Debug trouble
Debug trouble
jonnyescobar
hi
I am triying to debug my program, this stop on ldr r0, there is a discussion but the link doesn't work
Thread [1] <main> (Suspended : Signal : SIGTRAP:Trace/breakpoint trap)
__boot() at boot.S:66 0x7cc
the code where happen is:
/* Disable interrupts and clear pending flags */
        ldr r0, =NVIC_ICER0
        ldr r1, =NVIC_ICPR0
        ldr r2, =0xFFFFFFFF
        mov r3, #8
thanks a lot
soledad
Did you refer to this link KDS and PE Micro Debugger Setup?  ???
Sol
jonnyescobar
Hello
I am using MQX,  k64FN1M0VLQ12 and KDS 3.0, my board was worrking but i did minor changes on Processor Expert GPIO configuration.
soledad
Hello Jonny,
Please check the link below and let me know if this helps.
Sol
soledad
Hello Jonny,
Are you using MQX??
Which device are you using??
Which IDE are you using?
Sol
