Has anybody ported qcom_api for GT202 WiFi module on frdmk22f120m mqx platform in arm gcc ?
The same is available for IAR MQX but not for arm gcc.
Please check the below doc and let me know if this helps!!!
Sol
Thanks.
But that project is built with IAR not arm gcc. We tried to build qcom_api library with arm gcc tool. It is not very clear what are the source driver files to be included in build process to make qcom_api.a library.
qcom_api library for GT202 WiFi module on frdmk22f120m MQX has been ported in ARM gcc
