How to use freemaster with freertos and SDK2.0?
Are there examples for the FRDM K64 board ?
Raul
Hi Raul,
at the moment no, but in case of any change, I will let you know.
For this moment - you can see the example for KSDK 1.2 with PE, is there some example using freemaster+frdm-k64f + PE+kds3.0+ sdk 1.2?
and here is described whole procedure https://mcuoneclipse.com/2013/08/24/tutorial-freemaster-visualization-and-run-time-debugging/
I hope this helps you.
Iva
