclipse.cdt.dsf.gdb/defaultGdbInit=.gdbinit
/bundle_defaults/org.eclipse.cdt.ui/scalability.syntaxColor=false
/bundle_defaults/org.eclipse.ui.ide/LIMIT_TASKS=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.field.color=0,0,192
/bundle_defaults/org.eclipse.cdt.debug.core/org.eclipse.cdt.debug.corecDebug.Disassembly.instructionStepOn=false
/bundle_defaults/org.eclipse.cdt.ui/removeTrailingWhitespace=true
/bundle_defaults/org.eclipse.ui.editors/searchResultIndicationInVerticalRuler=true
/bundle_defaults/org.eclipse.cdt.ui/spelling_ignore_mixed=true
/bundle_defaults/org.eclipse.ui/VIEW_TAB_POSITION=128
/bundle_defaults/org.eclipse.cdt.ui/content_assist_proposals_foreground=0,0,0
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.occurrenceTextStyle=NONE
/bundle_defaults/org.eclipse.ui.editors/currentIPTextStyle=NONE
/bundle_defaults/org.eclipse.ui/USE_COLORED_LABELS=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.remove_all_expressions_prompt=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_enum_declarations=insert
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.error.GoToNextNavigationTarget=true
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.SaveAllEditors=false
/bundle_defaults/org.eclipse.cdt.core/indexer/indexImportLocation=.settings/cdt-index.zip
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.memory.paddedStr=??
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.test.wordDelimiter=
/bundle_defaults/org.eclipse.ui/EDITOR_TAB_POSITION=128
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_pinint.com.crt.advproject.projecttype.exe.500409353/com.crt.advproject.config.exe.debug.1554618354=com.crt.advproject.link.cpp.exe.debug.1515071553\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1895588001\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.870533861\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1867315417\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1897250593\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.282738432\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1554618354\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/linked.target.verticalruler=false
/bundle_defaults/org.eclipse.ui.editors/isSpellingGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/deletionIndicationInVerticalRuler=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.function.underline=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_template_parameters=do not insert
/bundle_defaults/org.eclipse.ui.workbench/RECENT_FILES=4
/bundle_defaults/org.eclipse.cdt.ui/inactiveCodeEnable=true
/bundle_defaults/com.crt.debugcommon/Red\ Probe\ Family=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_question_in_conditional=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_between_empty_parens_in_method_invocation=do not insert
/bundle_defaults/org.eclipse.cdt.ui/content_assist_order_proposals=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.label.bold=false
/instance/org.eclipse.cdt.core/macros/workspace=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?>\r\n<macros/>\r\n
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroDefinition.underline=false
/bundle_defaults/org.eclipse.cdt.dsf.ui/delaySteppingForViewUpdatesEnable=false
/bundle_defaults/org.eclipse.cdt.ui/spelling_ignore_string_literals=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/LPCXpresso176x_timer.com.crt.advproject.projecttype.exe.1447070015/com.crt.advproject.config.exe.release.355928930=com.crt.advproject.toolchain.exe.release.1378490699\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.811744456\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.348057984\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.1794124423\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1794703196\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1917935340\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_postfix_operator=do not insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.overloadedOperator.italic=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_parameters_in_method_declaration=16
/bundle_defaults/org.eclipse.cdt.ui/asm_label=127,0,85
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.avoidReadBeforePC=false
/bundle_defaults/org.eclipse.ui.ide/SWITCH_PERSPECTIVE_ON_PROJECT_CREATION=prompt
/bundle_defaults/org.eclipse.ui.editors/com.crt.etmetb.marker.pref.textStyle=IBEAM
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.c_keyword.enabled=true
/bundle_defaults/com.crt.debugcommon/warning_as_note=false
/bundle_defaults/org.eclipse.ui.editors/linked.focus.text.style=BOX
/bundle_defaults/org.eclipse.ui.editors/currentIPHighlight=true
/bundle_defaults/org.eclipse.ui/USE_WINDOW_WORKING_SET_BY_DEFAULT=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.method.bold=false
/bundle_defaults/org.eclipse.ui.editors/showTrailingSpaces=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.comment.min_distance_between_code_and_line_comment=1
/bundle_defaults/org.eclipse.cdt.ui/pp_header_italic=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.variable.capitalization=4
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_uart_rb.com.crt.advproject.projecttype.exe.1950633819/com.crt.advproject.config.exe.release.591215090=com.crt.advproject.link.exe.release.679425267\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1983682568\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.1335020951\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1666157320\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.2140904055\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.217606318\=rebuildState\\\=true\\r\\n\r\n
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_bod.com.crt.advproject.projecttype.exe.1330480440/com.crt.advproject.config.exe.debug.1121475055=com.crt.advproject.link.exe.debug.998466899\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1234966347\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.474972202\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1121475055\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.1991069582\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1117423890\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.33140722\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui/KEY_CONFIGURATION_ID=org.eclipse.ui.defaultAcceleratorConfiguration
/bundle_defaults/org.eclipse.core.resources/description.filestatelongevity=604800000
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_binary_expression=16
/bundle_defaults/org.eclipse.debug.ui/org.eclispe.debug.ui.Debug_view.mode=Debug_view.mode.auto
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_prefix_operator=do not insert
/bundle_defaults/com.crt.dsfdebug/periphFormatToWidth=false
/instance/org.eclipse.core.resources/version=1
/bundle_defaults/org.eclipse.cdt.ui/markOccurrences=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.use_tabs_only_for_leading_indentations=false
/instance/org.eclipse.cdt.debug.core/org.eclipse.cdt.debug.core.cDebug.default_source_containers=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?>\r\n<sourceLookupDirector>\r\n<sourceContainers duplicates\="false">\r\n<container memento\="AbsolutePath" typeId\="org.eclipse.cdt.debug.core.containerType.absolutePath"/>\r\n<container memento\="programRelativePath" typeId\="org.eclipse.cdt.debug.core.containerType.programRelativePath"/>\r\n<container memento\="&lt;?xml version\=&quot;1.0&quot; encoding\=&quot;UTF-8&quot; standalone\=&quot;no&quot;?&gt;&\#13;&\#10;&lt;project referencedProjects\=&quot;true&quot;/&gt;&\#13;&\#10;" typeId\="org.eclipse.cdt.debug.core.containerType.project"/>\r\n</sourceContainers>\r\n</sourceLookupDirector>\r\n
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.PREF_FILTER_LAUNCH_TYPES=false
/instance/org.eclipse.debug.core//org.eclipse.debug.core.PREFERRED_DELEGATES/org.eclipse.cdt.launch.postmortemLaunchType=org.eclipse.cdt.dsf.gdb.launch.coreCLaunch,debug,;
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.UseContextualLaunch=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enum.strikethrough=false
/bundle_defaults/org.eclipse.core.resources/delta.expiration=2592000000
/bundle_defaults/org.eclipse.ui.editors/printMarginColumn=80
/bundle_defaults/org.eclipse.ui.workbench/COLOR_ICONS=true
/bundle_defaults/org.eclipse.ui.editors/secondaryIPOverviewRuler=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_ethernet.com.crt.advproject.projecttype.exe.1632332403/com.crt.advproject.config.exe.release.1243387797=com.crt.advproject.toolchain.exe.release.1109289695\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.1005076799\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1328591123\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.993078141\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.511095667\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1549525454\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/com.crt.config/package=LPC1343
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_before_catch_in_try_statement=do not insert
/bundle_defaults/com.crt.debugcommon/genericVidpidScript=
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.function.enabled=false
/bundle_defaults/org.eclipse.ui.workbench/FVB_HIDE=false
/bundle_defaults/org.eclipse.cdt.ui/scalability.parserBasedContentAssist=false
/bundle_defaults/org.eclipse.cdt.core/useStructualParseMode=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.occurrenceIndicationColor=212,212,212
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.max_detail_length=10000
/bundle_defaults/org.eclipse.cdt.ui/spelling_locale=en_US
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_switchstatements_compare_to_cases=true
/bundle_defaults/com.crt.debugcommon/showExtended=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_namespace_declaration=end_of_line
/bundle_defaults/com.crt.advproject/dependeciesfix=true
/bundle_defaults/org.eclipse.ui.editors/com.crt.etmetb.marker.profile.pref.vertical=false
/bundle_defaults/org.eclipse.ui.editors/unchangedIndicationInVerticalRuler=false
/bundle_defaults/org.eclipse.cdt.codan.core/useParentScope=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.memory.rowSize=16
/bundle_defaults/org.eclipse.ui.editors/showFilteredSearchResultInNextPrevDropdownToolbarAction=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_if=do not insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariable.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/spelling_user_dictionary=
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.externalSDK.color=100,40,128
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.namespace.color=0,0,0
/bundle_defaults/com.crt.debugcommon/macBackgroundExec=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariable.bold=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_throws_clause_in_method_declaration=16
/bundle_defaults/org.eclipse.ui/VIEW_MINIMUM_CHARACTERS=1
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.label.underline=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.header.wordDelimiter=
/bundle_defaults/org.eclipse.ui/RECENTLY_USED_WORKINGSETS_SIZE=5
/bundle_defaults/org.eclipse.debug.ui/DEBUG.consoleOpenOnErr=true
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.constant.capitalization=1
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.functionDeclaration.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroDefinition.color=0,0,0
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_base_types=insert
/bundle_defaults/org.eclipse.ui.editors/showLineFeed=true
/bundle_defaults/org.eclipse.cdt.ui/c_comment_task_tag_bold=true
/bundle_defaults/org.eclipse.cdt.ui/formatter_profile=org.eclipse.cdt.ui.default.kandr_profile
/bundle_defaults/com.crt.debugcommon/bootLogFile=
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.setter.suffix=
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_before_closing_brace_in_array_initializer=do not insert
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.NavigationEndAction=prompt
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.manage_view_perspectives=DEFAULT
/bundle_defaults/org.eclipse.ui.ide/SAVE_ALL_BEFORE_BUILD=false
/bundle_defaults/org.eclipse.ui.editors/quickdiff.characterMode=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_brace_in_array_initializer=insert
/instance/org.eclipse.cdt.managedbuilder.core/properties/usbd_lib_hid_generic.com.crt.advproject.projecttype.exe.1358948682/com.crt.advproject.config.exe.debug.815324353=com.crt.advproject.config.exe.debug.815324353\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1493008474\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.131611243\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.81969147\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1255076903\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.537414472\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1024811717\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.core.net/proxyData/HTTPS/port=-1
/bundle_defaults/org.eclipse.cdt.dsf.gdb/org.eclipse.cdt.dsf.gdb.hideRunningThreads=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.dsf.debug.ui.hyperlinkdetector.stepIntoSelection_stateMask=327680
/bundle_defaults/org.eclipse.ui.editors/infoTextStyle=SQUIGGLES
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleInfoStreamColor=0,0,255
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.show_debug_perspective_default=org.eclipse.debug.ui.DebugPerspective
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleErrorStreamColor=255,0,0
/bundle_defaults/org.eclipse.ui.editors/spellingTextStyle=PROBLEM_UNDERLINE
/bundle_defaults/org.eclipse.ui.ide/PROBLEMS_FILTERS_MIGRATE=false
/bundle_defaults/org.eclipse.cdt.dsf.gdb/initialChildCountLimitForCollections=100
/bundle_defaults/org.eclipse.ui.ide/IMPORT_FILES_AND_FOLDERS_RELATIVE=true
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.addressColor=0,96,0
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_bod.com.crt.advproject.projecttype.exe.1330480440/com.crt.advproject.config.exe.release.1597988367=com.crt.advproject.gcc.exe.release.1008161469\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1862735863\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1883379497\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1170680966\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.637149094\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.330034282\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/pp_header=42,0,255
/bundle_defaults/org.eclipse.cdt.dsf.gdb/autoTerminateGdb=true
/instance/org.eclipse.ui.ide/tipsAndTricks=true
/bundle_defaults/org.eclipse.ui.editors/revisionAnnotationIndicationHighlighting=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.getter.prefix=get
/bundle_defaults/com.crt.debugcommon/redlink_useWmic=true
/bundle_defaults/org.eclipse.ui.editors/searchResultIndication=false
/bundle_defaults/org.eclipse.ui.editors/filteredSearchResultHighlighting=false
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_default_comments=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.method.wordDelimiter=
/bundle_defaults/org.eclipse.cdt.dsf.gdb/org.eclipse.cdt.dsf.gdb.commandTimeoutValue=10000
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_for=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_colon_in_default=do not insert
/bundle_defaults/org.eclipse.ui.workbench/EDITORLIST_SELECTION_SCOPE=1
/bundle_defaults/org.eclipse.ui.ide/WELCOME_DIALOG=true
/bundle_defaults/org.eclipse.cdt.core/scalability.limitTokensPerTU=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.variable.wordDelimiter=
/instance/org.eclipse.cdt.managedbuilder.core/properties/lwip_tcpecho_sa.com.crt.advproject.projecttype.exe.468432546/com.crt.advproject.config.exe.debug.1119530382=com.crt.advproject.link.cpp.exe.debug.2050365894\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1247192910\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.803449759\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1860283680\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1297078967\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1644762283\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1119530382\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.ide/PROJECT_OPEN_NEW_PERSPECTIVE=OPEN_PERSPECTIVE_REPLACE
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_method_invocation=do not insert
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.overrideIndicatorTextStyle=SQUIGGLES
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleProblemInfoBackgroundColor=244,247,254
@org.eclipse.cdt.core=5.8.0.201409172108
/bundle_defaults/org.eclipse.cdt.ui/content_assist_disabled_computers=org.eclipse.cdt.ui.textProposalCategory\u0000
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Color.Background.SystemDefault=true
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.IgnoreWhitespace=false
/bundle_defaults/com.crt.dsfdebug/windowsMakePathsRelative=false
/bundle_defaults/org.eclipse.ui.workbench/shouldPromptForEnablement=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.templateParameter.color=100,70,50
/bundle_defaults/org.eclipse.ui.editors/linked.exit.navigation.previous=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.activate_workbench=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.relaunch_in_debug_mode=never
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.problem.strikethrough=false
/bundle_defaults/org.eclipse.ui.ide/LIMIT_BOOKMARKS=true
/bundle_defaults/org.eclipse.debug.ui/Console.console_tab_width=8
/bundle_defaults/org.eclipse.core.resources/description.maxfilestates=50
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_breaks_compare_to_cases=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_method_declaration=do not insert
/bundle_defaults/org.eclipse.ui.editors/spellingIndicationInVerticalRuler=false
/bundle_defaults/com.crt.utils/newMacAddressMethod=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_flashiap.com.crt.advproject.projecttype.exe.2033906280/com.crt.advproject.config.exe.release.1130833511=com.crt.advproject.cpp.exe.release.1595716391\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1101117428\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1136415674\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1814748619\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1587509976\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.873115923\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.PREF_FILTER_LAUNCH_DELETED=true
/bundle_defaults/com.crt.utils/hideDebugView=true
/bundle_defaults/org.eclipse.ui.editors/bookmarkIndicationHighlighting=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_array_initializer=insert
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.PREF_LAUNCH_PERSPECTIVES=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?>\r\n<launchPerspectives>\r\n<launchPerspective configurationType\="com.crt.dsfdebug.crtmcu.launchType" mode\="debug" perspective\="com.crt.lite.perspective.CRTPerspective"/>\r\n</launchPerspectives>\r\n
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.auto_remove_old_launches=true
/bundle_defaults/com.crt.debugcommon/redlink_boot_image=(?i)LPC43.._Redlink_V([0-9]_[0-9]+).bin.hdr
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.setter.wordDelimiter=
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enumerator.italic=true
/bundle_defaults/org.eclipse.core.resources/description.defaultbuildorder=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_switch=do not insert
/bundle_defaults/org.eclipse.ui.editors/isTaskGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_angle_bracket_in_template_parameters=do not insert
/instance/org.eclipse.cdt.ui.prj-periph_blinky/buildConsole/logLocation=C\:\\Users\\Egitim5\\Documents\\LPCXpresso_7.6.2_326\\workspace\\.metadata\\.plugins\\org.eclipse.cdt.ui\\periph_blinky.build.log
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.method.italic=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_CORE_LPC112x.com.crt.advproject.projecttype.lib.481795455/com.crt.advproject.config.lib.debug.552843825=com.crt.advproject.ar.lib.debug.67772726\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.2069312955\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.752221769\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.1580605360\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.712578205\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.552843825\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/bundle_defaults/com.crt.debugcommon/probe_settle=250
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleTabWith=4
/bundle_defaults/org.eclipse.ui.editors/infoIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.ui.internal.editors.text.URLHyperlinkDetector_stateMask=-1
/bundle_defaults/org.eclipse.core.resources/description.maxbuilditerations=10
/bundle_defaults/org.eclipse.cdt.ui/c_braces_bold=false
/bundle_defaults/org.eclipse.cdt.ui/spelling_ignore_digits=true
/bundle_defaults/org.eclipse.ui.editors/linked.exit.navigation.next=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.warning.text=true
/bundle_defaults/com.crt.debugcommon/redlink_server_port=3025
/bundle_defaults/org.eclipse.core.net/proxyData/HTTPS/hasAuth=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.parameterVariable.underline=false
/instance/org.eclipse.cdt.core.prj-LPCX176x_cmsis2_systick/indexer/preferenceScope=0
/bundle_defaults/org.eclipse.ui.editors/searchResultHighlighting=true
/bundle_defaults/org.eclipse.ui.editors/hyperlinkColor=0,102,204
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.occurrenceHighlighting=true
/bundle_defaults/org.eclipse.ui.editors/errorIndicationInVerticalRuler=true
/bundle_defaults/org.eclipse.cdt.ui/pp_header_bold=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.functionDeclaration.bold=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_enum_declarations=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_namespace_declaration=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_declarator_list=16
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_spi.com.crt.advproject.projecttype.exe.1116578252/com.crt.advproject.config.exe.debug.601319979=com.crt.advproject.gcc.exe.debug.326242662\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.652166092\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.9224791\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.309974641\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.2027771857\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.415100223\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.601319979\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/instance/org.eclipse.cdt.managedbuilder.core/properties/LPCXpresso1768_systick.com.crt.advproject.projecttype.exe.783271606/com.crt.advproject.config.exe.debug.986034614=com.crt.advproject.gcc.exe.debug.2049914417.1184573733\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1701619043\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1801950365\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.986034614.52274068\=rebuildState\\\=true\\r\\n\r\norg.eclipse.cdt.managedbuilder.ui.rcbs.104766275\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.694254463\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.986034614\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.2049914417\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.487243263\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1291557132\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleProblemBackgroundColor=254,231,224
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.writeOccurrenceHighlighting=true
/bundle_defaults/org.eclipse.ui.editors/isBookmarkGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.ui.workbench/OPEN_ON_SINGLE_CLICK=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_flashiap.com.crt.advproject.projecttype.exe.2033906280/com.crt.advproject.config.exe.debug.1880147916=com.crt.advproject.link.cpp.exe.debug.1712581607\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1540092944\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1650853042\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1209267662\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1113455924\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1880147916\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1225921430\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/com.crt.debugcommon/semihostingState=false
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.system=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style blank_line_before\="true" keep_together\="true" order\="0"/>
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_while=do not insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enumerator.enabled=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enum.underline=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/lwip_tcpecho_sa.com.crt.advproject.projecttype.exe.468432546/com.crt.advproject.config.exe.release.1619684282=com.crt.advproject.gcc.exe.release.715600888\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1994205202\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.857667410\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.120251981\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.2064666483\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.173463807\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.typedef.strikethrough=false
/bundle_defaults/org.eclipse.ui.editors/isIndexResultInNextPrevDropdownToolbarAction=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_pmu.com.crt.advproject.projecttype.exe.1242046794/com.crt.advproject.config.exe.debug.815439733=com.crt.advproject.config.exe.debug.815439733\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.315300907\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1369234815\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1868866796\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.725131995\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.762982395\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1763844694\=rebuildState\\\=false\\r\\n\r\n
/instance/org.eclipse.cdt.core.prj-lpc_board_nxp_lpcxpresso_1769/indexer/preferenceScope=0
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk.scheduler/remindElapsedTime=30 minutes
/bundle_defaults/org.eclipse.ui.workbench/coolBarVisible=true
/bundle_defaults/org.eclipse.ui/CLOSE_EDITORS_ON_EXIT=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_exception_specification=do not insert
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_can.com.crt.advproject.projecttype.exe.1549120935/com.crt.advproject.config.exe.release.794995649=com.crt.advproject.link.exe.release.440877968\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1469513783\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.1926579303\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.212903690\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.2129410273\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.2074713666\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk.scheduler/enabled=false
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk/showLatestVersion=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.field.strikethrough=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_ethernet.com.crt.advproject.projecttype.exe.1632332403/com.crt.advproject.config.exe.debug.1090525059=com.crt.advproject.gas.exe.debug.421609304\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1090525059\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.909433006\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1459417064\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1587156633\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.878183164\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.825344951\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/errorIndication=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/webserver_freertos.com.crt.advproject.projecttype.exe.874780069/com.crt.advproject.config.exe.release.295130519=com.crt.advproject.link.exe.release.179256910\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1468130162\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1612063061\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.863141771\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1788992748\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.1495546561\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/content_assist_category_order=org.eclipse.cdt.ui.parserProposalCategory\:65539\u0000org.eclipse.cdt.ui.textProposalCategory\:65541\u0000org.eclipse.cdt.ui.templateProposalCategory\:2\u0000org.eclipse.cdt.ui.helpProposalCategory\:5\u0000
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.overrideIndicator=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariableDeclaration.enabled=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.isOverrideIndicatorGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/showRevisionAnnotationInNextPrevDropdownToolbarAction=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_catch=do not insert
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_default_functions=false
/bundle_defaults/org.eclipse.ui/SHOW_SYSTEM_JOBS=false
/bundle_defaults/org.eclipse.ui.editors/hyperlinksEnabled=true
/bundle_defaults/org.eclipse.ui/SHOW_MULTIPLE_EDITOR_TABS=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSISv2p00_LPC17xx.com.crt.advproject.projecttype.lib.1193160240/com.crt.advproject.config.lib.release.1079171862=com.crt.advproject.gas.lib.release.48688322\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.lib.release.352135057\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.ar.lib.release.1701225249\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.lib.release.1097962762\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.lib.release.1602026126\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.error.textstyle=SQUIGGLES
/bundle_defaults/org.eclipse.debug.core/org.eclipse.debug.core.PREF_ENABLE_STATUS_HANDLERS=true
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_preprocessor_enabled=false
/bundle_defaults/org.eclipse.cdt.ui/forwardDeclare.enums=false
/bundle_defaults/org.eclipse.ui.ide/saveInterval=5
/instance/org.eclipse.cdt.core.prj-LPCX176x_cmsis2_systick_twinkle/indexer/preferenceScope=0
/bundle_defaults/org.eclipse.cdt.ui/c_default=0,0,0
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.inSameProject=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style angle_brackets\="false" blank_line_before\="false" keep_together\="false" relative_path\="false"/>
/bundle_defaults/org.eclipse.ui.workbench/HeapStatus.showMax=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.templateParameter.underline=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_prefix_operator=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_declarator_list=do not insert
/bundle_defaults/com.crt.debugcommon/displayConsole=false
/instance/org.eclipse.cdt.core.prj-lpc_chip_175x_6x/indexer/preferenceScope=0
/bundle_defaults/org.eclipse.ui.editors/isUnchangedGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_closing_angle_bracket_in_template_parameters=insert
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.showSymbols=true
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.setter.prefix=set
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.methodDeclaration.italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.templateParameter.enabled=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_angle_bracket_in_template_arguments=do not insert
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.writeOccurrenceIndicationInVerticalRuler=false
/bundle_defaults/org.eclipse.cdt.ui/organizeIncludes.symbolExportingHeaders=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<maps>\r\n<map>\r\n<mapping key\="blkcnt_t" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="blkcnt_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="blksize_t" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="blksize_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="calloc" value\="&lt;cstdlib&gt;"/>\r\n<mapping key\="calloc" value\="&lt;stdlib.h&gt;"/>\r\n<mapping key\="daddr_t" value\="&lt;rpc/types.h&gt;"/>\r\n<mapping key\="daddr_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="dev_t" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="dev_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="EOF" value\="&lt;cstdio&gt;"/>\r\n<mapping key\="EOF" value\="&lt;libio.h&gt;"/>\r\n<mapping key\="EOF" value\="&lt;stdio.h&gt;"/>\r\n<mapping key\="error_t" value\="&lt;argp.h&gt;"/>\r\n<mapping key\="error_t" value\="&lt;argz.h&gt;"/>\r\n<mapping key\="error_t" value\="&lt;errno.h&gt;"/>\r\n<mapping key\="free" value\="&lt;cstdlib&gt;"/>\r\n<mapping key\="free" value\="&lt;stdlib.h&gt;"/>\r\n<mapping key\="fsblkcnt_t" value\="&lt;sys/statvfs.h&gt;"/>\r\n<mapping key\="fsblkcnt_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="fsfilcnt_t" value\="&lt;sys/statvfs.h&gt;"/>\r\n<mapping key\="fsfilcnt_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="gid_t" value\="&lt;grp.h&gt;"/>\r\n<mapping key\="gid_t" value\="&lt;pwd.h&gt;"/>\r\n<mapping key\="gid_t" value\="&lt;stropts.h&gt;"/>\r\n<mapping key\="gid_t" value\="&lt;sys/ipc.h&gt;"/>\r\n<mapping key\="gid_t" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="gid_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="gid_t" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="id_t" value\="&lt;sys/resource.h&gt;"/>\r\n<mapping key\="id_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="ino_t" value\="&lt;dirent.h&gt;"/>\r\n<mapping key\="ino_t" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="ino_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="ino64_t" value\="&lt;dirent.h&gt;"/>\r\n<mapping key\="ino64_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="int8_t" value\="&lt;stdint.h&gt;"/>\r\n<mapping key\="int8_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="intptr_t" value\="&lt;stdint.h&gt;"/>\r\n<mapping key\="intptr_t" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="key_t" value\="&lt;sys/ipc.h&gt;"/>\r\n<mapping key\="key_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="malloc" value\="&lt;cstdlib&gt;"/>\r\n<mapping key\="malloc" value\="&lt;stdlib.h&gt;"/>\r\n<mapping key\="mode_t" value\="&lt;sys/ipc.h&gt;"/>\r\n<mapping key\="mode_t" value\="&lt;sys/mman.h&gt;"/>\r\n<mapping key\="mode_t" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="mode_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="nlink_t" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="nlink_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="NULL" value\="&lt;cstddef&gt;"/>\r\n<mapping key\="NULL" value\="&lt;cstdio&gt;"/>\r\n<mapping key\="NULL" value\="&lt;cstdlib&gt;"/>\r\n<mapping key\="NULL" value\="&lt;cstring&gt;"/>\r\n<mapping key\="NULL" value\="&lt;ctime&gt;"/>\r\n<mapping key\="NULL" value\="&lt;cwchar&gt;"/>\r\n<mapping key\="NULL" value\="&lt;locale.h&gt;"/>\r\n<mapping key\="NULL" value\="&lt;stddef.h&gt;"/>\r\n<mapping key\="NULL" value\="&lt;stdio.h&gt;"/>\r\n<mapping key\="NULL" value\="&lt;stdlib.h&gt;"/>\r\n<mapping key\="NULL" value\="&lt;string&gt;"/>\r\n<mapping key\="NULL" value\="&lt;string.h&gt;"/>\r\n<mapping key\="NULL" value\="&lt;time.h&gt;"/>\r\n<mapping key\="NULL" value\="&lt;wchar.h&gt;"/>\r\n<mapping key\="off_t" value\="&lt;sys/mman.h&gt;"/>\r\n<mapping key\="off_t" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="off_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="off_t" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="off64_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="off64_t" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="pid_t" value\="&lt;ctime&gt;"/>\r\n<mapping key\="pid_t" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="pid_t" value\="&lt;sys/msg.h&gt;"/>\r\n<mapping key\="pid_t" value\="&lt;sys/shm.h&gt;"/>\r\n<mapping key\="pid_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="pid_t" value\="&lt;termios.h&gt;"/>\r\n<mapping key\="pid_t" value\="&lt;time.h&gt;"/>\r\n<mapping key\="pid_t" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="pid_t" value\="&lt;utmpx.h&gt;"/>\r\n<mapping key\="realloc" value\="&lt;cstdlib&gt;"/>\r\n<mapping key\="realloc" value\="&lt;stdlib.h&gt;"/>\r\n<mapping key\="sigset_t" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="sigset_t" value\="&lt;sys/epoll.h&gt;"/>\r\n<mapping key\="sigset_t" value\="&lt;sys/select.h&gt;"/>\r\n<mapping key\="size_t" value\="&lt;cstddef&gt;"/>\r\n<mapping key\="size_t" value\="&lt;stddef.h&gt;"/>\r\n<mapping key\="socklen_t" value\="&lt;arpa/inet.h&gt;"/>\r\n<mapping key\="socklen_t" value\="&lt;bits/socket.h&gt;"/>\r\n<mapping key\="socklen_t" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="ssize_t" value\="&lt;monetary.h&gt;"/>\r\n<mapping key\="ssize_t" value\="&lt;sys/msg.h&gt;"/>\r\n<mapping key\="ssize_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="ssize_t" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="std\:\:allocator" value\="&lt;map&gt;"/>\r\n<mapping key\="std\:\:allocator" value\="&lt;memory&gt;"/>\r\n<mapping key\="std\:\:allocator" value\="&lt;set&gt;"/>\r\n<mapping key\="std\:\:allocator" value\="&lt;string&gt;"/>\r\n<mapping key\="std\:\:allocator" value\="&lt;vector&gt;"/>\r\n<mapping key\="std\:\:char_traits" value\="&lt;istream&gt;"/>\r\n<mapping key\="std\:\:char_traits" value\="&lt;ostream&gt;"/>\r\n<mapping key\="std\:\:char_traits" value\="&lt;string&gt;"/>\r\n<mapping key\="suseconds_t" value\="&lt;sys/select.h&gt;"/>\r\n<mapping key\="suseconds_t" value\="&lt;sys/time.h&gt;"/>\r\n<mapping key\="suseconds_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="u_char" value\="&lt;rpc/types.h&gt;"/>\r\n<mapping key\="u_char" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="uid_t" value\="&lt;pwd.h&gt;"/>\r\n<mapping key\="uid_t" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="uid_t" value\="&lt;stropts.h&gt;"/>\r\n<mapping key\="uid_t" value\="&lt;sys/ipc.h&gt;"/>\r\n<mapping key\="uid_t" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="uid_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="uid_t" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="useconds_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="useconds_t" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="va_list" value\="&lt;cstdarg&gt;"/>\r\n<mapping key\="va_list" value\="&lt;stdarg.h&gt;"/>\r\n</map>\r\n</maps>
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_method_declaration=do not insert
/bundle_defaults/com.crt.debugcommon/streamAll=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_LPC43xx_DriverLib.com.crt.advproject.projecttype.lib.446509596/com.crt.advproject.config.lib.debug.1706711087=com.crt.advproject.gas.lib.debug.873301014\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.1970136550\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.1706711087\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.470207401\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.1549626933\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.1636147693\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_colon_in_case=do not insert
/bundle_defaults/com.crt.debugcommon/genericImageVista=LPCXpressoWIN.enc
/bundle_defaults/org.eclipse.cdt.ui/c_default_bold=false
/bundle_defaults/org.eclipse.ui.workbench/SINGLE_CLICK_METHOD=0
/bundle_defaults/org.eclipse.ui.editors/showCarriageReturn=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/RDB1768cmsis_EasyWeb.com.crt.advproject.projecttype.exe.1503643990/com.crt.advproject.config.exe.release.290126908=com.crt.advproject.link.exe.release.1509719446\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.2064883050\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.73082454\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1034802894\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1878142690\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.1785118895\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/isWarningGoToNextNavigationTarget=true
/bundle_defaults/org.eclipse.core.resources/description.autobuilding=true
/bundle_defaults/org.eclipse.cdt.ui/c_keyword_italic=false
/bundle_defaults/org.eclipse.cdt.core/indexer/indexerId=org.eclipse.cdt.core.fastIndexer
/bundle_defaults/org.eclipse.ui/initialFastViewBarLocation=bottom
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.taskCaseSensitive=false
/bundle_defaults/org.eclipse.ui.editors/isSearchResultGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.ui/wrapStrings=true
/bundle_defaults/org.eclipse.cdt.ui/matchingBrackets=true
/bundle_defaults/org.eclipse.ui.editors/changeIndication=false
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.functionOffsetsColor=96,0,0
/bundle_defaults/org.eclipse.ui.editors/currentLine=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.PREF_FILTER_LAUNCH_CLOSED=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_arguments_in_method_invocation=16
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.overloadedOperator.strikethrough=false
/bundle_defaults/org.eclipse.ui.editors/showLeadingTabs=true
/bundle_defaults/org.eclipse.ui.editors/searchResultIndicationColor=206,204,247
/bundle_defaults/org.eclipse.ui.editors/linked.exit.color=0,180,0
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.indexDBCacheSizePct=10
/bundle_defaults/org.eclipse.ui/showIntro=true
/bundle_defaults/org.eclipse.cdt.ui/closeStrings=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.ExpressionView+org.eclipse.debug.ui.ShowTypeNamesAction=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_declarator_list=insert
/bundle_defaults/org.eclipse.ui.editors/breakpointIndication=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_type_declaration=end_of_line
/instance/org.eclipse.cdt.managedbuilder.core/properties/webserver.com.crt.advproject.projecttype.exe.1345313107/com.crt.advproject.config.exe.debug.1009041700=com.crt.advproject.link.exe.debug.58094435\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1443586811\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1759689025\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.629714332\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1009041700\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.902041439\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1467576585\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.workspaceLanguageMappings=
/bundle_defaults/com.crt.debugcommon/genericPID=9
/instance/org.eclipse.cdt.managedbuilder.core/properties/usbd_lib_cdc_uart.com.crt.advproject.projecttype.exe.1798150368/com.crt.advproject.config.exe.debug.633067605=com.crt.advproject.config.exe.debug.633067605\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.92055126\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1784962483\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.486503944\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.2038387832\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.1475022981\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1429105598\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.templateParameter.italic=false
/bundle_defaults/org.eclipse.cdt.ui/c_operators_italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.label.color=0,0,0
/bundle_defaults/org.eclipse.ui.editors/isSearchResultGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/hyperlinkColor.SystemDefault=true
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Color.Background=255,255,255
/bundle_defaults/org.eclipse.ui.editors/hyperlinkKeyModifier=Ctrl
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.PREF_CHANGED_VALUE_BACKGROUND=255,255,0
/bundle_defaults/org.eclipse.ui.editors/isRevisionAnnotationGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.ui.ide/useSeparator.help.group.assist=true
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk.scheduler/download=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_array_initializer=insert
/instance/org.eclipse.cdt.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_watchdog.com.crt.advproject.projecttype.exe.720126098/com.crt.advproject.config.exe.debug.1064966769=com.crt.advproject.link.cpp.exe.debug.255382564\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.101020260\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.802481234\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1669682648\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1321532069\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.469196116\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1064966769\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_timer.com.crt.advproject.projecttype.exe.1309499312/com.crt.advproject.config.exe.debug.813915632=com.crt.advproject.toolchain.exe.debug.1571077862\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.64635116\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.713280462\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1673697699\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1163178252\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.135101893\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.813915632\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.namespace.strikethrough=false
/instance/org.eclipse.debug.ui/pref_state_memento.com.crt.peripheral.PeripheralView=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<VariablesViewMemento org.eclipse.debug.ui.SASH_DETAILS_PART\="315" org.eclipse.debug.ui.SASH_VIEW_PART\="684">\r\n<PRESENTATION_CONTEXT_PROPERTIES IMemento.internal.id\="PeripheralView">\r\n<BOOLEAN BOOLEAN\="true" IMemento.internal.id\="org.eclipse.debug.ui.check"/>\r\n</PRESENTATION_CONTEXT_PROPERTIES>\r\n</VariablesViewMemento>
/bundle_defaults/org.eclipse.cdt.ui/autoOpenConsole=true
/bundle_defaults/org.eclipse.ui.editors/linked.focus.text=true
/bundle_defaults/org.eclipse.core.resources/description.buildorder=
/bundle_defaults/org.eclipse.ui/SHIFT_OPEN_NEW_PERSPECTIVE=OPEN_PERSPECTIVE_REPLACE
/bundle_defaults/org.eclipse.ui.editors/othersIndicationInOverviewRuler=false
/bundle_defaults/org.eclipse.ui.ide/PROBLEMS_LIMIT=100
@org.eclipse.ui.workbench=3.106.1.v20140827-1737
/bundle_defaults/org.eclipse.cdt.ui/asm_label_bold=true
/bundle_defaults/org.eclipse.ui.editors/currentIPVerticalRuler=true
/bundle_defaults/org.eclipse.ui.editors/linked.focus.navigation.dropdown=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.header.capitalization=0
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_ritimer.com.crt.advproject.projecttype.exe.749237195/com.crt.advproject.config.exe.debug.1653325222=com.crt.advproject.link.exe.debug.1504230950\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1653325222\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.231976127\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.2077790918\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1951440756\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.1396920523\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.269804934\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/showTrailingIdeographicSpaces=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/webserver.com.crt.advproject.projecttype.exe.1345313107/com.crt.advproject.config.exe.release.1745840165=com.crt.advproject.toolchain.exe.release.295553106\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1306344566\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.2133637469\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.356011277\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.87988994\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.2038740337\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.editor.CElementHyperlinkDetector_stateMask=-1
/bundle_defaults/org.eclipse.ui.editors/filteredSearchResultIndicationInVerticalRuler=false
/bundle_defaults/org.eclipse.ui.workbench/ENABLE_COOL_BARS=true
/bundle_defaults/org.eclipse.cdt.core/indexer/indexOnOpen=false
/bundle_defaults/org.eclipse.ui.editors/linked.focus.verticalruler=false
/bundle_defaults/org.eclipse.cdt.ui/removeTrailingWhitespaceEditedLines=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.label.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.sameFolder=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style angle_brackets\="false" blank_line_before\="false" keep_together\="false" relative_path\="false"/>
/bundle_defaults/org.eclipse.ui.editors/showEnclosedSpaces=true
/bundle_defaults/org.eclipse.ui.editors/warningIndicationHighlighting=false
/bundle_defaults/org.eclipse.ui.workbench/USE_IPERSISTABLE_EDITORS=true
/bundle_defaults/org.eclipse.ui/ALTERNATE_OPEN_NEW_PERSPECTIVE=OPEN_PERSPECTIVE_REPLACE
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.NavigationEndActionLocal=loop
/bundle_defaults/com.crt.utils/useXMLcache=true
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Color.Foreground=0,0,0
/instance/org.eclipse.cdt.managedbuilder.core/properties/usbd_lib_cdc.com.crt.advproject.projecttype.exe.218798441/com.crt.advproject.config.exe.release.1194419284=com.crt.advproject.toolchain.exe.release.226839519\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.78030496\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.75777627\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.183333774\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.524848630\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.414188755\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.parameterVariable.enabled=false
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.related=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style blank_line_before\="false" keep_together\="false"/>
/bundle_defaults/org.eclipse.ui.editors/warn_if_input_derived=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.class.color=0,80,50
/bundle_defaults/com.crt.advproject/tempaddpaths=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticMethod.enabled=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/usbd_lib_hid_keyboard.com.crt.advproject.projecttype.exe.944853395/com.crt.advproject.config.exe.release.134692510=com.crt.advproject.toolchain.exe.release.1409852559\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1648508565\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1285760810\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1182439007\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.2048303538\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.498522395\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_body_declarations_compare_to_access_specifier=true
/bundle_defaults/com.crt.debugcommon/redlink_wirespeed=0
/bundle_defaults/org.eclipse.ui.editors/warningIndicationColor=244,200,45
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.save_dirty_editors_before_launch=prompt
/bundle_defaults/org.eclipse.cdt.ui/escapeStrings=false
/bundle_defaults/org.eclipse.core.resources/description.snapshotinterval=300000
/bundle_defaults/org.eclipse.ui.editors/secondaryIPIndication=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_adc.com.crt.advproject.projecttype.exe.1322797204/com.crt.advproject.config.exe.debug.570937243=com.crt.advproject.cpp.exe.debug.1554540715\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.570937243\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.859166281\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.949246481\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.671560872\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.79095767\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.994761076\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/indexResultIndication=true
/bundle_defaults/org.eclipse.cdt.ui/content_assist_autoactivation_trigger_replace_dot_with_arrow=true
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk.scheduler/remindOnSchedule=false
/bundle_defaults/org.eclipse.cdt.core/includes.exportPattern=IWYU\\s+(pragma\:?\\s+)?export
/bundle_defaults/org.eclipse.core.net/proxyData/HTTP/port=-1
/bundle_defaults/org.eclipse.ui.editors/unchangedIndicationColor=0,0,0
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_method_declaration_parameters=insert
/bundle_defaults/org.eclipse.ui.editors/isUnchangedGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.header.suffix=.h
/bundle_defaults/org.eclipse.ui/ENABLE_ANIMATIONS=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_if=insert
@org.eclipse.debug.ui=3.10.1.v20140822-1408
/bundle_defaults/org.eclipse.ui.editors/breakpointTextStyle=SQUIGGLES
/instance/org.eclipse.cdt.managedbuilder.core/properties/usbd_lib_composite.com.crt.advproject.projecttype.exe.2137007679/com.crt.advproject.config.exe.debug.1644757415=com.crt.advproject.cpp.exe.debug.2103935598\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.2079787435\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1800337119\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.626770401\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.944544801\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.928595566\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1644757415\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleProblemWarningBackgroundColor=254,243,218
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.path_canonicalization=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_switch=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.compact_else_if=true
/bundle_defaults/org.eclipse.cdt.ui/org.eclipse.cdt.ui.add_comments=false
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.systemWithExtension=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style angle_brackets\="true" blank_line_before\="false" keep_together\="true" order\="1" relative_path\="false"/>
/profile/file\:\\2fC\:\\2fnxp\\2fLPCXpresso_7.6.2_326\\2flpcxpresso\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.ui.sdk.scheduler/migrated34Prefs=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.field.italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.methodDeclaration.enabled=true
/bundle_defaults/org.eclipse.ui/PROJECT_OPEN_NEW_PERSPECTIVE=OPEN_PERSPECTIVE_REPLACE
/bundle_defaults/org.eclipse.cdt.ui/content_assist_autoactivation_delay=500
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_switchstatements_compare_to_switch=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_ssp.com.crt.advproject.projecttype.exe.2073917783/com.crt.advproject.config.exe.release.1685172963=com.crt.advproject.toolchain.exe.release.1661677\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.710368125\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.623441189\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1209643826\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.818233716\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.364014591\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/organizeIncludes.heuristicHeader_substitution=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.VariableView+org.eclipse.debug.ui.ShowDetailPaneAction=true
/bundle_defaults/org.eclipse.ui.workbench/ENABLE_NEW_MENUS=true
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleProblemHighlightedColor=255,0,0
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticField.bold=false
/bundle_defaults/org.eclipse.cdt.ui/stickyOccurrences=true
/configuration/org.eclipse.core.net/org.eclipse.core.net.hasMigrated=true
/bundle_defaults/org.eclipse.ui/SHOW_OTHER_IN_PERSPECTIVE_MENU=true
/bundle_defaults/org.eclipse.ui.editors/errorIndicationHighlighting=false
/bundle_defaults/org.eclipse.ui.editors/rulerContributions=
/instance/org.eclipse.ui.browser/internalWebBrowserHistory=file\:///C\:/nxp/LPCXpresso_7.6.2_326/lpcxpresso/pages/registeredFreeEdition.htm|*|file\://C\:/nxp/LPCXpresso_7.6.2_326/lpcxpresso/pages/registeredFreeEdition.htm|*|
/bundle_defaults/org.eclipse.ui.editors/changeIndicationInVerticalRuler=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_unary_operator=do not insert
/bundle_defaults/org.eclipse.ui.editors/errorTextStyle=PROBLEM_UNDERLINE
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.taskPriorities=normal
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Color.SelectionBackground.SystemDefault=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/webserver_freertos.com.crt.advproject.projecttype.exe.874780069/com.crt.advproject.config.exe.debug.1886496314=com.crt.advproject.cpp.exe.debug.1593928491\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1762572644\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.219570910\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1886496314\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.2046392211\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1488348836\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.457726334\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/isAdditionGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroSubstitution.italic=false
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.AddedLinesRegex=
/instance/org.eclipse.debug.ui/pref_state_memento.org.eclipse.debug.ui.RegisterView=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<VariablesViewMemento org.eclipse.debug.ui.SASH_DETAILS_PART\="315" org.eclipse.debug.ui.SASH_VIEW_PART\="684"/>
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_method_declaration=end_of_line
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_clkout.com.crt.advproject.projecttype.exe.1523737329/com.crt.advproject.config.exe.release.1167106413=com.crt.advproject.link.exe.release.530856060\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.845256876\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1838478822\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.781739769\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.508594437\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.305904039\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/scalability.detect=true
/bundle_defaults/org.eclipse.cdt.ui/org.eclipse.cdt.internal.ui.text.doctools.doxygen.multi=63,95,191
/bundle_defaults/org.eclipse.ui/EDITOR_MINIMUM_CHARACTERS=-1
/bundle_defaults/org.eclipse.cdt.ui/c_type_italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.method.enabled=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.MemoryHistoryKnownColor=0,0,0
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.error.overview=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroDefinition.italic=false
/bundle_defaults/org.eclipse.ui.editors/isBookmarkGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.switch_perspective_on_suspend=prompt
/bundle_defaults/org.eclipse.ui.editors/showTextHoverAffordance=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enum.italic=false
/bundle_defaults/org.eclipse.ui.editors/breakpointHighlight=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.cancel_launch_with_compile_errors=prompt
/bundle_defaults/org.eclipse.ui.editors/quickdiff.defaultProvider=org.eclipse.ui.internal.editors.quickdiff.LastSaveReferenceProvider
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_bracket=do not insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticMethod.italic=true
/bundle_defaults/org.eclipse.cdt.ui/function_output_parameters_before_input=false
/bundle_defaults/org.eclipse.ui.editors/linked.target.text.style=BOX
/bundle_defaults/org.eclipse.cdt.core/indexer/skipTypeReferences=false
/bundle_defaults/org.eclipse.cdt.ui/spelling_ignore_single_letters=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_after_opening_brace_in_array_initializer=do not insert
/bundle_defaults/org.eclipse.ui.ide/USE_MARKER_LIMITS=true
/bundle_defaults/org.eclipse.cdt.ui/c_braces=0,0,0
/bundle_defaults/com.crt.dsfdebug/bkptLocationFix=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/iperf_server.com.crt.advproject.projecttype.exe.1230739403/com.crt.advproject.config.exe.release.2134859713=com.crt.advproject.link.exe.release.1606298999\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.62265057\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1779487827\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.1452087926\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.2076973193\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.997436927\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/com.crt.debugcommon/debuggerName=arm-none-eabi-gdb
/bundle_defaults/org.eclipse.ui.workbench/EDITOR_TAB_WIDTH=3
/bundle_defaults/org.eclipse.cdt.ui/spelling_proposal_threshold=20
/bundle_defaults/org.eclipse.ui.ide/REFRESH_WORKSPACE_ON_STARTUP=false
@org.eclipse.ui.ide=3.10.1.v20140828-0944
/bundle_defaults/org.eclipse.ui/SHOW_TEXT_ON_PERSPECTIVE_BAR=true
/bundle_defaults/com.crt.debugcommon/showProgressInLog=false
/bundle_defaults/org.eclipse.cdt.ui/c_braces_italic=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_CORE_LPC17xx.com.crt.advproject.projecttype.lib.1132436677/com.crt.advproject.config.lib.debug.1991456843=com.crt.advproject.config.lib.debug.1991456843\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.1915179100\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.1423951452\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.1609401827\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.1973900125\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.1584584498\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.typedef.italic=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_CORE_LPC1102.com.crt.advproject.projecttype.lib.2134065871/com.crt.advproject.config.lib.debug.1171384745=com.crt.advproject.cpp.lib.debug.111687239\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.1229796127\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.1171384745\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.239783651\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.1219334096\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.1976020487\=rebuildState\\\=false\\r\\n\r\n
/instance/org.eclipse.cdt.managedbuilder.core/properties/LPCXpresso176x_timer.com.crt.advproject.projecttype.exe.1447070015/com.crt.advproject.config.exe.debug.1115091451=com.crt.advproject.gas.exe.debug.1691739915\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1083863975\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.922664229.1499417384\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.160123065\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1471583358\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1488813715\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1115091451.src/cr_startup_lpc176x.c\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.config.exe.debug.1115091451\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.922664229\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariableDeclaration.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticMethod.color=0,0,0
/instance/org.eclipse.cdt.core.prj-periph_blinky/indexer/preferenceScope=0
/bundle_defaults/com.crt.utils/showWelcomeView=true
/bundle_defaults/org.eclipse.ui/disableNewFastView=false
/bundle_defaults/org.eclipse.ui.editors/isFilteredSearchResultGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.ui/c_string_bold=false
/bundle_defaults/org.eclipse.ui.editors/useAnnotationsPrefPage=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_rtc.com.crt.advproject.projecttype.exe.605406851/com.crt.advproject.config.exe.debug.1144910716=com.crt.advproject.gas.exe.debug.1572169051\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.1573714766\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1144910716\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1005180494\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.962599421\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.2066055257\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1964125179\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariableDeclaration.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.typedef.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.parameterVariable.strikethrough=false
/bundle_defaults/com.crt.debugcommon/genericParameter=-wire\=winUSB
/bundle_defaults/com.crt.debugcommon/genericVID=8137
/instance/org.eclipse.cdt.managedbuilder.core/properties/LPCXpresso1768_systick.com.crt.advproject.projecttype.exe.783271606/com.crt.advproject.config.exe.release.591890536=com.crt.advproject.link.exe.release.2066767215\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.784804749\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.762673705\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.723349040\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1011426480\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.724136925\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_expressions_in_array_initializer=16
/bundle_defaults/org.eclipse.debug.core/org.eclipse.debug.core.USE_STEP_FILTERS=false
/bundle_defaults/org.eclipse.cdt.ui/org.eclipse.cdt.ui.editor.UseStructuralMode=false
/bundle_defaults/org.eclipse.ui.workbench/MULTI_KEY_ASSIST=true
/bundle_defaults/org.eclipse.cdt.ui/c_keyword=127,0,85
/bundle_defaults/org.eclipse.ui.editors/linked.exit.overviewruler=false
/bundle_defaults/com.crt.utils/commandPrompt=cmd.exe /C start
/bundle_defaults/org.eclipse.cdt.ui/content_assist_autoactivation_trigger_dot=true
/instance/org.eclipse.cdt.ui.prj-periph_blinky/buildConsole/keepLog=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_assignment=16
/bundle_defaults/org.eclipse.ui.editors/revisionRulerShowAuthor=false
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleOutputStreamColor=0,0,0
/bundle_defaults/org.eclipse.ui.editors/deletionIndicationColor=0,0,0
/bundle_defaults/org.eclipse.debug.ui/org.eclispe.debug.ui.memory.pageSize=20
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.field.underline=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.code_formatter=org.eclipse.cdt.core.defaultCodeFormatter
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.getter.wordDelimiter=
/bundle_defaults/org.eclipse.ui.editors/linked.slave.verticalruler=false
/bundle_defaults/org.eclipse.ui.workbench/EDITORLIST_SORT_CRITERIA=0
/bundle_defaults/org.eclipse.ui/ENABLE_MIN_MAX=true
/bundle_defaults/org.eclipse.ui.editors/additionIndicationInVerticalRuler=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_rtc.com.crt.advproject.projecttype.exe.605406851/com.crt.advproject.config.exe.release.2026987447=com.crt.advproject.link.cpp.exe.release.549761656\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1521143880\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.836740799\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1650596216\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1059462876\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.825377008\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_colon_in_case=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_while=do not insert
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.matchingPattern=
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_angle_bracket_in_template_arguments=do not insert
/bundle_defaults/org.eclipse.ui.editors/searchResultTextStyle=NONE
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.occurrenceIndicationInVerticalRuler=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/lpc_chip_175x_6x.com.crt.advproject.projecttype.lib.1977998334/com.crt.advproject.config.lib.debug.1264058482=com.crt.advproject.toolchain.lib.debug.593853259\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.1317359937\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.1653831520\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.1264058482\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.1864839615\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.756466351\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/bookmarkIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Color.SelectionForeground.SystemDefault=true
/bundle_defaults/org.eclipse.ui.editors/taskIndicationInOverviewRuler=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/usbd_lib_cdc.com.crt.advproject.projecttype.exe.218798441/com.crt.advproject.config.exe.debug.1792480862=com.crt.advproject.cpp.exe.debug.316691243\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1390072318\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.336376765\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.1082991463\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1302775373\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1792480862\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1330040580\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.core/includes.beginExportsPattern=IWYU\\s+(pragma\:?\\s+)?begin_exports?
/bundle_defaults/org.eclipse.ui.workbench/REUSE_OPEN_EDITORS_BOOLEAN=false
/bundle_defaults/com.crt.debugcommon/redlink_showTimestamps=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_compact_if=16
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_cast=do not insert
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_CORE_LPC11xx.com.crt.advproject.projecttype.lib.663819903/com.crt.advproject.config.lib.debug.1575154836=com.crt.advproject.config.lib.debug.1575154836\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.1921248460\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.483294928\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.224538997\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.1059437607\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.2095482798\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/com.crt.debugcommon/probe_use_old=true
/bundle_defaults/org.eclipse.debug.ui/org.eclispe.debug.ui.memory.postBufferSize=20
/bundle_defaults/org.eclipse.cdt.core/scalability.maximumTokens=25000000
/instance/org.eclipse.cdt.ui/spelling_locale_initialized=true
/bundle_defaults/org.eclipse.ui.editors/taskIndicationColor=0,128,255
/instance/org.eclipse.ui.ide/quickStart=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.remove_breakpoints_from_container_prompt=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticField.enabled=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_colon_in_labeled_statement=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_catch=do not insert
/bundle_defaults/org.eclipse.ui.editors/infoIndicationHighlighting=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.warning.color=255,255,0
/bundle_defaults/org.eclipse.cdt.ui/pp_default=0,0,0
/bundle_defaults/org.eclipse.ui.editors/showUnchangedInNextPrevDropdownToolbarAction=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/LPCXpresso1768_systick_twinkle.com.crt.advproject.projecttype.exe.2094231798/com.crt.advproject.config.exe.release.116571318=com.crt.advproject.link.cpp.exe.release.1527474121\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.26164475\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1526285554\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1124414934\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.2032773937\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1519254681\=rebuildState\\\=true\\r\\n\r\n
/instance/org.eclipse.cdt.managedbuilder.core/properties/ucos_iii_blinky.com.crt.advproject.projecttype.exe.113910480/com.crt.advproject.config.exe.debug.1728897436=com.crt.advproject.link.cpp.exe.debug.39638239\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1728897436\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1483790199\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1570489508\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1408003178\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.35123696\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1988230386\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_before_colon_in_constructor_initializer_list=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_enumerator_list=48
/bundle_defaults/org.eclipse.ui.editors/isBreakpointIndicationGoToNextNavigationTarget=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/usbd_lib_cdc_uart.com.crt.advproject.projecttype.exe.1798150368/com.crt.advproject.config.exe.release.1739015961=com.crt.advproject.toolchain.exe.release.140139306\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1080565756\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1212717813\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.271070702\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.182351402\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.875397863\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.workbench/overridepresentation=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.showoverrideIndicatorInNextPrevDropdownToolbarAction=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_colon_in_base_clause=do not insert
/bundle_defaults/org.eclipse.cdt.ui/hoverModifierMasks=org.eclipse.cdt.ui.BestMatchHover;0;org.eclipse.cdt.ui.CSourceHover;131072
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroDefinition.bold=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroSubstitution.enabled=false
/bundle_defaults/org.eclipse.cdt.ui/c_comment_task_tag_italic=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_semicolon_in_for=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_template_arguments=do not insert
/bundle_defaults/org.eclipse.cdt.dsf.gdb/defaultGdbCommand=gdb
/bundle_defaults/org.eclipse.cdt.codan.core/inEditor=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_blinky.com.crt.advproject.projecttype.exe.424940172/com.crt.advproject.config.exe.debug.320861772=com.crt.advproject.link.cpp.exe.debug.687245962\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.823968430\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.406618380\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1748761643\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.320861772\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1200583274\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1441851293\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/class_member_ascending_visibility_order=false
/bundle_defaults/org.eclipse.cdt.ui/sourceHoverBackgroundColor.SystemDefault=true
/bundle_defaults/org.eclipse.ui.editors/searchResultIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/linked.target.text=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.isOverrideIndicatorGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.ui/SHOW_TRADITIONAL_STYLE_TABS=true
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.UseOutlineView=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.RemoveFromLaunchHistory=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.method.color=0,0,0
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk.scheduler/showUpdateWizard=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.header.prefix=
/bundle_defaults/com.crt.advproject/createlinkerscript=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.LaunchParentProject=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.overloadedOperator.color=200,100,0
/bundle_defaults/org.eclipse.cdt.ui/Refactor.lightweight=true
/bundle_defaults/org.eclipse.debug.ui/Console.limitConsoleOutput=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_method_declaration=do not insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariable.enabled=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/LPCXpresso1768_systick_twinkle.com.crt.advproject.projecttype.exe.2094231798/com.crt.advproject.config.exe.debug.1700699240=org.eclipse.cdt.managedbuilder.ui.rcbs.1179417422\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.726819074\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1215601901\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.557441015\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1188391701\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1700699240.1872544513\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1543468204\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1700699240\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1215601901.1916540435\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.2118247634\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/spacesForTabs=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_after_template_declaration=do not insert
/bundle_defaults/org.eclipse.ui.editors/linked.target.overviewruler=false
/bundle_defaults/org.eclipse.ui.editors/deletionIndicationInOverviewRuler=false
/bundle_defaults/org.eclipse.ui.editors/linked.exit.text=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariableDeclaration.bold=false
/bundle_defaults/org.eclipse.ui.editors/bookmarkTextStyle=SQUIGGLES
/bundle_defaults/org.eclipse.core.resources/snapshots.operations=100
/bundle_defaults/org.eclipse.ui.editors/bookmarkIndication=false
/bundle_defaults/org.eclipse.ui.editors/indexResultIndicationColor=254,155,0
/bundle_defaults/org.eclipse.cdt.codan.core/onBuild=false
/bundle_defaults/org.eclipse.cdt.ui/closeAngularBrackets=true
/bundle_defaults/org.eclipse.cdt.ui/consoleOnTop=false
/bundle_defaults/org.eclipse.ui.editors/termin=110,220,110
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_watchdog.com.crt.advproject.projecttype.exe.720126098/com.crt.advproject.config.exe.release.1738151752=com.crt.advproject.cpp.exe.release.1487373402\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.417315122\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1915328161\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1683719605\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1429431212\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1097649050\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/breakpointIndicationColor=0,0,255
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_postfix_operator=do not insert
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_systick.com.crt.advproject.projecttype.exe.349735055/com.crt.advproject.config.exe.debug.1708114495=com.crt.advproject.gas.exe.debug.1510048182\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.470430945\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.1179205170\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1099851258\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1708114495\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.636559943\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.2110503964\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.dsf.gdb/maxGdbTraces=500000
/bundle_defaults/org.eclipse.cdt.ui/inactiveCodeColor=224,224,224
/instance/org.eclipse.cdt.managedbuilder.core/properties/lpcusblib_KeyboardHost.com.crt.advproject.projecttype.exe.1776494588/com.crt.advproject.config.exe.release.675946607=com.crt.advproject.cpp.exe.release.1593360022\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1250332176\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.6763122\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1816566527\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1063855647\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1543449802\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticMethod.strikethrough=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_constructor_initializer_list=0
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.method.strikethrough=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_CORE_LPC11xxLV.com.crt.advproject.projecttype.lib.1331552380/com.crt.advproject.config.lib.debug.1498659410=com.crt.advproject.gas.lib.debug.205943174\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.1476934997\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.1658191416\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.1000541325\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.1498659410\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.182558187\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/com.crt.debugcommon/genericEnabled=false
/instance/org.eclipse.cdt.core.prj-CMSISv2p00_LPC17xx/indexer/preferenceScope=0
/bundle_defaults/org.eclipse.cdt.core/scalability.skipTrivialExpressions=true
/bundle_defaults/org.eclipse.cdt.ui/handleTemporaryProblems=true
/bundle_defaults/org.eclipse.cdt.ui/c_single_line_comment=63,127,95
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.memory.columnSize=4
/bundle_defaults/com.crt.debugcommon/serverPort=0
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.warning.ruler=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/lpc_board_nxp_lpcxpresso_1769.com.crt.advproject.projecttype.lib.1078462419/com.crt.advproject.config.lib.debug.267437161=com.crt.advproject.gcc.lib.debug.1874917562\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.224156237\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.787516598\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.1176373407\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.267437161\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.486889114\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/linked.exit.highlight=false
/bundle_defaults/org.eclipse.cdt.ui/c_comment_task_tag=127,159,191
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroSubstitution.color=0,0,0
/bundle_defaults/org.eclipse.ui.editors/showChangeInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_angle_bracket_in_template_parameters=do not insert
/bundle_defaults/org.eclipse.cdt.ui/c_type=127,0,85
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticMethod.underline=false
/bundle_defaults/com.crt.dsfdebug/altRefreshBehavior=true
/bundle_defaults/org.eclipse.ui.editors/warningIndication=true
/bundle_defaults/org.eclipse.ui.workbench/EDITORLIST_PULLDOWN_ACTIVE=false
/bundle_defaults/org.eclipse.core.net/proxiesEnabled=true
/bundle_defaults/org.eclipse.ui.workbench/STICKY_CYCLE=false
/bundle_defaults/org.eclipse.cdt.ui/c_numbers_italic=false
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleLines=500
/bundle_defaults/org.eclipse.ui.workbench/SELECT_ON_HOVER=false
/bundle_defaults/org.eclipse.ui.editors/revisionAnnotationIndicationInVerticalRuler=false
/bundle_defaults/org.eclipse.ui.editors/linked.exit.navigation.dropdown=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_method_invocation=do not insert
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Color.Foreground.SystemDefault=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.label.italic=false
/bundle_defaults/com.crt.debugcommon/relink_dfu_find=true
/bundle_defaults/org.eclipse.cdt.dsf.gdb/defaultStopAtMainSymbol=main
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.format_guardian_clause_on_one_line=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_base_clause_in_type_declaration=80
/bundle_defaults/org.eclipse.ui.editors/linked.slave.navigation.previous=false
/bundle_defaults/org.eclipse.ui.editors/isAdditionGoToPreviousNavigationTarget=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/RDB1768cmsis_EasyWeb.com.crt.advproject.projecttype.exe.1503643990/com.crt.advproject.config.exe.debug.1095747236=com.crt.advproject.gcc.exe.debug.583453200.830262054\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.784245429\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1095747236\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.583453200\=rebuildState\\\=false\\r\\n\r\norg.eclipse.cdt.managedbuilder.ui.rcbs.409250964\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.debug.237846413\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.181471\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1617126296\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.2070344148\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1095747236.934195708\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.warning.NextPrevDropdownToolbar=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_conditional_expression_chain=18
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.writeOccurrenceTextStyle=NONE
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.OpenStructureCompare=true
/bundle_defaults/org.eclipse.ui.editors/errorIndicationColor=255,0,128
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_default_macros=false
/bundle_defaults/org.eclipse.ui.workbench/OPEN_AFTER_DELAY=false
/bundle_defaults/org.eclipse.debug.core/org.eclipse.debug.core.PREF_DELETE_CONFIGS_ON_PROJECT_DELETE=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.constant.suffix=
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_member_access=0
/bundle_defaults/com.crt.utils/showVerboseErrors=true
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.setter.capitalization=3
/bundle_defaults/org.eclipse.cdt.core/indexer/skipIncludedFilesLargerThanMB=16
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.parameterVariable.color=0,0,0
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_expression_list=0
/bundle_defaults/org.eclipse.ui.editors/isInfoGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/unchangedIndicationInOverviewRuler=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariable.underline=false
/bundle_defaults/org.eclipse.ui.editors/linked.slave.text.style=NONE
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_pmu.com.crt.advproject.projecttype.exe.1242046794/com.crt.advproject.config.exe.release.389189387=com.crt.advproject.toolchain.exe.release.978190380\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1470029090\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.1578400653\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1415685171\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1480216083\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1728937052\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.warning.GoToNextNavigationTarget=true
/profile/file\:\\2fC\:\\2fnxp\\2fLPCXpresso_7.6.2_326\\2flpcxpresso\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.ui.sdk.scheduler/autoUpdateInit=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.typedef.bold=false
/bundle_defaults/org.eclipse.cdt.core/indexer/skipFilesLargerThanMB=8
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_CORE_LPC12xx.com.crt.advproject.projecttype.lib.2046742754/com.crt.advproject.config.lib.debug.1869600139=com.crt.advproject.ar.lib.debug.2046574041\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.1869600139\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.1067127894\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.1038768540\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.26316877\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.223437482\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/warningTextStyle=PROBLEM_UNDERLINE
/bundle_defaults/org.eclipse.ui.editors/secondaryIPColor=219,235,204
/bundle_defaults/org.eclipse.cdt.ui/content_assist_autoactivation_trigger_doublecolon=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.field.enabled=true
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.getter.prefixForBoolean=is
/bundle_defaults/org.eclipse.ui.editors/showWarningInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.ui.editors/breakpointVerticalRuler=true
/bundle_defaults/org.eclipse.cdt.dsf.gdb/org.eclipse.cdt.dsf.gdb.commandTimeout=false
/instance/org.eclipse.debug.ui/preferredTargets=org.eclipse.cdt.debug.ui.toggleCBreakpointTarget,org.eclipse.cdt.debug.ui.toggleCDynamicPrintfTarget\:org.eclipse.cdt.debug.ui.toggleCBreakpointTarget|
/bundle_defaults/org.eclipse.cdt.ui/closeBraces=true
/bundle_defaults/org.eclipse.ui.editors/isWarningGoToPreviousNavigationTarget=true
/bundle_defaults/org.eclipse.cdt.ui/c_operators_bold=false
/bundle_defaults/com.crt.utils/quickstart.navlink=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.field.bold=false
/bundle_defaults/org.eclipse.ui.editors/showBookmarkInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.startAddress=0
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_body_declarations_compare_to_namespace_header=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_cast=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_between_empty_parens_in_exception_specification=do not insert
/bundle_defaults/org.eclipse.ui.workbench/HeapStatus.updateInterval=500
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_LPC43xx_DriverLib-M0.com.crt.advproject.projecttype.lib.1313392389/com.crt.advproject.config.lib.debug.489607714=com.crt.advproject.cpp.lib.debug.1400584359\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.1662940542\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.173058116\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.2039253860\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.1035256333\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.489607714\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.debug.core/org.eclipse.cdt.debug.corecDebug.character_set=UTF-16
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.showOccurrenceInNextPrevDropdownToolbarAction=true
/bundle_defaults/com.crt.debugcommon/swvPacketTimeout=0
/bundle_defaults/org.eclipse.cdt.core/indexer/indexUnusedHeadersWithAlternateLang=false
/bundle_defaults/org.eclipse.ui.editors/spellingIndicationColor=255,128,64
/bundle_defaults/org.eclipse.core.resources/description.maxfilestatesize=1048576
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.continuation_indentation=2
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Color.FindScope=185,176,180
/bundle_defaults/org.eclipse.ui.editors/isChangeGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/additionIndicationInOverviewRuler=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.globalVariable.color=0,0,0
/bundle_defaults/org.eclipse.cdt.core/scalability.maximumTrivialExpressions=1000
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.show_run_perspective_default=perspective_none
/bundle_defaults/org.eclipse.cdt.ui/organizeIncludes.allowReordering=true
/bundle_defaults/org.eclipse.ui.editors/isErrorGoToNextNavigationTarget=true
/bundle_defaults/com.crt.debugcommon/driver_settle=30
/bundle_defaults/com.crt.utils/crt.diagnostics=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.occurrenceIndication=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_expression_list=do not insert
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.getter.capitalization=3
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_template_parameters=insert
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.error.GoToPreviousNavigationTarget=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_switch=insert
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.remove_all_breakpoints_prompt=true
/bundle_defaults/org.eclipse.cdt.ui/spelling_user_dictionary_encoding=Cp1254
/bundle_defaults/com.crt.debugcommon/extendedLogging=false
/bundle_defaults/org.eclipse.ui/PROMPT_WHEN_SAVEABLE_STILL_OPEN=true
/bundle_defaults/com.crt.dsfdebug/altLabelProvider=false
/bundle_defaults/org.eclipse.ui.editors/useQuickDiffPrefPage=false
/bundle_defaults/org.eclipse.ui.ide/LIMIT_PROBLEMS=true
/bundle_defaults/org.eclipse.ui.editors/linked.focus.highlight=false
/bundle_defaults/org.eclipse.cdt.ui/c_single_line_comment_bold=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_method_declaration_throws=insert
/bundle_defaults/org.eclipse.cdt.ui/content_assist_proposal_filter=0;<Default Filter>
/bundle_defaults/com.crt.dsfdebug/altTerminate=false
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.showAddressRadix=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.problem.underline=false
/bundle_defaults/org.eclipse.cdt.ui/function_pass_output_parameters_by_pointer=false
/bundle_defaults/org.eclipse.ui.workbench/ENABLE_CONFIGURABLE_PROJECT_WIZARD=false
/bundle_defaults/org.eclipse.debug.ui/Expressions.detail.orientation=Variables.detail.orientation.underneath
/bundle_defaults/org.eclipse.ui.workbench/EDITORLIST_DISPLAY_FULL_NAME=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.PREF_FILTER_WORKING_SETS=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.function.italic=false
/bundle_defaults/com.crt.config/urlBase=
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticField.italic=true
/instance/org.eclipse.cdt.core.prj-LPCX176x_cmsis2_timers/indexer/preferenceScope=0
@org.eclipse.core.resources=3.9.1.v20140825-1431
/bundle_defaults/org.eclipse.cdt.debug.core/org.eclipse.cdt.debug.corecDebug.non_wide_character_set=windows-1254
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.InitiallyShowAncestorPane=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_statements_compare_to_body=true
/bundle_defaults/org.eclipse.cdt.core/build.proj.ref.configs.enabled=false
/bundle_defaults/org.eclipse.cdt.ui/codetemplates.includeGuardGenerationScheme=2
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.method.suffix=
/bundle_defaults/org.eclipse.ui.editors/com.crt.etmetb.marker.profile.pref.text=true
/bundle_defaults/org.eclipse.ui.workbench/WORKBENCH_SAVE_INTERVAL=5
/bundle_defaults/org.eclipse.ui.editors/spellingIndicationInOverviewRuler=false
/bundle_defaults/com.crt.dsfdebug/arrayChunkSize=100
/bundle_defaults/org.eclipse.ui.ide/BOOKMARKS_FILTERS_MIGRATE=false
/bundle_defaults/org.eclipse.ui.editors/taskIndication=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_method_declaration=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_if=do not insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.class.bold=false
/bundle_defaults/org.eclipse.ui.editors/changeIndicationColor=204,163,205
/bundle_defaults/org.eclipse.ui.editors/linked.target.highlight=false
/bundle_defaults/org.eclipse.ui.workbench/BIDI_SUPPORT=false
/bundle_defaults/org.eclipse.cdt.ui/asm_directive_bold=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticField.color=0,0,192
/bundle_defaults/org.eclipse.ui.editors/linked.focus.navigation.next=false
/bundle_defaults/org.eclipse.ui.editors/isInfoGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_exception_specification=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_expression_list=insert
/bundle_defaults/org.eclipse.ui.editors/revisionRulerRenderingMode=Age
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_switch=end_of_line
/bundle_defaults/org.eclipse.cdt.ui/content_assist_project_search_scope=false
@org.eclipse.ui.editors=3.8.200.v20140401-1310
/bundle_defaults/org.eclipse.cdt.ui/Refactoring.savealleditors=false
/bundle_defaults/org.eclipse.ui.ide/TASKS_LIMIT=100
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.externalSDK.underline=false
/bundle_defaults/org.eclipse.ui.editors/additionIndication=false
/bundle_defaults/org.eclipse.cdt.ui/c_type_bold=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_overloaded_left_shift_chain=16
/bundle_defaults/org.eclipse.cdt.ui/closeBrackets=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.MemoryHistoryUnknownColor=114,119,129
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_pinint.com.crt.advproject.projecttype.exe.500409353/com.crt.advproject.config.exe.release.809780712=com.crt.advproject.gcc.exe.release.607726278\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1281540969\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1043201516\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1771186119\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.590733964\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.2046459755\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.ide/useSeparator.help.group.updates=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/freertos_blinky.com.crt.advproject.projecttype.exe.1693076455/com.crt.advproject.config.exe.release.514344055=com.crt.advproject.cpp.exe.release.596333881\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1233252549\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.572949477\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1942620602\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1909829756\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1745362883\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/pp_directive=127,0,85
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.externalSDK.strikethrough=false
/instance/org.eclipse.ui.ide/PROBLEMS_FILTERS_MIGRATE=true
/bundle_defaults/com.crt.debugcommon/Redlink\ Server=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_assignment_operator=insert
/bundle_defaults/org.eclipse.ui.editors/isTaskGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.dsf.gdb/useInspectorHover=true
/bundle_defaults/com.crt.advproject/addchipdescriptions=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_between_empty_brackets=do not insert
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.track_views=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/lwip_tcpecho_freertos.com.crt.advproject.projecttype.exe.1420589482/com.crt.advproject.config.exe.release.1056112912=com.crt.advproject.cpp.exe.release.2063395937\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.572207940\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1638490324\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.288331770\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.738637504\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.792758414\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_for=insert
/instance/org.eclipse.ui.editors/overviewRuler_migration=migrated_3.1
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.showSourceFilesInBinaries=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_block_in_case=end_of_line
/instance/org.eclipse.cdt.managedbuilder.core/properties/lpcusblib_MassStorageHost.com.crt.advproject.projecttype.exe.71920452/com.crt.advproject.config.exe.release.602528808=com.crt.advproject.toolchain.exe.release.1566228802\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1136674319\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.60566226\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1225949085\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.213504139\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.143744362\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/com.crt.advproject/linkscriptdir=linkscripts
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.methodDeclaration.bold=true
/bundle_defaults/org.eclipse.ui.editors/errorIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/revisionAnnotationIndication=false
@org.eclipse.cdt.debug.core=7.5.0.201409172108
/bundle_defaults/org.eclipse.ui.editors/linked.target.navigation.previous=false
/bundle_defaults/org.eclipse.cdt.dsf.gdb/enablePrettyPrinting=true
/bundle_defaults/org.eclipse.core.resources/encoding=
/bundle_defaults/org.eclipse.ui.editors/unchangedIndication=false
/bundle_defaults/org.eclipse.core.resources/description.disableLinking=false
/bundle_defaults/org.eclipse.cdt.ui/forwardDeclare.functions=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_array_initializer=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_type_declaration=insert
/bundle_defaults/org.eclipse.ui.editors/tabWidth=4
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk/allowNonOKPlan=prompt
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_adc.com.crt.advproject.projecttype.exe.1322797204/com.crt.advproject.config.exe.release.1946989772=com.crt.advproject.gcc.exe.release.48021137\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.914124013\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.895665888\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.766485705\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1473272062\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.879936560\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Accessibility.WideCaret=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.problem.bold=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_access_specifier_compare_to_type_header=false
/bundle_defaults/com.crt.debugcommon/LPC-Link\ (HID)=true
file_export_version=3.0
/bundle_defaults/org.eclipse.cdt.core/includes.privatePattern=IWYU\\s+(pragma\:?\\s+)?private(,\\s+include\\s+(?<header>\\S+))?
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.inOtherProject=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style angle_brackets\="false" blank_line_before\="false" keep_together\="false" relative_path\="false"/>
/bundle_defaults/org.eclipse.ui.editors/linked.exit.text.style=IBEAM
/bundle_defaults/org.eclipse.cdt.ui/pp_directive_italic=false
/bundle_defaults/org.eclipse.cdt.ui/wizard.group.others.enable=true
/bundle_defaults/org.eclipse.ui.editors/isBreakpointIndicationGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariableDeclaration.color=128,0,0
/instance/org.eclipse.debug.core//org.eclipse.debug.core.PREFERRED_DELEGATES/org.eclipse.cdt.launch.attachLaunchType=org.eclipse.cdt.dsf.gdb.launch.attachCLaunch,debug,;
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.VariableView+org.eclipse.debug.ui.ShowTypeNamesAction=false
/bundle_defaults/org.eclipse.ui/OPEN_NEW_PERSPECTIVE=OPEN_PERSPECTIVE_REPLACE
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.problem.enabled=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_CORE_LPC13xx.com.crt.advproject.projecttype.lib.1385448813/com.crt.advproject.config.lib.debug.581745906=com.crt.advproject.ar.lib.debug.1292774045\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.1574829665\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.612994528\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.581745906\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.717048448\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.941307039\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_parenthesized_expression=do not insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.globalVariable.strikethrough=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.defaultEbcdicCodePage=CP037
/bundle_defaults/org.eclipse.ui.editors/secondaryIPVerticalRuler=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_clkout.com.crt.advproject.projecttype.exe.1523737329/com.crt.advproject.config.exe.debug.180527154=com.crt.advproject.link.exe.debug.1821395612\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.1745459261\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1708288974\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.556507730\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.180527154\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1687012010\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.2092012931\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/othersIndication=false
/bundle_defaults/com.crt.debugcommon/redlink_ask_to_boot=false
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.addressRadix=16
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indentation.size=4
/bundle_defaults/org.eclipse.cdt.ui/c_multi_line_comment_bold=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.constant.prefix=
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticMethod.bold=false
/bundle_defaults/org.eclipse.cdt.core/indexer/indexUnusedHeadersWithDefaultLang=true
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.opcodeRadix=16
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_block=insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enumerator.underline=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_spi.com.crt.advproject.projecttype.exe.1116578252/com.crt.advproject.config.exe.release.148649193=com.crt.advproject.link.cpp.exe.release.1766850755\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1024407775\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.503899537\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.575180509\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.38522315\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.922314565\=rebuildState\\\=true\\r\\n\r\n
/configuration/org.eclipse.ui.ide/MAX_RECENT_WORKSPACES=5
/bundle_defaults/org.eclipse.ui.editors/showDeletionInNextPrevDropdownToolbarAction=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.switch_to_perspective=never
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_CORE_LPC11Axx.com.crt.advproject.projecttype.lib.323077590/com.crt.advproject.config.lib.debug.155024037=com.crt.advproject.ar.lib.debug.619333461\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.479237615\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.155024037\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.453650134\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.143674930\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.130954740\=rebuildState\\\=false\\r\\n\r\n
/instance/org.eclipse.ui.workbench/UIActivities.org.eclipse.cdt.debug.dsfgdbActivity=true
/bundle_defaults/org.eclipse.ui.workbench/NL_EXTENSIONS=
/bundle_defaults/org.eclipse.core.net/proxyData/SOCKS/hasAuth=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.methodDeclaration.color=0,0,0
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.globalVariable.underline=false
/bundle_defaults/org.eclipse.cdt.core/indexer/skipMacroReferences=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.function.color=0,0,0
/bundle_defaults/org.eclipse.ui.editors/isRevisionAnnotationGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.core.net/systemProxiesEnabled=true
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.ShowPseudoConflicts=false
/bundle_defaults/org.eclipse.cdt.ui/c_default_italic=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.keep_then_statement_on_same_line=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_switch=do not insert
/bundle_defaults/org.eclipse.cdt.ui/org.eclipse.cdt.internal.ui.text.doctools.doxygen.single=63,95,191
/instance/org.eclipse.cdt.managedbuilder.core/properties/ucos_iii_blinky.com.crt.advproject.projecttype.exe.113910480/com.crt.advproject.config.exe.release.1706971613=com.crt.advproject.toolchain.exe.release.2108839201\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.848952791\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.513168767\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1970360558\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.135113262\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1079269625\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.parameterVariable.italic=false
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.showSource=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.isOccurrenceGoToPreviousNavigationTarget=false
/bundle_defaults/com.crt.quickstart/wizardTemplateSupport=true
/bundle_defaults/org.eclipse.cdt.ui/spelling_ignore_non_letters=true
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleBackgroundColor=255,255,255
/bundle_defaults/org.eclipse.ui.editors/linked.slave.text=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.writeOccurrenceIndicationInOverviewRuler=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/usbd_lib_composite.com.crt.advproject.projecttype.exe.2137007679/com.crt.advproject.config.exe.release.1869947099=com.crt.advproject.cpp.exe.release.1379756456\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1748461686\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1827532787\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.359222123\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.2090809526\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.393776227\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.workbench/DISABLE_OPEN_EDITOR_IN_PLACE=false
/bundle_defaults/org.eclipse.ui.editors/warningIndicationInVerticalRuler=true
/bundle_defaults/com.crt.quickstart/autpBrowseWeb=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.showSourceRootsAtTopLevelOfProject=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_in_empty_block=insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroSubstitution.bold=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.inColor=0,200,125
/bundle_defaults/org.eclipse.cdt.dsf.ui/stackFrameLimitEnable=true
/bundle_defaults/org.eclipse.ui.editors/revisionAnnotationIndicationColor=88,88,22
/bundle_defaults/com.crt.dsfdebug/attachRestart=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/usbd_lib_hid_generic.com.crt.advproject.projecttype.exe.1358948682/com.crt.advproject.config.exe.release.823668469=com.crt.advproject.toolchain.exe.release.1184916576\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.909534463\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1083649875\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.529656299\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.107267058\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.740681601\=rebuildState\\\=true\\r\\n\r\n
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES_PROTOCOL=3
/bundle_defaults/org.eclipse.cdt.ui/contentAssist.showCamelCaseMatches=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.keep_else_statement_on_same_line=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_method_invocation=do not insert
/bundle_defaults/org.eclipse.ui.editors/infoIndication=false
/bundle_defaults/org.eclipse.debug.ui/Variables.detail.orientation=Variables.detail.orientation.underneath
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enum.color=100,70,50
/bundle_defaults/com.crt.dsfdebug/extendedDebugTrace=0
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.parameterVariable.bold=false
/bundle_defaults/org.eclipse.ui.editors/textDragAndDropEnabled=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.methodDeclaration.underline=false
/bundle_defaults/org.eclipse.cdt.ui/c_single_line_comment_italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.namespace.bold=false
/profile/file\:\\2fC\:\\2fnxp\\2fLPCXpresso_7.6.2_326\\2flpcxpresso\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.ui.sdk/allowNonOKPlan=prompt
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.subfolder=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style angle_brackets\="false" blank_line_before\="false" keep_together\="false" relative_path\="false"/>
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.source.prefix=
/bundle_defaults/com.crt.advproject/library=newlib_nohost
/bundle_defaults/org.eclipse.ui.editors/whitespaceCharacterAlphaValue=80
/instance/org.eclipse.cdt.managedbuilder.core/properties/lpcusblib_MassStorageHost.com.crt.advproject.projecttype.exe.71920452/com.crt.advproject.config.exe.debug.1897601089=com.crt.advproject.gas.exe.debug.188816363\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1632082132\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.2136975254\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.641244994\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1837685795\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.1440619807\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1897601089\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/showSpellingInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.cdt.ui/spelling_ignore_urls=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_binary_operator=insert
/bundle_defaults/org.eclipse.ui.editors/showEnclosedTabs=true
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.test.suffix=_test.cpp
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.source.wordDelimiter=
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_default_headers=true
/bundle_defaults/org.eclipse.cdt.ui/c_operators=0,0,0
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Navigation.SmartHomeEnd=true
/bundle_defaults/org.eclipse.ui.editors/deletionIndication=false
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_default_methods=false
/bundle_defaults/org.eclipse.ui.editors/undoHistorySize=200
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.field.suffix=
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_parenthesized_expression=do not insert
/bundle_defaults/org.eclipse.debug.ui/Console.highWaterMark=100000
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_at_end_of_file_if_missing=do not insert
/bundle_defaults/org.eclipse.ui.editors/com.crt.etmetb.marker.profile.pref.overview=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_question_in_conditional=insert
/bundle_defaults/org.eclipse.ui.editors/currentIPIndication=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_colon_in_conditional=insert
/bundle_defaults/org.eclipse.cdt.debug.core/org.eclipse.cdt.debug.corecDebug.max_number_of_instructions=100
/bundle_defaults/org.eclipse.ui.workbench/MULTI_KEY_ASSIST_TIME=1000
/bundle_defaults/org.eclipse.cdt.ui/content_assist_autoactivation_trigger_arrow=true
/bundle_defaults/org.eclipse.cdt.ui/scalability.numberOfLines=5000
/bundle_defaults/org.eclipse.cdt.ui/organizeIncludes.unusedStatements=REMOVE
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_dac.com.crt.advproject.projecttype.exe.511991621/com.crt.advproject.config.exe.debug.1401400949=com.crt.advproject.link.cpp.exe.debug.691725567\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1614753469\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1401400949\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.645990063\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.571772906\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.574813121\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1661172651\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/c_keyword_bold=true
/bundle_defaults/org.eclipse.ui.workbench/OPEN_VIEW_MODE=0
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.globalVariable.enabled=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.field.wordDelimiter=
/bundle_defaults/org.eclipse.ui.editors/showTrailingTabs=true
/bundle_defaults/com.crt.config/vendor=NXP
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.method.prefix=
/bundle_defaults/com.crt.utils/spawnerTimeout=5000
/bundle_defaults/org.eclipse.ui.editors/othersIndicationColor=0,0,0
/bundle_defaults/com.crt.config/browser_internal=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.comment.preserve_white_space_between_code_and_line_comments=true
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.HighlightTokenChanges=true
@org.eclipse.cdt.managedbuilder.core=8.3.0.201409172108
/bundle_defaults/org.eclipse.cdt.ui/CEditor.ShowTemporaryProblem=false
/bundle_defaults/com.crt.debugcommon/genericStubMatch=.*
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_angle_bracket_in_template_parameters=do not insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.externalSDK.italic=false
/bundle_defaults/org.eclipse.ui.editors/currentLineColor=232,242,254
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_CORE_LPC177x_8x.com.crt.advproject.projecttype.lib.2013960403/com.crt.advproject.config.lib.debug.1827724080=com.crt.advproject.toolchain.lib.debug.2121956239\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.108587623\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.1569502926\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.1827724080\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.1646563063\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.1689288150\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_provider=org.eclipse.cdt.ui.text.defaultFoldingProvider
/bundle_defaults/com.crt.dsfdebug/complexExpressionBehavior=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_method_invocation_arguments=do not insert
/bundle_defaults/org.eclipse.ui.editors/currentIPOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/lineNumberColor=120,120,120
/bundle_defaults/org.eclipse.ui.ide/OPEN_REQUIRED_PROJECTS=prompt
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.class.enabled=true
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES=C\:\\Users\\Egitim5\\Documents\\LPCXpresso_7.6.2_326\\workspace
/bundle_defaults/org.eclipse.ui.editors/filteredSearchResultIndicationInOverviewRuler=false
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.SynchronizeScrolling=true
/bundle_defaults/org.eclipse.ui.editors/showBreakpointIndicationInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.cdt.ui/scalability.reconciler=true
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.variable.suffix=
/bundle_defaults/org.eclipse.ui.editors/isDeletionGoToPreviousNavigationTarget=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/usbd_lib_hid_mouse.com.crt.advproject.projecttype.exe.1164772426/com.crt.advproject.config.exe.debug.1247759680=com.crt.advproject.toolchain.exe.debug.1972215156\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.734843412\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1430832086\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1247759680\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.298929785\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.2016236950\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.2049096836\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/linked.focus.overviewruler=false
/bundle_defaults/org.eclipse.cdt.dsf.ui/minStepInterval=100
/bundle_defaults/org.eclipse.cdt.ui/ensureNewlineAtEOF=true
/bundle_defaults/org.eclipse.cdt.ui/c_multi_line_comment=63,127,95
/bundle_defaults/org.eclipse.ui/ENABLE_32_STICKY_CLOSE_BEHAVIOR=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.functionDeclaration.italic=false
/bundle_defaults/org.eclipse.cdt.ui/pp_directive_bold=true
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.method.capitalization=4
/bundle_defaults/org.eclipse.ui.ide/useSeparator.help.group.main=true
/bundle_defaults/org.eclipse.ui.ide/IMPORT_FILES_AND_FOLDERS_VIRTUAL_FOLDER_MODE=prompt
/bundle_defaults/org.eclipse.cdt.ui/scalability.contentAssistAutoActivation=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enumerator.bold=false
/bundle_defaults/org.eclipse.cdt.ui/smart_tab=true
/bundle_defaults/org.eclipse.ui.editors/infoIndicationInVerticalRuler=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_brace_in_array_initializer=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.tabulation.char=tab
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.globalVariable.bold=false
/instance/org.eclipse.cdt.core.prj-LPCX176x_cmsis2_EasyWeb/indexer/preferenceScope=0
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_dac.com.crt.advproject.projecttype.exe.511991621/com.crt.advproject.config.exe.release.319530200=com.crt.advproject.link.cpp.exe.release.1217990134\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1197744558\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1766615628\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.731175261\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1771472347\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.367199306\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/forwardDeclare.compositeTypes=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_method_declaration_throws=do not insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.globalVariable.italic=true
/bundle_defaults/org.eclipse.cdt.ui/clearConsole=true
/bundle_defaults/org.eclipse.ui.editors/linked.target.navigation.next=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_systick.com.crt.advproject.projecttype.exe.349735055/com.crt.advproject.config.exe.release.1432658484=com.crt.advproject.toolchain.exe.release.1075952010\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1242568218\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.264579604\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.60441288\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1322654774\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.236459667\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/content_assist_proposals_timeout=5000
/bundle_defaults/org.eclipse.ui/SHOW_FILTERED_TEXTS=true
/bundle_defaults/org.eclipse.ui.editors/show_range_indicator=true
*** Current Install Configuration:
Bundles in the system:
Id: com.crt.advproject, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.advproject_7.4.1.201502020932.jar
Id: com.crt.config, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.config_7.4.1.201502020932.jar
Id: com.crt.ctrlcenter, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.ctrlcenter_7.4.1.201502020932.jar
Id: com.crt.debugcommon, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.debugcommon_7.4.1.201502020932.jar
Id: com.crt.debugmgr, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.debugmgr_7.4.1.201502020932.jar
Id: com.crt.docs, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.docs_7.4.1.201502020932.jar
Id: com.crt.docs.rsguide, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.docs.rsguide_7.4.1.201502020932.jar
Id: com.crt.dsfdebug, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.dsfdebug_7.4.1.201502020932.jar
Id: com.crt.dsfswv, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.dsfswv_7.4.1.201502020932.jar
Id: com.crt.etmetb, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.etmetb_7.4.1.201502020932.jar
Id: com.crt.lite, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.lite_7.4.1.201502020932.jar
Id: com.crt.lpcxpresso.brand, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.lpcxpresso.brand_7.4.1.201502020932.jar
Id: com.crt.quickstart, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.quickstart_7.4.1.201502020932.jar
Id: com.crt.redstate, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.redstate_7.4.1.201502020932.jar
Id: com.crt.utils, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.utils_7.4.1.201502020932.jar
Id: com.crt.vendor.arm.generic, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.vendor.arm.generic_7.4.1.201502020932.jar
Id: com.crt.vendor.nxp.a7, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.vendor.nxp.a7_7.4.1.201502020932.jar
Id: com.crt.vendor.nxp.generic, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.vendor.nxp.generic_7.4.1.201502020932.jar
Id: com.crt.vendor.nxp.lpc11, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.vendor.nxp.lpc11_7.4.1.201502020932.jar
Id: com.crt.vendor.nxp.lpc13, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.vendor.nxp.lpc13_7.4.1.201502020932.jar
Id: com.crt.vendor.nxp.lpc17, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.vendor.nxp.lpc17_7.4.1.201502020932.jar
Id: com.crt.vendor.nxp.lpc18, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.vendor.nxp.lpc18_7.4.1.201502020932.jar
Id: com.crt.vendor.nxp.lpc29, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.vendor.nxp.lpc29_7.4.1.201502020932.jar
Id: com.crt.vendor.nxp.lpc31, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.vendor.nxp.lpc31_7.4.1.201502020932.jar
Id: com.crt.vendor.nxp.lpc43, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.vendor.nxp.lpc43_7.4.1.201502020932.jar
Id: com.crt.vendor.nxp.niobe, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.vendor.nxp.niobe_7.4.1.201502020932.jar
Id: com.ibm.icu, Version: 52.1.0.v201404241930, Location: reference:file:plugins/com.ibm.icu_52.1.0.v201404241930.jar
Id: com.jcraft.jsch, Version: 0.1.50.v201403120620, Location: reference:file:plugins/com.jcraft.jsch_0.1.50.v201403120620.jar
Id: com.nxp.gnudocs, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.nxp.gnudocs_7.4.1.201502020932.jar
Id: com.nxp.symbolbrowser, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.nxp.symbolbrowser_7.4.1.201502020932.jar
Id: com.sun.el, Version: 2.2.0.v201303151357, Location: reference:file:plugins/com.sun.el_2.2.0.v201303151357.jar
Id: javax.annotation, Version: 1.2.0.v201401042248, Location: reference:file:plugins/javax.annotation_1.2.0.v201401042248.jar
Id: javax.el, Version: 2.2.0.v201303151357, Location: reference:file:plugins/javax.el_2.2.0.v201303151357.jar
Id: javax.inject, Version: 1.0.0.v20091030, Location: reference:file:plugins/javax.inject_1.0.0.v20091030.jar
Id: javax.servlet, Version: 3.0.0.v201112011016, Location: reference:file:plugins/javax.servlet_3.0.0.v201112011016.jar
Id: javax.servlet.jsp, Version: 2.2.0.v201112011158, Location: reference:file:plugins/javax.servlet.jsp_2.2.0.v201112011158.jar
Id: javax.xml, Version: 1.3.4.v201005080400, Location: reference:file:plugins/javax.xml_1.3.4.v201005080400.jar
Id: org.apache.ant, Version: 1.9.2.v201404171502, Location: reference:file:plugins/org.apache.ant_1.9.2.v201404171502/
Id: org.apache.batik.css, Version: 1.7.0.v201011041433, Location: reference:file:plugins/org.apache.batik.css_1.7.0.v201011041433.jar
Id: org.apache.batik.util, Version: 1.7.0.v201011041433, Location: reference:file:plugins/org.apache.batik.util_1.7.0.v201011041433.jar
Id: org.apache.batik.util.gui, Version: 1.7.0.v200903091627, Location: reference:file:plugins/org.apache.batik.util.gui_1.7.0.v200903091627.jar
Id: org.apache.commons.codec, Version: 1.6.0.v201305230611, Location: reference:file:plugins/org.apache.commons.codec_1.6.0.v201305230611.jar
Id: org.apache.commons.logging, Version: 1.1.1.v201101211721, Location: reference:file:plugins/org.apache.commons.logging_1.1.1.v201101211721.jar
Id: org.apache.felix.gogo.command, Version: 0.10.0.v201209301215, Location: reference:file:plugins/org.apache.felix.gogo.command_0.10.0.v201209301215.jar
Id: org.apache.felix.gogo.runtime, Version: 0.10.0.v201209301036, Location: reference:file:plugins/org.apache.felix.gogo.runtime_0.10.0.v201209301036.jar
Id: org.apache.felix.gogo.shell, Version: 0.10.0.v201212101605, Location: reference:file:plugins/org.apache.felix.gogo.shell_0.10.0.v201212101605.jar
Id: org.apache.httpcomponents.httpclient, Version: 4.2.6.v201311072007, Location: reference:file:plugins/org.apache.httpcomponents.httpclient_4.2.6.v201311072007.jar
Id: org.apache.httpcomponents.httpcore, Version: 4.2.5.v201311072007, Location: reference:file:plugins/org.apache.httpcomponents.httpcore_4.2.5.v201311072007.jar
Id: org.apache.jasper.glassfish, Version: 2.2.2.v201205150955, Location: reference:file:plugins/org.apache.jasper.glassfish_2.2.2.v201205150955.jar
Id: org.apache.lucene.analysis, Version: 3.5.0.v20120725-1805, Location: reference:file:plugins/org.apache.lucene.analysis_3.5.0.v20120725-1805.jar
Id: org.apache.lucene.core, Version: 3.5.0.v20120725-1805, Location: reference:file:plugins/org.apache.lucene.core_3.5.0.v20120725-1805.jar
Id: org.eclipse.ant.core, Version: 3.3.0.v20140518-0042, Location: reference:file:plugins/org.eclipse.ant.core_3.3.0.v20140518-0042.jar
Id: org.eclipse.cdt, Version: 8.5.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt_8.5.0.201409172108.jar
Id: org.eclipse.cdt.codan.checkers, Version: 3.2.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.codan.checkers_3.2.0.201409172108.jar
Id: org.eclipse.cdt.codan.checkers.ui, Version: 3.2.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.codan.checkers.ui_3.2.0.201409172108.jar
Id: org.eclipse.cdt.codan.core, Version: 3.2.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.codan.core_3.2.0.201409172108.jar
Id: org.eclipse.cdt.codan.core.cxx, Version: 3.2.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.codan.core.cxx_3.2.0.201409172108.jar
Id: org.eclipse.cdt.codan.ui, Version: 3.2.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.codan.ui_3.2.0.201409172108.jar
Id: org.eclipse.cdt.codan.ui.cxx, Version: 3.2.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.codan.ui.cxx_3.2.0.201409172108.jar
Id: org.eclipse.cdt.core, Version: 5.8.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.core_5.8.0.201409172108.jar
Id: org.eclipse.cdt.core.native, Version: 5.7.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.core.native_5.7.0.201409172108.jar
Id: org.eclipse.cdt.core.win32, Version: 5.4.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.core.win32_5.4.0.201409172108.jar
Id: org.eclipse.cdt.core.win32.x86, Version: 5.3.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.core.win32.x86_5.3.0.201409172108/
Id: org.eclipse.cdt.debug.core, Version: 7.5.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.debug.core_7.5.0.201409172108.jar
Id: org.eclipse.cdt.debug.gdbjtag, Version: 7.0.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.debug.gdbjtag_7.0.0.201409172108.jar
Id: org.eclipse.cdt.debug.gdbjtag.core, Version: 8.4.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.debug.gdbjtag.core_8.4.0.201409172108.jar
Id: org.eclipse.cdt.debug.gdbjtag.ui, Version: 7.1.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.debug.gdbjtag.ui_7.1.0.201409172108.jar
Id: org.eclipse.cdt.debug.mi.core, Version: 7.3.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.debug.mi.core_7.3.0.201409172108.jar
Id: org.eclipse.cdt.debug.mi.ui, Version: 6.2.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.debug.mi.ui_6.2.0.201409172108.jar
Id: org.eclipse.cdt.debug.ui, Version: 7.5.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.debug.ui_7.5.0.201409172108.jar
Id: org.eclipse.cdt.debug.ui.memory.memorybrowser, Version: 1.3.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.debug.ui.memory.memorybrowser_1.3.0.201409172108.jar
Id: org.eclipse.cdt.debug.ui.memory.search, Version: 1.3.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.debug.ui.memory.search_1.3.0.201409172108.jar
Id: org.eclipse.cdt.debug.ui.memory.traditional, Version: 1.2.1.201409172108, Location: reference:file:plugins/org.eclipse.cdt.debug.ui.memory.traditional_1.2.1.201409172108.jar
Id: org.eclipse.cdt.debug.ui.memory.transport, Version: 2.1.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.debug.ui.memory.transport_2.1.0.201409172108.jar
Id: org.eclipse.cdt.doc.user, Version: 5.3.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.doc.user_5.3.0.201409172108.jar
Id: org.eclipse.cdt.dsf, Version: 2.5.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.dsf_2.5.0.201409172108.jar
Id: org.eclipse.cdt.dsf.gdb, Version: 4.5.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.dsf.gdb_4.5.0.201409172108.jar
Id: org.eclipse.cdt.dsf.gdb.ui, Version: 2.4.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.dsf.gdb.ui_2.4.0.201409172108.jar
Id: org.eclipse.cdt.dsf.ui, Version: 2.4.100.201409172108, Location: reference:file:plugins/org.eclipse.cdt.dsf.ui_2.4.100.201409172108.jar
Id: org.eclipse.cdt.gdb, Version: 7.0.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.gdb_7.0.0.201409172108.jar
Id: org.eclipse.cdt.gdb.ui, Version: 7.0.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.gdb.ui_7.0.0.201409172108.jar
Id: org.eclipse.cdt.launch, Version: 7.1.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.launch_7.1.0.201409172108.jar
Id: org.eclipse.cdt.make.core, Version: 7.3.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.make.core_7.3.0.201409172108.jar
Id: org.eclipse.cdt.make.ui, Version: 7.2.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.make.ui_7.2.0.201409172108.jar
Id: org.eclipse.cdt.managedbuilder.core, Version: 8.3.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.managedbuilder.core_8.3.0.201409172108.jar
Id: org.eclipse.cdt.managedbuilder.gnu.ui, Version: 8.3.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.managedbuilder.gnu.ui_8.3.0.201409172108.jar
Id: org.eclipse.cdt.managedbuilder.ui, Version: 8.2.2.201409172108, Location: reference:file:plugins/org.eclipse.cdt.managedbuilder.ui_8.2.2.201409172108.jar
Id: org.eclipse.cdt.ui, Version: 5.8.1.201409172108, Location: reference:file:plugins/org.eclipse.cdt.ui_5.8.1.201409172108.jar
Id: org.eclipse.compare, Version: 3.5.501.v20140817-1445, Location: reference:file:plugins/org.eclipse.compare_3.5.501.v20140817-1445.jar
Id: org.eclipse.compare.core, Version: 3.5.400.v20130903-0736, Location: reference:file:plugins/org.eclipse.compare.core_3.5.400.v20130903-0736.jar
Id: org.eclipse.compare.win32, Version: 1.0.200.v20130514-1224, Location: reference:file:plugins/org.eclipse.compare.win32_1.0.200.v20130514-1224.jar
Id: org.eclipse.core.commands, Version: 3.6.100.v20140528-1422, Location: reference:file:plugins/org.eclipse.core.commands_3.6.100.v20140528-1422.jar
Id: org.eclipse.core.contenttype, Version: 3.4.200.v20140207-1251, Location: reference:file:plugins/org.eclipse.core.contenttype_3.4.200.v20140207-1251.jar
Id: org.eclipse.core.databinding, Version: 1.4.2.v20140729-1044, Location: reference:file:plugins/org.eclipse.core.databinding_1.4.2.v20140729-1044.jar
Id: org.eclipse.core.databinding.beans, Version: 1.2.200.v20140214-0004, Location: reference:file:plugins/org.eclipse.core.databinding.beans_1.2.200.v20140214-0004.jar
Id: org.eclipse.core.databinding.observable, Version: 1.4.1.v20140210-1835, Location: reference:file:plugins/org.eclipse.core.databinding.observable_1.4.1.v20140210-1835.jar
Id: org.eclipse.core.databinding.property, Version: 1.4.200.v20140214-0004, Location: reference:file:plugins/org.eclipse.core.databinding.property_1.4.200.v20140214-0004.jar
Id: org.eclipse.core.expressions, Version: 3.4.600.v20140128-0851, Location: reference:file:plugins/org.eclipse.core.expressions_3.4.600.v20140128-0851.jar
Id: org.eclipse.core.externaltools, Version: 1.0.300.v20140219-0051, Location: reference:file:plugins/org.eclipse.core.externaltools_1.0.300.v20140219-0051.jar
Id: org.eclipse.core.filebuffers, Version: 3.5.400.v20140127-1516, Location: reference:file:plugins/org.eclipse.core.filebuffers_3.5.400.v20140127-1516.jar
Id: org.eclipse.core.filesystem, Version: 1.4.100.v20140514-1614, Location: reference:file:plugins/org.eclipse.core.filesystem_1.4.100.v20140514-1614.jar
Id: org.eclipse.core.filesystem.java7, Version: 1.0.0.v20140429-1531, Location: reference:file:plugins/org.eclipse.core.filesystem.java7_1.0.0.v20140429-1531.jar
Id: org.eclipse.core.filesystem.win32.x86, Version: 1.4.0.v20140124-1940, Location: reference:file:plugins/org.eclipse.core.filesystem.win32.x86_1.4.0.v20140124-1940.jar
Id: org.eclipse.core.jobs, Version: 3.6.0.v20140424-0053, Location: reference:file:plugins/org.eclipse.core.jobs_3.6.0.v20140424-0053.jar
Id: org.eclipse.core.net, Version: 1.2.200.v20140124-2013, Location: reference:file:plugins/org.eclipse.core.net_1.2.200.v20140124-2013.jar
Id: org.eclipse.core.net.win32.x86, Version: 1.0.100.v20140124-2013, Location: reference:file:plugins/org.eclipse.core.net.win32.x86_1.0.100.v20140124-2013.jar
Id: org.eclipse.core.resources, Version: 3.9.1.v20140825-1431, Location: reference:file:plugins/org.eclipse.core.resources_3.9.1.v20140825-1431.jar
Id: org.eclipse.core.resources.win32.x86, Version: 3.5.100.v20140124-1940, Location: reference:file:plugins/org.eclipse.core.resources.win32.x86_3.5.100.v20140124-1940.jar
Id: org.eclipse.core.runtime, Version: 3.10.0.v20140318-2214, Location: reference:file:plugins/org.eclipse.core.runtime_3.10.0.v20140318-2214.jar
Id: org.eclipse.core.runtime.compatibility, Version: 3.2.200.v20140128-0851, Location: reference:file:plugins/org.eclipse.core.runtime.compatibility_3.2.200.v20140128-0851.jar
Id: org.eclipse.core.runtime.compatibility.registry, Version: 3.5.300.v20140128-0851, Location: reference:file:plugins/org.eclipse.core.runtime.compatibility.registry_3.5.300.v20140128-0851/
Id: org.eclipse.core.variables, Version: 3.2.800.v20130819-1716, Location: reference:file:plugins/org.eclipse.core.variables_3.2.800.v20130819-1716.jar
Id: org.eclipse.cvs, Version: 1.4.100.v20140925-0400, Location: reference:file:plugins/org.eclipse.cvs_1.4.100.v20140925-0400.jar
Id: org.eclipse.debug.core, Version: 3.9.1.v20140805-1629, Location: reference:file:plugins/org.eclipse.debug.core_3.9.1.v20140805-1629.jar
Id: org.eclipse.debug.ui, Version: 3.10.1.v20140822-1408, Location: reference:file:plugins/org.eclipse.debug.ui_3.10.1.v20140822-1408.jar
Id: org.eclipse.draw2d, Version: 3.9.101.201408150207, Location: reference:file:plugins/org.eclipse.draw2d_3.9.101.201408150207.jar
Id: org.eclipse.e4.core.commands, Version: 0.10.2.v20140424-2344, Location: reference:file:plugins/org.eclipse.e4.core.commands_0.10.2.v20140424-2344.jar
Id: org.eclipse.e4.core.contexts, Version: 1.3.100.v20140407-1019, Location: reference:file:plugins/org.eclipse.e4.core.contexts_1.3.100.v20140407-1019.jar
Id: org.eclipse.e4.core.di, Version: 1.4.0.v20140414-1837, Location: reference:file:plugins/org.eclipse.e4.core.di_1.4.0.v20140414-1837.jar
Id: org.eclipse.e4.core.di.extensions, Version: 0.12.0.v20140417-2033, Location: reference:file:plugins/org.eclipse.e4.core.di.extensions_0.12.0.v20140417-2033.jar
Id: org.eclipse.e4.core.services, Version: 1.2.1.v20140808-1251, Location: reference:file:plugins/org.eclipse.e4.core.services_1.2.1.v20140808-1251.jar
Id: org.eclipse.e4.ui.bindings, Version: 0.10.200.v20140424-2042, Location: reference:file:plugins/org.eclipse.e4.ui.bindings_0.10.200.v20140424-2042.jar
Id: org.eclipse.e4.ui.css.core, Version: 0.10.100.v20140424-2042, Location: reference:file:plugins/org.eclipse.e4.ui.css.core_0.10.100.v20140424-2042.jar
Id: org.eclipse.e4.ui.css.swt, Version: 0.11.101.v20140818-1343, Location: reference:file:plugins/org.eclipse.e4.ui.css.swt_0.11.101.v20140818-1343.jar
Id: org.eclipse.e4.ui.css.swt.theme, Version: 0.9.300.v20140424-2042, Location: reference:file:plugins/org.eclipse.e4.ui.css.swt.theme_0.9.300.v20140424-2042.jar
Id: org.eclipse.e4.ui.di, Version: 1.0.0.v20140328-2112, Location: reference:file:plugins/org.eclipse.e4.ui.di_1.0.0.v20140328-2112.jar
Id: org.eclipse.e4.ui.model.workbench, Version: 1.1.0.v20140512-1820, Location: reference:file:plugins/org.eclipse.e4.ui.model.workbench_1.1.0.v20140512-1820.jar
Id: org.eclipse.e4.ui.services, Version: 1.1.0.v20140328-1925, Location: reference:file:plugins/org.eclipse.e4.ui.services_1.1.0.v20140328-1925.jar
Id: org.eclipse.e4.ui.widgets, Version: 1.0.0.v20140514-1823, Location: reference:file:plugins/org.eclipse.e4.ui.widgets_1.0.0.v20140514-1823.jar
Id: org.eclipse.e4.ui.workbench, Version: 1.2.1.v20140901-1244, Location: reference:file:plugins/org.eclipse.e4.ui.workbench_1.2.1.v20140901-1244.jar
Id: org.eclipse.e4.ui.workbench.addons.swt, Version: 1.1.1.v20140903-0821, Location: reference:file:plugins/org.eclipse.e4.ui.workbench.addons.swt_1.1.1.v20140903-0821.jar
Id: org.eclipse.e4.ui.workbench.renderers.swt, Version: 0.12.1.v20140903-1023, Location: reference:file:plugins/org.eclipse.e4.ui.workbench.renderers.swt_0.12.1.v20140903-1023.jar
Id: org.eclipse.e4.ui.workbench.swt, Version: 0.12.100.v20140530-1436, Location: reference:file:plugins/org.eclipse.e4.ui.workbench.swt_0.12.100.v20140530-1436.jar
Id: org.eclipse.e4.ui.workbench3, Version: 0.12.0.v20140227-2118, Location: reference:file:plugins/org.eclipse.e4.ui.workbench3_0.12.0.v20140227-2118.jar
Id: org.eclipse.ecf, Version: 3.4.0.v20140827-1444, Location: reference:file:plugins/org.eclipse.ecf_3.4.0.v20140827-1444.jar
Id: org.eclipse.ecf.filetransfer, Version: 5.0.0.v20140827-1444, Location: reference:file:plugins/org.eclipse.ecf.filetransfer_5.0.0.v20140827-1444.jar
Id: org.eclipse.ecf.identity, Version: 3.4.0.v20140827-1444, Location: reference:file:plugins/org.eclipse.ecf.identity_3.4.0.v20140827-1444.jar
Id: org.eclipse.ecf.provider.filetransfer, Version: 3.2.200.v20140827-1444, Location: reference:file:plugins/org.eclipse.ecf.provider.filetransfer_3.2.200.v20140827-1444.jar
Id: org.eclipse.ecf.provider.filetransfer.httpclient4, Version: 1.0.800.v20140827-1444, Location: reference:file:plugins/org.eclipse.ecf.provider.filetransfer.httpclient4_1.0.800.v20140827-1444.jar
Id: org.eclipse.ecf.provider.filetransfer.httpclient4.ssl, Version: 1.0.0.v20140827-1444, Location: reference:file:plugins/org.eclipse.ecf.provider.filetransfer.httpclient4.ssl_1.0.0.v20140827-1444.jar
Id: org.eclipse.ecf.provider.filetransfer.ssl, Version: 1.0.0.v20140827-1444, Location: reference:file:plugins/org.eclipse.ecf.provider.filetransfer.ssl_1.0.0.v20140827-1444.jar
Id: org.eclipse.ecf.ssl, Version: 1.1.0.v20140827-1444, Location: reference:file:plugins/org.eclipse.ecf.ssl_1.1.0.v20140827-1444.jar
Id: org.eclipse.emf.common, Version: 2.10.1.v20140901-1043, Location: reference:file:plugins/org.eclipse.emf.common_2.10.1.v20140901-1043.jar
Id: org.eclipse.emf.ecore, Version: 2.10.1.v20140901-1043, Location: reference:file:plugins/org.eclipse.emf.ecore_2.10.1.v20140901-1043.jar
Id: org.eclipse.emf.ecore.change, Version: 2.10.0.v20140901-1043, Location: reference:file:plugins/org.eclipse.emf.ecore.change_2.10.0.v20140901-1043.jar
Id: org.eclipse.emf.ecore.xmi, Version: 2.10.1.v20140901-1043, Location: reference:file:plugins/org.eclipse.emf.ecore.xmi_2.10.1.v20140901-1043.jar
Id: org.eclipse.equinox.app, Version: 1.3.200.v20130910-1609, Location: reference:file:plugins/org.eclipse.equinox.app_1.3.200.v20130910-1609.jar
Id: org.eclipse.equinox.bidi, Version: 0.10.0.v20130327-1442, Location: reference:file:plugins/org.eclipse.equinox.bidi_0.10.0.v20130327-1442.jar
Id: org.eclipse.equinox.common, Version: 3.6.200.v20130402-1505, Location: reference:file:plugins/org.eclipse.equinox.common_3.6.200.v20130402-1505.jar
Id: org.eclipse.equinox.concurrent, Version: 1.1.0.v20130327-1442, Location: reference:file:plugins/org.eclipse.equinox.concurrent_1.1.0.v20130327-1442.jar
Id: org.eclipse.equinox.console, Version: 1.1.0.v20140131-1639, Location: reference:file:plugins/org.eclipse.equinox.console_1.1.0.v20140131-1639.jar
Id: org.eclipse.equinox.ds, Version: 1.4.200.v20131126-2331, Location: reference:file:plugins/org.eclipse.equinox.ds_1.4.200.v20131126-2331.jar
Id: org.eclipse.equinox.event, Version: 1.3.100.v20140115-1647, Location: reference:file:plugins/org.eclipse.equinox.event_1.3.100.v20140115-1647.jar
Id: org.eclipse.equinox.frameworkadmin, Version: 2.0.100.v20131209-2144, Location: reference:file:plugins/org.eclipse.equinox.frameworkadmin_2.0.100.v20131209-2144.jar
Id: org.eclipse.equinox.frameworkadmin.equinox, Version: 1.0.500.v20131211-1531, Location: reference:file:plugins/org.eclipse.equinox.frameworkadmin.equinox_1.0.500.v20131211-1531.jar
Id: org.eclipse.equinox.http.jetty, Version: 3.0.200.v20131021-1843, Location: reference:file:plugins/org.eclipse.equinox.http.jetty_3.0.200.v20131021-1843.jar
Id: org.eclipse.equinox.http.registry, Version: 1.1.300.v20130402-1529, Location: reference:file:plugins/org.eclipse.equinox.http.registry_1.1.300.v20130402-1529.jar
Id: org.eclipse.equinox.http.servlet, Version: 1.1.500.v20140318-1755, Location: reference:file:plugins/org.eclipse.equinox.http.servlet_1.1.500.v20140318-1755.jar
Id: org.eclipse.equinox.jsp.jasper, Version: 1.0.400.v20130327-1442, Location: reference:file:plugins/org.eclipse.equinox.jsp.jasper_1.0.400.v20130327-1442.jar
Id: org.eclipse.equinox.jsp.jasper.registry, Version: 1.0.300.v20130327-1442, Location: reference:file:plugins/org.eclipse.equinox.jsp.jasper.registry_1.0.300.v20130327-1442.jar
Id: org.eclipse.equinox.launcher, Version: 1.3.0.v20140415-2008, Location: reference:file:plugins/org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar
Id: org.eclipse.equinox.launcher.win32.win32.x86, Version: 1.1.200.v20140603-1326, Location: reference:file:plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.1.200.v20140603-1326/
Id: org.eclipse.equinox.p2.artifact.repository, Version: 1.1.300.v20131211-1531, Location: reference:file:plugins/org.eclipse.equinox.p2.artifact.repository_1.1.300.v20131211-1531.jar
Id: org.eclipse.equinox.p2.console, Version: 1.0.300.v20131113-1212, Location: reference:file:plugins/org.eclipse.equinox.p2.console_1.0.300.v20131113-1212.jar
Id: org.eclipse.equinox.p2.core, Version: 2.3.0.v20131211-1531, Location: reference:file:plugins/org.eclipse.equinox.p2.core_2.3.0.v20131211-1531.jar
Id: org.eclipse.equinox.p2.director, Version: 2.3.100.v20140224-1921, Location: reference:file:plugins/org.eclipse.equinox.p2.director_2.3.100.v20140224-1921.jar
Id: org.eclipse.equinox.p2.director.app, Version: 1.0.300.v20140228-1829, Location: reference:file:plugins/org.eclipse.equinox.p2.director.app_1.0.300.v20140228-1829.jar
Id: org.eclipse.equinox.p2.directorywatcher, Version: 1.1.0.v20131211-1531, Location: reference:file:plugins/org.eclipse.equinox.p2.directorywatcher_1.1.0.v20131211-1531.jar
Id: org.eclipse.equinox.p2.engine, Version: 2.3.0.v20140506-1720, Location: reference:file:plugins/org.eclipse.equinox.p2.engine_2.3.0.v20140506-1720.jar
Id: org.eclipse.equinox.p2.extensionlocation, Version: 1.2.100.v20131119-0908, Location: reference:file:plugins/org.eclipse.equinox.p2.extensionlocation_1.2.100.v20131119-0908.jar
Id: org.eclipse.equinox.p2.garbagecollector, Version: 1.0.200.v20131115-1210, Location: reference:file:plugins/org.eclipse.equinox.p2.garbagecollector_1.0.200.v20131115-1210.jar
Id: org.eclipse.equinox.p2.jarprocessor, Version: 1.0.300.v20131211-1531, Location: reference:file:plugins/org.eclipse.equinox.p2.jarprocessor_1.0.300.v20131211-1531.jar
Id: org.eclipse.equinox.p2.metadata, Version: 2.2.0.v20131211-1531, Location: reference:file:plugins/org.eclipse.equinox.p2.metadata_2.2.0.v20131211-1531.jar
Id: org.eclipse.equinox.p2.metadata.repository, Version: 1.2.100.v20131209-2144, Location: reference:file:plugins/org.eclipse.equinox.p2.metadata.repository_1.2.100.v20131209-2144.jar
Id: org.eclipse.equinox.p2.operations, Version: 2.4.0.v20131119-0908, Location: reference:file:plugins/org.eclipse.equinox.p2.operations_2.4.0.v20131119-0908.jar
Id: org.eclipse.equinox.p2.publisher, Version: 1.3.0.v20140911-0143, Location: reference:file:plugins/org.eclipse.equinox.p2.publisher_1.3.0.v20140911-0143.jar
Id: org.eclipse.equinox.p2.publisher.eclipse, Version: 1.1.200.v20140414-0825, Location: reference:file:plugins/org.eclipse.equinox.p2.publisher.eclipse_1.1.200.v20140414-0825.jar
Id: org.eclipse.equinox.p2.ql, Version: 2.0.100.v20131211-1531, Location: reference:file:plugins/org.eclipse.equinox.p2.ql_2.0.100.v20131211-1531.jar
Id: org.eclipse.equinox.p2.reconciler.dropins, Version: 1.1.200.v20131119-0908, Location: reference:file:plugins/org.eclipse.equinox.p2.reconciler.dropins_1.1.200.v20131119-0908.jar
Id: org.eclipse.equinox.p2.repository, Version: 2.3.0.v20131211-1531, Location: reference:file:plugins/org.eclipse.equinox.p2.repository_2.3.0.v20131211-1531.jar
Id: org.eclipse.equinox.p2.repository.tools, Version: 2.1.0.v20131211-1531, Location: reference:file:plugins/org.eclipse.equinox.p2.repository.tools_2.1.0.v20131211-1531.jar
Id: org.eclipse.equinox.p2.touchpoint.eclipse, Version: 2.1.200.v20140512-1650, Location: reference:file:plugins/org.eclipse.equinox.p2.touchpoint.eclipse_2.1.200.v20140512-1650.jar
Id: org.eclipse.equinox.p2.touchpoint.natives, Version: 1.1.100.v20140523-0116, Location: reference:file:plugins/org.eclipse.equinox.p2.touchpoint.natives_1.1.100.v20140523-0116.jar
Id: org.eclipse.equinox.p2.transport.ecf, Version: 1.1.0.v20140408-1354, Location: reference:file:plugins/org.eclipse.equinox.p2.transport.ecf_1.1.0.v20140408-1354.jar
Id: org.eclipse.equinox.p2.ui, Version: 2.3.0.v20140404-1657, Location: reference:file:plugins/org.eclipse.equinox.p2.ui_2.3.0.v20140404-1657.jar
Id: org.eclipse.equinox.p2.ui.importexport, Version: 1.1.0.v20131210-1027, Location: reference:file:plugins/org.eclipse.equinox.p2.ui.importexport_1.1.0.v20131210-1027.jar
Id: org.eclipse.equinox.p2.ui.sdk, Version: 1.0.300.v20140407-1803, Location: reference:file:plugins/org.eclipse.equinox.p2.ui.sdk_1.0.300.v20140407-1803.jar
Id: org.eclipse.equinox.p2.ui.sdk.scheduler, Version: 1.2.0.v20140422-1847, Location: reference:file:plugins/org.eclipse.equinox.p2.ui.sdk.scheduler_1.2.0.v20140422-1847.jar
Id: org.eclipse.equinox.p2.updatechecker, Version: 1.1.200.v20131119-0908, Location: reference:file:plugins/org.eclipse.equinox.p2.updatechecker_1.1.200.v20131119-0908.jar
Id: org.eclipse.equinox.p2.updatesite, Version: 1.0.400.v20131211-1531, Location: reference:file:plugins/org.eclipse.equinox.p2.updatesite_1.0.400.v20131211-1531.jar
Id: org.eclipse.equinox.preferences, Version: 3.5.200.v20140224-1527, Location: reference:file:plugins/org.eclipse.equinox.preferences_3.5.200.v20140224-1527.jar
Id: org.eclipse.equinox.registry, Version: 3.5.400.v20140428-1507, Location: reference:file:plugins/org.eclipse.equinox.registry_3.5.400.v20140428-1507.jar
Id: org.eclipse.equinox.security, Version: 1.2.0.v20130424-1801, Location: reference:file:plugins/org.eclipse.equinox.security_1.2.0.v20130424-1801.jar
Id: org.eclipse.equinox.security.ui, Version: 1.1.200.v20130626-2037, Location: reference:file:plugins/org.eclipse.equinox.security.ui_1.1.200.v20130626-2037.jar
Id: org.eclipse.equinox.security.win32.x86, Version: 1.0.300.v20130327-1442, Location: reference:file:plugins/org.eclipse.equinox.security.win32.x86_1.0.300.v20130327-1442.jar
Id: org.eclipse.equinox.simpleconfigurator, Version: 1.1.0.v20131217-1203, Location: initial@reference:file:plugins/org.eclipse.equinox.simpleconfigurator_1.1.0.v20131217-1203.jar
Id: org.eclipse.equinox.simpleconfigurator.manipulator, Version: 2.0.0.v20131217-1203, Location: reference:file:plugins/org.eclipse.equinox.simpleconfigurator.manipulator_2.0.0.v20131217-1203.jar
Id: org.eclipse.equinox.util, Version: 1.0.500.v20130404-1337, Location: reference:file:plugins/org.eclipse.equinox.util_1.0.500.v20130404-1337.jar
Id: org.eclipse.gef, Version: 3.9.100.201408150207, Location: reference:file:plugins/org.eclipse.gef_3.9.100.201408150207.jar
Id: org.eclipse.help, Version: 3.6.0.v20130326-1254, Location: reference:file:plugins/org.eclipse.help_3.6.0.v20130326-1254.jar
Id: org.eclipse.help.base, Version: 4.0.200.v20140925-0400, Location: reference:file:plugins/org.eclipse.help.base_4.0.200.v20140925-0400.jar
Id: org.eclipse.help.ui, Version: 4.0.100.v20140401-0608, Location: reference:file:plugins/org.eclipse.help.ui_4.0.100.v20140401-0608.jar
Id: org.eclipse.help.webapp, Version: 3.6.300.v20140407-1855, Location: reference:file:plugins/org.eclipse.help.webapp_3.6.300.v20140407-1855.jar
Id: org.eclipse.jetty.continuation, Version: 8.1.14.v20131031, Location: reference:file:plugins/org.eclipse.jetty.continuation_8.1.14.v20131031.jar
Id: org.eclipse.jetty.http, Version: 8.1.14.v20131031, Location: reference:file:plugins/org.eclipse.jetty.http_8.1.14.v20131031.jar
Id: org.eclipse.jetty.io, Version: 8.1.14.v20131031, Location: reference:file:plugins/org.eclipse.jetty.io_8.1.14.v20131031.jar
Id: org.eclipse.jetty.security, Version: 8.1.14.v20131031, Location: reference:file:plugins/org.eclipse.jetty.security_8.1.14.v20131031.jar
Id: org.eclipse.jetty.server, Version: 8.1.14.v20131031, Location: reference:file:plugins/org.eclipse.jetty.server_8.1.14.v20131031.jar
Id: org.eclipse.jetty.servlet, Version: 8.1.14.v20131031, Location: reference:file:plugins/org.eclipse.jetty.servlet_8.1.14.v20131031.jar
Id: org.eclipse.jetty.util, Version: 8.1.14.v20131031, Location: reference:file:plugins/org.eclipse.jetty.util_8.1.14.v20131031.jar
Id: org.eclipse.jface, Version: 3.10.1.v20140813-1009, Location: reference:file:plugins/org.eclipse.jface_3.10.1.v20140813-1009.jar
Id: org.eclipse.jface.databinding, Version: 1.6.200.v20140528-1422, Location: reference:file:plugins/org.eclipse.jface.databinding_1.6.200.v20140528-1422.jar
Id: org.eclipse.jface.text, Version: 3.9.1.v20140827-1810, Location: reference:file:plugins/org.eclipse.jface.text_3.9.1.v20140827-1810.jar
Id: org.eclipse.jsch.core, Version: 1.1.500.v20131112-1442, Location: reference:file:plugins/org.eclipse.jsch.core_1.1.500.v20131112-1442.jar
Id: org.eclipse.jsch.ui, Version: 1.1.500.v20131112-1442, Location: reference:file:plugins/org.eclipse.jsch.ui_1.1.500.v20131112-1442.jar
Id: org.eclipse.ltk.core.refactoring, Version: 3.6.101.v20140817-1500, Location: reference:file:plugins/org.eclipse.ltk.core.refactoring_3.6.101.v20140817-1500.jar
Id: org.eclipse.ltk.ui.refactoring, Version: 3.7.100.v20140324-1358, Location: reference:file:plugins/org.eclipse.ltk.ui.refactoring_3.7.100.v20140324-1358.jar
Id: org.eclipse.osgi, Version: 3.10.1.v20140909-1633, Location: System Bundle
Id: org.eclipse.osgi.compatibility.state, Version: 1.0.1.v20140709-1414, Location: initial@reference:file:plugins/org.eclipse.osgi.compatibility.state_1.0.1.v20140709-1414.jar
Id: org.eclipse.osgi.services, Version: 3.4.0.v20140312-2051, Location: reference:file:plugins/org.eclipse.osgi.services_3.4.0.v20140312-2051.jar
Id: org.eclipse.osgi.util, Version: 3.3.0.v20131023-1243, Location: reference:file:plugins/org.eclipse.osgi.util_3.3.0.v20131023-1243.jar
Id: org.eclipse.platform, Version: 4.4.0.v20140925-0400, Location: reference:file:plugins/org.eclipse.platform_4.4.0.v20140925-0400/
Id: org.eclipse.platform.doc.user, Version: 4.4.1.v20140829-1306, Location: reference:file:plugins/org.eclipse.platform.doc.user_4.4.1.v20140829-1306.jar
Id: org.eclipse.rcp, Version: 4.3.100.v20140925-0400, Location: reference:file:plugins/org.eclipse.rcp_4.3.100.v20140925-0400.jar
Id: org.eclipse.search, Version: 3.9.100.v20140226-1637, Location: reference:file:plugins/org.eclipse.search_3.9.100.v20140226-1637.jar
Id: org.eclipse.swt, Version: 3.103.1.v20140903-1938, Location: reference:file:plugins/org.eclipse.swt_3.103.1.v20140903-1938.jar
Id: org.eclipse.swt.win32.win32.x86, Version: 3.103.1.v20140903-1947, Location: reference:file:plugins/org.eclipse.swt.win32.win32.x86_3.103.1.v20140903-1947.jar
Id: org.eclipse.team.core, Version: 3.7.0.v20130514-1224, Location: reference:file:plugins/org.eclipse.team.core_3.7.0.v20130514-1224.jar
Id: org.eclipse.team.cvs.core, Version: 3.3.600.v20131112-1442, Location: reference:file:plugins/org.eclipse.team.cvs.core_3.3.600.v20131112-1442.jar
Id: org.eclipse.team.cvs.ssh2, Version: 3.2.400.v20131112-1442, Location: reference:file:plugins/org.eclipse.team.cvs.ssh2_3.2.400.v20131112-1442.jar
Id: org.eclipse.team.cvs.ui, Version: 3.3.600.v20130514-1224, Location: reference:file:plugins/org.eclipse.team.cvs.ui_3.3.600.v20130514-1224.jar
Id: org.eclipse.team.ui, Version: 3.7.100.v20130710-1213, Location: reference:file:plugins/org.eclipse.team.ui_3.7.100.v20130710-1213.jar
Id: org.eclipse.text, Version: 3.5.300.v20130515-1451, Location: reference:file:plugins/org.eclipse.text_3.5.300.v20130515-1451.jar
Id: org.eclipse.ui, Version: 3.106.0.v20140812-1751, Location: reference:file:plugins/org.eclipse.ui_3.106.0.v20140812-1751.jar
Id: org.eclipse.ui.browser, Version: 3.4.200.v20131003-1453, Location: reference:file:plugins/org.eclipse.ui.browser_3.4.200.v20131003-1453.jar
Id: org.eclipse.ui.cheatsheets, Version: 3.4.200.v20131227-1524, Location: reference:file:plugins/org.eclipse.ui.cheatsheets_3.4.200.v20131227-1524.jar
Id: org.eclipse.ui.console, Version: 3.5.300.v20140424-1437, Location: reference:file:plugins/org.eclipse.ui.console_3.5.300.v20140424-1437.jar
Id: org.eclipse.ui.editors, Version: 3.8.200.v20140401-1310, Location: reference:file:plugins/org.eclipse.ui.editors_3.8.200.v20140401-1310.jar
Id: org.eclipse.ui.externaltools, Version: 3.2.300.v20140327-1949, Location: reference:file:plugins/org.eclipse.ui.externaltools_3.2.300.v20140327-1949.jar
Id: org.eclipse.ui.forms, Version: 3.6.100.v20140422-1825, Location: reference:file:plugins/org.eclipse.ui.forms_3.6.100.v20140422-1825.jar
Id: org.eclipse.ui.ide, Version: 3.10.1.v20140828-0944, Location: reference:file:plugins/org.eclipse.ui.ide_3.10.1.v20140828-0944.jar
Id: org.eclipse.ui.ide.application, Version: 1.0.500.v20140514-2033, Location: reference:file:plugins/org.eclipse.ui.ide.application_1.0.500.v20140514-2033.jar
Id: org.eclipse.ui.intro, Version: 3.4.200.v20130326-1254, Location: reference:file:plugins/org.eclipse.ui.intro_3.4.200.v20130326-1254.jar
Id: org.eclipse.ui.intro.universal, Version: 3.2.700.v20130904-1701, Location: reference:file:plugins/org.eclipse.ui.intro.universal_3.2.700.v20130904-1701/
Id: org.eclipse.ui.navigator, Version: 3.5.401.v20140724-1117, Location: reference:file:plugins/org.eclipse.ui.navigator_3.5.401.v20140724-1117.jar
Id: org.eclipse.ui.navigator.resources, Version: 3.4.700.v20140407-1004, Location: reference:file:plugins/org.eclipse.ui.navigator.resources_3.4.700.v20140407-1004.jar
Id: org.eclipse.ui.net, Version: 1.2.200.v20120807-0927, Location: reference:file:plugins/org.eclipse.ui.net_1.2.200.v20120807-0927.jar
Id: org.eclipse.ui.themes, Version: 1.0.1.v20140819-1717, Location: reference:file:plugins/org.eclipse.ui.themes_1.0.1.v20140819-1717/
Id: org.eclipse.ui.views, Version: 3.7.0.v20140408-0703, Location: reference:file:plugins/org.eclipse.ui.views_3.7.0.v20140408-0703.jar
Id: org.eclipse.ui.views.properties.tabbed, Version: 3.6.0.v20140519-0906, Location: reference:file:plugins/org.eclipse.ui.views.properties.tabbed_3.6.0.v20140519-0906.jar
Id: org.eclipse.ui.win32, Version: 3.2.400.v20140423-2207, Location: reference:file:plugins/org.eclipse.ui.win32_3.2.400.v20140423-2207.jar
Id: org.eclipse.ui.workbench, Version: 3.106.1.v20140827-1737, Location: reference:file:plugins/org.eclipse.ui.workbench_3.106.1.v20140827-1737.jar
Id: org.eclipse.ui.workbench.texteditor, Version: 3.9.0.v20140411-1521, Location: reference:file:plugins/org.eclipse.ui.workbench.texteditor_3.9.0.v20140411-1521.jar
Id: org.eclipse.update.configurator, Version: 3.3.300.v20140518-1928, Location: reference:file:plugins/org.eclipse.update.configurator_3.3.300.v20140518-1928.jar
Id: org.sat4j.core, Version: 2.3.5.v201308161310, Location: reference:file:plugins/org.sat4j.core_2.3.5.v201308161310.jar
Id: org.sat4j.pb, Version: 2.3.5.v201404071733, Location: reference:file:plugins/org.sat4j.pb_2.3.5.v201404071733.jar
Id: org.w3c.css.sac, Version: 1.3.1.v200903091627, Location: reference:file:plugins/org.w3c.css.sac_1.3.1.v200903091627.jar
Id: org.w3c.dom.events, Version: 3.0.0.draft20060413_v201105210656, Location: reference:file:plugins/org.w3c.dom.events_3.0.0.draft20060413_v201105210656.jar
Id: org.w3c.dom.smil, Version: 1.0.0.v200806040011, Location: reference:file:plugins/org.w3c.dom.smil_1.0.0.v200806040011.jar
Id: org.w3c.dom.svg, Version: 1.1.0.v201011041433, Location: reference:file:plugins/org.w3c.dom.svg_1.1.0.v201011041433.jar
*** Security Configuration:
Providers (10):
Provider: SUN, Version: 1.7, Class: sun.security.provider.Sun
  Description: SUN (DSA key/parameter generation; DSA signing; SHA-1, MD5 digests; SecureRandom; X.509 certificates; JKS keystore; PKIX CertPathValidator; PKIX CertPathBuilder; LDAP, Collection CertStores, JavaPolicy Policy; JavaLoginConfig Configuration)
  Services (23):
   Service: MessageDigest, Algorithm: SHA-512, Class: sun.security.provider.SHA5$SHA512
   Service: Configuration, Algorithm: JavaLoginConfig, Class: sun.security.provider.ConfigSpiFile
   Service: Signature, Algorithm: NONEwithDSA, Class: sun.security.provider.DSA$RawDSA
    Aliases: RawDSA
    Attributes:
      SupportedKeyClasses: java.security.interfaces.DSAPublicKey|java.security.interfaces.DSAPrivateKey
   Service: CertPathBuilder, Algorithm: PKIX, Class: sun.security.provider.certpath.SunCertPathBuilder
    Attributes:
      ImplementedIn: Software
      ValidationAlgorithm: RFC3280
   Service: CertStore, Algorithm: LDAP, Class: sun.security.provider.certpath.ldap.LDAPCertStore
    Attributes:
      LDAPSchema: RFC2587
   Service: MessageDigest, Algorithm: SHA, Class: sun.security.provider.SHA
    Aliases: SHA1
    Attributes:
   Service: CertificateFactory, Algorithm: X.509, Class: sun.security.provider.X509Factory
    Aliases: X509
    Attributes:
   Service: MessageDigest, Algorithm: SHA-384, Class: sun.security.provider.SHA5$SHA384
   Service: KeyPairGenerator, Algorithm: DSA, Class: sun.security.provider.DSAKeyPairGenerator
    Aliases: OID.1.2.840.10040.4.1
    Attributes:
      KeySize: 1024
   Service: KeyStore, Algorithm: JKS, Class: sun.security.provider.JavaKeyStore$JKS
    Attributes:
   Service: KeyStore, Algorithm: CaseExactJKS, Class: sun.security.provider.JavaKeyStore$CaseExactJKS
   Service: MessageDigest, Algorithm: SHA-256, Class: sun.security.provider.SHA2
   Service: CertStore, Algorithm: com.sun.security.IndexedCollection, Class: sun.security.provider.certpath.IndexedCollectionCertStore
    Attributes:
   Service: KeyFactory, Algorithm: DSA, Class: sun.security.provider.DSAKeyFactory
    Attributes:
   Service: SecureRandom, Algorithm: SHA1PRNG, Class: sun.security.provider.SecureRandom
    Attributes:
   Service: CertPathValidator, Algorithm: PKIX, Class: sun.security.provider.certpath.PKIXCertPathValidator
    Attributes:
   Service: CertStore, Algorithm: Collection, Class: sun.security.provider.certpath.CollectionCertStore
    Attributes:
   Service: MessageDigest, Algorithm: MD5, Class: sun.security.provider.MD5
    Attributes:
   Service: AlgorithmParameters, Algorithm: DSA, Class: sun.security.provider.DSAParameters
    Attributes:
   Service: Policy, Algorithm: JavaPolicy, Class: sun.security.provider.PolicySpiFile
   Service: MessageDigest, Algorithm: MD2, Class: sun.security.provider.MD2
   Service: Signature, Algorithm: SHA1withDSA, Class: sun.security.provider.DSA$SHA1withDSA
    Aliases: DSAWithSHA1
    Attributes:
      KeySize: 1024
   Service: AlgorithmParameterGenerator, Algorithm: DSA, Class: sun.security.provider.DSAParameterGenerator
    Attributes:
      KeySize: 1024
Provider: SunRsaSign, Version: 1.7, Class: sun.security.rsa.SunRsaSign
  Description: Sun RSA signature provider
  Services (8):
   Service: Signature, Algorithm: SHA512withRSA, Class: sun.security.rsa.RSASignature$SHA512withRSA
    Aliases: OID.1.2.840.113549.1.1.13
    Attributes:
      SupportedKeyClasses: java.security.interfaces.RSAPublicKey|java.security.interfaces.RSAPrivateKey
   Service: Signature, Algorithm: MD5withRSA, Class: sun.security.rsa.RSASignature$MD5withRSA
    Aliases: 1.2.840.113549.1.1.4
    Attributes:
   Service: KeyFactory, Algorithm: RSA, Class: sun.security.rsa.RSAKeyFactory
   Service: Signature, Algorithm: SHA1withRSA, Class: sun.security.rsa.RSASignature$SHA1withRSA
    Aliases: OID.1.2.840.113549.1.1.5
    Attributes:
   Service: Signature, Algorithm: SHA384withRSA, Class: sun.security.rsa.RSASignature$SHA384withRSA
    Aliases: OID.1.2.840.113549.1.1.12
    Attributes:
   Service: Signature, Algorithm: MD2withRSA, Class: sun.security.rsa.RSASignature$MD2withRSA
    Aliases: 1.2.840.113549.1.1.2
    Attributes:
   Service: KeyPairGenerator, Algorithm: RSA, Class: sun.security.rsa.RSAKeyPairGenerator
   Service: Signature, Algorithm: SHA256withRSA, Class: sun.security.rsa.RSASignature$SHA256withRSA
    Aliases: OID.1.2.840.113549.1.1.11
    Attributes:
Provider: SunEC, Version: 1.7, Class: sun.security.ec.SunEC
  Description: Sun Elliptic Curve provider (EC, ECDSA, ECDH)
  Services (9):
   Service: Signature, Algorithm: SHA512withECDSA, Class: sun.security.ec.ECDSASignature$SHA512
    Attributes:
      SupportedKeyClasses: java.security.interfaces.ECPublicKey|java.security.interfaces.ECPrivateKey
   Service: AlgorithmParameters, Algorithm: EC, Class: sun.security.ec.ECParameters
    Aliases: EllipticCurve
    Attributes:
      SupportedCurves: [secp112r1,1.3.132.0.6]|[secp112r2,1.3.132.0.7]|[secp128r1,1.3.132.0.28]|[secp128r2,1.3.132.0.29]|[secp160k1,1.3.132.0.9]|[secp160r1,1.3.132.0.8]|[secp160r2,1.3.132.0.30]|[secp192k1,1.3.132.0.31]|[secp192r1,NIST P-192,X9.62 prime192v1,1.2.840.10045.3.1.1]|[secp224k1,1.3.132.0.32]|[secp224r1,NIST P-224,1.3.132.0.33]|[secp256k1,1.3.132.0.10]|[secp256r1,NIST P-256,X9.62 prime256v1,1.2.840.10045.3.1.7]|[secp384r1,NIST P-384,1.3.132.0.34]|[secp521r1,NIST P-521,1.3.132.0.35]|[X9.62 prime192v2,1.2.840.10045.3.1.2]|[X9.62 prime192v3,1.2.840.10045.3.1.3]|[X9.62 prime239v1,1.2.840.10045.3.1.4]|[X9.62 prime239v2,1.2.840.10045.3.1.5]|[X9.62 prime239v3,1.2.840.10045.3.1.6]|[sect113r1,1.3.132.0.4]|[sect113r2,1.3.132.0.5]|[sect131r1,1.3.132.0.22]|[sect131r2,1.3.132.0.23]|[sect163k1,NIST K-163,1.3.132.0.1]|[sect163r1,1.3.132.0.2]|[sect163r2,NIST B-163,1.3.132.0.15]|[sect193r1,1.3.132.0.24]|[sect193r2,1.3.132.0.25]|[sect233k1,NIST K-233,1.3.132.0.26]|[sect233r1,NIST B-233,1.3.132.0.27]|[sect239k1,1.3.132.0.3]|[sect283k1,NIST K-283,1.3.132.0.16]|[sect283r1,NIST B-283,1.3.132.0.17]|[sect409k1,NIST K-409,1.3.132.0.36]|[sect409r1,NIST B-409,1.3.132.0.37]|[sect571k1,NIST K-571,1.3.132.0.38]|[sect571r1,NIST B-571,1.3.132.0.39]|[X9.62 c2tnb191v1,1.2.840.10045.3.0.5]|[X9.62 c2tnb191v2,1.2.840.10045.3.0.6]|[X9.62 c2tnb191v3,1.2.840.10045.3.0.7]|[X9.62 c2tnb239v1,1.2.840.10045.3.0.11]|[X9.62 c2tnb239v2,1.2.840.10045.3.0.12]|[X9.62 c2tnb239v3,1.2.840.10045.3.0.13]|[X9.62 c2tnb359v1,1.2.840.10045.3.0.18]|[X9.62 c2tnb431r1,1.2.840.10045.3.0.20]
      KeySize: 256
   Service: Signature, Algorithm: SHA384withECDSA, Class: sun.security.ec.ECDSASignature$SHA384
    Attributes:
   Service: Signature, Algorithm: NONEwithECDSA, Class: sun.security.ec.ECDSASignature$Raw
    Attributes:
   Service: Signature, Algorithm: SHA1withECDSA, Class: sun.security.ec.ECDSASignature$SHA1
    Attributes:
      KeySize: 256
   Service: KeyPairGenerator, Algorithm: EC, Class: sun.security.ec.ECKeyPairGenerator
    Attributes:
      KeySize: 256
   Service: KeyFactory, Algorithm: EC, Class: sun.security.ec.ECKeyFactory
    Attributes:
   Service: KeyAgreement, Algorithm: ECDH, Class: sun.security.ec.ECDHKeyAgreement
    Attributes:
   Service: Signature, Algorithm: SHA256withECDSA, Class: sun.security.ec.ECDSASignature$SHA256
    Attributes:
Provider: SunJSSE, Version: 1.7, Class: com.sun.net.ssl.internal.ssl.Provider
  Description: Sun JSSE provider(PKCS12, SunX509 key/trust factories, SSLv3, TLSv1)
  Services (15):
   Service: Signature, Algorithm: MD5andSHA1withRSA, Class: sun.security.ssl.RSASignature
   Service: SSLContext, Algorithm: Default, Class: sun.security.ssl.SSLContextImpl$DefaultSSLContext
   Service: KeyManagerFactory, Algorithm: SunX509, Class: sun.security.ssl.KeyManagerFactoryImpl$SunX509
    Aliases: OID.1.2.840.113549.1.1.4
   Service: TrustManagerFactory, Algorithm: SunX509, Class: sun.security.ssl.TrustManagerFactoryImpl$SimpleFactory
   Service: KeyStore, Algorithm: PKCS12, Class: sun.security.pkcs12.PKCS12KeyStore
   Service: SSLContext, Algorithm: TLSv1, Class: sun.security.ssl.SSLContextImpl$TLS10Context
    Aliases: TLS
   Service: SSLContext, Algorithm: TLSv1.2, Class: sun.security.ssl.SSLContextImpl$TLS12Context
   Service: KeyManagerFactory, Algorithm: NewSunX509, Class: sun.security.ssl.KeyManagerFactoryImpl$X509
    Aliases: PKIX
   Service: SSLContext, Algorithm: TLSv1.1, Class: sun.security.ssl.SSLContextImpl$TLS11Context
   Service: TrustManagerFactory, Algorithm: PKIX, Class: sun.security.ssl.TrustManagerFactoryImpl$PKIXFactory
    Aliases: X509
Provider: SunJCE, Version: 1.7, Class: com.sun.crypto.provider.SunJCE
  Description: SunJCE Provider (implements RSA, DES, Triple DES, AES, Blowfish, ARCFOUR, RC2, PBE, Diffie-Hellman, HMAC)
  Services (61):
   Service: KeyGenerator, Algorithm: DESede, Class: com.sun.crypto.provider.DESedeKeyGenerator
    Aliases: TripleDES
   Service: KeyGenerator, Algorithm: HmacSHA384, Class: com.sun.crypto.provider.KeyGeneratorCore$HmacSHA384KG
   Service: AlgorithmParameters, Algorithm: OAEP, Class: com.sun.crypto.provider.OAEPParameters
   Service: KeyGenerator, Algorithm: ARCFOUR, Class: com.sun.crypto.provider.KeyGeneratorCore$ARCFOURKeyGenerator
    Aliases: RC4
   Service: Cipher, Algorithm: AESWrap, Class: com.sun.crypto.provider.AESWrapCipher
    Attributes:
      SupportedPaddings: NOPADDING
      SupportedKeyFormats: RAW
      SupportedModes: ECB
   Service: KeyGenerator, Algorithm: HmacSHA256, Class: com.sun.crypto.provider.KeyGeneratorCore$HmacSHA256KG
   Service: KeyGenerator, Algorithm: HmacSHA512, Class: com.sun.crypto.provider.KeyGeneratorCore$HmacSHA512KG
   Service: KeyGenerator, Algorithm: SunTls12Prf, Class: com.sun.crypto.provider.TlsPrfGenerator$V12
   Service: AlgorithmParameters, Algorithm: AES, Class: com.sun.crypto.provider.AESParameters
    Aliases: Rijndael
   Service: AlgorithmParameters, Algorithm: PBEWithMD5AndTripleDES, Class: com.sun.crypto.provider.PBEParameters
   Service: AlgorithmParameters, Algorithm: RC2, Class: com.sun.crypto.provider.RC2Parameters
   Service: KeyStore, Algorithm: JCEKS, Class: com.sun.crypto.provider.JceKeyStore
   Service: KeyGenerator, Algorithm: SunTlsPrf, Class: com.sun.crypto.provider.TlsPrfGenerator$V10
   Service: Cipher, Algorithm: DES, Class: com.sun.crypto.provider.DESCipher
    Attributes:
      SupportedPaddings: NOPADDING|PKCS5PADDING|ISO10126PADDING
      SupportedModes: ECB|CBC|PCBC|CTR|CTS|CFB|OFB|CFB8|CFB16|CFB24|CFB32|CFB40|CFB48|CFB56|CFB64|OFB8|OFB16|OFB24|OFB32|OFB40|OFB48|OFB56|OFB64
   Service: Cipher, Algorithm: RSA, Class: com.sun.crypto.provider.RSACipher
    Attributes:
      SupportedPaddings: NOPADDING|PKCS1PADDING|OAEPWITHMD5ANDMGF1PADDING|OAEPWITHSHA1ANDMGF1PADDING|OAEPWITHSHA-1ANDMGF1PADDING|OAEPWITHSHA-256ANDMGF1PADDING|OAEPWITHSHA-384ANDMGF1PADDING|OAEPWITHSHA-512ANDMGF1PADDING
      SupportedModes: ECB
   Service: KeyFactory, Algorithm: DiffieHellman, Class: com.sun.crypto.provider.DHKeyFactory
    Aliases: DH
   Service: Cipher, Algorithm: PBEWithSHA1AndDESede, Class: com.sun.crypto.provider.PKCS12PBECipherCore$PBEWithSHA1AndDESede
    Aliases: OID.1.2.840.113549.1.12.1.3
   Service: AlgorithmParameters, Algorithm: DiffieHellman, Class: com.sun.crypto.provider.DHParameters
    Aliases: DH
   Service: Cipher, Algorithm: DESedeWrap, Class: com.sun.crypto.provider.DESedeWrapCipher
    Attributes:
      SupportedModes: CBC
   Service: KeyGenerator, Algorithm: SunTlsRsaPremasterSecret, Class: com.sun.crypto.provider.TlsRsaPremasterSecretGenerator
    Aliases: SunTls12RsaPremasterSecret
   Service: AlgorithmParameters, Algorithm: DESede, Class: com.sun.crypto.provider.DESedeParameters
    Aliases: TripleDES
   Service: KeyGenerator, Algorithm: HmacSHA1, Class: com.sun.crypto.provider.HmacSHA1KeyGenerator
   Service: SecretKeyFactory, Algorithm: PBEWithMD5AndDES, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithMD5AndDES
    Aliases: 1.2.840.113549.1.5.3
   Service: Cipher, Algorithm: PBEWithSHA1AndRC2_40, Class: com.sun.crypto.provider.PKCS12PBECipherCore$PBEWithSHA1AndRC2_40
    Aliases: OID.1.2.840.113549.1.12.1.6
   Service: Mac, Algorithm: HmacMD5, Class: com.sun.crypto.provider.HmacMD5
    Attributes:
   Service: SecretKeyFactory, Algorithm: DESede, Class: com.sun.crypto.provider.DESedeKeyFactory
    Aliases: TripleDES
   Service: Mac, Algorithm: SslMacSHA1, Class: com.sun.crypto.provider.SslMacCore$SslMacSHA1
    Attributes:
   Service: KeyGenerator, Algorithm: SunTlsMasterSecret, Class: com.sun.crypto.provider.TlsMasterSecretGenerator
    Aliases: SunTls12MasterSecret
   Service: KeyGenerator, Algorithm: DES, Class: com.sun.crypto.provider.DESKeyGenerator
   Service: Cipher, Algorithm: PBEWithMD5AndTripleDES, Class: com.sun.crypto.provider.PBEWithMD5AndTripleDESCipher
   Service: AlgorithmParameters, Algorithm: PBEWithSHA1AndDESede, Class: com.sun.crypto.provider.PBEParameters
   Service: Cipher, Algorithm: ARCFOUR, Class: com.sun.crypto.provider.ARCFOURCipher
    Aliases: RC4
    Attributes:
      SupportedModes: ECB
   Service: AlgorithmParameters, Algorithm: PBE, Class: com.sun.crypto.provider.PBEParameters
   Service: SecretKeyFactory, Algorithm: PBEWithMD5AndTripleDES, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithMD5AndTripleDES
   Service: Mac, Algorithm: HmacPBESHA1, Class: com.sun.crypto.provider.HmacPKCS12PBESHA1
    Attributes:
   Service: Cipher, Algorithm: AES, Class: com.sun.crypto.provider.AESCipher
    Aliases: Rijndael
    Attributes:
      SupportedModes: ECB|CBC|PCBC|CTR|CTS|CFB|OFB|CFB8|CFB16|CFB24|CFB32|CFB40|CFB48|CFB56|CFB64|OFB8|OFB16|OFB24|OFB32|OFB40|OFB48|OFB56|OFB64|CFB72|CFB80|CFB88|CFB96|CFB104|CFB112|CFB120|CFB128|OFB72|OFB80|OFB88|OFB96|OFB104|OFB112|OFB120|OFB128
   Service: SecretKeyFactory, Algorithm: DES, Class: com.sun.crypto.provider.DESKeyFactory
   Service: Cipher, Algorithm: RC2, Class: com.sun.crypto.provider.RC2Cipher
    Attributes:
   Service: AlgorithmParameters, Algorithm: PBEWithSHA1AndRC2_40, Class: com.sun.crypto.provider.PBEParameters
   Service: KeyAgreement, Algorithm: DiffieHellman, Class: com.sun.crypto.provider.DHKeyAgreement
    Aliases: DH
    Attributes:
      SupportedKeyClasses: javax.crypto.interfaces.DHPublicKey|javax.crypto.interfaces.DHPrivateKey
   Service: KeyGenerator, Algorithm: Blowfish, Class: com.sun.crypto.provider.BlowfishKeyGenerator
   Service: KeyPairGenerator, Algorithm: DiffieHellman, Class: com.sun.crypto.provider.DHKeyPairGenerator
    Aliases: DH
   Service: Cipher, Algorithm: PBEWithMD5AndDES, Class: com.sun.crypto.provider.PBEWithMD5AndDESCipher
   Service: Cipher, Algorithm: Blowfish, Class: com.sun.crypto.provider.BlowfishCipher
    Attributes:
   Service: AlgorithmParameters, Algorithm: DES, Class: com.sun.crypto.provider.DESParameters
   Service: KeyGenerator, Algorithm: AES, Class: com.sun.crypto.provider.AESKeyGenerator
    Aliases: Rijndael
   Service: KeyGenerator, Algorithm: HmacMD5, Class: com.sun.crypto.provider.HmacMD5KeyGenerator
   Service: SecretKeyFactory, Algorithm: PBKDF2WithHmacSHA1, Class: com.sun.crypto.provider.PBKDF2HmacSHA1Factory
    Aliases: OID.1.2.840.113549.1.5.12
   Service: KeyGenerator, Algorithm: RC2, Class: com.sun.crypto.provider.KeyGeneratorCore$RC2KeyGenerator
   Service: Mac, Algorithm: SslMacMD5, Class: com.sun.crypto.provider.SslMacCore$SslMacMD5
    Attributes:
   Service: SecretKeyFactory, Algorithm: PBEWithSHA1AndDESede, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithSHA1AndDESede
   Service: AlgorithmParameterGenerator, Algorithm: DiffieHellman, Class: com.sun.crypto.provider.DHParameterGenerator
    Aliases: DH
   Service: Mac, Algorithm: HmacSHA1, Class: com.sun.crypto.provider.HmacSHA1
    Attributes:
   Service: Mac, Algorithm: HmacSHA384, Class: com.sun.crypto.provider.HmacCore$HmacSHA384
    Attributes:
   Service: KeyGenerator, Algorithm: SunTlsKeyMaterial, Class: com.sun.crypto.provider.TlsKeyMaterialGenerator
    Aliases: SunTls12KeyMaterial
   Service: SecretKeyFactory, Algorithm: PBEWithSHA1AndRC2_40, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithSHA1AndRC2_40
   Service: Mac, Algorithm: HmacSHA256, Class: com.sun.crypto.provider.HmacCore$HmacSHA256
    Attributes:
   Service: AlgorithmParameters, Algorithm: Blowfish, Class: com.sun.crypto.provider.BlowfishParameters
   Service: Mac, Algorithm: HmacSHA512, Class: com.sun.crypto.provider.HmacCore$HmacSHA512
    Attributes:
   Service: AlgorithmParameters, Algorithm: PBEWithMD5AndDES, Class: com.sun.crypto.provider.PBEParameters
   Service: Cipher, Algorithm: DESede, Class: com.sun.crypto.provider.DESedeCipher
    Aliases: TripleDES
    Attributes:
Provider: SunJGSS, Version: 1.7, Class: sun.security.jgss.SunProvider
  Description: Sun (Kerberos v5, SPNEGO)
  Services (2):
   Service: GssApiMechanism, Algorithm: 1.3.6.1.5.5.2, Class: sun.security.jgss.spnego.SpNegoMechFactory
   Service: GssApiMechanism, Algorithm: 1.2.840.113554.1.2.2, Class: sun.security.jgss.krb5.Krb5MechFactory
Provider: SunSASL, Version: 1.7, Class: com.sun.security.sasl.Provider
  Description: Sun SASL provider(implements client mechanisms for: DIGEST-MD5, GSSAPI, EXTERNAL, PLAIN, CRAM-MD5, NTLM; server mechanisms for: DIGEST-MD5, GSSAPI, CRAM-MD5, NTLM)
  Services (10):
   Service: SaslClientFactory, Algorithm: NTLM, Class: com.sun.security.sasl.ntlm.FactoryImpl
   Service: SaslClientFactory, Algorithm: CRAM-MD5, Class: com.sun.security.sasl.ClientFactoryImpl
   Service: SaslClientFactory, Algorithm: EXTERNAL, Class: com.sun.security.sasl.ClientFactoryImpl
   Service: SaslClientFactory, Algorithm: DIGEST-MD5, Class: com.sun.security.sasl.digest.FactoryImpl
   Service: SaslClientFactory, Algorithm: PLAIN, Class: com.sun.security.sasl.ClientFactoryImpl
   Service: SaslServerFactory, Algorithm: NTLM, Class: com.sun.security.sasl.ntlm.FactoryImpl
   Service: SaslClientFactory, Algorithm: GSSAPI, Class: com.sun.security.sasl.gsskerb.FactoryImpl
   Service: SaslServerFactory, Algorithm: CRAM-MD5, Class: com.sun.security.sasl.ServerFactoryImpl
   Service: SaslServerFactory, Algorithm: DIGEST-MD5, Class: com.sun.security.sasl.digest.FactoryImpl
   Service: SaslServerFactory, Algorithm: GSSAPI, Class: com.sun.security.sasl.gsskerb.FactoryImpl
Provider: XMLDSig, Version: 1.0, Class: org.jcp.xml.dsig.internal.dom.XMLDSigRI
  Description: XMLDSig (DOM XMLSignatureFactory; DOM KeyInfoFactory)
  Services (13):
   Service: KeyInfoFactory, Algorithm: DOM, Class: org.jcp.xml.dsig.internal.dom.DOMKeyInfoFactory
   Service: TransformService, Algorithm: http://www.w3.org/TR/1999/REC-xpath-19991116, Class: org.jcp.xml.dsig.internal.dom.DOMXPathTransform
    Aliases: XPATH
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/TR/2001/REC-xml-c14n-20010315#WithComments, Class: org.jcp.xml.dsig.internal.dom.DOMCanonicalXMLC14NMethod
    Aliases: INCLUSIVE_WITH_COMMENTS
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/2000/09/xmldsig#base64, Class: org.jcp.xml.dsig.internal.dom.DOMBase64Transform
    Aliases: BASE64
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/2000/09/xmldsig#enveloped-signature, Class: org.jcp.xml.dsig.internal.dom.DOMEnvelopedTransform
    Aliases: ENVELOPED
    Attributes:
      MechanismType: DOM
   Service: XMLSignatureFactory, Algorithm: DOM, Class: org.jcp.xml.dsig.internal.dom.DOMXMLSignatureFactory
   Service: TransformService, Algorithm: http://www.w3.org/TR/2001/REC-xml-c14n-20010315, Class: org.jcp.xml.dsig.internal.dom.DOMCanonicalXMLC14NMethod
    Aliases: INCLUSIVE
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/2002/06/xmldsig-filter2, Class: org.jcp.xml.dsig.internal.dom.DOMXPathFilter2Transform
    Aliases: XPATH2
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/2001/10/xml-exc-c14n#, Class: org.jcp.xml.dsig.internal.dom.DOMExcC14NMethod
    Aliases: EXCLUSIVE
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/TR/1999/REC-xslt-19991116, Class: org.jcp.xml.dsig.internal.dom.DOMXSLTTransform
    Aliases: XSLT
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/2006/12/xml-c14n11#WithComments, Class: org.jcp.xml.dsig.internal.dom.DOMCanonicalXMLC14N11Method
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/2001/10/xml-exc-c14n#WithComments, Class: org.jcp.xml.dsig.internal.dom.DOMExcC14NMethod
    Aliases: EXCLUSIVE_WITH_COMMENTS
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/2006/12/xml-c14n11, Class: org.jcp.xml.dsig.internal.dom.DOMCanonicalXMLC14N11Method
    Attributes:
      MechanismType: DOM
Provider: SunPCSC, Version: 1.7, Class: sun.security.smartcardio.SunPCSC
  Description: Sun PC/SC provider
  Services (1):
   Service: TerminalFactory, Algorithm: PC/SC, Class: sun.security.smartcardio.SunPCSC$Factory
Provider: SunMSCAPI, Version: 1.7, Class: sun.security.mscapi.SunMSCAPI
  Description: Sun's Microsoft Crypto API provider
  Services (13):
   Service: Signature, Algorithm: SHA512withRSA, Class: sun.security.mscapi.RSASignature$SHA512
    Attributes:
      SupportedKeyClasses: sun.security.mscapi.Key
   Service: Signature, Algorithm: MD5withRSA, Class: sun.security.mscapi.RSASignature$MD5
    Attributes:
   Service: Signature, Algorithm: NONEwithRSA, Class: sun.security.mscapi.RSASignature$Raw
    Attributes:
   Service: Signature, Algorithm: SHA1withRSA, Class: sun.security.mscapi.RSASignature$SHA1
    Attributes:
   Service: Cipher, Algorithm: RSA, Class: sun.security.mscapi.RSACipher
    Attributes:
      SupportedPaddings: PKCS1PADDING
      SupportedModes: ECB
   Service: SecureRandom, Algorithm: Windows-PRNG, Class: sun.security.mscapi.PRNG
   Service: KeyStore, Algorithm: Windows-ROOT, Class: sun.security.mscapi.KeyStore$ROOT
   Service: Signature, Algorithm: SHA384withRSA, Class: sun.security.mscapi.RSASignature$SHA384
    Attributes:
   Service: KeyPairGenerator, Algorithm: RSA, Class: sun.security.mscapi.RSAKeyPairGenerator
    Attributes:
      KeySize: 1024
   Service: Signature, Algorithm: SHA256withRSA, Class: sun.security.mscapi.RSASignature$SHA256
    Attributes:
   Service: Cipher, Algorithm: RSA/ECB/PKCS1Padding, Class: sun.security.mscapi.RSACipher
   Service: Signature, Algorithm: MD2withRSA, Class: sun.security.mscapi.RSASignature$MD2
    Attributes:
   Service: KeyStore, Algorithm: Windows-MY, Class: sun.security.mscapi.KeyStore$MY
Content originally posted in LPCWare by nxpuser1 on Fri Mar 13 05:36:55 MST 2015
I use windows7, 64bits, Windows response
C:\Users\Egitim5>set
ALLUSERSPROFILE=C:\ProgramData
AMDAPPSDKROOT=C:\Program Files (x86)\AMD APP\
APPDATA=C:\Users\Egitim5\AppData\Roaming
CommonProgramFiles=C:\Program Files\Common Files
CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
CommonProgramW6432=C:\Program Files\Common Files
COMPUTERNAME=EGITIM5-HP
ComSpec=C:\Windows\system32\cmd.exe
FP_NO_HOST_CHECK=NO
HOMEDRIVE=C:
HOMEPATH=\Users\Egitim5
KMP_DUPLICATE_LIB_OK=TRUE
LOCALAPPDATA=C:\Users\Egitim5\AppData\Local
LOGONSERVER=\\EGITIM5-HP
MKL_SERIAL=YES
NUMBER_OF_PROCESSORS=4
OnlineServices=Online Services
OS=Windows_NT
Path=C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\HP SimplePass 20
11\;C:\Program Files\Broadcom\Broadcom 802.11\Driver;;C:\Program Files (x86)\AMD
APP\bin\x86_64;C:\Program Files (x86)\AMD APP\bin\x86;C:\Program Files\Common F
iles\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft
Shared\Windows Live;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\
Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Windows Live\Sha
red;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files
\WIDCOMM\Bluetooth Software\;C:\Program Files\WIDCOMM\Bluetooth Software\syswow6
4;C:\Program Files\Broadcom\WHL\;C:\Program Files\Broadcom\WHL\syswow64;C:\Progr
am Files\Broadcom\WHL\SysWow64\;C:\Program Files\Broadcom\WHL\SysWow64\syswow64;
C:\Program Files (x86)\Intel\Services\IPT\;C:\Program Files (x86)\Microchip\MPLA
B C32 Suite\bin;C:\Program Files (x86)\HI-TECH Software\PICC\9.83\bin;C:\Program
Files (x86)\Microchip\xc16\v1.21\bin;c:\Program Files (x86)\Microsoft SQL Serve
r\100\Tools\Binn\;c:\Program Files\Microsoft SQL Server\100\Tools\Binn\;c:\Progr
am Files\Microsoft SQL Server\100\DTS\Binn\
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
PCBRAND=Pavilion
Platform=MCD
PROCESSOR_ARCHITECTURE=AMD64
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 42 Stepping 7, GenuineIntel
PROCESSOR_LEVEL=6
PROCESSOR_REVISION=2a07
ProgramData=C:\ProgramData
PROMPT=$P$G
PSModulePath=C:\Windows\system32\WindowsPowerShell\v1.0\Modules\
PUBLIC=C:\Users\Public
SESSIONNAME=Console
SystemDrive=C:
SystemRoot=C:\Windows
TEMP=C:\Users\Egitim5\AppData\Local\Temp
TMP=C:\Users\Egitim5\AppData\Local\Temp
USERDOMAIN=Egitim5-HP
USERNAME=Egitim5
USERPROFILE=C:\Users\Egitim5
windir=C:\Windows
windows_tracing_flags=3
windows_tracing_logfile=C:\BVTBin\Tests\installpackage\csilogfile.log
IDE :
*** Date: 13 Mart 2015 Cuma 14:35:46 Doğu Avrupa Standart Saati
*** Platform Details:
*** System properties:
applicationXMI=org.eclipse.ui.workbench/LegacyIDE.e4xmi
awt.toolkit=sun.awt.windows.WToolkit
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
-launcher
C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\lpcxpresso.exe
-name
Lpcxpresso
--launcher.library
C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\\plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.1.200.v20140603-1326\eclipse_1603.dll
-startup
C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\\plugins/org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar
--launcher.overrideVmargs
-vm
C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\bin\client\jvm.dll
eclipse.home.location=file:/C:/nxp/LPCXpresso_7.6.2_326/lpcxpresso/
eclipse.launcher=C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\lpcxpresso.exe
eclipse.launcher.name=Lpcxpresso
eclipse.p2.data.area=@config.dir/../p2
eclipse.p2.profile=DefaultProfile
eclipse.product=com.crt.lpcxpresso.brand.product
eclipse.startTime=1426239422881
eclipse.stateSaveDelayInterval=30000
eclipse.vm=C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\bin\client\jvm.dll
eclipse.vmargs=-Dosgi.requiredJavaVersion=1.7
-Xms128m
-Xmx512m
-XX:MaxPermSize=256M
-Djava.class.path=C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\\plugins/org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar
equinox.use.ds=true
file.encoding=Cp1254
file.encoding.pkg=sun.io
file.separator=\
gosh.args=--nointeractive
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.version=51.0
java.endorsed.dirs=C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\lib\endorsed
java.ext.dirs=C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\lib\ext;C:\Windows\Sun\Java\lib\ext
java.home=C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre
java.io.tmpdir=C:\Users\Egitim5\AppData\Local\Temp\
java.library.path=C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:/nxp/LPCXpresso_7.6.2_326/lpcxpresso/jre/bin/client;C:/nxp/LPCXpresso_7.6.2_326/lpcxpresso/jre/bin;C:/nxp/LPCXpresso_7.6.2_326/lpcxpresso/jre/lib/i386;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\HP SimplePass 2011\;C:\Program Files\Broadcom\Broadcom 802.11\Driver;;C:\Program Files (x86)\AMD APP\bin\x86_64;C:\Program Files (x86)\AMD APP\bin\x86;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Windows Live\Shared;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files\WIDCOMM\Bluetooth Software\;C:\Program Files\WIDCOMM\Bluetooth Software\syswow64;C:\Program Files\Broadcom\WHL\;C:\Program Files\Broadcom\WHL\syswow64;C:\Program Files\Broadcom\WHL\SysWow64\;C:\Program Files\Broadcom\WHL\SysWow64\syswow64;C:\Program Files (x86)\Intel\Services\IPT\;C:\Program Files (x86)\Microchip\MPLAB C32 Suite\bin;C:\Program Files (x86)\HI-TECH Software\PICC\9.83\bin;C:\Program Files (x86)\Microchip\xc16\v1.21\bin;c:\Program Files (x86)\Microsoft SQL Server\100\Tools\Binn\;c:\Program Files\Microsoft SQL Server\100\Tools\Binn\;c:\Program Files\Microsoft SQL Server\100\DTS\Binn\;C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso;;.
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.7.0_71-b14
java.specification.name=Java Platform API Specification
java.specification.vendor=Oracle Corporation
java.specification.version=1.7
java.vendor=Oracle Corporation
java.vendor.url=http://java.oracle.com/
java.vendor.url.bug=http://bugreport.sun.com/bugreport/
java.version=1.7.0_71
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Oracle Corporation
java.vm.specification.version=1.7
java.vm.vendor=Oracle Corporation
java.vm.version=24.71-b01
line.separator=
org.eclipse.cdt.debug.ui.debuggerActive=false
org.eclipse.debug.ui.breakpoints.toggleFactoriesUsed=true
org.eclipse.equinox.launcher.splash.location=c:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\configuration\org.eclipse.equinox.launcher\com.crt.lpcxpresso.brand_7.4.1.201502020932\splash.bmp
org.eclipse.equinox.simpleconfigurator.configUrl=file:org.eclipse.equinox.simpleconfigurator/bundles.info
org.eclipse.update.reconcile=false
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSGi/Minimum-1.1,OSGi/Minimum-1.2,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,JavaSE-1.6,JavaSE-1.7
org.osgi.framework.language=tr
org.osgi.framework.os.name=Windows7
org.osgi.framework.os.version=6.1.0
org.osgi.framework.processor=x86
org.osgi.framework.system.capabilities=osgi.ee; osgi.ee="OSGi/Minimum"; version:List<Version>="1.0, 1.1, 1.2",osgi.ee; osgi.ee="JRE"; version:List<Version>="1.0, 1.1",osgi.ee; osgi.ee="JavaSE"; version:List<Version>="1.0, 1.1, 1.2, 1.3, 1.4, 1.5, 1.6, 1.7"
org.osgi.framework.system.packages=javax.accessibility,javax.activation,javax.activity,javax.annotation,javax.annotation.processing,javax.crypto,javax.crypto.interfaces,javax.crypto.spec,javax.imageio,javax.imageio.event,javax.imageio.metadata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap,javax.lang.model,javax.lang.model.element,javax.lang.model.type,javax.lang.model.util,javax.management,javax.management.loading,javax.management.modelmbean,javax.management.monitor,javax.management.openmbean,javax.management.relation,javax.management.remote,javax.management.remote.rmi,javax.management.timer,javax.naming,javax.naming.directory,javax.naming.event,javax.naming.ldap,javax.naming.spi,javax.net,javax.net.ssl,javax.print,javax.print.attribute,javax.print.attribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.rmi.ssl,javax.script,javax.security.auth,javax.security.auth.callback,javax.security.auth.kerberos,javax.security.auth.login,javax.security.auth.spi,javax.security.auth.x500,javax.security.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi,javax.swing,javax.swing.border,javax.swing.colorchooser,javax.swing.event,javax.swing.filechooser,javax.swing.plaf,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.nimbus,javax.swing.plaf.synth,javax.swing.table,javax.swing.text,javax.swing.text.html,javax.swing.text.html.parser,javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.tools,javax.transaction,javax.transaction.xa,javax.xml,javax.xml.bind,javax.xml.bind.annotation,javax.xml.bind.annotation.adapters,javax.xml.bind.attachment,javax.xml.bind.helpers,javax.xml.bind.util,javax.xml.crypto,javax.xml.crypto.dom,javax.xml.crypto.dsig,javax.xml.crypto.dsig.dom,javax.xml.crypto.dsig.keyinfo,javax.xml.crypto.dsig.spec,javax.xml.datatype,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,javax.xml.stream,javax.xml.stream.events,javax.xml.stream.util,javax.xml.transform,javax.xml.transform.dom,javax.xml.transform.sax,javax.xml.transform.stax,javax.xml.transform.stream,javax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax.xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,javax.xml.ws.spi,javax.xml.ws.spi.http,javax.xml.ws.wsaddressing,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNaming.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.omg.PortableServer,org.omg.PortableServer.CurrentPackage,org.omg.PortableServer.POAManagerPackage,org.omg.PortableServer.POAPackage,org.omg.PortableServer.portable,org.omg.PortableServer.ServantLocatorPackage,org.omg.SendingContext,org.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.css,org.w3c.dom.events,org.w3c.dom.html,org.w3c.dom.ls,org.w3c.dom.ranges,org.w3c.dom.stylesheets,org.w3c.dom.traversal,org.w3c.dom.views,org.w3c.dom.xpath,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.uuid=806c6981-64c9-0014-1923-c7caabcbe0d5
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.8.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=x86
os.name=Windows 7
os.version=6.1
osgi.arch=x86
osgi.bundles=reference:file:org.eclipse.osgi.compatibility.state_1.0.1.v20140709-1414.jar,reference:file:org.eclipse.equinox.simpleconfigurator_1.1.0.v20131217-1203.jar@1:start
osgi.bundles.defaultStartLevel=4
osgi.compatibility.bootdelegation=true
osgi.configuration.area=file:/C:/nxp/LPCXpresso_7.6.2_326/lpcxpresso/configuration/
osgi.configuration.area.default=null
osgi.framework=file:/c:/nxp/LPCXpresso_7.6.2_326/lpcxpresso/plugins/org.eclipse.osgi_3.10.1.v20140909-1633.jar
osgi.framework.extensions=reference:file:org.eclipse.osgi.compatibility.state_1.0.1.v20140709-1414.jar
osgi.framework.shape=jar
osgi.framework.useSystemProperties=true
osgi.frameworkClassPath=., file:c:/nxp/LPCXpresso_7.6.2_326/lpcxpresso/plugins/org.eclipse.osgi.compatibility.state_1.0.1.v20140709-1414.jar
osgi.install.area=file:/C:/nxp/LPCXpresso_7.6.2_326/lpcxpresso/
osgi.instance.area=file:/C:/Users/Egitim5/Documents/LPCXpresso_7.6.2_326/workspace/
osgi.instance.area.default=file:/C:/Users/Egitim5/Documents/LPCXpresso_7.6.2_326/workspace/
osgi.logfile=C:\Users\Egitim5\Documents\LPCXpresso_7.6.2_326\workspace\.metadata\.log
osgi.nl=tr_TR
osgi.os=win32
osgi.splashLocation=c:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\configuration\org.eclipse.equinox.launcher\com.crt.lpcxpresso.brand_7.4.1.201502020932\splash.bmp
osgi.splashPath=platform:/base/plugins/com.crt.lpcxpresso.brand
osgi.syspath=c:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\plugins
osgi.tracefile=C:\Users\Egitim5\Documents\LPCXpresso_7.6.2_326\workspace\.metadata\trace.log
osgi.user.area=null
osgi.user.area.default=null
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\lib\resources.jar;C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\lib\rt.jar;C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\lib\sunrsasign.jar;C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\lib\jsse.jar;C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\lib\jce.jar;C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\lib\charsets.jar;C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\lib\jfr.jar;C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\classes
sun.boot.library.path=C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium_pro+mmx pentium_pro pentium+mmx pentium i486 i386 i86
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1254
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 1
user.country=TR
user.dir=C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso
user.home=C:\Users\Egitim5
user.language=tr
user.name=Egitim5
user.script=
user.timezone=Europe/Athens
user.variant=
*** Features:
com.crt.lpcxpresso.feature (7.4.1.201502020932) "LPCXpresso Product Definition"
org.eclipse.cdt (8.5.0.201409172108) "Eclipse C/C++ Development Tools"
org.eclipse.cdt.gdb (8.5.0.201409172108) "GDB Common"
org.eclipse.cvs (1.4.100.v20140925-0400) "Eclipse CVS Client"
org.eclipse.emf.common (2.10.1.v20140901-1043) "EMF Common"
org.eclipse.emf.ecore (2.10.1.v20140901-1043) "EMF Ecore"
org.eclipse.help (2.0.102.v20140925-0400) "Help System Base"
org.eclipse.platform (4.4.0.v20140925-0400) "Eclipse Platform"
org.eclipse.rcp (4.4.0.v20140925-0400) "Eclipse RCP"
*** Plug-in Registry:
com.crt.advproject (7.4.1.201502020932) "Advanced Project Support" [Active]
com.crt.config (7.4.1.201502020932) "Target Configuration" [Active]
com.crt.ctrlcenter (7.4.1.201502020932) "Project Configuration" [Active]
com.crt.debugcommon (7.4.1.201502020932) "Debug Common" [Active]
com.crt.debugmgr (7.4.1.201502020932) "Debug Manager" [Starting]
com.crt.docs (7.4.1.201502020932) "LPCXpresso Documentation" [Resolved]
com.crt.docs.rsguide (7.4.1.201502020932) "LPCXpresso Guide" [Resolved]
com.crt.dsfdebug (7.4.1.201502020932) "DSF Debug Support" [Active]
com.crt.dsfswv (7.4.1.201502020932) "Red Trace+" [Starting]
com.crt.etmetb (7.4.1.201502020932) "Instruction Trace Support" [Starting]
com.crt.lite (7.4.1.201502020932) "Develop Perspective" [Active]
com.crt.lpcxpresso.brand (7.4.1.201502020932) "LPCXpresso Product Definition" [Active]
com.crt.quickstart (7.4.1.201502020932) "Quickstart Panel" [Active]
com.crt.redstate (7.4.1.201502020932) "RedState" [Starting]
com.crt.utils (7.4.1.201502020932) "LPCXpresso Utilities" [Active]
com.crt.vendor.arm.generic (7.4.1.201502020932) "Generic ARM Support" [Starting]
com.crt.vendor.nxp.a7 (7.4.1.201502020932) "NXP LPC2000 Support" [Active]
com.crt.vendor.nxp.generic (7.4.1.201502020932) "NXP Generic Core Support" [Active]
com.crt.vendor.nxp.lpc11 (7.4.1.201502020932) "NXP LPC1100 Support" [Active]
com.crt.vendor.nxp.lpc13 (7.4.1.201502020932) "NXP LPC1300 Support" [Active]
com.crt.vendor.nxp.lpc17 (7.4.1.201502020932) "NXP LPC1700 Support" [Active]
com.crt.vendor.nxp.lpc18 (7.4.1.201502020932) "NXP LPC1800 Support" [Active]
com.crt.vendor.nxp.lpc29 (7.4.1.201502020932) "NXP LPC2900 Support" [Active]
com.crt.vendor.nxp.lpc31 (7.4.1.201502020932) "NXP LPC3000 Support" [Active]
com.crt.vendor.nxp.lpc43 (7.4.1.201502020932) "NXP LPC4000 Support" [Active]
com.crt.vendor.nxp.niobe (7.4.1.201502020932) "NXP LPC5xxxx Series Support" [Active]
com.ibm.icu (52.1.0.v201404241930) "International Components for Unicode for Java (ICU4J)" [Active]
com.jcraft.jsch (0.1.50.v201403120620) "JSch" [Resolved]
com.nxp.gnudocs (7.4.1.201502020932) "GNU Help Documents Provider" [Starting]
com.nxp.symbolbrowser (7.4.1.201502020932) "Symbol Viewer" [Active]
com.sun.el (2.2.0.v201303151357) "Javax Expression Language Reference Implementation Bundle" [Resolved]
javax.annotation (1.2.0.v201401042248) "javax.annotation Bundle" [Resolved]
javax.el (2.2.0.v201303151357) "Javax Expression Language Bundle" [Resolved]
javax.inject (1.0.0.v20091030) "Atinject Dependency Injection Annotations" [Resolved]
javax.servlet (3.0.0.v201112011016) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.2.0.v201112011158) "JSP API Bundle" [Resolved]
javax.xml (1.3.4.v201005080400) "JAXP XML" [Resolved]
org.apache.ant (1.9.2.v201404171502) "Apache Ant" [Resolved]
org.apache.batik.css (1.7.0.v201011041433) "Apache Batik CSS" [Resolved]
org.apache.batik.util (1.7.0.v201011041433) "Apache Batik Utilities" [Resolved]
org.apache.batik.util.gui (1.7.0.v200903091627) "Apache Batik GUI Utilities" [Resolved]
org.apache.commons.codec (1.6.0.v201305230611) "Apache Commons Codec Plug-in" [Resolved]
org.apache.commons.logging (1.1.1.v201101211721) "Apache Commons Logging Plug-in" [Resolved]
org.apache.felix.gogo.command (0.10.0.v201209301215) "Apache Felix Gogo Command" [Active]
org.apache.felix.gogo.runtime (0.10.0.v201209301036) "Apache Felix Gogo Runtime" [Active]
org.apache.felix.gogo.shell (0.10.0.v201212101605) "Apache Felix Gogo Shell" [Active]
org.apache.httpcomponents.httpclient (4.2.6.v201311072007) "Apache HttpComponents HttpClient OSGi bundle" [Resolved]
org.apache.httpcomponents.httpcore (4.2.5.v201311072007) "Apache HttpComponents HttpCore" [Resolved]
org.apache.jasper.glassfish (2.2.2.v201205150955) "JSP 2.2 implementation from Glassfish" [Resolved]
org.apache.lucene.analysis (3.5.0.v20120725-1805) "Apache Lucene Analysis" [Resolved]
org.apache.lucene.core (3.5.0.v20120725-1805) "Apache Lucene Core" [Resolved]
org.eclipse.ant.core (3.3.0.v20140518-0042) "Ant Build Tool Core" [Starting]
org.eclipse.cdt (8.5.0.201409172108) "Eclipse C/C++ Development Tools" [Starting]
org.eclipse.cdt.codan.checkers (3.2.0.201409172108) "Codan Checkers" [Active]
org.eclipse.cdt.codan.checkers.ui (3.2.0.201409172108) "Codan Checkers UI" [Active]
org.eclipse.cdt.codan.core (3.2.0.201409172108) "Code Analysis Core" [Active]
org.eclipse.cdt.codan.core.cxx (3.2.0.201409172108) "Code Analysis Core for C/C++" [Active]
org.eclipse.cdt.codan.ui (3.2.0.201409172108) "Code Analysis UI" [Active]
org.eclipse.cdt.codan.ui.cxx (3.2.0.201409172108) "Codan Analysis UI for C/C++" [Active]
org.eclipse.cdt.core (5.8.0.201409172108) "C/C++ Development Tools Core" [Active]
org.eclipse.cdt.core.native (5.7.0.201409172108) "C/C++ Development Tools Core Native Utilities" [Active]
org.eclipse.cdt.core.win32 (5.4.0.201409172108) "C/C++ Development Tools Core Native Utilities for Windows" [Resolved]
org.eclipse.cdt.core.win32.x86 (5.3.0.201409172108) "C/C++ Development Tools Core Native Utilities for Windows (x86)" [Resolved]
org.eclipse.cdt.debug.core (7.5.0.201409172108) "C/C++ Development Tools Debug Model" [Active]
org.eclipse.cdt.debug.gdbjtag (7.0.0.201409172108) "Eclipse GDB Hardware Debugging Plug-in" [Resolved]
org.eclipse.cdt.debug.gdbjtag.core (8.4.0.201409172108) "Eclipse GDB Hardware Debug Core Plug-in" [Starting]
org.eclipse.cdt.debug.gdbjtag.ui (7.1.0.201409172108) "Eclipse GDB Hardware Debug UI Plug-in" [Starting]
org.eclipse.cdt.debug.mi.core (7.3.0.201409172108) "C/C++ Development Tools GDB/MI CDI Debugger Core" [Active]
org.eclipse.cdt.debug.mi.ui (6.2.0.201409172108) "C/C++ Development Tools GDB/MI CDI Debugger UI" [Active]
org.eclipse.cdt.debug.ui (7.5.0.201409172108) "C/C++ Development Tools Debugger UI" [Active]
org.eclipse.cdt.debug.ui.memory.memorybrowser (1.3.0.201409172108) "Memory Browser" [Starting]
org.eclipse.cdt.debug.ui.memory.search (1.3.0.201409172108) "Memory Search" [Starting]
org.eclipse.cdt.debug.ui.memory.traditional (1.2.1.201409172108) "Traditional Memory Rendering" [Starting]
org.eclipse.cdt.debug.ui.memory.transport (2.1.0.201409172108) "Memory Transport Plug-in" [Starting]
org.eclipse.cdt.doc.user (5.3.0.201409172108) "C/C++ Development User Guide" [Starting]
org.eclipse.cdt.dsf (2.5.0.201409172108) "Debug Services Framework Core" [Active]
org.eclipse.cdt.dsf.gdb (4.5.0.201409172108) "GDB DSF Debugger Integration Core" [Active]
org.eclipse.cdt.dsf.gdb.ui (2.4.0.201409172108) "GDB DSF Debugger Integration UI" [Active]
org.eclipse.cdt.dsf.ui (2.4.100.201409172108) "Debugger Services Framework UI" [Active]
org.eclipse.cdt.gdb (7.0.0.201409172108) "GDB Common" [Starting]
org.eclipse.cdt.gdb.ui (7.0.0.201409172108) "GDB UI Common" [Starting]
org.eclipse.cdt.launch (7.1.0.201409172108) "C/C++ Development Tools Launching Support" [Active]
org.eclipse.cdt.make.core (7.3.0.201409172108) "C/C++ Standard make Build Core" [Active]
org.eclipse.cdt.make.ui (7.2.0.201409172108) "C/C++ Standard make Build UI" [Active]
org.eclipse.cdt.managedbuilder.core (8.3.0.201409172108) "CDT Build System Core" [Active]
org.eclipse.cdt.managedbuilder.gnu.ui (8.3.0.201409172108) "GNU Managed Build Definitions" [Active]
org.eclipse.cdt.managedbuilder.ui (8.2.2.201409172108) "C/C++ Managed Builder UI" [Active]
org.eclipse.cdt.ui (5.8.1.201409172108) "C/C++ Development Tools UI" [Active]
org.eclipse.compare (3.5.501.v20140817-1445) "Compare Support" [Active]
org.eclipse.compare.core (3.5.400.v20130903-0736) "Core Compare Support" [Active]
org.eclipse.compare.win32 (1.0.200.v20130514-1224) "Compare Support for Word" [Starting]
org.eclipse.core.commands (3.6.100.v20140528-1422) "Commands" [Resolved]
org.eclipse.core.contenttype (3.4.200.v20140207-1251) "Eclipse Content Mechanism" [Active]
org.eclipse.core.databinding (1.4.2.v20140729-1044) "JFace Data Binding" [Starting]
org.eclipse.core.databinding.beans (1.2.200.v20140214-0004) "JFace Data Binding for JavaBeans" [Resolved]
org.eclipse.core.databinding.observable (1.4.1.v20140210-1835) "JFace Data Binding Observables" [Active]
org.eclipse.core.databinding.property (1.4.200.v20140214-0004) "JFace Data Binding Properties" [Starting]
org.eclipse.core.expressions (3.4.600.v20140128-0851) "Expression Language" [Active]
org.eclipse.core.externaltools (1.0.300.v20140219-0051) "External Tools Headless Support" [Active]
org.eclipse.core.filebuffers (3.5.400.v20140127-1516) "File Buffers" [Active]
org.eclipse.core.filesystem (1.4.100.v20140514-1614) "Core File Systems" [Active]
org.eclipse.core.filesystem.java7 (1.0.0.v20140429-1531) "Core File System for Java 7 and newer" [Resolved]
org.eclipse.core.filesystem.win32.x86 (1.4.0.v20140124-1940) "Core File System for Windows" [Resolved]
org.eclipse.core.jobs (3.6.0.v20140424-0053) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.net (1.2.200.v20140124-2013) "Internet Connection Management" [Active]
org.eclipse.core.net.win32.x86 (1.0.100.v20140124-2013) "Proxy for Windows" [Resolved]
org.eclipse.core.resources (3.9.1.v20140825-1431) "Core Resource Management" [Active]
org.eclipse.core.resources.win32.x86 (3.5.100.v20140124-1940) "Core Resource Management Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.10.0.v20140318-2214) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.2.200.v20140128-0851) "Core Runtime Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.registry (3.5.300.v20140128-0851) "Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.2.800.v20130819-1716) "Core Variables" [Active]
org.eclipse.cvs (1.4.100.v20140925-0400) "Eclipse CVS Client" [Starting]
org.eclipse.debug.core (3.9.1.v20140805-1629) "Debug Core" [Active]
org.eclipse.debug.ui (3.10.1.v20140822-1408) "Debug UI" [Active]
org.eclipse.draw2d (3.9.101.201408150207) "Graphical Editing Framework Draw2d" [Starting]
org.eclipse.e4.core.commands (0.10.2.v20140424-2344) "Eclipse e4 core commands" [Active]
org.eclipse.e4.core.contexts (1.3.100.v20140407-1019) "Eclipse Contexts" [Active]
org.eclipse.e4.core.di (1.4.0.v20140414-1837) "Eclipse Dependency Injection" [Active]
org.eclipse.e4.core.di.extensions (0.12.0.v20140417-2033) "Eclipse Dependency Injection Extensions" [Active]
org.eclipse.e4.core.services (1.2.1.v20140808-1251) "Eclipse Application Services" [Active]
org.eclipse.e4.ui.bindings (0.10.200.v20140424-2042) "Eclipse Bindings Support" [Active]
org.eclipse.e4.ui.css.core (0.10.100.v20140424-2042) "Eclipse CSS Core Support" [Resolved]
org.eclipse.e4.ui.css.swt (0.11.101.v20140818-1343) "Eclipse CSS SWT Support" [Active]
org.eclipse.e4.ui.css.swt.theme (0.9.300.v20140424-2042) "Eclipse CSS SWT Theme Support" [Active]
org.eclipse.e4.ui.di (1.0.0.v20140328-2112) "Eclipse UI Dependency Injection" [Active]
org.eclipse.e4.ui.model.workbench (1.1.0.v20140512-1820) "Eclipse Workbench Model" [Active]
org.eclipse.e4.ui.services (1.1.0.v20140328-1925) "Eclipse UI Application Services" [Active]
org.eclipse.e4.ui.widgets (1.0.0.v20140514-1823) "Eclipse UI Custom widgets" [Resolved]
org.eclipse.e4.ui.workbench (1.2.1.v20140901-1244) "Eclipse e4 Workbench" [Active]
org.eclipse.e4.ui.workbench.addons.swt (1.1.1.v20140903-0821) "Eclipse e4 Workbench Add-ons" [Active]
org.eclipse.e4.ui.workbench.renderers.swt (0.12.1.v20140903-1023) "Eclipse e4 Workbench SWT Renderer" [Active]
org.eclipse.e4.ui.workbench.swt (0.12.100.v20140530-1436) "Eclipse e4 Workbench SWT" [Active]
org.eclipse.e4.ui.workbench3 (0.12.0.v20140227-2118) "Bundle for Workbench APIs available in e4" [Resolved]
org.eclipse.ecf (3.4.0.v20140827-1444) "ECF Core API" [Starting]
org.eclipse.ecf.filetransfer (5.0.0.v20140827-1444) "ECF Filetransfer API" [Starting]
org.eclipse.ecf.identity (3.4.0.v20140827-1444) "ECF Identity Core API" [Starting]
org.eclipse.ecf.provider.filetransfer (3.2.200.v20140827-1444) "ECF Filetransfer Provider" [Starting]
org.eclipse.ecf.provider.filetransfer.httpclient4 (1.0.800.v20140827-1444) "ECF HttpComponents Filetransfer Provider" [Starting]
org.eclipse.ecf.provider.filetransfer.httpclient4.ssl (1.0.0.v20140827-1444) "ECF HttpComponents Filetransfer Provider" [Resolved]
org.eclipse.ecf.provider.filetransfer.ssl (1.0.0.v20140827-1444) "ECF Filetransfer Provider" [Resolved]
org.eclipse.ecf.ssl (1.1.0.v20140827-1444) "ECF Core API" [Resolved]
org.eclipse.emf.common (2.10.1.v20140901-1043) "EMF Common" [Active]
org.eclipse.emf.ecore (2.10.1.v20140901-1043) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.10.0.v20140901-1043) "EMF Change Model" [Starting]
org.eclipse.emf.ecore.xmi (2.10.1.v20140901-1043) "EMF XML/XMI Persistence" [Active]
org.eclipse.equinox.app (1.3.200.v20130910-1609) "Equinox Application Container" [Active]
org.eclipse.equinox.bidi (0.10.0.v20130327-1442) "Bidirectional Text Support" [Starting]
org.eclipse.equinox.common (3.6.200.v20130402-1505) "Common Eclipse Runtime" [Active]
org.eclipse.equinox.concurrent (1.1.0.v20130327-1442) "Equinox Concurrent API" [Starting]
org.eclipse.equinox.console (1.1.0.v20140131-1639) "Console plug-in" [Active]
org.eclipse.equinox.ds (1.4.200.v20131126-2331) "Declarative Services" [Active]
org.eclipse.equinox.event (1.3.100.v20140115-1647) "Event Admin" [Active]
org.eclipse.equinox.frameworkadmin (2.0.100.v20131209-2144) "Equinox Framework Admin" [Starting]
org.eclipse.equinox.frameworkadmin.equinox (1.0.500.v20131211-1531) "Equinox Framework Admin for Equinox" [Starting]
org.eclipse.equinox.http.jetty (3.0.200.v20131021-1843) "Jetty Http Service" [Starting]
org.eclipse.equinox.http.registry (1.1.300.v20130402-1529) "Http Service Registry Extensions" [Resolved]
org.eclipse.equinox.http.servlet (1.1.500.v20140318-1755) "Http Services Servlet" [Starting]
org.eclipse.equinox.jsp.jasper (1.0.400.v20130327-1442) "Jasper Jsp Support Bundle" [Starting]
org.eclipse.equinox.jsp.jasper.registry (1.0.300.v20130327-1442) "Jasper Jsp Registry Support Plug-in" [Starting]
org.eclipse.equinox.launcher (1.3.0.v20140415-2008) "Equinox Launcher" [Resolved]
org.eclipse.equinox.launcher.win32.win32.x86 (1.1.200.v20140603-1326) "Equinox Launcher Win32 X86 Fragment" [Resolved]
org.eclipse.equinox.p2.artifact.repository (1.1.300.v20131211-1531) "Equinox Provisioning Artifact Repository Support" [Starting]
org.eclipse.equinox.p2.console (1.0.300.v20131113-1212) "Equinox Provisioning Console" [Starting]
org.eclipse.equinox.p2.core (2.3.0.v20131211-1531) "Equinox Provisioning Core" [Active]
org.eclipse.equinox.p2.director (2.3.100.v20140224-1921) "Equinox Provisioning Director" [Starting]
org.eclipse.equinox.p2.director.app (1.0.300.v20140228-1829) "Equinox Provisioning Director Application" [Starting]
org.eclipse.equinox.p2.directorywatcher (1.1.0.v20131211-1531) "Equinox Provisioning Directory Watcher" [Active]
org.eclipse.equinox.p2.engine (2.3.0.v20140506-1720) "Equinox Provisioning Engine" [Active]
org.eclipse.equinox.p2.extensionlocation (1.2.100.v20131119-0908) "Equinox Provisioning Extension Location Repository Support" [Starting]
org.eclipse.equinox.p2.garbagecollector (1.0.200.v20131115-1210) "Equinox Provisioning Garbage Collector" [Starting]
org.eclipse.equinox.p2.jarprocessor (1.0.300.v20131211-1531) "Equinox Provisioning JAR Processor" [Resolved]
org.eclipse.equinox.p2.metadata (2.2.0.v20131211-1531) "Equinox Provisioning Metadata" [Active]
org.eclipse.equinox.p2.metadata.repository (1.2.100.v20131209-2144) "Equinox Provisioning Metadata Repository" [Active]
org.eclipse.equinox.p2.operations (2.4.0.v20131119-0908) "Equinox Provisioning Operations API" [Active]
org.eclipse.equinox.p2.publisher (1.3.0.v20140911-0143) "Equinox Provisioning Publisher Infrastructure" [Starting]
org.eclipse.equinox.p2.publisher.eclipse (1.1.200.v20140414-0825) "Equinox Provisioning Publisher for Eclipse" [Starting]
org.eclipse.equinox.p2.ql (2.0.100.v20131211-1531) "Equinox Provisioning p2 query language" [Starting]
org.eclipse.equinox.p2.reconciler.dropins (1.1.200.v20131119-0908) "Equinox Provisioning Drop-in" [Active]
org.eclipse.equinox.p2.repository (2.3.0.v20131211-1531) "Equinox Provisioning Repository" [Active]
org.eclipse.equinox.p2.repository.tools (2.1.0.v20131211-1531) "Equinox Provisioning Repository Tools" [Starting]
org.eclipse.equinox.p2.touchpoint.eclipse (2.1.200.v20140512-1650) "Equinox Provisioning Eclipse Touchpoint" [Starting]
org.eclipse.equinox.p2.touchpoint.natives (1.1.100.v20140523-0116) "Equinox Provisioning Native Touchpoint" [Starting]
org.eclipse.equinox.p2.transport.ecf (1.1.0.v20140408-1354) "Equinox Provisioning ECF based Transport" [Starting]
org.eclipse.equinox.p2.ui (2.3.0.v20140404-1657) "Equinox Provisioning UI Support" [Active]
org.eclipse.equinox.p2.ui.importexport (1.1.0.v20131210-1027) "Equinox Provisioning Import and Export" [Starting]
org.eclipse.equinox.p2.ui.sdk (1.0.300.v20140407-1803) "Equinox Provisioning Platform Update Support" [Active]
org.eclipse.equinox.p2.ui.sdk.scheduler (1.2.0.v20140422-1847) "Equinox Provisioning Platform Automatic Update Support" [Active]
org.eclipse.equinox.p2.updatechecker (1.1.200.v20131119-0908) "Equinox Provisioning Update Checker" [Active]
org.eclipse.equinox.p2.updatesite (1.0.400.v20131211-1531) "Equinox Provisioning Legacy Update Site Support" [Starting]
org.eclipse.equinox.preferences (3.5.200.v20140224-1527) "Eclipse Preferences Mechanism" [Active]
org.eclipse.equinox.registry (3.5.400.v20140428-1507) "Extension Registry Support" [Active]
org.eclipse.equinox.security (1.2.0.v20130424-1801) "Equinox Java Authentication and Authorization Service (JAAS)" [Active]
org.eclipse.equinox.security.ui (1.1.200.v20130626-2037) "Equinox Security Default UI" [Starting]
org.eclipse.equinox.security.win32.x86 (1.0.300.v20130327-1442) "Windows Data Protection services integration" [Resolved]
org.eclipse.equinox.simpleconfigurator (1.1.0.v20131217-1203) "Simple Configurator" [Active]
org.eclipse.equinox.simpleconfigurator.manipulator (2.0.0.v20131217-1203) "Simple Configurator Manipulator" [Starting]
org.eclipse.equinox.util (1.0.500.v20130404-1337) "Equinox Util Bundle" [Active]
org.eclipse.gef (3.9.100.201408150207) "Graphical Editing Framework GEF" [Starting]
org.eclipse.help (3.6.0.v20130326-1254) "Help System Core" [Active]
org.eclipse.help.base (4.0.200.v20140925-0400) "Help System Base" [Starting]
org.eclipse.help.ui (4.0.100.v20140401-0608) "Help System UI" [Starting]
org.eclipse.help.webapp (3.6.300.v20140407-1855) "Help System Webapp" [Starting]
org.eclipse.jetty.continuation (8.1.14.v20131031) "Jetty :: Continuation" [Resolved]
org.eclipse.jetty.http (8.1.14.v20131031) "Jetty :: Http Utility" [Resolved]
org.eclipse.jetty.io (8.1.14.v20131031) "Jetty :: IO Utility" [Resolved]
org.eclipse.jetty.security (8.1.14.v20131031) "Jetty :: Security" [Resolved]
org.eclipse.jetty.server (8.1.14.v20131031) "Jetty :: Server Core" [Resolved]
org.eclipse.jetty.servlet (8.1.14.v20131031) "Jetty :: Servlet Handling" [Resolved]
org.eclipse.jetty.util (8.1.14.v20131031) "Jetty :: Utilities" [Resolved]
org.eclipse.jface (3.10.1.v20140813-1009) "JFace" [Active]
org.eclipse.jface.databinding (1.6.200.v20140528-1422) "JFace Data Binding for SWT and JFace" [Resolved]
org.eclipse.jface.text (3.9.1.v20140827-1810) "JFace Text" [Resolved]
org.eclipse.jsch.core (1.1.500.v20131112-1442) "JSch Core" [Starting]
org.eclipse.jsch.ui (1.1.500.v20131112-1442) "JSch UI" [Starting]
org.eclipse.ltk.core.refactoring (3.6.101.v20140817-1500) "Refactoring Core" [Active]
org.eclipse.ltk.ui.refactoring (3.7.100.v20140324-1358) "Refactoring UI" [Active]
org.eclipse.osgi (3.10.1.v20140909-1633) "OSGi System Bundle" [Active]
org.eclipse.osgi.compatibility.state (1.0.1.v20140709-1414) "Equinox State and Resolver Compatibility Fragment" [Resolved]
org.eclipse.osgi.services (3.4.0.v20140312-2051) "OSGi Release 4.2.0 Services" [Resolved]
org.eclipse.osgi.util (3.3.0.v20131023-1243) "OSGi Release 4.2.0 Utility Classes" [Resolved]
org.eclipse.platform (4.4.0.v20140925-0400) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.user (4.4.1.v20140829-1306) "Eclipse Workbench User Guide" [Resolved]
org.eclipse.rcp (4.3.100.v20140925-0400) "Eclipse RCP" [Starting]
org.eclipse.search (3.9.100.v20140226-1637) "Search Support" [Active]
org.eclipse.swt (3.103.1.v20140903-1938) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.103.1.v20140903-1947) "Standard Widget Toolkit for Windows" [Resolved]
org.eclipse.team.core (3.7.0.v20130514-1224) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.3.600.v20131112-1442) "CVS Team Provider Core" [Starting]
org.eclipse.team.cvs.ssh2 (3.2.400.v20131112-1442) "CVS SSH2" [Starting]
org.eclipse.team.cvs.ui (3.3.600.v20130514-1224) "CVS Team Provider UI" [Starting]
org.eclipse.team.ui (3.7.100.v20130710-1213) "Team Support UI" [Starting]
org.eclipse.text (3.5.300.v20130515-1451) "Text" [Resolved]
org.eclipse.ui (3.106.0.v20140812-1751) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.4.200.v20131003-1453) "Browser Support" [Active]
org.eclipse.ui.cheatsheets (3.4.200.v20131227-1524) "Cheat Sheets" [Starting]
org.eclipse.ui.console (3.5.300.v20140424-1437) "Console" [Active]
org.eclipse.ui.editors (3.8.200.v20140401-1310) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.2.300.v20140327-1949) "External Tools" [Active]
org.eclipse.ui.forms (3.6.100.v20140422-1825) "Eclipse Forms" [Active]
org.eclipse.ui.ide (3.10.1.v20140828-0944) "Eclipse IDE UI" [Active]
org.eclipse.ui.ide.application (1.0.500.v20140514-2033) "Eclipse IDE UI Application" [Resolved]
org.eclipse.ui.intro (3.4.200.v20130326-1254) "Welcome Framework" [Starting]
org.eclipse.ui.intro.universal (3.2.700.v20130904-1701) "Universal Welcome" [Starting]
org.eclipse.ui.navigator (3.5.401.v20140724-1117) "Common Navigator View" [Active]
org.eclipse.ui.navigator.resources (3.4.700.v20140407-1004) "Navigator Workbench Components" [Active]
org.eclipse.ui.net (1.2.200.v20120807-0927) "Internet Connection Management UI" [Active]
org.eclipse.ui.themes (1.0.1.v20140819-1717) "Eclipse SDK Themes" [Active]
org.eclipse.ui.views (3.7.0.v20140408-0703) "Views" [Active]
org.eclipse.ui.views.properties.tabbed (3.6.0.v20140519-0906) "Tabbed Properties View" [Starting]
org.eclipse.ui.win32 (3.2.400.v20140423-2207) "Eclipse UI Win32 Enhancements" [Resolved]
org.eclipse.ui.workbench (3.106.1.v20140827-1737) "Eclipse Workbench" [Active]
org.eclipse.ui.workbench.texteditor (3.9.0.v20140411-1521) "Text Editor Framework" [Active]
org.eclipse.update.configurator (3.3.300.v20140518-1928) "Install/Update Configurator" [Active]
org.sat4j.core (2.3.5.v201308161310) "SAT4J Core" [Resolved]
org.sat4j.pb (2.3.5.v201404071733) "SAT4J Pseudo" [Resolved]
org.w3c.css.sac (1.3.1.v200903091627) "W3C CSS SAC" [Resolved]
org.w3c.dom.events (3.0.0.draft20060413_v201105210656) "W3C DOM Level 3 Events" [Resolved]
org.w3c.dom.smil (1.0.0.v200806040011) "W3C SMIL DOM" [Resolved]
org.w3c.dom.svg (1.1.0.v201011041433) "W3C SVG DOM" [Resolved]
*** User Preferences:
#Fri Mar 13 14:35:49 EET 2015
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.keep_imple_if_on_one_line=false
/bundle_defaults/org.eclipse.debug.ui/org.eclpise.debug.ui.memory.dynamicLoad=true
/bundle_defaults/org.eclipse.core.resources/refresh.enabled=false
/bundle_defaults/org.eclipse.ui.editors/revisionRulerShowRevision=false
/bundle_defaults/org.eclipse.ui.editors/showEnclosedIdeographicSpaces=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.wait_for_build=always
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_empty_lines=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enum.enabled=false
/bundle_defaults/org.eclipse.cdt.ui/c_numbers=0,0,0
/bundle_defaults/org.eclipse.core.net/proxyData/SOCKS/port=-1
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_i2c.com.crt.advproject.projecttype.exe.1156213048/com.crt.advproject.config.exe.debug.1628265668=com.crt.advproject.gas.exe.debug.233328306\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.712719831\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.395675803\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1148277983\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1628265668\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1824689233\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.771600061\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.debug.core/org.eclipse.cdt.debug.corecDebug.default_variable_format=0
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.CappingDisable=false
/bundle_defaults/org.eclipse.cdt.ui/content_assist_default_argument_display_arguments=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_before_else_in_if_statement=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.lineSplit=80
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.build_before_launch=true
/bundle_defaults/com.crt.debugcommon/showJtagConfig=false
/bundle_defaults/org.eclipse.cdt.core/indexer/indexAllFiles=true
/bundle_defaults/org.eclipse.ui.editors/lineNumberRuler=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_can.com.crt.advproject.projecttype.exe.1549120935/com.crt.advproject.config.exe.debug.1793298790=com.crt.advproject.link.exe.debug.1086263632\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.301086546\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.1802943088\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.2001482070\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1607471089\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1793298790\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1898004798\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/com.crt.dsfdebug/restartDisabled=false
/bundle_defaults/com.crt.debugcommon/overrideSemihosting=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.overloadedOperator.enabled=false
/bundle_defaults/com.crt.debugcommon/stuboutput=server
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.detail_pane_word_wrap=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_closing_brace_in_block=insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.method.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enumerator.color=0,0,192
/bundle_defaults/org.eclipse.cdt.ui/content_assist_autoinsert=true
/bundle_defaults/org.eclipse.debug.ui/Console.wrap=false
/bundle_defaults/org.eclipse.ui.editors/changeIndicationInOverviewRuler=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/lpc_board_nxp_lpcxpresso_1769.com.crt.advproject.projecttype.lib.1078462419/com.crt.advproject.config.lib.release.207171896=com.crt.advproject.config.lib.release.207171896\=rcState\\\=-1\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.release.47261584\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.ar.lib.release.2088203039\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.release.129627712\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.release.845687461\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.release.24618102\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.overrideIndicatorColor=180,207,205
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_conditional_expression=34
/bundle_defaults/org.eclipse.cdt.ui/scalability.semanticHighlight=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_i2c.com.crt.advproject.projecttype.exe.1156213048/com.crt.advproject.config.exe.release.447110820=com.crt.advproject.gcc.exe.release.228429012\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.794665935\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.2065030373\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.107787932\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.303648522\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1909782007\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.error.color=255,0,0
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_default_inactive=false
@org.eclipse.cdt.ui=5.8.1.201409172108
/bundle_defaults/org.eclipse.cdt.ui/org.eclipse.cdt.internal.ui.text.doctools.doxygen.recognizedTag=127,159,191
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enabled=true
/bundle_defaults/com.crt.debugcommon/cmsisdap_multi_swd=false
/bundle_defaults/org.eclipse.ui.ide/MARKER_LIMITS_VALUE=100
/bundle_defaults/org.eclipse.ui.editors/spellingEngine=
/bundle_defaults/org.eclipse.ui.ide/IMPORT_FILES_AND_FOLDERS_TYPE=
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_method_declaration_parameters=do not insert
/bundle_defaults/org.eclipse.ui.ide/CLOSE_UNRELATED_PROJECTS=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enumerator.strikethrough=false
/bundle_defaults/org.eclipse.ui.editors/showErrorInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_method_invocation_arguments=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_bracket=do not insert
/instance/org.eclipse.cdt.ui/useAnnotationsPrefPage=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.namespace.italic=false
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleWrapLines=false
/bundle_defaults/org.eclipse.ui.editors/showTaskInNextPrevDropdownToolbarAction=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSISv2p00_LPC17xx.com.crt.advproject.projecttype.lib.1193160240/com.crt.advproject.config.lib.debug.1814355025=com.crt.advproject.toolchain.lib.debug.1548108302\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.1814355025\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.1004026908\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.1199056603\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.2004041978\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.1604093373\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_enabled=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS-CORE_LPC407x_8x.com.crt.advproject.projecttype.lib.1117785161/com.crt.advproject.config.lib.debug.1588975745=com.crt.advproject.toolchain.lib.debug.328928775\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.1588975745\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.775312103\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.221963309\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.1338608115\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.1509436562\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.class.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enum.bold=false
/bundle_defaults/org.eclipse.cdt.ui/spelling_ignore_sentence=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_closing_angle_bracket_in_template_arguments=insert
/bundle_defaults/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_DIALOG=true
/bundle_defaults/org.eclipse.cdt.core/indexer/useHeuristicIncludeResolution=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroDefinition.strikethrough=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_closing_paren_in_cast=insert
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_CORE_LPC8xx.com.crt.advproject.projecttype.lib.1939000741/com.crt.advproject.config.lib.debug.971437645=com.crt.advproject.cpp.lib.debug.919233593\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.971437645\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.659785245\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.65527192\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.397544059\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.597267139\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk.scheduler/schedule=on-startup
/bundle_defaults/org.eclipse.ui.editors/warningIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.warning.overview=true
/bundle_defaults/org.eclipse.ui/LINK_NAVIGATOR_TO_EDITOR=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_CORE_LPC11Uxx.com.crt.advproject.projecttype.lib.1741498279/com.crt.advproject.config.lib.debug.1849963468=com.crt.advproject.ar.lib.debug.2069571765\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.546768532\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.1398100781\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.255055000\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.1207749252\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.1849963468\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.defaultAsciiCodePage=CP1252
/bundle_defaults/com.crt.utils/wizardHome=
/bundle_defaults/org.eclipse.cdt.ui/content_assist_current_file_search_scope=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.overrideIndicatorInVerticalRuler=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.class.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/org.eclipse.cdt.ui.editor.showSegments=false
/bundle_defaults/org.eclipse.ui.workbench/REUSE_DIRTY_EDITORS=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/lwip_tcpecho_freertos.com.crt.advproject.projecttype.exe.1420589482/com.crt.advproject.config.exe.debug.590435786=com.crt.advproject.link.cpp.exe.debug.1900712405\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1420949215\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1982606965\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1047653261\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.590435786\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.800053964\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1759785151\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.workbench/perspectiveBarVisible=true
/bundle_defaults/org.eclipse.cdt.ui/spelling_ignore_upper=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_LPC18xx_DriverLib.com.crt.advproject.projecttype.lib.2008270429/com.crt.advproject.config.lib.debug.558990107=com.crt.advproject.ar.lib.debug.2089549182\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.315045615\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.410362843\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.1064384326\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.641404760\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.558990107\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/secondaryIPTextStyle=NONE
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariable.italic=false
/bundle_defaults/org.eclipse.ui.workbench/OPEN_PERSPECTIVE_MODE=0
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.test.prefix=
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_timer.com.crt.advproject.projecttype.exe.1309499312/com.crt.advproject.config.exe.release.2130611758=com.crt.advproject.toolchain.exe.release.371298027\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.788026692\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1944172024\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.215350013\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1560242080\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.557206652\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.debug.ui/Console.width=80
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.systemWithoutExtension=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style angle_brackets\="true" blank_line_before\="false" keep_together\="true" order\="2" relative_path\="false"/>
/bundle_defaults/org.eclipse.ui.editors/printMarginColor=176,180,185
/bundle_defaults/org.eclipse.ui.editors/linked.focus.color=50,70,120
/bundle_defaults/org.eclipse.cdt.ui/forwardDeclare.namespaceElements=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/lpc_chip_175x_6x.com.crt.advproject.projecttype.lib.1977998334/com.crt.advproject.config.lib.release.748848757=com.crt.advproject.gas.lib.release.1568034180\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.release.1757629049\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.release.748848757\=rcState\\\=-1\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.release.1488485948\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.lib.release.474949157\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.release.199714480\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/com.crt.dsfdebug/debuggerPathFix=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_base_types=do not insert
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.field.prefix=
/bundle_defaults/org.eclipse.cdt.ui/autoIndent=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/usbd_lib_hid_mouse.com.crt.advproject.projecttype.exe.1164772426/com.crt.advproject.config.exe.release.682907672=com.crt.advproject.link.cpp.exe.release.1811715833\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.918384092\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1175370789\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.1615735383\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.775007655\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1088698866\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/c_string_italic=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_declaration_compare_to_template_header=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_uart_rb.com.crt.advproject.projecttype.exe.1950633819/com.crt.advproject.config.exe.debug.1365584524=com.crt.advproject.toolchain.exe.debug.1113849227\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.1843758335\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1334949695\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.38449263\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.386306012\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.47576862\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1365584524\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/filteredSearchResultIndicationColor=237,237,252
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.error.ruler=true
/bundle_defaults/org.eclipse.debug.ui/Breakpoints.detail.orientation=Variables.detail.orientation.underneath
/bundle_defaults/org.eclipse.ui.editors/currentIPColor=198,219,174
@org.eclipse.core.net=1.2.200.v20140124-2013
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.warning.textstyle=SQUIGGLES
/bundle_defaults/org.eclipse.cdt.ui/scalability.enableAll=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.consoleBackground=255,255,255
/bundle_defaults/org.eclipse.cdt.ui/c_numbers_bold=false
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.UseSingleLine=true
/bundle_defaults/org.eclipse.ui.workbench/DISABLE_DIALOG_FONT=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_block=end_of_line
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.test.capitalization=0
/bundle_defaults/org.eclipse.ui.editors/linked.slave.overviewruler=false
/bundle_defaults/org.eclipse.cdt.dsf.gdb/defaultStopAtMain=true
/bundle_defaults/org.eclipse.ui.editors/indexResultIndicationInVerticalRuler=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/freertos_blinky.com.crt.advproject.projecttype.exe.1693076455/com.crt.advproject.config.exe.debug.897255787=com.crt.advproject.link.exe.debug.1302659769\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1225049255\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.24640360\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.272389732\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.897255787\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.51313821\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.475703418\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_angle_bracket_in_template_arguments=do not insert
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.occurrenceIndicationInOverviewRuler=true
/bundle_defaults/com.crt.debugcommon/debuggerInit=
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.function.bold=true
@org.eclipse.cdt.dsf.ui=2.4.100.201409172108
/bundle_defaults/org.eclipse.ui.editors/taskIndicationHighlighting=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.field.capitalization=4
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_binary_operator=insert
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.source.suffix=.cpp
/bundle_defaults/org.eclipse.cdt.ui/asm_label_italic=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.ExpressionView+org.eclipse.debug.ui.ShowDetailPaneAction=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/usbd_lib_hid_keyboard.com.crt.advproject.projecttype.exe.944853395/com.crt.advproject.config.exe.debug.234199146=com.crt.advproject.config.exe.debug.234199146\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1056025160\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1144847496\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1535204238\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.47077161\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.1096740313\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1947046434\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/isChangeGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/secondaryIPHighlight=true
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.variable.prefix=
/bundle_defaults/org.eclipse.ui.editors/linked.slave.navigation.dropdown=false
/bundle_defaults/org.eclipse.ui.editors/showLeadingIdeographicSpaces=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.continuation_indentation_for_array_initializer=2
/bundle_defaults/org.eclipse.cdt.debug.core/org.eclipse.cdt.debug.corecDebug.default_expression_format=0
/instance/org.eclipse.cdt.dsf.ui/useAnnotationsPrefPage=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.functionDeclaration.enabled=true
/bundle_defaults/org.eclipse.cdt.ui/content_assist_prefix_completion=true
/bundle_defaults/com.crt.debugcommon/redlink_server_shutdown=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_semicolon_in_for=insert
/bundle_defaults/org.eclipse.cdt.core/build.all.configs.enabled=false
/bundle_defaults/org.eclipse.cdt.core/indexer/skipImplicitReferences=false
/bundle_defaults/com.crt.debugcommon/debuggerTimeout=10
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.maxIndexDBCacheSizeMB=64
/bundle_defaults/org.eclipse.ui/presentationFactoryId=org.eclipse.ui.presentations.default
/bundle_defaults/org.eclipse.ui.editors/Accessibility.UseSaturatedColors=false
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Accessibility.UseCustomCarets=true
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.RemovedLinesRegex=
/bundle_defaults/org.eclipse.cdt.core/includes.endExportsPattern=IWYU\\s+(pragma\:?\\s+)?end_exports?
/bundle_defaults/org.eclipse.cdt.dsf.gdb/org.eclipse.cdt.dsf.gdb.useRtti=true
/bundle_defaults/org.eclipse.ui.editors/spellingEnabled=true
/bundle_defaults/org.eclipse.cdt.dsf.gdb/defaultNonStop=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.typedef.enabled=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_for=do not insert
/bundle_defaults/org.eclipse.debug.ui/Console.lowWaterMark=80000
/bundle_defaults/org.eclipse.ui.editors/showLeadingSpaces=true
/bundle_defaults/org.eclipse.ui.editors/linked.target.color=170,185,220
/bundle_defaults/org.eclipse.ui.ide/BOOKMARKS_LIMIT=100
/bundle_defaults/org.eclipse.ui.editors/isIndexResultGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.dsf.gdb/org.eclipse.cdt.dsf.gdb.aggressiveBpFilter=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.externalSDK.enabled=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.warning.GoToPreviousNavigationTarget=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_assignment_operator=insert
/instance/org.eclipse.cdt.managedbuilder.core/properties/lpcusblib_KeyboardHost.com.crt.advproject.projecttype.exe.1776494588/com.crt.advproject.config.exe.debug.332576409=com.crt.advproject.cpp.exe.debug.1763337745\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1794156581\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.547450235\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.39850578\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.578710282\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.153195668\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.332576409\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.changedDebugElement=255,0,0
@org.eclipse.debug.core=3.9.1.v20140805-1629
/bundle_defaults/org.eclipse.ui.editors/showInfoInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.cdt.ui/pp_default_italic=false
/bundle_defaults/org.eclipse.ui.editors/spellingIndication=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.problem.color=224,0,0
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_unary_operator=do not insert
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.PathFilter=
/bundle_defaults/org.eclipse.ui.editors/isFilteredSearchResultGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.methodDeclaration.strikethrough=false
/bundle_defaults/org.eclipse.ui.editors/bookmarkIndicationColor=34,164,99
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_while=insert
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.other=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style blank_line_before\="true" keep_together\="true" order\="3"/>
/bundle_defaults/com.crt.debugcommon/LPC-Link\ (WinUSB)\ or\ RDB-Link=true
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_default_structures=false
/bundle_defaults/org.eclipse.cdt.ui/c_multi_line_comment_italic=false
/bundle_defaults/org.eclipse.ui.editors/hyperlinkKeyModifierMask=262144
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.overloadedOperator.underline=false
/bundle_defaults/org.eclipse.ui.editors/isDeletionGoToNextNavigationTarget=false
/instance/org.eclipse.ui.ide/platformState=1426237440991
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.max_history_size=10
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_colon_in_labeled_statement=do not insert
/bundle_defaults/com.crt.debugcommon/redlink_boot_state=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_statements_compare_to_block=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.activate_debug_view=true
@org.eclipse.ui.browser=3.4.200.v20131003-1453
/bundle_defaults/org.eclipse.ui/DOCK_PERSPECTIVE_BAR=topLeft
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_blinky.com.crt.advproject.projecttype.exe.424940172/com.crt.advproject.config.exe.release.835156494=com.crt.advproject.gcc.exe.release.1591236150\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.release.1645349510\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.298607713\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.543793768\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.318297782\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1446495013\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.release.835156494\=rcState\\\=-1\\r\\nrebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_parenthesized_expression=do not insert
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.error.text=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_catch=insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.label.enabled=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_ritimer.com.crt.advproject.projecttype.exe.749237195/com.crt.advproject.config.exe.release.1763634750=com.crt.advproject.gas.exe.release.936462419\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.189745666\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1063923478\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1679678845\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.1550794809\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1411309420\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.workbench/REUSE_OPEN_EDITORS=8
/bundle_defaults/org.eclipse.cdt.ui/markOverloadedOperatorsOccurrences=false
/bundle_defaults/org.eclipse.ui.editors/linked.slave.highlight=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.join_wrapped_lines=true
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.source.capitalization=0
/instance/org.eclipse.cdt.managedbuilder.core/properties/iperf_server.com.crt.advproject.projecttype.exe.1230739403/com.crt.advproject.config.exe.debug.1512339721=com.crt.advproject.toolchain.exe.debug.380405632\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.387641087\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.463030857\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.51870270\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.472993163\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.762089801\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1512339721\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/forwardDeclare.externalVariables=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_exception_specification=do not insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroSubstitution.strikethrough=false
/bundle_defaults/org.eclipse.debug.core/org.eclipse.debug.core.PREF_BREAKPOINT_MANAGER_ENABLED_STATE=true
/bundle_defaults/org.eclipse.ui.editors/overviewRuler=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.namespace.enabled=false
/bundle_defaults/org.eclipse.ui.editors/additionIndicationColor=188,188,222
/bundle_defaults/org.eclipse.cdt.ui/c_string=42,0,255
/bundle_defaults/org.eclipse.debug.ui/Registers.detail.orientation=Variables.detail.orientation.underneath
/bundle_defaults/org.eclipse.cdt.ui/organizeIncludes.allowPartnerIndirectInclusion=true
/bundle_defaults/org.eclipse.ui.editors/com.crt.etmetb.marker.profile.pref.high=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.isOccurrenceGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.templateParameter.bold=true
/bundle_defaults/org.eclipse.cdt.debug.core/org.eclipse.cdt.debug.corecDebug.default_register_format=0
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroSubstitution.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.function.strikethrough=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.writeOccurrenceIndicationColor=240,216,168
/bundle_defaults/org.eclipse.ui.ide/EXIT_PROMPT_ON_CLOSE_LAST_WINDOW=true
/bundle_defaults/org.eclipse.ui.editors/printMargin=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_ssp.com.crt.advproject.projecttype.exe.2073917783/com.crt.advproject.config.exe.debug.132243330=com.crt.advproject.config.exe.debug.132243330\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1276505785\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1415199486\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.670756160\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.2080663046\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1855615787\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.425397908\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.constant.wordDelimiter=_
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_template_arguments=insert
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.errorColor=255,0,0
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.taskTags=TODO,FIXME,XXX
/bundle_defaults/org.eclipse.ui.editors/isSpellingGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.ui/spelling_problems_threshold=100
/bundle_defaults/org.eclipse.cdt.ui/content_assist_default_argument_display_parameters_with_default_argument=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariable.color=0,0,0
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.codeReaderCache=64
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariableDeclaration.italic=false
/bundle_defaults/org.eclipse.ui.editors/revisionAnnotationIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.partner=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style angle_brackets\="false" blank_line_before\="true" keep_together\="true" order\="0" relative_path\="false"/>
/bundle_defaults/org.eclipse.cdt.ui/subWordNavigation=true
/bundle_defaults/org.eclipse.debug.ui/DEBUG.consoleOpenOnOut=true
/bundle_defaults/org.eclipse.cdt.ui/asm_directive=127,0,85
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.error.NextPrevDropdownToolbar=true
/bundle_defaults/org.eclipse.cdt.ui/org.eclipse.cdt.ui.editor.linkToEditor=false
/bundle_defaults/org.eclipse.ui.editors/linked.slave.navigation.next=false
/bundle_defaults/org.eclipse.ui.editors/isErrorGoToPreviousNavigationTarget=true
/configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_DIALOG=true
/bundle_defaults/org.eclipse.ui.editors/linked.focus.navigation.previous=false
/bundle_defaults/org.eclipse.cdt.ui/content_assist_parameters_background=255,255,255
/instance/org.eclipse.debug.core//org.eclipse.debug.core.PREFERRED_DELEGATES/org.eclipse.cdt.launch.applicationLaunchType=org.eclipse.cdt.dsf.gdb.launch.localCLaunch,debug,;org.eclipse.cdt.cdi.launch.localCLaunch,run,;
/bundle_defaults/org.eclipse.cdt.ui/asm_directive_italic=false
/bundle_defaults/org.eclipse.core.net/nonProxiedHosts=localhost|127.0.0.1
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_before_while_in_do_statement=do not insert
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.external=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style angle_brackets\="false" blank_line_before\="false" keep_together\="false" relative_path\="false"/>
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.reuse_editor=true
/bundle_defaults/org.eclipse.ui.ide/IMPORT_FILES_AND_FOLDERS_MODE=prompt
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.codeBytesColor=96,0,0
/bundle_defaults/org.eclipse.cdt.core/indexer/indexAllHeaderVersions=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.functionDeclaration.strikethrough=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_CORE_LPC13Uxx.com.crt.advproject.projecttype.lib.273512484/com.crt.advproject.config.lib.debug.673940478=com.crt.advproject.gas.lib.debug.198052387\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.847974778\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.2129923167\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.673940478\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.2123539662\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.1540782685\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.class.italic=false
/bundle_defaults/org.eclipse.ui.editors/breakpointIndicationInOverviewRuler=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_access_specifier_extra_spaces=0
/bundle_defaults/org.eclipse.ui.editors/showSearchResultInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.templateParameter.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/includes.partnerFileSuffixes=test,unittest
/bundle_defaults/org.eclipse.ui/SHOW_OPEN_ON_PERSPECTIVE_BAR=true
/bundle_defaults/org.eclipse.cdt.ui/pp_default_bold=false
/bundle_defaults/org.eclipse.ui.editors/spellingIndicationHighlighting=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.overrideIndicatorInOverviewRuler=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.namespace.underline=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.outColor=0,0,0
/bundle_defaults/org.eclipse.core.resources/description.applyfilestatepolicy=true
/bundle_defaults/org.eclipse.ui.editors/taskTextStyle=SQUIGGLES
/bundle_defaults/com.crt.debugcommon/redlink_kill_exit=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_bracket=do not insert
/bundle_defaults/org.eclipse.ui.ide/SYSTEM_EXPLORER=explorer /E,/select\=${selected_resource_loc}
/bundle_defaults/com.crt.debugcommon/displayAsyncErrors=true
/bundle_defaults/org.eclipse.ui.editors/infoIndicationColor=244,200,45
/bundle_defaults/com.crt.utils/quickstart.navstate=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroDefinition.enabled=false
/bundle_defaults/org.eclipse.ui.editors/filteredSearchResultTextStyle=SQUIGGLES
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.comment.never_indent_line_comments_on_first_column=true
/bundle_defaults/org.eclipse.ui.editors/quickdiff.nowarn.before.switch=
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_array_initializer=end_of_line
/bundle_defaults/org.eclipse.ui.editors/hoverReplaceMode=0
/bundle_defaults/org.eclipse.cdt.core/indexer/skipReferences=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.skip_breakpoints_during_run_to_line=false
/bundle_defaults/org.eclipse.cdt.dsf.ui/stackFrameLimit=10
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.keep_empty_array_initializer_on_one_line=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_before_identifier_in_function_declaration=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_colon_in_conditional=insert
/instance/org.eclipse.core.net/org.eclipse.core.net.hasMigrated=true
/bundle_defaults/org.eclipse.cdt.ui/content_assist_parameters_foreground=0,0,0
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.problem.italic=false
/bundle_defaults/org.eclipse.ui.editors/linked.exit.verticalruler=false
/bundle_defaults/com.crt.debugcommon/genericImageXP=LPCXpressoWIN.enc
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.tabulation.size=4
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticField.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.externalSDK.bold=true
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.endAddress=0x10000000000000000
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.typedef.color=0,80,50
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_between_empty_parens_in_method_declaration=do not insert
/bundle_defaults/com.crt.debugcommon/redlink_experimental=false
/bundle_defaults/org.eclipse.ui.editors/linked.target.navigation.dropdown=false
/bundle_defaults/org.eclipse.ui.editors/isIndexResultGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/showWhitespaceCharacters=false
/bundle_defaults/com.crt.utils/directories.bin=C\:\\nxp\\LPCXpresso_7.6.2_326\\lpcxpresso\\bin;C\:\\nxp\\LPCXpresso_7.6.2_326\\lpcxpresso\\msys\\bin;C\:\\nxp\\LPCXpresso_7.6.2_326\\lpcxpresso\\tools\\bin;
/bundle_defaults/com.crt.debugcommon/CMSIS-DAP=true
/bundle_defaults/org.eclipse.cdt.ui/org.eclipse.cdt.ui.editor.CUChildren=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_between_empty_braces_in_array_initializer=do not insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.functionDeclaration.color=0,0,0
/bundle_defaults/org.eclipse.ui.editors/indexResultIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.cdt.ui/smartPaste=true
/bundle_defaults/org.eclipse.ui/ENABLE_DETACHED_VIEWS=true
/bundle_defaults/org.eclipse.ui.editors/bookmarkIndicationInVerticalRuler=true
/bundle_defaults/org.eclipse.debug.ui/org.eclispe.debug.ui.memory.preBufferSize=20
/bundle_defaults/com.crt.advproject/multicoreslavetemplate=arm-none-eabi-objcopy --target elf32-littlearm --verbose --strip-all --redefine-sym %3$s\=%3$s%4$s --keep-symbol %3$s%4$s %2$s"%1$s" "%1$s.o"
/bundle_defaults/org.eclipse.ui.editors/taskIndicationInVerticalRuler=true
/bundle_defaults/org.eclipse.debug.ui/Modules.detail.orientation=Variables.detail.orientation.underneath
/bundle_defaults/org.eclipse.ui.workbench/TEXT_DIRECTION=
/bundle_defaults/org.eclipse.cdt.ui/content_assist_proposals_background=255,255,255
/bundle_defaults/org.eclipse.cdt.ui/organizeIncludes.headerSubstitution=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<maps>\r\n<map cpp_only\="false" name\="GCC C Header Substitution">\r\n<unconditional_substitution_map>\r\n<mapping key\="&lt;asm/errno.h&gt;" value\="&lt;errno.h&gt;"/>\r\n<mapping key\="&lt;asm/errno-base.h&gt;" value\="&lt;errno.h&gt;"/>\r\n<mapping key\="&lt;asm/ioctls.h&gt;" value\="&lt;sys/ioctl.h&gt;"/>\r\n<mapping key\="&lt;asm/posix_types_32.h&gt;" value\="&lt;asm/posix_types.h&gt;"/>\r\n<mapping key\="&lt;asm/posix_types_64.h&gt;" value\="&lt;asm/posix_types.h&gt;"/>\r\n<mapping key\="&lt;asm/ptrace-abi.h&gt;" value\="&lt;asm/ptrace.h&gt;"/>\r\n<mapping key\="&lt;asm/socket.h&gt;" value\="&lt;sys/socket.h&gt;"/>\r\n<mapping key\="&lt;asm/unistd.h&gt;" value\="&lt;syscall.h&gt;"/>\r\n<mapping key\="&lt;asm/unistd_32.h&gt;" value\="&lt;syscall.h&gt;"/>\r\n<mapping key\="&lt;asm/unistd_64.h&gt;" value\="&lt;syscall.h&gt;"/>\r\n<mapping key\="&lt;bits/a.out.h&gt;" value\="&lt;a.out.h&gt;"/>\r\n<mapping key\="&lt;bits/byteswap.h&gt;" value\="&lt;byteswap.h&gt;"/>\r\n<mapping key\="&lt;bits/cmathcalls.h&gt;" value\="&lt;complex.h&gt;"/>\r\n<mapping key\="&lt;bits/confname.h&gt;" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="&lt;bits/dirent.h&gt;" value\="&lt;dirent.h&gt;"/>\r\n<mapping key\="&lt;bits/dlfcn.h&gt;" value\="&lt;dlfcn.h&gt;"/>\r\n<mapping key\="&lt;bits/elfclass.h&gt;" value\="&lt;link.h&gt;"/>\r\n<mapping key\="&lt;bits/endian.h&gt;" value\="&lt;endian.h&gt;"/>\r\n<mapping key\="&lt;bits/environments.h&gt;" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="&lt;bits/errno.h&gt;" value\="&lt;errno.h&gt;"/>\r\n<mapping key\="&lt;bits/error.h&gt;" value\="&lt;error.h&gt;"/>\r\n<mapping key\="&lt;bits/fcntl.h&gt;" value\="&lt;fcntl.h&gt;"/>\r\n<mapping key\="&lt;bits/fcntl-linux.h&gt;" value\="&lt;fcntl.h&gt;"/>\r\n<mapping key\="&lt;bits/fcntl2.h&gt;" value\="&lt;fcntl.h&gt;"/>\r\n<mapping key\="&lt;bits/fenv.h&gt;" value\="&lt;fenv.h&gt;"/>\r\n<mapping key\="&lt;bits/fenvinline.h&gt;" value\="&lt;fenv.h&gt;"/>\r\n<mapping key\="&lt;bits/huge_val.h&gt;" value\="&lt;math.h&gt;"/>\r\n<mapping key\="&lt;bits/huge_valf.h&gt;" value\="&lt;math.h&gt;"/>\r\n<mapping key\="&lt;bits/huge_vall.h&gt;" value\="&lt;math.h&gt;"/>\r\n<mapping key\="&lt;bits/in.h&gt;" value\="&lt;netinet/in.h&gt;"/>\r\n<mapping key\="&lt;bits/inf.h&gt;" value\="&lt;math.h&gt;"/>\r\n<mapping key\="&lt;bits/ioctl-types.h&gt;" value\="&lt;sys/ioctl.h&gt;"/>\r\n<mapping key\="&lt;bits/ioctls.h&gt;" value\="&lt;sys/ioctl.h&gt;"/>\r\n<mapping key\="&lt;bits/ipc.h&gt;" value\="&lt;sys/ipc.h&gt;"/>\r\n<mapping key\="&lt;bits/ipctypes.h&gt;" value\="&lt;sys/ipc.h&gt;"/>\r\n<mapping key\="&lt;bits/libio-ldbl.h&gt;" value\="&lt;libio.h&gt;"/>\r\n<mapping key\="&lt;bits/link.h&gt;" value\="&lt;link.h&gt;"/>\r\n<mapping key\="&lt;bits/locale.h&gt;" value\="&lt;locale.h&gt;"/>\r\n<mapping key\="&lt;bits/mathcalls.h&gt;" value\="&lt;math.h&gt;"/>\r\n<mapping key\="&lt;bits/mathdef.h&gt;" value\="&lt;math.h&gt;"/>\r\n<mapping key\="&lt;bits/mathinline.h&gt;" value\="&lt;math.h&gt;"/>\r\n<mapping key\="&lt;bits/mman.h&gt;" value\="&lt;sys/mman.h&gt;"/>\r\n<mapping key\="&lt;bits/monetary-ldbl.h&gt;" value\="&lt;monetary.h&gt;"/>\r\n<mapping key\="&lt;bits/mqueue.h&gt;" value\="&lt;mqueue.h&gt;"/>\r\n<mapping key\="&lt;bits/mqueue2.h&gt;" value\="&lt;mqueue.h&gt;"/>\r\n<mapping key\="&lt;bits/msq.h&gt;" value\="&lt;sys/msg.h&gt;"/>\r\n<mapping key\="&lt;bits/nan.h&gt;" value\="&lt;math.h&gt;"/>\r\n<mapping key\="&lt;bits/netdb.h&gt;" value\="&lt;netdb.h&gt;"/>\r\n<mapping key\="&lt;bits/poll.h&gt;" value\="&lt;poll.h&gt;"/>\r\n<mapping key\="&lt;bits/posix_opt.h&gt;" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="&lt;bits/posix1_lim.h&gt;" value\="&lt;limits.h&gt;"/>\r\n<mapping key\="&lt;bits/posix2_lim.h&gt;" value\="&lt;limits.h&gt;"/>\r\n<mapping key\="&lt;bits/predefs.h&gt;" value\="&lt;features.h&gt;"/>\r\n<mapping key\="&lt;bits/printf-ldbl.h&gt;" value\="&lt;printf.h&gt;"/>\r\n<mapping key\="&lt;bits/pthreadtypes.h&gt;" value\="&lt;pthread.h&gt;"/>\r\n<mapping key\="&lt;bits/resource.h&gt;" value\="&lt;sys/resource.h&gt;"/>\r\n<mapping key\="&lt;bits/sched.h&gt;" value\="&lt;sched.h&gt;"/>\r\n<mapping key\="&lt;bits/select.h&gt;" value\="&lt;sys/select.h&gt;"/>\r\n<mapping key\="&lt;bits/sem.h&gt;" value\="&lt;sys/sem.h&gt;"/>\r\n<mapping key\="&lt;bits/semaphore.h&gt;" value\="&lt;semaphore.h&gt;"/>\r\n<mapping key\="&lt;bits/setjmp.h&gt;" value\="&lt;setjmp.h&gt;"/>\r\n<mapping key\="&lt;bits/shm.h&gt;" value\="&lt;sys/shm.h&gt;"/>\r\n<mapping key\="&lt;bits/sigaction.h&gt;" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="&lt;bits/sigcontext.h&gt;" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="&lt;bits/siginfo.h&gt;" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="&lt;bits/signum.h&gt;" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="&lt;bits/sigset.h&gt;" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="&lt;bits/sigstack.h&gt;" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="&lt;bits/sigthread.h&gt;" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="&lt;bits/sockaddr.h&gt;" value\="&lt;sys/un.h&gt;"/>\r\n<mapping key\="&lt;bits/socket.h&gt;" value\="&lt;sys/socket.h&gt;"/>\r\n<mapping key\="&lt;bits/stab.def&gt;" value\="&lt;stab.h&gt;"/>\r\n<mapping key\="&lt;bits/stat.h&gt;" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="&lt;bits/statfs.h&gt;" value\="&lt;sys/statfs.h&gt;"/>\r\n<mapping key\="&lt;bits/statvfs.h&gt;" value\="&lt;sys/statvfs.h&gt;"/>\r\n<mapping key\="&lt;bits/stdio.h&gt;" value\="&lt;stdio.h&gt;"/>\r\n<mapping key\="&lt;bits/stdio_lim.h&gt;" value\="&lt;stdio.h&gt;"/>\r\n<mapping key\="&lt;bits/stdio-ldbl.h&gt;" value\="&lt;stdio.h&gt;"/>\r\n<mapping key\="&lt;bits/stdio-lock.h&gt;" value\="&lt;libio.h&gt;"/>\r\n<mapping key\="&lt;bits/stdio2.h&gt;" value\="&lt;stdio.h&gt;"/>\r\n<mapping key\="&lt;bits/stdlib.h&gt;" value\="&lt;stdlib.h&gt;"/>\r\n<mapping key\="&lt;bits/stdlib-ldbl.h&gt;" value\="&lt;stdlib.h&gt;"/>\r\n<mapping key\="&lt;bits/string.h&gt;" value\="&lt;string.h&gt;"/>\r\n<mapping key\="&lt;bits/string2.h&gt;" value\="&lt;string.h&gt;"/>\r\n<mapping key\="&lt;bits/string3.h&gt;" value\="&lt;string.h&gt;"/>\r\n<mapping key\="&lt;bits/stropts.h&gt;" value\="&lt;stropts.h&gt;"/>\r\n<mapping key\="&lt;bits/sys_errlist.h&gt;" value\="&lt;stdio.h&gt;"/>\r\n<mapping key\="&lt;bits/syscall.h&gt;" value\="&lt;syscall.h&gt;"/>\r\n<mapping key\="&lt;bits/syslog.h&gt;" value\="&lt;syslog.h&gt;"/>\r\n<mapping key\="&lt;bits/syslog-ldbl.h&gt;" value\="&lt;syslog.h&gt;"/>\r\n<mapping key\="&lt;bits/syslog-path.h&gt;" value\="&lt;syslog.h&gt;"/>\r\n<mapping key\="&lt;bits/termios.h&gt;" value\="&lt;termios.h&gt;"/>\r\n<mapping key\="&lt;bits/time.h&gt;" value\="&lt;sys/time.h&gt;"/>\r\n<mapping key\="&lt;bits/types.h&gt;" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="&lt;bits/uio.h&gt;" value\="&lt;sys/uio.h&gt;"/>\r\n<mapping key\="&lt;bits/unistd.h&gt;" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="&lt;bits/ustat.h&gt;" value\="&lt;ustat.h&gt;"/>\r\n<mapping key\="&lt;bits/utmp.h&gt;" value\="&lt;utmp.h&gt;"/>\r\n<mapping key\="&lt;bits/utmpx.h&gt;" value\="&lt;utmpx.h&gt;"/>\r\n<mapping key\="&lt;bits/utsname.h&gt;" value\="&lt;sys/utsname.h&gt;"/>\r\n<mapping key\="&lt;bits/waitflags.h&gt;" value\="&lt;sys/wait.h&gt;"/>\r\n<mapping key\="&lt;bits/waitstatus.h&gt;" value\="&lt;sys/wait.h&gt;"/>\r\n<mapping key\="&lt;bits/wchar.h&gt;" value\="&lt;wchar.h&gt;"/>\r\n<mapping key\="&lt;bits/wchar-ldbl.h&gt;" value\="&lt;wchar.h&gt;"/>\r\n<mapping key\="&lt;bits/wchar2.h&gt;" value\="&lt;wchar.h&gt;"/>\r\n<mapping key\="&lt;bits/xopen_lim.h&gt;" value\="&lt;limits.h&gt;"/>\r\n<mapping key\="&lt;bits/xtitypes.h&gt;" value\="&lt;stropts.h&gt;"/>\r\n<mapping key\="&lt;linux/errno.h&gt;" value\="&lt;errno.h&gt;"/>\r\n<mapping key\="&lt;linux/limits.h&gt;" value\="&lt;limits.h&gt;"/>\r\n<mapping key\="&lt;linux/socket.h&gt;" value\="&lt;sys/socket.h&gt;"/>\r\n<mapping key\="&lt;sys/poll.h&gt;" value\="&lt;poll.h&gt;"/>\r\n<mapping key\="&lt;sys/syscall.h&gt;" value\="&lt;syscall.h&gt;"/>\r\n<mapping key\="&lt;sys/syslog.h&gt;" value\="&lt;syslog.h&gt;"/>\r\n<mapping key\="&lt;sys/ucontext.h&gt;" value\="&lt;ucontext.h&gt;"/>\r\n<mapping key\="&lt;sys/ustat.h&gt;" value\="&lt;ustat.h&gt;"/>\r\n<mapping key\="&lt;wait.h&gt;" value\="&lt;sys/wait.h&gt;"/>\r\n</unconditional_substitution_map>\r\n<optional_substitution_map/>\r\n</map>\r\n<map cpp_only\="true" name\="GCC C++ Header Substitution">\r\n<unconditional_substitution_map>\r\n<mapping key\="&lt;auto_ptr.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;backward/auto_ptr.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;backward/binders.h&gt;" value\="&lt;functional&gt;"/>\r\n<mapping key\="&lt;backward/hash_fun.h&gt;" value\="&lt;hash_map&gt;"/>\r\n<mapping key\="&lt;backward/hash_fun.h&gt;" value\="&lt;hash_set&gt;"/>\r\n<mapping key\="&lt;backward/hashtable.h&gt;" value\="&lt;hash_map&gt;"/>\r\n<mapping key\="&lt;backward/hashtable.h&gt;" value\="&lt;hash_set&gt;"/>\r\n<mapping key\="&lt;backward/strstream&gt;" value\="&lt;strstream&gt;"/>\r\n<mapping key\="&lt;binders.h&gt;" value\="&lt;functional&gt;"/>\r\n<mapping key\="&lt;bits/algorithmfwd.h&gt;" value\="&lt;algorithm&gt;"/>\r\n<mapping key\="&lt;bits/allocator.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;bits/atomic_word.h&gt;" value\="&lt;ext/atomicity.h&gt;"/>\r\n<mapping key\="&lt;bits/basic_file.h&gt;" value\="&lt;fstream&gt;"/>\r\n<mapping key\="&lt;bits/basic_ios.h&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;bits/basic_string.h&gt;" value\="&lt;string&gt;"/>\r\n<mapping key\="&lt;bits/basic_string.tcc&gt;" value\="&lt;string&gt;"/>\r\n<mapping key\="&lt;bits/boost_concept_check.h&gt;" value\="&lt;bits/concept_check.h&gt;"/>\r\n<mapping key\="&lt;bits/boost_sp_shared_count.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;bits/c++allocator.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;bits/c++config.h&gt;" value\="&lt;cstddef&gt;"/>\r\n<mapping key\="&lt;bits/c++io.h&gt;" value\="&lt;ext/stdio_sync_filebuf.h&gt;"/>\r\n<mapping key\="&lt;bits/char_traits.h&gt;" value\="&lt;string&gt;"/>\r\n<mapping key\="&lt;bits/cmath.tcc&gt;" value\="&lt;cmath&gt;"/>\r\n<mapping key\="&lt;bits/codecvt.h&gt;" value\="&lt;fstream&gt;"/>\r\n<mapping key\="&lt;bits/codecvt.h&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/ctype_base.h&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/ctype_base.h&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;bits/ctype_inline.h&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/ctype_inline.h&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;bits/cxxabi_tweaks.h&gt;" value\="&lt;cxxabi.h&gt;"/>\r\n<mapping key\="&lt;bits/deque.tcc&gt;" value\="&lt;deque&gt;"/>\r\n<mapping key\="&lt;bits/exception_defines.h&gt;" value\="&lt;exception&gt;"/>\r\n<mapping key\="&lt;bits/fstream.tcc&gt;" value\="&lt;fstream&gt;"/>\r\n<mapping key\="&lt;bits/functexcept.h&gt;" value\="&lt;algorithm&gt;"/>\r\n<mapping key\="&lt;bits/functional_hash.h&gt;" value\="&lt;unordered_map&gt;"/>\r\n<mapping key\="&lt;bits/gslice.h&gt;" value\="&lt;valarray&gt;"/>\r\n<mapping key\="&lt;bits/gslice_array.h&gt;" value\="&lt;valarray&gt;"/>\r\n<mapping key\="&lt;bits/hashtable.h&gt;" value\="&lt;unordered_map&gt;"/>\r\n<mapping key\="&lt;bits/hashtable.h&gt;" value\="&lt;unordered_set&gt;"/>\r\n<mapping key\="&lt;bits/indirect_array.h&gt;" value\="&lt;valarray&gt;"/>\r\n<mapping key\="&lt;bits/ios_base.h&gt;" value\="&lt;iostream&gt;"/>\r\n<mapping key\="&lt;bits/ios_base.h&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;bits/ios_base.h&gt;" value\="&lt;iomanip&gt;"/>\r\n<mapping key\="&lt;bits/istream.tcc&gt;" value\="&lt;istream&gt;"/>\r\n<mapping key\="&lt;bits/list.tcc&gt;" value\="&lt;list&gt;"/>\r\n<mapping key\="&lt;bits/locale_classes.h&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/locale_classes.h&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;bits/locale_classes.tcc&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/locale_classes.tcc&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;bits/locale_facets.h&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/locale_facets.h&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;bits/locale_facets.tcc&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/locale_facets.tcc&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;bits/locale_facets_nonio.h&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/locale_facets_nonio.tcc&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/localefwd.h&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/mask_array.h&gt;" value\="&lt;valarray&gt;"/>\r\n<mapping key\="&lt;bits/messages_members.h&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/move.h&gt;" value\="&lt;algorithm&gt;"/>\r\n<mapping key\="&lt;bits/ostream.tcc&gt;" value\="&lt;ostream&gt;"/>\r\n<mapping key\="&lt;bits/ostream_insert.h&gt;" value\="&lt;ostream&gt;"/>\r\n<mapping key\="&lt;bits/postypes.h&gt;" value\="&lt;iostream&gt;"/>\r\n<mapping key\="&lt;bits/postypes.h&gt;" value\="&lt;string&gt;"/>\r\n<mapping key\="&lt;bits/shared_ptr.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;bits/slice_array.h&gt;" value\="&lt;valarray&gt;"/>\r\n<mapping key\="&lt;bits/sstream.tcc&gt;" value\="&lt;sstream&gt;"/>\r\n<mapping key\="&lt;bits/stl_algo.h&gt;" value\="&lt;algorithm&gt;"/>\r\n<mapping key\="&lt;bits/stl_algobase.h&gt;" value\="&lt;algorithm&gt;"/>\r\n<mapping key\="&lt;bits/stl_bvector.h&gt;" value\="&lt;vector&gt;"/>\r\n<mapping key\="&lt;bits/stl_construct.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;bits/stl_deque.h&gt;" value\="&lt;deque&gt;"/>\r\n<mapping key\="&lt;bits/stl_function.h&gt;" value\="&lt;functional&gt;"/>\r\n<mapping key\="&lt;bits/stl_heap.h&gt;" value\="&lt;queue&gt;"/>\r\n<mapping key\="&lt;bits/stl_iterator.h&gt;" value\="&lt;iterator&gt;"/>\r\n<mapping key\="&lt;bits/stl_iterator_base_funcs.h&gt;" value\="&lt;iterator&gt;"/>\r\n<mapping key\="&lt;bits/stl_iterator_base_types.h&gt;" value\="&lt;iterator&gt;"/>\r\n<mapping key\="&lt;bits/stl_list.h&gt;" value\="&lt;list&gt;"/>\r\n<mapping key\="&lt;bits/stl_map.h&gt;" value\="&lt;map&gt;"/>\r\n<mapping key\="&lt;bits/stl_move.h&gt;" value\="&lt;algorithm&gt;"/>\r\n<mapping key\="&lt;bits/stl_multimap.h&gt;" value\="&lt;map&gt;"/>\r\n<mapping key\="&lt;bits/stl_multiset.h&gt;" value\="&lt;set&gt;"/>\r\n<mapping key\="&lt;bits/stl_numeric.h&gt;" value\="&lt;numeric&gt;"/>\r\n<mapping key\="&lt;bits/stl_pair.h&gt;" value\="&lt;utility&gt;"/>\r\n<mapping key\="&lt;bits/stl_pair.h&gt;" value\="&lt;tr1/utility&gt;"/>\r\n<mapping key\="&lt;bits/stl_queue.h&gt;" value\="&lt;queue&gt;"/>\r\n<mapping key\="&lt;bits/stl_raw_storage_iter.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;bits/stl_relops.h&gt;" value\="&lt;utility&gt;"/>\r\n<mapping key\="&lt;bits/stl_set.h&gt;" value\="&lt;set&gt;"/>\r\n<mapping key\="&lt;bits/stl_stack.h&gt;" value\="&lt;stack&gt;"/>\r\n<mapping key\="&lt;bits/stl_tempbuf.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;bits/stl_tree.h&gt;" value\="&lt;map&gt;"/>\r\n<mapping key\="&lt;bits/stl_tree.h&gt;" value\="&lt;set&gt;"/>\r\n<mapping key\="&lt;bits/stl_uninitialized.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;bits/stl_vector.h&gt;" value\="&lt;vector&gt;"/>\r\n<mapping key\="&lt;bits/stream_iterator.h&gt;" value\="&lt;iterator&gt;"/>\r\n<mapping key\="&lt;bits/streambuf.tcc&gt;" value\="&lt;streambuf&gt;"/>\r\n<mapping key\="&lt;bits/streambuf_iterator.h&gt;" value\="&lt;iterator&gt;"/>\r\n<mapping key\="&lt;bits/streambuf_iterator.h&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;bits/stringfwd.h&gt;" value\="&lt;string&gt;"/>\r\n<mapping key\="&lt;bits/unique_ptr.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;bits/valarray_after.h&gt;" value\="&lt;valarray&gt;"/>\r\n<mapping key\="&lt;bits/valarray_array.h&gt;" value\="&lt;valarray&gt;"/>\r\n<mapping key\="&lt;bits/valarray_array.tcc&gt;" value\="&lt;valarray&gt;"/>\r\n<mapping key\="&lt;bits/valarray_before.h&gt;" value\="&lt;valarray&gt;"/>\r\n<mapping key\="&lt;bits/vector.tcc&gt;" value\="&lt;vector&gt;"/>\r\n<mapping key\="&lt;debug/safe_iterator.tcc&gt;" value\="&lt;debug/safe_iterator.h&gt;"/>\r\n<mapping key\="&lt;exception_defines.h&gt;" value\="&lt;exception&gt;"/>\r\n<mapping key\="&lt;ext/algorithm&gt;" value\="&lt;algorithm&gt;"/>\r\n<mapping key\="&lt;ext/functional&gt;" value\="&lt;functional&gt;"/>\r\n<mapping key\="&lt;ext/hash_map&gt;" value\="&lt;hash_map&gt;"/>\r\n<mapping key\="&lt;ext/hash_set&gt;" value\="&lt;hash_set&gt;"/>\r\n<mapping key\="&lt;ext/numeric&gt;" value\="&lt;numeric&gt;"/>\r\n<mapping key\="&lt;ext/slist&gt;" value\="&lt;slist&gt;"/>\r\n<mapping key\="&lt;ext/sso_string_base.h&gt;" value\="&lt;string&gt;"/>\r\n<mapping key\="&lt;ext/vstring.h&gt;" value\="&lt;string&gt;"/>\r\n<mapping key\="&lt;ext/vstring.tcc&gt;" value\="&lt;string&gt;"/>\r\n<mapping key\="&lt;ext/vstring_fwd.h&gt;" value\="&lt;string&gt;"/>\r\n<mapping key\="&lt;hash_fun.h&gt;" value\="&lt;hash_map&gt;"/>\r\n<mapping key\="&lt;hash_fun.h&gt;" value\="&lt;hash_set&gt;"/>\r\n<mapping key\="&lt;hashtable.h&gt;" value\="&lt;hash_map&gt;"/>\r\n<mapping key\="&lt;hashtable.h&gt;" value\="&lt;hash_set&gt;"/>\r\n<mapping key\="&lt;tr1/bessel_function.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/beta_function.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/ell_integral.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/exp_integral.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/gamma.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/hypergeometric.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/legendre_function.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/modified_bessel_func.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/poly_hermite.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/poly_laguerre.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/riemann_zeta.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1_impl/array&gt;" value\="&lt;array&gt;"/>\r\n<mapping key\="&lt;tr1_impl/array&gt;" value\="&lt;tr1/array&gt;"/>\r\n<mapping key\="&lt;tr1_impl/boost_shared_ptr.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;tr1_impl/boost_shared_ptr.h&gt;" value\="&lt;tr1/memory&gt;"/>\r\n<mapping key\="&lt;tr1_impl/boost_sp_counted_base.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;tr1_impl/boost_sp_counted_base.h&gt;" value\="&lt;tr1/memory&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cctype&gt;" value\="&lt;cctype&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cctype&gt;" value\="&lt;tr1/cctype&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cfenv&gt;" value\="&lt;cfenv&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cfenv&gt;" value\="&lt;tr1/cfenv&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cinttypes&gt;" value\="&lt;cinttypes&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cinttypes&gt;" value\="&lt;tr1/cinttypes&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cmath&gt;" value\="&lt;cmath&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cmath&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1_impl/complex&gt;" value\="&lt;complex&gt;"/>\r\n<mapping key\="&lt;tr1_impl/complex&gt;" value\="&lt;tr1/complex&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cstdint&gt;" value\="&lt;cstdint&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cstdint&gt;" value\="&lt;tr1/cstdint&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cstdio&gt;" value\="&lt;cstdio&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cstdio&gt;" value\="&lt;tr1/cstdio&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cstdlib&gt;" value\="&lt;cstdlib&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cstdlib&gt;" value\="&lt;tr1/cstdlib&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cwchar&gt;" value\="&lt;cwchar&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cwchar&gt;" value\="&lt;tr1/cwchar&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cwctype&gt;" value\="&lt;cwctype&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cwctype&gt;" value\="&lt;tr1/cwctype&gt;"/>\r\n<mapping key\="&lt;tr1_impl/functional&gt;" value\="&lt;functional&gt;"/>\r\n<mapping key\="&lt;tr1_impl/functional&gt;" value\="&lt;tr1/functional&gt;"/>\r\n<mapping key\="&lt;tr1_impl/functional_hash.h&gt;" value\="&lt;tr1/functional_hash.h&gt;"/>\r\n<mapping key\="&lt;tr1_impl/hashtable&gt;" value\="&lt;tr1/hashtable.h&gt;"/>\r\n<mapping key\="&lt;tr1_impl/random&gt;" value\="&lt;random&gt;"/>\r\n<mapping key\="&lt;tr1_impl/random&gt;" value\="&lt;tr1/random&gt;"/>\r\n<mapping key\="&lt;tr1_impl/random.tcc&gt;" value\="&lt;random&gt;"/>\r\n<mapping key\="&lt;tr1_impl/random.tcc&gt;" value\="&lt;tr1/random&gt;"/>\r\n<mapping key\="&lt;tr1_impl/regex&gt;" value\="&lt;regex&gt;"/>\r\n<mapping key\="&lt;tr1_impl/regex&gt;" value\="&lt;tr1/regex&gt;"/>\r\n<mapping key\="&lt;tr1_impl/type_traits&gt;" value\="&lt;tr1/type_traits&gt;"/>\r\n<mapping key\="&lt;tr1_impl/type_traits&gt;" value\="&lt;type_traits&gt;"/>\r\n<mapping key\="&lt;tr1_impl/unordered_map&gt;" value\="&lt;tr1/unordered_map&gt;"/>\r\n<mapping key\="&lt;tr1_impl/unordered_map&gt;" value\="&lt;unordered_map&gt;"/>\r\n<mapping key\="&lt;tr1_impl/unordered_set&gt;" value\="&lt;tr1/unordered_set&gt;"/>\r\n<mapping key\="&lt;tr1_impl/unordered_set&gt;" value\="&lt;unordered_set&gt;"/>\r\n<mapping key\="&lt;tr1_impl/utility&gt;" value\="&lt;tr1/utility&gt;"/>\r\n<mapping key\="&lt;tr1_impl/utility&gt;" value\="&lt;utility&gt;"/>\r\n</unconditional_substitution_map>\r\n<optional_substitution_map>\r\n<mapping key\="&lt;assert.h&gt;" value\="&lt;cassert&gt;"/>\r\n<mapping key\="&lt;complex.h&gt;" value\="&lt;ccomplex&gt;"/>\r\n<mapping key\="&lt;ctype.h&gt;" value\="&lt;cctype&gt;"/>\r\n<mapping key\="&lt;errno.h&gt;" value\="&lt;cerrno&gt;"/>\r\n<mapping key\="&lt;fenv.h&gt;" value\="&lt;cfenv&gt;"/>\r\n<mapping key\="&lt;float.h&gt;" value\="&lt;cfloat&gt;"/>\r\n<mapping key\="&lt;inttypes.h&gt;" value\="&lt;cinttypes&gt;"/>\r\n<mapping key\="&lt;ios&gt;" value\="&lt;iostream&gt;"/>\r\n<mapping key\="&lt;ios&gt;" value\="&lt;istream&gt;"/>\r\n<mapping key\="&lt;ios&gt;" value\="&lt;ostream&gt;"/>\r\n<mapping key\="&lt;iosfwd&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;iosfwd&gt;" value\="&lt;streambuf&gt;"/>\r\n<mapping key\="&lt;iso646.h&gt;" value\="&lt;ciso646&gt;"/>\r\n<mapping key\="&lt;istream&gt;" value\="&lt;iostream&gt;"/>\r\n<mapping key\="&lt;istream&gt;" value\="&lt;fstream&gt;"/>\r\n<mapping key\="&lt;istream&gt;" value\="&lt;sstream&gt;"/>\r\n<mapping key\="&lt;limits.h&gt;" value\="&lt;climits&gt;"/>\r\n<mapping key\="&lt;locale.h&gt;" value\="&lt;clocale&gt;"/>\r\n<mapping key\="&lt;math.h&gt;" value\="&lt;cmath&gt;"/>\r\n<mapping key\="&lt;ostream&gt;" value\="&lt;iostream&gt;"/>\r\n<mapping key\="&lt;ostream&gt;" value\="&lt;fstream&gt;"/>\r\n<mapping key\="&lt;ostream&gt;" value\="&lt;istream&gt;"/>\r\n<mapping key\="&lt;ostream&gt;" value\="&lt;sstream&gt;"/>\r\n<mapping key\="&lt;setjmp.h&gt;" value\="&lt;csetjmp&gt;"/>\r\n<mapping key\="&lt;signal.h&gt;" value\="&lt;csignal&gt;"/>\r\n<mapping key\="&lt;stdarg.h&gt;" value\="&lt;cstdarg&gt;"/>\r\n<mapping key\="&lt;stdbool.h&gt;" value\="&lt;cstdbool&gt;"/>\r\n<mapping key\="&lt;stddef.h&gt;" value\="&lt;cstddef&gt;"/>\r\n<mapping key\="&lt;stdint.h&gt;" value\="&lt;cstdint&gt;"/>\r\n<mapping key\="&lt;stdio.h&gt;" value\="&lt;cstdio&gt;"/>\r\n<mapping key\="&lt;stdlib.h&gt;" value\="&lt;cstdlib&gt;"/>\r\n<mapping key\="&lt;streambuf&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;string.h&gt;" value\="&lt;cstring&gt;"/>\r\n<mapping key\="&lt;tgmath.h&gt;" value\="&lt;ctgmath&gt;"/>\r\n<mapping key\="&lt;time.h&gt;" value\="&lt;ctime&gt;"/>\r\n<mapping key\="&lt;wchar.h&gt;" value\="&lt;cwchar&gt;"/>\r\n<mapping key\="&lt;wctype.h&gt;" value\="&lt;cwctype&gt;"/>\r\n</optional_substitution_map>\r\n</map>\r\n</maps>
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.number_of_empty_lines_to_preserve=1
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.LaunchLastIfNotLaunchable=true
/bundle_defaults/org.eclipse.ui.workbench/SHOW_MEMORY_MONITOR=false
/bundle_defaults/org.eclipse.cdt.ui/forwardDeclare.templates=false
/bundle_defaults/org.eclipse.cdt.ui/matchingBracketsColor=170,170,170
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_colon_in_base_clause=insert
/bundle_defaults/org.eclipse.ui.editors/quickdiff.quickDiff=true
/bundle_defaults/com.crt.utils/extendedToolsSupport=false
/bundle_defaults/org.eclipse.core.resources/refresh.lightweight.enabled=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.getter.suffix=
/bundle_defaults/org.eclipse.ui.editors/linked.slave.color=180,215,255
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticField.underline=false
/bundle_defaults/org.eclipse.ui.ide/TASKS_FILTERS_MIGRATE=false
/bundle_defaults/org.eclipse.core.net/proxyData/HTTP/hasAuth=false
/bundle_defaults/org.eclipse.cdt.dsf.gdb/tracesEnable=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.overloadedOperator.bold=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_semicolon=do not insert
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.pcHistorySize=4
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.reset_memory_block=org.eclipse.debug.uiresetMemoryBlock.visible
/bundle_defaults/org.eclipse.ui.editors/filteredSearchResultIndication=false
/bundle_defaults/org.eclipse.ui.workbench/KEYS_PREFERENCE_SELECTED_TAB=0
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.overrideIndicatorHighlighting=false
/bundle_defaults/org.eclipse.ui.editors/showAdditionInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.put_empty_statement_on_new_line=true
/bundle_defaults/org.eclipse.ui.workbench/ENABLED_DECORATORS=
/bundle_defaults/org.eclipse.ui.workbench/LAYOUT_DIRECTION=0
/bundle_defaults/org.eclipse.cdt.ui/hoverModifiers=org.eclipse.cdt.ui.BestMatchHover;0;org.eclipse.cdt.ui.CSourceHover;Shift
/bundle_defaults/org.eclipse.cdt.dsf.gdb/defaultGdbInit=.gdbinit
/bundle_defaults/org.eclipse.cdt.ui/scalability.syntaxColor=false
/bundle_defaults/org.eclipse.ui.ide/LIMIT_TASKS=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.field.color=0,0,192
/bundle_defaults/org.eclipse.cdt.debug.core/org.eclipse.cdt.debug.corecDebug.Disassembly.instructionStepOn=false
/bundle_defaults/org.eclipse.cdt.ui/removeTrailingWhitespace=true
/bundle_defaults/org.eclipse.ui.editors/searchResultIndicationInVerticalRuler=true
/bundle_defaults/org.eclipse.cdt.ui/spelling_ignore_mixed=true
/bundle_defaults/org.eclipse.ui/VIEW_TAB_POSITION=128
/bundle_defaults/org.eclipse.cdt.ui/content_assist_proposals_foreground=0,0,0
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.occurrenceTextStyle=NONE
/bundle_defaults/org.eclipse.ui.editors/currentIPTextStyle=NONE
/bundle_defaults/org.eclipse.ui/USE_COLORED_LABELS=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.remove_all_expressions_prompt=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_enum_declarations=insert
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.error.GoToNextNavigationTarget=true
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.SaveAllEditors=false
/bundle_defaults/org.eclipse.cdt.core/indexer/indexImportLocation=.settings/cdt-index.zip
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.memory.paddedStr=??
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.test.wordDelimiter=
/bundle_defaults/org.eclipse.ui/EDITOR_TAB_POSITION=128
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_pinint.com.crt.advproject.projecttype.exe.500409353/com.crt.advproject.config.exe.debug.1554618354=com.crt.advproject.link.cpp.exe.debug.1515071553\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1895588001\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.870533861\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1867315417\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1897250593\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.282738432\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1554618354\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/linked.target.verticalruler=false
/bundle_defaults/org.eclipse.ui.editors/isSpellingGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/deletionIndicationInVerticalRuler=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.function.underline=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_template_parameters=do not insert
/bundle_defaults/org.eclipse.ui.workbench/RECENT_FILES=4
/bundle_defaults/org.eclipse.cdt.ui/inactiveCodeEnable=true
/bundle_defaults/com.crt.debugcommon/Red\ Probe\ Family=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_question_in_conditional=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_between_empty_parens_in_method_invocation=do not insert
/bundle_defaults/org.eclipse.cdt.ui/content_assist_order_proposals=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.label.bold=false
/instance/org.eclipse.cdt.core/macros/workspace=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?>\r\n<macros/>\r\n
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroDefinition.underline=false
/bundle_defaults/org.eclipse.cdt.dsf.ui/delaySteppingForViewUpdatesEnable=false
/bundle_defaults/org.eclipse.cdt.ui/spelling_ignore_string_literals=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/LPCXpresso176x_timer.com.crt.advproject.projecttype.exe.1447070015/com.crt.advproject.config.exe.release.355928930=com.crt.advproject.toolchain.exe.release.1378490699\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.811744456\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.348057984\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.1794124423\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1794703196\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1917935340\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_postfix_operator=do not insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.overloadedOperator.italic=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_parameters_in_method_declaration=16
/bundle_defaults/org.eclipse.cdt.ui/asm_label=127,0,85
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.avoidReadBeforePC=false
/bundle_defaults/org.eclipse.ui.ide/SWITCH_PERSPECTIVE_ON_PROJECT_CREATION=prompt
/bundle_defaults/org.eclipse.ui.editors/com.crt.etmetb.marker.pref.textStyle=IBEAM
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.c_keyword.enabled=true
/bundle_defaults/com.crt.debugcommon/warning_as_note=false
/bundle_defaults/org.eclipse.ui.editors/linked.focus.text.style=BOX
/bundle_defaults/org.eclipse.ui.editors/currentIPHighlight=true
/bundle_defaults/org.eclipse.ui/USE_WINDOW_WORKING_SET_BY_DEFAULT=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.method.bold=false
/bundle_defaults/org.eclipse.ui.editors/showTrailingSpaces=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.comment.min_distance_between_code_and_line_comment=1
/bundle_defaults/org.eclipse.cdt.ui/pp_header_italic=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.variable.capitalization=4
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_uart_rb.com.crt.advproject.projecttype.exe.1950633819/com.crt.advproject.config.exe.release.591215090=com.crt.advproject.link.exe.release.679425267\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1983682568\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.1335020951\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1666157320\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.2140904055\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.217606318\=rebuildState\\\=true\\r\\n\r\n
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_bod.com.crt.advproject.projecttype.exe.1330480440/com.crt.advproject.config.exe.debug.1121475055=com.crt.advproject.link.exe.debug.998466899\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1234966347\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.474972202\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1121475055\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.1991069582\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1117423890\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.33140722\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui/KEY_CONFIGURATION_ID=org.eclipse.ui.defaultAcceleratorConfiguration
/bundle_defaults/org.eclipse.core.resources/description.filestatelongevity=604800000
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_binary_expression=16
/bundle_defaults/org.eclipse.debug.ui/org.eclispe.debug.ui.Debug_view.mode=Debug_view.mode.auto
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_prefix_operator=do not insert
/bundle_defaults/com.crt.dsfdebug/periphFormatToWidth=false
/instance/org.eclipse.core.resources/version=1
/bundle_defaults/org.eclipse.cdt.ui/markOccurrences=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.use_tabs_only_for_leading_indentations=false
/instance/org.eclipse.cdt.debug.core/org.eclipse.cdt.debug.core.cDebug.default_source_containers=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?>\r\n<sourceLookupDirector>\r\n<sourceContainers duplicates\="false">\r\n<container memento\="AbsolutePath" typeId\="org.eclipse.cdt.debug.core.containerType.absolutePath"/>\r\n<container memento\="programRelativePath" typeId\="org.eclipse.cdt.debug.core.containerType.programRelativePath"/>\r\n<container memento\="&lt;?xml version\=&quot;1.0&quot; encoding\=&quot;UTF-8&quot; standalone\=&quot;no&quot;?&gt;&\#13;&\#10;&lt;project referencedProjects\=&quot;true&quot;/&gt;&\#13;&\#10;" typeId\="org.eclipse.cdt.debug.core.containerType.project"/>\r\n</sourceContainers>\r\n</sourceLookupDirector>\r\n
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.PREF_FILTER_LAUNCH_TYPES=false
/instance/org.eclipse.debug.core//org.eclipse.debug.core.PREFERRED_DELEGATES/org.eclipse.cdt.launch.postmortemLaunchType=org.eclipse.cdt.dsf.gdb.launch.coreCLaunch,debug,;
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.UseContextualLaunch=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enum.strikethrough=false
/bundle_defaults/org.eclipse.core.resources/delta.expiration=2592000000
/bundle_defaults/org.eclipse.ui.editors/printMarginColumn=80
/bundle_defaults/org.eclipse.ui.workbench/COLOR_ICONS=true
/bundle_defaults/org.eclipse.ui.editors/secondaryIPOverviewRuler=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_ethernet.com.crt.advproject.projecttype.exe.1632332403/com.crt.advproject.config.exe.release.1243387797=com.crt.advproject.toolchain.exe.release.1109289695\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.1005076799\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1328591123\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.993078141\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.511095667\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1549525454\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/com.crt.config/package=LPC1343
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_before_catch_in_try_statement=do not insert
/bundle_defaults/com.crt.debugcommon/genericVidpidScript=
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.function.enabled=false
/bundle_defaults/org.eclipse.ui.workbench/FVB_HIDE=false
/bundle_defaults/org.eclipse.cdt.ui/scalability.parserBasedContentAssist=false
/bundle_defaults/org.eclipse.cdt.core/useStructualParseMode=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.occurrenceIndicationColor=212,212,212
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.max_detail_length=10000
/bundle_defaults/org.eclipse.cdt.ui/spelling_locale=en_US
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_switchstatements_compare_to_cases=true
/bundle_defaults/com.crt.debugcommon/showExtended=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_namespace_declaration=end_of_line
/bundle_defaults/com.crt.advproject/dependeciesfix=true
/bundle_defaults/org.eclipse.ui.editors/com.crt.etmetb.marker.profile.pref.vertical=false
/bundle_defaults/org.eclipse.ui.editors/unchangedIndicationInVerticalRuler=false
/bundle_defaults/org.eclipse.cdt.codan.core/useParentScope=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.memory.rowSize=16
/bundle_defaults/org.eclipse.ui.editors/showFilteredSearchResultInNextPrevDropdownToolbarAction=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_if=do not insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariable.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/spelling_user_dictionary=
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.externalSDK.color=100,40,128
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.namespace.color=0,0,0
/bundle_defaults/com.crt.debugcommon/macBackgroundExec=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariable.bold=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_throws_clause_in_method_declaration=16
/bundle_defaults/org.eclipse.ui/VIEW_MINIMUM_CHARACTERS=1
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.label.underline=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.header.wordDelimiter=
/bundle_defaults/org.eclipse.ui/RECENTLY_USED_WORKINGSETS_SIZE=5
/bundle_defaults/org.eclipse.debug.ui/DEBUG.consoleOpenOnErr=true
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.constant.capitalization=1
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.functionDeclaration.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroDefinition.color=0,0,0
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_base_types=insert
/bundle_defaults/org.eclipse.ui.editors/showLineFeed=true
/bundle_defaults/org.eclipse.cdt.ui/c_comment_task_tag_bold=true
/bundle_defaults/org.eclipse.cdt.ui/formatter_profile=org.eclipse.cdt.ui.default.kandr_profile
/bundle_defaults/com.crt.debugcommon/bootLogFile=
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.setter.suffix=
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_before_closing_brace_in_array_initializer=do not insert
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.NavigationEndAction=prompt
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.manage_view_perspectives=DEFAULT
/bundle_defaults/org.eclipse.ui.ide/SAVE_ALL_BEFORE_BUILD=false
/bundle_defaults/org.eclipse.ui.editors/quickdiff.characterMode=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_brace_in_array_initializer=insert
/instance/org.eclipse.cdt.managedbuilder.core/properties/usbd_lib_hid_generic.com.crt.advproject.projecttype.exe.1358948682/com.crt.advproject.config.exe.debug.815324353=com.crt.advproject.config.exe.debug.815324353\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1493008474\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.131611243\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.81969147\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1255076903\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.537414472\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1024811717\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.core.net/proxyData/HTTPS/port=-1
/bundle_defaults/org.eclipse.cdt.dsf.gdb/org.eclipse.cdt.dsf.gdb.hideRunningThreads=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.dsf.debug.ui.hyperlinkdetector.stepIntoSelection_stateMask=327680
/bundle_defaults/org.eclipse.ui.editors/infoTextStyle=SQUIGGLES
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleInfoStreamColor=0,0,255
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.show_debug_perspective_default=org.eclipse.debug.ui.DebugPerspective
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleErrorStreamColor=255,0,0
/bundle_defaults/org.eclipse.ui.editors/spellingTextStyle=PROBLEM_UNDERLINE
/bundle_defaults/org.eclipse.ui.ide/PROBLEMS_FILTERS_MIGRATE=false
/bundle_defaults/org.eclipse.cdt.dsf.gdb/initialChildCountLimitForCollections=100
/bundle_defaults/org.eclipse.ui.ide/IMPORT_FILES_AND_FOLDERS_RELATIVE=true
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.addressColor=0,96,0
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_bod.com.crt.advproject.projecttype.exe.1330480440/com.crt.advproject.config.exe.release.1597988367=com.crt.advproject.gcc.exe.release.1008161469\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1862735863\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1883379497\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1170680966\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.637149094\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.330034282\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/pp_header=42,0,255
/bundle_defaults/org.eclipse.cdt.dsf.gdb/autoTerminateGdb=true
/instance/org.eclipse.ui.ide/tipsAndTricks=true
/bundle_defaults/org.eclipse.ui.editors/revisionAnnotationIndicationHighlighting=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.getter.prefix=get
/bundle_defaults/com.crt.debugcommon/redlink_useWmic=true
/bundle_defaults/org.eclipse.ui.editors/searchResultIndication=false
/bundle_defaults/org.eclipse.ui.editors/filteredSearchResultHighlighting=false
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_default_comments=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.method.wordDelimiter=
/bundle_defaults/org.eclipse.cdt.dsf.gdb/org.eclipse.cdt.dsf.gdb.commandTimeoutValue=10000
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_for=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_colon_in_default=do not insert
/bundle_defaults/org.eclipse.ui.workbench/EDITORLIST_SELECTION_SCOPE=1
/bundle_defaults/org.eclipse.ui.ide/WELCOME_DIALOG=true
/bundle_defaults/org.eclipse.cdt.core/scalability.limitTokensPerTU=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.variable.wordDelimiter=
/instance/org.eclipse.cdt.managedbuilder.core/properties/lwip_tcpecho_sa.com.crt.advproject.projecttype.exe.468432546/com.crt.advproject.config.exe.debug.1119530382=com.crt.advproject.link.cpp.exe.debug.2050365894\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1247192910\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.803449759\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1860283680\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1297078967\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1644762283\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1119530382\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.ide/PROJECT_OPEN_NEW_PERSPECTIVE=OPEN_PERSPECTIVE_REPLACE
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_method_invocation=do not insert
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.overrideIndicatorTextStyle=SQUIGGLES
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleProblemInfoBackgroundColor=244,247,254
@org.eclipse.cdt.core=5.8.0.201409172108
/bundle_defaults/org.eclipse.cdt.ui/content_assist_disabled_computers=org.eclipse.cdt.ui.textProposalCategory\u0000
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Color.Background.SystemDefault=true
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.IgnoreWhitespace=false
/bundle_defaults/com.crt.dsfdebug/windowsMakePathsRelative=false
/bundle_defaults/org.eclipse.ui.workbench/shouldPromptForEnablement=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.templateParameter.color=100,70,50
/bundle_defaults/org.eclipse.ui.editors/linked.exit.navigation.previous=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.activate_workbench=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.relaunch_in_debug_mode=never
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.problem.strikethrough=false
/bundle_defaults/org.eclipse.ui.ide/LIMIT_BOOKMARKS=true
/bundle_defaults/org.eclipse.debug.ui/Console.console_tab_width=8
/bundle_defaults/org.eclipse.core.resources/description.maxfilestates=50
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_breaks_compare_to_cases=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_method_declaration=do not insert
/bundle_defaults/org.eclipse.ui.editors/spellingIndicationInVerticalRuler=false
/bundle_defaults/com.crt.utils/newMacAddressMethod=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_flashiap.com.crt.advproject.projecttype.exe.2033906280/com.crt.advproject.config.exe.release.1130833511=com.crt.advproject.cpp.exe.release.1595716391\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1101117428\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1136415674\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1814748619\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1587509976\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.873115923\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.PREF_FILTER_LAUNCH_DELETED=true
/bundle_defaults/com.crt.utils/hideDebugView=true
/bundle_defaults/org.eclipse.ui.editors/bookmarkIndicationHighlighting=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_array_initializer=insert
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.PREF_LAUNCH_PERSPECTIVES=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?>\r\n<launchPerspectives>\r\n<launchPerspective configurationType\="com.crt.dsfdebug.crtmcu.launchType" mode\="debug" perspective\="com.crt.lite.perspective.CRTPerspective"/>\r\n</launchPerspectives>\r\n
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.auto_remove_old_launches=true
/bundle_defaults/com.crt.debugcommon/redlink_boot_image=(?i)LPC43.._Redlink_V([0-9]_[0-9]+).bin.hdr
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.setter.wordDelimiter=
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enumerator.italic=true
/bundle_defaults/org.eclipse.core.resources/description.defaultbuildorder=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_switch=do not insert
/bundle_defaults/org.eclipse.ui.editors/isTaskGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_angle_bracket_in_template_parameters=do not insert
/instance/org.eclipse.cdt.ui.prj-periph_blinky/buildConsole/logLocation=C\:\\Users\\Egitim5\\Documents\\LPCXpresso_7.6.2_326\\workspace\\.metadata\\.plugins\\org.eclipse.cdt.ui\\periph_blinky.build.log
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.method.italic=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_CORE_LPC112x.com.crt.advproject.projecttype.lib.481795455/com.crt.advproject.config.lib.debug.552843825=com.crt.advproject.ar.lib.debug.67772726\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.2069312955\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.752221769\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.1580605360\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.712578205\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.552843825\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/bundle_defaults/com.crt.debugcommon/probe_settle=250
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleTabWith=4
/bundle_defaults/org.eclipse.ui.editors/infoIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.ui.internal.editors.text.URLHyperlinkDetector_stateMask=-1
/bundle_defaults/org.eclipse.core.resources/description.maxbuilditerations=10
/bundle_defaults/org.eclipse.cdt.ui/c_braces_bold=false
/bundle_defaults/org.eclipse.cdt.ui/spelling_ignore_digits=true
/bundle_defaults/org.eclipse.ui.editors/linked.exit.navigation.next=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.warning.text=true
/bundle_defaults/com.crt.debugcommon/redlink_server_port=3025
/bundle_defaults/org.eclipse.core.net/proxyData/HTTPS/hasAuth=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.parameterVariable.underline=false
/instance/org.eclipse.cdt.core.prj-LPCX176x_cmsis2_systick/indexer/preferenceScope=0
/bundle_defaults/org.eclipse.ui.editors/searchResultHighlighting=true
/bundle_defaults/org.eclipse.ui.editors/hyperlinkColor=0,102,204
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.occurrenceHighlighting=true
/bundle_defaults/org.eclipse.ui.editors/errorIndicationInVerticalRuler=true
/bundle_defaults/org.eclipse.cdt.ui/pp_header_bold=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.functionDeclaration.bold=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_enum_declarations=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_namespace_declaration=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_declarator_list=16
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_spi.com.crt.advproject.projecttype.exe.1116578252/com.crt.advproject.config.exe.debug.601319979=com.crt.advproject.gcc.exe.debug.326242662\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.652166092\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.9224791\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.309974641\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.2027771857\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.415100223\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.601319979\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/instance/org.eclipse.cdt.managedbuilder.core/properties/LPCXpresso1768_systick.com.crt.advproject.projecttype.exe.783271606/com.crt.advproject.config.exe.debug.986034614=com.crt.advproject.gcc.exe.debug.2049914417.1184573733\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1701619043\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1801950365\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.986034614.52274068\=rebuildState\\\=true\\r\\n\r\norg.eclipse.cdt.managedbuilder.ui.rcbs.104766275\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.694254463\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.986034614\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.2049914417\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.487243263\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1291557132\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleProblemBackgroundColor=254,231,224
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.writeOccurrenceHighlighting=true
/bundle_defaults/org.eclipse.ui.editors/isBookmarkGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.ui.workbench/OPEN_ON_SINGLE_CLICK=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_flashiap.com.crt.advproject.projecttype.exe.2033906280/com.crt.advproject.config.exe.debug.1880147916=com.crt.advproject.link.cpp.exe.debug.1712581607\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1540092944\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1650853042\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1209267662\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1113455924\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1880147916\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1225921430\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/com.crt.debugcommon/semihostingState=false
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.system=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style blank_line_before\="true" keep_together\="true" order\="0"/>
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_while=do not insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enumerator.enabled=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enum.underline=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/lwip_tcpecho_sa.com.crt.advproject.projecttype.exe.468432546/com.crt.advproject.config.exe.release.1619684282=com.crt.advproject.gcc.exe.release.715600888\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1994205202\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.857667410\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.120251981\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.2064666483\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.173463807\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.typedef.strikethrough=false
/bundle_defaults/org.eclipse.ui.editors/isIndexResultInNextPrevDropdownToolbarAction=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_pmu.com.crt.advproject.projecttype.exe.1242046794/com.crt.advproject.config.exe.debug.815439733=com.crt.advproject.config.exe.debug.815439733\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.315300907\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1369234815\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1868866796\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.725131995\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.762982395\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1763844694\=rebuildState\\\=false\\r\\n\r\n
/instance/org.eclipse.cdt.core.prj-lpc_board_nxp_lpcxpresso_1769/indexer/preferenceScope=0
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk.scheduler/remindElapsedTime=30 minutes
/bundle_defaults/org.eclipse.ui.workbench/coolBarVisible=true
/bundle_defaults/org.eclipse.ui/CLOSE_EDITORS_ON_EXIT=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_exception_specification=do not insert
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_can.com.crt.advproject.projecttype.exe.1549120935/com.crt.advproject.config.exe.release.794995649=com.crt.advproject.link.exe.release.440877968\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1469513783\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.1926579303\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.212903690\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.2129410273\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.2074713666\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk.scheduler/enabled=false
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk/showLatestVersion=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.field.strikethrough=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_ethernet.com.crt.advproject.projecttype.exe.1632332403/com.crt.advproject.config.exe.debug.1090525059=com.crt.advproject.gas.exe.debug.421609304\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1090525059\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.909433006\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1459417064\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1587156633\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.878183164\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.825344951\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/errorIndication=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/webserver_freertos.com.crt.advproject.projecttype.exe.874780069/com.crt.advproject.config.exe.release.295130519=com.crt.advproject.link.exe.release.179256910\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1468130162\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1612063061\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.863141771\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1788992748\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.1495546561\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/content_assist_category_order=org.eclipse.cdt.ui.parserProposalCategory\:65539\u0000org.eclipse.cdt.ui.textProposalCategory\:65541\u0000org.eclipse.cdt.ui.templateProposalCategory\:2\u0000org.eclipse.cdt.ui.helpProposalCategory\:5\u0000
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.overrideIndicator=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariableDeclaration.enabled=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.isOverrideIndicatorGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/showRevisionAnnotationInNextPrevDropdownToolbarAction=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_catch=do not insert
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_default_functions=false
/bundle_defaults/org.eclipse.ui/SHOW_SYSTEM_JOBS=false
/bundle_defaults/org.eclipse.ui.editors/hyperlinksEnabled=true
/bundle_defaults/org.eclipse.ui/SHOW_MULTIPLE_EDITOR_TABS=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSISv2p00_LPC17xx.com.crt.advproject.projecttype.lib.1193160240/com.crt.advproject.config.lib.release.1079171862=com.crt.advproject.gas.lib.release.48688322\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.lib.release.352135057\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.ar.lib.release.1701225249\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.lib.release.1097962762\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.lib.release.1602026126\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.error.textstyle=SQUIGGLES
/bundle_defaults/org.eclipse.debug.core/org.eclipse.debug.core.PREF_ENABLE_STATUS_HANDLERS=true
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_preprocessor_enabled=false
/bundle_defaults/org.eclipse.cdt.ui/forwardDeclare.enums=false
/bundle_defaults/org.eclipse.ui.ide/saveInterval=5
/instance/org.eclipse.cdt.core.prj-LPCX176x_cmsis2_systick_twinkle/indexer/preferenceScope=0
/bundle_defaults/org.eclipse.cdt.ui/c_default=0,0,0
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.inSameProject=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style angle_brackets\="false" blank_line_before\="false" keep_together\="false" relative_path\="false"/>
/bundle_defaults/org.eclipse.ui.workbench/HeapStatus.showMax=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.templateParameter.underline=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_prefix_operator=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_declarator_list=do not insert
/bundle_defaults/com.crt.debugcommon/displayConsole=false
/instance/org.eclipse.cdt.core.prj-lpc_chip_175x_6x/indexer/preferenceScope=0
/bundle_defaults/org.eclipse.ui.editors/isUnchangedGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_closing_angle_bracket_in_template_parameters=insert
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.showSymbols=true
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.setter.prefix=set
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.methodDeclaration.italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.templateParameter.enabled=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_angle_bracket_in_template_arguments=do not insert
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.writeOccurrenceIndicationInVerticalRuler=false
/bundle_defaults/org.eclipse.cdt.ui/organizeIncludes.symbolExportingHeaders=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<maps>\r\n<map>\r\n<mapping key\="blkcnt_t" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="blkcnt_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="blksize_t" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="blksize_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="calloc" value\="&lt;cstdlib&gt;"/>\r\n<mapping key\="calloc" value\="&lt;stdlib.h&gt;"/>\r\n<mapping key\="daddr_t" value\="&lt;rpc/types.h&gt;"/>\r\n<mapping key\="daddr_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="dev_t" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="dev_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="EOF" value\="&lt;cstdio&gt;"/>\r\n<mapping key\="EOF" value\="&lt;libio.h&gt;"/>\r\n<mapping key\="EOF" value\="&lt;stdio.h&gt;"/>\r\n<mapping key\="error_t" value\="&lt;argp.h&gt;"/>\r\n<mapping key\="error_t" value\="&lt;argz.h&gt;"/>\r\n<mapping key\="error_t" value\="&lt;errno.h&gt;"/>\r\n<mapping key\="free" value\="&lt;cstdlib&gt;"/>\r\n<mapping key\="free" value\="&lt;stdlib.h&gt;"/>\r\n<mapping key\="fsblkcnt_t" value\="&lt;sys/statvfs.h&gt;"/>\r\n<mapping key\="fsblkcnt_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="fsfilcnt_t" value\="&lt;sys/statvfs.h&gt;"/>\r\n<mapping key\="fsfilcnt_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="gid_t" value\="&lt;grp.h&gt;"/>\r\n<mapping key\="gid_t" value\="&lt;pwd.h&gt;"/>\r\n<mapping key\="gid_t" value\="&lt;stropts.h&gt;"/>\r\n<mapping key\="gid_t" value\="&lt;sys/ipc.h&gt;"/>\r\n<mapping key\="gid_t" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="gid_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="gid_t" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="id_t" value\="&lt;sys/resource.h&gt;"/>\r\n<mapping key\="id_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="ino_t" value\="&lt;dirent.h&gt;"/>\r\n<mapping key\="ino_t" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="ino_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="ino64_t" value\="&lt;dirent.h&gt;"/>\r\n<mapping key\="ino64_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="int8_t" value\="&lt;stdint.h&gt;"/>\r\n<mapping key\="int8_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="intptr_t" value\="&lt;stdint.h&gt;"/>\r\n<mapping key\="intptr_t" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="key_t" value\="&lt;sys/ipc.h&gt;"/>\r\n<mapping key\="key_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="malloc" value\="&lt;cstdlib&gt;"/>\r\n<mapping key\="malloc" value\="&lt;stdlib.h&gt;"/>\r\n<mapping key\="mode_t" value\="&lt;sys/ipc.h&gt;"/>\r\n<mapping key\="mode_t" value\="&lt;sys/mman.h&gt;"/>\r\n<mapping key\="mode_t" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="mode_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="nlink_t" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="nlink_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="NULL" value\="&lt;cstddef&gt;"/>\r\n<mapping key\="NULL" value\="&lt;cstdio&gt;"/>\r\n<mapping key\="NULL" value\="&lt;cstdlib&gt;"/>\r\n<mapping key\="NULL" value\="&lt;cstring&gt;"/>\r\n<mapping key\="NULL" value\="&lt;ctime&gt;"/>\r\n<mapping key\="NULL" value\="&lt;cwchar&gt;"/>\r\n<mapping key\="NULL" value\="&lt;locale.h&gt;"/>\r\n<mapping key\="NULL" value\="&lt;stddef.h&gt;"/>\r\n<mapping key\="NULL" value\="&lt;stdio.h&gt;"/>\r\n<mapping key\="NULL" value\="&lt;stdlib.h&gt;"/>\r\n<mapping key\="NULL" value\="&lt;string&gt;"/>\r\n<mapping key\="NULL" value\="&lt;string.h&gt;"/>\r\n<mapping key\="NULL" value\="&lt;time.h&gt;"/>\r\n<mapping key\="NULL" value\="&lt;wchar.h&gt;"/>\r\n<mapping key\="off_t" value\="&lt;sys/mman.h&gt;"/>\r\n<mapping key\="off_t" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="off_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="off_t" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="off64_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="off64_t" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="pid_t" value\="&lt;ctime&gt;"/>\r\n<mapping key\="pid_t" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="pid_t" value\="&lt;sys/msg.h&gt;"/>\r\n<mapping key\="pid_t" value\="&lt;sys/shm.h&gt;"/>\r\n<mapping key\="pid_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="pid_t" value\="&lt;termios.h&gt;"/>\r\n<mapping key\="pid_t" value\="&lt;time.h&gt;"/>\r\n<mapping key\="pid_t" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="pid_t" value\="&lt;utmpx.h&gt;"/>\r\n<mapping key\="realloc" value\="&lt;cstdlib&gt;"/>\r\n<mapping key\="realloc" value\="&lt;stdlib.h&gt;"/>\r\n<mapping key\="sigset_t" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="sigset_t" value\="&lt;sys/epoll.h&gt;"/>\r\n<mapping key\="sigset_t" value\="&lt;sys/select.h&gt;"/>\r\n<mapping key\="size_t" value\="&lt;cstddef&gt;"/>\r\n<mapping key\="size_t" value\="&lt;stddef.h&gt;"/>\r\n<mapping key\="socklen_t" value\="&lt;arpa/inet.h&gt;"/>\r\n<mapping key\="socklen_t" value\="&lt;bits/socket.h&gt;"/>\r\n<mapping key\="socklen_t" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="ssize_t" value\="&lt;monetary.h&gt;"/>\r\n<mapping key\="ssize_t" value\="&lt;sys/msg.h&gt;"/>\r\n<mapping key\="ssize_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="ssize_t" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="std\:\:allocator" value\="&lt;map&gt;"/>\r\n<mapping key\="std\:\:allocator" value\="&lt;memory&gt;"/>\r\n<mapping key\="std\:\:allocator" value\="&lt;set&gt;"/>\r\n<mapping key\="std\:\:allocator" value\="&lt;string&gt;"/>\r\n<mapping key\="std\:\:allocator" value\="&lt;vector&gt;"/>\r\n<mapping key\="std\:\:char_traits" value\="&lt;istream&gt;"/>\r\n<mapping key\="std\:\:char_traits" value\="&lt;ostream&gt;"/>\r\n<mapping key\="std\:\:char_traits" value\="&lt;string&gt;"/>\r\n<mapping key\="suseconds_t" value\="&lt;sys/select.h&gt;"/>\r\n<mapping key\="suseconds_t" value\="&lt;sys/time.h&gt;"/>\r\n<mapping key\="suseconds_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="u_char" value\="&lt;rpc/types.h&gt;"/>\r\n<mapping key\="u_char" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="uid_t" value\="&lt;pwd.h&gt;"/>\r\n<mapping key\="uid_t" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="uid_t" value\="&lt;stropts.h&gt;"/>\r\n<mapping key\="uid_t" value\="&lt;sys/ipc.h&gt;"/>\r\n<mapping key\="uid_t" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="uid_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="uid_t" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="useconds_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="useconds_t" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="va_list" value\="&lt;cstdarg&gt;"/>\r\n<mapping key\="va_list" value\="&lt;stdarg.h&gt;"/>\r\n</map>\r\n</maps>
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_method_declaration=do not insert
/bundle_defaults/com.crt.debugcommon/streamAll=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_LPC43xx_DriverLib.com.crt.advproject.projecttype.lib.446509596/com.crt.advproject.config.lib.debug.1706711087=com.crt.advproject.gas.lib.debug.873301014\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.1970136550\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.1706711087\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.470207401\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.1549626933\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.1636147693\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_colon_in_case=do not insert
/bundle_defaults/com.crt.debugcommon/genericImageVista=LPCXpressoWIN.enc
/bundle_defaults/org.eclipse.cdt.ui/c_default_bold=false
/bundle_defaults/org.eclipse.ui.workbench/SINGLE_CLICK_METHOD=0
/bundle_defaults/org.eclipse.ui.editors/showCarriageReturn=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/RDB1768cmsis_EasyWeb.com.crt.advproject.projecttype.exe.1503643990/com.crt.advproject.config.exe.release.290126908=com.crt.advproject.link.exe.release.1509719446\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.2064883050\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.73082454\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1034802894\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1878142690\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.1785118895\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/isWarningGoToNextNavigationTarget=true
/bundle_defaults/org.eclipse.core.resources/description.autobuilding=true
/bundle_defaults/org.eclipse.cdt.ui/c_keyword_italic=false
/bundle_defaults/org.eclipse.cdt.core/indexer/indexerId=org.eclipse.cdt.core.fastIndexer
/bundle_defaults/org.eclipse.ui/initialFastViewBarLocation=bottom
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.taskCaseSensitive=false
/bundle_defaults/org.eclipse.ui.editors/isSearchResultGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.ui/wrapStrings=true
/bundle_defaults/org.eclipse.cdt.ui/matchingBrackets=true
/bundle_defaults/org.eclipse.ui.editors/changeIndication=false
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.functionOffsetsColor=96,0,0
/bundle_defaults/org.eclipse.ui.editors/currentLine=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.PREF_FILTER_LAUNCH_CLOSED=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_arguments_in_method_invocation=16
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.overloadedOperator.strikethrough=false
/bundle_defaults/org.eclipse.ui.editors/showLeadingTabs=true
/bundle_defaults/org.eclipse.ui.editors/searchResultIndicationColor=206,204,247
/bundle_defaults/org.eclipse.ui.editors/linked.exit.color=0,180,0
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.indexDBCacheSizePct=10
/bundle_defaults/org.eclipse.ui/showIntro=true
/bundle_defaults/org.eclipse.cdt.ui/closeStrings=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.ExpressionView+org.eclipse.debug.ui.ShowTypeNamesAction=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_declarator_list=insert
/bundle_defaults/org.eclipse.ui.editors/breakpointIndication=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_type_declaration=end_of_line
/instance/org.eclipse.cdt.managedbuilder.core/properties/webserver.com.crt.advproject.projecttype.exe.1345313107/com.crt.advproject.config.exe.debug.1009041700=com.crt.advproject.link.exe.debug.58094435\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1443586811\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1759689025\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.629714332\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1009041700\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.902041439\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1467576585\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.workspaceLanguageMappings=
/bundle_defaults/com.crt.debugcommon/genericPID=9
/instance/org.eclipse.cdt.managedbuilder.core/properties/usbd_lib_cdc_uart.com.crt.advproject.projecttype.exe.1798150368/com.crt.advproject.config.exe.debug.633067605=com.crt.advproject.config.exe.debug.633067605\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.92055126\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1784962483\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.486503944\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.2038387832\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.1475022981\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1429105598\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.templateParameter.italic=false
/bundle_defaults/org.eclipse.cdt.ui/c_operators_italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.label.color=0,0,0
/bundle_defaults/org.eclipse.ui.editors/isSearchResultGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/hyperlinkColor.SystemDefault=true
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Color.Background=255,255,255
/bundle_defaults/org.eclipse.ui.editors/hyperlinkKeyModifier=Ctrl
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.PREF_CHANGED_VALUE_BACKGROUND=255,255,0
/bundle_defaults/org.eclipse.ui.editors/isRevisionAnnotationGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.ui.ide/useSeparator.help.group.assist=true
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk.scheduler/download=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_array_initializer=insert
/instance/org.eclipse.cdt.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_watchdog.com.crt.advproject.projecttype.exe.720126098/com.crt.advproject.config.exe.debug.1064966769=com.crt.advproject.link.cpp.exe.debug.255382564\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.101020260\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.802481234\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1669682648\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1321532069\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.469196116\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1064966769\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_timer.com.crt.advproject.projecttype.exe.1309499312/com.crt.advproject.config.exe.debug.813915632=com.crt.advproject.toolchain.exe.debug.1571077862\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.64635116\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.713280462\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1673697699\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1163178252\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.135101893\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.813915632\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.namespace.strikethrough=false
/instance/org.eclipse.debug.ui/pref_state_memento.com.crt.peripheral.PeripheralView=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<VariablesViewMemento org.eclipse.debug.ui.SASH_DETAILS_PART\="315" org.eclipse.debug.ui.SASH_VIEW_PART\="684">\r\n<PRESENTATION_CONTEXT_PROPERTIES IMemento.internal.id\="PeripheralView">\r\n<BOOLEAN BOOLEAN\="true" IMemento.internal.id\="org.eclipse.debug.ui.check"/>\r\n</PRESENTATION_CONTEXT_PROPERTIES>\r\n</VariablesViewMemento>
/bundle_defaults/org.eclipse.cdt.ui/autoOpenConsole=true
/bundle_defaults/org.eclipse.ui.editors/linked.focus.text=true
/bundle_defaults/org.eclipse.core.resources/description.buildorder=
/bundle_defaults/org.eclipse.ui/SHIFT_OPEN_NEW_PERSPECTIVE=OPEN_PERSPECTIVE_REPLACE
/bundle_defaults/org.eclipse.ui.editors/othersIndicationInOverviewRuler=false
/bundle_defaults/org.eclipse.ui.ide/PROBLEMS_LIMIT=100
@org.eclipse.ui.workbench=3.106.1.v20140827-1737
/bundle_defaults/org.eclipse.cdt.ui/asm_label_bold=true
/bundle_defaults/org.eclipse.ui.editors/currentIPVerticalRuler=true
/bundle_defaults/org.eclipse.ui.editors/linked.focus.navigation.dropdown=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.header.capitalization=0
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_ritimer.com.crt.advproject.projecttype.exe.749237195/com.crt.advproject.config.exe.debug.1653325222=com.crt.advproject.link.exe.debug.1504230950\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1653325222\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.231976127\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.2077790918\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1951440756\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.1396920523\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.269804934\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/showTrailingIdeographicSpaces=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/webserver.com.crt.advproject.projecttype.exe.1345313107/com.crt.advproject.config.exe.release.1745840165=com.crt.advproject.toolchain.exe.release.295553106\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1306344566\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.2133637469\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.356011277\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.87988994\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.2038740337\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.editor.CElementHyperlinkDetector_stateMask=-1
/bundle_defaults/org.eclipse.ui.editors/filteredSearchResultIndicationInVerticalRuler=false
/bundle_defaults/org.eclipse.ui.workbench/ENABLE_COOL_BARS=true
/bundle_defaults/org.eclipse.cdt.core/indexer/indexOnOpen=false
/bundle_defaults/org.eclipse.ui.editors/linked.focus.verticalruler=false
/bundle_defaults/org.eclipse.cdt.ui/removeTrailingWhitespaceEditedLines=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.label.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.sameFolder=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style angle_brackets\="false" blank_line_before\="false" keep_together\="false" relative_path\="false"/>
/bundle_defaults/org.eclipse.ui.editors/showEnclosedSpaces=true
/bundle_defaults/org.eclipse.ui.editors/warningIndicationHighlighting=false
/bundle_defaults/org.eclipse.ui.workbench/USE_IPERSISTABLE_EDITORS=true
/bundle_defaults/org.eclipse.ui/ALTERNATE_OPEN_NEW_PERSPECTIVE=OPEN_PERSPECTIVE_REPLACE
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.NavigationEndActionLocal=loop
/bundle_defaults/com.crt.utils/useXMLcache=true
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Color.Foreground=0,0,0
/instance/org.eclipse.cdt.managedbuilder.core/properties/usbd_lib_cdc.com.crt.advproject.projecttype.exe.218798441/com.crt.advproject.config.exe.release.1194419284=com.crt.advproject.toolchain.exe.release.226839519\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.78030496\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.75777627\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.183333774\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.524848630\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.414188755\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.parameterVariable.enabled=false
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.related=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style blank_line_before\="false" keep_together\="false"/>
/bundle_defaults/org.eclipse.ui.editors/warn_if_input_derived=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.class.color=0,80,50
/bundle_defaults/com.crt.advproject/tempaddpaths=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticMethod.enabled=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/usbd_lib_hid_keyboard.com.crt.advproject.projecttype.exe.944853395/com.crt.advproject.config.exe.release.134692510=com.crt.advproject.toolchain.exe.release.1409852559\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1648508565\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1285760810\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1182439007\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.2048303538\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.498522395\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_body_declarations_compare_to_access_specifier=true
/bundle_defaults/com.crt.debugcommon/redlink_wirespeed=0
/bundle_defaults/org.eclipse.ui.editors/warningIndicationColor=244,200,45
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.save_dirty_editors_before_launch=prompt
/bundle_defaults/org.eclipse.cdt.ui/escapeStrings=false
/bundle_defaults/org.eclipse.core.resources/description.snapshotinterval=300000
/bundle_defaults/org.eclipse.ui.editors/secondaryIPIndication=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_adc.com.crt.advproject.projecttype.exe.1322797204/com.crt.advproject.config.exe.debug.570937243=com.crt.advproject.cpp.exe.debug.1554540715\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.570937243\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.859166281\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.949246481\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.671560872\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.79095767\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.994761076\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/indexResultIndication=true
/bundle_defaults/org.eclipse.cdt.ui/content_assist_autoactivation_trigger_replace_dot_with_arrow=true
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk.scheduler/remindOnSchedule=false
/bundle_defaults/org.eclipse.cdt.core/includes.exportPattern=IWYU\\s+(pragma\:?\\s+)?export
/bundle_defaults/org.eclipse.core.net/proxyData/HTTP/port=-1
/bundle_defaults/org.eclipse.ui.editors/unchangedIndicationColor=0,0,0
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_method_declaration_parameters=insert
/bundle_defaults/org.eclipse.ui.editors/isUnchangedGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.header.suffix=.h
/bundle_defaults/org.eclipse.ui/ENABLE_ANIMATIONS=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_if=insert
@org.eclipse.debug.ui=3.10.1.v20140822-1408
/bundle_defaults/org.eclipse.ui.editors/breakpointTextStyle=SQUIGGLES
/instance/org.eclipse.cdt.managedbuilder.core/properties/usbd_lib_composite.com.crt.advproject.projecttype.exe.2137007679/com.crt.advproject.config.exe.debug.1644757415=com.crt.advproject.cpp.exe.debug.2103935598\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.2079787435\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1800337119\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.626770401\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.944544801\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.928595566\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1644757415\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleProblemWarningBackgroundColor=254,243,218
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.path_canonicalization=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_switch=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.compact_else_if=true
/bundle_defaults/org.eclipse.cdt.ui/org.eclipse.cdt.ui.add_comments=false
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.systemWithExtension=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style angle_brackets\="true" blank_line_before\="false" keep_together\="true" order\="1" relative_path\="false"/>
/profile/file\:\\2fC\:\\2fnxp\\2fLPCXpresso_7.6.2_326\\2flpcxpresso\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.ui.sdk.scheduler/migrated34Prefs=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.field.italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.methodDeclaration.enabled=true
/bundle_defaults/org.eclipse.ui/PROJECT_OPEN_NEW_PERSPECTIVE=OPEN_PERSPECTIVE_REPLACE
/bundle_defaults/org.eclipse.cdt.ui/content_assist_autoactivation_delay=500
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_switchstatements_compare_to_switch=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_ssp.com.crt.advproject.projecttype.exe.2073917783/com.crt.advproject.config.exe.release.1685172963=com.crt.advproject.toolchain.exe.release.1661677\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.710368125\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.623441189\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1209643826\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.818233716\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.364014591\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/organizeIncludes.heuristicHeader_substitution=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.VariableView+org.eclipse.debug.ui.ShowDetailPaneAction=true
/bundle_defaults/org.eclipse.ui.workbench/ENABLE_NEW_MENUS=true
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleProblemHighlightedColor=255,0,0
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticField.bold=false
/bundle_defaults/org.eclipse.cdt.ui/stickyOccurrences=true
/configuration/org.eclipse.core.net/org.eclipse.core.net.hasMigrated=true
/bundle_defaults/org.eclipse.ui/SHOW_OTHER_IN_PERSPECTIVE_MENU=true
/bundle_defaults/org.eclipse.ui.editors/errorIndicationHighlighting=false
/bundle_defaults/org.eclipse.ui.editors/rulerContributions=
/instance/org.eclipse.ui.browser/internalWebBrowserHistory=file\:///C\:/nxp/LPCXpresso_7.6.2_326/lpcxpresso/pages/registeredFreeEdition.htm|*|file\://C\:/nxp/LPCXpresso_7.6.2_326/lpcxpresso/pages/registeredFreeEdition.htm|*|
/bundle_defaults/org.eclipse.ui.editors/changeIndicationInVerticalRuler=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_unary_operator=do not insert
/bundle_defaults/org.eclipse.ui.editors/errorTextStyle=PROBLEM_UNDERLINE
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.taskPriorities=normal
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Color.SelectionBackground.SystemDefault=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/webserver_freertos.com.crt.advproject.projecttype.exe.874780069/com.crt.advproject.config.exe.debug.1886496314=com.crt.advproject.cpp.exe.debug.1593928491\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1762572644\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.219570910\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1886496314\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.2046392211\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1488348836\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.457726334\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/isAdditionGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroSubstitution.italic=false
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.AddedLinesRegex=
/instance/org.eclipse.debug.ui/pref_state_memento.org.eclipse.debug.ui.RegisterView=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<VariablesViewMemento org.eclipse.debug.ui.SASH_DETAILS_PART\="315" org.eclipse.debug.ui.SASH_VIEW_PART\="684"/>
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_method_declaration=end_of_line
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_clkout.com.crt.advproject.projecttype.exe.1523737329/com.crt.advproject.config.exe.release.1167106413=com.crt.advproject.link.exe.release.530856060\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.845256876\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1838478822\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.781739769\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.508594437\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.305904039\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/scalability.detect=true
/bundle_defaults/org.eclipse.cdt.ui/org.eclipse.cdt.internal.ui.text.doctools.doxygen.multi=63,95,191
/bundle_defaults/org.eclipse.ui/EDITOR_MINIMUM_CHARACTERS=-1
/bundle_defaults/org.eclipse.cdt.ui/c_type_italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.method.enabled=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.MemoryHistoryKnownColor=0,0,0
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.error.overview=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroDefinition.italic=false
/bundle_defaults/org.eclipse.ui.editors/isBookmarkGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.switch_perspective_on_suspend=prompt
/bundle_defaults/org.eclipse.ui.editors/showTextHoverAffordance=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enum.italic=false
/bundle_defaults/org.eclipse.ui.editors/breakpointHighlight=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.cancel_launch_with_compile_errors=prompt
/bundle_defaults/org.eclipse.ui.editors/quickdiff.defaultProvider=org.eclipse.ui.internal.editors.quickdiff.LastSaveReferenceProvider
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_bracket=do not insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticMethod.italic=true
/bundle_defaults/org.eclipse.cdt.ui/function_output_parameters_before_input=false
/bundle_defaults/org.eclipse.ui.editors/linked.target.text.style=BOX
/bundle_defaults/org.eclipse.cdt.core/indexer/skipTypeReferences=false
/bundle_defaults/org.eclipse.cdt.ui/spelling_ignore_single_letters=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_after_opening_brace_in_array_initializer=do not insert
/bundle_defaults/org.eclipse.ui.ide/USE_MARKER_LIMITS=true
/bundle_defaults/org.eclipse.cdt.ui/c_braces=0,0,0
/bundle_defaults/com.crt.dsfdebug/bkptLocationFix=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/iperf_server.com.crt.advproject.projecttype.exe.1230739403/com.crt.advproject.config.exe.release.2134859713=com.crt.advproject.link.exe.release.1606298999\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.62265057\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1779487827\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.1452087926\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.2076973193\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.997436927\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/com.crt.debugcommon/debuggerName=arm-none-eabi-gdb
/bundle_defaults/org.eclipse.ui.workbench/EDITOR_TAB_WIDTH=3
/bundle_defaults/org.eclipse.cdt.ui/spelling_proposal_threshold=20
/bundle_defaults/org.eclipse.ui.ide/REFRESH_WORKSPACE_ON_STARTUP=false
@org.eclipse.ui.ide=3.10.1.v20140828-0944
/bundle_defaults/org.eclipse.ui/SHOW_TEXT_ON_PERSPECTIVE_BAR=true
/bundle_defaults/com.crt.debugcommon/showProgressInLog=false
/bundle_defaults/org.eclipse.cdt.ui/c_braces_italic=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_CORE_LPC17xx.com.crt.advproject.projecttype.lib.1132436677/com.crt.advproject.config.lib.debug.1991456843=com.crt.advproject.config.lib.debug.1991456843\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.1915179100\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.1423951452\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.1609401827\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.1973900125\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.1584584498\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.typedef.italic=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_CORE_LPC1102.com.crt.advproject.projecttype.lib.2134065871/com.crt.advproject.config.lib.debug.1171384745=com.crt.advproject.cpp.lib.debug.111687239\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.1229796127\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.1171384745\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.239783651\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.1219334096\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.1976020487\=rebuildState\\\=false\\r\\n\r\n
/instance/org.eclipse.cdt.managedbuilder.core/properties/LPCXpresso176x_timer.com.crt.advproject.projecttype.exe.1447070015/com.crt.advproject.config.exe.debug.1115091451=com.crt.advproject.gas.exe.debug.1691739915\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1083863975\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.922664229.1499417384\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.160123065\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1471583358\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1488813715\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1115091451.src/cr_startup_lpc176x.c\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.config.exe.debug.1115091451\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.922664229\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariableDeclaration.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticMethod.color=0,0,0
/instance/org.eclipse.cdt.core.prj-periph_blinky/indexer/preferenceScope=0
/bundle_defaults/com.crt.utils/showWelcomeView=true
/bundle_defaults/org.eclipse.ui/disableNewFastView=false
/bundle_defaults/org.eclipse.ui.editors/isFilteredSearchResultGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.ui/c_string_bold=false
/bundle_defaults/org.eclipse.ui.editors/useAnnotationsPrefPage=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_rtc.com.crt.advproject.projecttype.exe.605406851/com.crt.advproject.config.exe.debug.1144910716=com.crt.advproject.gas.exe.debug.1572169051\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.1573714766\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1144910716\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1005180494\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.962599421\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.2066055257\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1964125179\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariableDeclaration.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.typedef.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.parameterVariable.strikethrough=false
/bundle_defaults/com.crt.debugcommon/genericParameter=-wire\=winUSB
/bundle_defaults/com.crt.debugcommon/genericVID=8137
/instance/org.eclipse.cdt.managedbuilder.core/properties/LPCXpresso1768_systick.com.crt.advproject.projecttype.exe.783271606/com.crt.advproject.config.exe.release.591890536=com.crt.advproject.link.exe.release.2066767215\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.784804749\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.762673705\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.723349040\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1011426480\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.724136925\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_expressions_in_array_initializer=16
/bundle_defaults/org.eclipse.debug.core/org.eclipse.debug.core.USE_STEP_FILTERS=false
/bundle_defaults/org.eclipse.cdt.ui/org.eclipse.cdt.ui.editor.UseStructuralMode=false
/bundle_defaults/org.eclipse.ui.workbench/MULTI_KEY_ASSIST=true
/bundle_defaults/org.eclipse.cdt.ui/c_keyword=127,0,85
/bundle_defaults/org.eclipse.ui.editors/linked.exit.overviewruler=false
/bundle_defaults/com.crt.utils/commandPrompt=cmd.exe /C start
/bundle_defaults/org.eclipse.cdt.ui/content_assist_autoactivation_trigger_dot=true
/instance/org.eclipse.cdt.ui.prj-periph_blinky/buildConsole/keepLog=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_assignment=16
/bundle_defaults/org.eclipse.ui.editors/revisionRulerShowAuthor=false
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleOutputStreamColor=0,0,0
/bundle_defaults/org.eclipse.ui.editors/deletionIndicationColor=0,0,0
/bundle_defaults/org.eclipse.debug.ui/org.eclispe.debug.ui.memory.pageSize=20
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.field.underline=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.code_formatter=org.eclipse.cdt.core.defaultCodeFormatter
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.getter.wordDelimiter=
/bundle_defaults/org.eclipse.ui.editors/linked.slave.verticalruler=false
/bundle_defaults/org.eclipse.ui.workbench/EDITORLIST_SORT_CRITERIA=0
/bundle_defaults/org.eclipse.ui/ENABLE_MIN_MAX=true
/bundle_defaults/org.eclipse.ui.editors/additionIndicationInVerticalRuler=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_rtc.com.crt.advproject.projecttype.exe.605406851/com.crt.advproject.config.exe.release.2026987447=com.crt.advproject.link.cpp.exe.release.549761656\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1521143880\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.836740799\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1650596216\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1059462876\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.825377008\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_colon_in_case=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_while=do not insert
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.matchingPattern=
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_angle_bracket_in_template_arguments=do not insert
/bundle_defaults/org.eclipse.ui.editors/searchResultTextStyle=NONE
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.occurrenceIndicationInVerticalRuler=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/lpc_chip_175x_6x.com.crt.advproject.projecttype.lib.1977998334/com.crt.advproject.config.lib.debug.1264058482=com.crt.advproject.toolchain.lib.debug.593853259\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.1317359937\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.1653831520\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.1264058482\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.1864839615\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.756466351\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/bookmarkIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Color.SelectionForeground.SystemDefault=true
/bundle_defaults/org.eclipse.ui.editors/taskIndicationInOverviewRuler=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/usbd_lib_cdc.com.crt.advproject.projecttype.exe.218798441/com.crt.advproject.config.exe.debug.1792480862=com.crt.advproject.cpp.exe.debug.316691243\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1390072318\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.336376765\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.1082991463\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1302775373\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1792480862\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1330040580\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.core/includes.beginExportsPattern=IWYU\\s+(pragma\:?\\s+)?begin_exports?
/bundle_defaults/org.eclipse.ui.workbench/REUSE_OPEN_EDITORS_BOOLEAN=false
/bundle_defaults/com.crt.debugcommon/redlink_showTimestamps=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_compact_if=16
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_cast=do not insert
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_CORE_LPC11xx.com.crt.advproject.projecttype.lib.663819903/com.crt.advproject.config.lib.debug.1575154836=com.crt.advproject.config.lib.debug.1575154836\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.1921248460\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.483294928\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.224538997\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.1059437607\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.2095482798\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/com.crt.debugcommon/probe_use_old=true
/bundle_defaults/org.eclipse.debug.ui/org.eclispe.debug.ui.memory.postBufferSize=20
/bundle_defaults/org.eclipse.cdt.core/scalability.maximumTokens=25000000
/instance/org.eclipse.cdt.ui/spelling_locale_initialized=true
/bundle_defaults/org.eclipse.ui.editors/taskIndicationColor=0,128,255
/instance/org.eclipse.ui.ide/quickStart=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.remove_breakpoints_from_container_prompt=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticField.enabled=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_colon_in_labeled_statement=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_catch=do not insert
/bundle_defaults/org.eclipse.ui.editors/infoIndicationHighlighting=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.warning.color=255,255,0
/bundle_defaults/org.eclipse.cdt.ui/pp_default=0,0,0
/bundle_defaults/org.eclipse.ui.editors/showUnchangedInNextPrevDropdownToolbarAction=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/LPCXpresso1768_systick_twinkle.com.crt.advproject.projecttype.exe.2094231798/com.crt.advproject.config.exe.release.116571318=com.crt.advproject.link.cpp.exe.release.1527474121\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.26164475\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1526285554\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1124414934\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.2032773937\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1519254681\=rebuildState\\\=true\\r\\n\r\n
/instance/org.eclipse.cdt.managedbuilder.core/properties/ucos_iii_blinky.com.crt.advproject.projecttype.exe.113910480/com.crt.advproject.config.exe.debug.1728897436=com.crt.advproject.link.cpp.exe.debug.39638239\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1728897436\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1483790199\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1570489508\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1408003178\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.35123696\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1988230386\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_before_colon_in_constructor_initializer_list=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_enumerator_list=48
/bundle_defaults/org.eclipse.ui.editors/isBreakpointIndicationGoToNextNavigationTarget=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/usbd_lib_cdc_uart.com.crt.advproject.projecttype.exe.1798150368/com.crt.advproject.config.exe.release.1739015961=com.crt.advproject.toolchain.exe.release.140139306\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1080565756\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1212717813\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.271070702\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.182351402\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.875397863\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.workbench/overridepresentation=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.showoverrideIndicatorInNextPrevDropdownToolbarAction=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_colon_in_base_clause=do not insert
/bundle_defaults/org.eclipse.cdt.ui/hoverModifierMasks=org.eclipse.cdt.ui.BestMatchHover;0;org.eclipse.cdt.ui.CSourceHover;131072
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroDefinition.bold=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroSubstitution.enabled=false
/bundle_defaults/org.eclipse.cdt.ui/c_comment_task_tag_italic=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_semicolon_in_for=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_template_arguments=do not insert
/bundle_defaults/org.eclipse.cdt.dsf.gdb/defaultGdbCommand=gdb
/bundle_defaults/org.eclipse.cdt.codan.core/inEditor=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_blinky.com.crt.advproject.projecttype.exe.424940172/com.crt.advproject.config.exe.debug.320861772=com.crt.advproject.link.cpp.exe.debug.687245962\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.823968430\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.406618380\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1748761643\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.320861772\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1200583274\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1441851293\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/class_member_ascending_visibility_order=false
/bundle_defaults/org.eclipse.cdt.ui/sourceHoverBackgroundColor.SystemDefault=true
/bundle_defaults/org.eclipse.ui.editors/searchResultIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/linked.target.text=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.isOverrideIndicatorGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.ui/SHOW_TRADITIONAL_STYLE_TABS=true
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.UseOutlineView=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.RemoveFromLaunchHistory=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.method.color=0,0,0
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk.scheduler/showUpdateWizard=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.header.prefix=
/bundle_defaults/com.crt.advproject/createlinkerscript=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.LaunchParentProject=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.overloadedOperator.color=200,100,0
/bundle_defaults/org.eclipse.cdt.ui/Refactor.lightweight=true
/bundle_defaults/org.eclipse.debug.ui/Console.limitConsoleOutput=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_method_declaration=do not insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariable.enabled=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/LPCXpresso1768_systick_twinkle.com.crt.advproject.projecttype.exe.2094231798/com.crt.advproject.config.exe.debug.1700699240=org.eclipse.cdt.managedbuilder.ui.rcbs.1179417422\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.726819074\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1215601901\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.557441015\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1188391701\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1700699240.1872544513\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1543468204\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1700699240\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1215601901.1916540435\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.2118247634\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/spacesForTabs=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_after_template_declaration=do not insert
/bundle_defaults/org.eclipse.ui.editors/linked.target.overviewruler=false
/bundle_defaults/org.eclipse.ui.editors/deletionIndicationInOverviewRuler=false
/bundle_defaults/org.eclipse.ui.editors/linked.exit.text=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariableDeclaration.bold=false
/bundle_defaults/org.eclipse.ui.editors/bookmarkTextStyle=SQUIGGLES
/bundle_defaults/org.eclipse.core.resources/snapshots.operations=100
/bundle_defaults/org.eclipse.ui.editors/bookmarkIndication=false
/bundle_defaults/org.eclipse.ui.editors/indexResultIndicationColor=254,155,0
/bundle_defaults/org.eclipse.cdt.codan.core/onBuild=false
/bundle_defaults/org.eclipse.cdt.ui/closeAngularBrackets=true
/bundle_defaults/org.eclipse.cdt.ui/consoleOnTop=false
/bundle_defaults/org.eclipse.ui.editors/termin=110,220,110
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_watchdog.com.crt.advproject.projecttype.exe.720126098/com.crt.advproject.config.exe.release.1738151752=com.crt.advproject.cpp.exe.release.1487373402\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.417315122\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1915328161\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1683719605\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1429431212\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1097649050\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/breakpointIndicationColor=0,0,255
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_postfix_operator=do not insert
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_systick.com.crt.advproject.projecttype.exe.349735055/com.crt.advproject.config.exe.debug.1708114495=com.crt.advproject.gas.exe.debug.1510048182\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.470430945\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.1179205170\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1099851258\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1708114495\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.636559943\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.2110503964\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.dsf.gdb/maxGdbTraces=500000
/bundle_defaults/org.eclipse.cdt.ui/inactiveCodeColor=224,224,224
/instance/org.eclipse.cdt.managedbuilder.core/properties/lpcusblib_KeyboardHost.com.crt.advproject.projecttype.exe.1776494588/com.crt.advproject.config.exe.release.675946607=com.crt.advproject.cpp.exe.release.1593360022\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1250332176\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.6763122\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1816566527\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1063855647\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1543449802\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticMethod.strikethrough=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_constructor_initializer_list=0
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.method.strikethrough=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_CORE_LPC11xxLV.com.crt.advproject.projecttype.lib.1331552380/com.crt.advproject.config.lib.debug.1498659410=com.crt.advproject.gas.lib.debug.205943174\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.1476934997\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.1658191416\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.1000541325\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.1498659410\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.182558187\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/com.crt.debugcommon/genericEnabled=false
/instance/org.eclipse.cdt.core.prj-CMSISv2p00_LPC17xx/indexer/preferenceScope=0
/bundle_defaults/org.eclipse.cdt.core/scalability.skipTrivialExpressions=true
/bundle_defaults/org.eclipse.cdt.ui/handleTemporaryProblems=true
/bundle_defaults/org.eclipse.cdt.ui/c_single_line_comment=63,127,95
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.memory.columnSize=4
/bundle_defaults/com.crt.debugcommon/serverPort=0
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.warning.ruler=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/lpc_board_nxp_lpcxpresso_1769.com.crt.advproject.projecttype.lib.1078462419/com.crt.advproject.config.lib.debug.267437161=com.crt.advproject.gcc.lib.debug.1874917562\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.224156237\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.787516598\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.1176373407\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.267437161\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.486889114\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/linked.exit.highlight=false
/bundle_defaults/org.eclipse.cdt.ui/c_comment_task_tag=127,159,191
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroSubstitution.color=0,0,0
/bundle_defaults/org.eclipse.ui.editors/showChangeInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_angle_bracket_in_template_parameters=do not insert
/bundle_defaults/org.eclipse.cdt.ui/c_type=127,0,85
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticMethod.underline=false
/bundle_defaults/com.crt.dsfdebug/altRefreshBehavior=true
/bundle_defaults/org.eclipse.ui.editors/warningIndication=true
/bundle_defaults/org.eclipse.ui.workbench/EDITORLIST_PULLDOWN_ACTIVE=false
/bundle_defaults/org.eclipse.core.net/proxiesEnabled=true
/bundle_defaults/org.eclipse.ui.workbench/STICKY_CYCLE=false
/bundle_defaults/org.eclipse.cdt.ui/c_numbers_italic=false
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleLines=500
/bundle_defaults/org.eclipse.ui.workbench/SELECT_ON_HOVER=false
/bundle_defaults/org.eclipse.ui.editors/revisionAnnotationIndicationInVerticalRuler=false
/bundle_defaults/org.eclipse.ui.editors/linked.exit.navigation.dropdown=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_method_invocation=do not insert
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Color.Foreground.SystemDefault=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.label.italic=false
/bundle_defaults/com.crt.debugcommon/relink_dfu_find=true
/bundle_defaults/org.eclipse.cdt.dsf.gdb/defaultStopAtMainSymbol=main
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.format_guardian_clause_on_one_line=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_base_clause_in_type_declaration=80
/bundle_defaults/org.eclipse.ui.editors/linked.slave.navigation.previous=false
/bundle_defaults/org.eclipse.ui.editors/isAdditionGoToPreviousNavigationTarget=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/RDB1768cmsis_EasyWeb.com.crt.advproject.projecttype.exe.1503643990/com.crt.advproject.config.exe.debug.1095747236=com.crt.advproject.gcc.exe.debug.583453200.830262054\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.784245429\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1095747236\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.583453200\=rebuildState\\\=false\\r\\n\r\norg.eclipse.cdt.managedbuilder.ui.rcbs.409250964\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.debug.237846413\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.181471\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1617126296\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.2070344148\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1095747236.934195708\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.warning.NextPrevDropdownToolbar=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_conditional_expression_chain=18
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.writeOccurrenceTextStyle=NONE
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.OpenStructureCompare=true
/bundle_defaults/org.eclipse.ui.editors/errorIndicationColor=255,0,128
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_default_macros=false
/bundle_defaults/org.eclipse.ui.workbench/OPEN_AFTER_DELAY=false
/bundle_defaults/org.eclipse.debug.core/org.eclipse.debug.core.PREF_DELETE_CONFIGS_ON_PROJECT_DELETE=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.constant.suffix=
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_member_access=0
/bundle_defaults/com.crt.utils/showVerboseErrors=true
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.setter.capitalization=3
/bundle_defaults/org.eclipse.cdt.core/indexer/skipIncludedFilesLargerThanMB=16
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.parameterVariable.color=0,0,0
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_expression_list=0
/bundle_defaults/org.eclipse.ui.editors/isInfoGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/unchangedIndicationInOverviewRuler=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariable.underline=false
/bundle_defaults/org.eclipse.ui.editors/linked.slave.text.style=NONE
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_pmu.com.crt.advproject.projecttype.exe.1242046794/com.crt.advproject.config.exe.release.389189387=com.crt.advproject.toolchain.exe.release.978190380\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1470029090\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.1578400653\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1415685171\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1480216083\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1728937052\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.warning.GoToNextNavigationTarget=true
/profile/file\:\\2fC\:\\2fnxp\\2fLPCXpresso_7.6.2_326\\2flpcxpresso\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.ui.sdk.scheduler/autoUpdateInit=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.typedef.bold=false
/bundle_defaults/org.eclipse.cdt.core/indexer/skipFilesLargerThanMB=8
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_CORE_LPC12xx.com.crt.advproject.projecttype.lib.2046742754/com.crt.advproject.config.lib.debug.1869600139=com.crt.advproject.ar.lib.debug.2046574041\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.1869600139\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.1067127894\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.1038768540\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.26316877\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.223437482\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/warningTextStyle=PROBLEM_UNDERLINE
/bundle_defaults/org.eclipse.ui.editors/secondaryIPColor=219,235,204
/bundle_defaults/org.eclipse.cdt.ui/content_assist_autoactivation_trigger_doublecolon=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.field.enabled=true
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.getter.prefixForBoolean=is
/bundle_defaults/org.eclipse.ui.editors/showWarningInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.ui.editors/breakpointVerticalRuler=true
/bundle_defaults/org.eclipse.cdt.dsf.gdb/org.eclipse.cdt.dsf.gdb.commandTimeout=false
/instance/org.eclipse.debug.ui/preferredTargets=org.eclipse.cdt.debug.ui.toggleCBreakpointTarget,org.eclipse.cdt.debug.ui.toggleCDynamicPrintfTarget\:org.eclipse.cdt.debug.ui.toggleCBreakpointTarget|
/bundle_defaults/org.eclipse.cdt.ui/closeBraces=true
/bundle_defaults/org.eclipse.ui.editors/isWarningGoToPreviousNavigationTarget=true
/bundle_defaults/org.eclipse.cdt.ui/c_operators_bold=false
/bundle_defaults/com.crt.utils/quickstart.navlink=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.field.bold=false
/bundle_defaults/org.eclipse.ui.editors/showBookmarkInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.startAddress=0
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_body_declarations_compare_to_namespace_header=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_cast=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_between_empty_parens_in_exception_specification=do not insert
/bundle_defaults/org.eclipse.ui.workbench/HeapStatus.updateInterval=500
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_LPC43xx_DriverLib-M0.com.crt.advproject.projecttype.lib.1313392389/com.crt.advproject.config.lib.debug.489607714=com.crt.advproject.cpp.lib.debug.1400584359\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.1662940542\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.173058116\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.2039253860\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.1035256333\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.489607714\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.debug.core/org.eclipse.cdt.debug.corecDebug.character_set=UTF-16
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.showOccurrenceInNextPrevDropdownToolbarAction=true
/bundle_defaults/com.crt.debugcommon/swvPacketTimeout=0
/bundle_defaults/org.eclipse.cdt.core/indexer/indexUnusedHeadersWithAlternateLang=false
/bundle_defaults/org.eclipse.ui.editors/spellingIndicationColor=255,128,64
/bundle_defaults/org.eclipse.core.resources/description.maxfilestatesize=1048576
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.continuation_indentation=2
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Color.FindScope=185,176,180
/bundle_defaults/org.eclipse.ui.editors/isChangeGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/additionIndicationInOverviewRuler=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.globalVariable.color=0,0,0
/bundle_defaults/org.eclipse.cdt.core/scalability.maximumTrivialExpressions=1000
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.show_run_perspective_default=perspective_none
/bundle_defaults/org.eclipse.cdt.ui/organizeIncludes.allowReordering=true
/bundle_defaults/org.eclipse.ui.editors/isErrorGoToNextNavigationTarget=true
/bundle_defaults/com.crt.debugcommon/driver_settle=30
/bundle_defaults/com.crt.utils/crt.diagnostics=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.occurrenceIndication=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_expression_list=do not insert
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.getter.capitalization=3
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_template_parameters=insert
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.error.GoToPreviousNavigationTarget=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_switch=insert
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.remove_all_breakpoints_prompt=true
/bundle_defaults/org.eclipse.cdt.ui/spelling_user_dictionary_encoding=Cp1254
/bundle_defaults/com.crt.debugcommon/extendedLogging=false
/bundle_defaults/org.eclipse.ui/PROMPT_WHEN_SAVEABLE_STILL_OPEN=true
/bundle_defaults/com.crt.dsfdebug/altLabelProvider=false
/bundle_defaults/org.eclipse.ui.editors/useQuickDiffPrefPage=false
/bundle_defaults/org.eclipse.ui.ide/LIMIT_PROBLEMS=true
/bundle_defaults/org.eclipse.ui.editors/linked.focus.highlight=false
/bundle_defaults/org.eclipse.cdt.ui/c_single_line_comment_bold=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_method_declaration_throws=insert
/bundle_defaults/org.eclipse.cdt.ui/content_assist_proposal_filter=0;<Default Filter>
/bundle_defaults/com.crt.dsfdebug/altTerminate=false
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.showAddressRadix=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.problem.underline=false
/bundle_defaults/org.eclipse.cdt.ui/function_pass_output_parameters_by_pointer=false
/bundle_defaults/org.eclipse.ui.workbench/ENABLE_CONFIGURABLE_PROJECT_WIZARD=false
/bundle_defaults/org.eclipse.debug.ui/Expressions.detail.orientation=Variables.detail.orientation.underneath
/bundle_defaults/org.eclipse.ui.workbench/EDITORLIST_DISPLAY_FULL_NAME=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.PREF_FILTER_WORKING_SETS=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.function.italic=false
/bundle_defaults/com.crt.config/urlBase=
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticField.italic=true
/instance/org.eclipse.cdt.core.prj-LPCX176x_cmsis2_timers/indexer/preferenceScope=0
@org.eclipse.core.resources=3.9.1.v20140825-1431
/bundle_defaults/org.eclipse.cdt.debug.core/org.eclipse.cdt.debug.corecDebug.non_wide_character_set=windows-1254
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.InitiallyShowAncestorPane=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_statements_compare_to_body=true
/bundle_defaults/org.eclipse.cdt.core/build.proj.ref.configs.enabled=false
/bundle_defaults/org.eclipse.cdt.ui/codetemplates.includeGuardGenerationScheme=2
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.method.suffix=
/bundle_defaults/org.eclipse.ui.editors/com.crt.etmetb.marker.profile.pref.text=true
/bundle_defaults/org.eclipse.ui.workbench/WORKBENCH_SAVE_INTERVAL=5
/bundle_defaults/org.eclipse.ui.editors/spellingIndicationInOverviewRuler=false
/bundle_defaults/com.crt.dsfdebug/arrayChunkSize=100
/bundle_defaults/org.eclipse.ui.ide/BOOKMARKS_FILTERS_MIGRATE=false
/bundle_defaults/org.eclipse.ui.editors/taskIndication=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_method_declaration=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_if=do not insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.class.bold=false
/bundle_defaults/org.eclipse.ui.editors/changeIndicationColor=204,163,205
/bundle_defaults/org.eclipse.ui.editors/linked.target.highlight=false
/bundle_defaults/org.eclipse.ui.workbench/BIDI_SUPPORT=false
/bundle_defaults/org.eclipse.cdt.ui/asm_directive_bold=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticField.color=0,0,192
/bundle_defaults/org.eclipse.ui.editors/linked.focus.navigation.next=false
/bundle_defaults/org.eclipse.ui.editors/isInfoGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_exception_specification=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_expression_list=insert
/bundle_defaults/org.eclipse.ui.editors/revisionRulerRenderingMode=Age
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_switch=end_of_line
/bundle_defaults/org.eclipse.cdt.ui/content_assist_project_search_scope=false
@org.eclipse.ui.editors=3.8.200.v20140401-1310
/bundle_defaults/org.eclipse.cdt.ui/Refactoring.savealleditors=false
/bundle_defaults/org.eclipse.ui.ide/TASKS_LIMIT=100
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.externalSDK.underline=false
/bundle_defaults/org.eclipse.ui.editors/additionIndication=false
/bundle_defaults/org.eclipse.cdt.ui/c_type_bold=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_overloaded_left_shift_chain=16
/bundle_defaults/org.eclipse.cdt.ui/closeBrackets=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.MemoryHistoryUnknownColor=114,119,129
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_pinint.com.crt.advproject.projecttype.exe.500409353/com.crt.advproject.config.exe.release.809780712=com.crt.advproject.gcc.exe.release.607726278\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1281540969\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1043201516\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1771186119\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.590733964\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.2046459755\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.ide/useSeparator.help.group.updates=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/freertos_blinky.com.crt.advproject.projecttype.exe.1693076455/com.crt.advproject.config.exe.release.514344055=com.crt.advproject.cpp.exe.release.596333881\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1233252549\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.572949477\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1942620602\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1909829756\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1745362883\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/pp_directive=127,0,85
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.externalSDK.strikethrough=false
/instance/org.eclipse.ui.ide/PROBLEMS_FILTERS_MIGRATE=true
/bundle_defaults/com.crt.debugcommon/Redlink\ Server=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_assignment_operator=insert
/bundle_defaults/org.eclipse.ui.editors/isTaskGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.dsf.gdb/useInspectorHover=true
/bundle_defaults/com.crt.advproject/addchipdescriptions=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_between_empty_brackets=do not insert
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.track_views=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/lwip_tcpecho_freertos.com.crt.advproject.projecttype.exe.1420589482/com.crt.advproject.config.exe.release.1056112912=com.crt.advproject.cpp.exe.release.2063395937\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.572207940\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1638490324\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.288331770\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.738637504\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.792758414\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_for=insert
/instance/org.eclipse.ui.editors/overviewRuler_migration=migrated_3.1
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.showSourceFilesInBinaries=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_block_in_case=end_of_line
/instance/org.eclipse.cdt.managedbuilder.core/properties/lpcusblib_MassStorageHost.com.crt.advproject.projecttype.exe.71920452/com.crt.advproject.config.exe.release.602528808=com.crt.advproject.toolchain.exe.release.1566228802\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1136674319\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.60566226\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1225949085\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.213504139\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.143744362\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/com.crt.advproject/linkscriptdir=linkscripts
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.methodDeclaration.bold=true
/bundle_defaults/org.eclipse.ui.editors/errorIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/revisionAnnotationIndication=false
@org.eclipse.cdt.debug.core=7.5.0.201409172108
/bundle_defaults/org.eclipse.ui.editors/linked.target.navigation.previous=false
/bundle_defaults/org.eclipse.cdt.dsf.gdb/enablePrettyPrinting=true
/bundle_defaults/org.eclipse.core.resources/encoding=
/bundle_defaults/org.eclipse.ui.editors/unchangedIndication=false
/bundle_defaults/org.eclipse.core.resources/description.disableLinking=false
/bundle_defaults/org.eclipse.cdt.ui/forwardDeclare.functions=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_array_initializer=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_type_declaration=insert
/bundle_defaults/org.eclipse.ui.editors/tabWidth=4
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk/allowNonOKPlan=prompt
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_adc.com.crt.advproject.projecttype.exe.1322797204/com.crt.advproject.config.exe.release.1946989772=com.crt.advproject.gcc.exe.release.48021137\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.914124013\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.895665888\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.766485705\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1473272062\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.879936560\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Accessibility.WideCaret=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.problem.bold=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_access_specifier_compare_to_type_header=false
/bundle_defaults/com.crt.debugcommon/LPC-Link\ (HID)=true
file_export_version=3.0
/bundle_defaults/org.eclipse.cdt.core/includes.privatePattern=IWYU\\s+(pragma\:?\\s+)?private(,\\s+include\\s+(?<header>\\S+))?
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.inOtherProject=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style angle_brackets\="false" blank_line_before\="false" keep_together\="false" relative_path\="false"/>
/bundle_defaults/org.eclipse.ui.editors/linked.exit.text.style=IBEAM
/bundle_defaults/org.eclipse.cdt.ui/pp_directive_italic=false
/bundle_defaults/org.eclipse.cdt.ui/wizard.group.others.enable=true
/bundle_defaults/org.eclipse.ui.editors/isBreakpointIndicationGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariableDeclaration.color=128,0,0
/instance/org.eclipse.debug.core//org.eclipse.debug.core.PREFERRED_DELEGATES/org.eclipse.cdt.launch.attachLaunchType=org.eclipse.cdt.dsf.gdb.launch.attachCLaunch,debug,;
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.VariableView+org.eclipse.debug.ui.ShowTypeNamesAction=false
/bundle_defaults/org.eclipse.ui/OPEN_NEW_PERSPECTIVE=OPEN_PERSPECTIVE_REPLACE
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.problem.enabled=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_CORE_LPC13xx.com.crt.advproject.projecttype.lib.1385448813/com.crt.advproject.config.lib.debug.581745906=com.crt.advproject.ar.lib.debug.1292774045\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.1574829665\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.612994528\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.581745906\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.717048448\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.941307039\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_parenthesized_expression=do not insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.globalVariable.strikethrough=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.defaultEbcdicCodePage=CP037
/bundle_defaults/org.eclipse.ui.editors/secondaryIPVerticalRuler=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_clkout.com.crt.advproject.projecttype.exe.1523737329/com.crt.advproject.config.exe.debug.180527154=com.crt.advproject.link.exe.debug.1821395612\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.1745459261\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1708288974\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.556507730\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.180527154\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1687012010\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.2092012931\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/othersIndication=false
/bundle_defaults/com.crt.debugcommon/redlink_ask_to_boot=false
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.addressRadix=16
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indentation.size=4
/bundle_defaults/org.eclipse.cdt.ui/c_multi_line_comment_bold=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.constant.prefix=
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticMethod.bold=false
/bundle_defaults/org.eclipse.cdt.core/indexer/indexUnusedHeadersWithDefaultLang=true
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.opcodeRadix=16
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_block=insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enumerator.underline=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_spi.com.crt.advproject.projecttype.exe.1116578252/com.crt.advproject.config.exe.release.148649193=com.crt.advproject.link.cpp.exe.release.1766850755\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1024407775\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.503899537\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.575180509\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.38522315\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.922314565\=rebuildState\\\=true\\r\\n\r\n
/configuration/org.eclipse.ui.ide/MAX_RECENT_WORKSPACES=5
/bundle_defaults/org.eclipse.ui.editors/showDeletionInNextPrevDropdownToolbarAction=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.switch_to_perspective=never
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_CORE_LPC11Axx.com.crt.advproject.projecttype.lib.323077590/com.crt.advproject.config.lib.debug.155024037=com.crt.advproject.ar.lib.debug.619333461\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.479237615\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.155024037\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.453650134\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.143674930\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.130954740\=rebuildState\\\=false\\r\\n\r\n
/instance/org.eclipse.ui.workbench/UIActivities.org.eclipse.cdt.debug.dsfgdbActivity=true
/bundle_defaults/org.eclipse.ui.workbench/NL_EXTENSIONS=
/bundle_defaults/org.eclipse.core.net/proxyData/SOCKS/hasAuth=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.methodDeclaration.color=0,0,0
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.globalVariable.underline=false
/bundle_defaults/org.eclipse.cdt.core/indexer/skipMacroReferences=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.function.color=0,0,0
/bundle_defaults/org.eclipse.ui.editors/isRevisionAnnotationGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.core.net/systemProxiesEnabled=true
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.ShowPseudoConflicts=false
/bundle_defaults/org.eclipse.cdt.ui/c_default_italic=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.keep_then_statement_on_same_line=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_switch=do not insert
/bundle_defaults/org.eclipse.cdt.ui/org.eclipse.cdt.internal.ui.text.doctools.doxygen.single=63,95,191
/instance/org.eclipse.cdt.managedbuilder.core/properties/ucos_iii_blinky.com.crt.advproject.projecttype.exe.113910480/com.crt.advproject.config.exe.release.1706971613=com.crt.advproject.toolchain.exe.release.2108839201\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.848952791\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.513168767\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1970360558\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.135113262\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1079269625\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.parameterVariable.italic=false
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.showSource=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.isOccurrenceGoToPreviousNavigationTarget=false
/bundle_defaults/com.crt.quickstart/wizardTemplateSupport=true
/bundle_defaults/org.eclipse.cdt.ui/spelling_ignore_non_letters=true
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleBackgroundColor=255,255,255
/bundle_defaults/org.eclipse.ui.editors/linked.slave.text=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.writeOccurrenceIndicationInOverviewRuler=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/usbd_lib_composite.com.crt.advproject.projecttype.exe.2137007679/com.crt.advproject.config.exe.release.1869947099=com.crt.advproject.cpp.exe.release.1379756456\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1748461686\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1827532787\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.359222123\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.2090809526\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.393776227\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.workbench/DISABLE_OPEN_EDITOR_IN_PLACE=false
/bundle_defaults/org.eclipse.ui.editors/warningIndicationInVerticalRuler=true
/bundle_defaults/com.crt.quickstart/autpBrowseWeb=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.showSourceRootsAtTopLevelOfProject=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_in_empty_block=insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroSubstitution.bold=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.inColor=0,200,125
/bundle_defaults/org.eclipse.cdt.dsf.ui/stackFrameLimitEnable=true
/bundle_defaults/org.eclipse.ui.editors/revisionAnnotationIndicationColor=88,88,22
/bundle_defaults/com.crt.dsfdebug/attachRestart=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/usbd_lib_hid_generic.com.crt.advproject.projecttype.exe.1358948682/com.crt.advproject.config.exe.release.823668469=com.crt.advproject.toolchain.exe.release.1184916576\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.909534463\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1083649875\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.529656299\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.107267058\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.740681601\=rebuildState\\\=true\\r\\n\r\n
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES_PROTOCOL=3
/bundle_defaults/org.eclipse.cdt.ui/contentAssist.showCamelCaseMatches=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.keep_else_statement_on_same_line=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_method_invocation=do not insert
/bundle_defaults/org.eclipse.ui.editors/infoIndication=false
/bundle_defaults/org.eclipse.debug.ui/Variables.detail.orientation=Variables.detail.orientation.underneath
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enum.color=100,70,50
/bundle_defaults/com.crt.dsfdebug/extendedDebugTrace=0
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.parameterVariable.bold=false
/bundle_defaults/org.eclipse.ui.editors/textDragAndDropEnabled=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.methodDeclaration.underline=false
/bundle_defaults/org.eclipse.cdt.ui/c_single_line_comment_italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.namespace.bold=false
/profile/file\:\\2fC\:\\2fnxp\\2fLPCXpresso_7.6.2_326\\2flpcxpresso\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.ui.sdk/allowNonOKPlan=prompt
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.subfolder=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style angle_brackets\="false" blank_line_before\="false" keep_together\="false" relative_path\="false"/>
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.source.prefix=
/bundle_defaults/com.crt.advproject/library=newlib_nohost
/bundle_defaults/org.eclipse.ui.editors/whitespaceCharacterAlphaValue=80
/instance/org.eclipse.cdt.managedbuilder.core/properties/lpcusblib_MassStorageHost.com.crt.advproject.projecttype.exe.71920452/com.crt.advproject.config.exe.debug.1897601089=com.crt.advproject.gas.exe.debug.188816363\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1632082132\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.2136975254\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.641244994\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1837685795\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.1440619807\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1897601089\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/showSpellingInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.cdt.ui/spelling_ignore_urls=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_binary_operator=insert
/bundle_defaults/org.eclipse.ui.editors/showEnclosedTabs=true
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.test.suffix=_test.cpp
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.source.wordDelimiter=
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_default_headers=true
/bundle_defaults/org.eclipse.cdt.ui/c_operators=0,0,0
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Navigation.SmartHomeEnd=true
/bundle_defaults/org.eclipse.ui.editors/deletionIndication=false
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_default_methods=false
/bundle_defaults/org.eclipse.ui.editors/undoHistorySize=200
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.field.suffix=
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_parenthesized_expression=do not insert
/bundle_defaults/org.eclipse.debug.ui/Console.highWaterMark=100000
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_at_end_of_file_if_missing=do not insert
/bundle_defaults/org.eclipse.ui.editors/com.crt.etmetb.marker.profile.pref.overview=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_question_in_conditional=insert
/bundle_defaults/org.eclipse.ui.editors/currentIPIndication=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_colon_in_conditional=insert
/bundle_defaults/org.eclipse.cdt.debug.core/org.eclipse.cdt.debug.corecDebug.max_number_of_instructions=100
/bundle_defaults/org.eclipse.ui.workbench/MULTI_KEY_ASSIST_TIME=1000
/bundle_defaults/org.eclipse.cdt.ui/content_assist_autoactivation_trigger_arrow=true
/bundle_defaults/org.eclipse.cdt.ui/scalability.numberOfLines=5000
/bundle_defaults/org.eclipse.cdt.ui/organizeIncludes.unusedStatements=REMOVE
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_dac.com.crt.advproject.projecttype.exe.511991621/com.crt.advproject.config.exe.debug.1401400949=com.crt.advproject.link.cpp.exe.debug.691725567\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1614753469\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1401400949\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.645990063\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.571772906\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.574813121\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1661172651\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/c_keyword_bold=true
/bundle_defaults/org.eclipse.ui.workbench/OPEN_VIEW_MODE=0
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.globalVariable.enabled=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.field.wordDelimiter=
/bundle_defaults/org.eclipse.ui.editors/showTrailingTabs=true
/bundle_defaults/com.crt.config/vendor=NXP
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.method.prefix=
/bundle_defaults/com.crt.utils/spawnerTimeout=5000
/bundle_defaults/org.eclipse.ui.editors/othersIndicationColor=0,0,0
/bundle_defaults/com.crt.config/browser_internal=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.comment.preserve_white_space_between_code_and_line_comments=true
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.HighlightTokenChanges=true
@org.eclipse.cdt.managedbuilder.core=8.3.0.201409172108
/bundle_defaults/org.eclipse.cdt.ui/CEditor.ShowTemporaryProblem=false
/bundle_defaults/com.crt.debugcommon/genericStubMatch=.*
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_angle_bracket_in_template_parameters=do not insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.externalSDK.italic=false
/bundle_defaults/org.eclipse.ui.editors/currentLineColor=232,242,254
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_CORE_LPC177x_8x.com.crt.advproject.projecttype.lib.2013960403/com.crt.advproject.config.lib.debug.1827724080=com.crt.advproject.toolchain.lib.debug.2121956239\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.108587623\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.1569502926\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.1827724080\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.1646563063\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.1689288150\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_provider=org.eclipse.cdt.ui.text.defaultFoldingProvider
/bundle_defaults/com.crt.dsfdebug/complexExpressionBehavior=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_method_invocation_arguments=do not insert
/bundle_defaults/org.eclipse.ui.editors/currentIPOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/lineNumberColor=120,120,120
/bundle_defaults/org.eclipse.ui.ide/OPEN_REQUIRED_PROJECTS=prompt
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.class.enabled=true
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES=C\:\\Users\\Egitim5\\Documents\\LPCXpresso_7.6.2_326\\workspace
/bundle_defaults/org.eclipse.ui.editors/filteredSearchResultIndicationInOverviewRuler=false
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.SynchronizeScrolling=true
/bundle_defaults/org.eclipse.ui.editors/showBreakpointIndicationInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.cdt.ui/scalability.reconciler=true
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.variable.suffix=
/bundle_defaults/org.eclipse.ui.editors/isDeletionGoToPreviousNavigationTarget=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/usbd_lib_hid_mouse.com.crt.advproject.projecttype.exe.1164772426/com.crt.advproject.config.exe.debug.1247759680=com.crt.advproject.toolchain.exe.debug.1972215156\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.734843412\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1430832086\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1247759680\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.298929785\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.2016236950\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.2049096836\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/linked.focus.overviewruler=false
/bundle_defaults/org.eclipse.cdt.dsf.ui/minStepInterval=100
/bundle_defaults/org.eclipse.cdt.ui/ensureNewlineAtEOF=true
/bundle_defaults/org.eclipse.cdt.ui/c_multi_line_comment=63,127,95
/bundle_defaults/org.eclipse.ui/ENABLE_32_STICKY_CLOSE_BEHAVIOR=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.functionDeclaration.italic=false
/bundle_defaults/org.eclipse.cdt.ui/pp_directive_bold=true
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.method.capitalization=4
/bundle_defaults/org.eclipse.ui.ide/useSeparator.help.group.main=true
/bundle_defaults/org.eclipse.ui.ide/IMPORT_FILES_AND_FOLDERS_VIRTUAL_FOLDER_MODE=prompt
/bundle_defaults/org.eclipse.cdt.ui/scalability.contentAssistAutoActivation=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enumerator.bold=false
/bundle_defaults/org.eclipse.cdt.ui/smart_tab=true
/bundle_defaults/org.eclipse.ui.editors/infoIndicationInVerticalRuler=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_brace_in_array_initializer=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.tabulation.char=tab
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.globalVariable.bold=false
/instance/org.eclipse.cdt.core.prj-LPCX176x_cmsis2_EasyWeb/indexer/preferenceScope=0
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_dac.com.crt.advproject.projecttype.exe.511991621/com.crt.advproject.config.exe.release.319530200=com.crt.advproject.link.cpp.exe.release.1217990134\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1197744558\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1766615628\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.731175261\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1771472347\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.367199306\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/forwardDeclare.compositeTypes=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_method_declaration_throws=do not insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.globalVariable.italic=true
/bundle_defaults/org.eclipse.cdt.ui/clearConsole=true
/bundle_defaults/org.eclipse.ui.editors/linked.target.navigation.next=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_systick.com.crt.advproject.projecttype.exe.349735055/com.crt.advproject.config.exe.release.1432658484=com.crt.advproject.toolchain.exe.release.1075952010\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1242568218\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.264579604\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.60441288\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1322654774\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.236459667\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/content_assist_proposals_timeout=5000
/bundle_defaults/org.eclipse.ui/SHOW_FILTERED_TEXTS=true
/bundle_defaults/org.eclipse.ui.editors/show_range_indicator=true
*** Current Install Configuration:
Bundles in the system:
Id: com.crt.advproject, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.advproject_7.4.1.201502020932.jar
Id: com.crt.config, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.config_7.4.1.201502020932.jar
Id: com.crt.ctrlcenter, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.ctrlcenter_7.4.1.201502020932.jar
Id: com.crt.debugcommon, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.debugcommon_7.4.1.201502020932.jar
Id: com.crt.debugmgr, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.debugmgr_7.4.1.201502020932.jar
Id: com.crt.docs, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.docs_7.4.1.201502020932.jar
Id: com.crt.docs.rsguide, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.docs.rsguide_7.4.1.201502020932.jar
Id: com.crt.dsfdebug, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.dsfdebug_7.4.1.201502020932.jar
Id: com.crt.dsfswv, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.dsfswv_7.4.1.201502020932.jar
Id: com.crt.etmetb, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.etmetb_7.4.1.201502020932.jar
Id: com.crt.lite, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.lite_7.4.1.201502020932.jar
Id: com.crt.lpcxpresso.brand, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.lpcxpresso.brand_7.4.1.201502020932.jar
Id: com.crt.quickstart, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.quickstart_7.4.1.201502020932.jar
Id: com.crt.redstate, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.redstate_7.4.1.201502020932.jar
Id: com.crt.utils, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.utils_7.4.1.201502020932.jar
Id: com.crt.vendor.arm.generic, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.vendor.arm.generic_7.4.1.201502020932.jar
Id: com.crt.vendor.nxp.a7, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.vendor.nxp.a7_7.4.1.201502020932.jar
Id: com.crt.vendor.nxp.generic, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.vendor.nxp.generic_7.4.1.201502020932.jar
Id: com.crt.vendor.nxp.lpc11, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.vendor.nxp.lpc11_7.4.1.201502020932.jar
Id: com.crt.vendor.nxp.lpc13, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.vendor.nxp.lpc13_7.4.1.201502020932.jar
Id: com.crt.vendor.nxp.lpc17, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.vendor.nxp.lpc17_7.4.1.201502020932.jar
Id: com.crt.vendor.nxp.lpc18, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.vendor.nxp.lpc18_7.4.1.201502020932.jar
Id: com.crt.vendor.nxp.lpc29, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.vendor.nxp.lpc29_7.4.1.201502020932.jar
Id: com.crt.vendor.nxp.lpc31, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.vendor.nxp.lpc31_7.4.1.201502020932.jar
Id: com.crt.vendor.nxp.lpc43, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.vendor.nxp.lpc43_7.4.1.201502020932.jar
Id: com.crt.vendor.nxp.niobe, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.vendor.nxp.niobe_7.4.1.201502020932.jar
Id: com.ibm.icu, Version: 52.1.0.v201404241930, Location: reference:file:plugins/com.ibm.icu_52.1.0.v201404241930.jar
Id: com.jcraft.jsch, Version: 0.1.50.v201403120620, Location: reference:file:plugins/com.jcraft.jsch_0.1.50.v201403120620.jar
Id: com.nxp.gnudocs, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.nxp.gnudocs_7.4.1.201502020932.jar
Id: com.nxp.symbolbrowser, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.nxp.symbolbrowser_7.4.1.201502020932.jar
Id: com.sun.el, Version: 2.2.0.v201303151357, Location: reference:file:plugins/com.sun.el_2.2.0.v201303151357.jar
Id: javax.annotation, Version: 1.2.0.v201401042248, Location: reference:file:plugins/javax.annotation_1.2.0.v201401042248.jar
Id: javax.el, Version: 2.2.0.v201303151357, Location: reference:file:plugins/javax.el_2.2.0.v201303151357.jar
Id: javax.inject, Version: 1.0.0.v20091030, Location: reference:file:plugins/javax.inject_1.0.0.v20091030.jar
Id: javax.servlet, Version: 3.0.0.v201112011016, Location: reference:file:plugins/javax.servlet_3.0.0.v201112011016.jar
Id: javax.servlet.jsp, Version: 2.2.0.v201112011158, Location: reference:file:plugins/javax.servlet.jsp_2.2.0.v201112011158.jar
Id: javax.xml, Version: 1.3.4.v201005080400, Location: reference:file:plugins/javax.xml_1.3.4.v201005080400.jar
Id: org.apache.ant, Version: 1.9.2.v201404171502, Location: reference:file:plugins/org.apache.ant_1.9.2.v201404171502/
Id: org.apache.batik.css, Version: 1.7.0.v201011041433, Location: reference:file:plugins/org.apache.batik.css_1.7.0.v201011041433.jar
Id: org.apache.batik.util, Version: 1.7.0.v201011041433, Location: reference:file:plugins/org.apache.batik.util_1.7.0.v201011041433.jar
Id: org.apache.batik.util.gui, Version: 1.7.0.v200903091627, Location: reference:file:plugins/org.apache.batik.util.gui_1.7.0.v200903091627.jar
Id: org.apache.commons.codec, Version: 1.6.0.v201305230611, Location: reference:file:plugins/org.apache.commons.codec_1.6.0.v201305230611.jar
Id: org.apache.commons.logging, Version: 1.1.1.v201101211721, Location: reference:file:plugins/org.apache.commons.logging_1.1.1.v201101211721.jar
Id: org.apache.felix.gogo.command, Version: 0.10.0.v201209301215, Location: reference:file:plugins/org.apache.felix.gogo.command_0.10.0.v201209301215.jar
Id: org.apache.felix.gogo.runtime, Version: 0.10.0.v201209301036, Location: reference:file:plugins/org.apache.felix.gogo.runtime_0.10.0.v201209301036.jar
Id: org.apache.felix.gogo.shell, Version: 0.10.0.v201212101605, Location: reference:file:plugins/org.apache.felix.gogo.shell_0.10.0.v201212101605.jar
Id: org.apache.httpcomponents.httpclient, Version: 4.2.6.v201311072007, Location: reference:file:plugins/org.apache.httpcomponents.httpclient_4.2.6.v201311072007.jar
Id: org.apache.httpcomponents.httpcore, Version: 4.2.5.v201311072007, Location: reference:file:plugins/org.apache.httpcomponents.httpcore_4.2.5.v201311072007.jar
Id: org.apache.jasper.glassfish, Version: 2.2.2.v201205150955, Location: reference:file:plugins/org.apache.jasper.glassfish_2.2.2.v201205150955.jar
Id: org.apache.lucene.analysis, Version: 3.5.0.v20120725-1805, Location: reference:file:plugins/org.apache.lucene.analysis_3.5.0.v20120725-1805.jar
Id: org.apache.lucene.core, Version: 3.5.0.v20120725-1805, Location: reference:file:plugins/org.apache.lucene.core_3.5.0.v20120725-1805.jar
Id: org.eclipse.ant.core, Version: 3.3.0.v20140518-0042, Location: reference:file:plugins/org.eclipse.ant.core_3.3.0.v20140518-0042.jar
Id: org.eclipse.cdt, Version: 8.5.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt_8.5.0.201409172108.jar
Id: org.eclipse.cdt.codan.checkers, Version: 3.2.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.codan.checkers_3.2.0.201409172108.jar
Id: org.eclipse.cdt.codan.checkers.ui, Version: 3.2.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.codan.checkers.ui_3.2.0.201409172108.jar
Id: org.eclipse.cdt.codan.core, Version: 3.2.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.codan.core_3.2.0.201409172108.jar
Id: org.eclipse.cdt.codan.core.cxx, Version: 3.2.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.codan.core.cxx_3.2.0.201409172108.jar
Id: org.eclipse.cdt.codan.ui, Version: 3.2.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.codan.ui_3.2.0.201409172108.jar
Id: org.eclipse.cdt.codan.ui.cxx, Version: 3.2.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.codan.ui.cxx_3.2.0.201409172108.jar
Id: org.eclipse.cdt.core, Version: 5.8.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.core_5.8.0.201409172108.jar
Id: org.eclipse.cdt.core.native, Version: 5.7.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.core.native_5.7.0.201409172108.jar
Id: org.eclipse.cdt.core.win32, Version: 5.4.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.core.win32_5.4.0.201409172108.jar
Id: org.eclipse.cdt.core.win32.x86, Version: 5.3.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.core.win32.x86_5.3.0.201409172108/
Id: org.eclipse.cdt.debug.core, Version: 7.5.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.debug.core_7.5.0.201409172108.jar
Id: org.eclipse.cdt.debug.gdbjtag, Version: 7.0.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.debug.gdbjtag_7.0.0.201409172108.jar
Id: org.eclipse.cdt.debug.gdbjtag.core, Version: 8.4.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.debug.gdbjtag.core_8.4.0.201409172108.jar
Id: org.eclipse.cdt.debug.gdbjtag.ui, Version: 7.1.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.debug.gdbjtag.ui_7.1.0.201409172108.jar
Id: org.eclipse.cdt.debug.mi.core, Version: 7.3.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.debug.mi.core_7.3.0.201409172108.jar
Id: org.eclipse.cdt.debug.mi.ui, Version: 6.2.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.debug.mi.ui_6.2.0.201409172108.jar
Id: org.eclipse.cdt.debug.ui, Version: 7.5.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.debug.ui_7.5.0.201409172108.jar
Id: org.eclipse.cdt.debug.ui.memory.memorybrowser, Version: 1.3.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.debug.ui.memory.memorybrowser_1.3.0.201409172108.jar
Id: org.eclipse.cdt.debug.ui.memory.search, Version: 1.3.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.debug.ui.memory.search_1.3.0.201409172108.jar
Id: org.eclipse.cdt.debug.ui.memory.traditional, Version: 1.2.1.201409172108, Location: reference:file:plugins/org.eclipse.cdt.debug.ui.memory.traditional_1.2.1.201409172108.jar
Id: org.eclipse.cdt.debug.ui.memory.transport, Version: 2.1.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.debug.ui.memory.transport_2.1.0.201409172108.jar
Id: org.eclipse.cdt.doc.user, Version: 5.3.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.doc.user_5.3.0.201409172108.jar
Id: org.eclipse.cdt.dsf, Version: 2.5.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.dsf_2.5.0.201409172108.jar
Id: org.eclipse.cdt.dsf.gdb, Version: 4.5.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.dsf.gdb_4.5.0.201409172108.jar
Id: org.eclipse.cdt.dsf.gdb.ui, Version: 2.4.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.dsf.gdb.ui_2.4.0.201409172108.jar
Id: org.eclipse.cdt.dsf.ui, Version: 2.4.100.201409172108, Location: reference:file:plugins/org.eclipse.cdt.dsf.ui_2.4.100.201409172108.jar
Id: org.eclipse.cdt.gdb, Version: 7.0.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.gdb_7.0.0.201409172108.jar
Id: org.eclipse.cdt.gdb.ui, Version: 7.0.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.gdb.ui_7.0.0.201409172108.jar
Id: org.eclipse.cdt.launch, Version: 7.1.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.launch_7.1.0.201409172108.jar
Id: org.eclipse.cdt.make.core, Version: 7.3.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.make.core_7.3.0.201409172108.jar
Id: org.eclipse.cdt.make.ui, Version: 7.2.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.make.ui_7.2.0.201409172108.jar
Id: org.eclipse.cdt.managedbuilder.core, Version: 8.3.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.managedbuilder.core_8.3.0.201409172108.jar
Id: org.eclipse.cdt.managedbuilder.gnu.ui, Version: 8.3.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.managedbuilder.gnu.ui_8.3.0.201409172108.jar
Id: org.eclipse.cdt.managedbuilder.ui, Version: 8.2.2.201409172108, Location: reference:file:plugins/org.eclipse.cdt.managedbuilder.ui_8.2.2.201409172108.jar
Id: org.eclipse.cdt.ui, Version: 5.8.1.201409172108, Location: reference:file:plugins/org.eclipse.cdt.ui_5.8.1.201409172108.jar
Id: org.eclipse.compare, Version: 3.5.501.v20140817-1445, Location: reference:file:plugins/org.eclipse.compare_3.5.501.v20140817-1445.jar
Id: org.eclipse.compare.core, Version: 3.5.400.v20130903-0736, Location: reference:file:plugins/org.eclipse.compare.core_3.5.400.v20130903-0736.jar
Id: org.eclipse.compare.win32, Version: 1.0.200.v20130514-1224, Location: reference:file:plugins/org.eclipse.compare.win32_1.0.200.v20130514-1224.jar
Id: org.eclipse.core.commands, Version: 3.6.100.v20140528-1422, Location: reference:file:plugins/org.eclipse.core.commands_3.6.100.v20140528-1422.jar
Id: org.eclipse.core.contenttype, Version: 3.4.200.v20140207-1251, Location: reference:file:plugins/org.eclipse.core.contenttype_3.4.200.v20140207-1251.jar
Id: org.eclipse.core.databinding, Version: 1.4.2.v20140729-1044, Location: reference:file:plugins/org.eclipse.core.databinding_1.4.2.v20140729-1044.jar
Id: org.eclipse.core.databinding.beans, Version: 1.2.200.v20140214-0004, Location: reference:file:plugins/org.eclipse.core.databinding.beans_1.2.200.v20140214-0004.jar
Id: org.eclipse.core.databinding.observable, Version: 1.4.1.v20140210-1835, Location: reference:file:plugins/org.eclipse.core.databinding.observable_1.4.1.v20140210-1835.jar
Id: org.eclipse.core.databinding.property, Version: 1.4.200.v20140214-0004, Location: reference:file:plugins/org.eclipse.core.databinding.property_1.4.200.v20140214-0004.jar
Id: org.eclipse.core.expressions, Version: 3.4.600.v20140128-0851, Location: reference:file:plugins/org.eclipse.core.expressions_3.4.600.v20140128-0851.jar
Id: org.eclipse.core.externaltools, Version: 1.0.300.v20140219-0051, Location: reference:file:plugins/org.eclipse.core.externaltools_1.0.300.v20140219-0051.jar
Id: org.eclipse.core.filebuffers, Version: 3.5.400.v20140127-1516, Location: reference:file:plugins/org.eclipse.core.filebuffers_3.5.400.v20140127-1516.jar
Id: org.eclipse.core.filesystem, Version: 1.4.100.v20140514-1614, Location: reference:file:plugins/org.eclipse.core.filesystem_1.4.100.v20140514-1614.jar
Id: org.eclipse.core.filesystem.java7, Version: 1.0.0.v20140429-1531, Location: reference:file:plugins/org.eclipse.core.filesystem.java7_1.0.0.v20140429-1531.jar
Id: org.eclipse.core.filesystem.win32.x86, Version: 1.4.0.v20140124-1940, Location: reference:file:plugins/org.eclipse.core.filesystem.win32.x86_1.4.0.v20140124-1940.jar
Id: org.eclipse.core.jobs, Version: 3.6.0.v20140424-0053, Location: reference:file:plugins/org.eclipse.core.jobs_3.6.0.v20140424-0053.jar
Id: org.eclipse.core.net, Version: 1.2.200.v20140124-2013, Location: reference:file:plugins/org.eclipse.core.net_1.2.200.v20140124-2013.jar
Id: org.eclipse.core.net.win32.x86, Version: 1.0.100.v20140124-2013, Location: reference:file:plugins/org.eclipse.core.net.win32.x86_1.0.100.v20140124-2013.jar
Id: org.eclipse.core.resources, Version: 3.9.1.v20140825-1431, Location: reference:file:plugins/org.eclipse.core.resources_3.9.1.v20140825-1431.jar
Id: org.eclipse.core.resources.win32.x86, Version: 3.5.100.v20140124-1940, Location: reference:file:plugins/org.eclipse.core.resources.win32.x86_3.5.100.v20140124-1940.jar
Id: org.eclipse.core.runtime, Version: 3.10.0.v20140318-2214, Location: reference:file:plugins/org.eclipse.core.runtime_3.10.0.v20140318-2214.jar
Id: org.eclipse.core.runtime.compatibility, Version: 3.2.200.v20140128-0851, Location: reference:file:plugins/org.eclipse.core.runtime.compatibility_3.2.200.v20140128-0851.jar
Id: org.eclipse.core.runtime.compatibility.registry, Version: 3.5.300.v20140128-0851, Location: reference:file:plugins/org.eclipse.core.runtime.compatibility.registry_3.5.300.v20140128-0851/
Id: org.eclipse.core.variables, Version: 3.2.800.v20130819-1716, Location: reference:file:plugins/org.eclipse.core.variables_3.2.800.v20130819-1716.jar
Id: org.eclipse.cvs, Version: 1.4.100.v20140925-0400, Location: reference:file:plugins/org.eclipse.cvs_1.4.100.v20140925-0400.jar
Id: org.eclipse.debug.core, Version: 3.9.1.v20140805-1629, Location: reference:file:plugins/org.eclipse.debug.core_3.9.1.v20140805-1629.jar
Id: org.eclipse.debug.ui, Version: 3.10.1.v20140822-1408, Location: reference:file:plugins/org.eclipse.debug.ui_3.10.1.v20140822-1408.jar
Id: org.eclipse.draw2d, Version: 3.9.101.201408150207, Location: reference:file:plugins/org.eclipse.draw2d_3.9.101.201408150207.jar
Id: org.eclipse.e4.core.commands, Version: 0.10.2.v20140424-2344, Location: reference:file:plugins/org.eclipse.e4.core.commands_0.10.2.v20140424-2344.jar
Id: org.eclipse.e4.core.contexts, Version: 1.3.100.v20140407-1019, Location: reference:file:plugins/org.eclipse.e4.core.contexts_1.3.100.v20140407-1019.jar
Id: org.eclipse.e4.core.di, Version: 1.4.0.v20140414-1837, Location: reference:file:plugins/org.eclipse.e4.core.di_1.4.0.v20140414-1837.jar
Id: org.eclipse.e4.core.di.extensions, Version: 0.12.0.v20140417-2033, Location: reference:file:plugins/org.eclipse.e4.core.di.extensions_0.12.0.v20140417-2033.jar
Id: org.eclipse.e4.core.services, Version: 1.2.1.v20140808-1251, Location: reference:file:plugins/org.eclipse.e4.core.services_1.2.1.v20140808-1251.jar
Id: org.eclipse.e4.ui.bindings, Version: 0.10.200.v20140424-2042, Location: reference:file:plugins/org.eclipse.e4.ui.bindings_0.10.200.v20140424-2042.jar
Id: org.eclipse.e4.ui.css.core, Version: 0.10.100.v20140424-2042, Location: reference:file:plugins/org.eclipse.e4.ui.css.core_0.10.100.v20140424-2042.jar
Id: org.eclipse.e4.ui.css.swt, Version: 0.11.101.v20140818-1343, Location: reference:file:plugins/org.eclipse.e4.ui.css.swt_0.11.101.v20140818-1343.jar
Id: org.eclipse.e4.ui.css.swt.theme, Version: 0.9.300.v20140424-2042, Location: reference:file:plugins/org.eclipse.e4.ui.css.swt.theme_0.9.300.v20140424-2042.jar
Id: org.eclipse.e4.ui.di, Version: 1.0.0.v20140328-2112, Location: reference:file:plugins/org.eclipse.e4.ui.di_1.0.0.v20140328-2112.jar
Id: org.eclipse.e4.ui.model.workbench, Version: 1.1.0.v20140512-1820, Location: reference:file:plugins/org.eclipse.e4.ui.model.workbench_1.1.0.v20140512-1820.jar
Id: org.eclipse.e4.ui.services, Version: 1.1.0.v20140328-1925, Location: reference:file:plugins/org.eclipse.e4.ui.services_1.1.0.v20140328-1925.jar
Id: org.eclipse.e4.ui.widgets, Version: 1.0.0.v20140514-1823, Location: reference:file:plugins/org.eclipse.e4.ui.widgets_1.0.0.v20140514-1823.jar
Id: org.eclipse.e4.ui.workbench, Version: 1.2.1.v20140901-1244, Location: reference:file:plugins/org.eclipse.e4.ui.workbench_1.2.1.v20140901-1244.jar
Id: org.eclipse.e4.ui.workbench.addons.swt, Version: 1.1.1.v20140903-0821, Location: reference:file:plugins/org.eclipse.e4.ui.workbench.addons.swt_1.1.1.v20140903-0821.jar
Id: org.eclipse.e4.ui.workbench.renderers.swt, Version: 0.12.1.v20140903-1023, Location: reference:file:plugins/org.eclipse.e4.ui.workbench.renderers.swt_0.12.1.v20140903-1023.jar
Id: org.eclipse.e4.ui.workbench.swt, Version: 0.12.100.v20140530-1436, Location: reference:file:plugins/org.eclipse.e4.ui.workbench.swt_0.12.100.v20140530-1436.jar
Id: org.eclipse.e4.ui.workbench3, Version: 0.12.0.v20140227-2118, Location: reference:file:plugins/org.eclipse.e4.ui.workbench3_0.12.0.v20140227-2118.jar
Id: org.eclipse.ecf, Version: 3.4.0.v20140827-1444, Location: reference:file:plugins/org.eclipse.ecf_3.4.0.v20140827-1444.jar
Id: org.eclipse.ecf.filetransfer, Version: 5.0.0.v20140827-1444, Location: reference:file:plugins/org.eclipse.ecf.filetransfer_5.0.0.v20140827-1444.jar
Id: org.eclipse.ecf.identity, Version: 3.4.0.v20140827-1444, Location: reference:file:plugins/org.eclipse.ecf.identity_3.4.0.v20140827-1444.jar
Id: org.eclipse.ecf.provider.filetransfer, Version: 3.2.200.v20140827-1444, Location: reference:file:plugins/org.eclipse.ecf.provider.filetransfer_3.2.200.v20140827-1444.jar
Id: org.eclipse.ecf.provider.filetransfer.httpclient4, Version: 1.0.800.v20140827-1444, Location: reference:file:plugins/org.eclipse.ecf.provider.filetransfer.httpclient4_1.0.800.v20140827-1444.jar
Id: org.eclipse.ecf.provider.filetransfer.httpclient4.ssl, Version: 1.0.0.v20140827-1444, Location: reference:file:plugins/org.eclipse.ecf.provider.filetransfer.httpclient4.ssl_1.0.0.v20140827-1444.jar
Id: org.eclipse.ecf.provider.filetransfer.ssl, Version: 1.0.0.v20140827-1444, Location: reference:file:plugins/org.eclipse.ecf.provider.filetransfer.ssl_1.0.0.v20140827-1444.jar
Id: org.eclipse.ecf.ssl, Version: 1.1.0.v20140827-1444, Location: reference:file:plugins/org.eclipse.ecf.ssl_1.1.0.v20140827-1444.jar
Id: org.eclipse.emf.common, Version: 2.10.1.v20140901-1043, Location: reference:file:plugins/org.eclipse.emf.common_2.10.1.v20140901-1043.jar
Id: org.eclipse.emf.ecore, Version: 2.10.1.v20140901-1043, Location: reference:file:plugins/org.eclipse.emf.ecore_2.10.1.v20140901-1043.jar
Id: org.eclipse.emf.ecore.change, Version: 2.10.0.v20140901-1043, Location: reference:file:plugins/org.eclipse.emf.ecore.change_2.10.0.v20140901-1043.jar
Id: org.eclipse.emf.ecore.xmi, Version: 2.10.1.v20140901-1043, Location: reference:file:plugins/org.eclipse.emf.ecore.xmi_2.10.1.v20140901-1043.jar
Id: org.eclipse.equinox.app, Version: 1.3.200.v20130910-1609, Location: reference:file:plugins/org.eclipse.equinox.app_1.3.200.v20130910-1609.jar
Id: org.eclipse.equinox.bidi, Version: 0.10.0.v20130327-1442, Location: reference:file:plugins/org.eclipse.equinox.bidi_0.10.0.v20130327-1442.jar
Id: org.eclipse.equinox.common, Version: 3.6.200.v20130402-1505, Location: reference:file:plugins/org.eclipse.equinox.common_3.6.200.v20130402-1505.jar
Id: org.eclipse.equinox.concurrent, Version: 1.1.0.v20130327-1442, Location: reference:file:plugins/org.eclipse.equinox.concurrent_1.1.0.v20130327-1442.jar
Id: org.eclipse.equinox.console, Version: 1.1.0.v20140131-1639, Location: reference:file:plugins/org.eclipse.equinox.console_1.1.0.v20140131-1639.jar
Id: org.eclipse.equinox.ds, Version: 1.4.200.v20131126-2331, Location: reference:file:plugins/org.eclipse.equinox.ds_1.4.200.v20131126-2331.jar
Id: org.eclipse.equinox.event, Version: 1.3.100.v20140115-1647, Location: reference:file:plugins/org.eclipse.equinox.event_1.3.100.v20140115-1647.jar
Id: org.eclipse.equinox.frameworkadmin, Version: 2.0.100.v20131209-2144, Location: reference:file:plugins/org.eclipse.equinox.frameworkadmin_2.0.100.v20131209-2144.jar
Id: org.eclipse.equinox.frameworkadmin.equinox, Version: 1.0.500.v20131211-1531, Location: reference:file:plugins/org.eclipse.equinox.frameworkadmin.equinox_1.0.500.v20131211-1531.jar
Id: org.eclipse.equinox.http.jetty, Version: 3.0.200.v20131021-1843, Location: reference:file:plugins/org.eclipse.equinox.http.jetty_3.0.200.v20131021-1843.jar
Id: org.eclipse.equinox.http.registry, Version: 1.1.300.v20130402-1529, Location: reference:file:plugins/org.eclipse.equinox.http.registry_1.1.300.v20130402-1529.jar
Id: org.eclipse.equinox.http.servlet, Version: 1.1.500.v20140318-1755, Location: reference:file:plugins/org.eclipse.equinox.http.servlet_1.1.500.v20140318-1755.jar
Id: org.eclipse.equinox.jsp.jasper, Version: 1.0.400.v20130327-1442, Location: reference:file:plugins/org.eclipse.equinox.jsp.jasper_1.0.400.v20130327-1442.jar
Id: org.eclipse.equinox.jsp.jasper.registry, Version: 1.0.300.v20130327-1442, Location: reference:file:plugins/org.eclipse.equinox.jsp.jasper.registry_1.0.300.v20130327-1442.jar
Id: org.eclipse.equinox.launcher, Version: 1.3.0.v20140415-2008, Location: reference:file:plugins/org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar
Id: org.eclipse.equinox.launcher.win32.win32.x86, Version: 1.1.200.v20140603-1326, Location: reference:file:plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.1.200.v20140603-1326/
Id: org.eclipse.equinox.p2.artifact.repository, Version: 1.1.300.v20131211-1531, Location: reference:file:plugins/org.eclipse.equinox.p2.artifact.repository_1.1.300.v20131211-1531.jar
Id: org.eclipse.equinox.p2.console, Version: 1.0.300.v20131113-1212, Location: reference:file:plugins/org.eclipse.equinox.p2.console_1.0.300.v20131113-1212.jar
Id: org.eclipse.equinox.p2.core, Version: 2.3.0.v20131211-1531, Location: reference:file:plugins/org.eclipse.equinox.p2.core_2.3.0.v20131211-1531.jar
Id: org.eclipse.equinox.p2.director, Version: 2.3.100.v20140224-1921, Location: reference:file:plugins/org.eclipse.equinox.p2.director_2.3.100.v20140224-1921.jar
Id: org.eclipse.equinox.p2.director.app, Version: 1.0.300.v20140228-1829, Location: reference:file:plugins/org.eclipse.equinox.p2.director.app_1.0.300.v20140228-1829.jar
Id: org.eclipse.equinox.p2.directorywatcher, Version: 1.1.0.v20131211-1531, Location: reference:file:plugins/org.eclipse.equinox.p2.directorywatcher_1.1.0.v20131211-1531.jar
Id: org.eclipse.equinox.p2.engine, Version: 2.3.0.v20140506-1720, Location: reference:file:plugins/org.eclipse.equinox.p2.engine_2.3.0.v20140506-1720.jar
Id: org.eclipse.equinox.p2.extensionlocation, Version: 1.2.100.v20131119-0908, Location: reference:file:plugins/org.eclipse.equinox.p2.extensionlocation_1.2.100.v20131119-0908.jar
Id: org.eclipse.equinox.p2.garbagecollector, Version: 1.0.200.v20131115-1210, Location: reference:file:plugins/org.eclipse.equinox.p2.garbagecollector_1.0.200.v20131115-1210.jar
Id: org.eclipse.equinox.p2.jarprocessor, Version: 1.0.300.v20131211-1531, Location: reference:file:plugins/org.eclipse.equinox.p2.jarprocessor_1.0.300.v20131211-1531.jar
Id: org.eclipse.equinox.p2.metadata, Version: 2.2.0.v20131211-1531, Location: reference:file:plugins/org.eclipse.equinox.p2.metadata_2.2.0.v20131211-1531.jar
Id: org.eclipse.equinox.p2.metadata.repository, Version: 1.2.100.v20131209-2144, Location: reference:file:plugins/org.eclipse.equinox.p2.metadata.repository_1.2.100.v20131209-2144.jar
Id: org.eclipse.equinox.p2.operations, Version: 2.4.0.v20131119-0908, Location: reference:file:plugins/org.eclipse.equinox.p2.operations_2.4.0.v20131119-0908.jar
Id: org.eclipse.equinox.p2.publisher, Version: 1.3.0.v20140911-0143, Location: reference:file:plugins/org.eclipse.equinox.p2.publisher_1.3.0.v20140911-0143.jar
Id: org.eclipse.equinox.p2.publisher.eclipse, Version: 1.1.200.v20140414-0825, Location: reference:file:plugins/org.eclipse.equinox.p2.publisher.eclipse_1.1.200.v20140414-0825.jar
Id: org.eclipse.equinox.p2.ql, Version: 2.0.100.v20131211-1531, Location: reference:file:plugins/org.eclipse.equinox.p2.ql_2.0.100.v20131211-1531.jar
Id: org.eclipse.equinox.p2.reconciler.dropins, Version: 1.1.200.v20131119-0908, Location: reference:file:plugins/org.eclipse.equinox.p2.reconciler.dropins_1.1.200.v20131119-0908.jar
Id: org.eclipse.equinox.p2.repository, Version: 2.3.0.v20131211-1531, Location: reference:file:plugins/org.eclipse.equinox.p2.repository_2.3.0.v20131211-1531.jar
Id: org.eclipse.equinox.p2.repository.tools, Version: 2.1.0.v20131211-1531, Location: reference:file:plugins/org.eclipse.equinox.p2.repository.tools_2.1.0.v20131211-1531.jar
Id: org.eclipse.equinox.p2.touchpoint.eclipse, Version: 2.1.200.v20140512-1650, Location: reference:file:plugins/org.eclipse.equinox.p2.touchpoint.eclipse_2.1.200.v20140512-1650.jar
Id: org.eclipse.equinox.p2.touchpoint.natives, Version: 1.1.100.v20140523-0116, Location: reference:file:plugins/org.eclipse.equinox.p2.touchpoint.natives_1.1.100.v20140523-0116.jar
Id: org.eclipse.equinox.p2.transport.ecf, Version: 1.1.0.v20140408-1354, Location: reference:file:plugins/org.eclipse.equinox.p2.transport.ecf_1.1.0.v20140408-1354.jar
Id: org.eclipse.equinox.p2.ui, Version: 2.3.0.v20140404-1657, Location: reference:file:plugins/org.eclipse.equinox.p2.ui_2.3.0.v20140404-1657.jar
Id: org.eclipse.equinox.p2.ui.importexport, Version: 1.1.0.v20131210-1027, Location: reference:file:plugins/org.eclipse.equinox.p2.ui.importexport_1.1.0.v20131210-1027.jar
Id: org.eclipse.equinox.p2.ui.sdk, Version: 1.0.300.v20140407-1803, Location: reference:file:plugins/org.eclipse.equinox.p2.ui.sdk_1.0.300.v20140407-1803.jar
Id: org.eclipse.equinox.p2.ui.sdk.scheduler, Version: 1.2.0.v20140422-1847, Location: reference:file:plugins/org.eclipse.equinox.p2.ui.sdk.scheduler_1.2.0.v20140422-1847.jar
Id: org.eclipse.equinox.p2.updatechecker, Version: 1.1.200.v20131119-0908, Location: reference:file:plugins/org.eclipse.equinox.p2.updatechecker_1.1.200.v20131119-0908.jar
Id: org.eclipse.equinox.p2.updatesite, Version: 1.0.400.v20131211-1531, Location: reference:file:plugins/org.eclipse.equinox.p2.updatesite_1.0.400.v20131211-1531.jar
Id: org.eclipse.equinox.preferences, Version: 3.5.200.v20140224-1527, Location: reference:file:plugins/org.eclipse.equinox.preferences_3.5.200.v20140224-1527.jar
Id: org.eclipse.equinox.registry, Version: 3.5.400.v20140428-1507, Location: reference:file:plugins/org.eclipse.equinox.registry_3.5.400.v20140428-1507.jar
Id: org.eclipse.equinox.security, Version: 1.2.0.v20130424-1801, Location: reference:file:plugins/org.eclipse.equinox.security_1.2.0.v20130424-1801.jar
Id: org.eclipse.equinox.security.ui, Version: 1.1.200.v20130626-2037, Location: reference:file:plugins/org.eclipse.equinox.security.ui_1.1.200.v20130626-2037.jar
Id: org.eclipse.equinox.security.win32.x86, Version: 1.0.300.v20130327-1442, Location: reference:file:plugins/org.eclipse.equinox.security.win32.x86_1.0.300.v20130327-1442.jar
Id: org.eclipse.equinox.simpleconfigurator, Version: 1.1.0.v20131217-1203, Location: initial@reference:file:plugins/org.eclipse.equinox.simpleconfigurator_1.1.0.v20131217-1203.jar
Id: org.eclipse.equinox.simpleconfigurator.manipulator, Version: 2.0.0.v20131217-1203, Location: reference:file:plugins/org.eclipse.equinox.simpleconfigurator.manipulator_2.0.0.v20131217-1203.jar
Id: org.eclipse.equinox.util, Version: 1.0.500.v20130404-1337, Location: reference:file:plugins/org.eclipse.equinox.util_1.0.500.v20130404-1337.jar
Id: org.eclipse.gef, Version: 3.9.100.201408150207, Location: reference:file:plugins/org.eclipse.gef_3.9.100.201408150207.jar
Id: org.eclipse.help, Version: 3.6.0.v20130326-1254, Location: reference:file:plugins/org.eclipse.help_3.6.0.v20130326-1254.jar
Id: org.eclipse.help.base, Version: 4.0.200.v20140925-0400, Location: reference:file:plugins/org.eclipse.help.base_4.0.200.v20140925-0400.jar
Id: org.eclipse.help.ui, Version: 4.0.100.v20140401-0608, Location: reference:file:plugins/org.eclipse.help.ui_4.0.100.v20140401-0608.jar
Id: org.eclipse.help.webapp, Version: 3.6.300.v20140407-1855, Location: reference:file:plugins/org.eclipse.help.webapp_3.6.300.v20140407-1855.jar
Id: org.eclipse.jetty.continuation, Version: 8.1.14.v20131031, Location: reference:file:plugins/org.eclipse.jetty.continuation_8.1.14.v20131031.jar
Id: org.eclipse.jetty.http, Version: 8.1.14.v20131031, Location: reference:file:plugins/org.eclipse.jetty.http_8.1.14.v20131031.jar
Id: org.eclipse.jetty.io, Version: 8.1.14.v20131031, Location: reference:file:plugins/org.eclipse.jetty.io_8.1.14.v20131031.jar
Id: org.eclipse.jetty.security, Version: 8.1.14.v20131031, Location: reference:file:plugins/org.eclipse.jetty.security_8.1.14.v20131031.jar
Id: org.eclipse.jetty.server, Version: 8.1.14.v20131031, Location: reference:file:plugins/org.eclipse.jetty.server_8.1.14.v20131031.jar
Id: org.eclipse.jetty.servlet, Version: 8.1.14.v20131031, Location: reference:file:plugins/org.eclipse.jetty.servlet_8.1.14.v20131031.jar
Id: org.eclipse.jetty.util, Version: 8.1.14.v20131031, Location: reference:file:plugins/org.eclipse.jetty.util_8.1.14.v20131031.jar
Id: org.eclipse.jface, Version: 3.10.1.v20140813-1009, Location: reference:file:plugins/org.eclipse.jface_3.10.1.v20140813-1009.jar
Id: org.eclipse.jface.databinding, Version: 1.6.200.v20140528-1422, Location: reference:file:plugins/org.eclipse.jface.databinding_1.6.200.v20140528-1422.jar
Id: org.eclipse.jface.text, Version: 3.9.1.v20140827-1810, Location: reference:file:plugins/org.eclipse.jface.text_3.9.1.v20140827-1810.jar
Id: org.eclipse.jsch.core, Version: 1.1.500.v20131112-1442, Location: reference:file:plugins/org.eclipse.jsch.core_1.1.500.v20131112-1442.jar
Id: org.eclipse.jsch.ui, Version: 1.1.500.v20131112-1442, Location: reference:file:plugins/org.eclipse.jsch.ui_1.1.500.v20131112-1442.jar
Id: org.eclipse.ltk.core.refactoring, Version: 3.6.101.v20140817-1500, Location: reference:file:plugins/org.eclipse.ltk.core.refactoring_3.6.101.v20140817-1500.jar
Id: org.eclipse.ltk.ui.refactoring, Version: 3.7.100.v20140324-1358, Location: reference:file:plugins/org.eclipse.ltk.ui.refactoring_3.7.100.v20140324-1358.jar
Id: org.eclipse.osgi, Version: 3.10.1.v20140909-1633, Location: System Bundle
Id: org.eclipse.osgi.compatibility.state, Version: 1.0.1.v20140709-1414, Location: initial@reference:file:plugins/org.eclipse.osgi.compatibility.state_1.0.1.v20140709-1414.jar
Id: org.eclipse.osgi.services, Version: 3.4.0.v20140312-2051, Location: reference:file:plugins/org.eclipse.osgi.services_3.4.0.v20140312-2051.jar
Id: org.eclipse.osgi.util, Version: 3.3.0.v20131023-1243, Location: reference:file:plugins/org.eclipse.osgi.util_3.3.0.v20131023-1243.jar
Id: org.eclipse.platform, Version: 4.4.0.v20140925-0400, Location: reference:file:plugins/org.eclipse.platform_4.4.0.v20140925-0400/
Id: org.eclipse.platform.doc.user, Version: 4.4.1.v20140829-1306, Location: reference:file:plugins/org.eclipse.platform.doc.user_4.4.1.v20140829-1306.jar
Id: org.eclipse.rcp, Version: 4.3.100.v20140925-0400, Location: reference:file:plugins/org.eclipse.rcp_4.3.100.v20140925-0400.jar
Id: org.eclipse.search, Version: 3.9.100.v20140226-1637, Location: reference:file:plugins/org.eclipse.search_3.9.100.v20140226-1637.jar
Id: org.eclipse.swt, Version: 3.103.1.v20140903-1938, Location: reference:file:plugins/org.eclipse.swt_3.103.1.v20140903-1938.jar
Id: org.eclipse.swt.win32.win32.x86, Version: 3.103.1.v20140903-1947, Location: reference:file:plugins/org.eclipse.swt.win32.win32.x86_3.103.1.v20140903-1947.jar
Id: org.eclipse.team.core, Version: 3.7.0.v20130514-1224, Location: reference:file:plugins/org.eclipse.team.core_3.7.0.v20130514-1224.jar
Id: org.eclipse.team.cvs.core, Version: 3.3.600.v20131112-1442, Location: reference:file:plugins/org.eclipse.team.cvs.core_3.3.600.v20131112-1442.jar
Id: org.eclipse.team.cvs.ssh2, Version: 3.2.400.v20131112-1442, Location: reference:file:plugins/org.eclipse.team.cvs.ssh2_3.2.400.v20131112-1442.jar
Id: org.eclipse.team.cvs.ui, Version: 3.3.600.v20130514-1224, Location: reference:file:plugins/org.eclipse.team.cvs.ui_3.3.600.v20130514-1224.jar
Id: org.eclipse.team.ui, Version: 3.7.100.v20130710-1213, Location: reference:file:plugins/org.eclipse.team.ui_3.7.100.v20130710-1213.jar
Id: org.eclipse.text, Version: 3.5.300.v20130515-1451, Location: reference:file:plugins/org.eclipse.text_3.5.300.v20130515-1451.jar
Id: org.eclipse.ui, Version: 3.106.0.v20140812-1751, Location: reference:file:plugins/org.eclipse.ui_3.106.0.v20140812-1751.jar
Id: org.eclipse.ui.browser, Version: 3.4.200.v20131003-1453, Location: reference:file:plugins/org.eclipse.ui.browser_3.4.200.v20131003-1453.jar
Id: org.eclipse.ui.cheatsheets, Version: 3.4.200.v20131227-1524, Location: reference:file:plugins/org.eclipse.ui.cheatsheets_3.4.200.v20131227-1524.jar
Id: org.eclipse.ui.console, Version: 3.5.300.v20140424-1437, Location: reference:file:plugins/org.eclipse.ui.console_3.5.300.v20140424-1437.jar
Id: org.eclipse.ui.editors, Version: 3.8.200.v20140401-1310, Location: reference:file:plugins/org.eclipse.ui.editors_3.8.200.v20140401-1310.jar
Id: org.eclipse.ui.externaltools, Version: 3.2.300.v20140327-1949, Location: reference:file:plugins/org.eclipse.ui.externaltools_3.2.300.v20140327-1949.jar
Id: org.eclipse.ui.forms, Version: 3.6.100.v20140422-1825, Location: reference:file:plugins/org.eclipse.ui.forms_3.6.100.v20140422-1825.jar
Id: org.eclipse.ui.ide, Version: 3.10.1.v20140828-0944, Location: reference:file:plugins/org.eclipse.ui.ide_3.10.1.v20140828-0944.jar
Id: org.eclipse.ui.ide.application, Version: 1.0.500.v20140514-2033, Location: reference:file:plugins/org.eclipse.ui.ide.application_1.0.500.v20140514-2033.jar
Id: org.eclipse.ui.intro, Version: 3.4.200.v20130326-1254, Location: reference:file:plugins/org.eclipse.ui.intro_3.4.200.v20130326-1254.jar
Id: org.eclipse.ui.intro.universal, Version: 3.2.700.v20130904-1701, Location: reference:file:plugins/org.eclipse.ui.intro.universal_3.2.700.v20130904-1701/
Id: org.eclipse.ui.navigator, Version: 3.5.401.v20140724-1117, Location: reference:file:plugins/org.eclipse.ui.navigator_3.5.401.v20140724-1117.jar
Id: org.eclipse.ui.navigator.resources, Version: 3.4.700.v20140407-1004, Location: reference:file:plugins/org.eclipse.ui.navigator.resources_3.4.700.v20140407-1004.jar
Id: org.eclipse.ui.net, Version: 1.2.200.v20120807-0927, Location: reference:file:plugins/org.eclipse.ui.net_1.2.200.v20120807-0927.jar
Id: org.eclipse.ui.themes, Version: 1.0.1.v20140819-1717, Location: reference:file:plugins/org.eclipse.ui.themes_1.0.1.v20140819-1717/
Id: org.eclipse.ui.views, Version: 3.7.0.v20140408-0703, Location: reference:file:plugins/org.eclipse.ui.views_3.7.0.v20140408-0703.jar
Id: org.eclipse.ui.views.properties.tabbed, Version: 3.6.0.v20140519-0906, Location: reference:file:plugins/org.eclipse.ui.views.properties.tabbed_3.6.0.v20140519-0906.jar
Id: org.eclipse.ui.win32, Version: 3.2.400.v20140423-2207, Location: reference:file:plugins/org.eclipse.ui.win32_3.2.400.v20140423-2207.jar
Id: org.eclipse.ui.workbench, Version: 3.106.1.v20140827-1737, Location: reference:file:plugins/org.eclipse.ui.workbench_3.106.1.v20140827-1737.jar
Id: org.eclipse.ui.workbench.texteditor, Version: 3.9.0.v20140411-1521, Location: reference:file:plugins/org.eclipse.ui.workbench.texteditor_3.9.0.v20140411-1521.jar
Id: org.eclipse.update.configurator, Version: 3.3.300.v20140518-1928, Location: reference:file:plugins/org.eclipse.update.configurator_3.3.300.v20140518-1928.jar
Id: org.sat4j.core, Version: 2.3.5.v201308161310, Location: reference:file:plugins/org.sat4j.core_2.3.5.v201308161310.jar
Id: org.sat4j.pb, Version: 2.3.5.v201404071733, Location: reference:file:plugins/org.sat4j.pb_2.3.5.v201404071733.jar
Id: org.w3c.css.sac, Version: 1.3.1.v200903091627, Location: reference:file:plugins/org.w3c.css.sac_1.3.1.v200903091627.jar
Id: org.w3c.dom.events, Version: 3.0.0.draft20060413_v201105210656, Location: reference:file:plugins/org.w3c.dom.events_3.0.0.draft20060413_v201105210656.jar
Id: org.w3c.dom.smil, Version: 1.0.0.v200806040011, Location: reference:file:plugins/org.w3c.dom.smil_1.0.0.v200806040011.jar
Id: org.w3c.dom.svg, Version: 1.1.0.v201011041433, Location: reference:file:plugins/org.w3c.dom.svg_1.1.0.v201011041433.jar
*** Security Configuration:
Providers (10):
Provider: SUN, Version: 1.7, Class: sun.security.provider.Sun
  Description: SUN (DSA key/parameter generation; DSA signing; SHA-1, MD5 digests; SecureRandom; X.509 certificates; JKS keystore; PKIX CertPathValidator; PKIX CertPathBuilder; LDAP, Collection CertStores, JavaPolicy Policy; JavaLoginConfig Configuration)
  Services (23):
   Service: MessageDigest, Algorithm: SHA-512, Class: sun.security.provider.SHA5$SHA512
   Service: Configuration, Algorithm: JavaLoginConfig, Class: sun.security.provider.ConfigSpiFile
   Service: Signature, Algorithm: NONEwithDSA, Class: sun.security.provider.DSA$RawDSA
    Aliases: RawDSA
    Attributes:
      SupportedKeyClasses: java.security.interfaces.DSAPublicKey|java.security.interfaces.DSAPrivateKey
   Service: CertPathBuilder, Algorithm: PKIX, Class: sun.security.provider.certpath.SunCertPathBuilder
    Attributes:
      ImplementedIn: Software
      ValidationAlgorithm: RFC3280
   Service: CertStore, Algorithm: LDAP, Class: sun.security.provider.certpath.ldap.LDAPCertStore
    Attributes:
      LDAPSchema: RFC2587
   Service: MessageDigest, Algorithm: SHA, Class: sun.security.provider.SHA
    Aliases: SHA1
    Attributes:
   Service: CertificateFactory, Algorithm: X.509, Class: sun.security.provider.X509Factory
    Aliases: X509
    Attributes:
   Service: MessageDigest, Algorithm: SHA-384, Class: sun.security.provider.SHA5$SHA384
   Service: KeyPairGenerator, Algorithm: DSA, Class: sun.security.provider.DSAKeyPairGenerator
    Aliases: OID.1.2.840.10040.4.1
    Attributes:
      KeySize: 1024
   Service: KeyStore, Algorithm: JKS, Class: sun.security.provider.JavaKeyStore$JKS
    Attributes:
   Service: KeyStore, Algorithm: CaseExactJKS, Class: sun.security.provider.JavaKeyStore$CaseExactJKS
   Service: MessageDigest, Algorithm: SHA-256, Class: sun.security.provider.SHA2
   Service: CertStore, Algorithm: com.sun.security.IndexedCollection, Class: sun.security.provider.certpath.IndexedCollectionCertStore
    Attributes:
   Service: KeyFactory, Algorithm: DSA, Class: sun.security.provider.DSAKeyFactory
    Attributes:
   Service: SecureRandom, Algorithm: SHA1PRNG, Class: sun.security.provider.SecureRandom
    Attributes:
   Service: CertPathValidator, Algorithm: PKIX, Class: sun.security.provider.certpath.PKIXCertPathValidator
    Attributes:
   Service: CertStore, Algorithm: Collection, Class: sun.security.provider.certpath.CollectionCertStore
    Attributes:
   Service: MessageDigest, Algorithm: MD5, Class: sun.security.provider.MD5
    Attributes:
   Service: AlgorithmParameters, Algorithm: DSA, Class: sun.security.provider.DSAParameters
    Attributes:
   Service: Policy, Algorithm: JavaPolicy, Class: sun.security.provider.PolicySpiFile
   Service: MessageDigest, Algorithm: MD2, Class: sun.security.provider.MD2
   Service: Signature, Algorithm: SHA1withDSA, Class: sun.security.provider.DSA$SHA1withDSA
    Aliases: DSAWithSHA1
    Attributes:
      KeySize: 1024
   Service: AlgorithmParameterGenerator, Algorithm: DSA, Class: sun.security.provider.DSAParameterGenerator
    Attributes:
      KeySize: 1024
Provider: SunRsaSign, Version: 1.7, Class: sun.security.rsa.SunRsaSign
  Description: Sun RSA signature provider
  Services (8):
   Service: Signature, Algorithm: SHA512withRSA, Class: sun.security.rsa.RSASignature$SHA512withRSA
    Aliases: OID.1.2.840.113549.1.1.13
    Attributes:
      SupportedKeyClasses: java.security.interfaces.RSAPublicKey|java.security.interfaces.RSAPrivateKey
   Service: Signature, Algorithm: MD5withRSA, Class: sun.security.rsa.RSASignature$MD5withRSA
    Aliases: 1.2.840.113549.1.1.4
    Attributes:
   Service: KeyFactory, Algorithm: RSA, Class: sun.security.rsa.RSAKeyFactory
   Service: Signature, Algorithm: SHA1withRSA, Class: sun.security.rsa.RSASignature$SHA1withRSA
    Aliases: OID.1.2.840.113549.1.1.5
    Attributes:
   Service: Signature, Algorithm: SHA384withRSA, Class: sun.security.rsa.RSASignature$SHA384withRSA
    Aliases: OID.1.2.840.113549.1.1.12
    Attributes:
   Service: Signature, Algorithm: MD2withRSA, Class: sun.security.rsa.RSASignature$MD2withRSA
    Aliases: 1.2.840.113549.1.1.2
    Attributes:
   Service: KeyPairGenerator, Algorithm: RSA, Class: sun.security.rsa.RSAKeyPairGenerator
   Service: Signature, Algorithm: SHA256withRSA, Class: sun.security.rsa.RSASignature$SHA256withRSA
    Aliases: OID.1.2.840.113549.1.1.11
    Attributes:
Provider: SunEC, Version: 1.7, Class: sun.security.ec.SunEC
  Description: Sun Elliptic Curve provider (EC, ECDSA, ECDH)
  Services (9):
   Service: Signature, Algorithm: SHA512withECDSA, Class: sun.security.ec.ECDSASignature$SHA512
    Attributes:
      SupportedKeyClasses: java.security.interfaces.ECPublicKey|java.security.interfaces.ECPrivateKey
   Service: AlgorithmParameters, Algorithm: EC, Class: sun.security.ec.ECParameters
    Aliases: EllipticCurve
    Attributes:
      SupportedCurves: [secp112r1,1.3.132.0.6]|[secp112r2,1.3.132.0.7]|[secp128r1,1.3.132.0.28]|[secp128r2,1.3.132.0.29]|[secp160k1,1.3.132.0.9]|[secp160r1,1.3.132.0.8]|[secp160r2,1.3.132.0.30]|[secp192k1,1.3.132.0.31]|[secp192r1,NIST P-192,X9.62 prime192v1,1.2.840.10045.3.1.1]|[secp224k1,1.3.132.0.32]|[secp224r1,NIST P-224,1.3.132.0.33]|[secp256k1,1.3.132.0.10]|[secp256r1,NIST P-256,X9.62 prime256v1,1.2.840.10045.3.1.7]|[secp384r1,NIST P-384,1.3.132.0.34]|[secp521r1,NIST P-521,1.3.132.0.35]|[X9.62 prime192v2,1.2.840.10045.3.1.2]|[X9.62 prime192v3,1.2.840.10045.3.1.3]|[X9.62 prime239v1,1.2.840.10045.3.1.4]|[X9.62 prime239v2,1.2.840.10045.3.1.5]|[X9.62 prime239v3,1.2.840.10045.3.1.6]|[sect113r1,1.3.132.0.4]|[sect113r2,1.3.132.0.5]|[sect131r1,1.3.132.0.22]|[sect131r2,1.3.132.0.23]|[sect163k1,NIST K-163,1.3.132.0.1]|[sect163r1,1.3.132.0.2]|[sect163r2,NIST B-163,1.3.132.0.15]|[sect193r1,1.3.132.0.24]|[sect193r2,1.3.132.0.25]|[sect233k1,NIST K-233,1.3.132.0.26]|[sect233r1,NIST B-233,1.3.132.0.27]|[sect239k1,1.3.132.0.3]|[sect283k1,NIST K-283,1.3.132.0.16]|[sect283r1,NIST B-283,1.3.132.0.17]|[sect409k1,NIST K-409,1.3.132.0.36]|[sect409r1,NIST B-409,1.3.132.0.37]|[sect571k1,NIST K-571,1.3.132.0.38]|[sect571r1,NIST B-571,1.3.132.0.39]|[X9.62 c2tnb191v1,1.2.840.10045.3.0.5]|[X9.62 c2tnb191v2,1.2.840.10045.3.0.6]|[X9.62 c2tnb191v3,1.2.840.10045.3.0.7]|[X9.62 c2tnb239v1,1.2.840.10045.3.0.11]|[X9.62 c2tnb239v2,1.2.840.10045.3.0.12]|[X9.62 c2tnb239v3,1.2.840.10045.3.0.13]|[X9.62 c2tnb359v1,1.2.840.10045.3.0.18]|[X9.62 c2tnb431r1,1.2.840.10045.3.0.20]
      KeySize: 256
   Service: Signature, Algorithm: SHA384withECDSA, Class: sun.security.ec.ECDSASignature$SHA384
    Attributes:
   Service: Signature, Algorithm: NONEwithECDSA, Class: sun.security.ec.ECDSASignature$Raw
    Attributes:
   Service: Signature, Algorithm: SHA1withECDSA, Class: sun.security.ec.ECDSASignature$SHA1
    Attributes:
      KeySize: 256
   Service: KeyPairGenerator, Algorithm: EC, Class: sun.security.ec.ECKeyPairGenerator
    Attributes:
      KeySize: 256
   Service: KeyFactory, Algorithm: EC, Class: sun.security.ec.ECKeyFactory
    Attributes:
   Service: KeyAgreement, Algorithm: ECDH, Class: sun.security.ec.ECDHKeyAgreement
    Attributes:
   Service: Signature, Algorithm: SHA256withECDSA, Class: sun.security.ec.ECDSASignature$SHA256
    Attributes:
Provider: SunJSSE, Version: 1.7, Class: com.sun.net.ssl.internal.ssl.Provider
  Description: Sun JSSE provider(PKCS12, SunX509 key/trust factories, SSLv3, TLSv1)
  Services (15):
   Service: Signature, Algorithm: MD5andSHA1withRSA, Class: sun.security.ssl.RSASignature
   Service: SSLContext, Algorithm: Default, Class: sun.security.ssl.SSLContextImpl$DefaultSSLContext
   Service: KeyManagerFactory, Algorithm: SunX509, Class: sun.security.ssl.KeyManagerFactoryImpl$SunX509
    Aliases: OID.1.2.840.113549.1.1.4
   Service: TrustManagerFactory, Algorithm: SunX509, Class: sun.security.ssl.TrustManagerFactoryImpl$SimpleFactory
   Service: KeyStore, Algorithm: PKCS12, Class: sun.security.pkcs12.PKCS12KeyStore
   Service: SSLContext, Algorithm: TLSv1, Class: sun.security.ssl.SSLContextImpl$TLS10Context
    Aliases: TLS
   Service: SSLContext, Algorithm: TLSv1.2, Class: sun.security.ssl.SSLContextImpl$TLS12Context
   Service: KeyManagerFactory, Algorithm: NewSunX509, Class: sun.security.ssl.KeyManagerFactoryImpl$X509
    Aliases: PKIX
   Service: SSLContext, Algorithm: TLSv1.1, Class: sun.security.ssl.SSLContextImpl$TLS11Context
   Service: TrustManagerFactory, Algorithm: PKIX, Class: sun.security.ssl.TrustManagerFactoryImpl$PKIXFactory
    Aliases: X509
Provider: SunJCE, Version: 1.7, Class: com.sun.crypto.provider.SunJCE
  Description: SunJCE Provider (implements RSA, DES, Triple DES, AES, Blowfish, ARCFOUR, RC2, PBE, Diffie-Hellman, HMAC)
  Services (61):
   Service: KeyGenerator, Algorithm: DESede, Class: com.sun.crypto.provider.DESedeKeyGenerator
    Aliases: TripleDES
   Service: KeyGenerator, Algorithm: HmacSHA384, Class: com.sun.crypto.provider.KeyGeneratorCore$HmacSHA384KG
   Service: AlgorithmParameters, Algorithm: OAEP, Class: com.sun.crypto.provider.OAEPParameters
   Service: KeyGenerator, Algorithm: ARCFOUR, Class: com.sun.crypto.provider.KeyGeneratorCore$ARCFOURKeyGenerator
    Aliases: RC4
   Service: Cipher, Algorithm: AESWrap, Class: com.sun.crypto.provider.AESWrapCipher
    Attributes:
      SupportedPaddings: NOPADDING
      SupportedKeyFormats: RAW
      SupportedModes: ECB
   Service: KeyGenerator, Algorithm: HmacSHA256, Class: com.sun.crypto.provider.KeyGeneratorCore$HmacSHA256KG
   Service: KeyGenerator, Algorithm: HmacSHA512, Class: com.sun.crypto.provider.KeyGeneratorCore$HmacSHA512KG
   Service: KeyGenerator, Algorithm: SunTls12Prf, Class: com.sun.crypto.provider.TlsPrfGenerator$V12
   Service: AlgorithmParameters, Algorithm: AES, Class: com.sun.crypto.provider.AESParameters
    Aliases: Rijndael
   Service: AlgorithmParameters, Algorithm: PBEWithMD5AndTripleDES, Class: com.sun.crypto.provider.PBEParameters
   Service: AlgorithmParameters, Algorithm: RC2, Class: com.sun.crypto.provider.RC2Parameters
   Service: KeyStore, Algorithm: JCEKS, Class: com.sun.crypto.provider.JceKeyStore
   Service: KeyGenerator, Algorithm: SunTlsPrf, Class: com.sun.crypto.provider.TlsPrfGenerator$V10
   Service: Cipher, Algorithm: DES, Class: com.sun.crypto.provider.DESCipher
    Attributes:
      SupportedPaddings: NOPADDING|PKCS5PADDING|ISO10126PADDING
      SupportedModes: ECB|CBC|PCBC|CTR|CTS|CFB|OFB|CFB8|CFB16|CFB24|CFB32|CFB40|CFB48|CFB56|CFB64|OFB8|OFB16|OFB24|OFB32|OFB40|OFB48|OFB56|OFB64
   Service: Cipher, Algorithm: RSA, Class: com.sun.crypto.provider.RSACipher
    Attributes:
      SupportedPaddings: NOPADDING|PKCS1PADDING|OAEPWITHMD5ANDMGF1PADDING|OAEPWITHSHA1ANDMGF1PADDING|OAEPWITHSHA-1ANDMGF1PADDING|OAEPWITHSHA-256ANDMGF1PADDING|OAEPWITHSHA-384ANDMGF1PADDING|OAEPWITHSHA-512ANDMGF1PADDING
      SupportedModes: ECB
   Service: KeyFactory, Algorithm: DiffieHellman, Class: com.sun.crypto.provider.DHKeyFactory
    Aliases: DH
   Service: Cipher, Algorithm: PBEWithSHA1AndDESede, Class: com.sun.crypto.provider.PKCS12PBECipherCore$PBEWithSHA1AndDESede
    Aliases: OID.1.2.840.113549.1.12.1.3
   Service: AlgorithmParameters, Algorithm: DiffieHellman, Class: com.sun.crypto.provider.DHParameters
    Aliases: DH
   Service: Cipher, Algorithm: DESedeWrap, Class: com.sun.crypto.provider.DESedeWrapCipher
    Attributes:
      SupportedModes: CBC
   Service: KeyGenerator, Algorithm: SunTlsRsaPremasterSecret, Class: com.sun.crypto.provider.TlsRsaPremasterSecretGenerator
    Aliases: SunTls12RsaPremasterSecret
   Service: AlgorithmParameters, Algorithm: DESede, Class: com.sun.crypto.provider.DESedeParameters
    Aliases: TripleDES
   Service: KeyGenerator, Algorithm: HmacSHA1, Class: com.sun.crypto.provider.HmacSHA1KeyGenerator
   Service: SecretKeyFactory, Algorithm: PBEWithMD5AndDES, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithMD5AndDES
    Aliases: 1.2.840.113549.1.5.3
   Service: Cipher, Algorithm: PBEWithSHA1AndRC2_40, Class: com.sun.crypto.provider.PKCS12PBECipherCore$PBEWithSHA1AndRC2_40
    Aliases: OID.1.2.840.113549.1.12.1.6
   Service: Mac, Algorithm: HmacMD5, Class: com.sun.crypto.provider.HmacMD5
    Attributes:
   Service: SecretKeyFactory, Algorithm: DESede, Class: com.sun.crypto.provider.DESedeKeyFactory
    Aliases: TripleDES
   Service: Mac, Algorithm: SslMacSHA1, Class: com.sun.crypto.provider.SslMacCore$SslMacSHA1
    Attributes:
   Service: KeyGenerator, Algorithm: SunTlsMasterSecret, Class: com.sun.crypto.provider.TlsMasterSecretGenerator
    Aliases: SunTls12MasterSecret
   Service: KeyGenerator, Algorithm: DES, Class: com.sun.crypto.provider.DESKeyGenerator
   Service: Cipher, Algorithm: PBEWithMD5AndTripleDES, Class: com.sun.crypto.provider.PBEWithMD5AndTripleDESCipher
   Service: AlgorithmParameters, Algorithm: PBEWithSHA1AndDESede, Class: com.sun.crypto.provider.PBEParameters
   Service: Cipher, Algorithm: ARCFOUR, Class: com.sun.crypto.provider.ARCFOURCipher
    Aliases: RC4
    Attributes:
      SupportedModes: ECB
   Service: AlgorithmParameters, Algorithm: PBE, Class: com.sun.crypto.provider.PBEParameters
   Service: SecretKeyFactory, Algorithm: PBEWithMD5AndTripleDES, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithMD5AndTripleDES
   Service: Mac, Algorithm: HmacPBESHA1, Class: com.sun.crypto.provider.HmacPKCS12PBESHA1
    Attributes:
   Service: Cipher, Algorithm: AES, Class: com.sun.crypto.provider.AESCipher
    Aliases: Rijndael
    Attributes:
      SupportedModes: ECB|CBC|PCBC|CTR|CTS|CFB|OFB|CFB8|CFB16|CFB24|CFB32|CFB40|CFB48|CFB56|CFB64|OFB8|OFB16|OFB24|OFB32|OFB40|OFB48|OFB56|OFB64|CFB72|CFB80|CFB88|CFB96|CFB104|CFB112|CFB120|CFB128|OFB72|OFB80|OFB88|OFB96|OFB104|OFB112|OFB120|OFB128
   Service: SecretKeyFactory, Algorithm: DES, Class: com.sun.crypto.provider.DESKeyFactory
   Service: Cipher, Algorithm: RC2, Class: com.sun.crypto.provider.RC2Cipher
    Attributes:
   Service: AlgorithmParameters, Algorithm: PBEWithSHA1AndRC2_40, Class: com.sun.crypto.provider.PBEParameters
   Service: KeyAgreement, Algorithm: DiffieHellman, Class: com.sun.crypto.provider.DHKeyAgreement
    Aliases: DH
    Attributes:
      SupportedKeyClasses: javax.crypto.interfaces.DHPublicKey|javax.crypto.interfaces.DHPrivateKey
   Service: KeyGenerator, Algorithm: Blowfish, Class: com.sun.crypto.provider.BlowfishKeyGenerator
   Service: KeyPairGenerator, Algorithm: DiffieHellman, Class: com.sun.crypto.provider.DHKeyPairGenerator
    Aliases: DH
   Service: Cipher, Algorithm: PBEWithMD5AndDES, Class: com.sun.crypto.provider.PBEWithMD5AndDESCipher
   Service: Cipher, Algorithm: Blowfish, Class: com.sun.crypto.provider.BlowfishCipher
    Attributes:
   Service: AlgorithmParameters, Algorithm: DES, Class: com.sun.crypto.provider.DESParameters
   Service: KeyGenerator, Algorithm: AES, Class: com.sun.crypto.provider.AESKeyGenerator
    Aliases: Rijndael
   Service: KeyGenerator, Algorithm: HmacMD5, Class: com.sun.crypto.provider.HmacMD5KeyGenerator
   Service: SecretKeyFactory, Algorithm: PBKDF2WithHmacSHA1, Class: com.sun.crypto.provider.PBKDF2HmacSHA1Factory
    Aliases: OID.1.2.840.113549.1.5.12
   Service: KeyGenerator, Algorithm: RC2, Class: com.sun.crypto.provider.KeyGeneratorCore$RC2KeyGenerator
   Service: Mac, Algorithm: SslMacMD5, Class: com.sun.crypto.provider.SslMacCore$SslMacMD5
    Attributes:
   Service: SecretKeyFactory, Algorithm: PBEWithSHA1AndDESede, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithSHA1AndDESede
   Service: AlgorithmParameterGenerator, Algorithm: DiffieHellman, Class: com.sun.crypto.provider.DHParameterGenerator
    Aliases: DH
   Service: Mac, Algorithm: HmacSHA1, Class: com.sun.crypto.provider.HmacSHA1
    Attributes:
   Service: Mac, Algorithm: HmacSHA384, Class: com.sun.crypto.provider.HmacCore$HmacSHA384
    Attributes:
   Service: KeyGenerator, Algorithm: SunTlsKeyMaterial, Class: com.sun.crypto.provider.TlsKeyMaterialGenerator
    Aliases: SunTls12KeyMaterial
   Service: SecretKeyFactory, Algorithm: PBEWithSHA1AndRC2_40, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithSHA1AndRC2_40
   Service: Mac, Algorithm: HmacSHA256, Class: com.sun.crypto.provider.HmacCore$HmacSHA256
    Attributes:
   Service: AlgorithmParameters, Algorithm: Blowfish, Class: com.sun.crypto.provider.BlowfishParameters
   Service: Mac, Algorithm: HmacSHA512, Class: com.sun.crypto.provider.HmacCore$HmacSHA512
    Attributes:
   Service: AlgorithmParameters, Algorithm: PBEWithMD5AndDES, Class: com.sun.crypto.provider.PBEParameters
   Service: Cipher, Algorithm: DESede, Class: com.sun.crypto.provider.DESedeCipher
    Aliases: TripleDES
    Attributes:
Provider: SunJGSS, Version: 1.7, Class: sun.security.jgss.SunProvider
  Description: Sun (Kerberos v5, SPNEGO)
  Services (2):
   Service: GssApiMechanism, Algorithm: 1.3.6.1.5.5.2, Class: sun.security.jgss.spnego.SpNegoMechFactory
   Service: GssApiMechanism, Algorithm: 1.2.840.113554.1.2.2, Class: sun.security.jgss.krb5.Krb5MechFactory
Provider: SunSASL, Version: 1.7, Class: com.sun.security.sasl.Provider
  Description: Sun SASL provider(implements client mechanisms for: DIGEST-MD5, GSSAPI, EXTERNAL, PLAIN, CRAM-MD5, NTLM; server mechanisms for: DIGEST-MD5, GSSAPI, CRAM-MD5, NTLM)
  Services (10):
   Service: SaslClientFactory, Algorithm: NTLM, Class: com.sun.security.sasl.ntlm.FactoryImpl
   Service: SaslClientFactory, Algorithm: CRAM-MD5, Class: com.sun.security.sasl.ClientFactoryImpl
   Service: SaslClientFactory, Algorithm: EXTERNAL, Class: com.sun.security.sasl.ClientFactoryImpl
   Service: SaslClientFactory, Algorithm: DIGEST-MD5, Class: com.sun.security.sasl.digest.FactoryImpl
   Service: SaslClientFactory, Algorithm: PLAIN, Class: com.sun.security.sasl.ClientFactoryImpl
   Service: SaslServerFactory, Algorithm: NTLM, Class: com.sun.security.sasl.ntlm.FactoryImpl
   Service: SaslClientFactory, Algorithm: GSSAPI, Class: com.sun.security.sasl.gsskerb.FactoryImpl
   Service: SaslServerFactory, Algorithm: CRAM-MD5, Class: com.sun.security.sasl.ServerFactoryImpl
   Service: SaslServerFactory, Algorithm: DIGEST-MD5, Class: com.sun.security.sasl.digest.FactoryImpl
   Service: SaslServerFactory, Algorithm: GSSAPI, Class: com.sun.security.sasl.gsskerb.FactoryImpl
Provider: XMLDSig, Version: 1.0, Class: org.jcp.xml.dsig.internal.dom.XMLDSigRI
  Description: XMLDSig (DOM XMLSignatureFactory; DOM KeyInfoFactory)
  Services (13):
   Service: KeyInfoFactory, Algorithm: DOM, Class: org.jcp.xml.dsig.internal.dom.DOMKeyInfoFactory
   Service: TransformService, Algorithm: http://www.w3.org/TR/1999/REC-xpath-19991116, Class: org.jcp.xml.dsig.internal.dom.DOMXPathTransform
    Aliases: XPATH
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/TR/2001/REC-xml-c14n-20010315#WithComments, Class: org.jcp.xml.dsig.internal.dom.DOMCanonicalXMLC14NMethod
    Aliases: INCLUSIVE_WITH_COMMENTS
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/2000/09/xmldsig#base64, Class: org.jcp.xml.dsig.internal.dom.DOMBase64Transform
    Aliases: BASE64
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/2000/09/xmldsig#enveloped-signature, Class: org.jcp.xml.dsig.internal.dom.DOMEnvelopedTransform
    Aliases: ENVELOPED
    Attributes:
      MechanismType: DOM
   Service: XMLSignatureFactory, Algorithm: DOM, Class: org.jcp.xml.dsig.internal.dom.DOMXMLSignatureFactory
   Service: TransformService, Algorithm: http://www.w3.org/TR/2001/REC-xml-c14n-20010315, Class: org.jcp.xml.dsig.internal.dom.DOMCanonicalXMLC14NMethod
    Aliases: INCLUSIVE
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/2002/06/xmldsig-filter2, Class: org.jcp.xml.dsig.internal.dom.DOMXPathFilter2Transform
    Aliases: XPATH2
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/2001/10/xml-exc-c14n#, Class: org.jcp.xml.dsig.internal.dom.DOMExcC14NMethod
    Aliases: EXCLUSIVE
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/TR/1999/REC-xslt-19991116, Class: org.jcp.xml.dsig.internal.dom.DOMXSLTTransform
    Aliases: XSLT
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/2006/12/xml-c14n11#WithComments, Class: org.jcp.xml.dsig.internal.dom.DOMCanonicalXMLC14N11Method
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/2001/10/xml-exc-c14n#WithComments, Class: org.jcp.xml.dsig.internal.dom.DOMExcC14NMethod
    Aliases: EXCLUSIVE_WITH_COMMENTS
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/2006/12/xml-c14n11, Class: org.jcp.xml.dsig.internal.dom.DOMCanonicalXMLC14N11Method
    Attributes:
      MechanismType: DOM
Provider: SunPCSC, Version: 1.7, Class: sun.security.smartcardio.SunPCSC
  Description: Sun PC/SC provider
  Services (1):
   Service: TerminalFactory, Algorithm: PC/SC, Class: sun.security.smartcardio.SunPCSC$Factory
Provider: SunMSCAPI, Version: 1.7, Class: sun.security.mscapi.SunMSCAPI
  Description: Sun's Microsoft Crypto API provider
  Services (13):
   Service: Signature, Algorithm: SHA512withRSA, Class: sun.security.mscapi.RSASignature$SHA512
    Attributes:
      SupportedKeyClasses: sun.security.mscapi.Key
   Service: Signature, Algorithm: MD5withRSA, Class: sun.security.mscapi.RSASignature$MD5
    Attributes:
   Service: Signature, Algorithm: NONEwithRSA, Class: sun.security.mscapi.RSASignature$Raw
    Attributes:
   Service: Signature, Algorithm: SHA1withRSA, Class: sun.security.mscapi.RSASignature$SHA1
    Attributes:
   Service: Cipher, Algorithm: RSA, Class: sun.security.mscapi.RSACipher
    Attributes:
      SupportedPaddings: PKCS1PADDING
      SupportedModes: ECB
   Service: SecureRandom, Algorithm: Windows-PRNG, Class: sun.security.mscapi.PRNG
   Service: KeyStore, Algorithm: Windows-ROOT, Class: sun.security.mscapi.KeyStore$ROOT
   Service: Signature, Algorithm: SHA384withRSA, Class: sun.security.mscapi.RSASignature$SHA384
    Attributes:
   Service: KeyPairGenerator, Algorithm: RSA, Class: sun.security.mscapi.RSAKeyPairGenerator
    Attributes:
      KeySize: 1024
   Service: Signature, Algorithm: SHA256withRSA, Class: sun.security.mscapi.RSASignature$SHA256
    Attributes:
   Service: Cipher, Algorithm: RSA/ECB/PKCS1Padding, Class: sun.security.mscapi.RSACipher
   Service: Signature, Algorithm: MD2withRSA, Class: sun.security.mscapi.RSASignature$MD2
    Attributes:
   Service: KeyStore, Algorithm: Windows-MY, Class: sun.security.mscapi.KeyStore$MY
Content originally posted in LPCWare by nxpuser1 on Fri Mar 13 05:36:50 MST 2015
I use windows7, 64bits, Windows response
C:\Users\Egitim5>set
ALLUSERSPROFILE=C:\ProgramData
AMDAPPSDKROOT=C:\Program Files (x86)\AMD APP\
APPDATA=C:\Users\Egitim5\AppData\Roaming
CommonProgramFiles=C:\Program Files\Common Files
CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
CommonProgramW6432=C:\Program Files\Common Files
COMPUTERNAME=EGITIM5-HP
ComSpec=C:\Windows\system32\cmd.exe
FP_NO_HOST_CHECK=NO
HOMEDRIVE=C:
HOMEPATH=\Users\Egitim5
KMP_DUPLICATE_LIB_OK=TRUE
LOCALAPPDATA=C:\Users\Egitim5\AppData\Local
LOGONSERVER=\\EGITIM5-HP
MKL_SERIAL=YES
NUMBER_OF_PROCESSORS=4
OnlineServices=Online Services
OS=Windows_NT
Path=C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\HP SimplePass 20
11\;C:\Program Files\Broadcom\Broadcom 802.11\Driver;;C:\Program Files (x86)\AMD
APP\bin\x86_64;C:\Program Files (x86)\AMD APP\bin\x86;C:\Program Files\Common F
iles\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft
Shared\Windows Live;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\
Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Windows Live\Sha
red;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files
\WIDCOMM\Bluetooth Software\;C:\Program Files\WIDCOMM\Bluetooth Software\syswow6
4;C:\Program Files\Broadcom\WHL\;C:\Program Files\Broadcom\WHL\syswow64;C:\Progr
am Files\Broadcom\WHL\SysWow64\;C:\Program Files\Broadcom\WHL\SysWow64\syswow64;
C:\Program Files (x86)\Intel\Services\IPT\;C:\Program Files (x86)\Microchip\MPLA
B C32 Suite\bin;C:\Program Files (x86)\HI-TECH Software\PICC\9.83\bin;C:\Program
Files (x86)\Microchip\xc16\v1.21\bin;c:\Program Files (x86)\Microsoft SQL Serve
r\100\Tools\Binn\;c:\Program Files\Microsoft SQL Server\100\Tools\Binn\;c:\Progr
am Files\Microsoft SQL Server\100\DTS\Binn\
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
PCBRAND=Pavilion
Platform=MCD
PROCESSOR_ARCHITECTURE=AMD64
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 42 Stepping 7, GenuineIntel
PROCESSOR_LEVEL=6
PROCESSOR_REVISION=2a07
ProgramData=C:\ProgramData
PROMPT=$P$G
PSModulePath=C:\Windows\system32\WindowsPowerShell\v1.0\Modules\
PUBLIC=C:\Users\Public
SESSIONNAME=Console
SystemDrive=C:
SystemRoot=C:\Windows
TEMP=C:\Users\Egitim5\AppData\Local\Temp
TMP=C:\Users\Egitim5\AppData\Local\Temp
USERDOMAIN=Egitim5-HP
USERNAME=Egitim5
USERPROFILE=C:\Users\Egitim5
windir=C:\Windows
windows_tracing_flags=3
windows_tracing_logfile=C:\BVTBin\Tests\installpackage\csilogfile.log
IDE :
*** Date: 13 Mart 2015 Cuma 14:35:46 Doğu Avrupa Standart Saati
*** Platform Details:
*** System properties:
applicationXMI=org.eclipse.ui.workbench/LegacyIDE.e4xmi
awt.toolkit=sun.awt.windows.WToolkit
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
-launcher
C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\lpcxpresso.exe
-name
Lpcxpresso
--launcher.library
C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\\plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.1.200.v20140603-1326\eclipse_1603.dll
-startup
C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\\plugins/org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar
--launcher.overrideVmargs
-vm
C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\bin\client\jvm.dll
eclipse.home.location=file:/C:/nxp/LPCXpresso_7.6.2_326/lpcxpresso/
eclipse.launcher=C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\lpcxpresso.exe
eclipse.launcher.name=Lpcxpresso
eclipse.p2.data.area=@config.dir/../p2
eclipse.p2.profile=DefaultProfile
eclipse.product=com.crt.lpcxpresso.brand.product
eclipse.startTime=1426239422881
eclipse.stateSaveDelayInterval=30000
eclipse.vm=C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\bin\client\jvm.dll
eclipse.vmargs=-Dosgi.requiredJavaVersion=1.7
-Xms128m
-Xmx512m
-XX:MaxPermSize=256M
-Djava.class.path=C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\\plugins/org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar
equinox.use.ds=true
file.encoding=Cp1254
file.encoding.pkg=sun.io
file.separator=\
gosh.args=--nointeractive
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.version=51.0
java.endorsed.dirs=C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\lib\endorsed
java.ext.dirs=C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\lib\ext;C:\Windows\Sun\Java\lib\ext
java.home=C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre
java.io.tmpdir=C:\Users\Egitim5\AppData\Local\Temp\
java.library.path=C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:/nxp/LPCXpresso_7.6.2_326/lpcxpresso/jre/bin/client;C:/nxp/LPCXpresso_7.6.2_326/lpcxpresso/jre/bin;C:/nxp/LPCXpresso_7.6.2_326/lpcxpresso/jre/lib/i386;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\HP SimplePass 2011\;C:\Program Files\Broadcom\Broadcom 802.11\Driver;;C:\Program Files (x86)\AMD APP\bin\x86_64;C:\Program Files (x86)\AMD APP\bin\x86;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Windows Live\Shared;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files\WIDCOMM\Bluetooth Software\;C:\Program Files\WIDCOMM\Bluetooth Software\syswow64;C:\Program Files\Broadcom\WHL\;C:\Program Files\Broadcom\WHL\syswow64;C:\Program Files\Broadcom\WHL\SysWow64\;C:\Program Files\Broadcom\WHL\SysWow64\syswow64;C:\Program Files (x86)\Intel\Services\IPT\;C:\Program Files (x86)\Microchip\MPLAB C32 Suite\bin;C:\Program Files (x86)\HI-TECH Software\PICC\9.83\bin;C:\Program Files (x86)\Microchip\xc16\v1.21\bin;c:\Program Files (x86)\Microsoft SQL Server\100\Tools\Binn\;c:\Program Files\Microsoft SQL Server\100\Tools\Binn\;c:\Program Files\Microsoft SQL Server\100\DTS\Binn\;C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso;;.
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.7.0_71-b14
java.specification.name=Java Platform API Specification
java.specification.vendor=Oracle Corporation
java.specification.version=1.7
java.vendor=Oracle Corporation
java.vendor.url=http://java.oracle.com/
java.vendor.url.bug=http://bugreport.sun.com/bugreport/
java.version=1.7.0_71
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Oracle Corporation
java.vm.specification.version=1.7
java.vm.vendor=Oracle Corporation
java.vm.version=24.71-b01
line.separator=
org.eclipse.cdt.debug.ui.debuggerActive=false
org.eclipse.debug.ui.breakpoints.toggleFactoriesUsed=true
org.eclipse.equinox.launcher.splash.location=c:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\configuration\org.eclipse.equinox.launcher\com.crt.lpcxpresso.brand_7.4.1.201502020932\splash.bmp
org.eclipse.equinox.simpleconfigurator.configUrl=file:org.eclipse.equinox.simpleconfigurator/bundles.info
org.eclipse.update.reconcile=false
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSGi/Minimum-1.1,OSGi/Minimum-1.2,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,JavaSE-1.6,JavaSE-1.7
org.osgi.framework.language=tr
org.osgi.framework.os.name=Windows7
org.osgi.framework.os.version=6.1.0
org.osgi.framework.processor=x86
org.osgi.framework.system.capabilities=osgi.ee; osgi.ee="OSGi/Minimum"; version:List<Version>="1.0, 1.1, 1.2",osgi.ee; osgi.ee="JRE"; version:List<Version>="1.0, 1.1",osgi.ee; osgi.ee="JavaSE"; version:List<Version>="1.0, 1.1, 1.2, 1.3, 1.4, 1.5, 1.6, 1.7"
org.osgi.framework.system.packages=javax.accessibility,javax.activation,javax.activity,javax.annotation,javax.annotation.processing,javax.crypto,javax.crypto.interfaces,javax.crypto.spec,javax.imageio,javax.imageio.event,javax.imageio.metadata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap,javax.lang.model,javax.lang.model.element,javax.lang.model.type,javax.lang.model.util,javax.management,javax.management.loading,javax.management.modelmbean,javax.management.monitor,javax.management.openmbean,javax.management.relation,javax.management.remote,javax.management.remote.rmi,javax.management.timer,javax.naming,javax.naming.directory,javax.naming.event,javax.naming.ldap,javax.naming.spi,javax.net,javax.net.ssl,javax.print,javax.print.attribute,javax.print.attribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.rmi.ssl,javax.script,javax.security.auth,javax.security.auth.callback,javax.security.auth.kerberos,javax.security.auth.login,javax.security.auth.spi,javax.security.auth.x500,javax.security.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi,javax.swing,javax.swing.border,javax.swing.colorchooser,javax.swing.event,javax.swing.filechooser,javax.swing.plaf,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.nimbus,javax.swing.plaf.synth,javax.swing.table,javax.swing.text,javax.swing.text.html,javax.swing.text.html.parser,javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.tools,javax.transaction,javax.transaction.xa,javax.xml,javax.xml.bind,javax.xml.bind.annotation,javax.xml.bind.annotation.adapters,javax.xml.bind.attachment,javax.xml.bind.helpers,javax.xml.bind.util,javax.xml.crypto,javax.xml.crypto.dom,javax.xml.crypto.dsig,javax.xml.crypto.dsig.dom,javax.xml.crypto.dsig.keyinfo,javax.xml.crypto.dsig.spec,javax.xml.datatype,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,javax.xml.stream,javax.xml.stream.events,javax.xml.stream.util,javax.xml.transform,javax.xml.transform.dom,javax.xml.transform.sax,javax.xml.transform.stax,javax.xml.transform.stream,javax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax.xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,javax.xml.ws.spi,javax.xml.ws.spi.http,javax.xml.ws.wsaddressing,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNaming.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.omg.PortableServer,org.omg.PortableServer.CurrentPackage,org.omg.PortableServer.POAManagerPackage,org.omg.PortableServer.POAPackage,org.omg.PortableServer.portable,org.omg.PortableServer.ServantLocatorPackage,org.omg.SendingContext,org.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.css,org.w3c.dom.events,org.w3c.dom.html,org.w3c.dom.ls,org.w3c.dom.ranges,org.w3c.dom.stylesheets,org.w3c.dom.traversal,org.w3c.dom.views,org.w3c.dom.xpath,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.uuid=806c6981-64c9-0014-1923-c7caabcbe0d5
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.8.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=x86
os.name=Windows 7
os.version=6.1
osgi.arch=x86
osgi.bundles=reference:file:org.eclipse.osgi.compatibility.state_1.0.1.v20140709-1414.jar,reference:file:org.eclipse.equinox.simpleconfigurator_1.1.0.v20131217-1203.jar@1:start
osgi.bundles.defaultStartLevel=4
osgi.compatibility.bootdelegation=true
osgi.configuration.area=file:/C:/nxp/LPCXpresso_7.6.2_326/lpcxpresso/configuration/
osgi.configuration.area.default=null
osgi.framework=file:/c:/nxp/LPCXpresso_7.6.2_326/lpcxpresso/plugins/org.eclipse.osgi_3.10.1.v20140909-1633.jar
osgi.framework.extensions=reference:file:org.eclipse.osgi.compatibility.state_1.0.1.v20140709-1414.jar
osgi.framework.shape=jar
osgi.framework.useSystemProperties=true
osgi.frameworkClassPath=., file:c:/nxp/LPCXpresso_7.6.2_326/lpcxpresso/plugins/org.eclipse.osgi.compatibility.state_1.0.1.v20140709-1414.jar
osgi.install.area=file:/C:/nxp/LPCXpresso_7.6.2_326/lpcxpresso/
osgi.instance.area=file:/C:/Users/Egitim5/Documents/LPCXpresso_7.6.2_326/workspace/
osgi.instance.area.default=file:/C:/Users/Egitim5/Documents/LPCXpresso_7.6.2_326/workspace/
osgi.logfile=C:\Users\Egitim5\Documents\LPCXpresso_7.6.2_326\workspace\.metadata\.log
osgi.nl=tr_TR
osgi.os=win32
osgi.splashLocation=c:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\configuration\org.eclipse.equinox.launcher\com.crt.lpcxpresso.brand_7.4.1.201502020932\splash.bmp
osgi.splashPath=platform:/base/plugins/com.crt.lpcxpresso.brand
osgi.syspath=c:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\plugins
osgi.tracefile=C:\Users\Egitim5\Documents\LPCXpresso_7.6.2_326\workspace\.metadata\trace.log
osgi.user.area=null
osgi.user.area.default=null
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\lib\resources.jar;C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\lib\rt.jar;C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\lib\sunrsasign.jar;C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\lib\jsse.jar;C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\lib\jce.jar;C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\lib\charsets.jar;C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\lib\jfr.jar;C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\classes
sun.boot.library.path=C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso\jre\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium_pro+mmx pentium_pro pentium+mmx pentium i486 i386 i86
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1254
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 1
user.country=TR
user.dir=C:\nxp\LPCXpresso_7.6.2_326\lpcxpresso
user.home=C:\Users\Egitim5
user.language=tr
user.name=Egitim5
user.script=
user.timezone=Europe/Athens
user.variant=
*** Features:
com.crt.lpcxpresso.feature (7.4.1.201502020932) "LPCXpresso Product Definition"
org.eclipse.cdt (8.5.0.201409172108) "Eclipse C/C++ Development Tools"
org.eclipse.cdt.gdb (8.5.0.201409172108) "GDB Common"
org.eclipse.cvs (1.4.100.v20140925-0400) "Eclipse CVS Client"
org.eclipse.emf.common (2.10.1.v20140901-1043) "EMF Common"
org.eclipse.emf.ecore (2.10.1.v20140901-1043) "EMF Ecore"
org.eclipse.help (2.0.102.v20140925-0400) "Help System Base"
org.eclipse.platform (4.4.0.v20140925-0400) "Eclipse Platform"
org.eclipse.rcp (4.4.0.v20140925-0400) "Eclipse RCP"
*** Plug-in Registry:
com.crt.advproject (7.4.1.201502020932) "Advanced Project Support" [Active]
com.crt.config (7.4.1.201502020932) "Target Configuration" [Active]
com.crt.ctrlcenter (7.4.1.201502020932) "Project Configuration" [Active]
com.crt.debugcommon (7.4.1.201502020932) "Debug Common" [Active]
com.crt.debugmgr (7.4.1.201502020932) "Debug Manager" [Starting]
com.crt.docs (7.4.1.201502020932) "LPCXpresso Documentation" [Resolved]
com.crt.docs.rsguide (7.4.1.201502020932) "LPCXpresso Guide" [Resolved]
com.crt.dsfdebug (7.4.1.201502020932) "DSF Debug Support" [Active]
com.crt.dsfswv (7.4.1.201502020932) "Red Trace+" [Starting]
com.crt.etmetb (7.4.1.201502020932) "Instruction Trace Support" [Starting]
com.crt.lite (7.4.1.201502020932) "Develop Perspective" [Active]
com.crt.lpcxpresso.brand (7.4.1.201502020932) "LPCXpresso Product Definition" [Active]
com.crt.quickstart (7.4.1.201502020932) "Quickstart Panel" [Active]
com.crt.redstate (7.4.1.201502020932) "RedState" [Starting]
com.crt.utils (7.4.1.201502020932) "LPCXpresso Utilities" [Active]
com.crt.vendor.arm.generic (7.4.1.201502020932) "Generic ARM Support" [Starting]
com.crt.vendor.nxp.a7 (7.4.1.201502020932) "NXP LPC2000 Support" [Active]
com.crt.vendor.nxp.generic (7.4.1.201502020932) "NXP Generic Core Support" [Active]
com.crt.vendor.nxp.lpc11 (7.4.1.201502020932) "NXP LPC1100 Support" [Active]
com.crt.vendor.nxp.lpc13 (7.4.1.201502020932) "NXP LPC1300 Support" [Active]
com.crt.vendor.nxp.lpc17 (7.4.1.201502020932) "NXP LPC1700 Support" [Active]
com.crt.vendor.nxp.lpc18 (7.4.1.201502020932) "NXP LPC1800 Support" [Active]
com.crt.vendor.nxp.lpc29 (7.4.1.201502020932) "NXP LPC2900 Support" [Active]
com.crt.vendor.nxp.lpc31 (7.4.1.201502020932) "NXP LPC3000 Support" [Active]
com.crt.vendor.nxp.lpc43 (7.4.1.201502020932) "NXP LPC4000 Support" [Active]
com.crt.vendor.nxp.niobe (7.4.1.201502020932) "NXP LPC5xxxx Series Support" [Active]
com.ibm.icu (52.1.0.v201404241930) "International Components for Unicode for Java (ICU4J)" [Active]
com.jcraft.jsch (0.1.50.v201403120620) "JSch" [Resolved]
com.nxp.gnudocs (7.4.1.201502020932) "GNU Help Documents Provider" [Starting]
com.nxp.symbolbrowser (7.4.1.201502020932) "Symbol Viewer" [Active]
com.sun.el (2.2.0.v201303151357) "Javax Expression Language Reference Implementation Bundle" [Resolved]
javax.annotation (1.2.0.v201401042248) "javax.annotation Bundle" [Resolved]
javax.el (2.2.0.v201303151357) "Javax Expression Language Bundle" [Resolved]
javax.inject (1.0.0.v20091030) "Atinject Dependency Injection Annotations" [Resolved]
javax.servlet (3.0.0.v201112011016) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.2.0.v201112011158) "JSP API Bundle" [Resolved]
javax.xml (1.3.4.v201005080400) "JAXP XML" [Resolved]
org.apache.ant (1.9.2.v201404171502) "Apache Ant" [Resolved]
org.apache.batik.css (1.7.0.v201011041433) "Apache Batik CSS" [Resolved]
org.apache.batik.util (1.7.0.v201011041433) "Apache Batik Utilities" [Resolved]
org.apache.batik.util.gui (1.7.0.v200903091627) "Apache Batik GUI Utilities" [Resolved]
org.apache.commons.codec (1.6.0.v201305230611) "Apache Commons Codec Plug-in" [Resolved]
org.apache.commons.logging (1.1.1.v201101211721) "Apache Commons Logging Plug-in" [Resolved]
org.apache.felix.gogo.command (0.10.0.v201209301215) "Apache Felix Gogo Command" [Active]
org.apache.felix.gogo.runtime (0.10.0.v201209301036) "Apache Felix Gogo Runtime" [Active]
org.apache.felix.gogo.shell (0.10.0.v201212101605) "Apache Felix Gogo Shell" [Active]
org.apache.httpcomponents.httpclient (4.2.6.v201311072007) "Apache HttpComponents HttpClient OSGi bundle" [Resolved]
org.apache.httpcomponents.httpcore (4.2.5.v201311072007) "Apache HttpComponents HttpCore" [Resolved]
org.apache.jasper.glassfish (2.2.2.v201205150955) "JSP 2.2 implementation from Glassfish" [Resolved]
org.apache.lucene.analysis (3.5.0.v20120725-1805) "Apache Lucene Analysis" [Resolved]
org.apache.lucene.core (3.5.0.v20120725-1805) "Apache Lucene Core" [Resolved]
org.eclipse.ant.core (3.3.0.v20140518-0042) "Ant Build Tool Core" [Starting]
org.eclipse.cdt (8.5.0.201409172108) "Eclipse C/C++ Development Tools" [Starting]
org.eclipse.cdt.codan.checkers (3.2.0.201409172108) "Codan Checkers" [Active]
org.eclipse.cdt.codan.checkers.ui (3.2.0.201409172108) "Codan Checkers UI" [Active]
org.eclipse.cdt.codan.core (3.2.0.201409172108) "Code Analysis Core" [Active]
org.eclipse.cdt.codan.core.cxx (3.2.0.201409172108) "Code Analysis Core for C/C++" [Active]
org.eclipse.cdt.codan.ui (3.2.0.201409172108) "Code Analysis UI" [Active]
org.eclipse.cdt.codan.ui.cxx (3.2.0.201409172108) "Codan Analysis UI for C/C++" [Active]
org.eclipse.cdt.core (5.8.0.201409172108) "C/C++ Development Tools Core" [Active]
org.eclipse.cdt.core.native (5.7.0.201409172108) "C/C++ Development Tools Core Native Utilities" [Active]
org.eclipse.cdt.core.win32 (5.4.0.201409172108) "C/C++ Development Tools Core Native Utilities for Windows" [Resolved]
org.eclipse.cdt.core.win32.x86 (5.3.0.201409172108) "C/C++ Development Tools Core Native Utilities for Windows (x86)" [Resolved]
org.eclipse.cdt.debug.core (7.5.0.201409172108) "C/C++ Development Tools Debug Model" [Active]
org.eclipse.cdt.debug.gdbjtag (7.0.0.201409172108) "Eclipse GDB Hardware Debugging Plug-in" [Resolved]
org.eclipse.cdt.debug.gdbjtag.core (8.4.0.201409172108) "Eclipse GDB Hardware Debug Core Plug-in" [Starting]
org.eclipse.cdt.debug.gdbjtag.ui (7.1.0.201409172108) "Eclipse GDB Hardware Debug UI Plug-in" [Starting]
org.eclipse.cdt.debug.mi.core (7.3.0.201409172108) "C/C++ Development Tools GDB/MI CDI Debugger Core" [Active]
org.eclipse.cdt.debug.mi.ui (6.2.0.201409172108) "C/C++ Development Tools GDB/MI CDI Debugger UI" [Active]
org.eclipse.cdt.debug.ui (7.5.0.201409172108) "C/C++ Development Tools Debugger UI" [Active]
org.eclipse.cdt.debug.ui.memory.memorybrowser (1.3.0.201409172108) "Memory Browser" [Starting]
org.eclipse.cdt.debug.ui.memory.search (1.3.0.201409172108) "Memory Search" [Starting]
org.eclipse.cdt.debug.ui.memory.traditional (1.2.1.201409172108) "Traditional Memory Rendering" [Starting]
org.eclipse.cdt.debug.ui.memory.transport (2.1.0.201409172108) "Memory Transport Plug-in" [Starting]
org.eclipse.cdt.doc.user (5.3.0.201409172108) "C/C++ Development User Guide" [Starting]
org.eclipse.cdt.dsf (2.5.0.201409172108) "Debug Services Framework Core" [Active]
org.eclipse.cdt.dsf.gdb (4.5.0.201409172108) "GDB DSF Debugger Integration Core" [Active]
org.eclipse.cdt.dsf.gdb.ui (2.4.0.201409172108) "GDB DSF Debugger Integration UI" [Active]
org.eclipse.cdt.dsf.ui (2.4.100.201409172108) "Debugger Services Framework UI" [Active]
org.eclipse.cdt.gdb (7.0.0.201409172108) "GDB Common" [Starting]
org.eclipse.cdt.gdb.ui (7.0.0.201409172108) "GDB UI Common" [Starting]
org.eclipse.cdt.launch (7.1.0.201409172108) "C/C++ Development Tools Launching Support" [Active]
org.eclipse.cdt.make.core (7.3.0.201409172108) "C/C++ Standard make Build Core" [Active]
org.eclipse.cdt.make.ui (7.2.0.201409172108) "C/C++ Standard make Build UI" [Active]
org.eclipse.cdt.managedbuilder.core (8.3.0.201409172108) "CDT Build System Core" [Active]
org.eclipse.cdt.managedbuilder.gnu.ui (8.3.0.201409172108) "GNU Managed Build Definitions" [Active]
org.eclipse.cdt.managedbuilder.ui (8.2.2.201409172108) "C/C++ Managed Builder UI" [Active]
org.eclipse.cdt.ui (5.8.1.201409172108) "C/C++ Development Tools UI" [Active]
org.eclipse.compare (3.5.501.v20140817-1445) "Compare Support" [Active]
org.eclipse.compare.core (3.5.400.v20130903-0736) "Core Compare Support" [Active]
org.eclipse.compare.win32 (1.0.200.v20130514-1224) "Compare Support for Word" [Starting]
org.eclipse.core.commands (3.6.100.v20140528-1422) "Commands" [Resolved]
org.eclipse.core.contenttype (3.4.200.v20140207-1251) "Eclipse Content Mechanism" [Active]
org.eclipse.core.databinding (1.4.2.v20140729-1044) "JFace Data Binding" [Starting]
org.eclipse.core.databinding.beans (1.2.200.v20140214-0004) "JFace Data Binding for JavaBeans" [Resolved]
org.eclipse.core.databinding.observable (1.4.1.v20140210-1835) "JFace Data Binding Observables" [Active]
org.eclipse.core.databinding.property (1.4.200.v20140214-0004) "JFace Data Binding Properties" [Starting]
org.eclipse.core.expressions (3.4.600.v20140128-0851) "Expression Language" [Active]
org.eclipse.core.externaltools (1.0.300.v20140219-0051) "External Tools Headless Support" [Active]
org.eclipse.core.filebuffers (3.5.400.v20140127-1516) "File Buffers" [Active]
org.eclipse.core.filesystem (1.4.100.v20140514-1614) "Core File Systems" [Active]
org.eclipse.core.filesystem.java7 (1.0.0.v20140429-1531) "Core File System for Java 7 and newer" [Resolved]
org.eclipse.core.filesystem.win32.x86 (1.4.0.v20140124-1940) "Core File System for Windows" [Resolved]
org.eclipse.core.jobs (3.6.0.v20140424-0053) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.net (1.2.200.v20140124-2013) "Internet Connection Management" [Active]
org.eclipse.core.net.win32.x86 (1.0.100.v20140124-2013) "Proxy for Windows" [Resolved]
org.eclipse.core.resources (3.9.1.v20140825-1431) "Core Resource Management" [Active]
org.eclipse.core.resources.win32.x86 (3.5.100.v20140124-1940) "Core Resource Management Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.10.0.v20140318-2214) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.2.200.v20140128-0851) "Core Runtime Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.registry (3.5.300.v20140128-0851) "Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.2.800.v20130819-1716) "Core Variables" [Active]
org.eclipse.cvs (1.4.100.v20140925-0400) "Eclipse CVS Client" [Starting]
org.eclipse.debug.core (3.9.1.v20140805-1629) "Debug Core" [Active]
org.eclipse.debug.ui (3.10.1.v20140822-1408) "Debug UI" [Active]
org.eclipse.draw2d (3.9.101.201408150207) "Graphical Editing Framework Draw2d" [Starting]
org.eclipse.e4.core.commands (0.10.2.v20140424-2344) "Eclipse e4 core commands" [Active]
org.eclipse.e4.core.contexts (1.3.100.v20140407-1019) "Eclipse Contexts" [Active]
org.eclipse.e4.core.di (1.4.0.v20140414-1837) "Eclipse Dependency Injection" [Active]
org.eclipse.e4.core.di.extensions (0.12.0.v20140417-2033) "Eclipse Dependency Injection Extensions" [Active]
org.eclipse.e4.core.services (1.2.1.v20140808-1251) "Eclipse Application Services" [Active]
org.eclipse.e4.ui.bindings (0.10.200.v20140424-2042) "Eclipse Bindings Support" [Active]
org.eclipse.e4.ui.css.core (0.10.100.v20140424-2042) "Eclipse CSS Core Support" [Resolved]
org.eclipse.e4.ui.css.swt (0.11.101.v20140818-1343) "Eclipse CSS SWT Support" [Active]
org.eclipse.e4.ui.css.swt.theme (0.9.300.v20140424-2042) "Eclipse CSS SWT Theme Support" [Active]
org.eclipse.e4.ui.di (1.0.0.v20140328-2112) "Eclipse UI Dependency Injection" [Active]
org.eclipse.e4.ui.model.workbench (1.1.0.v20140512-1820) "Eclipse Workbench Model" [Active]
org.eclipse.e4.ui.services (1.1.0.v20140328-1925) "Eclipse UI Application Services" [Active]
org.eclipse.e4.ui.widgets (1.0.0.v20140514-1823) "Eclipse UI Custom widgets" [Resolved]
org.eclipse.e4.ui.workbench (1.2.1.v20140901-1244) "Eclipse e4 Workbench" [Active]
org.eclipse.e4.ui.workbench.addons.swt (1.1.1.v20140903-0821) "Eclipse e4 Workbench Add-ons" [Active]
org.eclipse.e4.ui.workbench.renderers.swt (0.12.1.v20140903-1023) "Eclipse e4 Workbench SWT Renderer" [Active]
org.eclipse.e4.ui.workbench.swt (0.12.100.v20140530-1436) "Eclipse e4 Workbench SWT" [Active]
org.eclipse.e4.ui.workbench3 (0.12.0.v20140227-2118) "Bundle for Workbench APIs available in e4" [Resolved]
org.eclipse.ecf (3.4.0.v20140827-1444) "ECF Core API" [Starting]
org.eclipse.ecf.filetransfer (5.0.0.v20140827-1444) "ECF Filetransfer API" [Starting]
org.eclipse.ecf.identity (3.4.0.v20140827-1444) "ECF Identity Core API" [Starting]
org.eclipse.ecf.provider.filetransfer (3.2.200.v20140827-1444) "ECF Filetransfer Provider" [Starting]
org.eclipse.ecf.provider.filetransfer.httpclient4 (1.0.800.v20140827-1444) "ECF HttpComponents Filetransfer Provider" [Starting]
org.eclipse.ecf.provider.filetransfer.httpclient4.ssl (1.0.0.v20140827-1444) "ECF HttpComponents Filetransfer Provider" [Resolved]
org.eclipse.ecf.provider.filetransfer.ssl (1.0.0.v20140827-1444) "ECF Filetransfer Provider" [Resolved]
org.eclipse.ecf.ssl (1.1.0.v20140827-1444) "ECF Core API" [Resolved]
org.eclipse.emf.common (2.10.1.v20140901-1043) "EMF Common" [Active]
org.eclipse.emf.ecore (2.10.1.v20140901-1043) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.10.0.v20140901-1043) "EMF Change Model" [Starting]
org.eclipse.emf.ecore.xmi (2.10.1.v20140901-1043) "EMF XML/XMI Persistence" [Active]
org.eclipse.equinox.app (1.3.200.v20130910-1609) "Equinox Application Container" [Active]
org.eclipse.equinox.bidi (0.10.0.v20130327-1442) "Bidirectional Text Support" [Starting]
org.eclipse.equinox.common (3.6.200.v20130402-1505) "Common Eclipse Runtime" [Active]
org.eclipse.equinox.concurrent (1.1.0.v20130327-1442) "Equinox Concurrent API" [Starting]
org.eclipse.equinox.console (1.1.0.v20140131-1639) "Console plug-in" [Active]
org.eclipse.equinox.ds (1.4.200.v20131126-2331) "Declarative Services" [Active]
org.eclipse.equinox.event (1.3.100.v20140115-1647) "Event Admin" [Active]
org.eclipse.equinox.frameworkadmin (2.0.100.v20131209-2144) "Equinox Framework Admin" [Starting]
org.eclipse.equinox.frameworkadmin.equinox (1.0.500.v20131211-1531) "Equinox Framework Admin for Equinox" [Starting]
org.eclipse.equinox.http.jetty (3.0.200.v20131021-1843) "Jetty Http Service" [Starting]
org.eclipse.equinox.http.registry (1.1.300.v20130402-1529) "Http Service Registry Extensions" [Resolved]
org.eclipse.equinox.http.servlet (1.1.500.v20140318-1755) "Http Services Servlet" [Starting]
org.eclipse.equinox.jsp.jasper (1.0.400.v20130327-1442) "Jasper Jsp Support Bundle" [Starting]
org.eclipse.equinox.jsp.jasper.registry (1.0.300.v20130327-1442) "Jasper Jsp Registry Support Plug-in" [Starting]
org.eclipse.equinox.launcher (1.3.0.v20140415-2008) "Equinox Launcher" [Resolved]
org.eclipse.equinox.launcher.win32.win32.x86 (1.1.200.v20140603-1326) "Equinox Launcher Win32 X86 Fragment" [Resolved]
org.eclipse.equinox.p2.artifact.repository (1.1.300.v20131211-1531) "Equinox Provisioning Artifact Repository Support" [Starting]
org.eclipse.equinox.p2.console (1.0.300.v20131113-1212) "Equinox Provisioning Console" [Starting]
org.eclipse.equinox.p2.core (2.3.0.v20131211-1531) "Equinox Provisioning Core" [Active]
org.eclipse.equinox.p2.director (2.3.100.v20140224-1921) "Equinox Provisioning Director" [Starting]
org.eclipse.equinox.p2.director.app (1.0.300.v20140228-1829) "Equinox Provisioning Director Application" [Starting]
org.eclipse.equinox.p2.directorywatcher (1.1.0.v20131211-1531) "Equinox Provisioning Directory Watcher" [Active]
org.eclipse.equinox.p2.engine (2.3.0.v20140506-1720) "Equinox Provisioning Engine" [Active]
org.eclipse.equinox.p2.extensionlocation (1.2.100.v20131119-0908) "Equinox Provisioning Extension Location Repository Support" [Starting]
org.eclipse.equinox.p2.garbagecollector (1.0.200.v20131115-1210) "Equinox Provisioning Garbage Collector" [Starting]
org.eclipse.equinox.p2.jarprocessor (1.0.300.v20131211-1531) "Equinox Provisioning JAR Processor" [Resolved]
org.eclipse.equinox.p2.metadata (2.2.0.v20131211-1531) "Equinox Provisioning Metadata" [Active]
org.eclipse.equinox.p2.metadata.repository (1.2.100.v20131209-2144) "Equinox Provisioning Metadata Repository" [Active]
org.eclipse.equinox.p2.operations (2.4.0.v20131119-0908) "Equinox Provisioning Operations API" [Active]
org.eclipse.equinox.p2.publisher (1.3.0.v20140911-0143) "Equinox Provisioning Publisher Infrastructure" [Starting]
org.eclipse.equinox.p2.publisher.eclipse (1.1.200.v20140414-0825) "Equinox Provisioning Publisher for Eclipse" [Starting]
org.eclipse.equinox.p2.ql (2.0.100.v20131211-1531) "Equinox Provisioning p2 query language" [Starting]
org.eclipse.equinox.p2.reconciler.dropins (1.1.200.v20131119-0908) "Equinox Provisioning Drop-in" [Active]
org.eclipse.equinox.p2.repository (2.3.0.v20131211-1531) "Equinox Provisioning Repository" [Active]
org.eclipse.equinox.p2.repository.tools (2.1.0.v20131211-1531) "Equinox Provisioning Repository Tools" [Starting]
org.eclipse.equinox.p2.touchpoint.eclipse (2.1.200.v20140512-1650) "Equinox Provisioning Eclipse Touchpoint" [Starting]
org.eclipse.equinox.p2.touchpoint.natives (1.1.100.v20140523-0116) "Equinox Provisioning Native Touchpoint" [Starting]
org.eclipse.equinox.p2.transport.ecf (1.1.0.v20140408-1354) "Equinox Provisioning ECF based Transport" [Starting]
org.eclipse.equinox.p2.ui (2.3.0.v20140404-1657) "Equinox Provisioning UI Support" [Active]
org.eclipse.equinox.p2.ui.importexport (1.1.0.v20131210-1027) "Equinox Provisioning Import and Export" [Starting]
org.eclipse.equinox.p2.ui.sdk (1.0.300.v20140407-1803) "Equinox Provisioning Platform Update Support" [Active]
org.eclipse.equinox.p2.ui.sdk.scheduler (1.2.0.v20140422-1847) "Equinox Provisioning Platform Automatic Update Support" [Active]
org.eclipse.equinox.p2.updatechecker (1.1.200.v20131119-0908) "Equinox Provisioning Update Checker" [Active]
org.eclipse.equinox.p2.updatesite (1.0.400.v20131211-1531) "Equinox Provisioning Legacy Update Site Support" [Starting]
org.eclipse.equinox.preferences (3.5.200.v20140224-1527) "Eclipse Preferences Mechanism" [Active]
org.eclipse.equinox.registry (3.5.400.v20140428-1507) "Extension Registry Support" [Active]
org.eclipse.equinox.security (1.2.0.v20130424-1801) "Equinox Java Authentication and Authorization Service (JAAS)" [Active]
org.eclipse.equinox.security.ui (1.1.200.v20130626-2037) "Equinox Security Default UI" [Starting]
org.eclipse.equinox.security.win32.x86 (1.0.300.v20130327-1442) "Windows Data Protection services integration" [Resolved]
org.eclipse.equinox.simpleconfigurator (1.1.0.v20131217-1203) "Simple Configurator" [Active]
org.eclipse.equinox.simpleconfigurator.manipulator (2.0.0.v20131217-1203) "Simple Configurator Manipulator" [Starting]
org.eclipse.equinox.util (1.0.500.v20130404-1337) "Equinox Util Bundle" [Active]
org.eclipse.gef (3.9.100.201408150207) "Graphical Editing Framework GEF" [Starting]
org.eclipse.help (3.6.0.v20130326-1254) "Help System Core" [Active]
org.eclipse.help.base (4.0.200.v20140925-0400) "Help System Base" [Starting]
org.eclipse.help.ui (4.0.100.v20140401-0608) "Help System UI" [Starting]
org.eclipse.help.webapp (3.6.300.v20140407-1855) "Help System Webapp" [Starting]
org.eclipse.jetty.continuation (8.1.14.v20131031) "Jetty :: Continuation" [Resolved]
org.eclipse.jetty.http (8.1.14.v20131031) "Jetty :: Http Utility" [Resolved]
org.eclipse.jetty.io (8.1.14.v20131031) "Jetty :: IO Utility" [Resolved]
org.eclipse.jetty.security (8.1.14.v20131031) "Jetty :: Security" [Resolved]
org.eclipse.jetty.server (8.1.14.v20131031) "Jetty :: Server Core" [Resolved]
org.eclipse.jetty.servlet (8.1.14.v20131031) "Jetty :: Servlet Handling" [Resolved]
org.eclipse.jetty.util (8.1.14.v20131031) "Jetty :: Utilities" [Resolved]
org.eclipse.jface (3.10.1.v20140813-1009) "JFace" [Active]
org.eclipse.jface.databinding (1.6.200.v20140528-1422) "JFace Data Binding for SWT and JFace" [Resolved]
org.eclipse.jface.text (3.9.1.v20140827-1810) "JFace Text" [Resolved]
org.eclipse.jsch.core (1.1.500.v20131112-1442) "JSch Core" [Starting]
org.eclipse.jsch.ui (1.1.500.v20131112-1442) "JSch UI" [Starting]
org.eclipse.ltk.core.refactoring (3.6.101.v20140817-1500) "Refactoring Core" [Active]
org.eclipse.ltk.ui.refactoring (3.7.100.v20140324-1358) "Refactoring UI" [Active]
org.eclipse.osgi (3.10.1.v20140909-1633) "OSGi System Bundle" [Active]
org.eclipse.osgi.compatibility.state (1.0.1.v20140709-1414) "Equinox State and Resolver Compatibility Fragment" [Resolved]
org.eclipse.osgi.services (3.4.0.v20140312-2051) "OSGi Release 4.2.0 Services" [Resolved]
org.eclipse.osgi.util (3.3.0.v20131023-1243) "OSGi Release 4.2.0 Utility Classes" [Resolved]
org.eclipse.platform (4.4.0.v20140925-0400) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.user (4.4.1.v20140829-1306) "Eclipse Workbench User Guide" [Resolved]
org.eclipse.rcp (4.3.100.v20140925-0400) "Eclipse RCP" [Starting]
org.eclipse.search (3.9.100.v20140226-1637) "Search Support" [Active]
org.eclipse.swt (3.103.1.v20140903-1938) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.103.1.v20140903-1947) "Standard Widget Toolkit for Windows" [Resolved]
org.eclipse.team.core (3.7.0.v20130514-1224) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.3.600.v20131112-1442) "CVS Team Provider Core" [Starting]
org.eclipse.team.cvs.ssh2 (3.2.400.v20131112-1442) "CVS SSH2" [Starting]
org.eclipse.team.cvs.ui (3.3.600.v20130514-1224) "CVS Team Provider UI" [Starting]
org.eclipse.team.ui (3.7.100.v20130710-1213) "Team Support UI" [Starting]
org.eclipse.text (3.5.300.v20130515-1451) "Text" [Resolved]
org.eclipse.ui (3.106.0.v20140812-1751) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.4.200.v20131003-1453) "Browser Support" [Active]
org.eclipse.ui.cheatsheets (3.4.200.v20131227-1524) "Cheat Sheets" [Starting]
org.eclipse.ui.console (3.5.300.v20140424-1437) "Console" [Active]
org.eclipse.ui.editors (3.8.200.v20140401-1310) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.2.300.v20140327-1949) "External Tools" [Active]
org.eclipse.ui.forms (3.6.100.v20140422-1825) "Eclipse Forms" [Active]
org.eclipse.ui.ide (3.10.1.v20140828-0944) "Eclipse IDE UI" [Active]
org.eclipse.ui.ide.application (1.0.500.v20140514-2033) "Eclipse IDE UI Application" [Resolved]
org.eclipse.ui.intro (3.4.200.v20130326-1254) "Welcome Framework" [Starting]
org.eclipse.ui.intro.universal (3.2.700.v20130904-1701) "Universal Welcome" [Starting]
org.eclipse.ui.navigator (3.5.401.v20140724-1117) "Common Navigator View" [Active]
org.eclipse.ui.navigator.resources (3.4.700.v20140407-1004) "Navigator Workbench Components" [Active]
org.eclipse.ui.net (1.2.200.v20120807-0927) "Internet Connection Management UI" [Active]
org.eclipse.ui.themes (1.0.1.v20140819-1717) "Eclipse SDK Themes" [Active]
org.eclipse.ui.views (3.7.0.v20140408-0703) "Views" [Active]
org.eclipse.ui.views.properties.tabbed (3.6.0.v20140519-0906) "Tabbed Properties View" [Starting]
org.eclipse.ui.win32 (3.2.400.v20140423-2207) "Eclipse UI Win32 Enhancements" [Resolved]
org.eclipse.ui.workbench (3.106.1.v20140827-1737) "Eclipse Workbench" [Active]
org.eclipse.ui.workbench.texteditor (3.9.0.v20140411-1521) "Text Editor Framework" [Active]
org.eclipse.update.configurator (3.3.300.v20140518-1928) "Install/Update Configurator" [Active]
org.sat4j.core (2.3.5.v201308161310) "SAT4J Core" [Resolved]
org.sat4j.pb (2.3.5.v201404071733) "SAT4J Pseudo" [Resolved]
org.w3c.css.sac (1.3.1.v200903091627) "W3C CSS SAC" [Resolved]
org.w3c.dom.events (3.0.0.draft20060413_v201105210656) "W3C DOM Level 3 Events" [Resolved]
org.w3c.dom.smil (1.0.0.v200806040011) "W3C SMIL DOM" [Resolved]
org.w3c.dom.svg (1.1.0.v201011041433) "W3C SVG DOM" [Resolved]
*** User Preferences:
#Fri Mar 13 14:35:49 EET 2015
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.keep_imple_if_on_one_line=false
/bundle_defaults/org.eclipse.debug.ui/org.eclpise.debug.ui.memory.dynamicLoad=true
/bundle_defaults/org.eclipse.core.resources/refresh.enabled=false
/bundle_defaults/org.eclipse.ui.editors/revisionRulerShowRevision=false
/bundle_defaults/org.eclipse.ui.editors/showEnclosedIdeographicSpaces=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.wait_for_build=always
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_empty_lines=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enum.enabled=false
/bundle_defaults/org.eclipse.cdt.ui/c_numbers=0,0,0
/bundle_defaults/org.eclipse.core.net/proxyData/SOCKS/port=-1
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_i2c.com.crt.advproject.projecttype.exe.1156213048/com.crt.advproject.config.exe.debug.1628265668=com.crt.advproject.gas.exe.debug.233328306\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.712719831\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.395675803\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1148277983\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1628265668\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1824689233\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.771600061\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.debug.core/org.eclipse.cdt.debug.corecDebug.default_variable_format=0
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.CappingDisable=false
/bundle_defaults/org.eclipse.cdt.ui/content_assist_default_argument_display_arguments=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_before_else_in_if_statement=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.lineSplit=80
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.build_before_launch=true
/bundle_defaults/com.crt.debugcommon/showJtagConfig=false
/bundle_defaults/org.eclipse.cdt.core/indexer/indexAllFiles=true
/bundle_defaults/org.eclipse.ui.editors/lineNumberRuler=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_can.com.crt.advproject.projecttype.exe.1549120935/com.crt.advproject.config.exe.debug.1793298790=com.crt.advproject.link.exe.debug.1086263632\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.301086546\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.1802943088\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.2001482070\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1607471089\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1793298790\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1898004798\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/com.crt.dsfdebug/restartDisabled=false
/bundle_defaults/com.crt.debugcommon/overrideSemihosting=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.overloadedOperator.enabled=false
/bundle_defaults/com.crt.debugcommon/stuboutput=server
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.detail_pane_word_wrap=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_closing_brace_in_block=insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.method.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enumerator.color=0,0,192
/bundle_defaults/org.eclipse.cdt.ui/content_assist_autoinsert=true
/bundle_defaults/org.eclipse.debug.ui/Console.wrap=false
/bundle_defaults/org.eclipse.ui.editors/changeIndicationInOverviewRuler=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/lpc_board_nxp_lpcxpresso_1769.com.crt.advproject.projecttype.lib.1078462419/com.crt.advproject.config.lib.release.207171896=com.crt.advproject.config.lib.release.207171896\=rcState\\\=-1\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.release.47261584\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.ar.lib.release.2088203039\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.release.129627712\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.release.845687461\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.release.24618102\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.overrideIndicatorColor=180,207,205
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_conditional_expression=34
/bundle_defaults/org.eclipse.cdt.ui/scalability.semanticHighlight=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_i2c.com.crt.advproject.projecttype.exe.1156213048/com.crt.advproject.config.exe.release.447110820=com.crt.advproject.gcc.exe.release.228429012\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.794665935\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.2065030373\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.107787932\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.303648522\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1909782007\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.error.color=255,0,0
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_default_inactive=false
@org.eclipse.cdt.ui=5.8.1.201409172108
/bundle_defaults/org.eclipse.cdt.ui/org.eclipse.cdt.internal.ui.text.doctools.doxygen.recognizedTag=127,159,191
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enabled=true
/bundle_defaults/com.crt.debugcommon/cmsisdap_multi_swd=false
/bundle_defaults/org.eclipse.ui.ide/MARKER_LIMITS_VALUE=100
/bundle_defaults/org.eclipse.ui.editors/spellingEngine=
/bundle_defaults/org.eclipse.ui.ide/IMPORT_FILES_AND_FOLDERS_TYPE=
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_method_declaration_parameters=do not insert
/bundle_defaults/org.eclipse.ui.ide/CLOSE_UNRELATED_PROJECTS=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enumerator.strikethrough=false
/bundle_defaults/org.eclipse.ui.editors/showErrorInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_method_invocation_arguments=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_bracket=do not insert
/instance/org.eclipse.cdt.ui/useAnnotationsPrefPage=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.namespace.italic=false
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleWrapLines=false
/bundle_defaults/org.eclipse.ui.editors/showTaskInNextPrevDropdownToolbarAction=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSISv2p00_LPC17xx.com.crt.advproject.projecttype.lib.1193160240/com.crt.advproject.config.lib.debug.1814355025=com.crt.advproject.toolchain.lib.debug.1548108302\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.1814355025\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.1004026908\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.1199056603\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.2004041978\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.1604093373\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_enabled=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS-CORE_LPC407x_8x.com.crt.advproject.projecttype.lib.1117785161/com.crt.advproject.config.lib.debug.1588975745=com.crt.advproject.toolchain.lib.debug.328928775\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.1588975745\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.775312103\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.221963309\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.1338608115\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.1509436562\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.class.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enum.bold=false
/bundle_defaults/org.eclipse.cdt.ui/spelling_ignore_sentence=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_closing_angle_bracket_in_template_arguments=insert
/bundle_defaults/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_DIALOG=true
/bundle_defaults/org.eclipse.cdt.core/indexer/useHeuristicIncludeResolution=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroDefinition.strikethrough=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_closing_paren_in_cast=insert
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_CORE_LPC8xx.com.crt.advproject.projecttype.lib.1939000741/com.crt.advproject.config.lib.debug.971437645=com.crt.advproject.cpp.lib.debug.919233593\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.971437645\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.659785245\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.65527192\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.397544059\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.597267139\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk.scheduler/schedule=on-startup
/bundle_defaults/org.eclipse.ui.editors/warningIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.warning.overview=true
/bundle_defaults/org.eclipse.ui/LINK_NAVIGATOR_TO_EDITOR=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_CORE_LPC11Uxx.com.crt.advproject.projecttype.lib.1741498279/com.crt.advproject.config.lib.debug.1849963468=com.crt.advproject.ar.lib.debug.2069571765\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.546768532\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.1398100781\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.255055000\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.1207749252\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.1849963468\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.defaultAsciiCodePage=CP1252
/bundle_defaults/com.crt.utils/wizardHome=
/bundle_defaults/org.eclipse.cdt.ui/content_assist_current_file_search_scope=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.overrideIndicatorInVerticalRuler=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.class.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/org.eclipse.cdt.ui.editor.showSegments=false
/bundle_defaults/org.eclipse.ui.workbench/REUSE_DIRTY_EDITORS=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/lwip_tcpecho_freertos.com.crt.advproject.projecttype.exe.1420589482/com.crt.advproject.config.exe.debug.590435786=com.crt.advproject.link.cpp.exe.debug.1900712405\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1420949215\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1982606965\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1047653261\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.590435786\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.800053964\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1759785151\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.workbench/perspectiveBarVisible=true
/bundle_defaults/org.eclipse.cdt.ui/spelling_ignore_upper=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_LPC18xx_DriverLib.com.crt.advproject.projecttype.lib.2008270429/com.crt.advproject.config.lib.debug.558990107=com.crt.advproject.ar.lib.debug.2089549182\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.315045615\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.410362843\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.1064384326\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.641404760\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.558990107\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/secondaryIPTextStyle=NONE
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariable.italic=false
/bundle_defaults/org.eclipse.ui.workbench/OPEN_PERSPECTIVE_MODE=0
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.test.prefix=
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_timer.com.crt.advproject.projecttype.exe.1309499312/com.crt.advproject.config.exe.release.2130611758=com.crt.advproject.toolchain.exe.release.371298027\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.788026692\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1944172024\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.215350013\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1560242080\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.557206652\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.debug.ui/Console.width=80
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.systemWithoutExtension=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style angle_brackets\="true" blank_line_before\="false" keep_together\="true" order\="2" relative_path\="false"/>
/bundle_defaults/org.eclipse.ui.editors/printMarginColor=176,180,185
/bundle_defaults/org.eclipse.ui.editors/linked.focus.color=50,70,120
/bundle_defaults/org.eclipse.cdt.ui/forwardDeclare.namespaceElements=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/lpc_chip_175x_6x.com.crt.advproject.projecttype.lib.1977998334/com.crt.advproject.config.lib.release.748848757=com.crt.advproject.gas.lib.release.1568034180\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.release.1757629049\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.release.748848757\=rcState\\\=-1\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.release.1488485948\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.lib.release.474949157\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.release.199714480\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/com.crt.dsfdebug/debuggerPathFix=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_base_types=do not insert
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.field.prefix=
/bundle_defaults/org.eclipse.cdt.ui/autoIndent=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/usbd_lib_hid_mouse.com.crt.advproject.projecttype.exe.1164772426/com.crt.advproject.config.exe.release.682907672=com.crt.advproject.link.cpp.exe.release.1811715833\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.918384092\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1175370789\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.1615735383\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.775007655\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1088698866\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/c_string_italic=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_declaration_compare_to_template_header=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_uart_rb.com.crt.advproject.projecttype.exe.1950633819/com.crt.advproject.config.exe.debug.1365584524=com.crt.advproject.toolchain.exe.debug.1113849227\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.1843758335\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1334949695\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.38449263\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.386306012\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.47576862\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1365584524\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/filteredSearchResultIndicationColor=237,237,252
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.error.ruler=true
/bundle_defaults/org.eclipse.debug.ui/Breakpoints.detail.orientation=Variables.detail.orientation.underneath
/bundle_defaults/org.eclipse.ui.editors/currentIPColor=198,219,174
@org.eclipse.core.net=1.2.200.v20140124-2013
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.warning.textstyle=SQUIGGLES
/bundle_defaults/org.eclipse.cdt.ui/scalability.enableAll=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.consoleBackground=255,255,255
/bundle_defaults/org.eclipse.cdt.ui/c_numbers_bold=false
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.UseSingleLine=true
/bundle_defaults/org.eclipse.ui.workbench/DISABLE_DIALOG_FONT=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_block=end_of_line
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.test.capitalization=0
/bundle_defaults/org.eclipse.ui.editors/linked.slave.overviewruler=false
/bundle_defaults/org.eclipse.cdt.dsf.gdb/defaultStopAtMain=true
/bundle_defaults/org.eclipse.ui.editors/indexResultIndicationInVerticalRuler=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/freertos_blinky.com.crt.advproject.projecttype.exe.1693076455/com.crt.advproject.config.exe.debug.897255787=com.crt.advproject.link.exe.debug.1302659769\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1225049255\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.24640360\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.272389732\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.897255787\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.51313821\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.475703418\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_angle_bracket_in_template_arguments=do not insert
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.occurrenceIndicationInOverviewRuler=true
/bundle_defaults/com.crt.debugcommon/debuggerInit=
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.function.bold=true
@org.eclipse.cdt.dsf.ui=2.4.100.201409172108
/bundle_defaults/org.eclipse.ui.editors/taskIndicationHighlighting=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.field.capitalization=4
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_binary_operator=insert
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.source.suffix=.cpp
/bundle_defaults/org.eclipse.cdt.ui/asm_label_italic=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.ExpressionView+org.eclipse.debug.ui.ShowDetailPaneAction=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/usbd_lib_hid_keyboard.com.crt.advproject.projecttype.exe.944853395/com.crt.advproject.config.exe.debug.234199146=com.crt.advproject.config.exe.debug.234199146\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1056025160\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1144847496\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1535204238\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.47077161\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.1096740313\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1947046434\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/isChangeGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/secondaryIPHighlight=true
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.variable.prefix=
/bundle_defaults/org.eclipse.ui.editors/linked.slave.navigation.dropdown=false
/bundle_defaults/org.eclipse.ui.editors/showLeadingIdeographicSpaces=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.continuation_indentation_for_array_initializer=2
/bundle_defaults/org.eclipse.cdt.debug.core/org.eclipse.cdt.debug.corecDebug.default_expression_format=0
/instance/org.eclipse.cdt.dsf.ui/useAnnotationsPrefPage=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.functionDeclaration.enabled=true
/bundle_defaults/org.eclipse.cdt.ui/content_assist_prefix_completion=true
/bundle_defaults/com.crt.debugcommon/redlink_server_shutdown=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_semicolon_in_for=insert
/bundle_defaults/org.eclipse.cdt.core/build.all.configs.enabled=false
/bundle_defaults/org.eclipse.cdt.core/indexer/skipImplicitReferences=false
/bundle_defaults/com.crt.debugcommon/debuggerTimeout=10
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.maxIndexDBCacheSizeMB=64
/bundle_defaults/org.eclipse.ui/presentationFactoryId=org.eclipse.ui.presentations.default
/bundle_defaults/org.eclipse.ui.editors/Accessibility.UseSaturatedColors=false
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Accessibility.UseCustomCarets=true
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.RemovedLinesRegex=
/bundle_defaults/org.eclipse.cdt.core/includes.endExportsPattern=IWYU\\s+(pragma\:?\\s+)?end_exports?
/bundle_defaults/org.eclipse.cdt.dsf.gdb/org.eclipse.cdt.dsf.gdb.useRtti=true
/bundle_defaults/org.eclipse.ui.editors/spellingEnabled=true
/bundle_defaults/org.eclipse.cdt.dsf.gdb/defaultNonStop=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.typedef.enabled=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_for=do not insert
/bundle_defaults/org.eclipse.debug.ui/Console.lowWaterMark=80000
/bundle_defaults/org.eclipse.ui.editors/showLeadingSpaces=true
/bundle_defaults/org.eclipse.ui.editors/linked.target.color=170,185,220
/bundle_defaults/org.eclipse.ui.ide/BOOKMARKS_LIMIT=100
/bundle_defaults/org.eclipse.ui.editors/isIndexResultGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.dsf.gdb/org.eclipse.cdt.dsf.gdb.aggressiveBpFilter=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.externalSDK.enabled=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.warning.GoToPreviousNavigationTarget=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_assignment_operator=insert
/instance/org.eclipse.cdt.managedbuilder.core/properties/lpcusblib_KeyboardHost.com.crt.advproject.projecttype.exe.1776494588/com.crt.advproject.config.exe.debug.332576409=com.crt.advproject.cpp.exe.debug.1763337745\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1794156581\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.547450235\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.39850578\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.578710282\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.153195668\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.332576409\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.changedDebugElement=255,0,0
@org.eclipse.debug.core=3.9.1.v20140805-1629
/bundle_defaults/org.eclipse.ui.editors/showInfoInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.cdt.ui/pp_default_italic=false
/bundle_defaults/org.eclipse.ui.editors/spellingIndication=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.problem.color=224,0,0
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_unary_operator=do not insert
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.PathFilter=
/bundle_defaults/org.eclipse.ui.editors/isFilteredSearchResultGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.methodDeclaration.strikethrough=false
/bundle_defaults/org.eclipse.ui.editors/bookmarkIndicationColor=34,164,99
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_while=insert
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.other=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style blank_line_before\="true" keep_together\="true" order\="3"/>
/bundle_defaults/com.crt.debugcommon/LPC-Link\ (WinUSB)\ or\ RDB-Link=true
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_default_structures=false
/bundle_defaults/org.eclipse.cdt.ui/c_multi_line_comment_italic=false
/bundle_defaults/org.eclipse.ui.editors/hyperlinkKeyModifierMask=262144
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.overloadedOperator.underline=false
/bundle_defaults/org.eclipse.ui.editors/isDeletionGoToNextNavigationTarget=false
/instance/org.eclipse.ui.ide/platformState=1426237440991
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.max_history_size=10
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_colon_in_labeled_statement=do not insert
/bundle_defaults/com.crt.debugcommon/redlink_boot_state=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_statements_compare_to_block=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.activate_debug_view=true
@org.eclipse.ui.browser=3.4.200.v20131003-1453
/bundle_defaults/org.eclipse.ui/DOCK_PERSPECTIVE_BAR=topLeft
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_blinky.com.crt.advproject.projecttype.exe.424940172/com.crt.advproject.config.exe.release.835156494=com.crt.advproject.gcc.exe.release.1591236150\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.release.1645349510\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.298607713\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.543793768\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.318297782\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1446495013\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.release.835156494\=rcState\\\=-1\\r\\nrebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_parenthesized_expression=do not insert
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.error.text=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_catch=insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.label.enabled=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_ritimer.com.crt.advproject.projecttype.exe.749237195/com.crt.advproject.config.exe.release.1763634750=com.crt.advproject.gas.exe.release.936462419\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.189745666\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1063923478\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1679678845\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.1550794809\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1411309420\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.workbench/REUSE_OPEN_EDITORS=8
/bundle_defaults/org.eclipse.cdt.ui/markOverloadedOperatorsOccurrences=false
/bundle_defaults/org.eclipse.ui.editors/linked.slave.highlight=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.join_wrapped_lines=true
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.source.capitalization=0
/instance/org.eclipse.cdt.managedbuilder.core/properties/iperf_server.com.crt.advproject.projecttype.exe.1230739403/com.crt.advproject.config.exe.debug.1512339721=com.crt.advproject.toolchain.exe.debug.380405632\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.387641087\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.463030857\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.51870270\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.472993163\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.762089801\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1512339721\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/forwardDeclare.externalVariables=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_exception_specification=do not insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroSubstitution.strikethrough=false
/bundle_defaults/org.eclipse.debug.core/org.eclipse.debug.core.PREF_BREAKPOINT_MANAGER_ENABLED_STATE=true
/bundle_defaults/org.eclipse.ui.editors/overviewRuler=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.namespace.enabled=false
/bundle_defaults/org.eclipse.ui.editors/additionIndicationColor=188,188,222
/bundle_defaults/org.eclipse.cdt.ui/c_string=42,0,255
/bundle_defaults/org.eclipse.debug.ui/Registers.detail.orientation=Variables.detail.orientation.underneath
/bundle_defaults/org.eclipse.cdt.ui/organizeIncludes.allowPartnerIndirectInclusion=true
/bundle_defaults/org.eclipse.ui.editors/com.crt.etmetb.marker.profile.pref.high=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.isOccurrenceGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.templateParameter.bold=true
/bundle_defaults/org.eclipse.cdt.debug.core/org.eclipse.cdt.debug.corecDebug.default_register_format=0
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroSubstitution.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.function.strikethrough=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.writeOccurrenceIndicationColor=240,216,168
/bundle_defaults/org.eclipse.ui.ide/EXIT_PROMPT_ON_CLOSE_LAST_WINDOW=true
/bundle_defaults/org.eclipse.ui.editors/printMargin=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_ssp.com.crt.advproject.projecttype.exe.2073917783/com.crt.advproject.config.exe.debug.132243330=com.crt.advproject.config.exe.debug.132243330\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1276505785\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1415199486\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.670756160\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.2080663046\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1855615787\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.425397908\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.constant.wordDelimiter=_
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_template_arguments=insert
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.errorColor=255,0,0
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.taskTags=TODO,FIXME,XXX
/bundle_defaults/org.eclipse.ui.editors/isSpellingGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.ui/spelling_problems_threshold=100
/bundle_defaults/org.eclipse.cdt.ui/content_assist_default_argument_display_parameters_with_default_argument=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariable.color=0,0,0
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.codeReaderCache=64
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariableDeclaration.italic=false
/bundle_defaults/org.eclipse.ui.editors/revisionAnnotationIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.partner=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style angle_brackets\="false" blank_line_before\="true" keep_together\="true" order\="0" relative_path\="false"/>
/bundle_defaults/org.eclipse.cdt.ui/subWordNavigation=true
/bundle_defaults/org.eclipse.debug.ui/DEBUG.consoleOpenOnOut=true
/bundle_defaults/org.eclipse.cdt.ui/asm_directive=127,0,85
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.error.NextPrevDropdownToolbar=true
/bundle_defaults/org.eclipse.cdt.ui/org.eclipse.cdt.ui.editor.linkToEditor=false
/bundle_defaults/org.eclipse.ui.editors/linked.slave.navigation.next=false
/bundle_defaults/org.eclipse.ui.editors/isErrorGoToPreviousNavigationTarget=true
/configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_DIALOG=true
/bundle_defaults/org.eclipse.ui.editors/linked.focus.navigation.previous=false
/bundle_defaults/org.eclipse.cdt.ui/content_assist_parameters_background=255,255,255
/instance/org.eclipse.debug.core//org.eclipse.debug.core.PREFERRED_DELEGATES/org.eclipse.cdt.launch.applicationLaunchType=org.eclipse.cdt.dsf.gdb.launch.localCLaunch,debug,;org.eclipse.cdt.cdi.launch.localCLaunch,run,;
/bundle_defaults/org.eclipse.cdt.ui/asm_directive_italic=false
/bundle_defaults/org.eclipse.core.net/nonProxiedHosts=localhost|127.0.0.1
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_before_while_in_do_statement=do not insert
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.external=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style angle_brackets\="false" blank_line_before\="false" keep_together\="false" relative_path\="false"/>
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.reuse_editor=true
/bundle_defaults/org.eclipse.ui.ide/IMPORT_FILES_AND_FOLDERS_MODE=prompt
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.codeBytesColor=96,0,0
/bundle_defaults/org.eclipse.cdt.core/indexer/indexAllHeaderVersions=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.functionDeclaration.strikethrough=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_CORE_LPC13Uxx.com.crt.advproject.projecttype.lib.273512484/com.crt.advproject.config.lib.debug.673940478=com.crt.advproject.gas.lib.debug.198052387\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.847974778\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.2129923167\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.673940478\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.2123539662\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.1540782685\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.class.italic=false
/bundle_defaults/org.eclipse.ui.editors/breakpointIndicationInOverviewRuler=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_access_specifier_extra_spaces=0
/bundle_defaults/org.eclipse.ui.editors/showSearchResultInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.templateParameter.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/includes.partnerFileSuffixes=test,unittest
/bundle_defaults/org.eclipse.ui/SHOW_OPEN_ON_PERSPECTIVE_BAR=true
/bundle_defaults/org.eclipse.cdt.ui/pp_default_bold=false
/bundle_defaults/org.eclipse.ui.editors/spellingIndicationHighlighting=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.overrideIndicatorInOverviewRuler=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.namespace.underline=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.outColor=0,0,0
/bundle_defaults/org.eclipse.core.resources/description.applyfilestatepolicy=true
/bundle_defaults/org.eclipse.ui.editors/taskTextStyle=SQUIGGLES
/bundle_defaults/com.crt.debugcommon/redlink_kill_exit=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_bracket=do not insert
/bundle_defaults/org.eclipse.ui.ide/SYSTEM_EXPLORER=explorer /E,/select\=${selected_resource_loc}
/bundle_defaults/com.crt.debugcommon/displayAsyncErrors=true
/bundle_defaults/org.eclipse.ui.editors/infoIndicationColor=244,200,45
/bundle_defaults/com.crt.utils/quickstart.navstate=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroDefinition.enabled=false
/bundle_defaults/org.eclipse.ui.editors/filteredSearchResultTextStyle=SQUIGGLES
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.comment.never_indent_line_comments_on_first_column=true
/bundle_defaults/org.eclipse.ui.editors/quickdiff.nowarn.before.switch=
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_array_initializer=end_of_line
/bundle_defaults/org.eclipse.ui.editors/hoverReplaceMode=0
/bundle_defaults/org.eclipse.cdt.core/indexer/skipReferences=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.skip_breakpoints_during_run_to_line=false
/bundle_defaults/org.eclipse.cdt.dsf.ui/stackFrameLimit=10
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.keep_empty_array_initializer_on_one_line=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_before_identifier_in_function_declaration=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_colon_in_conditional=insert
/instance/org.eclipse.core.net/org.eclipse.core.net.hasMigrated=true
/bundle_defaults/org.eclipse.cdt.ui/content_assist_parameters_foreground=0,0,0
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.problem.italic=false
/bundle_defaults/org.eclipse.ui.editors/linked.exit.verticalruler=false
/bundle_defaults/com.crt.debugcommon/genericImageXP=LPCXpressoWIN.enc
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.tabulation.size=4
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticField.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.externalSDK.bold=true
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.endAddress=0x10000000000000000
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.typedef.color=0,80,50
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_between_empty_parens_in_method_declaration=do not insert
/bundle_defaults/com.crt.debugcommon/redlink_experimental=false
/bundle_defaults/org.eclipse.ui.editors/linked.target.navigation.dropdown=false
/bundle_defaults/org.eclipse.ui.editors/isIndexResultGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/showWhitespaceCharacters=false
/bundle_defaults/com.crt.utils/directories.bin=C\:\\nxp\\LPCXpresso_7.6.2_326\\lpcxpresso\\bin;C\:\\nxp\\LPCXpresso_7.6.2_326\\lpcxpresso\\msys\\bin;C\:\\nxp\\LPCXpresso_7.6.2_326\\lpcxpresso\\tools\\bin;
/bundle_defaults/com.crt.debugcommon/CMSIS-DAP=true
/bundle_defaults/org.eclipse.cdt.ui/org.eclipse.cdt.ui.editor.CUChildren=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_between_empty_braces_in_array_initializer=do not insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.functionDeclaration.color=0,0,0
/bundle_defaults/org.eclipse.ui.editors/indexResultIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.cdt.ui/smartPaste=true
/bundle_defaults/org.eclipse.ui/ENABLE_DETACHED_VIEWS=true
/bundle_defaults/org.eclipse.ui.editors/bookmarkIndicationInVerticalRuler=true
/bundle_defaults/org.eclipse.debug.ui/org.eclispe.debug.ui.memory.preBufferSize=20
/bundle_defaults/com.crt.advproject/multicoreslavetemplate=arm-none-eabi-objcopy --target elf32-littlearm --verbose --strip-all --redefine-sym %3$s\=%3$s%4$s --keep-symbol %3$s%4$s %2$s"%1$s" "%1$s.o"
/bundle_defaults/org.eclipse.ui.editors/taskIndicationInVerticalRuler=true
/bundle_defaults/org.eclipse.debug.ui/Modules.detail.orientation=Variables.detail.orientation.underneath
/bundle_defaults/org.eclipse.ui.workbench/TEXT_DIRECTION=
/bundle_defaults/org.eclipse.cdt.ui/content_assist_proposals_background=255,255,255
/bundle_defaults/org.eclipse.cdt.ui/organizeIncludes.headerSubstitution=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<maps>\r\n<map cpp_only\="false" name\="GCC C Header Substitution">\r\n<unconditional_substitution_map>\r\n<mapping key\="&lt;asm/errno.h&gt;" value\="&lt;errno.h&gt;"/>\r\n<mapping key\="&lt;asm/errno-base.h&gt;" value\="&lt;errno.h&gt;"/>\r\n<mapping key\="&lt;asm/ioctls.h&gt;" value\="&lt;sys/ioctl.h&gt;"/>\r\n<mapping key\="&lt;asm/posix_types_32.h&gt;" value\="&lt;asm/posix_types.h&gt;"/>\r\n<mapping key\="&lt;asm/posix_types_64.h&gt;" value\="&lt;asm/posix_types.h&gt;"/>\r\n<mapping key\="&lt;asm/ptrace-abi.h&gt;" value\="&lt;asm/ptrace.h&gt;"/>\r\n<mapping key\="&lt;asm/socket.h&gt;" value\="&lt;sys/socket.h&gt;"/>\r\n<mapping key\="&lt;asm/unistd.h&gt;" value\="&lt;syscall.h&gt;"/>\r\n<mapping key\="&lt;asm/unistd_32.h&gt;" value\="&lt;syscall.h&gt;"/>\r\n<mapping key\="&lt;asm/unistd_64.h&gt;" value\="&lt;syscall.h&gt;"/>\r\n<mapping key\="&lt;bits/a.out.h&gt;" value\="&lt;a.out.h&gt;"/>\r\n<mapping key\="&lt;bits/byteswap.h&gt;" value\="&lt;byteswap.h&gt;"/>\r\n<mapping key\="&lt;bits/cmathcalls.h&gt;" value\="&lt;complex.h&gt;"/>\r\n<mapping key\="&lt;bits/confname.h&gt;" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="&lt;bits/dirent.h&gt;" value\="&lt;dirent.h&gt;"/>\r\n<mapping key\="&lt;bits/dlfcn.h&gt;" value\="&lt;dlfcn.h&gt;"/>\r\n<mapping key\="&lt;bits/elfclass.h&gt;" value\="&lt;link.h&gt;"/>\r\n<mapping key\="&lt;bits/endian.h&gt;" value\="&lt;endian.h&gt;"/>\r\n<mapping key\="&lt;bits/environments.h&gt;" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="&lt;bits/errno.h&gt;" value\="&lt;errno.h&gt;"/>\r\n<mapping key\="&lt;bits/error.h&gt;" value\="&lt;error.h&gt;"/>\r\n<mapping key\="&lt;bits/fcntl.h&gt;" value\="&lt;fcntl.h&gt;"/>\r\n<mapping key\="&lt;bits/fcntl-linux.h&gt;" value\="&lt;fcntl.h&gt;"/>\r\n<mapping key\="&lt;bits/fcntl2.h&gt;" value\="&lt;fcntl.h&gt;"/>\r\n<mapping key\="&lt;bits/fenv.h&gt;" value\="&lt;fenv.h&gt;"/>\r\n<mapping key\="&lt;bits/fenvinline.h&gt;" value\="&lt;fenv.h&gt;"/>\r\n<mapping key\="&lt;bits/huge_val.h&gt;" value\="&lt;math.h&gt;"/>\r\n<mapping key\="&lt;bits/huge_valf.h&gt;" value\="&lt;math.h&gt;"/>\r\n<mapping key\="&lt;bits/huge_vall.h&gt;" value\="&lt;math.h&gt;"/>\r\n<mapping key\="&lt;bits/in.h&gt;" value\="&lt;netinet/in.h&gt;"/>\r\n<mapping key\="&lt;bits/inf.h&gt;" value\="&lt;math.h&gt;"/>\r\n<mapping key\="&lt;bits/ioctl-types.h&gt;" value\="&lt;sys/ioctl.h&gt;"/>\r\n<mapping key\="&lt;bits/ioctls.h&gt;" value\="&lt;sys/ioctl.h&gt;"/>\r\n<mapping key\="&lt;bits/ipc.h&gt;" value\="&lt;sys/ipc.h&gt;"/>\r\n<mapping key\="&lt;bits/ipctypes.h&gt;" value\="&lt;sys/ipc.h&gt;"/>\r\n<mapping key\="&lt;bits/libio-ldbl.h&gt;" value\="&lt;libio.h&gt;"/>\r\n<mapping key\="&lt;bits/link.h&gt;" value\="&lt;link.h&gt;"/>\r\n<mapping key\="&lt;bits/locale.h&gt;" value\="&lt;locale.h&gt;"/>\r\n<mapping key\="&lt;bits/mathcalls.h&gt;" value\="&lt;math.h&gt;"/>\r\n<mapping key\="&lt;bits/mathdef.h&gt;" value\="&lt;math.h&gt;"/>\r\n<mapping key\="&lt;bits/mathinline.h&gt;" value\="&lt;math.h&gt;"/>\r\n<mapping key\="&lt;bits/mman.h&gt;" value\="&lt;sys/mman.h&gt;"/>\r\n<mapping key\="&lt;bits/monetary-ldbl.h&gt;" value\="&lt;monetary.h&gt;"/>\r\n<mapping key\="&lt;bits/mqueue.h&gt;" value\="&lt;mqueue.h&gt;"/>\r\n<mapping key\="&lt;bits/mqueue2.h&gt;" value\="&lt;mqueue.h&gt;"/>\r\n<mapping key\="&lt;bits/msq.h&gt;" value\="&lt;sys/msg.h&gt;"/>\r\n<mapping key\="&lt;bits/nan.h&gt;" value\="&lt;math.h&gt;"/>\r\n<mapping key\="&lt;bits/netdb.h&gt;" value\="&lt;netdb.h&gt;"/>\r\n<mapping key\="&lt;bits/poll.h&gt;" value\="&lt;poll.h&gt;"/>\r\n<mapping key\="&lt;bits/posix_opt.h&gt;" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="&lt;bits/posix1_lim.h&gt;" value\="&lt;limits.h&gt;"/>\r\n<mapping key\="&lt;bits/posix2_lim.h&gt;" value\="&lt;limits.h&gt;"/>\r\n<mapping key\="&lt;bits/predefs.h&gt;" value\="&lt;features.h&gt;"/>\r\n<mapping key\="&lt;bits/printf-ldbl.h&gt;" value\="&lt;printf.h&gt;"/>\r\n<mapping key\="&lt;bits/pthreadtypes.h&gt;" value\="&lt;pthread.h&gt;"/>\r\n<mapping key\="&lt;bits/resource.h&gt;" value\="&lt;sys/resource.h&gt;"/>\r\n<mapping key\="&lt;bits/sched.h&gt;" value\="&lt;sched.h&gt;"/>\r\n<mapping key\="&lt;bits/select.h&gt;" value\="&lt;sys/select.h&gt;"/>\r\n<mapping key\="&lt;bits/sem.h&gt;" value\="&lt;sys/sem.h&gt;"/>\r\n<mapping key\="&lt;bits/semaphore.h&gt;" value\="&lt;semaphore.h&gt;"/>\r\n<mapping key\="&lt;bits/setjmp.h&gt;" value\="&lt;setjmp.h&gt;"/>\r\n<mapping key\="&lt;bits/shm.h&gt;" value\="&lt;sys/shm.h&gt;"/>\r\n<mapping key\="&lt;bits/sigaction.h&gt;" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="&lt;bits/sigcontext.h&gt;" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="&lt;bits/siginfo.h&gt;" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="&lt;bits/signum.h&gt;" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="&lt;bits/sigset.h&gt;" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="&lt;bits/sigstack.h&gt;" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="&lt;bits/sigthread.h&gt;" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="&lt;bits/sockaddr.h&gt;" value\="&lt;sys/un.h&gt;"/>\r\n<mapping key\="&lt;bits/socket.h&gt;" value\="&lt;sys/socket.h&gt;"/>\r\n<mapping key\="&lt;bits/stab.def&gt;" value\="&lt;stab.h&gt;"/>\r\n<mapping key\="&lt;bits/stat.h&gt;" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="&lt;bits/statfs.h&gt;" value\="&lt;sys/statfs.h&gt;"/>\r\n<mapping key\="&lt;bits/statvfs.h&gt;" value\="&lt;sys/statvfs.h&gt;"/>\r\n<mapping key\="&lt;bits/stdio.h&gt;" value\="&lt;stdio.h&gt;"/>\r\n<mapping key\="&lt;bits/stdio_lim.h&gt;" value\="&lt;stdio.h&gt;"/>\r\n<mapping key\="&lt;bits/stdio-ldbl.h&gt;" value\="&lt;stdio.h&gt;"/>\r\n<mapping key\="&lt;bits/stdio-lock.h&gt;" value\="&lt;libio.h&gt;"/>\r\n<mapping key\="&lt;bits/stdio2.h&gt;" value\="&lt;stdio.h&gt;"/>\r\n<mapping key\="&lt;bits/stdlib.h&gt;" value\="&lt;stdlib.h&gt;"/>\r\n<mapping key\="&lt;bits/stdlib-ldbl.h&gt;" value\="&lt;stdlib.h&gt;"/>\r\n<mapping key\="&lt;bits/string.h&gt;" value\="&lt;string.h&gt;"/>\r\n<mapping key\="&lt;bits/string2.h&gt;" value\="&lt;string.h&gt;"/>\r\n<mapping key\="&lt;bits/string3.h&gt;" value\="&lt;string.h&gt;"/>\r\n<mapping key\="&lt;bits/stropts.h&gt;" value\="&lt;stropts.h&gt;"/>\r\n<mapping key\="&lt;bits/sys_errlist.h&gt;" value\="&lt;stdio.h&gt;"/>\r\n<mapping key\="&lt;bits/syscall.h&gt;" value\="&lt;syscall.h&gt;"/>\r\n<mapping key\="&lt;bits/syslog.h&gt;" value\="&lt;syslog.h&gt;"/>\r\n<mapping key\="&lt;bits/syslog-ldbl.h&gt;" value\="&lt;syslog.h&gt;"/>\r\n<mapping key\="&lt;bits/syslog-path.h&gt;" value\="&lt;syslog.h&gt;"/>\r\n<mapping key\="&lt;bits/termios.h&gt;" value\="&lt;termios.h&gt;"/>\r\n<mapping key\="&lt;bits/time.h&gt;" value\="&lt;sys/time.h&gt;"/>\r\n<mapping key\="&lt;bits/types.h&gt;" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="&lt;bits/uio.h&gt;" value\="&lt;sys/uio.h&gt;"/>\r\n<mapping key\="&lt;bits/unistd.h&gt;" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="&lt;bits/ustat.h&gt;" value\="&lt;ustat.h&gt;"/>\r\n<mapping key\="&lt;bits/utmp.h&gt;" value\="&lt;utmp.h&gt;"/>\r\n<mapping key\="&lt;bits/utmpx.h&gt;" value\="&lt;utmpx.h&gt;"/>\r\n<mapping key\="&lt;bits/utsname.h&gt;" value\="&lt;sys/utsname.h&gt;"/>\r\n<mapping key\="&lt;bits/waitflags.h&gt;" value\="&lt;sys/wait.h&gt;"/>\r\n<mapping key\="&lt;bits/waitstatus.h&gt;" value\="&lt;sys/wait.h&gt;"/>\r\n<mapping key\="&lt;bits/wchar.h&gt;" value\="&lt;wchar.h&gt;"/>\r\n<mapping key\="&lt;bits/wchar-ldbl.h&gt;" value\="&lt;wchar.h&gt;"/>\r\n<mapping key\="&lt;bits/wchar2.h&gt;" value\="&lt;wchar.h&gt;"/>\r\n<mapping key\="&lt;bits/xopen_lim.h&gt;" value\="&lt;limits.h&gt;"/>\r\n<mapping key\="&lt;bits/xtitypes.h&gt;" value\="&lt;stropts.h&gt;"/>\r\n<mapping key\="&lt;linux/errno.h&gt;" value\="&lt;errno.h&gt;"/>\r\n<mapping key\="&lt;linux/limits.h&gt;" value\="&lt;limits.h&gt;"/>\r\n<mapping key\="&lt;linux/socket.h&gt;" value\="&lt;sys/socket.h&gt;"/>\r\n<mapping key\="&lt;sys/poll.h&gt;" value\="&lt;poll.h&gt;"/>\r\n<mapping key\="&lt;sys/syscall.h&gt;" value\="&lt;syscall.h&gt;"/>\r\n<mapping key\="&lt;sys/syslog.h&gt;" value\="&lt;syslog.h&gt;"/>\r\n<mapping key\="&lt;sys/ucontext.h&gt;" value\="&lt;ucontext.h&gt;"/>\r\n<mapping key\="&lt;sys/ustat.h&gt;" value\="&lt;ustat.h&gt;"/>\r\n<mapping key\="&lt;wait.h&gt;" value\="&lt;sys/wait.h&gt;"/>\r\n</unconditional_substitution_map>\r\n<optional_substitution_map/>\r\n</map>\r\n<map cpp_only\="true" name\="GCC C++ Header Substitution">\r\n<unconditional_substitution_map>\r\n<mapping key\="&lt;auto_ptr.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;backward/auto_ptr.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;backward/binders.h&gt;" value\="&lt;functional&gt;"/>\r\n<mapping key\="&lt;backward/hash_fun.h&gt;" value\="&lt;hash_map&gt;"/>\r\n<mapping key\="&lt;backward/hash_fun.h&gt;" value\="&lt;hash_set&gt;"/>\r\n<mapping key\="&lt;backward/hashtable.h&gt;" value\="&lt;hash_map&gt;"/>\r\n<mapping key\="&lt;backward/hashtable.h&gt;" value\="&lt;hash_set&gt;"/>\r\n<mapping key\="&lt;backward/strstream&gt;" value\="&lt;strstream&gt;"/>\r\n<mapping key\="&lt;binders.h&gt;" value\="&lt;functional&gt;"/>\r\n<mapping key\="&lt;bits/algorithmfwd.h&gt;" value\="&lt;algorithm&gt;"/>\r\n<mapping key\="&lt;bits/allocator.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;bits/atomic_word.h&gt;" value\="&lt;ext/atomicity.h&gt;"/>\r\n<mapping key\="&lt;bits/basic_file.h&gt;" value\="&lt;fstream&gt;"/>\r\n<mapping key\="&lt;bits/basic_ios.h&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;bits/basic_string.h&gt;" value\="&lt;string&gt;"/>\r\n<mapping key\="&lt;bits/basic_string.tcc&gt;" value\="&lt;string&gt;"/>\r\n<mapping key\="&lt;bits/boost_concept_check.h&gt;" value\="&lt;bits/concept_check.h&gt;"/>\r\n<mapping key\="&lt;bits/boost_sp_shared_count.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;bits/c++allocator.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;bits/c++config.h&gt;" value\="&lt;cstddef&gt;"/>\r\n<mapping key\="&lt;bits/c++io.h&gt;" value\="&lt;ext/stdio_sync_filebuf.h&gt;"/>\r\n<mapping key\="&lt;bits/char_traits.h&gt;" value\="&lt;string&gt;"/>\r\n<mapping key\="&lt;bits/cmath.tcc&gt;" value\="&lt;cmath&gt;"/>\r\n<mapping key\="&lt;bits/codecvt.h&gt;" value\="&lt;fstream&gt;"/>\r\n<mapping key\="&lt;bits/codecvt.h&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/ctype_base.h&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/ctype_base.h&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;bits/ctype_inline.h&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/ctype_inline.h&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;bits/cxxabi_tweaks.h&gt;" value\="&lt;cxxabi.h&gt;"/>\r\n<mapping key\="&lt;bits/deque.tcc&gt;" value\="&lt;deque&gt;"/>\r\n<mapping key\="&lt;bits/exception_defines.h&gt;" value\="&lt;exception&gt;"/>\r\n<mapping key\="&lt;bits/fstream.tcc&gt;" value\="&lt;fstream&gt;"/>\r\n<mapping key\="&lt;bits/functexcept.h&gt;" value\="&lt;algorithm&gt;"/>\r\n<mapping key\="&lt;bits/functional_hash.h&gt;" value\="&lt;unordered_map&gt;"/>\r\n<mapping key\="&lt;bits/gslice.h&gt;" value\="&lt;valarray&gt;"/>\r\n<mapping key\="&lt;bits/gslice_array.h&gt;" value\="&lt;valarray&gt;"/>\r\n<mapping key\="&lt;bits/hashtable.h&gt;" value\="&lt;unordered_map&gt;"/>\r\n<mapping key\="&lt;bits/hashtable.h&gt;" value\="&lt;unordered_set&gt;"/>\r\n<mapping key\="&lt;bits/indirect_array.h&gt;" value\="&lt;valarray&gt;"/>\r\n<mapping key\="&lt;bits/ios_base.h&gt;" value\="&lt;iostream&gt;"/>\r\n<mapping key\="&lt;bits/ios_base.h&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;bits/ios_base.h&gt;" value\="&lt;iomanip&gt;"/>\r\n<mapping key\="&lt;bits/istream.tcc&gt;" value\="&lt;istream&gt;"/>\r\n<mapping key\="&lt;bits/list.tcc&gt;" value\="&lt;list&gt;"/>\r\n<mapping key\="&lt;bits/locale_classes.h&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/locale_classes.h&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;bits/locale_classes.tcc&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/locale_classes.tcc&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;bits/locale_facets.h&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/locale_facets.h&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;bits/locale_facets.tcc&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/locale_facets.tcc&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;bits/locale_facets_nonio.h&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/locale_facets_nonio.tcc&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/localefwd.h&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/mask_array.h&gt;" value\="&lt;valarray&gt;"/>\r\n<mapping key\="&lt;bits/messages_members.h&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/move.h&gt;" value\="&lt;algorithm&gt;"/>\r\n<mapping key\="&lt;bits/ostream.tcc&gt;" value\="&lt;ostream&gt;"/>\r\n<mapping key\="&lt;bits/ostream_insert.h&gt;" value\="&lt;ostream&gt;"/>\r\n<mapping key\="&lt;bits/postypes.h&gt;" value\="&lt;iostream&gt;"/>\r\n<mapping key\="&lt;bits/postypes.h&gt;" value\="&lt;string&gt;"/>\r\n<mapping key\="&lt;bits/shared_ptr.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;bits/slice_array.h&gt;" value\="&lt;valarray&gt;"/>\r\n<mapping key\="&lt;bits/sstream.tcc&gt;" value\="&lt;sstream&gt;"/>\r\n<mapping key\="&lt;bits/stl_algo.h&gt;" value\="&lt;algorithm&gt;"/>\r\n<mapping key\="&lt;bits/stl_algobase.h&gt;" value\="&lt;algorithm&gt;"/>\r\n<mapping key\="&lt;bits/stl_bvector.h&gt;" value\="&lt;vector&gt;"/>\r\n<mapping key\="&lt;bits/stl_construct.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;bits/stl_deque.h&gt;" value\="&lt;deque&gt;"/>\r\n<mapping key\="&lt;bits/stl_function.h&gt;" value\="&lt;functional&gt;"/>\r\n<mapping key\="&lt;bits/stl_heap.h&gt;" value\="&lt;queue&gt;"/>\r\n<mapping key\="&lt;bits/stl_iterator.h&gt;" value\="&lt;iterator&gt;"/>\r\n<mapping key\="&lt;bits/stl_iterator_base_funcs.h&gt;" value\="&lt;iterator&gt;"/>\r\n<mapping key\="&lt;bits/stl_iterator_base_types.h&gt;" value\="&lt;iterator&gt;"/>\r\n<mapping key\="&lt;bits/stl_list.h&gt;" value\="&lt;list&gt;"/>\r\n<mapping key\="&lt;bits/stl_map.h&gt;" value\="&lt;map&gt;"/>\r\n<mapping key\="&lt;bits/stl_move.h&gt;" value\="&lt;algorithm&gt;"/>\r\n<mapping key\="&lt;bits/stl_multimap.h&gt;" value\="&lt;map&gt;"/>\r\n<mapping key\="&lt;bits/stl_multiset.h&gt;" value\="&lt;set&gt;"/>\r\n<mapping key\="&lt;bits/stl_numeric.h&gt;" value\="&lt;numeric&gt;"/>\r\n<mapping key\="&lt;bits/stl_pair.h&gt;" value\="&lt;utility&gt;"/>\r\n<mapping key\="&lt;bits/stl_pair.h&gt;" value\="&lt;tr1/utility&gt;"/>\r\n<mapping key\="&lt;bits/stl_queue.h&gt;" value\="&lt;queue&gt;"/>\r\n<mapping key\="&lt;bits/stl_raw_storage_iter.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;bits/stl_relops.h&gt;" value\="&lt;utility&gt;"/>\r\n<mapping key\="&lt;bits/stl_set.h&gt;" value\="&lt;set&gt;"/>\r\n<mapping key\="&lt;bits/stl_stack.h&gt;" value\="&lt;stack&gt;"/>\r\n<mapping key\="&lt;bits/stl_tempbuf.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;bits/stl_tree.h&gt;" value\="&lt;map&gt;"/>\r\n<mapping key\="&lt;bits/stl_tree.h&gt;" value\="&lt;set&gt;"/>\r\n<mapping key\="&lt;bits/stl_uninitialized.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;bits/stl_vector.h&gt;" value\="&lt;vector&gt;"/>\r\n<mapping key\="&lt;bits/stream_iterator.h&gt;" value\="&lt;iterator&gt;"/>\r\n<mapping key\="&lt;bits/streambuf.tcc&gt;" value\="&lt;streambuf&gt;"/>\r\n<mapping key\="&lt;bits/streambuf_iterator.h&gt;" value\="&lt;iterator&gt;"/>\r\n<mapping key\="&lt;bits/streambuf_iterator.h&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;bits/stringfwd.h&gt;" value\="&lt;string&gt;"/>\r\n<mapping key\="&lt;bits/unique_ptr.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;bits/valarray_after.h&gt;" value\="&lt;valarray&gt;"/>\r\n<mapping key\="&lt;bits/valarray_array.h&gt;" value\="&lt;valarray&gt;"/>\r\n<mapping key\="&lt;bits/valarray_array.tcc&gt;" value\="&lt;valarray&gt;"/>\r\n<mapping key\="&lt;bits/valarray_before.h&gt;" value\="&lt;valarray&gt;"/>\r\n<mapping key\="&lt;bits/vector.tcc&gt;" value\="&lt;vector&gt;"/>\r\n<mapping key\="&lt;debug/safe_iterator.tcc&gt;" value\="&lt;debug/safe_iterator.h&gt;"/>\r\n<mapping key\="&lt;exception_defines.h&gt;" value\="&lt;exception&gt;"/>\r\n<mapping key\="&lt;ext/algorithm&gt;" value\="&lt;algorithm&gt;"/>\r\n<mapping key\="&lt;ext/functional&gt;" value\="&lt;functional&gt;"/>\r\n<mapping key\="&lt;ext/hash_map&gt;" value\="&lt;hash_map&gt;"/>\r\n<mapping key\="&lt;ext/hash_set&gt;" value\="&lt;hash_set&gt;"/>\r\n<mapping key\="&lt;ext/numeric&gt;" value\="&lt;numeric&gt;"/>\r\n<mapping key\="&lt;ext/slist&gt;" value\="&lt;slist&gt;"/>\r\n<mapping key\="&lt;ext/sso_string_base.h&gt;" value\="&lt;string&gt;"/>\r\n<mapping key\="&lt;ext/vstring.h&gt;" value\="&lt;string&gt;"/>\r\n<mapping key\="&lt;ext/vstring.tcc&gt;" value\="&lt;string&gt;"/>\r\n<mapping key\="&lt;ext/vstring_fwd.h&gt;" value\="&lt;string&gt;"/>\r\n<mapping key\="&lt;hash_fun.h&gt;" value\="&lt;hash_map&gt;"/>\r\n<mapping key\="&lt;hash_fun.h&gt;" value\="&lt;hash_set&gt;"/>\r\n<mapping key\="&lt;hashtable.h&gt;" value\="&lt;hash_map&gt;"/>\r\n<mapping key\="&lt;hashtable.h&gt;" value\="&lt;hash_set&gt;"/>\r\n<mapping key\="&lt;tr1/bessel_function.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/beta_function.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/ell_integral.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/exp_integral.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/gamma.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/hypergeometric.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/legendre_function.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/modified_bessel_func.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/poly_hermite.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/poly_laguerre.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/riemann_zeta.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1_impl/array&gt;" value\="&lt;array&gt;"/>\r\n<mapping key\="&lt;tr1_impl/array&gt;" value\="&lt;tr1/array&gt;"/>\r\n<mapping key\="&lt;tr1_impl/boost_shared_ptr.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;tr1_impl/boost_shared_ptr.h&gt;" value\="&lt;tr1/memory&gt;"/>\r\n<mapping key\="&lt;tr1_impl/boost_sp_counted_base.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;tr1_impl/boost_sp_counted_base.h&gt;" value\="&lt;tr1/memory&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cctype&gt;" value\="&lt;cctype&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cctype&gt;" value\="&lt;tr1/cctype&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cfenv&gt;" value\="&lt;cfenv&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cfenv&gt;" value\="&lt;tr1/cfenv&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cinttypes&gt;" value\="&lt;cinttypes&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cinttypes&gt;" value\="&lt;tr1/cinttypes&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cmath&gt;" value\="&lt;cmath&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cmath&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1_impl/complex&gt;" value\="&lt;complex&gt;"/>\r\n<mapping key\="&lt;tr1_impl/complex&gt;" value\="&lt;tr1/complex&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cstdint&gt;" value\="&lt;cstdint&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cstdint&gt;" value\="&lt;tr1/cstdint&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cstdio&gt;" value\="&lt;cstdio&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cstdio&gt;" value\="&lt;tr1/cstdio&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cstdlib&gt;" value\="&lt;cstdlib&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cstdlib&gt;" value\="&lt;tr1/cstdlib&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cwchar&gt;" value\="&lt;cwchar&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cwchar&gt;" value\="&lt;tr1/cwchar&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cwctype&gt;" value\="&lt;cwctype&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cwctype&gt;" value\="&lt;tr1/cwctype&gt;"/>\r\n<mapping key\="&lt;tr1_impl/functional&gt;" value\="&lt;functional&gt;"/>\r\n<mapping key\="&lt;tr1_impl/functional&gt;" value\="&lt;tr1/functional&gt;"/>\r\n<mapping key\="&lt;tr1_impl/functional_hash.h&gt;" value\="&lt;tr1/functional_hash.h&gt;"/>\r\n<mapping key\="&lt;tr1_impl/hashtable&gt;" value\="&lt;tr1/hashtable.h&gt;"/>\r\n<mapping key\="&lt;tr1_impl/random&gt;" value\="&lt;random&gt;"/>\r\n<mapping key\="&lt;tr1_impl/random&gt;" value\="&lt;tr1/random&gt;"/>\r\n<mapping key\="&lt;tr1_impl/random.tcc&gt;" value\="&lt;random&gt;"/>\r\n<mapping key\="&lt;tr1_impl/random.tcc&gt;" value\="&lt;tr1/random&gt;"/>\r\n<mapping key\="&lt;tr1_impl/regex&gt;" value\="&lt;regex&gt;"/>\r\n<mapping key\="&lt;tr1_impl/regex&gt;" value\="&lt;tr1/regex&gt;"/>\r\n<mapping key\="&lt;tr1_impl/type_traits&gt;" value\="&lt;tr1/type_traits&gt;"/>\r\n<mapping key\="&lt;tr1_impl/type_traits&gt;" value\="&lt;type_traits&gt;"/>\r\n<mapping key\="&lt;tr1_impl/unordered_map&gt;" value\="&lt;tr1/unordered_map&gt;"/>\r\n<mapping key\="&lt;tr1_impl/unordered_map&gt;" value\="&lt;unordered_map&gt;"/>\r\n<mapping key\="&lt;tr1_impl/unordered_set&gt;" value\="&lt;tr1/unordered_set&gt;"/>\r\n<mapping key\="&lt;tr1_impl/unordered_set&gt;" value\="&lt;unordered_set&gt;"/>\r\n<mapping key\="&lt;tr1_impl/utility&gt;" value\="&lt;tr1/utility&gt;"/>\r\n<mapping key\="&lt;tr1_impl/utility&gt;" value\="&lt;utility&gt;"/>\r\n</unconditional_substitution_map>\r\n<optional_substitution_map>\r\n<mapping key\="&lt;assert.h&gt;" value\="&lt;cassert&gt;"/>\r\n<mapping key\="&lt;complex.h&gt;" value\="&lt;ccomplex&gt;"/>\r\n<mapping key\="&lt;ctype.h&gt;" value\="&lt;cctype&gt;"/>\r\n<mapping key\="&lt;errno.h&gt;" value\="&lt;cerrno&gt;"/>\r\n<mapping key\="&lt;fenv.h&gt;" value\="&lt;cfenv&gt;"/>\r\n<mapping key\="&lt;float.h&gt;" value\="&lt;cfloat&gt;"/>\r\n<mapping key\="&lt;inttypes.h&gt;" value\="&lt;cinttypes&gt;"/>\r\n<mapping key\="&lt;ios&gt;" value\="&lt;iostream&gt;"/>\r\n<mapping key\="&lt;ios&gt;" value\="&lt;istream&gt;"/>\r\n<mapping key\="&lt;ios&gt;" value\="&lt;ostream&gt;"/>\r\n<mapping key\="&lt;iosfwd&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;iosfwd&gt;" value\="&lt;streambuf&gt;"/>\r\n<mapping key\="&lt;iso646.h&gt;" value\="&lt;ciso646&gt;"/>\r\n<mapping key\="&lt;istream&gt;" value\="&lt;iostream&gt;"/>\r\n<mapping key\="&lt;istream&gt;" value\="&lt;fstream&gt;"/>\r\n<mapping key\="&lt;istream&gt;" value\="&lt;sstream&gt;"/>\r\n<mapping key\="&lt;limits.h&gt;" value\="&lt;climits&gt;"/>\r\n<mapping key\="&lt;locale.h&gt;" value\="&lt;clocale&gt;"/>\r\n<mapping key\="&lt;math.h&gt;" value\="&lt;cmath&gt;"/>\r\n<mapping key\="&lt;ostream&gt;" value\="&lt;iostream&gt;"/>\r\n<mapping key\="&lt;ostream&gt;" value\="&lt;fstream&gt;"/>\r\n<mapping key\="&lt;ostream&gt;" value\="&lt;istream&gt;"/>\r\n<mapping key\="&lt;ostream&gt;" value\="&lt;sstream&gt;"/>\r\n<mapping key\="&lt;setjmp.h&gt;" value\="&lt;csetjmp&gt;"/>\r\n<mapping key\="&lt;signal.h&gt;" value\="&lt;csignal&gt;"/>\r\n<mapping key\="&lt;stdarg.h&gt;" value\="&lt;cstdarg&gt;"/>\r\n<mapping key\="&lt;stdbool.h&gt;" value\="&lt;cstdbool&gt;"/>\r\n<mapping key\="&lt;stddef.h&gt;" value\="&lt;cstddef&gt;"/>\r\n<mapping key\="&lt;stdint.h&gt;" value\="&lt;cstdint&gt;"/>\r\n<mapping key\="&lt;stdio.h&gt;" value\="&lt;cstdio&gt;"/>\r\n<mapping key\="&lt;stdlib.h&gt;" value\="&lt;cstdlib&gt;"/>\r\n<mapping key\="&lt;streambuf&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;string.h&gt;" value\="&lt;cstring&gt;"/>\r\n<mapping key\="&lt;tgmath.h&gt;" value\="&lt;ctgmath&gt;"/>\r\n<mapping key\="&lt;time.h&gt;" value\="&lt;ctime&gt;"/>\r\n<mapping key\="&lt;wchar.h&gt;" value\="&lt;cwchar&gt;"/>\r\n<mapping key\="&lt;wctype.h&gt;" value\="&lt;cwctype&gt;"/>\r\n</optional_substitution_map>\r\n</map>\r\n</maps>
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.number_of_empty_lines_to_preserve=1
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.LaunchLastIfNotLaunchable=true
/bundle_defaults/org.eclipse.ui.workbench/SHOW_MEMORY_MONITOR=false
/bundle_defaults/org.eclipse.cdt.ui/forwardDeclare.templates=false
/bundle_defaults/org.eclipse.cdt.ui/matchingBracketsColor=170,170,170
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_colon_in_base_clause=insert
/bundle_defaults/org.eclipse.ui.editors/quickdiff.quickDiff=true
/bundle_defaults/com.crt.utils/extendedToolsSupport=false
/bundle_defaults/org.eclipse.core.resources/refresh.lightweight.enabled=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.getter.suffix=
/bundle_defaults/org.eclipse.ui.editors/linked.slave.color=180,215,255
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticField.underline=false
/bundle_defaults/org.eclipse.ui.ide/TASKS_FILTERS_MIGRATE=false
/bundle_defaults/org.eclipse.core.net/proxyData/HTTP/hasAuth=false
/bundle_defaults/org.eclipse.cdt.dsf.gdb/tracesEnable=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.overloadedOperator.bold=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_semicolon=do not insert
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.pcHistorySize=4
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.reset_memory_block=org.eclipse.debug.uiresetMemoryBlock.visible
/bundle_defaults/org.eclipse.ui.editors/filteredSearchResultIndication=false
/bundle_defaults/org.eclipse.ui.workbench/KEYS_PREFERENCE_SELECTED_TAB=0
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.overrideIndicatorHighlighting=false
/bundle_defaults/org.eclipse.ui.editors/showAdditionInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.put_empty_statement_on_new_line=true
/bundle_defaults/org.eclipse.ui.workbench/ENABLED_DECORATORS=
/bundle_defaults/org.eclipse.ui.workbench/LAYOUT_DIRECTION=0
/bundle_defaults/org.eclipse.cdt.ui/hoverModifiers=org.eclipse.cdt.ui.BestMatchHover;0;org.eclipse.cdt.ui.CSourceHover;Shift
/bundle_defaults/org.eclipse.cdt.dsf.gdb/defaultGdbInit=.gdbinit
/bundle_defaults/org.eclipse.cdt.ui/scalability.syntaxColor=false
/bundle_defaults/org.eclipse.ui.ide/LIMIT_TASKS=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.field.color=0,0,192
/bundle_defaults/org.eclipse.cdt.debug.core/org.eclipse.cdt.debug.corecDebug.Disassembly.instructionStepOn=false
/bundle_defaults/org.eclipse.cdt.ui/removeTrailingWhitespace=true
/bundle_defaults/org.eclipse.ui.editors/searchResultIndicationInVerticalRuler=true
/bundle_defaults/org.eclipse.cdt.ui/spelling_ignore_mixed=true
/bundle_defaults/org.eclipse.ui/VIEW_TAB_POSITION=128
/bundle_defaults/org.eclipse.cdt.ui/content_assist_proposals_foreground=0,0,0
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.occurrenceTextStyle=NONE
/bundle_defaults/org.eclipse.ui.editors/currentIPTextStyle=NONE
/bundle_defaults/org.eclipse.ui/USE_COLORED_LABELS=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.remove_all_expressions_prompt=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_enum_declarations=insert
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.error.GoToNextNavigationTarget=true
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.SaveAllEditors=false
/bundle_defaults/org.eclipse.cdt.core/indexer/indexImportLocation=.settings/cdt-index.zip
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.memory.paddedStr=??
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.test.wordDelimiter=
/bundle_defaults/org.eclipse.ui/EDITOR_TAB_POSITION=128
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_pinint.com.crt.advproject.projecttype.exe.500409353/com.crt.advproject.config.exe.debug.1554618354=com.crt.advproject.link.cpp.exe.debug.1515071553\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1895588001\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.870533861\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1867315417\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1897250593\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.282738432\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1554618354\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/linked.target.verticalruler=false
/bundle_defaults/org.eclipse.ui.editors/isSpellingGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/deletionIndicationInVerticalRuler=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.function.underline=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_template_parameters=do not insert
/bundle_defaults/org.eclipse.ui.workbench/RECENT_FILES=4
/bundle_defaults/org.eclipse.cdt.ui/inactiveCodeEnable=true
/bundle_defaults/com.crt.debugcommon/Red\ Probe\ Family=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_question_in_conditional=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_between_empty_parens_in_method_invocation=do not insert
/bundle_defaults/org.eclipse.cdt.ui/content_assist_order_proposals=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.label.bold=false
/instance/org.eclipse.cdt.core/macros/workspace=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?>\r\n<macros/>\r\n
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroDefinition.underline=false
/bundle_defaults/org.eclipse.cdt.dsf.ui/delaySteppingForViewUpdatesEnable=false
/bundle_defaults/org.eclipse.cdt.ui/spelling_ignore_string_literals=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/LPCXpresso176x_timer.com.crt.advproject.projecttype.exe.1447070015/com.crt.advproject.config.exe.release.355928930=com.crt.advproject.toolchain.exe.release.1378490699\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.811744456\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.348057984\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.1794124423\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1794703196\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1917935340\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_postfix_operator=do not insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.overloadedOperator.italic=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_parameters_in_method_declaration=16
/bundle_defaults/org.eclipse.cdt.ui/asm_label=127,0,85
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.avoidReadBeforePC=false
/bundle_defaults/org.eclipse.ui.ide/SWITCH_PERSPECTIVE_ON_PROJECT_CREATION=prompt
/bundle_defaults/org.eclipse.ui.editors/com.crt.etmetb.marker.pref.textStyle=IBEAM
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.c_keyword.enabled=true
/bundle_defaults/com.crt.debugcommon/warning_as_note=false
/bundle_defaults/org.eclipse.ui.editors/linked.focus.text.style=BOX
/bundle_defaults/org.eclipse.ui.editors/currentIPHighlight=true
/bundle_defaults/org.eclipse.ui/USE_WINDOW_WORKING_SET_BY_DEFAULT=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.method.bold=false
/bundle_defaults/org.eclipse.ui.editors/showTrailingSpaces=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.comment.min_distance_between_code_and_line_comment=1
/bundle_defaults/org.eclipse.cdt.ui/pp_header_italic=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.variable.capitalization=4
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_uart_rb.com.crt.advproject.projecttype.exe.1950633819/com.crt.advproject.config.exe.release.591215090=com.crt.advproject.link.exe.release.679425267\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1983682568\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.1335020951\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1666157320\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.2140904055\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.217606318\=rebuildState\\\=true\\r\\n\r\n
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_bod.com.crt.advproject.projecttype.exe.1330480440/com.crt.advproject.config.exe.debug.1121475055=com.crt.advproject.link.exe.debug.998466899\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1234966347\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.474972202\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1121475055\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.1991069582\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1117423890\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.33140722\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui/KEY_CONFIGURATION_ID=org.eclipse.ui.defaultAcceleratorConfiguration
/bundle_defaults/org.eclipse.core.resources/description.filestatelongevity=604800000
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_binary_expression=16
/bundle_defaults/org.eclipse.debug.ui/org.eclispe.debug.ui.Debug_view.mode=Debug_view.mode.auto
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_prefix_operator=do not insert
/bundle_defaults/com.crt.dsfdebug/periphFormatToWidth=false
/instance/org.eclipse.core.resources/version=1
/bundle_defaults/org.eclipse.cdt.ui/markOccurrences=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.use_tabs_only_for_leading_indentations=false
/instance/org.eclipse.cdt.debug.core/org.eclipse.cdt.debug.core.cDebug.default_source_containers=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?>\r\n<sourceLookupDirector>\r\n<sourceContainers duplicates\="false">\r\n<container memento\="AbsolutePath" typeId\="org.eclipse.cdt.debug.core.containerType.absolutePath"/>\r\n<container memento\="programRelativePath" typeId\="org.eclipse.cdt.debug.core.containerType.programRelativePath"/>\r\n<container memento\="&lt;?xml version\=&quot;1.0&quot; encoding\=&quot;UTF-8&quot; standalone\=&quot;no&quot;?&gt;&\#13;&\#10;&lt;project referencedProjects\=&quot;true&quot;/&gt;&\#13;&\#10;" typeId\="org.eclipse.cdt.debug.core.containerType.project"/>\r\n</sourceContainers>\r\n</sourceLookupDirector>\r\n
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.PREF_FILTER_LAUNCH_TYPES=false
/instance/org.eclipse.debug.core//org.eclipse.debug.core.PREFERRED_DELEGATES/org.eclipse.cdt.launch.postmortemLaunchType=org.eclipse.cdt.dsf.gdb.launch.coreCLaunch,debug,;
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.UseContextualLaunch=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enum.strikethrough=false
/bundle_defaults/org.eclipse.core.resources/delta.expiration=2592000000
/bundle_defaults/org.eclipse.ui.editors/printMarginColumn=80
/bundle_defaults/org.eclipse.ui.workbench/COLOR_ICONS=true
/bundle_defaults/org.eclipse.ui.editors/secondaryIPOverviewRuler=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_ethernet.com.crt.advproject.projecttype.exe.1632332403/com.crt.advproject.config.exe.release.1243387797=com.crt.advproject.toolchain.exe.release.1109289695\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.1005076799\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1328591123\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.993078141\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.511095667\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1549525454\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/com.crt.config/package=LPC1343
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_before_catch_in_try_statement=do not insert
/bundle_defaults/com.crt.debugcommon/genericVidpidScript=
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.function.enabled=false
/bundle_defaults/org.eclipse.ui.workbench/FVB_HIDE=false
/bundle_defaults/org.eclipse.cdt.ui/scalability.parserBasedContentAssist=false
/bundle_defaults/org.eclipse.cdt.core/useStructualParseMode=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.occurrenceIndicationColor=212,212,212
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.max_detail_length=10000
/bundle_defaults/org.eclipse.cdt.ui/spelling_locale=en_US
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_switchstatements_compare_to_cases=true
/bundle_defaults/com.crt.debugcommon/showExtended=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_namespace_declaration=end_of_line
/bundle_defaults/com.crt.advproject/dependeciesfix=true
/bundle_defaults/org.eclipse.ui.editors/com.crt.etmetb.marker.profile.pref.vertical=false
/bundle_defaults/org.eclipse.ui.editors/unchangedIndicationInVerticalRuler=false
/bundle_defaults/org.eclipse.cdt.codan.core/useParentScope=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.memory.rowSize=16
/bundle_defaults/org.eclipse.ui.editors/showFilteredSearchResultInNextPrevDropdownToolbarAction=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_if=do not insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariable.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/spelling_user_dictionary=
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.externalSDK.color=100,40,128
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.namespace.color=0,0,0
/bundle_defaults/com.crt.debugcommon/macBackgroundExec=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariable.bold=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_throws_clause_in_method_declaration=16
/bundle_defaults/org.eclipse.ui/VIEW_MINIMUM_CHARACTERS=1
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.label.underline=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.header.wordDelimiter=
/bundle_defaults/org.eclipse.ui/RECENTLY_USED_WORKINGSETS_SIZE=5
/bundle_defaults/org.eclipse.debug.ui/DEBUG.consoleOpenOnErr=true
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.constant.capitalization=1
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.functionDeclaration.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroDefinition.color=0,0,0
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_base_types=insert
/bundle_defaults/org.eclipse.ui.editors/showLineFeed=true
/bundle_defaults/org.eclipse.cdt.ui/c_comment_task_tag_bold=true
/bundle_defaults/org.eclipse.cdt.ui/formatter_profile=org.eclipse.cdt.ui.default.kandr_profile
/bundle_defaults/com.crt.debugcommon/bootLogFile=
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.setter.suffix=
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_before_closing_brace_in_array_initializer=do not insert
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.NavigationEndAction=prompt
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.manage_view_perspectives=DEFAULT
/bundle_defaults/org.eclipse.ui.ide/SAVE_ALL_BEFORE_BUILD=false
/bundle_defaults/org.eclipse.ui.editors/quickdiff.characterMode=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_brace_in_array_initializer=insert
/instance/org.eclipse.cdt.managedbuilder.core/properties/usbd_lib_hid_generic.com.crt.advproject.projecttype.exe.1358948682/com.crt.advproject.config.exe.debug.815324353=com.crt.advproject.config.exe.debug.815324353\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1493008474\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.131611243\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.81969147\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1255076903\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.537414472\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1024811717\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.core.net/proxyData/HTTPS/port=-1
/bundle_defaults/org.eclipse.cdt.dsf.gdb/org.eclipse.cdt.dsf.gdb.hideRunningThreads=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.dsf.debug.ui.hyperlinkdetector.stepIntoSelection_stateMask=327680
/bundle_defaults/org.eclipse.ui.editors/infoTextStyle=SQUIGGLES
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleInfoStreamColor=0,0,255
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.show_debug_perspective_default=org.eclipse.debug.ui.DebugPerspective
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleErrorStreamColor=255,0,0
/bundle_defaults/org.eclipse.ui.editors/spellingTextStyle=PROBLEM_UNDERLINE
/bundle_defaults/org.eclipse.ui.ide/PROBLEMS_FILTERS_MIGRATE=false
/bundle_defaults/org.eclipse.cdt.dsf.gdb/initialChildCountLimitForCollections=100
/bundle_defaults/org.eclipse.ui.ide/IMPORT_FILES_AND_FOLDERS_RELATIVE=true
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.addressColor=0,96,0
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_bod.com.crt.advproject.projecttype.exe.1330480440/com.crt.advproject.config.exe.release.1597988367=com.crt.advproject.gcc.exe.release.1008161469\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1862735863\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1883379497\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1170680966\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.637149094\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.330034282\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/pp_header=42,0,255
/bundle_defaults/org.eclipse.cdt.dsf.gdb/autoTerminateGdb=true
/instance/org.eclipse.ui.ide/tipsAndTricks=true
/bundle_defaults/org.eclipse.ui.editors/revisionAnnotationIndicationHighlighting=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.getter.prefix=get
/bundle_defaults/com.crt.debugcommon/redlink_useWmic=true
/bundle_defaults/org.eclipse.ui.editors/searchResultIndication=false
/bundle_defaults/org.eclipse.ui.editors/filteredSearchResultHighlighting=false
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_default_comments=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.method.wordDelimiter=
/bundle_defaults/org.eclipse.cdt.dsf.gdb/org.eclipse.cdt.dsf.gdb.commandTimeoutValue=10000
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_for=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_colon_in_default=do not insert
/bundle_defaults/org.eclipse.ui.workbench/EDITORLIST_SELECTION_SCOPE=1
/bundle_defaults/org.eclipse.ui.ide/WELCOME_DIALOG=true
/bundle_defaults/org.eclipse.cdt.core/scalability.limitTokensPerTU=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.variable.wordDelimiter=
/instance/org.eclipse.cdt.managedbuilder.core/properties/lwip_tcpecho_sa.com.crt.advproject.projecttype.exe.468432546/com.crt.advproject.config.exe.debug.1119530382=com.crt.advproject.link.cpp.exe.debug.2050365894\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1247192910\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.803449759\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1860283680\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1297078967\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1644762283\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1119530382\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.ide/PROJECT_OPEN_NEW_PERSPECTIVE=OPEN_PERSPECTIVE_REPLACE
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_method_invocation=do not insert
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.overrideIndicatorTextStyle=SQUIGGLES
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleProblemInfoBackgroundColor=244,247,254
@org.eclipse.cdt.core=5.8.0.201409172108
/bundle_defaults/org.eclipse.cdt.ui/content_assist_disabled_computers=org.eclipse.cdt.ui.textProposalCategory\u0000
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Color.Background.SystemDefault=true
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.IgnoreWhitespace=false
/bundle_defaults/com.crt.dsfdebug/windowsMakePathsRelative=false
/bundle_defaults/org.eclipse.ui.workbench/shouldPromptForEnablement=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.templateParameter.color=100,70,50
/bundle_defaults/org.eclipse.ui.editors/linked.exit.navigation.previous=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.activate_workbench=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.relaunch_in_debug_mode=never
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.problem.strikethrough=false
/bundle_defaults/org.eclipse.ui.ide/LIMIT_BOOKMARKS=true
/bundle_defaults/org.eclipse.debug.ui/Console.console_tab_width=8
/bundle_defaults/org.eclipse.core.resources/description.maxfilestates=50
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_breaks_compare_to_cases=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_method_declaration=do not insert
/bundle_defaults/org.eclipse.ui.editors/spellingIndicationInVerticalRuler=false
/bundle_defaults/com.crt.utils/newMacAddressMethod=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_flashiap.com.crt.advproject.projecttype.exe.2033906280/com.crt.advproject.config.exe.release.1130833511=com.crt.advproject.cpp.exe.release.1595716391\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1101117428\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1136415674\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1814748619\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1587509976\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.873115923\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.PREF_FILTER_LAUNCH_DELETED=true
/bundle_defaults/com.crt.utils/hideDebugView=true
/bundle_defaults/org.eclipse.ui.editors/bookmarkIndicationHighlighting=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_array_initializer=insert
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.PREF_LAUNCH_PERSPECTIVES=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?>\r\n<launchPerspectives>\r\n<launchPerspective configurationType\="com.crt.dsfdebug.crtmcu.launchType" mode\="debug" perspective\="com.crt.lite.perspective.CRTPerspective"/>\r\n</launchPerspectives>\r\n
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.auto_remove_old_launches=true
/bundle_defaults/com.crt.debugcommon/redlink_boot_image=(?i)LPC43.._Redlink_V([0-9]_[0-9]+).bin.hdr
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.setter.wordDelimiter=
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enumerator.italic=true
/bundle_defaults/org.eclipse.core.resources/description.defaultbuildorder=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_switch=do not insert
/bundle_defaults/org.eclipse.ui.editors/isTaskGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_angle_bracket_in_template_parameters=do not insert
/instance/org.eclipse.cdt.ui.prj-periph_blinky/buildConsole/logLocation=C\:\\Users\\Egitim5\\Documents\\LPCXpresso_7.6.2_326\\workspace\\.metadata\\.plugins\\org.eclipse.cdt.ui\\periph_blinky.build.log
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.method.italic=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_CORE_LPC112x.com.crt.advproject.projecttype.lib.481795455/com.crt.advproject.config.lib.debug.552843825=com.crt.advproject.ar.lib.debug.67772726\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.2069312955\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.752221769\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.1580605360\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.712578205\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.552843825\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/bundle_defaults/com.crt.debugcommon/probe_settle=250
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleTabWith=4
/bundle_defaults/org.eclipse.ui.editors/infoIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.ui.internal.editors.text.URLHyperlinkDetector_stateMask=-1
/bundle_defaults/org.eclipse.core.resources/description.maxbuilditerations=10
/bundle_defaults/org.eclipse.cdt.ui/c_braces_bold=false
/bundle_defaults/org.eclipse.cdt.ui/spelling_ignore_digits=true
/bundle_defaults/org.eclipse.ui.editors/linked.exit.navigation.next=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.warning.text=true
/bundle_defaults/com.crt.debugcommon/redlink_server_port=3025
/bundle_defaults/org.eclipse.core.net/proxyData/HTTPS/hasAuth=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.parameterVariable.underline=false
/instance/org.eclipse.cdt.core.prj-LPCX176x_cmsis2_systick/indexer/preferenceScope=0
/bundle_defaults/org.eclipse.ui.editors/searchResultHighlighting=true
/bundle_defaults/org.eclipse.ui.editors/hyperlinkColor=0,102,204
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.occurrenceHighlighting=true
/bundle_defaults/org.eclipse.ui.editors/errorIndicationInVerticalRuler=true
/bundle_defaults/org.eclipse.cdt.ui/pp_header_bold=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.functionDeclaration.bold=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_enum_declarations=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_namespace_declaration=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_declarator_list=16
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_spi.com.crt.advproject.projecttype.exe.1116578252/com.crt.advproject.config.exe.debug.601319979=com.crt.advproject.gcc.exe.debug.326242662\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.652166092\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.9224791\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.309974641\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.2027771857\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.415100223\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.601319979\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/instance/org.eclipse.cdt.managedbuilder.core/properties/LPCXpresso1768_systick.com.crt.advproject.projecttype.exe.783271606/com.crt.advproject.config.exe.debug.986034614=com.crt.advproject.gcc.exe.debug.2049914417.1184573733\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1701619043\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1801950365\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.986034614.52274068\=rebuildState\\\=true\\r\\n\r\norg.eclipse.cdt.managedbuilder.ui.rcbs.104766275\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.694254463\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.986034614\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.2049914417\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.487243263\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1291557132\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleProblemBackgroundColor=254,231,224
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.writeOccurrenceHighlighting=true
/bundle_defaults/org.eclipse.ui.editors/isBookmarkGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.ui.workbench/OPEN_ON_SINGLE_CLICK=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_flashiap.com.crt.advproject.projecttype.exe.2033906280/com.crt.advproject.config.exe.debug.1880147916=com.crt.advproject.link.cpp.exe.debug.1712581607\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1540092944\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1650853042\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1209267662\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1113455924\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1880147916\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1225921430\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/com.crt.debugcommon/semihostingState=false
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.system=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style blank_line_before\="true" keep_together\="true" order\="0"/>
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_while=do not insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enumerator.enabled=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enum.underline=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/lwip_tcpecho_sa.com.crt.advproject.projecttype.exe.468432546/com.crt.advproject.config.exe.release.1619684282=com.crt.advproject.gcc.exe.release.715600888\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1994205202\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.857667410\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.120251981\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.2064666483\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.173463807\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.typedef.strikethrough=false
/bundle_defaults/org.eclipse.ui.editors/isIndexResultInNextPrevDropdownToolbarAction=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_pmu.com.crt.advproject.projecttype.exe.1242046794/com.crt.advproject.config.exe.debug.815439733=com.crt.advproject.config.exe.debug.815439733\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.315300907\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1369234815\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1868866796\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.725131995\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.762982395\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1763844694\=rebuildState\\\=false\\r\\n\r\n
/instance/org.eclipse.cdt.core.prj-lpc_board_nxp_lpcxpresso_1769/indexer/preferenceScope=0
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk.scheduler/remindElapsedTime=30 minutes
/bundle_defaults/org.eclipse.ui.workbench/coolBarVisible=true
/bundle_defaults/org.eclipse.ui/CLOSE_EDITORS_ON_EXIT=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_exception_specification=do not insert
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_can.com.crt.advproject.projecttype.exe.1549120935/com.crt.advproject.config.exe.release.794995649=com.crt.advproject.link.exe.release.440877968\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1469513783\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.1926579303\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.212903690\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.2129410273\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.2074713666\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk.scheduler/enabled=false
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk/showLatestVersion=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.field.strikethrough=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_ethernet.com.crt.advproject.projecttype.exe.1632332403/com.crt.advproject.config.exe.debug.1090525059=com.crt.advproject.gas.exe.debug.421609304\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1090525059\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.909433006\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1459417064\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1587156633\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.878183164\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.825344951\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/errorIndication=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/webserver_freertos.com.crt.advproject.projecttype.exe.874780069/com.crt.advproject.config.exe.release.295130519=com.crt.advproject.link.exe.release.179256910\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1468130162\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1612063061\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.863141771\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1788992748\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.1495546561\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/content_assist_category_order=org.eclipse.cdt.ui.parserProposalCategory\:65539\u0000org.eclipse.cdt.ui.textProposalCategory\:65541\u0000org.eclipse.cdt.ui.templateProposalCategory\:2\u0000org.eclipse.cdt.ui.helpProposalCategory\:5\u0000
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.overrideIndicator=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariableDeclaration.enabled=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.isOverrideIndicatorGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/showRevisionAnnotationInNextPrevDropdownToolbarAction=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_catch=do not insert
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_default_functions=false
/bundle_defaults/org.eclipse.ui/SHOW_SYSTEM_JOBS=false
/bundle_defaults/org.eclipse.ui.editors/hyperlinksEnabled=true
/bundle_defaults/org.eclipse.ui/SHOW_MULTIPLE_EDITOR_TABS=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSISv2p00_LPC17xx.com.crt.advproject.projecttype.lib.1193160240/com.crt.advproject.config.lib.release.1079171862=com.crt.advproject.gas.lib.release.48688322\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.lib.release.352135057\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.ar.lib.release.1701225249\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.lib.release.1097962762\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.lib.release.1602026126\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.error.textstyle=SQUIGGLES
/bundle_defaults/org.eclipse.debug.core/org.eclipse.debug.core.PREF_ENABLE_STATUS_HANDLERS=true
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_preprocessor_enabled=false
/bundle_defaults/org.eclipse.cdt.ui/forwardDeclare.enums=false
/bundle_defaults/org.eclipse.ui.ide/saveInterval=5
/instance/org.eclipse.cdt.core.prj-LPCX176x_cmsis2_systick_twinkle/indexer/preferenceScope=0
/bundle_defaults/org.eclipse.cdt.ui/c_default=0,0,0
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.inSameProject=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style angle_brackets\="false" blank_line_before\="false" keep_together\="false" relative_path\="false"/>
/bundle_defaults/org.eclipse.ui.workbench/HeapStatus.showMax=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.templateParameter.underline=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_prefix_operator=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_declarator_list=do not insert
/bundle_defaults/com.crt.debugcommon/displayConsole=false
/instance/org.eclipse.cdt.core.prj-lpc_chip_175x_6x/indexer/preferenceScope=0
/bundle_defaults/org.eclipse.ui.editors/isUnchangedGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_closing_angle_bracket_in_template_parameters=insert
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.showSymbols=true
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.setter.prefix=set
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.methodDeclaration.italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.templateParameter.enabled=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_angle_bracket_in_template_arguments=do not insert
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.writeOccurrenceIndicationInVerticalRuler=false
/bundle_defaults/org.eclipse.cdt.ui/organizeIncludes.symbolExportingHeaders=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<maps>\r\n<map>\r\n<mapping key\="blkcnt_t" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="blkcnt_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="blksize_t" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="blksize_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="calloc" value\="&lt;cstdlib&gt;"/>\r\n<mapping key\="calloc" value\="&lt;stdlib.h&gt;"/>\r\n<mapping key\="daddr_t" value\="&lt;rpc/types.h&gt;"/>\r\n<mapping key\="daddr_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="dev_t" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="dev_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="EOF" value\="&lt;cstdio&gt;"/>\r\n<mapping key\="EOF" value\="&lt;libio.h&gt;"/>\r\n<mapping key\="EOF" value\="&lt;stdio.h&gt;"/>\r\n<mapping key\="error_t" value\="&lt;argp.h&gt;"/>\r\n<mapping key\="error_t" value\="&lt;argz.h&gt;"/>\r\n<mapping key\="error_t" value\="&lt;errno.h&gt;"/>\r\n<mapping key\="free" value\="&lt;cstdlib&gt;"/>\r\n<mapping key\="free" value\="&lt;stdlib.h&gt;"/>\r\n<mapping key\="fsblkcnt_t" value\="&lt;sys/statvfs.h&gt;"/>\r\n<mapping key\="fsblkcnt_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="fsfilcnt_t" value\="&lt;sys/statvfs.h&gt;"/>\r\n<mapping key\="fsfilcnt_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="gid_t" value\="&lt;grp.h&gt;"/>\r\n<mapping key\="gid_t" value\="&lt;pwd.h&gt;"/>\r\n<mapping key\="gid_t" value\="&lt;stropts.h&gt;"/>\r\n<mapping key\="gid_t" value\="&lt;sys/ipc.h&gt;"/>\r\n<mapping key\="gid_t" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="gid_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="gid_t" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="id_t" value\="&lt;sys/resource.h&gt;"/>\r\n<mapping key\="id_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="ino_t" value\="&lt;dirent.h&gt;"/>\r\n<mapping key\="ino_t" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="ino_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="ino64_t" value\="&lt;dirent.h&gt;"/>\r\n<mapping key\="ino64_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="int8_t" value\="&lt;stdint.h&gt;"/>\r\n<mapping key\="int8_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="intptr_t" value\="&lt;stdint.h&gt;"/>\r\n<mapping key\="intptr_t" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="key_t" value\="&lt;sys/ipc.h&gt;"/>\r\n<mapping key\="key_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="malloc" value\="&lt;cstdlib&gt;"/>\r\n<mapping key\="malloc" value\="&lt;stdlib.h&gt;"/>\r\n<mapping key\="mode_t" value\="&lt;sys/ipc.h&gt;"/>\r\n<mapping key\="mode_t" value\="&lt;sys/mman.h&gt;"/>\r\n<mapping key\="mode_t" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="mode_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="nlink_t" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="nlink_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="NULL" value\="&lt;cstddef&gt;"/>\r\n<mapping key\="NULL" value\="&lt;cstdio&gt;"/>\r\n<mapping key\="NULL" value\="&lt;cstdlib&gt;"/>\r\n<mapping key\="NULL" value\="&lt;cstring&gt;"/>\r\n<mapping key\="NULL" value\="&lt;ctime&gt;"/>\r\n<mapping key\="NULL" value\="&lt;cwchar&gt;"/>\r\n<mapping key\="NULL" value\="&lt;locale.h&gt;"/>\r\n<mapping key\="NULL" value\="&lt;stddef.h&gt;"/>\r\n<mapping key\="NULL" value\="&lt;stdio.h&gt;"/>\r\n<mapping key\="NULL" value\="&lt;stdlib.h&gt;"/>\r\n<mapping key\="NULL" value\="&lt;string&gt;"/>\r\n<mapping key\="NULL" value\="&lt;string.h&gt;"/>\r\n<mapping key\="NULL" value\="&lt;time.h&gt;"/>\r\n<mapping key\="NULL" value\="&lt;wchar.h&gt;"/>\r\n<mapping key\="off_t" value\="&lt;sys/mman.h&gt;"/>\r\n<mapping key\="off_t" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="off_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="off_t" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="off64_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="off64_t" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="pid_t" value\="&lt;ctime&gt;"/>\r\n<mapping key\="pid_t" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="pid_t" value\="&lt;sys/msg.h&gt;"/>\r\n<mapping key\="pid_t" value\="&lt;sys/shm.h&gt;"/>\r\n<mapping key\="pid_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="pid_t" value\="&lt;termios.h&gt;"/>\r\n<mapping key\="pid_t" value\="&lt;time.h&gt;"/>\r\n<mapping key\="pid_t" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="pid_t" value\="&lt;utmpx.h&gt;"/>\r\n<mapping key\="realloc" value\="&lt;cstdlib&gt;"/>\r\n<mapping key\="realloc" value\="&lt;stdlib.h&gt;"/>\r\n<mapping key\="sigset_t" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="sigset_t" value\="&lt;sys/epoll.h&gt;"/>\r\n<mapping key\="sigset_t" value\="&lt;sys/select.h&gt;"/>\r\n<mapping key\="size_t" value\="&lt;cstddef&gt;"/>\r\n<mapping key\="size_t" value\="&lt;stddef.h&gt;"/>\r\n<mapping key\="socklen_t" value\="&lt;arpa/inet.h&gt;"/>\r\n<mapping key\="socklen_t" value\="&lt;bits/socket.h&gt;"/>\r\n<mapping key\="socklen_t" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="ssize_t" value\="&lt;monetary.h&gt;"/>\r\n<mapping key\="ssize_t" value\="&lt;sys/msg.h&gt;"/>\r\n<mapping key\="ssize_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="ssize_t" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="std\:\:allocator" value\="&lt;map&gt;"/>\r\n<mapping key\="std\:\:allocator" value\="&lt;memory&gt;"/>\r\n<mapping key\="std\:\:allocator" value\="&lt;set&gt;"/>\r\n<mapping key\="std\:\:allocator" value\="&lt;string&gt;"/>\r\n<mapping key\="std\:\:allocator" value\="&lt;vector&gt;"/>\r\n<mapping key\="std\:\:char_traits" value\="&lt;istream&gt;"/>\r\n<mapping key\="std\:\:char_traits" value\="&lt;ostream&gt;"/>\r\n<mapping key\="std\:\:char_traits" value\="&lt;string&gt;"/>\r\n<mapping key\="suseconds_t" value\="&lt;sys/select.h&gt;"/>\r\n<mapping key\="suseconds_t" value\="&lt;sys/time.h&gt;"/>\r\n<mapping key\="suseconds_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="u_char" value\="&lt;rpc/types.h&gt;"/>\r\n<mapping key\="u_char" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="uid_t" value\="&lt;pwd.h&gt;"/>\r\n<mapping key\="uid_t" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="uid_t" value\="&lt;stropts.h&gt;"/>\r\n<mapping key\="uid_t" value\="&lt;sys/ipc.h&gt;"/>\r\n<mapping key\="uid_t" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="uid_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="uid_t" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="useconds_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="useconds_t" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="va_list" value\="&lt;cstdarg&gt;"/>\r\n<mapping key\="va_list" value\="&lt;stdarg.h&gt;"/>\r\n</map>\r\n</maps>
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_method_declaration=do not insert
/bundle_defaults/com.crt.debugcommon/streamAll=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_LPC43xx_DriverLib.com.crt.advproject.projecttype.lib.446509596/com.crt.advproject.config.lib.debug.1706711087=com.crt.advproject.gas.lib.debug.873301014\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.1970136550\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.1706711087\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.470207401\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.1549626933\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.1636147693\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_colon_in_case=do not insert
/bundle_defaults/com.crt.debugcommon/genericImageVista=LPCXpressoWIN.enc
/bundle_defaults/org.eclipse.cdt.ui/c_default_bold=false
/bundle_defaults/org.eclipse.ui.workbench/SINGLE_CLICK_METHOD=0
/bundle_defaults/org.eclipse.ui.editors/showCarriageReturn=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/RDB1768cmsis_EasyWeb.com.crt.advproject.projecttype.exe.1503643990/com.crt.advproject.config.exe.release.290126908=com.crt.advproject.link.exe.release.1509719446\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.2064883050\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.73082454\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1034802894\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1878142690\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.1785118895\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/isWarningGoToNextNavigationTarget=true
/bundle_defaults/org.eclipse.core.resources/description.autobuilding=true
/bundle_defaults/org.eclipse.cdt.ui/c_keyword_italic=false
/bundle_defaults/org.eclipse.cdt.core/indexer/indexerId=org.eclipse.cdt.core.fastIndexer
/bundle_defaults/org.eclipse.ui/initialFastViewBarLocation=bottom
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.taskCaseSensitive=false
/bundle_defaults/org.eclipse.ui.editors/isSearchResultGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.ui/wrapStrings=true
/bundle_defaults/org.eclipse.cdt.ui/matchingBrackets=true
/bundle_defaults/org.eclipse.ui.editors/changeIndication=false
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.functionOffsetsColor=96,0,0
/bundle_defaults/org.eclipse.ui.editors/currentLine=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.PREF_FILTER_LAUNCH_CLOSED=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_arguments_in_method_invocation=16
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.overloadedOperator.strikethrough=false
/bundle_defaults/org.eclipse.ui.editors/showLeadingTabs=true
/bundle_defaults/org.eclipse.ui.editors/searchResultIndicationColor=206,204,247
/bundle_defaults/org.eclipse.ui.editors/linked.exit.color=0,180,0
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.indexDBCacheSizePct=10
/bundle_defaults/org.eclipse.ui/showIntro=true
/bundle_defaults/org.eclipse.cdt.ui/closeStrings=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.ExpressionView+org.eclipse.debug.ui.ShowTypeNamesAction=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_declarator_list=insert
/bundle_defaults/org.eclipse.ui.editors/breakpointIndication=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_type_declaration=end_of_line
/instance/org.eclipse.cdt.managedbuilder.core/properties/webserver.com.crt.advproject.projecttype.exe.1345313107/com.crt.advproject.config.exe.debug.1009041700=com.crt.advproject.link.exe.debug.58094435\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1443586811\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1759689025\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.629714332\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1009041700\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.902041439\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1467576585\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.workspaceLanguageMappings=
/bundle_defaults/com.crt.debugcommon/genericPID=9
/instance/org.eclipse.cdt.managedbuilder.core/properties/usbd_lib_cdc_uart.com.crt.advproject.projecttype.exe.1798150368/com.crt.advproject.config.exe.debug.633067605=com.crt.advproject.config.exe.debug.633067605\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.92055126\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1784962483\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.486503944\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.2038387832\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.1475022981\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1429105598\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.templateParameter.italic=false
/bundle_defaults/org.eclipse.cdt.ui/c_operators_italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.label.color=0,0,0
/bundle_defaults/org.eclipse.ui.editors/isSearchResultGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/hyperlinkColor.SystemDefault=true
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Color.Background=255,255,255
/bundle_defaults/org.eclipse.ui.editors/hyperlinkKeyModifier=Ctrl
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.PREF_CHANGED_VALUE_BACKGROUND=255,255,0
/bundle_defaults/org.eclipse.ui.editors/isRevisionAnnotationGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.ui.ide/useSeparator.help.group.assist=true
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk.scheduler/download=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_array_initializer=insert
/instance/org.eclipse.cdt.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_watchdog.com.crt.advproject.projecttype.exe.720126098/com.crt.advproject.config.exe.debug.1064966769=com.crt.advproject.link.cpp.exe.debug.255382564\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.101020260\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.802481234\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1669682648\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1321532069\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.469196116\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1064966769\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_timer.com.crt.advproject.projecttype.exe.1309499312/com.crt.advproject.config.exe.debug.813915632=com.crt.advproject.toolchain.exe.debug.1571077862\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.64635116\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.713280462\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1673697699\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1163178252\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.135101893\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.813915632\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.namespace.strikethrough=false
/instance/org.eclipse.debug.ui/pref_state_memento.com.crt.peripheral.PeripheralView=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<VariablesViewMemento org.eclipse.debug.ui.SASH_DETAILS_PART\="315" org.eclipse.debug.ui.SASH_VIEW_PART\="684">\r\n<PRESENTATION_CONTEXT_PROPERTIES IMemento.internal.id\="PeripheralView">\r\n<BOOLEAN BOOLEAN\="true" IMemento.internal.id\="org.eclipse.debug.ui.check"/>\r\n</PRESENTATION_CONTEXT_PROPERTIES>\r\n</VariablesViewMemento>
/bundle_defaults/org.eclipse.cdt.ui/autoOpenConsole=true
/bundle_defaults/org.eclipse.ui.editors/linked.focus.text=true
/bundle_defaults/org.eclipse.core.resources/description.buildorder=
/bundle_defaults/org.eclipse.ui/SHIFT_OPEN_NEW_PERSPECTIVE=OPEN_PERSPECTIVE_REPLACE
/bundle_defaults/org.eclipse.ui.editors/othersIndicationInOverviewRuler=false
/bundle_defaults/org.eclipse.ui.ide/PROBLEMS_LIMIT=100
@org.eclipse.ui.workbench=3.106.1.v20140827-1737
/bundle_defaults/org.eclipse.cdt.ui/asm_label_bold=true
/bundle_defaults/org.eclipse.ui.editors/currentIPVerticalRuler=true
/bundle_defaults/org.eclipse.ui.editors/linked.focus.navigation.dropdown=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.header.capitalization=0
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_ritimer.com.crt.advproject.projecttype.exe.749237195/com.crt.advproject.config.exe.debug.1653325222=com.crt.advproject.link.exe.debug.1504230950\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1653325222\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.231976127\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.2077790918\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1951440756\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.1396920523\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.269804934\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/showTrailingIdeographicSpaces=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/webserver.com.crt.advproject.projecttype.exe.1345313107/com.crt.advproject.config.exe.release.1745840165=com.crt.advproject.toolchain.exe.release.295553106\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1306344566\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.2133637469\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.356011277\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.87988994\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.2038740337\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.editor.CElementHyperlinkDetector_stateMask=-1
/bundle_defaults/org.eclipse.ui.editors/filteredSearchResultIndicationInVerticalRuler=false
/bundle_defaults/org.eclipse.ui.workbench/ENABLE_COOL_BARS=true
/bundle_defaults/org.eclipse.cdt.core/indexer/indexOnOpen=false
/bundle_defaults/org.eclipse.ui.editors/linked.focus.verticalruler=false
/bundle_defaults/org.eclipse.cdt.ui/removeTrailingWhitespaceEditedLines=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.label.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.sameFolder=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style angle_brackets\="false" blank_line_before\="false" keep_together\="false" relative_path\="false"/>
/bundle_defaults/org.eclipse.ui.editors/showEnclosedSpaces=true
/bundle_defaults/org.eclipse.ui.editors/warningIndicationHighlighting=false
/bundle_defaults/org.eclipse.ui.workbench/USE_IPERSISTABLE_EDITORS=true
/bundle_defaults/org.eclipse.ui/ALTERNATE_OPEN_NEW_PERSPECTIVE=OPEN_PERSPECTIVE_REPLACE
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.NavigationEndActionLocal=loop
/bundle_defaults/com.crt.utils/useXMLcache=true
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Color.Foreground=0,0,0
/instance/org.eclipse.cdt.managedbuilder.core/properties/usbd_lib_cdc.com.crt.advproject.projecttype.exe.218798441/com.crt.advproject.config.exe.release.1194419284=com.crt.advproject.toolchain.exe.release.226839519\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.78030496\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.75777627\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.183333774\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.524848630\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.414188755\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.parameterVariable.enabled=false
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.related=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style blank_line_before\="false" keep_together\="false"/>
/bundle_defaults/org.eclipse.ui.editors/warn_if_input_derived=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.class.color=0,80,50
/bundle_defaults/com.crt.advproject/tempaddpaths=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticMethod.enabled=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/usbd_lib_hid_keyboard.com.crt.advproject.projecttype.exe.944853395/com.crt.advproject.config.exe.release.134692510=com.crt.advproject.toolchain.exe.release.1409852559\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1648508565\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1285760810\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1182439007\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.2048303538\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.498522395\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_body_declarations_compare_to_access_specifier=true
/bundle_defaults/com.crt.debugcommon/redlink_wirespeed=0
/bundle_defaults/org.eclipse.ui.editors/warningIndicationColor=244,200,45
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.save_dirty_editors_before_launch=prompt
/bundle_defaults/org.eclipse.cdt.ui/escapeStrings=false
/bundle_defaults/org.eclipse.core.resources/description.snapshotinterval=300000
/bundle_defaults/org.eclipse.ui.editors/secondaryIPIndication=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_adc.com.crt.advproject.projecttype.exe.1322797204/com.crt.advproject.config.exe.debug.570937243=com.crt.advproject.cpp.exe.debug.1554540715\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.570937243\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.859166281\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.949246481\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.671560872\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.79095767\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.994761076\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/indexResultIndication=true
/bundle_defaults/org.eclipse.cdt.ui/content_assist_autoactivation_trigger_replace_dot_with_arrow=true
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk.scheduler/remindOnSchedule=false
/bundle_defaults/org.eclipse.cdt.core/includes.exportPattern=IWYU\\s+(pragma\:?\\s+)?export
/bundle_defaults/org.eclipse.core.net/proxyData/HTTP/port=-1
/bundle_defaults/org.eclipse.ui.editors/unchangedIndicationColor=0,0,0
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_method_declaration_parameters=insert
/bundle_defaults/org.eclipse.ui.editors/isUnchangedGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.header.suffix=.h
/bundle_defaults/org.eclipse.ui/ENABLE_ANIMATIONS=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_if=insert
@org.eclipse.debug.ui=3.10.1.v20140822-1408
/bundle_defaults/org.eclipse.ui.editors/breakpointTextStyle=SQUIGGLES
/instance/org.eclipse.cdt.managedbuilder.core/properties/usbd_lib_composite.com.crt.advproject.projecttype.exe.2137007679/com.crt.advproject.config.exe.debug.1644757415=com.crt.advproject.cpp.exe.debug.2103935598\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.2079787435\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1800337119\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.626770401\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.944544801\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.928595566\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1644757415\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleProblemWarningBackgroundColor=254,243,218
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.path_canonicalization=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_switch=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.compact_else_if=true
/bundle_defaults/org.eclipse.cdt.ui/org.eclipse.cdt.ui.add_comments=false
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.systemWithExtension=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style angle_brackets\="true" blank_line_before\="false" keep_together\="true" order\="1" relative_path\="false"/>
/profile/file\:\\2fC\:\\2fnxp\\2fLPCXpresso_7.6.2_326\\2flpcxpresso\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.ui.sdk.scheduler/migrated34Prefs=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.field.italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.methodDeclaration.enabled=true
/bundle_defaults/org.eclipse.ui/PROJECT_OPEN_NEW_PERSPECTIVE=OPEN_PERSPECTIVE_REPLACE
/bundle_defaults/org.eclipse.cdt.ui/content_assist_autoactivation_delay=500
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_switchstatements_compare_to_switch=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_ssp.com.crt.advproject.projecttype.exe.2073917783/com.crt.advproject.config.exe.release.1685172963=com.crt.advproject.toolchain.exe.release.1661677\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.710368125\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.623441189\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1209643826\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.818233716\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.364014591\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/organizeIncludes.heuristicHeader_substitution=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.VariableView+org.eclipse.debug.ui.ShowDetailPaneAction=true
/bundle_defaults/org.eclipse.ui.workbench/ENABLE_NEW_MENUS=true
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleProblemHighlightedColor=255,0,0
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticField.bold=false
/bundle_defaults/org.eclipse.cdt.ui/stickyOccurrences=true
/configuration/org.eclipse.core.net/org.eclipse.core.net.hasMigrated=true
/bundle_defaults/org.eclipse.ui/SHOW_OTHER_IN_PERSPECTIVE_MENU=true
/bundle_defaults/org.eclipse.ui.editors/errorIndicationHighlighting=false
/bundle_defaults/org.eclipse.ui.editors/rulerContributions=
/instance/org.eclipse.ui.browser/internalWebBrowserHistory=file\:///C\:/nxp/LPCXpresso_7.6.2_326/lpcxpresso/pages/registeredFreeEdition.htm|*|file\://C\:/nxp/LPCXpresso_7.6.2_326/lpcxpresso/pages/registeredFreeEdition.htm|*|
/bundle_defaults/org.eclipse.ui.editors/changeIndicationInVerticalRuler=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_unary_operator=do not insert
/bundle_defaults/org.eclipse.ui.editors/errorTextStyle=PROBLEM_UNDERLINE
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.taskPriorities=normal
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Color.SelectionBackground.SystemDefault=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/webserver_freertos.com.crt.advproject.projecttype.exe.874780069/com.crt.advproject.config.exe.debug.1886496314=com.crt.advproject.cpp.exe.debug.1593928491\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1762572644\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.219570910\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1886496314\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.2046392211\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1488348836\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.457726334\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/isAdditionGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroSubstitution.italic=false
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.AddedLinesRegex=
/instance/org.eclipse.debug.ui/pref_state_memento.org.eclipse.debug.ui.RegisterView=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<VariablesViewMemento org.eclipse.debug.ui.SASH_DETAILS_PART\="315" org.eclipse.debug.ui.SASH_VIEW_PART\="684"/>
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_method_declaration=end_of_line
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_clkout.com.crt.advproject.projecttype.exe.1523737329/com.crt.advproject.config.exe.release.1167106413=com.crt.advproject.link.exe.release.530856060\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.845256876\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1838478822\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.781739769\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.508594437\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.305904039\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/scalability.detect=true
/bundle_defaults/org.eclipse.cdt.ui/org.eclipse.cdt.internal.ui.text.doctools.doxygen.multi=63,95,191
/bundle_defaults/org.eclipse.ui/EDITOR_MINIMUM_CHARACTERS=-1
/bundle_defaults/org.eclipse.cdt.ui/c_type_italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.method.enabled=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.MemoryHistoryKnownColor=0,0,0
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.error.overview=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroDefinition.italic=false
/bundle_defaults/org.eclipse.ui.editors/isBookmarkGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.switch_perspective_on_suspend=prompt
/bundle_defaults/org.eclipse.ui.editors/showTextHoverAffordance=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enum.italic=false
/bundle_defaults/org.eclipse.ui.editors/breakpointHighlight=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.cancel_launch_with_compile_errors=prompt
/bundle_defaults/org.eclipse.ui.editors/quickdiff.defaultProvider=org.eclipse.ui.internal.editors.quickdiff.LastSaveReferenceProvider
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_bracket=do not insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticMethod.italic=true
/bundle_defaults/org.eclipse.cdt.ui/function_output_parameters_before_input=false
/bundle_defaults/org.eclipse.ui.editors/linked.target.text.style=BOX
/bundle_defaults/org.eclipse.cdt.core/indexer/skipTypeReferences=false
/bundle_defaults/org.eclipse.cdt.ui/spelling_ignore_single_letters=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_after_opening_brace_in_array_initializer=do not insert
/bundle_defaults/org.eclipse.ui.ide/USE_MARKER_LIMITS=true
/bundle_defaults/org.eclipse.cdt.ui/c_braces=0,0,0
/bundle_defaults/com.crt.dsfdebug/bkptLocationFix=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/iperf_server.com.crt.advproject.projecttype.exe.1230739403/com.crt.advproject.config.exe.release.2134859713=com.crt.advproject.link.exe.release.1606298999\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.62265057\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1779487827\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.1452087926\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.2076973193\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.997436927\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/com.crt.debugcommon/debuggerName=arm-none-eabi-gdb
/bundle_defaults/org.eclipse.ui.workbench/EDITOR_TAB_WIDTH=3
/bundle_defaults/org.eclipse.cdt.ui/spelling_proposal_threshold=20
/bundle_defaults/org.eclipse.ui.ide/REFRESH_WORKSPACE_ON_STARTUP=false
@org.eclipse.ui.ide=3.10.1.v20140828-0944
/bundle_defaults/org.eclipse.ui/SHOW_TEXT_ON_PERSPECTIVE_BAR=true
/bundle_defaults/com.crt.debugcommon/showProgressInLog=false
/bundle_defaults/org.eclipse.cdt.ui/c_braces_italic=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_CORE_LPC17xx.com.crt.advproject.projecttype.lib.1132436677/com.crt.advproject.config.lib.debug.1991456843=com.crt.advproject.config.lib.debug.1991456843\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.1915179100\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.1423951452\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.1609401827\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.1973900125\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.1584584498\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.typedef.italic=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_CORE_LPC1102.com.crt.advproject.projecttype.lib.2134065871/com.crt.advproject.config.lib.debug.1171384745=com.crt.advproject.cpp.lib.debug.111687239\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.1229796127\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.1171384745\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.239783651\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.1219334096\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.1976020487\=rebuildState\\\=false\\r\\n\r\n
/instance/org.eclipse.cdt.managedbuilder.core/properties/LPCXpresso176x_timer.com.crt.advproject.projecttype.exe.1447070015/com.crt.advproject.config.exe.debug.1115091451=com.crt.advproject.gas.exe.debug.1691739915\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1083863975\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.922664229.1499417384\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.160123065\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1471583358\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1488813715\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1115091451.src/cr_startup_lpc176x.c\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.config.exe.debug.1115091451\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.922664229\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariableDeclaration.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticMethod.color=0,0,0
/instance/org.eclipse.cdt.core.prj-periph_blinky/indexer/preferenceScope=0
/bundle_defaults/com.crt.utils/showWelcomeView=true
/bundle_defaults/org.eclipse.ui/disableNewFastView=false
/bundle_defaults/org.eclipse.ui.editors/isFilteredSearchResultGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.ui/c_string_bold=false
/bundle_defaults/org.eclipse.ui.editors/useAnnotationsPrefPage=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_rtc.com.crt.advproject.projecttype.exe.605406851/com.crt.advproject.config.exe.debug.1144910716=com.crt.advproject.gas.exe.debug.1572169051\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.1573714766\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1144910716\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1005180494\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.962599421\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.2066055257\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1964125179\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariableDeclaration.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.typedef.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.parameterVariable.strikethrough=false
/bundle_defaults/com.crt.debugcommon/genericParameter=-wire\=winUSB
/bundle_defaults/com.crt.debugcommon/genericVID=8137
/instance/org.eclipse.cdt.managedbuilder.core/properties/LPCXpresso1768_systick.com.crt.advproject.projecttype.exe.783271606/com.crt.advproject.config.exe.release.591890536=com.crt.advproject.link.exe.release.2066767215\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.784804749\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.762673705\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.723349040\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1011426480\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.724136925\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_expressions_in_array_initializer=16
/bundle_defaults/org.eclipse.debug.core/org.eclipse.debug.core.USE_STEP_FILTERS=false
/bundle_defaults/org.eclipse.cdt.ui/org.eclipse.cdt.ui.editor.UseStructuralMode=false
/bundle_defaults/org.eclipse.ui.workbench/MULTI_KEY_ASSIST=true
/bundle_defaults/org.eclipse.cdt.ui/c_keyword=127,0,85
/bundle_defaults/org.eclipse.ui.editors/linked.exit.overviewruler=false
/bundle_defaults/com.crt.utils/commandPrompt=cmd.exe /C start
/bundle_defaults/org.eclipse.cdt.ui/content_assist_autoactivation_trigger_dot=true
/instance/org.eclipse.cdt.ui.prj-periph_blinky/buildConsole/keepLog=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_assignment=16
/bundle_defaults/org.eclipse.ui.editors/revisionRulerShowAuthor=false
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleOutputStreamColor=0,0,0
/bundle_defaults/org.eclipse.ui.editors/deletionIndicationColor=0,0,0
/bundle_defaults/org.eclipse.debug.ui/org.eclispe.debug.ui.memory.pageSize=20
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.field.underline=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.code_formatter=org.eclipse.cdt.core.defaultCodeFormatter
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.getter.wordDelimiter=
/bundle_defaults/org.eclipse.ui.editors/linked.slave.verticalruler=false
/bundle_defaults/org.eclipse.ui.workbench/EDITORLIST_SORT_CRITERIA=0
/bundle_defaults/org.eclipse.ui/ENABLE_MIN_MAX=true
/bundle_defaults/org.eclipse.ui.editors/additionIndicationInVerticalRuler=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_rtc.com.crt.advproject.projecttype.exe.605406851/com.crt.advproject.config.exe.release.2026987447=com.crt.advproject.link.cpp.exe.release.549761656\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1521143880\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.836740799\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1650596216\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1059462876\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.825377008\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_colon_in_case=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_while=do not insert
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.matchingPattern=
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_angle_bracket_in_template_arguments=do not insert
/bundle_defaults/org.eclipse.ui.editors/searchResultTextStyle=NONE
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.occurrenceIndicationInVerticalRuler=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/lpc_chip_175x_6x.com.crt.advproject.projecttype.lib.1977998334/com.crt.advproject.config.lib.debug.1264058482=com.crt.advproject.toolchain.lib.debug.593853259\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.1317359937\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.1653831520\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.1264058482\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.1864839615\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.756466351\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/bookmarkIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Color.SelectionForeground.SystemDefault=true
/bundle_defaults/org.eclipse.ui.editors/taskIndicationInOverviewRuler=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/usbd_lib_cdc.com.crt.advproject.projecttype.exe.218798441/com.crt.advproject.config.exe.debug.1792480862=com.crt.advproject.cpp.exe.debug.316691243\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1390072318\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.336376765\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.1082991463\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1302775373\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1792480862\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1330040580\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.core/includes.beginExportsPattern=IWYU\\s+(pragma\:?\\s+)?begin_exports?
/bundle_defaults/org.eclipse.ui.workbench/REUSE_OPEN_EDITORS_BOOLEAN=false
/bundle_defaults/com.crt.debugcommon/redlink_showTimestamps=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_compact_if=16
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_cast=do not insert
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_CORE_LPC11xx.com.crt.advproject.projecttype.lib.663819903/com.crt.advproject.config.lib.debug.1575154836=com.crt.advproject.config.lib.debug.1575154836\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.1921248460\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.483294928\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.224538997\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.1059437607\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.2095482798\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/com.crt.debugcommon/probe_use_old=true
/bundle_defaults/org.eclipse.debug.ui/org.eclispe.debug.ui.memory.postBufferSize=20
/bundle_defaults/org.eclipse.cdt.core/scalability.maximumTokens=25000000
/instance/org.eclipse.cdt.ui/spelling_locale_initialized=true
/bundle_defaults/org.eclipse.ui.editors/taskIndicationColor=0,128,255
/instance/org.eclipse.ui.ide/quickStart=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.remove_breakpoints_from_container_prompt=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticField.enabled=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_colon_in_labeled_statement=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_catch=do not insert
/bundle_defaults/org.eclipse.ui.editors/infoIndicationHighlighting=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.warning.color=255,255,0
/bundle_defaults/org.eclipse.cdt.ui/pp_default=0,0,0
/bundle_defaults/org.eclipse.ui.editors/showUnchangedInNextPrevDropdownToolbarAction=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/LPCXpresso1768_systick_twinkle.com.crt.advproject.projecttype.exe.2094231798/com.crt.advproject.config.exe.release.116571318=com.crt.advproject.link.cpp.exe.release.1527474121\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.26164475\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1526285554\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1124414934\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.2032773937\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1519254681\=rebuildState\\\=true\\r\\n\r\n
/instance/org.eclipse.cdt.managedbuilder.core/properties/ucos_iii_blinky.com.crt.advproject.projecttype.exe.113910480/com.crt.advproject.config.exe.debug.1728897436=com.crt.advproject.link.cpp.exe.debug.39638239\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1728897436\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1483790199\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1570489508\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1408003178\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.35123696\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1988230386\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_before_colon_in_constructor_initializer_list=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_enumerator_list=48
/bundle_defaults/org.eclipse.ui.editors/isBreakpointIndicationGoToNextNavigationTarget=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/usbd_lib_cdc_uart.com.crt.advproject.projecttype.exe.1798150368/com.crt.advproject.config.exe.release.1739015961=com.crt.advproject.toolchain.exe.release.140139306\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1080565756\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1212717813\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.271070702\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.182351402\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.875397863\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.workbench/overridepresentation=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.showoverrideIndicatorInNextPrevDropdownToolbarAction=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_colon_in_base_clause=do not insert
/bundle_defaults/org.eclipse.cdt.ui/hoverModifierMasks=org.eclipse.cdt.ui.BestMatchHover;0;org.eclipse.cdt.ui.CSourceHover;131072
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroDefinition.bold=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroSubstitution.enabled=false
/bundle_defaults/org.eclipse.cdt.ui/c_comment_task_tag_italic=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_semicolon_in_for=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_template_arguments=do not insert
/bundle_defaults/org.eclipse.cdt.dsf.gdb/defaultGdbCommand=gdb
/bundle_defaults/org.eclipse.cdt.codan.core/inEditor=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_blinky.com.crt.advproject.projecttype.exe.424940172/com.crt.advproject.config.exe.debug.320861772=com.crt.advproject.link.cpp.exe.debug.687245962\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.823968430\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.406618380\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1748761643\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.320861772\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1200583274\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1441851293\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/class_member_ascending_visibility_order=false
/bundle_defaults/org.eclipse.cdt.ui/sourceHoverBackgroundColor.SystemDefault=true
/bundle_defaults/org.eclipse.ui.editors/searchResultIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/linked.target.text=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.isOverrideIndicatorGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.ui/SHOW_TRADITIONAL_STYLE_TABS=true
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.UseOutlineView=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.RemoveFromLaunchHistory=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.method.color=0,0,0
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk.scheduler/showUpdateWizard=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.header.prefix=
/bundle_defaults/com.crt.advproject/createlinkerscript=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.LaunchParentProject=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.overloadedOperator.color=200,100,0
/bundle_defaults/org.eclipse.cdt.ui/Refactor.lightweight=true
/bundle_defaults/org.eclipse.debug.ui/Console.limitConsoleOutput=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_method_declaration=do not insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariable.enabled=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/LPCXpresso1768_systick_twinkle.com.crt.advproject.projecttype.exe.2094231798/com.crt.advproject.config.exe.debug.1700699240=org.eclipse.cdt.managedbuilder.ui.rcbs.1179417422\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.726819074\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1215601901\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.557441015\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1188391701\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1700699240.1872544513\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1543468204\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1700699240\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1215601901.1916540435\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.2118247634\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/spacesForTabs=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_after_template_declaration=do not insert
/bundle_defaults/org.eclipse.ui.editors/linked.target.overviewruler=false
/bundle_defaults/org.eclipse.ui.editors/deletionIndicationInOverviewRuler=false
/bundle_defaults/org.eclipse.ui.editors/linked.exit.text=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariableDeclaration.bold=false
/bundle_defaults/org.eclipse.ui.editors/bookmarkTextStyle=SQUIGGLES
/bundle_defaults/org.eclipse.core.resources/snapshots.operations=100
/bundle_defaults/org.eclipse.ui.editors/bookmarkIndication=false
/bundle_defaults/org.eclipse.ui.editors/indexResultIndicationColor=254,155,0
/bundle_defaults/org.eclipse.cdt.codan.core/onBuild=false
/bundle_defaults/org.eclipse.cdt.ui/closeAngularBrackets=true
/bundle_defaults/org.eclipse.cdt.ui/consoleOnTop=false
/bundle_defaults/org.eclipse.ui.editors/termin=110,220,110
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_watchdog.com.crt.advproject.projecttype.exe.720126098/com.crt.advproject.config.exe.release.1738151752=com.crt.advproject.cpp.exe.release.1487373402\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.417315122\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1915328161\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1683719605\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1429431212\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1097649050\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/breakpointIndicationColor=0,0,255
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_postfix_operator=do not insert
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_systick.com.crt.advproject.projecttype.exe.349735055/com.crt.advproject.config.exe.debug.1708114495=com.crt.advproject.gas.exe.debug.1510048182\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.470430945\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.1179205170\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1099851258\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1708114495\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.636559943\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.2110503964\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.dsf.gdb/maxGdbTraces=500000
/bundle_defaults/org.eclipse.cdt.ui/inactiveCodeColor=224,224,224
/instance/org.eclipse.cdt.managedbuilder.core/properties/lpcusblib_KeyboardHost.com.crt.advproject.projecttype.exe.1776494588/com.crt.advproject.config.exe.release.675946607=com.crt.advproject.cpp.exe.release.1593360022\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1250332176\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.6763122\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1816566527\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1063855647\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1543449802\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticMethod.strikethrough=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_constructor_initializer_list=0
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.method.strikethrough=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_CORE_LPC11xxLV.com.crt.advproject.projecttype.lib.1331552380/com.crt.advproject.config.lib.debug.1498659410=com.crt.advproject.gas.lib.debug.205943174\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.1476934997\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.1658191416\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.1000541325\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.1498659410\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.182558187\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/com.crt.debugcommon/genericEnabled=false
/instance/org.eclipse.cdt.core.prj-CMSISv2p00_LPC17xx/indexer/preferenceScope=0
/bundle_defaults/org.eclipse.cdt.core/scalability.skipTrivialExpressions=true
/bundle_defaults/org.eclipse.cdt.ui/handleTemporaryProblems=true
/bundle_defaults/org.eclipse.cdt.ui/c_single_line_comment=63,127,95
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.memory.columnSize=4
/bundle_defaults/com.crt.debugcommon/serverPort=0
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.warning.ruler=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/lpc_board_nxp_lpcxpresso_1769.com.crt.advproject.projecttype.lib.1078462419/com.crt.advproject.config.lib.debug.267437161=com.crt.advproject.gcc.lib.debug.1874917562\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.224156237\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.787516598\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.1176373407\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.267437161\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.486889114\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/linked.exit.highlight=false
/bundle_defaults/org.eclipse.cdt.ui/c_comment_task_tag=127,159,191
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroSubstitution.color=0,0,0
/bundle_defaults/org.eclipse.ui.editors/showChangeInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_angle_bracket_in_template_parameters=do not insert
/bundle_defaults/org.eclipse.cdt.ui/c_type=127,0,85
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticMethod.underline=false
/bundle_defaults/com.crt.dsfdebug/altRefreshBehavior=true
/bundle_defaults/org.eclipse.ui.editors/warningIndication=true
/bundle_defaults/org.eclipse.ui.workbench/EDITORLIST_PULLDOWN_ACTIVE=false
/bundle_defaults/org.eclipse.core.net/proxiesEnabled=true
/bundle_defaults/org.eclipse.ui.workbench/STICKY_CYCLE=false
/bundle_defaults/org.eclipse.cdt.ui/c_numbers_italic=false
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleLines=500
/bundle_defaults/org.eclipse.ui.workbench/SELECT_ON_HOVER=false
/bundle_defaults/org.eclipse.ui.editors/revisionAnnotationIndicationInVerticalRuler=false
/bundle_defaults/org.eclipse.ui.editors/linked.exit.navigation.dropdown=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_method_invocation=do not insert
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Color.Foreground.SystemDefault=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.label.italic=false
/bundle_defaults/com.crt.debugcommon/relink_dfu_find=true
/bundle_defaults/org.eclipse.cdt.dsf.gdb/defaultStopAtMainSymbol=main
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.format_guardian_clause_on_one_line=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_base_clause_in_type_declaration=80
/bundle_defaults/org.eclipse.ui.editors/linked.slave.navigation.previous=false
/bundle_defaults/org.eclipse.ui.editors/isAdditionGoToPreviousNavigationTarget=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/RDB1768cmsis_EasyWeb.com.crt.advproject.projecttype.exe.1503643990/com.crt.advproject.config.exe.debug.1095747236=com.crt.advproject.gcc.exe.debug.583453200.830262054\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.784245429\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1095747236\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.583453200\=rebuildState\\\=false\\r\\n\r\norg.eclipse.cdt.managedbuilder.ui.rcbs.409250964\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.debug.237846413\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.181471\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.1617126296\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.2070344148\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1095747236.934195708\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.warning.NextPrevDropdownToolbar=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_conditional_expression_chain=18
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.writeOccurrenceTextStyle=NONE
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.OpenStructureCompare=true
/bundle_defaults/org.eclipse.ui.editors/errorIndicationColor=255,0,128
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_default_macros=false
/bundle_defaults/org.eclipse.ui.workbench/OPEN_AFTER_DELAY=false
/bundle_defaults/org.eclipse.debug.core/org.eclipse.debug.core.PREF_DELETE_CONFIGS_ON_PROJECT_DELETE=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.constant.suffix=
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_member_access=0
/bundle_defaults/com.crt.utils/showVerboseErrors=true
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.setter.capitalization=3
/bundle_defaults/org.eclipse.cdt.core/indexer/skipIncludedFilesLargerThanMB=16
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.parameterVariable.color=0,0,0
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_expression_list=0
/bundle_defaults/org.eclipse.ui.editors/isInfoGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/unchangedIndicationInOverviewRuler=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariable.underline=false
/bundle_defaults/org.eclipse.ui.editors/linked.slave.text.style=NONE
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_pmu.com.crt.advproject.projecttype.exe.1242046794/com.crt.advproject.config.exe.release.389189387=com.crt.advproject.toolchain.exe.release.978190380\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1470029090\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.1578400653\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1415685171\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1480216083\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1728937052\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.warning.GoToNextNavigationTarget=true
/profile/file\:\\2fC\:\\2fnxp\\2fLPCXpresso_7.6.2_326\\2flpcxpresso\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.ui.sdk.scheduler/autoUpdateInit=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.typedef.bold=false
/bundle_defaults/org.eclipse.cdt.core/indexer/skipFilesLargerThanMB=8
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_CORE_LPC12xx.com.crt.advproject.projecttype.lib.2046742754/com.crt.advproject.config.lib.debug.1869600139=com.crt.advproject.ar.lib.debug.2046574041\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.1869600139\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.1067127894\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.1038768540\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.26316877\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.223437482\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/warningTextStyle=PROBLEM_UNDERLINE
/bundle_defaults/org.eclipse.ui.editors/secondaryIPColor=219,235,204
/bundle_defaults/org.eclipse.cdt.ui/content_assist_autoactivation_trigger_doublecolon=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.field.enabled=true
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.getter.prefixForBoolean=is
/bundle_defaults/org.eclipse.ui.editors/showWarningInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.ui.editors/breakpointVerticalRuler=true
/bundle_defaults/org.eclipse.cdt.dsf.gdb/org.eclipse.cdt.dsf.gdb.commandTimeout=false
/instance/org.eclipse.debug.ui/preferredTargets=org.eclipse.cdt.debug.ui.toggleCBreakpointTarget,org.eclipse.cdt.debug.ui.toggleCDynamicPrintfTarget\:org.eclipse.cdt.debug.ui.toggleCBreakpointTarget|
/bundle_defaults/org.eclipse.cdt.ui/closeBraces=true
/bundle_defaults/org.eclipse.ui.editors/isWarningGoToPreviousNavigationTarget=true
/bundle_defaults/org.eclipse.cdt.ui/c_operators_bold=false
/bundle_defaults/com.crt.utils/quickstart.navlink=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.field.bold=false
/bundle_defaults/org.eclipse.ui.editors/showBookmarkInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.startAddress=0
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_body_declarations_compare_to_namespace_header=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_cast=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_between_empty_parens_in_exception_specification=do not insert
/bundle_defaults/org.eclipse.ui.workbench/HeapStatus.updateInterval=500
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_LPC43xx_DriverLib-M0.com.crt.advproject.projecttype.lib.1313392389/com.crt.advproject.config.lib.debug.489607714=com.crt.advproject.cpp.lib.debug.1400584359\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.1662940542\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.173058116\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.2039253860\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.1035256333\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.489607714\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.debug.core/org.eclipse.cdt.debug.corecDebug.character_set=UTF-16
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.showOccurrenceInNextPrevDropdownToolbarAction=true
/bundle_defaults/com.crt.debugcommon/swvPacketTimeout=0
/bundle_defaults/org.eclipse.cdt.core/indexer/indexUnusedHeadersWithAlternateLang=false
/bundle_defaults/org.eclipse.ui.editors/spellingIndicationColor=255,128,64
/bundle_defaults/org.eclipse.core.resources/description.maxfilestatesize=1048576
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.continuation_indentation=2
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Color.FindScope=185,176,180
/bundle_defaults/org.eclipse.ui.editors/isChangeGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/additionIndicationInOverviewRuler=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.globalVariable.color=0,0,0
/bundle_defaults/org.eclipse.cdt.core/scalability.maximumTrivialExpressions=1000
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.show_run_perspective_default=perspective_none
/bundle_defaults/org.eclipse.cdt.ui/organizeIncludes.allowReordering=true
/bundle_defaults/org.eclipse.ui.editors/isErrorGoToNextNavigationTarget=true
/bundle_defaults/com.crt.debugcommon/driver_settle=30
/bundle_defaults/com.crt.utils/crt.diagnostics=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.occurrenceIndication=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_expression_list=do not insert
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.getter.capitalization=3
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_template_parameters=insert
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.error.GoToPreviousNavigationTarget=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_switch=insert
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.remove_all_breakpoints_prompt=true
/bundle_defaults/org.eclipse.cdt.ui/spelling_user_dictionary_encoding=Cp1254
/bundle_defaults/com.crt.debugcommon/extendedLogging=false
/bundle_defaults/org.eclipse.ui/PROMPT_WHEN_SAVEABLE_STILL_OPEN=true
/bundle_defaults/com.crt.dsfdebug/altLabelProvider=false
/bundle_defaults/org.eclipse.ui.editors/useQuickDiffPrefPage=false
/bundle_defaults/org.eclipse.ui.ide/LIMIT_PROBLEMS=true
/bundle_defaults/org.eclipse.ui.editors/linked.focus.highlight=false
/bundle_defaults/org.eclipse.cdt.ui/c_single_line_comment_bold=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_method_declaration_throws=insert
/bundle_defaults/org.eclipse.cdt.ui/content_assist_proposal_filter=0;<Default Filter>
/bundle_defaults/com.crt.dsfdebug/altTerminate=false
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.showAddressRadix=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.problem.underline=false
/bundle_defaults/org.eclipse.cdt.ui/function_pass_output_parameters_by_pointer=false
/bundle_defaults/org.eclipse.ui.workbench/ENABLE_CONFIGURABLE_PROJECT_WIZARD=false
/bundle_defaults/org.eclipse.debug.ui/Expressions.detail.orientation=Variables.detail.orientation.underneath
/bundle_defaults/org.eclipse.ui.workbench/EDITORLIST_DISPLAY_FULL_NAME=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.PREF_FILTER_WORKING_SETS=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.function.italic=false
/bundle_defaults/com.crt.config/urlBase=
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticField.italic=true
/instance/org.eclipse.cdt.core.prj-LPCX176x_cmsis2_timers/indexer/preferenceScope=0
@org.eclipse.core.resources=3.9.1.v20140825-1431
/bundle_defaults/org.eclipse.cdt.debug.core/org.eclipse.cdt.debug.corecDebug.non_wide_character_set=windows-1254
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.InitiallyShowAncestorPane=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_statements_compare_to_body=true
/bundle_defaults/org.eclipse.cdt.core/build.proj.ref.configs.enabled=false
/bundle_defaults/org.eclipse.cdt.ui/codetemplates.includeGuardGenerationScheme=2
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.method.suffix=
/bundle_defaults/org.eclipse.ui.editors/com.crt.etmetb.marker.profile.pref.text=true
/bundle_defaults/org.eclipse.ui.workbench/WORKBENCH_SAVE_INTERVAL=5
/bundle_defaults/org.eclipse.ui.editors/spellingIndicationInOverviewRuler=false
/bundle_defaults/com.crt.dsfdebug/arrayChunkSize=100
/bundle_defaults/org.eclipse.ui.ide/BOOKMARKS_FILTERS_MIGRATE=false
/bundle_defaults/org.eclipse.ui.editors/taskIndication=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_method_declaration=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_if=do not insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.class.bold=false
/bundle_defaults/org.eclipse.ui.editors/changeIndicationColor=204,163,205
/bundle_defaults/org.eclipse.ui.editors/linked.target.highlight=false
/bundle_defaults/org.eclipse.ui.workbench/BIDI_SUPPORT=false
/bundle_defaults/org.eclipse.cdt.ui/asm_directive_bold=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticField.color=0,0,192
/bundle_defaults/org.eclipse.ui.editors/linked.focus.navigation.next=false
/bundle_defaults/org.eclipse.ui.editors/isInfoGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_exception_specification=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_expression_list=insert
/bundle_defaults/org.eclipse.ui.editors/revisionRulerRenderingMode=Age
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_switch=end_of_line
/bundle_defaults/org.eclipse.cdt.ui/content_assist_project_search_scope=false
@org.eclipse.ui.editors=3.8.200.v20140401-1310
/bundle_defaults/org.eclipse.cdt.ui/Refactoring.savealleditors=false
/bundle_defaults/org.eclipse.ui.ide/TASKS_LIMIT=100
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.externalSDK.underline=false
/bundle_defaults/org.eclipse.ui.editors/additionIndication=false
/bundle_defaults/org.eclipse.cdt.ui/c_type_bold=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_overloaded_left_shift_chain=16
/bundle_defaults/org.eclipse.cdt.ui/closeBrackets=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.MemoryHistoryUnknownColor=114,119,129
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_pinint.com.crt.advproject.projecttype.exe.500409353/com.crt.advproject.config.exe.release.809780712=com.crt.advproject.gcc.exe.release.607726278\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1281540969\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1043201516\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1771186119\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.590733964\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.2046459755\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.ide/useSeparator.help.group.updates=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/freertos_blinky.com.crt.advproject.projecttype.exe.1693076455/com.crt.advproject.config.exe.release.514344055=com.crt.advproject.cpp.exe.release.596333881\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1233252549\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.572949477\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1942620602\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1909829756\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1745362883\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/pp_directive=127,0,85
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.externalSDK.strikethrough=false
/instance/org.eclipse.ui.ide/PROBLEMS_FILTERS_MIGRATE=true
/bundle_defaults/com.crt.debugcommon/Redlink\ Server=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_assignment_operator=insert
/bundle_defaults/org.eclipse.ui.editors/isTaskGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.dsf.gdb/useInspectorHover=true
/bundle_defaults/com.crt.advproject/addchipdescriptions=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_between_empty_brackets=do not insert
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.track_views=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/lwip_tcpecho_freertos.com.crt.advproject.projecttype.exe.1420589482/com.crt.advproject.config.exe.release.1056112912=com.crt.advproject.cpp.exe.release.2063395937\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.572207940\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1638490324\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.288331770\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.738637504\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.792758414\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_for=insert
/instance/org.eclipse.ui.editors/overviewRuler_migration=migrated_3.1
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.showSourceFilesInBinaries=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_block_in_case=end_of_line
/instance/org.eclipse.cdt.managedbuilder.core/properties/lpcusblib_MassStorageHost.com.crt.advproject.projecttype.exe.71920452/com.crt.advproject.config.exe.release.602528808=com.crt.advproject.toolchain.exe.release.1566228802\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1136674319\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.60566226\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1225949085\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.213504139\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.143744362\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/com.crt.advproject/linkscriptdir=linkscripts
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.methodDeclaration.bold=true
/bundle_defaults/org.eclipse.ui.editors/errorIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/revisionAnnotationIndication=false
@org.eclipse.cdt.debug.core=7.5.0.201409172108
/bundle_defaults/org.eclipse.ui.editors/linked.target.navigation.previous=false
/bundle_defaults/org.eclipse.cdt.dsf.gdb/enablePrettyPrinting=true
/bundle_defaults/org.eclipse.core.resources/encoding=
/bundle_defaults/org.eclipse.ui.editors/unchangedIndication=false
/bundle_defaults/org.eclipse.core.resources/description.disableLinking=false
/bundle_defaults/org.eclipse.cdt.ui/forwardDeclare.functions=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_array_initializer=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_type_declaration=insert
/bundle_defaults/org.eclipse.ui.editors/tabWidth=4
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk/allowNonOKPlan=prompt
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_adc.com.crt.advproject.projecttype.exe.1322797204/com.crt.advproject.config.exe.release.1946989772=com.crt.advproject.gcc.exe.release.48021137\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.914124013\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.895665888\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.766485705\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1473272062\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.879936560\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Accessibility.WideCaret=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.problem.bold=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_access_specifier_compare_to_type_header=false
/bundle_defaults/com.crt.debugcommon/LPC-Link\ (HID)=true
file_export_version=3.0
/bundle_defaults/org.eclipse.cdt.core/includes.privatePattern=IWYU\\s+(pragma\:?\\s+)?private(,\\s+include\\s+(?<header>\\S+))?
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.inOtherProject=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style angle_brackets\="false" blank_line_before\="false" keep_together\="false" relative_path\="false"/>
/bundle_defaults/org.eclipse.ui.editors/linked.exit.text.style=IBEAM
/bundle_defaults/org.eclipse.cdt.ui/pp_directive_italic=false
/bundle_defaults/org.eclipse.cdt.ui/wizard.group.others.enable=true
/bundle_defaults/org.eclipse.ui.editors/isBreakpointIndicationGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariableDeclaration.color=128,0,0
/instance/org.eclipse.debug.core//org.eclipse.debug.core.PREFERRED_DELEGATES/org.eclipse.cdt.launch.attachLaunchType=org.eclipse.cdt.dsf.gdb.launch.attachCLaunch,debug,;
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.VariableView+org.eclipse.debug.ui.ShowTypeNamesAction=false
/bundle_defaults/org.eclipse.ui/OPEN_NEW_PERSPECTIVE=OPEN_PERSPECTIVE_REPLACE
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.problem.enabled=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_CORE_LPC13xx.com.crt.advproject.projecttype.lib.1385448813/com.crt.advproject.config.lib.debug.581745906=com.crt.advproject.ar.lib.debug.1292774045\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.1574829665\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.612994528\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.581745906\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.717048448\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.941307039\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_parenthesized_expression=do not insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.globalVariable.strikethrough=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.defaultEbcdicCodePage=CP037
/bundle_defaults/org.eclipse.ui.editors/secondaryIPVerticalRuler=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_clkout.com.crt.advproject.projecttype.exe.1523737329/com.crt.advproject.config.exe.debug.180527154=com.crt.advproject.link.exe.debug.1821395612\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.1745459261\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1708288974\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.556507730\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.180527154\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1687012010\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.2092012931\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/othersIndication=false
/bundle_defaults/com.crt.debugcommon/redlink_ask_to_boot=false
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.addressRadix=16
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indentation.size=4
/bundle_defaults/org.eclipse.cdt.ui/c_multi_line_comment_bold=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.constant.prefix=
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticMethod.bold=false
/bundle_defaults/org.eclipse.cdt.core/indexer/indexUnusedHeadersWithDefaultLang=true
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.opcodeRadix=16
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_block=insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enumerator.underline=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_spi.com.crt.advproject.projecttype.exe.1116578252/com.crt.advproject.config.exe.release.148649193=com.crt.advproject.link.cpp.exe.release.1766850755\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1024407775\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.503899537\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.575180509\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.38522315\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.922314565\=rebuildState\\\=true\\r\\n\r\n
/configuration/org.eclipse.ui.ide/MAX_RECENT_WORKSPACES=5
/bundle_defaults/org.eclipse.ui.editors/showDeletionInNextPrevDropdownToolbarAction=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.switch_to_perspective=never
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_CORE_LPC11Axx.com.crt.advproject.projecttype.lib.323077590/com.crt.advproject.config.lib.debug.155024037=com.crt.advproject.ar.lib.debug.619333461\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.lib.debug.479237615\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.155024037\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.453650134\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.143674930\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.130954740\=rebuildState\\\=false\\r\\n\r\n
/instance/org.eclipse.ui.workbench/UIActivities.org.eclipse.cdt.debug.dsfgdbActivity=true
/bundle_defaults/org.eclipse.ui.workbench/NL_EXTENSIONS=
/bundle_defaults/org.eclipse.core.net/proxyData/SOCKS/hasAuth=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.methodDeclaration.color=0,0,0
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.globalVariable.underline=false
/bundle_defaults/org.eclipse.cdt.core/indexer/skipMacroReferences=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.function.color=0,0,0
/bundle_defaults/org.eclipse.ui.editors/isRevisionAnnotationGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.core.net/systemProxiesEnabled=true
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.ShowPseudoConflicts=false
/bundle_defaults/org.eclipse.cdt.ui/c_default_italic=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.keep_then_statement_on_same_line=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_switch=do not insert
/bundle_defaults/org.eclipse.cdt.ui/org.eclipse.cdt.internal.ui.text.doctools.doxygen.single=63,95,191
/instance/org.eclipse.cdt.managedbuilder.core/properties/ucos_iii_blinky.com.crt.advproject.projecttype.exe.113910480/com.crt.advproject.config.exe.release.1706971613=com.crt.advproject.toolchain.exe.release.2108839201\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.848952791\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.513168767\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1970360558\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.135113262\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1079269625\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.parameterVariable.italic=false
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.showSource=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.isOccurrenceGoToPreviousNavigationTarget=false
/bundle_defaults/com.crt.quickstart/wizardTemplateSupport=true
/bundle_defaults/org.eclipse.cdt.ui/spelling_ignore_non_letters=true
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleBackgroundColor=255,255,255
/bundle_defaults/org.eclipse.ui.editors/linked.slave.text=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.writeOccurrenceIndicationInOverviewRuler=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/usbd_lib_composite.com.crt.advproject.projecttype.exe.2137007679/com.crt.advproject.config.exe.release.1869947099=com.crt.advproject.cpp.exe.release.1379756456\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1748461686\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1827532787\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.359222123\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.2090809526\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.393776227\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.workbench/DISABLE_OPEN_EDITOR_IN_PLACE=false
/bundle_defaults/org.eclipse.ui.editors/warningIndicationInVerticalRuler=true
/bundle_defaults/com.crt.quickstart/autpBrowseWeb=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.showSourceRootsAtTopLevelOfProject=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_in_empty_block=insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroSubstitution.bold=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.inColor=0,200,125
/bundle_defaults/org.eclipse.cdt.dsf.ui/stackFrameLimitEnable=true
/bundle_defaults/org.eclipse.ui.editors/revisionAnnotationIndicationColor=88,88,22
/bundle_defaults/com.crt.dsfdebug/attachRestart=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/usbd_lib_hid_generic.com.crt.advproject.projecttype.exe.1358948682/com.crt.advproject.config.exe.release.823668469=com.crt.advproject.toolchain.exe.release.1184916576\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.909534463\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1083649875\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.529656299\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.107267058\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.740681601\=rebuildState\\\=true\\r\\n\r\n
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES_PROTOCOL=3
/bundle_defaults/org.eclipse.cdt.ui/contentAssist.showCamelCaseMatches=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.keep_else_statement_on_same_line=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_method_invocation=do not insert
/bundle_defaults/org.eclipse.ui.editors/infoIndication=false
/bundle_defaults/org.eclipse.debug.ui/Variables.detail.orientation=Variables.detail.orientation.underneath
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enum.color=100,70,50
/bundle_defaults/com.crt.dsfdebug/extendedDebugTrace=0
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.parameterVariable.bold=false
/bundle_defaults/org.eclipse.ui.editors/textDragAndDropEnabled=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.methodDeclaration.underline=false
/bundle_defaults/org.eclipse.cdt.ui/c_single_line_comment_italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.namespace.bold=false
/profile/file\:\\2fC\:\\2fnxp\\2fLPCXpresso_7.6.2_326\\2flpcxpresso\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.ui.sdk/allowNonOKPlan=prompt
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.subfolder=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style angle_brackets\="false" blank_line_before\="false" keep_together\="false" relative_path\="false"/>
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.source.prefix=
/bundle_defaults/com.crt.advproject/library=newlib_nohost
/bundle_defaults/org.eclipse.ui.editors/whitespaceCharacterAlphaValue=80
/instance/org.eclipse.cdt.managedbuilder.core/properties/lpcusblib_MassStorageHost.com.crt.advproject.projecttype.exe.71920452/com.crt.advproject.config.exe.debug.1897601089=com.crt.advproject.gas.exe.debug.188816363\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.1632082132\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.2136975254\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.641244994\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.1837685795\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.1440619807\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1897601089\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/showSpellingInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.cdt.ui/spelling_ignore_urls=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_binary_operator=insert
/bundle_defaults/org.eclipse.ui.editors/showEnclosedTabs=true
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.test.suffix=_test.cpp
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.source.wordDelimiter=
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_default_headers=true
/bundle_defaults/org.eclipse.cdt.ui/c_operators=0,0,0
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Navigation.SmartHomeEnd=true
/bundle_defaults/org.eclipse.ui.editors/deletionIndication=false
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_default_methods=false
/bundle_defaults/org.eclipse.ui.editors/undoHistorySize=200
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.field.suffix=
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_parenthesized_expression=do not insert
/bundle_defaults/org.eclipse.debug.ui/Console.highWaterMark=100000
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_at_end_of_file_if_missing=do not insert
/bundle_defaults/org.eclipse.ui.editors/com.crt.etmetb.marker.profile.pref.overview=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_question_in_conditional=insert
/bundle_defaults/org.eclipse.ui.editors/currentIPIndication=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_colon_in_conditional=insert
/bundle_defaults/org.eclipse.cdt.debug.core/org.eclipse.cdt.debug.corecDebug.max_number_of_instructions=100
/bundle_defaults/org.eclipse.ui.workbench/MULTI_KEY_ASSIST_TIME=1000
/bundle_defaults/org.eclipse.cdt.ui/content_assist_autoactivation_trigger_arrow=true
/bundle_defaults/org.eclipse.cdt.ui/scalability.numberOfLines=5000
/bundle_defaults/org.eclipse.cdt.ui/organizeIncludes.unusedStatements=REMOVE
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_dac.com.crt.advproject.projecttype.exe.511991621/com.crt.advproject.config.exe.debug.1401400949=com.crt.advproject.link.cpp.exe.debug.691725567\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1614753469\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1401400949\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.645990063\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.571772906\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.toolchain.exe.debug.574813121\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.1661172651\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/c_keyword_bold=true
/bundle_defaults/org.eclipse.ui.workbench/OPEN_VIEW_MODE=0
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.globalVariable.enabled=false
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.field.wordDelimiter=
/bundle_defaults/org.eclipse.ui.editors/showTrailingTabs=true
/bundle_defaults/com.crt.config/vendor=NXP
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.method.prefix=
/bundle_defaults/com.crt.utils/spawnerTimeout=5000
/bundle_defaults/org.eclipse.ui.editors/othersIndicationColor=0,0,0
/bundle_defaults/com.crt.config/browser_internal=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.comment.preserve_white_space_between_code_and_line_comments=true
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.HighlightTokenChanges=true
@org.eclipse.cdt.managedbuilder.core=8.3.0.201409172108
/bundle_defaults/org.eclipse.cdt.ui/CEditor.ShowTemporaryProblem=false
/bundle_defaults/com.crt.debugcommon/genericStubMatch=.*
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_angle_bracket_in_template_parameters=do not insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.externalSDK.italic=false
/bundle_defaults/org.eclipse.ui.editors/currentLineColor=232,242,254
/instance/org.eclipse.cdt.managedbuilder.core/properties/CMSIS_CORE_LPC177x_8x.com.crt.advproject.projecttype.lib.2013960403/com.crt.advproject.config.lib.debug.1827724080=com.crt.advproject.toolchain.lib.debug.2121956239\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.lib.debug.108587623\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.lib.debug.1569502926\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.lib.debug.1827724080\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.lib.debug.1646563063\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.ar.lib.debug.1689288150\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_provider=org.eclipse.cdt.ui.text.defaultFoldingProvider
/bundle_defaults/com.crt.dsfdebug/complexExpressionBehavior=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_method_invocation_arguments=do not insert
/bundle_defaults/org.eclipse.ui.editors/currentIPOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/lineNumberColor=120,120,120
/bundle_defaults/org.eclipse.ui.ide/OPEN_REQUIRED_PROJECTS=prompt
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.class.enabled=true
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES=C\:\\Users\\Egitim5\\Documents\\LPCXpresso_7.6.2_326\\workspace
/bundle_defaults/org.eclipse.ui.editors/filteredSearchResultIndicationInOverviewRuler=false
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.SynchronizeScrolling=true
/bundle_defaults/org.eclipse.ui.editors/showBreakpointIndicationInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.cdt.ui/scalability.reconciler=true
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.variable.suffix=
/bundle_defaults/org.eclipse.ui.editors/isDeletionGoToPreviousNavigationTarget=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/usbd_lib_hid_mouse.com.crt.advproject.projecttype.exe.1164772426/com.crt.advproject.config.exe.debug.1247759680=com.crt.advproject.toolchain.exe.debug.1972215156\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.exe.debug.734843412\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gas.exe.debug.1430832086\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.config.exe.debug.1247759680\=rcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.crt.advproject.link.cpp.exe.debug.298929785\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.cpp.exe.debug.2016236950\=rebuildState\\\=false\\r\\n\r\ncom.crt.advproject.gcc.exe.debug.2049096836\=rebuildState\\\=false\\r\\n\r\n
/bundle_defaults/org.eclipse.ui.editors/linked.focus.overviewruler=false
/bundle_defaults/org.eclipse.cdt.dsf.ui/minStepInterval=100
/bundle_defaults/org.eclipse.cdt.ui/ensureNewlineAtEOF=true
/bundle_defaults/org.eclipse.cdt.ui/c_multi_line_comment=63,127,95
/bundle_defaults/org.eclipse.ui/ENABLE_32_STICKY_CLOSE_BEHAVIOR=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.functionDeclaration.italic=false
/bundle_defaults/org.eclipse.cdt.ui/pp_directive_bold=true
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.method.capitalization=4
/bundle_defaults/org.eclipse.ui.ide/useSeparator.help.group.main=true
/bundle_defaults/org.eclipse.ui.ide/IMPORT_FILES_AND_FOLDERS_VIRTUAL_FOLDER_MODE=prompt
/bundle_defaults/org.eclipse.cdt.ui/scalability.contentAssistAutoActivation=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enumerator.bold=false
/bundle_defaults/org.eclipse.cdt.ui/smart_tab=true
/bundle_defaults/org.eclipse.ui.editors/infoIndicationInVerticalRuler=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_brace_in_array_initializer=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.tabulation.char=tab
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.globalVariable.bold=false
/instance/org.eclipse.cdt.core.prj-LPCX176x_cmsis2_EasyWeb/indexer/preferenceScope=0
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_dac.com.crt.advproject.projecttype.exe.511991621/com.crt.advproject.config.exe.release.319530200=com.crt.advproject.link.cpp.exe.release.1217990134\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.1197744558\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.1766615628\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.731175261\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.toolchain.exe.release.1771472347\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.367199306\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/forwardDeclare.compositeTypes=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_method_declaration_throws=do not insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.globalVariable.italic=true
/bundle_defaults/org.eclipse.cdt.ui/clearConsole=true
/bundle_defaults/org.eclipse.ui.editors/linked.target.navigation.next=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/periph_systick.com.crt.advproject.projecttype.exe.349735055/com.crt.advproject.config.exe.release.1432658484=com.crt.advproject.toolchain.exe.release.1075952010\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.cpp.exe.release.1242568218\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gcc.exe.release.264579604\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.link.exe.release.60441288\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.gas.exe.release.1322654774\=rebuildState\\\=true\\r\\n\r\ncom.crt.advproject.cpp.exe.release.236459667\=rebuildState\\\=true\\r\\n\r\n
/bundle_defaults/org.eclipse.cdt.ui/content_assist_proposals_timeout=5000
/bundle_defaults/org.eclipse.ui/SHOW_FILTERED_TEXTS=true
/bundle_defaults/org.eclipse.ui.editors/show_range_indicator=true
*** Current Install Configuration:
Bundles in the system:
Id: com.crt.advproject, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.advproject_7.4.1.201502020932.jar
Id: com.crt.config, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.config_7.4.1.201502020932.jar
Id: com.crt.ctrlcenter, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.ctrlcenter_7.4.1.201502020932.jar
Id: com.crt.debugcommon, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.debugcommon_7.4.1.201502020932.jar
Id: com.crt.debugmgr, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.debugmgr_7.4.1.201502020932.jar
Id: com.crt.docs, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.docs_7.4.1.201502020932.jar
Id: com.crt.docs.rsguide, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.docs.rsguide_7.4.1.201502020932.jar
Id: com.crt.dsfdebug, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.dsfdebug_7.4.1.201502020932.jar
Id: com.crt.dsfswv, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.dsfswv_7.4.1.201502020932.jar
Id: com.crt.etmetb, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.etmetb_7.4.1.201502020932.jar
Id: com.crt.lite, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.lite_7.4.1.201502020932.jar
Id: com.crt.lpcxpresso.brand, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.lpcxpresso.brand_7.4.1.201502020932.jar
Id: com.crt.quickstart, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.quickstart_7.4.1.201502020932.jar
Id: com.crt.redstate, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.redstate_7.4.1.201502020932.jar
Id: com.crt.utils, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.utils_7.4.1.201502020932.jar
Id: com.crt.vendor.arm.generic, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.vendor.arm.generic_7.4.1.201502020932.jar
Id: com.crt.vendor.nxp.a7, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.vendor.nxp.a7_7.4.1.201502020932.jar
Id: com.crt.vendor.nxp.generic, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.vendor.nxp.generic_7.4.1.201502020932.jar
Id: com.crt.vendor.nxp.lpc11, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.vendor.nxp.lpc11_7.4.1.201502020932.jar
Id: com.crt.vendor.nxp.lpc13, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.vendor.nxp.lpc13_7.4.1.201502020932.jar
Id: com.crt.vendor.nxp.lpc17, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.vendor.nxp.lpc17_7.4.1.201502020932.jar
Id: com.crt.vendor.nxp.lpc18, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.vendor.nxp.lpc18_7.4.1.201502020932.jar
Id: com.crt.vendor.nxp.lpc29, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.vendor.nxp.lpc29_7.4.1.201502020932.jar
Id: com.crt.vendor.nxp.lpc31, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.vendor.nxp.lpc31_7.4.1.201502020932.jar
Id: com.crt.vendor.nxp.lpc43, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.vendor.nxp.lpc43_7.4.1.201502020932.jar
Id: com.crt.vendor.nxp.niobe, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.crt.vendor.nxp.niobe_7.4.1.201502020932.jar
Id: com.ibm.icu, Version: 52.1.0.v201404241930, Location: reference:file:plugins/com.ibm.icu_52.1.0.v201404241930.jar
Id: com.jcraft.jsch, Version: 0.1.50.v201403120620, Location: reference:file:plugins/com.jcraft.jsch_0.1.50.v201403120620.jar
Id: com.nxp.gnudocs, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.nxp.gnudocs_7.4.1.201502020932.jar
Id: com.nxp.symbolbrowser, Version: 7.4.1.201502020932, Location: reference:file:plugins/com.nxp.symbolbrowser_7.4.1.201502020932.jar
Id: com.sun.el, Version: 2.2.0.v201303151357, Location: reference:file:plugins/com.sun.el_2.2.0.v201303151357.jar
Id: javax.annotation, Version: 1.2.0.v201401042248, Location: reference:file:plugins/javax.annotation_1.2.0.v201401042248.jar
Id: javax.el, Version: 2.2.0.v201303151357, Location: reference:file:plugins/javax.el_2.2.0.v201303151357.jar
Id: javax.inject, Version: 1.0.0.v20091030, Location: reference:file:plugins/javax.inject_1.0.0.v20091030.jar
Id: javax.servlet, Version: 3.0.0.v201112011016, Location: reference:file:plugins/javax.servlet_3.0.0.v201112011016.jar
Id: javax.servlet.jsp, Version: 2.2.0.v201112011158, Location: reference:file:plugins/javax.servlet.jsp_2.2.0.v201112011158.jar
Id: javax.xml, Version: 1.3.4.v201005080400, Location: reference:file:plugins/javax.xml_1.3.4.v201005080400.jar
Id: org.apache.ant, Version: 1.9.2.v201404171502, Location: reference:file:plugins/org.apache.ant_1.9.2.v201404171502/
Id: org.apache.batik.css, Version: 1.7.0.v201011041433, Location: reference:file:plugins/org.apache.batik.css_1.7.0.v201011041433.jar
Id: org.apache.batik.util, Version: 1.7.0.v201011041433, Location: reference:file:plugins/org.apache.batik.util_1.7.0.v201011041433.jar
Id: org.apache.batik.util.gui, Version: 1.7.0.v200903091627, Location: reference:file:plugins/org.apache.batik.util.gui_1.7.0.v200903091627.jar
Id: org.apache.commons.codec, Version: 1.6.0.v201305230611, Location: reference:file:plugins/org.apache.commons.codec_1.6.0.v201305230611.jar
Id: org.apache.commons.logging, Version: 1.1.1.v201101211721, Location: reference:file:plugins/org.apache.commons.logging_1.1.1.v201101211721.jar
Id: org.apache.felix.gogo.command, Version: 0.10.0.v201209301215, Location: reference:file:plugins/org.apache.felix.gogo.command_0.10.0.v201209301215.jar
Id: org.apache.felix.gogo.runtime, Version: 0.10.0.v201209301036, Location: reference:file:plugins/org.apache.felix.gogo.runtime_0.10.0.v201209301036.jar
Id: org.apache.felix.gogo.shell, Version: 0.10.0.v201212101605, Location: reference:file:plugins/org.apache.felix.gogo.shell_0.10.0.v201212101605.jar
Id: org.apache.httpcomponents.httpclient, Version: 4.2.6.v201311072007, Location: reference:file:plugins/org.apache.httpcomponents.httpclient_4.2.6.v201311072007.jar
Id: org.apache.httpcomponents.httpcore, Version: 4.2.5.v201311072007, Location: reference:file:plugins/org.apache.httpcomponents.httpcore_4.2.5.v201311072007.jar
Id: org.apache.jasper.glassfish, Version: 2.2.2.v201205150955, Location: reference:file:plugins/org.apache.jasper.glassfish_2.2.2.v201205150955.jar
Id: org.apache.lucene.analysis, Version: 3.5.0.v20120725-1805, Location: reference:file:plugins/org.apache.lucene.analysis_3.5.0.v20120725-1805.jar
Id: org.apache.lucene.core, Version: 3.5.0.v20120725-1805, Location: reference:file:plugins/org.apache.lucene.core_3.5.0.v20120725-1805.jar
Id: org.eclipse.ant.core, Version: 3.3.0.v20140518-0042, Location: reference:file:plugins/org.eclipse.ant.core_3.3.0.v20140518-0042.jar
Id: org.eclipse.cdt, Version: 8.5.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt_8.5.0.201409172108.jar
Id: org.eclipse.cdt.codan.checkers, Version: 3.2.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.codan.checkers_3.2.0.201409172108.jar
Id: org.eclipse.cdt.codan.checkers.ui, Version: 3.2.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.codan.checkers.ui_3.2.0.201409172108.jar
Id: org.eclipse.cdt.codan.core, Version: 3.2.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.codan.core_3.2.0.201409172108.jar
Id: org.eclipse.cdt.codan.core.cxx, Version: 3.2.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.codan.core.cxx_3.2.0.201409172108.jar
Id: org.eclipse.cdt.codan.ui, Version: 3.2.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.codan.ui_3.2.0.201409172108.jar
Id: org.eclipse.cdt.codan.ui.cxx, Version: 3.2.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.codan.ui.cxx_3.2.0.201409172108.jar
Id: org.eclipse.cdt.core, Version: 5.8.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.core_5.8.0.201409172108.jar
Id: org.eclipse.cdt.core.native, Version: 5.7.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.core.native_5.7.0.201409172108.jar
Id: org.eclipse.cdt.core.win32, Version: 5.4.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.core.win32_5.4.0.201409172108.jar
Id: org.eclipse.cdt.core.win32.x86, Version: 5.3.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.core.win32.x86_5.3.0.201409172108/
Id: org.eclipse.cdt.debug.core, Version: 7.5.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.debug.core_7.5.0.201409172108.jar
Id: org.eclipse.cdt.debug.gdbjtag, Version: 7.0.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.debug.gdbjtag_7.0.0.201409172108.jar
Id: org.eclipse.cdt.debug.gdbjtag.core, Version: 8.4.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.debug.gdbjtag.core_8.4.0.201409172108.jar
Id: org.eclipse.cdt.debug.gdbjtag.ui, Version: 7.1.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.debug.gdbjtag.ui_7.1.0.201409172108.jar
Id: org.eclipse.cdt.debug.mi.core, Version: 7.3.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.debug.mi.core_7.3.0.201409172108.jar
Id: org.eclipse.cdt.debug.mi.ui, Version: 6.2.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.debug.mi.ui_6.2.0.201409172108.jar
Id: org.eclipse.cdt.debug.ui, Version: 7.5.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.debug.ui_7.5.0.201409172108.jar
Id: org.eclipse.cdt.debug.ui.memory.memorybrowser, Version: 1.3.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.debug.ui.memory.memorybrowser_1.3.0.201409172108.jar
Id: org.eclipse.cdt.debug.ui.memory.search, Version: 1.3.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.debug.ui.memory.search_1.3.0.201409172108.jar
Id: org.eclipse.cdt.debug.ui.memory.traditional, Version: 1.2.1.201409172108, Location: reference:file:plugins/org.eclipse.cdt.debug.ui.memory.traditional_1.2.1.201409172108.jar
Id: org.eclipse.cdt.debug.ui.memory.transport, Version: 2.1.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.debug.ui.memory.transport_2.1.0.201409172108.jar
Id: org.eclipse.cdt.doc.user, Version: 5.3.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.doc.user_5.3.0.201409172108.jar
Id: org.eclipse.cdt.dsf, Version: 2.5.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.dsf_2.5.0.201409172108.jar
Id: org.eclipse.cdt.dsf.gdb, Version: 4.5.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.dsf.gdb_4.5.0.201409172108.jar
Id: org.eclipse.cdt.dsf.gdb.ui, Version: 2.4.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.dsf.gdb.ui_2.4.0.201409172108.jar
Id: org.eclipse.cdt.dsf.ui, Version: 2.4.100.201409172108, Location: reference:file:plugins/org.eclipse.cdt.dsf.ui_2.4.100.201409172108.jar
Id: org.eclipse.cdt.gdb, Version: 7.0.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.gdb_7.0.0.201409172108.jar
Id: org.eclipse.cdt.gdb.ui, Version: 7.0.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.gdb.ui_7.0.0.201409172108.jar
Id: org.eclipse.cdt.launch, Version: 7.1.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.launch_7.1.0.201409172108.jar
Id: org.eclipse.cdt.make.core, Version: 7.3.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.make.core_7.3.0.201409172108.jar
Id: org.eclipse.cdt.make.ui, Version: 7.2.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.make.ui_7.2.0.201409172108.jar
Id: org.eclipse.cdt.managedbuilder.core, Version: 8.3.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.managedbuilder.core_8.3.0.201409172108.jar
Id: org.eclipse.cdt.managedbuilder.gnu.ui, Version: 8.3.0.201409172108, Location: reference:file:plugins/org.eclipse.cdt.managedbuilder.gnu.ui_8.3.0.201409172108.jar
Id: org.eclipse.cdt.managedbuilder.ui, Version: 8.2.2.201409172108, Location: reference:file:plugins/org.eclipse.cdt.managedbuilder.ui_8.2.2.201409172108.jar
Id: org.eclipse.cdt.ui, Version: 5.8.1.201409172108, Location: reference:file:plugins/org.eclipse.cdt.ui_5.8.1.201409172108.jar
Id: org.eclipse.compare, Version: 3.5.501.v20140817-1445, Location: reference:file:plugins/org.eclipse.compare_3.5.501.v20140817-1445.jar
Id: org.eclipse.compare.core, Version: 3.5.400.v20130903-0736, Location: reference:file:plugins/org.eclipse.compare.core_3.5.400.v20130903-0736.jar
Id: org.eclipse.compare.win32, Version: 1.0.200.v20130514-1224, Location: reference:file:plugins/org.eclipse.compare.win32_1.0.200.v20130514-1224.jar
Id: org.eclipse.core.commands, Version: 3.6.100.v20140528-1422, Location: reference:file:plugins/org.eclipse.core.commands_3.6.100.v20140528-1422.jar
Id: org.eclipse.core.contenttype, Version: 3.4.200.v20140207-1251, Location: reference:file:plugins/org.eclipse.core.contenttype_3.4.200.v20140207-1251.jar
Id: org.eclipse.core.databinding, Version: 1.4.2.v20140729-1044, Location: reference:file:plugins/org.eclipse.core.databinding_1.4.2.v20140729-1044.jar
Id: org.eclipse.core.databinding.beans, Version: 1.2.200.v20140214-0004, Location: reference:file:plugins/org.eclipse.core.databinding.beans_1.2.200.v20140214-0004.jar
Id: org.eclipse.core.databinding.observable, Version: 1.4.1.v20140210-1835, Location: reference:file:plugins/org.eclipse.core.databinding.observable_1.4.1.v20140210-1835.jar
Id: org.eclipse.core.databinding.property, Version: 1.4.200.v20140214-0004, Location: reference:file:plugins/org.eclipse.core.databinding.property_1.4.200.v20140214-0004.jar
Id: org.eclipse.core.expressions, Version: 3.4.600.v20140128-0851, Location: reference:file:plugins/org.eclipse.core.expressions_3.4.600.v20140128-0851.jar
Id: org.eclipse.core.externaltools, Version: 1.0.300.v20140219-0051, Location: reference:file:plugins/org.eclipse.core.externaltools_1.0.300.v20140219-0051.jar
Id: org.eclipse.core.filebuffers, Version: 3.5.400.v20140127-1516, Location: reference:file:plugins/org.eclipse.core.filebuffers_3.5.400.v20140127-1516.jar
Id: org.eclipse.core.filesystem, Version: 1.4.100.v20140514-1614, Location: reference:file:plugins/org.eclipse.core.filesystem_1.4.100.v20140514-1614.jar
Id: org.eclipse.core.filesystem.java7, Version: 1.0.0.v20140429-1531, Location: reference:file:plugins/org.eclipse.core.filesystem.java7_1.0.0.v20140429-1531.jar
Id: org.eclipse.core.filesystem.win32.x86, Version: 1.4.0.v20140124-1940, Location: reference:file:plugins/org.eclipse.core.filesystem.win32.x86_1.4.0.v20140124-1940.jar
Id: org.eclipse.core.jobs, Version: 3.6.0.v20140424-0053, Location: reference:file:plugins/org.eclipse.core.jobs_3.6.0.v20140424-0053.jar
Id: org.eclipse.core.net, Version: 1.2.200.v20140124-2013, Location: reference:file:plugins/org.eclipse.core.net_1.2.200.v20140124-2013.jar
Id: org.eclipse.core.net.win32.x86, Version: 1.0.100.v20140124-2013, Location: reference:file:plugins/org.eclipse.core.net.win32.x86_1.0.100.v20140124-2013.jar
Id: org.eclipse.core.resources, Version: 3.9.1.v20140825-1431, Location: reference:file:plugins/org.eclipse.core.resources_3.9.1.v20140825-1431.jar
Id: org.eclipse.core.resources.win32.x86, Version: 3.5.100.v20140124-1940, Location: reference:file:plugins/org.eclipse.core.resources.win32.x86_3.5.100.v20140124-1940.jar
Id: org.eclipse.core.runtime, Version: 3.10.0.v20140318-2214, Location: reference:file:plugins/org.eclipse.core.runtime_3.10.0.v20140318-2214.jar
Id: org.eclipse.core.runtime.compatibility, Version: 3.2.200.v20140128-0851, Location: reference:file:plugins/org.eclipse.core.runtime.compatibility_3.2.200.v20140128-0851.jar
Id: org.eclipse.core.runtime.compatibility.registry, Version: 3.5.300.v20140128-0851, Location: reference:file:plugins/org.eclipse.core.runtime.compatibility.registry_3.5.300.v20140128-0851/
Id: org.eclipse.core.variables, Version: 3.2.800.v20130819-1716, Location: reference:file:plugins/org.eclipse.core.variables_3.2.800.v20130819-1716.jar
Id: org.eclipse.cvs, Version: 1.4.100.v20140925-0400, Location: reference:file:plugins/org.eclipse.cvs_1.4.100.v20140925-0400.jar
Id: org.eclipse.debug.core, Version: 3.9.1.v20140805-1629, Location: reference:file:plugins/org.eclipse.debug.core_3.9.1.v20140805-1629.jar
Id: org.eclipse.debug.ui, Version: 3.10.1.v20140822-1408, Location: reference:file:plugins/org.eclipse.debug.ui_3.10.1.v20140822-1408.jar
Id: org.eclipse.draw2d, Version: 3.9.101.201408150207, Location: reference:file:plugins/org.eclipse.draw2d_3.9.101.201408150207.jar
Id: org.eclipse.e4.core.commands, Version: 0.10.2.v20140424-2344, Location: reference:file:plugins/org.eclipse.e4.core.commands_0.10.2.v20140424-2344.jar
Id: org.eclipse.e4.core.contexts, Version: 1.3.100.v20140407-1019, Location: reference:file:plugins/org.eclipse.e4.core.contexts_1.3.100.v20140407-1019.jar
Id: org.eclipse.e4.core.di, Version: 1.4.0.v20140414-1837, Location: reference:file:plugins/org.eclipse.e4.core.di_1.4.0.v20140414-1837.jar
Id: org.eclipse.e4.core.di.extensions, Version: 0.12.0.v20140417-2033, Location: reference:file:plugins/org.eclipse.e4.core.di.extensions_0.12.0.v20140417-2033.jar
Id: org.eclipse.e4.core.services, Version: 1.2.1.v20140808-1251, Location: reference:file:plugins/org.eclipse.e4.core.services_1.2.1.v20140808-1251.jar
Id: org.eclipse.e4.ui.bindings, Version: 0.10.200.v20140424-2042, Location: reference:file:plugins/org.eclipse.e4.ui.bindings_0.10.200.v20140424-2042.jar
Id: org.eclipse.e4.ui.css.core, Version: 0.10.100.v20140424-2042, Location: reference:file:plugins/org.eclipse.e4.ui.css.core_0.10.100.v20140424-2042.jar
Id: org.eclipse.e4.ui.css.swt, Version: 0.11.101.v20140818-1343, Location: reference:file:plugins/org.eclipse.e4.ui.css.swt_0.11.101.v20140818-1343.jar
Id: org.eclipse.e4.ui.css.swt.theme, Version: 0.9.300.v20140424-2042, Location: reference:file:plugins/org.eclipse.e4.ui.css.swt.theme_0.9.300.v20140424-2042.jar
Id: org.eclipse.e4.ui.di, Version: 1.0.0.v20140328-2112, Location: reference:file:plugins/org.eclipse.e4.ui.di_1.0.0.v20140328-2112.jar
Id: org.eclipse.e4.ui.model.workbench, Version: 1.1.0.v20140512-1820, Location: reference:file:plugins/org.eclipse.e4.ui.model.workbench_1.1.0.v20140512-1820.jar
Id: org.eclipse.e4.ui.services, Version: 1.1.0.v20140328-1925, Location: reference:file:plugins/org.eclipse.e4.ui.services_1.1.0.v20140328-1925.jar
Id: org.eclipse.e4.ui.widgets, Version: 1.0.0.v20140514-1823, Location: reference:file:plugins/org.eclipse.e4.ui.widgets_1.0.0.v20140514-1823.jar
Id: org.eclipse.e4.ui.workbench, Version: 1.2.1.v20140901-1244, Location: reference:file:plugins/org.eclipse.e4.ui.workbench_1.2.1.v20140901-1244.jar
Id: org.eclipse.e4.ui.workbench.addons.swt, Version: 1.1.1.v20140903-0821, Location: reference:file:plugins/org.eclipse.e4.ui.workbench.addons.swt_1.1.1.v20140903-0821.jar
Id: org.eclipse.e4.ui.workbench.renderers.swt, Version: 0.12.1.v20140903-1023, Location: reference:file:plugins/org.eclipse.e4.ui.workbench.renderers.swt_0.12.1.v20140903-1023.jar
Id: org.eclipse.e4.ui.workbench.swt, Version: 0.12.100.v20140530-1436, Location: reference:file:plugins/org.eclipse.e4.ui.workbench.swt_0.12.100.v20140530-1436.jar
Id: org.eclipse.e4.ui.workbench3, Version: 0.12.0.v20140227-2118, Location: reference:file:plugins/org.eclipse.e4.ui.workbench3_0.12.0.v20140227-2118.jar
Id: org.eclipse.ecf, Version: 3.4.0.v20140827-1444, Location: reference:file:plugins/org.eclipse.ecf_3.4.0.v20140827-1444.jar
Id: org.eclipse.ecf.filetransfer, Version: 5.0.0.v20140827-1444, Location: reference:file:plugins/org.eclipse.ecf.filetransfer_5.0.0.v20140827-1444.jar
Id: org.eclipse.ecf.identity, Version: 3.4.0.v20140827-1444, Location: reference:file:plugins/org.eclipse.ecf.identity_3.4.0.v20140827-1444.jar
Id: org.eclipse.ecf.provider.filetransfer, Version: 3.2.200.v20140827-1444, Location: reference:file:plugins/org.eclipse.ecf.provider.filetransfer_3.2.200.v20140827-1444.jar
Id: org.eclipse.ecf.provider.filetransfer.httpclient4, Version: 1.0.800.v20140827-1444, Location: reference:file:plugins/org.eclipse.ecf.provider.filetransfer.httpclient4_1.0.800.v20140827-1444.jar
Id: org.eclipse.ecf.provider.filetransfer.httpclient4.ssl, Version: 1.0.0.v20140827-1444, Location: reference:file:plugins/org.eclipse.ecf.provider.filetransfer.httpclient4.ssl_1.0.0.v20140827-1444.jar
Id: org.eclipse.ecf.provider.filetransfer.ssl, Version: 1.0.0.v20140827-1444, Location: reference:file:plugins/org.eclipse.ecf.provider.filetransfer.ssl_1.0.0.v20140827-1444.jar
Id: org.eclipse.ecf.ssl, Version: 1.1.0.v20140827-1444, Location: reference:file:plugins/org.eclipse.ecf.ssl_1.1.0.v20140827-1444.jar
Id: org.eclipse.emf.common, Version: 2.10.1.v20140901-1043, Location: reference:file:plugins/org.eclipse.emf.common_2.10.1.v20140901-1043.jar
Id: org.eclipse.emf.ecore, Version: 2.10.1.v20140901-1043, Location: reference:file:plugins/org.eclipse.emf.ecore_2.10.1.v20140901-1043.jar
Id: org.eclipse.emf.ecore.change, Version: 2.10.0.v20140901-1043, Location: reference:file:plugins/org.eclipse.emf.ecore.change_2.10.0.v20140901-1043.jar
Id: org.eclipse.emf.ecore.xmi, Version: 2.10.1.v20140901-1043, Location: reference:file:plugins/org.eclipse.emf.ecore.xmi_2.10.1.v20140901-1043.jar
Id: org.eclipse.equinox.app, Version: 1.3.200.v20130910-1609, Location: reference:file:plugins/org.eclipse.equinox.app_1.3.200.v20130910-1609.jar
Id: org.eclipse.equinox.bidi, Version: 0.10.0.v20130327-1442, Location: reference:file:plugins/org.eclipse.equinox.bidi_0.10.0.v20130327-1442.jar
Id: org.eclipse.equinox.common, Version: 3.6.200.v20130402-1505, Location: reference:file:plugins/org.eclipse.equinox.common_3.6.200.v20130402-1505.jar
Id: org.eclipse.equinox.concurrent, Version: 1.1.0.v20130327-1442, Location: reference:file:plugins/org.eclipse.equinox.concurrent_1.1.0.v20130327-1442.jar
Id: org.eclipse.equinox.console, Version: 1.1.0.v20140131-1639, Location: reference:file:plugins/org.eclipse.equinox.console_1.1.0.v20140131-1639.jar
Id: org.eclipse.equinox.ds, Version: 1.4.200.v20131126-2331, Location: reference:file:plugins/org.eclipse.equinox.ds_1.4.200.v20131126-2331.jar
Id: org.eclipse.equinox.event, Version: 1.3.100.v20140115-1647, Location: reference:file:plugins/org.eclipse.equinox.event_1.3.100.v20140115-1647.jar
Id: org.eclipse.equinox.frameworkadmin, Version: 2.0.100.v20131209-2144, Location: reference:file:plugins/org.eclipse.equinox.frameworkadmin_2.0.100.v20131209-2144.jar
Id: org.eclipse.equinox.frameworkadmin.equinox, Version: 1.0.500.v20131211-1531, Location: reference:file:plugins/org.eclipse.equinox.frameworkadmin.equinox_1.0.500.v20131211-1531.jar
Id: org.eclipse.equinox.http.jetty, Version: 3.0.200.v20131021-1843, Location: reference:file:plugins/org.eclipse.equinox.http.jetty_3.0.200.v20131021-1843.jar
Id: org.eclipse.equinox.http.registry, Version: 1.1.300.v20130402-1529, Location: reference:file:plugins/org.eclipse.equinox.http.registry_1.1.300.v20130402-1529.jar
Id: org.eclipse.equinox.http.servlet, Version: 1.1.500.v20140318-1755, Location: reference:file:plugins/org.eclipse.equinox.http.servlet_1.1.500.v20140318-1755.jar
Id: org.eclipse.equinox.jsp.jasper, Version: 1.0.400.v20130327-1442, Location: reference:file:plugins/org.eclipse.equinox.jsp.jasper_1.0.400.v20130327-1442.jar
Id: org.eclipse.equinox.jsp.jasper.registry, Version: 1.0.300.v20130327-1442, Location: reference:file:plugins/org.eclipse.equinox.jsp.jasper.registry_1.0.300.v20130327-1442.jar
Id: org.eclipse.equinox.launcher, Version: 1.3.0.v20140415-2008, Location: reference:file:plugins/org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar
Id: org.eclipse.equinox.launcher.win32.win32.x86, Version: 1.1.200.v20140603-1326, Location: reference:file:plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.1.200.v20140603-1326/
Id: org.eclipse.equinox.p2.artifact.repository, Version: 1.1.300.v20131211-1531, Location: reference:file:plugins/org.eclipse.equinox.p2.artifact.repository_1.1.300.v20131211-1531.jar
Id: org.eclipse.equinox.p2.console, Version: 1.0.300.v20131113-1212, Location: reference:file:plugins/org.eclipse.equinox.p2.console_1.0.300.v20131113-1212.jar
Id: org.eclipse.equinox.p2.core, Version: 2.3.0.v20131211-1531, Location: reference:file:plugins/org.eclipse.equinox.p2.core_2.3.0.v20131211-1531.jar
Id: org.eclipse.equinox.p2.director, Version: 2.3.100.v20140224-1921, Location: reference:file:plugins/org.eclipse.equinox.p2.director_2.3.100.v20140224-1921.jar
Id: org.eclipse.equinox.p2.director.app, Version: 1.0.300.v20140228-1829, Location: reference:file:plugins/org.eclipse.equinox.p2.director.app_1.0.300.v20140228-1829.jar
Id: org.eclipse.equinox.p2.directorywatcher, Version: 1.1.0.v20131211-1531, Location: reference:file:plugins/org.eclipse.equinox.p2.directorywatcher_1.1.0.v20131211-1531.jar
Id: org.eclipse.equinox.p2.engine, Version: 2.3.0.v20140506-1720, Location: reference:file:plugins/org.eclipse.equinox.p2.engine_2.3.0.v20140506-1720.jar
Id: org.eclipse.equinox.p2.extensionlocation, Version: 1.2.100.v20131119-0908, Location: reference:file:plugins/org.eclipse.equinox.p2.extensionlocation_1.2.100.v20131119-0908.jar
Id: org.eclipse.equinox.p2.garbagecollector, Version: 1.0.200.v20131115-1210, Location: reference:file:plugins/org.eclipse.equinox.p2.garbagecollector_1.0.200.v20131115-1210.jar
Id: org.eclipse.equinox.p2.jarprocessor, Version: 1.0.300.v20131211-1531, Location: reference:file:plugins/org.eclipse.equinox.p2.jarprocessor_1.0.300.v20131211-1531.jar
Id: org.eclipse.equinox.p2.metadata, Version: 2.2.0.v20131211-1531, Location: reference:file:plugins/org.eclipse.equinox.p2.metadata_2.2.0.v20131211-1531.jar
Id: org.eclipse.equinox.p2.metadata.repository, Version: 1.2.100.v20131209-2144, Location: reference:file:plugins/org.eclipse.equinox.p2.metadata.repository_1.2.100.v20131209-2144.jar
Id: org.eclipse.equinox.p2.operations, Version: 2.4.0.v20131119-0908, Location: reference:file:plugins/org.eclipse.equinox.p2.operations_2.4.0.v20131119-0908.jar
Id: org.eclipse.equinox.p2.publisher, Version: 1.3.0.v20140911-0143, Location: reference:file:plugins/org.eclipse.equinox.p2.publisher_1.3.0.v20140911-0143.jar
Id: org.eclipse.equinox.p2.publisher.eclipse, Version: 1.1.200.v20140414-0825, Location: reference:file:plugins/org.eclipse.equinox.p2.publisher.eclipse_1.1.200.v20140414-0825.jar
Id: org.eclipse.equinox.p2.ql, Version: 2.0.100.v20131211-1531, Location: reference:file:plugins/org.eclipse.equinox.p2.ql_2.0.100.v20131211-1531.jar
Id: org.eclipse.equinox.p2.reconciler.dropins, Version: 1.1.200.v20131119-0908, Location: reference:file:plugins/org.eclipse.equinox.p2.reconciler.dropins_1.1.200.v20131119-0908.jar
Id: org.eclipse.equinox.p2.repository, Version: 2.3.0.v20131211-1531, Location: reference:file:plugins/org.eclipse.equinox.p2.repository_2.3.0.v20131211-1531.jar
Id: org.eclipse.equinox.p2.repository.tools, Version: 2.1.0.v20131211-1531, Location: reference:file:plugins/org.eclipse.equinox.p2.repository.tools_2.1.0.v20131211-1531.jar
Id: org.eclipse.equinox.p2.touchpoint.eclipse, Version: 2.1.200.v20140512-1650, Location: reference:file:plugins/org.eclipse.equinox.p2.touchpoint.eclipse_2.1.200.v20140512-1650.jar
Id: org.eclipse.equinox.p2.touchpoint.natives, Version: 1.1.100.v20140523-0116, Location: reference:file:plugins/org.eclipse.equinox.p2.touchpoint.natives_1.1.100.v20140523-0116.jar
Id: org.eclipse.equinox.p2.transport.ecf, Version: 1.1.0.v20140408-1354, Location: reference:file:plugins/org.eclipse.equinox.p2.transport.ecf_1.1.0.v20140408-1354.jar
Id: org.eclipse.equinox.p2.ui, Version: 2.3.0.v20140404-1657, Location: reference:file:plugins/org.eclipse.equinox.p2.ui_2.3.0.v20140404-1657.jar
Id: org.eclipse.equinox.p2.ui.importexport, Version: 1.1.0.v20131210-1027, Location: reference:file:plugins/org.eclipse.equinox.p2.ui.importexport_1.1.0.v20131210-1027.jar
Id: org.eclipse.equinox.p2.ui.sdk, Version: 1.0.300.v20140407-1803, Location: reference:file:plugins/org.eclipse.equinox.p2.ui.sdk_1.0.300.v20140407-1803.jar
Id: org.eclipse.equinox.p2.ui.sdk.scheduler, Version: 1.2.0.v20140422-1847, Location: reference:file:plugins/org.eclipse.equinox.p2.ui.sdk.scheduler_1.2.0.v20140422-1847.jar
Id: org.eclipse.equinox.p2.updatechecker, Version: 1.1.200.v20131119-0908, Location: reference:file:plugins/org.eclipse.equinox.p2.updatechecker_1.1.200.v20131119-0908.jar
Id: org.eclipse.equinox.p2.updatesite, Version: 1.0.400.v20131211-1531, Location: reference:file:plugins/org.eclipse.equinox.p2.updatesite_1.0.400.v20131211-1531.jar
Id: org.eclipse.equinox.preferences, Version: 3.5.200.v20140224-1527, Location: reference:file:plugins/org.eclipse.equinox.preferences_3.5.200.v20140224-1527.jar
Id: org.eclipse.equinox.registry, Version: 3.5.400.v20140428-1507, Location: reference:file:plugins/org.eclipse.equinox.registry_3.5.400.v20140428-1507.jar
Id: org.eclipse.equinox.security, Version: 1.2.0.v20130424-1801, Location: reference:file:plugins/org.eclipse.equinox.security_1.2.0.v20130424-1801.jar
Id: org.eclipse.equinox.security.ui, Version: 1.1.200.v20130626-2037, Location: reference:file:plugins/org.eclipse.equinox.security.ui_1.1.200.v20130626-2037.jar
Id: org.eclipse.equinox.security.win32.x86, Version: 1.0.300.v20130327-1442, Location: reference:file:plugins/org.eclipse.equinox.security.win32.x86_1.0.300.v20130327-1442.jar
Id: org.eclipse.equinox.simpleconfigurator, Version: 1.1.0.v20131217-1203, Location: initial@reference:file:plugins/org.eclipse.equinox.simpleconfigurator_1.1.0.v20131217-1203.jar
Id: org.eclipse.equinox.simpleconfigurator.manipulator, Version: 2.0.0.v20131217-1203, Location: reference:file:plugins/org.eclipse.equinox.simpleconfigurator.manipulator_2.0.0.v20131217-1203.jar
Id: org.eclipse.equinox.util, Version: 1.0.500.v20130404-1337, Location: reference:file:plugins/org.eclipse.equinox.util_1.0.500.v20130404-1337.jar
Id: org.eclipse.gef, Version: 3.9.100.201408150207, Location: reference:file:plugins/org.eclipse.gef_3.9.100.201408150207.jar
Id: org.eclipse.help, Version: 3.6.0.v20130326-1254, Location: reference:file:plugins/org.eclipse.help_3.6.0.v20130326-1254.jar
Id: org.eclipse.help.base, Version: 4.0.200.v20140925-0400, Location: reference:file:plugins/org.eclipse.help.base_4.0.200.v20140925-0400.jar
Id: org.eclipse.help.ui, Version: 4.0.100.v20140401-0608, Location: reference:file:plugins/org.eclipse.help.ui_4.0.100.v20140401-0608.jar
Id: org.eclipse.help.webapp, Version: 3.6.300.v20140407-1855, Location: reference:file:plugins/org.eclipse.help.webapp_3.6.300.v20140407-1855.jar
Id: org.eclipse.jetty.continuation, Version: 8.1.14.v20131031, Location: reference:file:plugins/org.eclipse.jetty.continuation_8.1.14.v20131031.jar
Id: org.eclipse.jetty.http, Version: 8.1.14.v20131031, Location: reference:file:plugins/org.eclipse.jetty.http_8.1.14.v20131031.jar
Id: org.eclipse.jetty.io, Version: 8.1.14.v20131031, Location: reference:file:plugins/org.eclipse.jetty.io_8.1.14.v20131031.jar
Id: org.eclipse.jetty.security, Version: 8.1.14.v20131031, Location: reference:file:plugins/org.eclipse.jetty.security_8.1.14.v20131031.jar
Id: org.eclipse.jetty.server, Version: 8.1.14.v20131031, Location: reference:file:plugins/org.eclipse.jetty.server_8.1.14.v20131031.jar
Id: org.eclipse.jetty.servlet, Version: 8.1.14.v20131031, Location: reference:file:plugins/org.eclipse.jetty.servlet_8.1.14.v20131031.jar
Id: org.eclipse.jetty.util, Version: 8.1.14.v20131031, Location: reference:file:plugins/org.eclipse.jetty.util_8.1.14.v20131031.jar
Id: org.eclipse.jface, Version: 3.10.1.v20140813-1009, Location: reference:file:plugins/org.eclipse.jface_3.10.1.v20140813-1009.jar
Id: org.eclipse.jface.databinding, Version: 1.6.200.v20140528-1422, Location: reference:file:plugins/org.eclipse.jface.databinding_1.6.200.v20140528-1422.jar
Id: org.eclipse.jface.text, Version: 3.9.1.v20140827-1810, Location: reference:file:plugins/org.eclipse.jface.text_3.9.1.v20140827-1810.jar
Id: org.eclipse.jsch.core, Version: 1.1.500.v20131112-1442, Location: reference:file:plugins/org.eclipse.jsch.core_1.1.500.v20131112-1442.jar
Id: org.eclipse.jsch.ui, Version: 1.1.500.v20131112-1442, Location: reference:file:plugins/org.eclipse.jsch.ui_1.1.500.v20131112-1442.jar
Id: org.eclipse.ltk.core.refactoring, Version: 3.6.101.v20140817-1500, Location: reference:file:plugins/org.eclipse.ltk.core.refactoring_3.6.101.v20140817-1500.jar
Id: org.eclipse.ltk.ui.refactoring, Version: 3.7.100.v20140324-1358, Location: reference:file:plugins/org.eclipse.ltk.ui.refactoring_3.7.100.v20140324-1358.jar
Id: org.eclipse.osgi, Version: 3.10.1.v20140909-1633, Location: System Bundle
Id: org.eclipse.osgi.compatibility.state, Version: 1.0.1.v20140709-1414, Location: initial@reference:file:plugins/org.eclipse.osgi.compatibility.state_1.0.1.v20140709-1414.jar
Id: org.eclipse.osgi.services, Version: 3.4.0.v20140312-2051, Location: reference:file:plugins/org.eclipse.osgi.services_3.4.0.v20140312-2051.jar
Id: org.eclipse.osgi.util, Version: 3.3.0.v20131023-1243, Location: reference:file:plugins/org.eclipse.osgi.util_3.3.0.v20131023-1243.jar
Id: org.eclipse.platform, Version: 4.4.0.v20140925-0400, Location: reference:file:plugins/org.eclipse.platform_4.4.0.v20140925-0400/
Id: org.eclipse.platform.doc.user, Version: 4.4.1.v20140829-1306, Location: reference:file:plugins/org.eclipse.platform.doc.user_4.4.1.v20140829-1306.jar
Id: org.eclipse.rcp, Version: 4.3.100.v20140925-0400, Location: reference:file:plugins/org.eclipse.rcp_4.3.100.v20140925-0400.jar
Id: org.eclipse.search, Version: 3.9.100.v20140226-1637, Location: reference:file:plugins/org.eclipse.search_3.9.100.v20140226-1637.jar
Id: org.eclipse.swt, Version: 3.103.1.v20140903-1938, Location: reference:file:plugins/org.eclipse.swt_3.103.1.v20140903-1938.jar
Id: org.eclipse.swt.win32.win32.x86, Version: 3.103.1.v20140903-1947, Location: reference:file:plugins/org.eclipse.swt.win32.win32.x86_3.103.1.v20140903-1947.jar
Id: org.eclipse.team.core, Version: 3.7.0.v20130514-1224, Location: reference:file:plugins/org.eclipse.team.core_3.7.0.v20130514-1224.jar
Id: org.eclipse.team.cvs.core, Version: 3.3.600.v20131112-1442, Location: reference:file:plugins/org.eclipse.team.cvs.core_3.3.600.v20131112-1442.jar
Id: org.eclipse.team.cvs.ssh2, Version: 3.2.400.v20131112-1442, Location: reference:file:plugins/org.eclipse.team.cvs.ssh2_3.2.400.v20131112-1442.jar
Id: org.eclipse.team.cvs.ui, Version: 3.3.600.v20130514-1224, Location: reference:file:plugins/org.eclipse.team.cvs.ui_3.3.600.v20130514-1224.jar
Id: org.eclipse.team.ui, Version: 3.7.100.v20130710-1213, Location: reference:file:plugins/org.eclipse.team.ui_3.7.100.v20130710-1213.jar
Id: org.eclipse.text, Version: 3.5.300.v20130515-1451, Location: reference:file:plugins/org.eclipse.text_3.5.300.v20130515-1451.jar
Id: org.eclipse.ui, Version: 3.106.0.v20140812-1751, Location: reference:file:plugins/org.eclipse.ui_3.106.0.v20140812-1751.jar
Id: org.eclipse.ui.browser, Version: 3.4.200.v20131003-1453, Location: reference:file:plugins/org.eclipse.ui.browser_3.4.200.v20131003-1453.jar
Id: org.eclipse.ui.cheatsheets, Version: 3.4.200.v20131227-1524, Location: reference:file:plugins/org.eclipse.ui.cheatsheets_3.4.200.v20131227-1524.jar
Id: org.eclipse.ui.console, Version: 3.5.300.v20140424-1437, Location: reference:file:plugins/org.eclipse.ui.console_3.5.300.v20140424-1437.jar
Id: org.eclipse.ui.editors, Version: 3.8.200.v20140401-1310, Location: reference:file:plugins/org.eclipse.ui.editors_3.8.200.v20140401-1310.jar
Id: org.eclipse.ui.externaltools, Version: 3.2.300.v20140327-1949, Location: reference:file:plugins/org.eclipse.ui.externaltools_3.2.300.v20140327-1949.jar
Id: org.eclipse.ui.forms, Version: 3.6.100.v20140422-1825, Location: reference:file:plugins/org.eclipse.ui.forms_3.6.100.v20140422-1825.jar
Id: org.eclipse.ui.ide, Version: 3.10.1.v20140828-0944, Location: reference:file:plugins/org.eclipse.ui.ide_3.10.1.v20140828-0944.jar
Id: org.eclipse.ui.ide.application, Version: 1.0.500.v20140514-2033, Location: reference:file:plugins/org.eclipse.ui.ide.application_1.0.500.v20140514-2033.jar
Id: org.eclipse.ui.intro, Version: 3.4.200.v20130326-1254, Location: reference:file:plugins/org.eclipse.ui.intro_3.4.200.v20130326-1254.jar
Id: org.eclipse.ui.intro.universal, Version: 3.2.700.v20130904-1701, Location: reference:file:plugins/org.eclipse.ui.intro.universal_3.2.700.v20130904-1701/
Id: org.eclipse.ui.navigator, Version: 3.5.401.v20140724-1117, Location: reference:file:plugins/org.eclipse.ui.navigator_3.5.401.v20140724-1117.jar
Id: org.eclipse.ui.navigator.resources, Version: 3.4.700.v20140407-1004, Location: reference:file:plugins/org.eclipse.ui.navigator.resources_3.4.700.v20140407-1004.jar
Id: org.eclipse.ui.net, Version: 1.2.200.v20120807-0927, Location: reference:file:plugins/org.eclipse.ui.net_1.2.200.v20120807-0927.jar
Id: org.eclipse.ui.themes, Version: 1.0.1.v20140819-1717, Location: reference:file:plugins/org.eclipse.ui.themes_1.0.1.v20140819-1717/
Id: org.eclipse.ui.views, Version: 3.7.0.v20140408-0703, Location: reference:file:plugins/org.eclipse.ui.views_3.7.0.v20140408-0703.jar
Id: org.eclipse.ui.views.properties.tabbed, Version: 3.6.0.v20140519-0906, Location: reference:file:plugins/org.eclipse.ui.views.properties.tabbed_3.6.0.v20140519-0906.jar
Id: org.eclipse.ui.win32, Version: 3.2.400.v20140423-2207, Location: reference:file:plugins/org.eclipse.ui.win32_3.2.400.v20140423-2207.jar
Id: org.eclipse.ui.workbench, Version: 3.106.1.v20140827-1737, Location: reference:file:plugins/org.eclipse.ui.workbench_3.106.1.v20140827-1737.jar
Id: org.eclipse.ui.workbench.texteditor, Version: 3.9.0.v20140411-1521, Location: reference:file:plugins/org.eclipse.ui.workbench.texteditor_3.9.0.v20140411-1521.jar
Id: org.eclipse.update.configurator, Version: 3.3.300.v20140518-1928, Location: reference:file:plugins/org.eclipse.update.configurator_3.3.300.v20140518-1928.jar
Id: org.sat4j.core, Version: 2.3.5.v201308161310, Location: reference:file:plugins/org.sat4j.core_2.3.5.v201308161310.jar
Id: org.sat4j.pb, Version: 2.3.5.v201404071733, Location: reference:file:plugins/org.sat4j.pb_2.3.5.v201404071733.jar
Id: org.w3c.css.sac, Version: 1.3.1.v200903091627, Location: reference:file:plugins/org.w3c.css.sac_1.3.1.v200903091627.jar
Id: org.w3c.dom.events, Version: 3.0.0.draft20060413_v201105210656, Location: reference:file:plugins/org.w3c.dom.events_3.0.0.draft20060413_v201105210656.jar
Id: org.w3c.dom.smil, Version: 1.0.0.v200806040011, Location: reference:file:plugins/org.w3c.dom.smil_1.0.0.v200806040011.jar
Id: org.w3c.dom.svg, Version: 1.1.0.v201011041433, Location: reference:file:plugins/org.w3c.dom.svg_1.1.0.v201011041433.jar
*** Security Configuration:
Providers (10):
Provider: SUN, Version: 1.7, Class: sun.security.provider.Sun
  Description: SUN (DSA key/parameter generation; DSA signing; SHA-1, MD5 digests; SecureRandom; X.509 certificates; JKS keystore; PKIX CertPathValidator; PKIX CertPathBuilder; LDAP, Collection CertStores, JavaPolicy Policy; JavaLoginConfig Configuration)
  Services (23):
   Service: MessageDigest, Algorithm: SHA-512, Class: sun.security.provider.SHA5$SHA512
   Service: Configuration, Algorithm: JavaLoginConfig, Class: sun.security.provider.ConfigSpiFile
   Service: Signature, Algorithm: NONEwithDSA, Class: sun.security.provider.DSA$RawDSA
    Aliases: RawDSA
    Attributes:
      SupportedKeyClasses: java.security.interfaces.DSAPublicKey|java.security.interfaces.DSAPrivateKey
   Service: CertPathBuilder, Algorithm: PKIX, Class: sun.security.provider.certpath.SunCertPathBuilder
    Attributes:
      ImplementedIn: Software
      ValidationAlgorithm: RFC3280
   Service: CertStore, Algorithm: LDAP, Class: sun.security.provider.certpath.ldap.LDAPCertStore
    Attributes:
      LDAPSchema: RFC2587
   Service: MessageDigest, Algorithm: SHA, Class: sun.security.provider.SHA
    Aliases: SHA1
    Attributes:
   Service: CertificateFactory, Algorithm: X.509, Class: sun.security.provider.X509Factory
    Aliases: X509
    Attributes:
   Service: MessageDigest, Algorithm: SHA-384, Class: sun.security.provider.SHA5$SHA384
   Service: KeyPairGenerator, Algorithm: DSA, Class: sun.security.provider.DSAKeyPairGenerator
    Aliases: OID.1.2.840.10040.4.1
    Attributes:
      KeySize: 1024
   Service: KeyStore, Algorithm: JKS, Class: sun.security.provider.JavaKeyStore$JKS
    Attributes:
   Service: KeyStore, Algorithm: CaseExactJKS, Class: sun.security.provider.JavaKeyStore$CaseExactJKS
   Service: MessageDigest, Algorithm: SHA-256, Class: sun.security.provider.SHA2
   Service: CertStore, Algorithm: com.sun.security.IndexedCollection, Class: sun.security.provider.certpath.IndexedCollectionCertStore
    Attributes:
   Service: KeyFactory, Algorithm: DSA, Class: sun.security.provider.DSAKeyFactory
    Attributes:
   Service: SecureRandom, Algorithm: SHA1PRNG, Class: sun.security.provider.SecureRandom
    Attributes:
   Service: CertPathValidator, Algorithm: PKIX, Class: sun.security.provider.certpath.PKIXCertPathValidator
    Attributes:
   Service: CertStore, Algorithm: Collection, Class: sun.security.provider.certpath.CollectionCertStore
    Attributes:
   Service: MessageDigest, Algorithm: MD5, Class: sun.security.provider.MD5
    Attributes:
   Service: AlgorithmParameters, Algorithm: DSA, Class: sun.security.provider.DSAParameters
    Attributes:
   Service: Policy, Algorithm: JavaPolicy, Class: sun.security.provider.PolicySpiFile
   Service: MessageDigest, Algorithm: MD2, Class: sun.security.provider.MD2
   Service: Signature, Algorithm: SHA1withDSA, Class: sun.security.provider.DSA$SHA1withDSA
    Aliases: DSAWithSHA1
    Attributes:
      KeySize: 1024
   Service: AlgorithmParameterGenerator, Algorithm: DSA, Class: sun.security.provider.DSAParameterGenerator
    Attributes:
      KeySize: 1024
Provider: SunRsaSign, Version: 1.7, Class: sun.security.rsa.SunRsaSign
  Description: Sun RSA signature provider
  Services (8):
   Service: Signature, Algorithm: SHA512withRSA, Class: sun.security.rsa.RSASignature$SHA512withRSA
    Aliases: OID.1.2.840.113549.1.1.13
    Attributes:
      SupportedKeyClasses: java.security.interfaces.RSAPublicKey|java.security.interfaces.RSAPrivateKey
   Service: Signature, Algorithm: MD5withRSA, Class: sun.security.rsa.RSASignature$MD5withRSA
    Aliases: 1.2.840.113549.1.1.4
    Attributes:
   Service: KeyFactory, Algorithm: RSA, Class: sun.security.rsa.RSAKeyFactory
   Service: Signature, Algorithm: SHA1withRSA, Class: sun.security.rsa.RSASignature$SHA1withRSA
    Aliases: OID.1.2.840.113549.1.1.5
    Attributes:
   Service: Signature, Algorithm: SHA384withRSA, Class: sun.security.rsa.RSASignature$SHA384withRSA
    Aliases: OID.1.2.840.113549.1.1.12
    Attributes:
   Service: Signature, Algorithm: MD2withRSA, Class: sun.security.rsa.RSASignature$MD2withRSA
    Aliases: 1.2.840.113549.1.1.2
    Attributes:
   Service: KeyPairGenerator, Algorithm: RSA, Class: sun.security.rsa.RSAKeyPairGenerator
   Service: Signature, Algorithm: SHA256withRSA, Class: sun.security.rsa.RSASignature$SHA256withRSA
    Aliases: OID.1.2.840.113549.1.1.11
    Attributes:
Provider: SunEC, Version: 1.7, Class: sun.security.ec.SunEC
  Description: Sun Elliptic Curve provider (EC, ECDSA, ECDH)
  Services (9):
   Service: Signature, Algorithm: SHA512withECDSA, Class: sun.security.ec.ECDSASignature$SHA512
    Attributes:
      SupportedKeyClasses: java.security.interfaces.ECPublicKey|java.security.interfaces.ECPrivateKey
   Service: AlgorithmParameters, Algorithm: EC, Class: sun.security.ec.ECParameters
    Aliases: EllipticCurve
    Attributes:
      SupportedCurves: [secp112r1,1.3.132.0.6]|[secp112r2,1.3.132.0.7]|[secp128r1,1.3.132.0.28]|[secp128r2,1.3.132.0.29]|[secp160k1,1.3.132.0.9]|[secp160r1,1.3.132.0.8]|[secp160r2,1.3.132.0.30]|[secp192k1,1.3.132.0.31]|[secp192r1,NIST P-192,X9.62 prime192v1,1.2.840.10045.3.1.1]|[secp224k1,1.3.132.0.32]|[secp224r1,NIST P-224,1.3.132.0.33]|[secp256k1,1.3.132.0.10]|[secp256r1,NIST P-256,X9.62 prime256v1,1.2.840.10045.3.1.7]|[secp384r1,NIST P-384,1.3.132.0.34]|[secp521r1,NIST P-521,1.3.132.0.35]|[X9.62 prime192v2,1.2.840.10045.3.1.2]|[X9.62 prime192v3,1.2.840.10045.3.1.3]|[X9.62 prime239v1,1.2.840.10045.3.1.4]|[X9.62 prime239v2,1.2.840.10045.3.1.5]|[X9.62 prime239v3,1.2.840.10045.3.1.6]|[sect113r1,1.3.132.0.4]|[sect113r2,1.3.132.0.5]|[sect131r1,1.3.132.0.22]|[sect131r2,1.3.132.0.23]|[sect163k1,NIST K-163,1.3.132.0.1]|[sect163r1,1.3.132.0.2]|[sect163r2,NIST B-163,1.3.132.0.15]|[sect193r1,1.3.132.0.24]|[sect193r2,1.3.132.0.25]|[sect233k1,NIST K-233,1.3.132.0.26]|[sect233r1,NIST B-233,1.3.132.0.27]|[sect239k1,1.3.132.0.3]|[sect283k1,NIST K-283,1.3.132.0.16]|[sect283r1,NIST B-283,1.3.132.0.17]|[sect409k1,NIST K-409,1.3.132.0.36]|[sect409r1,NIST B-409,1.3.132.0.37]|[sect571k1,NIST K-571,1.3.132.0.38]|[sect571r1,NIST B-571,1.3.132.0.39]|[X9.62 c2tnb191v1,1.2.840.10045.3.0.5]|[X9.62 c2tnb191v2,1.2.840.10045.3.0.6]|[X9.62 c2tnb191v3,1.2.840.10045.3.0.7]|[X9.62 c2tnb239v1,1.2.840.10045.3.0.11]|[X9.62 c2tnb239v2,1.2.840.10045.3.0.12]|[X9.62 c2tnb239v3,1.2.840.10045.3.0.13]|[X9.62 c2tnb359v1,1.2.840.10045.3.0.18]|[X9.62 c2tnb431r1,1.2.840.10045.3.0.20]
      KeySize: 256
   Service: Signature, Algorithm: SHA384withECDSA, Class: sun.security.ec.ECDSASignature$SHA384
    Attributes:
   Service: Signature, Algorithm: NONEwithECDSA, Class: sun.security.ec.ECDSASignature$Raw
    Attributes:
   Service: Signature, Algorithm: SHA1withECDSA, Class: sun.security.ec.ECDSASignature$SHA1
    Attributes:
      KeySize: 256
   Service: KeyPairGenerator, Algorithm: EC, Class: sun.security.ec.ECKeyPairGenerator
    Attributes:
      KeySize: 256
   Service: KeyFactory, Algorithm: EC, Class: sun.security.ec.ECKeyFactory
    Attributes:
   Service: KeyAgreement, Algorithm: ECDH, Class: sun.security.ec.ECDHKeyAgreement
    Attributes:
   Service: Signature, Algorithm: SHA256withECDSA, Class: sun.security.ec.ECDSASignature$SHA256
    Attributes:
Provider: SunJSSE, Version: 1.7, Class: com.sun.net.ssl.internal.ssl.Provider
  Description: Sun JSSE provider(PKCS12, SunX509 key/trust factories, SSLv3, TLSv1)
  Services (15):
   Service: Signature, Algorithm: MD5andSHA1withRSA, Class: sun.security.ssl.RSASignature
   Service: SSLContext, Algorithm: Default, Class: sun.security.ssl.SSLContextImpl$DefaultSSLContext
   Service: KeyManagerFactory, Algorithm: SunX509, Class: sun.security.ssl.KeyManagerFactoryImpl$SunX509
    Aliases: OID.1.2.840.113549.1.1.4
   Service: TrustManagerFactory, Algorithm: SunX509, Class: sun.security.ssl.TrustManagerFactoryImpl$SimpleFactory
   Service: KeyStore, Algorithm: PKCS12, Class: sun.security.pkcs12.PKCS12KeyStore
   Service: SSLContext, Algorithm: TLSv1, Class: sun.security.ssl.SSLContextImpl$TLS10Context
    Aliases: TLS
   Service: SSLContext, Algorithm: TLSv1.2, Class: sun.security.ssl.SSLContextImpl$TLS12Context
   Service: KeyManagerFactory, Algorithm: NewSunX509, Class: sun.security.ssl.KeyManagerFactoryImpl$X509
    Aliases: PKIX
   Service: SSLContext, Algorithm: TLSv1.1, Class: sun.security.ssl.SSLContextImpl$TLS11Context
   Service: TrustManagerFactory, Algorithm: PKIX, Class: sun.security.ssl.TrustManagerFactoryImpl$PKIXFactory
    Aliases: X509
Provider: SunJCE, Version: 1.7, Class: com.sun.crypto.provider.SunJCE
  Description: SunJCE Provider (implements RSA, DES, Triple DES, AES, Blowfish, ARCFOUR, RC2, PBE, Diffie-Hellman, HMAC)
  Services (61):
   Service: KeyGenerator, Algorithm: DESede, Class: com.sun.crypto.provider.DESedeKeyGenerator
    Aliases: TripleDES
   Service: KeyGenerator, Algorithm: HmacSHA384, Class: com.sun.crypto.provider.KeyGeneratorCore$HmacSHA384KG
   Service: AlgorithmParameters, Algorithm: OAEP, Class: com.sun.crypto.provider.OAEPParameters
   Service: KeyGenerator, Algorithm: ARCFOUR, Class: com.sun.crypto.provider.KeyGeneratorCore$ARCFOURKeyGenerator
    Aliases: RC4
   Service: Cipher, Algorithm: AESWrap, Class: com.sun.crypto.provider.AESWrapCipher
    Attributes:
      SupportedPaddings: NOPADDING
      SupportedKeyFormats: RAW
      SupportedModes: ECB
   Service: KeyGenerator, Algorithm: HmacSHA256, Class: com.sun.crypto.provider.KeyGeneratorCore$HmacSHA256KG
   Service: KeyGenerator, Algorithm: HmacSHA512, Class: com.sun.crypto.provider.KeyGeneratorCore$HmacSHA512KG
   Service: KeyGenerator, Algorithm: SunTls12Prf, Class: com.sun.crypto.provider.TlsPrfGenerator$V12
   Service: AlgorithmParameters, Algorithm: AES, Class: com.sun.crypto.provider.AESParameters
    Aliases: Rijndael
   Service: AlgorithmParameters, Algorithm: PBEWithMD5AndTripleDES, Class: com.sun.crypto.provider.PBEParameters
   Service: AlgorithmParameters, Algorithm: RC2, Class: com.sun.crypto.provider.RC2Parameters
   Service: KeyStore, Algorithm: JCEKS, Class: com.sun.crypto.provider.JceKeyStore
   Service: KeyGenerator, Algorithm: SunTlsPrf, Class: com.sun.crypto.provider.TlsPrfGenerator$V10
   Service: Cipher, Algorithm: DES, Class: com.sun.crypto.provider.DESCipher
    Attributes:
      SupportedPaddings: NOPADDING|PKCS5PADDING|ISO10126PADDING
      SupportedModes: ECB|CBC|PCBC|CTR|CTS|CFB|OFB|CFB8|CFB16|CFB24|CFB32|CFB40|CFB48|CFB56|CFB64|OFB8|OFB16|OFB24|OFB32|OFB40|OFB48|OFB56|OFB64
   Service: Cipher, Algorithm: RSA, Class: com.sun.crypto.provider.RSACipher
    Attributes:
      SupportedPaddings: NOPADDING|PKCS1PADDING|OAEPWITHMD5ANDMGF1PADDING|OAEPWITHSHA1ANDMGF1PADDING|OAEPWITHSHA-1ANDMGF1PADDING|OAEPWITHSHA-256ANDMGF1PADDING|OAEPWITHSHA-384ANDMGF1PADDING|OAEPWITHSHA-512ANDMGF1PADDING
      SupportedModes: ECB
   Service: KeyFactory, Algorithm: DiffieHellman, Class: com.sun.crypto.provider.DHKeyFactory
    Aliases: DH
   Service: Cipher, Algorithm: PBEWithSHA1AndDESede, Class: com.sun.crypto.provider.PKCS12PBECipherCore$PBEWithSHA1AndDESede
    Aliases: OID.1.2.840.113549.1.12.1.3
   Service: AlgorithmParameters, Algorithm: DiffieHellman, Class: com.sun.crypto.provider.DHParameters
    Aliases: DH
   Service: Cipher, Algorithm: DESedeWrap, Class: com.sun.crypto.provider.DESedeWrapCipher
    Attributes:
      SupportedModes: CBC
   Service: KeyGenerator, Algorithm: SunTlsRsaPremasterSecret, Class: com.sun.crypto.provider.TlsRsaPremasterSecretGenerator
    Aliases: SunTls12RsaPremasterSecret
   Service: AlgorithmParameters, Algorithm: DESede, Class: com.sun.crypto.provider.DESedeParameters
    Aliases: TripleDES
   Service: KeyGenerator, Algorithm: HmacSHA1, Class: com.sun.crypto.provider.HmacSHA1KeyGenerator
   Service: SecretKeyFactory, Algorithm: PBEWithMD5AndDES, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithMD5AndDES
    Aliases: 1.2.840.113549.1.5.3
   Service: Cipher, Algorithm: PBEWithSHA1AndRC2_40, Class: com.sun.crypto.provider.PKCS12PBECipherCore$PBEWithSHA1AndRC2_40
    Aliases: OID.1.2.840.113549.1.12.1.6
   Service: Mac, Algorithm: HmacMD5, Class: com.sun.crypto.provider.HmacMD5
    Attributes:
   Service: SecretKeyFactory, Algorithm: DESede, Class: com.sun.crypto.provider.DESedeKeyFactory
    Aliases: TripleDES
   Service: Mac, Algorithm: SslMacSHA1, Class: com.sun.crypto.provider.SslMacCore$SslMacSHA1
    Attributes:
   Service: KeyGenerator, Algorithm: SunTlsMasterSecret, Class: com.sun.crypto.provider.TlsMasterSecretGenerator
    Aliases: SunTls12MasterSecret
   Service: KeyGenerator, Algorithm: DES, Class: com.sun.crypto.provider.DESKeyGenerator
   Service: Cipher, Algorithm: PBEWithMD5AndTripleDES, Class: com.sun.crypto.provider.PBEWithMD5AndTripleDESCipher
   Service: AlgorithmParameters, Algorithm: PBEWithSHA1AndDESede, Class: com.sun.crypto.provider.PBEParameters
   Service: Cipher, Algorithm: ARCFOUR, Class: com.sun.crypto.provider.ARCFOURCipher
    Aliases: RC4
    Attributes:
      SupportedModes: ECB
   Service: AlgorithmParameters, Algorithm: PBE, Class: com.sun.crypto.provider.PBEParameters
   Service: SecretKeyFactory, Algorithm: PBEWithMD5AndTripleDES, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithMD5AndTripleDES
   Service: Mac, Algorithm: HmacPBESHA1, Class: com.sun.crypto.provider.HmacPKCS12PBESHA1
    Attributes:
   Service: Cipher, Algorithm: AES, Class: com.sun.crypto.provider.AESCipher
    Aliases: Rijndael
    Attributes:
      SupportedModes: ECB|CBC|PCBC|CTR|CTS|CFB|OFB|CFB8|CFB16|CFB24|CFB32|CFB40|CFB48|CFB56|CFB64|OFB8|OFB16|OFB24|OFB32|OFB40|OFB48|OFB56|OFB64|CFB72|CFB80|CFB88|CFB96|CFB104|CFB112|CFB120|CFB128|OFB72|OFB80|OFB88|OFB96|OFB104|OFB112|OFB120|OFB128
   Service: SecretKeyFactory, Algorithm: DES, Class: com.sun.crypto.provider.DESKeyFactory
   Service: Cipher, Algorithm: RC2, Class: com.sun.crypto.provider.RC2Cipher
    Attributes:
   Service: AlgorithmParameters, Algorithm: PBEWithSHA1AndRC2_40, Class: com.sun.crypto.provider.PBEParameters
   Service: KeyAgreement, Algorithm: DiffieHellman, Class: com.sun.crypto.provider.DHKeyAgreement
    Aliases: DH
    Attributes:
      SupportedKeyClasses: javax.crypto.interfaces.DHPublicKey|javax.crypto.interfaces.DHPrivateKey
   Service: KeyGenerator, Algorithm: Blowfish, Class: com.sun.crypto.provider.BlowfishKeyGenerator
   Service: KeyPairGenerator, Algorithm: DiffieHellman, Class: com.sun.crypto.provider.DHKeyPairGenerator
    Aliases: DH
   Service: Cipher, Algorithm: PBEWithMD5AndDES, Class: com.sun.crypto.provider.PBEWithMD5AndDESCipher
   Service: Cipher, Algorithm: Blowfish, Class: com.sun.crypto.provider.BlowfishCipher
    Attributes:
   Service: AlgorithmParameters, Algorithm: DES, Class: com.sun.crypto.provider.DESParameters
   Service: KeyGenerator, Algorithm: AES, Class: com.sun.crypto.provider.AESKeyGenerator
    Aliases: Rijndael
   Service: KeyGenerator, Algorithm: HmacMD5, Class: com.sun.crypto.provider.HmacMD5KeyGenerator
   Service: SecretKeyFactory, Algorithm: PBKDF2WithHmacSHA1, Class: com.sun.crypto.provider.PBKDF2HmacSHA1Factory
    Aliases: OID.1.2.840.113549.1.5.12
   Service: KeyGenerator, Algorithm: RC2, Class: com.sun.crypto.provider.KeyGeneratorCore$RC2KeyGenerator
   Service: Mac, Algorithm: SslMacMD5, Class: com.sun.crypto.provider.SslMacCore$SslMacMD5
    Attributes:
   Service: SecretKeyFactory, Algorithm: PBEWithSHA1AndDESede, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithSHA1AndDESede
   Service: AlgorithmParameterGenerator, Algorithm: DiffieHellman, Class: com.sun.crypto.provider.DHParameterGenerator
    Aliases: DH
   Service: Mac, Algorithm: HmacSHA1, Class: com.sun.crypto.provider.HmacSHA1
    Attributes:
   Service: Mac, Algorithm: HmacSHA384, Class: com.sun.crypto.provider.HmacCore$HmacSHA384
    Attributes:
   Service: KeyGenerator, Algorithm: SunTlsKeyMaterial, Class: com.sun.crypto.provider.TlsKeyMaterialGenerator
    Aliases: SunTls12KeyMaterial
   Service: SecretKeyFactory, Algorithm: PBEWithSHA1AndRC2_40, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithSHA1AndRC2_40
   Service: Mac, Algorithm: HmacSHA256, Class: com.sun.crypto.provider.HmacCore$HmacSHA256
    Attributes:
   Service: AlgorithmParameters, Algorithm: Blowfish, Class: com.sun.crypto.provider.BlowfishParameters
   Service: Mac, Algorithm: HmacSHA512, Class: com.sun.crypto.provider.HmacCore$HmacSHA512
    Attributes:
   Service: AlgorithmParameters, Algorithm: PBEWithMD5AndDES, Class: com.sun.crypto.provider.PBEParameters
   Service: Cipher, Algorithm: DESede, Class: com.sun.crypto.provider.DESedeCipher
    Aliases: TripleDES
    Attributes:
Provider: SunJGSS, Version: 1.7, Class: sun.security.jgss.SunProvider
  Description: Sun (Kerberos v5, SPNEGO)
  Services (2):
   Service: GssApiMechanism, Algorithm: 1.3.6.1.5.5.2, Class: sun.security.jgss.spnego.SpNegoMechFactory
   Service: GssApiMechanism, Algorithm: 1.2.840.113554.1.2.2, Class: sun.security.jgss.krb5.Krb5MechFactory
Provider: SunSASL, Version: 1.7, Class: com.sun.security.sasl.Provider
  Description: Sun SASL provider(implements client mechanisms for: DIGEST-MD5, GSSAPI, EXTERNAL, PLAIN, CRAM-MD5, NTLM; server mechanisms for: DIGEST-MD5, GSSAPI, CRAM-MD5, NTLM)
  Services (10):
   Service: SaslClientFactory, Algorithm: NTLM, Class: com.sun.security.sasl.ntlm.FactoryImpl
   Service: SaslClientFactory, Algorithm: CRAM-MD5, Class: com.sun.security.sasl.ClientFactoryImpl
   Service: SaslClientFactory, Algorithm: EXTERNAL, Class: com.sun.security.sasl.ClientFactoryImpl
   Service: SaslClientFactory, Algorithm: DIGEST-MD5, Class: com.sun.security.sasl.digest.FactoryImpl
   Service: SaslClientFactory, Algorithm: PLAIN, Class: com.sun.security.sasl.ClientFactoryImpl
   Service: SaslServerFactory, Algorithm: NTLM, Class: com.sun.security.sasl.ntlm.FactoryImpl
   Service: SaslClientFactory, Algorithm: GSSAPI, Class: com.sun.security.sasl.gsskerb.FactoryImpl
   Service: SaslServerFactory, Algorithm: CRAM-MD5, Class: com.sun.security.sasl.ServerFactoryImpl
   Service: SaslServerFactory, Algorithm: DIGEST-MD5, Class: com.sun.security.sasl.digest.FactoryImpl
   Service: SaslServerFactory, Algorithm: GSSAPI, Class: com.sun.security.sasl.gsskerb.FactoryImpl
Provider: XMLDSig, Version: 1.0, Class: org.jcp.xml.dsig.internal.dom.XMLDSigRI
  Description: XMLDSig (DOM XMLSignatureFactory; DOM KeyInfoFactory)
  Services (13):
   Service: KeyInfoFactory, Algorithm: DOM, Class: org.jcp.xml.dsig.internal.dom.DOMKeyInfoFactory
   Service: TransformService, Algorithm: http://www.w3.org/TR/1999/REC-xpath-19991116, Class: org.jcp.xml.dsig.internal.dom.DOMXPathTransform
    Aliases: XPATH
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/TR/2001/REC-xml-c14n-20010315#WithComments, Class: org.jcp.xml.dsig.internal.dom.DOMCanonicalXMLC14NMethod
    Aliases: INCLUSIVE_WITH_COMMENTS
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/2000/09/xmldsig#base64, Class: org.jcp.xml.dsig.internal.dom.DOMBase64Transform
    Aliases: BASE64
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/2000/09/xmldsig#enveloped-signature, Class: org.jcp.xml.dsig.internal.dom.DOMEnvelopedTransform
    Aliases: ENVELOPED
    Attributes:
      MechanismType: DOM
   Service: XMLSignatureFactory, Algorithm: DOM, Class: org.jcp.xml.dsig.internal.dom.DOMXMLSignatureFactory
   Service: TransformService, Algorithm: http://www.w3.org/TR/2001/REC-xml-c14n-20010315, Class: org.jcp.xml.dsig.internal.dom.DOMCanonicalXMLC14NMethod
    Aliases: INCLUSIVE
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/2002/06/xmldsig-filter2, Class: org.jcp.xml.dsig.internal.dom.DOMXPathFilter2Transform
    Aliases: XPATH2
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/2001/10/xml-exc-c14n#, Class: org.jcp.xml.dsig.internal.dom.DOMExcC14NMethod
    Aliases: EXCLUSIVE
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/TR/1999/REC-xslt-19991116, Class: org.jcp.xml.dsig.internal.dom.DOMXSLTTransform
    Aliases: XSLT
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/2006/12/xml-c14n11#WithComments, Class: org.jcp.xml.dsig.internal.dom.DOMCanonicalXMLC14N11Method
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/2001/10/xml-exc-c14n#WithComments, Class: org.jcp.xml.dsig.internal.dom.DOMExcC14NMethod
    Aliases: EXCLUSIVE_WITH_COMMENTS
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/2006/12/xml-c14n11, Class: org.jcp.xml.dsig.internal.dom.DOMCanonicalXMLC14N11Method
    Attributes:
      MechanismType: DOM
Provider: SunPCSC, Version: 1.7, Class: sun.security.smartcardio.SunPCSC
  Description: Sun PC/SC provider
  Services (1):
   Service: TerminalFactory, Algorithm: PC/SC, Class: sun.security.smartcardio.SunPCSC$Factory
Provider: SunMSCAPI, Version: 1.7, Class: sun.security.mscapi.SunMSCAPI
  Description: Sun's Microsoft Crypto API provider
  Services (13):
   Service: Signature, Algorithm: SHA512withRSA, Class: sun.security.mscapi.RSASignature$SHA512
    Attributes:
      SupportedKeyClasses: sun.security.mscapi.Key
   Service: Signature, Algorithm: MD5withRSA, Class: sun.security.mscapi.RSASignature$MD5
    Attributes:
   Service: Signature, Algorithm: NONEwithRSA, Class: sun.security.mscapi.RSASignature$Raw
    Attributes:
   Service: Signature, Algorithm: SHA1withRSA, Class: sun.security.mscapi.RSASignature$SHA1
    Attributes:
   Service: Cipher, Algorithm: RSA, Class: sun.security.mscapi.RSACipher
    Attributes:
      SupportedPaddings: PKCS1PADDING
      SupportedModes: ECB
   Service: SecureRandom, Algorithm: Windows-PRNG, Class: sun.security.mscapi.PRNG
   Service: KeyStore, Algorithm: Windows-ROOT, Class: sun.security.mscapi.KeyStore$ROOT
   Service: Signature, Algorithm: SHA384withRSA, Class: sun.security.mscapi.RSASignature$SHA384
    Attributes:
   Service: KeyPairGenerator, Algorithm: RSA, Class: sun.security.mscapi.RSAKeyPairGenerator
    Attributes:
      KeySize: 1024
   Service: Signature, Algorithm: SHA256withRSA, Class: sun.security.mscapi.RSASignature$SHA256
    Attributes:
   Service: Cipher, Algorithm: RSA/ECB/PKCS1Padding, Class: sun.security.mscapi.RSACipher
   Service: Signature, Algorithm: MD2withRSA, Class: sun.security.mscapi.RSASignature$MD2
    Attributes:
   Service: KeyStore, Algorithm: Windows-MY, Class: sun.security.mscapi.KeyStore$MY
Content originally posted in LPCWare by lpcxpresso-support on Fri Mar 13 05:30:41 MST 2015
That project builds correctly here (as I would expect), so I guess it is an issue on your PC. Lets see if we can identify the issue:
1. Which version of Windows are you using
2. please open a command window and type
set
and post the results
3.In the IDE, use the menu item Help->About LPCXpresso, then click on "Installation Details", then on the Configuration tab. Wait for the data to populate and then press Copy to Clipboard and post the results
Content originally posted in LPCWare by nxpuser1 on Fri Mar 13 04:49:21 MST 2015
hi,
example project attaching folder is my project wanting to debug. I make that you write above. But give me error again.
Content originally posted in LPCWare by lpcxpresso-support on Fri Mar 13 03:09:38 MST 2015
There are working examples supplied in the product.
Quickstart->Import projects
Browse to Examples\NXP\LPC1000\LPC17xx
and Open LPCXpresso176x_cmsis2.zip
now finish the Wizard and build/debug any of the examples
I asked you to EXPORT the project that is failing for you. I can then tell you what you have done wrong.
Content originally posted in LPCWare by nxpuser1 on Fri Mar 13 03:03:25 MST 2015
Yes I read, I think I import projects correctly. I follow below way to do it.
In the Quickstart Panel, click on Import projects
If Importing from a zip file, press the Archive Browse button
Browse to the zip file, and press OK
A list of importable projects contained in the directory is displayed
Check/uncheck projects from the list as necessary and Finish  ------- I check all projects.
I try to do invadually build reference project and build main project. I try vice versa, ı mean without any reference build process, only buil main project. For example to run periph_bilinky project first only build this project, but there is a  same problem. And than try it with build two reference of project that lpc_chip_175x_6x and lpc_board_nxp_lpcxpresso_1769 projects. But there is a same problem. I do it when all projects are in the workspace.
I think I have linker problem but I can't solve it. Can you send me basic project for Lpcxpresso_1769 board. I try to run it, please
Thank you.
Content originally posted in LPCWare by lpcxpresso-support on Fri Mar 13 01:16:41 MST 2015
Please export your project and post it to this thread
http://www.lpcware.com/content/faq/lpcxpresso/how-importexport-projects
Content originally posted in LPCWare by nxpuser1 on Fri Mar 13 00:55:06 MST 2015
below written In console
09:50:36 Build Finished (took 153ms)
09:50:38 **** Build of configuration Debug for project periph_blinky ****
make -r all
Building file: ../example/src/cr_startup_lpc175x_6x.c
Invoking: MCU C Compiler
arm-none-eabi-gcc -D__REDLIB__ -DDEBUG -D__CODE_RED -D__USE_LPCOPEN -DCORE_M3 -I"C:\Users\Egitim5\Documents\LPCXpresso_7.6.2_326\lpc_chip_175x_6x\inc" -I"C:\Users\Egitim5\Documents\LPCXpresso_7.6.2_326\lpc_board_nxp_lpcxpresso_1769\inc" -O0 -g3 -Wall -c -fmessage-length=0 -fno-builtin -ffunction-sections -fdata-sections -mcpu=cortex-m3 -mthumb -D__REDLIB__ -specs=redlib.specs -MMD -MP -MF"example/src/cr_startup_lpc175x_6x.d" -MT"example/src/cr_startup_lpc175x_6x.o" -MT"example/src/cr_startup_lpc175x_6x.d" -o "example/src/cr_startup_lpc175x_6x.o" "../example/src/cr_startup_lpc175x_6x.c"
Finished building: ../example/src/cr_startup_lpc175x_6x.c
Building file: ../example/src/sysinit.c
arm-none-eabi-gcc -D__REDLIB__ -DDEBUG -D__CODE_RED -D__USE_LPCOPEN -DCORE_M3 -I"C:\Users\Egitim5\Documents\LPCXpresso_7.6.2_326\lpc_chip_175x_6x\inc" -I"C:\Users\Egitim5\Documents\LPCXpresso_7.6.2_326\lpc_board_nxp_lpcxpresso_1769\inc" -O0 -g3 -Wall -c -fmessage-length=0 -fno-builtin -ffunction-sections -fdata-sections -mcpu=cortex-m3 -mthumb -D__REDLIB__ -specs=redlib.specs -MMD -MP -MF"example/src/sysinit.d" -MT"example/src/sysinit.o" -MT"example/src/sysinit.d" -o "example/src/sysinit.o" "../example/src/sysinit.c"
Finished building: ../example/src/sysinit.c
Building file: ../example/src/systick.c
arm-none-eabi-gcc -D__REDLIB__ -DDEBUG -D__CODE_RED -D__USE_LPCOPEN -DCORE_M3 -I"C:\Users\Egitim5\Documents\LPCXpresso_7.6.2_326\lpc_chip_175x_6x\inc" -I"C:\Users\Egitim5\Documents\LPCXpresso_7.6.2_326\lpc_board_nxp_lpcxpresso_1769\inc" -O0 -g3 -Wall -c -fmessage-length=0 -fno-builtin -ffunction-sections -fdata-sections -mcpu=cortex-m3 -mthumb -D__REDLIB__ -specs=redlib.specs -MMD -MP -MF"example/src/systick.d" -MT"example/src/systick.o" -MT"example/src/systick.d" -o "example/src/systick.o" "../example/src/systick.c"
Finished building: ../example/src/systick.c
Building target: periph_blinky.axf
Invoking: MCU Linker
arm-none-eabi-gcc -nostdlib -L"C:\Users\Egitim5\Documents\LPCXpresso_7.6.2_326\lpc_chip_175x_6x\Debug" -L"C:\Users\Egitim5\Documents\LPCXpresso_7.6.2_326\lpc_board_nxp_lpcxpresso_1769\Debug" -Xlinker -Map="periph_blinky.map" -Xlinker --gc-sections -mcpu=cortex-m3 -mthumb -T "periph_blinky_Debug.ld" -o "periph_blinky.axf"  ./example/src/cr_startup_lpc175x_6x.o ./example/src/sysinit.o ./example/src/systick.o   -llpc_board_nxp_lpcxpresso_1769 -llpc_chip_175x_6x
c:/nxp/lpcxpresso_7.6.2_326/lpcxpresso/tools/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ld.exe: invalid data statement
collect2.exe: error: ld returned 1 exit status
make: *** [periph_blinky.axf] Error 1
09:50:40 Build Finished (took 1s.416ms)
Content originally posted in LPCWare by lpcxpresso-support on Tue Mar 10 10:07:26 MST 2015
Another question to ask is whether you imported the project files from an archive, or simply extracted the archive directly into your workspace? You should use LPCXpresso File->Import. In the dialog, select General->Existing Projects into Workspace.
LPCXpresso Support
Content originally posted in LPCWare by whitecoe on Tue Mar 10 09:49:49 MST 2015
So the error message "invalid data statement" might suggest a locale problem...
http://www.lpcware.com/content/forum/762-fails-build-any-project-library-projects
PS - you do know you can copy/paste text out of the build console ??  :)
http://www.lpcware.com/content/faq/lpcxpresso/build-console
Content originally posted in LPCWare by nxpuser1 on Tue Mar 10 08:36:03 MST 2015
I attached my screen shoot. I suppose that you can look my problem via picture.
thanks again.
Content originally posted in LPCWare by lpcxpresso-support on Tue Mar 10 07:02:11 MST 2015
You have to explain what you did, and what errors you receive.
I just downloaded the examples, and they build without error.
