i use imx6q .I want to port the rtl8723bs to android 4.3 ,I port it with realtek's guid,but it is not work.I can not to enable it from Android UI.the follow is the dmesg infomation.what can i do?
root@sabresd_6dq:/ # dmesg
ost suspend begins
<7>will suspend roothub and its children
<7>ehci_fsl_bus_suspend begins, DR
<7>ehci_fsl_bus_suspend ends, DR
<7>host suspend ends
<7>USB Gadget resume begins
<7>fsl_udc_resume, Wait for wakeup thread finishes
<7>dr_controller_run: udc out low power mode
<7>USB Gadget resume ends
<6>fsl-usb2-udc: bind to driver android_usb
<6>mousedev: PS/2 mouse device common for all mice
<6>input: gpio-keys as /devices/platform/gpio-keys/input/input0
<6>input: tq_hs0038 as /devices/virtual/input/input1
<4>Input: S3C GPIO hs0038 Registered
<6>input: ft5x06_ts as /devices/virtual/input/input2
<4>i2c-core: driver [isl29023] using legacy suspend method
<4>i2c-core: driver [isl29023] using legacy resume method
<4>Flag is 0x20
<4>rtc-rx8025t 0-0032: Update time was detected
<6>rtc-rx8025t 0-0032: rx8025t_get_time: date 10s 54m 9h 5wd 1md 3m 116y
<6>using rtc device, rx8025t, for alarms
<6>rtc-rx8025t 0-0032: rtc core: registered rx8025t as rtc0
<6>i2c /dev entries driver
<6>Linux video capture interface: v2.00
<4>i2c-core: driver [tuner] using legacy suspend method
<4>i2c-core: driver [tuner] using legacy resume method
<4>i2c-core: driver [msp3400] using legacy suspend method
<4>i2c-core: driver [msp3400] using legacy resume method
<6>android_work: did not send uevent (0 0 (null))
<6>usb 2-1: new high speed USB device number 2 using fsl-ehci
<6>android_work: sent uevent USB_STATE=CONNECTED
<6>android_work: sent uevent USB_STATE=DISCONNECTED
<3>ov3640_read_reg:write reg error:reg=300a
<3>ov3640_read_reg:write reg error:reg=300b
<6>hub 2-1:1.0: USB hub found
<6>hub 2-1:1.0: 4 ports detected
<6>mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video16
<6>mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video17
<6>usbcore: registered new interface driver usbvision
<6>USBVision USB Video Device Driver for Linux : 0.9.10
<6>usbcore: registered new interface driver pvrusb2
<6>pvrusb2: V4L in-tree version:Hauppauge WinTV-PVR-USB2 MPEG2 Encoder/Tuner
<6>pvrusb2: Debug mask is 31 (0x1f)
<6>usbcore: registered new interface driver zr364xx
<6>zr364xx: Zoran 364xx
<6>usbcore: registered new interface driver stkwebcam
<6>sn9c102: V4L2 driver for SN9C1xx PC Camera Controllers v1:1.47pre49
<6>usbcore: registered new interface driver sn9c102
<6>et61x251: V4L2 driver for ET61X[12]51 PC Camera Controllers v1:1.09
<6>usbcore: registered new interface driver et61x251
<6>pwc: Philips webcam module version 10.0.14 loaded.
<6>pwc: Supports Philips PCA645/646, PCVC675/680/690, PCVC720[40]/730/740/750 & PCVC830/840.
<6>pwc: Also supports the Askey VC010, various Logitech Quickcams, Samsung MPC-C10 and MPC-C30,
<6>pwc: the Creative WebCam 5 & Pro Ex, SOTEC Afina Eye and Visionite VCS-UC300 and VCS-UM100.
<6>usbcore: registered new interface driver Philips webcam
<6>gspca: v2.13.0 registered
<6>usbcore: registered new interface driver benq
<6>usbcore: registered new interface driver conex
<6>usbcore: registered new interface driver cpia1
<6>usbcore: registered new interface driver etoms
<6>usbcore: registered new interface driver finepix
<6>usbcore: registered new interface driver jeilinj
<6>usbcore: registered new interface driver kinect
<6>usbcore: registered new interface driver konica
<6>usbcore: registered new interface driver mars
<6>usbcore: registered new interface driver mr97310a
<6>usbcore: registered new interface driver nw80x
<6>usbcore: registered new interface driver ov519
<6>usbcore: registered new interface driver ov534
<6>usbcore: registered new interface driver ov534_9
<6>usbcore: registered new interface driver pac207
<6>usbcore: registered new interface driver pac7302
<6>usbcore: registered new interface driver pac7311
<6>usbcore: registered new interface driver sn9c2028
<6>usbcore: registered new interface driver sn9c20x
<6>usbcore: registered new interface driver sonixb
<6>usbcore: registered new interface driver sonixj
<6>usbcore: registered new interface driver spca500
<6>usbcore: registered new interface driver spca501
<6>usbcore: registered new interface driver spca505
<6>usbcore: registered new interface driver spca506
<6>usbcore: registered new interface driver spca508
<6>usbcore: registered new interface driver spca561
<6>usbcore: registered new interface driver spca1528
<6>usbcore: registered new interface driver sq905
<6>usbcore: registered new interface driver sq905c
<6>usbcore: registered new interface driver sq930x
<6>usbcore: registered new interface driver sunplus
<6>usbcore: registered new interface driver stk014
<6>usbcore: registered new interface driver stv0680
<6>usbcore: registered new interface driver t613
<6>usbcore: registered new interface driver tv8532
<6>usbcore: registered new interface driver vc032x
<6>usbcore: registered new interface driver vicam
<6>usbcore: registered new interface driver xirlink-cit
<6>usbcore: registered new interface driver zc3xx
<6>usbcore: registered new interface driver ALi m5602
<6>usbcore: registered new interface driver STV06xx
<6>usbcore: registered new interface driver gspca_gl860
<6>usbcore: registered new interface driver hdpvr
<6>usbcore: registered new interface driver s2255
<6>usbcore: registered new interface driver uvcvideo
<6>USB Video Class driver (v1.1.0)
<4>i2c-core: driver [mag3110] using legacy suspend method
<4>i2c-core: driver [mag3110] using legacy resume method
<6>imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=1)
<6>device-mapper: uevent: version 1.0.3
<6>device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
<6>Bluetooth: Virtual HCI driver ver 1.3
<6>Bluetooth: HCI UART driver ver 2.2
<6>Bluetooth: HCIATH3K protocol initialized
<6>Bluetooth: Generic Bluetooth USB driver ver 0.6
<6>usbcore: registered new interface driver btusb
<6>cpuidle: using governor ladder
<6>cpuidle: using governor menu
<6>sdhci: Secure Digital Host Controller Interface driver
<6>sdhci: Copyright(c) Pierre Ossman
<6>mmc0: SDHCI controller on platform [sdhci-esdhc-imx.3] using DMA
<6>mmc1: SDHCI controller on platform [sdhci-esdhc-imx.1] using DMA
<6>mmc2: SDHCI controller on platform [sdhci-esdhc-imx.2] using DMA
<6>mxc_vdoa mxc_vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
<6>VPU initialized
<6>mxc_asrc registered
<6>Galcore version 4.6.9.9754
<4>revserved_memory_account:viv_gpu registerd
<6>Thermal calibration data is 0x5864f469
<6>Thermal sensor with ratio = 183
<6>Anatop Thermal registered as thermal_zone0
<6>anatop_thermal_probe: default cooling device is cpufreq!
<7>Registered led device: led0
<7>Registered led device: led1
<7>Registered led device: led2
<6>usbcore: registered new interface driver usbhid
<6>usbhid: USB HID core driver
<6>logger: created 256K log 'log_main'
<6>logger: created 256K log 'log_events'
<6>logger: created 256K log 'log_radio'
<6>logger: created 256K log 'log_system'
<6>usbcore: registered new interface driver snd-usb-audio
<6>mxc_hdmi_soc mxc_hdmi_soc.0: MXC HDMI Audio
<3>imx-hdmi-soc-dai imx-hdmi-soc-dai.0: Failed: Load HDMI-video first.
<6>sgtl5000 1-000a: sgtl5000 revision 17
<6>print_constraints: 1-000a: 850 <--> 1600 mV at 1200 mV normal
<6>mmc0: new high speed DDR MMC card at address 0001
<6>mmcblk0: mmc0:0001 SEM04G 3.68 GiB
<6>mmcblk0boot0: mmc0:0001 SEM04G partition 1 1.00 MiB
<6>mmcblk0boot1: mmc0:0001 SEM04G partition 2 1.00 MiB
<6> mmcblk0: p1 p2 p3 < p5 p6 p7 p8 p9 > p4
<6> mmcblk0boot1: unknown partition table
<6> mmcblk0boot0: unknown partition table
<6>asoc: sgtl5000 <-> imx-ssi.1 mapping ok
<3>Initialize HDMI-audio failed. Load HDMI-video first!
<6>ALSA device list:
<6> #0: sgtl5000-audio
<6>oprofile: using arm/armv7-ca9
<6>GACT probability NOT on
<6>Mirror/redirect action on
<6>u32 classifier
<6> Actions configured
<6>Netfilter messages via NETLINK v0.30.
<6>nf_conntrack version 0.5.0 (12183 buckets, 48732 max)
<6>ctnetlink v0.93: registering with nfnetlink.
<6>NF_TPROXY: Transparent proxy support initialized, version 4.1.0
<6>NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
<6>xt_time: kernel timezone is -0000
<6>IPv4 over IPv4 tunneling driver
<6>GRE over IPv4 demultiplexor driver
<6>ip_tables: (C) 2000-2006 Netfilter Core Team
<6>arp_tables: (C) 2002 David S. Miller
<6>TCP cubic registered
<6>NET: Registered protocol family 10
<6>Mobile IPv6
<6>ip6_tables: (C) 2000-2006 Netfilter Core Team
<6>IPv6 over IPv4 tunneling driver
<6>NET: Registered protocol family 17
<6>NET: Registered protocol family 15
<6>can: controller area network core (rev 20090105 abi 8)
<6>NET: Registered protocol family 29
<6>can: raw protocol (rev 20090105)
<6>can: broadcast manager protocol (rev 20090105 t)
<6>Bluetooth: RFCOMM TTY layer initialized
<6>Bluetooth: RFCOMM socket layer initialized
<6>Bluetooth: RFCOMM ver 1.11
<6>Bluetooth: BNEP (Ethernet Emulation) ver 1.3
<6>Bluetooth: BNEP filters: protocol multicast
<6>Bluetooth: HIDP (Human Interface Emulation) ver 1.2
<6>L2TP core driver, V2.0
<6>PPPoL2TP kernel driver, V2.0
<6>L2TP IP encapsulation support (L2TPv3)
<6>L2TP netlink interface
<6>L2TP ethernet pseudowire support (L2TPv3)
<6>lib80211: common routines for IEEE802.11 drivers
<7>lib80211_crypt: registered algorithm 'NULL'
<7>lib80211_crypt: registered algorithm 'WEP'
<7>lib80211_crypt: registered algorithm 'CCMP'
<7>lib80211_crypt: registered algorithm 'TKIP'
<6>VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
<6>Bus freq driver module loaded
<6>Bus freq driver Enabled
<6>DVFS driver module loaded
<4>regulator_init_complete: VDDD: incomplete constraints, leaving on
<6>rtc-rx8025t 0-0032: rx8025t_get_time: date 11s 54m 9h 5wd 1md 3m 116y
<6>rtc-rx8025t 0-0032: setting system clock to 2016-04-01 09:54:11 UTC (1459504451)
<6>Freeing init memory: 236K
<4>SELinux: Could not mount selinuxfs: No such device
<3>init: /init.freescale.rc: 169: ignored duplicate definition of service 'dhcpcd_wlan0'
<3>init: /init.freescale.rc: 203: ignored duplicate definition of service 'dhcpcd_wlan0'
<3>init: /init.freescale.rc: 207: ignored duplicate definition of service 'dhcpcd_p2p'
<3>init: /init.freescale.rc: 211: ignored duplicate definition of service 'iprenew_wlan0'
<4>init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
<6>mmc2: new high speed SDIO card at address 0001
<4>RTL871X: register rtw_netdev_ops to netdev_ops
<4>RTL871X: rtw_wdev_alloc(padapter=d9c08000)
<4>RTL871X: Chip Version Info: CHIP_8723B_Normal_Chip_TSMC_B_CUT_1T1R_RomVer(0)
<4>RTL871X: RF_Type is 3!!
<4>RTL871X: EEPROM type is E-FUSE
<4>RTL871X: SetHwReg8723B: bMacPwrCtrlOn=1
<4>RTL871X: hal_EfuseSwitchToBank: Efuse switch bank to 0
<6>keychord: using input dev tq_hs0038 for fevent
<4>RTL871X: hal_ReadEFuse_WiFi: data end at address=0xab
<4>RTL871X: Efuse Realmap:
<4>
<4>29 81 03 7C 51 08 28 00 62 07 0D 45 10 00 00 00
<4>31 31 2F 2E 2E 2E 33 33 31 30 30 02 FF FF FF FF
<4>FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
<4>FF FF FF FF FF FF FF FF FF FF 26 26 26 26 26 26
<4>28 28 28 28 28 02 FF FF FF FF FF FF FF FF FF FF
<4>FF FF FF FF FF FF FF FF 20 26 24 00 00 00 FF FF
<4>FF 29 20 11 00 00 00 FF 00 FF 12 FF FF FF FF FF
<4>3E 10 01 02 23 00 00 FF 20 04 4C 02 23 B7 21 02
<4>0C 00 22 04 00 08 00 32 FF 21 02 0C 00 22 2A 01
<4>01 00 00 00 00 00 00 00 00 00 00 00 02 00 FF FF
<4>00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
<4>00 EB 00 6E 01 00 00 00 00 FF 58 63 56 5E 79 87
<4>RTL871X: Hal_EfuseParseBTCoexistInfo_8723B: Enable BT-coex, ant_num=1
<4>RTL871X: Hal_EfuseParsePackageType_8723B phy efuse read 0x1FB =fc
<4>RTL871X: PackageType = 0x4
<4>RTL871X: Hal_EfuseParseVoltage_8723B hwinfo[EEPROM_Voltage_ADDR_8723B] =62
<4>RTL871X: Hal_EfuseParseVoltage_8723B pEEPROM->adjuseVoltageVal =6
<4>RTL871X: AutoloadFail =0,
<4>RTL871X: Adapter->eeprompriv.EEPROMRFGainVal=f3
<4>RTL871X: EEPRORFGainOffset = 0x29
<4>RTL871X: SetHwReg8723B: bMacPwrCtrlOn=0
<4>RTL871X: <==== _ReadAdapterInfo8723BS in 100 ms
<4>RTL871X: init_channel_set ChannelPlan ID 20 Chan num:13
<4>RTL871X: rtw_register_early_suspend
<4>RTL871X: Init_ODM_ComInfo_8723b(): fab_ver=0 cut_ver=0
<4>RTL871X: rtw_macaddr_cfg MAC Address = 58:63:56:5e:79:87
<4>RTL871X: bDriverStopped:1, bSurpriseRemoved:0, bup:0, hw_init_completed:0
<4>RTL871X: rtw_ndev_init(wlan0)
<4>RTL871X: _rtw_drv_register_netdev, MAC Address (if1) = 58:63:56:5e:79:87
<6>EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
<4>EXT4-fs (mmcblk0p4): warning: checktime reached, running e2fsck is recommended
<6>EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,noauto_da_alloc,errors=panic
<4>EXT4-fs (mmcblk0p6): warning: checktime reached, running e2fsck is recommended
<6>EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: nomblk_io_submit
<4>EXT4-fs (mmcblk0p7): warning: checktime reached, running e2fsck is recommended
<6>EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
<4>rtusb init rt2870 --->
<6>usbcore: registered new interface driver rt2870
<6>usbcore: registered new interface driver rtl8723bu
<6>usbcore: registered new interface driver rtk_btusb
<3>init: using deprecated syntax for specifying property 'ro.product.manufacturer', use ${name} instead
<3>init: using deprecated syntax for specifying property 'ro.product.model', use ${name} instead
<3>init: using deprecated syntax for specifying property 'ro.serialno', use ${name} instead
<3>init: cannot find '/system/bin/dbus-daemon', disabling 'dbus'
<4>camera_subdev: disagrees about version of symbol module_layout
<6>warning: `daemonsu' uses 32-bit capabilities (legacy support in use)
<3>android_usb: already disabled
<6>mtp_bind_config
<3>ov3640_write_reg:write reg error:reg=3012,val=80
<3>ERROR: v4l2 capture: slave not found!
<7>ehci_fsl_bus_suspend begins, Host 1
<7>ehci_fsl_bus_suspend ends, Host 1
<6>request_suspend_state: wakeup (3->0) at 16063594671 (2016-04-01 09:54:24.255785002 UTC)
<6>cpufreq_interactive_input_connect: connect to ft5x06_ts
<6>eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=1:00, irq=-1)
<4>use ar8031
<6>ADDRCONF(NETDEV_UP): eth0: link is not ready
<6>acc_open
<6>acc_release
<7>ehci_fsl_bus_resume begins, Host 1
<7>ehci_fsl_bus_resume ends, Host 1
<7>ehci_fsl_bus_resume begins, DR
<3>init: sys_prop: permission denied uid:1003 name:service.bootanim.exit
Hi leavs
please try patches on below link
How to enable wifi scan mode in android4.3?
hi igorpadykov,
thanks for your answer.my SDIO WIFI js not work,not the scan mode,can you have any other idea?
leavs
