I am working with USB-MSD demo on FRDM-K64F and I would like to add some C++ code I did to the project. How can I add C++ support to this project? I don't see "Cross ARM C++ compiler" and "Cross ARM C++ linker" in Tool Settings list (just C compiler + linker) under C/C++ build -> Settings -> Tool Settings just like in new project created by wizzard.
I am looking for something easier than creating new project with wizzard and copying all include paths and settings But if there won't be any other way, I will have to do that.
Martin
Solved! Go to Solution.
I found out what I wanted - I just had to add line
<nature>org.eclipse.cdt.core.ccnature</nature>
into .project file into <natures> section and now I can also see C++ settings
For more complete answer, see: https://community.nxp.com/message/843799
Hi Martin,
Please review following to see if it helps.
How to Create a C++ Project Using MQX RTOS for KSDK1.2
David
