we trying to bringup ethernet with smsc phy in dual lite . we have done the pin muxing as follows.
MX6DL_PAD_ENET_MDC__ENET_MDC,
MX6DL_PAD_ENET_MDIO__ENET_MDIO,
MX6DL_PAD_ENET_CRS_DV__ENET_RX_EN,
MX6DL_PAD_ENET_RXD0__ENET_RDATA_0,
MX6DL_PAD_ENET_RXD1__ENET_RDATA_1,
MX6DL_PAD_ENET_TX_EN__ENET_TX_EN,
MX6DL_PAD_ENET_TXD0__ENET_TDATA_0,
MX6DL_PAD_ENET_TXD1__ENET_TDATA_1,
MX6DL_PAD_GPIO_16__ENET_ANATOP_ETHERNET_REF_OUT,
we can able to detect phy .but when we try to transmit data , only transmission occurs but no packets on rx line.
is this kernel have support for rmii ?
Hi ela
I believe it is not supported, by solution can be found on links below
https://community.freescale.com/thread/313741
https://community.freescale.com/message/346089#346089
