How to set the Gateway and Netmask of Ethernet in Android 4.4.3
erickang
Hi All,
I want to set the Gateway and Netmask of Ethernet in Android 4.4.3.
Could you tell me how to set those?
Our development environment is like below,
- AP/Board : i.MX6DL-SabreSDP
- OS : Android 4.4.3 (Linux 3.10.53)
I could confirm the method how to apply IP and DNS from Ethernet App in packages/apps/fsl_imx_demo,
But I couldn't find how to set the Gateway and Netmask of Ethernet.
Eric.
Labels (4)
Yuri
Hello, Eric !
Android networking is property based and is available through getprop / setprop commands.
Also standard Linux utilities ifconfig and route are still available.
Have You tried it ?
$ ifconfig eth0 192.168.1.151 255.255.255.0
$ route add default gw 192.168.1.1 dev eth0
$ setprop net.eth0.dns1 8.8.8.8
Yuri
erickang
Hi Yuri,
Thanks for your response.
I used the below command to set the Ethernet Configuration.
  ~$ ipconfig eth0 xxx.xxx.xxx.xxx netmask 255.255.255.0
  ~$ route add default gw yyy.yyy.yyy.yyy dev eth0
But I couldn't find the ethernet.apk to set those.
Eric.
johnnyjhao
Hi Yuri,
I found a ethernet.apk in freescale website,  but the app can't set gateway
https://community.freescale.com/servlet/JiveServlet/download/93626-9-264786/ethernet.apk.zip
Yuri
What is log ?
Yuri
  We do not provide .apk, sorry.
Nevertheless, You may look at How to Add Ethernet UI Support in ICS
Yuri.
