About imx6 spi be used on application layer.
guanliangding
Hi, all:
     I config the devicetree and menuconfig like attach. But in the /dev, i don't find spidevx.x still. I use linux kernel is 3.10.17.
Tags (2)
Hi guanliang
compatible = "spidev" should be added as in
SPI block device
How to enable and test SPI in i.MX6SoloLite using kernel 3.10.17?
and enable spidev support in the kernel with menuconfig
Hi guanliang
SPI block device
