I'd like to make i.MX6 Solo to run at 1GHz using i.MX6 DL SabreSD
I bitbaked a solo image with 3.14.28_1.0.0 sdk.
Then run it in i.MX6 DL SabreSD.
However I can't get 1GHz OPP in time_in_state.
cat /sys/devices/system/cpu/cpu0/cpufreq/stats/time_in_state
396000 43616
792000 155597
The kernel is using imx6dl-sabresd.dtb which has following settins in imx6dl.dtsi.
fsl,soc-operating-points = <
/* ARM kHz SOC-PU uV */
996000 1175000
792000 1175000
396000 1175000
How can I enable 1GHz for i.MX 6 Solo with i.MX 6 DL SabreSD?
Nori Shinozaki
Have you taken a look at the following thread?:
Let me know if it answers your questions.
