Code crashes at __libc_init_array
prashanttawde
I am working on MK61FX512 controller with MQX as RTOS. My development environment is Kinetis Design Studio.
I am running my application from DRAM memory. Currently, I am able to build, link MQX code to my application and it is debugging properly with jlink debugger.
Here, I am facing one issue. whenever code reaches to __libc_init_array call from toolchain_startup function. My code get crashes without any traces.
Any special library need to this during compilation or anything else I am missing here.
Thanks and Regards,
Prashant Tawde
soledad
Please check the below thread and let me know if this helps!!!
On the startup
Sol
prashanttawde
Thanks Soledad. Issue is resolved now.
