Hello to the whole community. I'm about to use vector redirection and want to know if the compiler and linker recognizes this redirect, and correctly assigns the vectors allocated in the PRM file or should I do it myself?
Hi Daniel,
There are some posts you can refer to handle this question.
Can you have a look on:
RELOCATED INTERRUPT VECTOR TABLE
AN4757-Migration Guide From S08 to Kinetis E Family.pdf
You can also refer to the manual provided in the tool installation.
For instance under CW for MCU V10.6.4:
\CW MCU v10.6.4\MCU\Help\PDF\MCU_Build_Tools_Utilities.pdf -> perform a search for "Vector Table"
Pascal
Freescale Technical Support
