I created MQXLite project using Processor export in Kinetis Design Studio. One of the task initializes ethernet controller of K60 Kinetis MCU. It also calls:
_int_install_default_isr( &MyDefaultHandler);
The problem is that my program crashes with this on stack:
UnhandledInterrupt() at Vectors.c:68 0xc1c
<signal handler called>() at 0xfffffff1
stack_heap.12096() at 0x200030d0
_time_notify_kernel() at time_ticks.c:845 0x2e84
SystemTimer1_OnCounterRestart() at MQX1.c:117 0x3024
SystemTimer1_Interrupt() at SystemTimer1.c:399 0x32b2
_isr_execute() at dispatch.S:652 0x14b36
<...more frames...>
Can you please help?
Hello Martin,
Please check the below threads and let me know if it helps.
How to define a interrupt in MQX-Lite?
Interrupts outside of MQX Lite
Interrupts in MQXlite
Sol
