how to add IP FILTER in frdnk64f120
sudhakarp
     i am using KDS 2.0 and ksdk1.1.0 rtcs example code.
in ethernet to serial example code i want to add IP filter. the controller only receive(or connect) data from particular IP address only.
how to do this one. any API function available for this one.
regards,
sudhakar p
soledad
Please check your the answer in the following link
how to implement IP filtering in FRDMk64
Sol
