Content originally posted in LPCWare by frame on Sat Feb 02 08:58:26 MST 2013
Two things you can try.
First, does it run when you start as root ?
If so, there might be a access rights problem (less likely).
Second, you might need to change the default java. AFAIK, most distributions come with OpenJDK.
Eclipse/LPCXpresso might not work well with it; [FONT=Courier New][B]update-java-alternatives[/B][/FONT] could help in this case.
