I was wondering if there was a way to record the camera video input to storage (SD card) on the SABRE board. I am able to get the camera output to the display (SDP) and have streamed it, but I would also like to record the camera input to the SD card.
Any help is greatly appreciated.
Thanks.
Thanks for the response. I am looking for an example if someone has stored a video stream on the SD card on the SABRE board.
Thanks.
You may try using "tee" or just to run several gstreamer pipelines as different Linux tasks.
But performance may be an issue in such cases.
Yuri
