I downloaded and installed the KDS 3.0 and SDK 1.2.0 but I can't see any difference between this version and previous version of KDS. I have no new µC added now example files etc...
Do I need to do something else like linking the KDS and the SDK?
How can I do that?
I m using Windows 8 64bit version.
Thank You in advence.
Alexandre
Thanks a lot for helping.
I hadn't installed the eclipse update on KDS. I m new to Freescale MCU's. I'm switching from Atmel's AVR MCU to the Freescale's Kinetis Family.
You info helped me to get up and running thanks a lot.
Carlos Mendoza and ZhanJennie
Hi Alexandre,
please see Erich's article for what's new in KDS3.0
(see https://community.freescale.com/docs/DOC-104880 for details)
for device support, please see attached release note, section " Devices Supported "
See https://community.freescale.com/docs/DOC-103698 for additional details, especially about porting KDS v2.0.0 projects to the GNU ARM Embedded (launchpad) tools.
for beginner user, I also recommend this article for
How to start customized KSDK project based on KSDK demo code
can this help?
Zhang Jun
Hi Alexandre,
Did you installed the Kinetis SDK eclipse update on KDS? please take a look at this video that explains how to do it:
Hope it helps!
Carlos Mendoza
Technical Support Engineer
