Gstreamer plugin mpegtsdemux is abnormal
zhang_derek
Hello community. Recently I used Gstreamer on i.MX Phase2 board (Yocto built OS), I found the plugin mpegtsdemux didn't work as gst_element_factory_make("mpegtsdemux", NULL) returned NULL. Type in command: gst-inspect-0.10 mpegtsdemux, the output information only including "plugin detail", No "element" and "pad".
I have installed gstreamer0.10-plugins-bad, and libgstmpegtsdemux.so existed in right directory.
How to fix the problem? Anly help will be appreciated.
Labels (3)
jimmychan
For example:
demuxer_1 = gst_element_factory_make ("mpegtsdemux", "demux1");
if(!demuxer_1) g_printerr("demux1 not created\n");
Do you mean it return NULL? Is your pipeline work in your program?
For your reference:
Can not play double-image screen
zhang_derek
jimmychan 撰写:
For example:
For your reference:
Yeah, gst_element_factory_make("mpegtsdemux", "demux1") returns NULL, and pipeline doesn't work.
Following is the output message of command: gst-inspect-0.10 mpegtsdemux
Plugin Details:
  Description:  MPEG TS demuxer
  Filename:  /usr/lib/gstreamer-0.10/libgstmpegtsdemux.so
  Version:  0.10.23
  License:  unknown
  Source module: gst-plugins-bad
  Source release date: 2012-02-20
  Binary package: GStreamer Bad Plug-ins source release
  Origin URL:  Unknown package origin
  tsparse: MPEG transport stream parser
  tsdemux: MPEG transport stream demuxer
  2 features:
  +-- 2 elements
Later I used "tsdemux" instead of "mpegtsdemux", and it really works.
I guess "mpegtsdemux" is just a plugin, it includes "tsparse" and "tsdemux" which are the true elements required by gst_element_factory_make()
is my guess right? anyhow "tsdemux" solved my problem :smileyhappy:
jimmychan
yes, your thinking is right. "tsdemux' is the element in this plugin.
