Hi all,
I'm looking for recommendations for good USB connectors for a design using a Kinetis L chip (MKL27Z).
I'm currently basing my design on: HIROSE UX60SC-MB-5S8
I like this connector because it has large mounting holes, making it look quite sturdy.
However, as others have found (Routing USB to Kinetis K20: crossing traces? ) this connector and most others I've seen, you need to swap traces on the board.
D+/D- have to be swapped, and VREGIN also has to cross both data lines.
Can anyone recommend a good USB connector that doesn't have this issue? I am looking for mini USB, but I am also interested in micro USB for future projects.
Also, for traces that will be ~13cm, can someone recommend values for good trace width / trace spacing?
I used Edge Coupled Microstrip Impedance | Electronics and Electrical Engineering Tools | EEWeb Community to calculate 0.508mm width and 0.254mm spacing would give ~140 Ohms diff impedance. (The recommend is 90 Ohms)
Thanks!
Joey
Just bumping my thread to try get more visibility, and hopefully some replies!
