Hello all,
I have ask a question about the bus clock of S12ZVMC12 ,
Please see here : How to cacluate the bus clock of S12ZVMC12
I use CW 10.6 , create PE project .
When i use "Internal clock" , it is 1MHZ, what's the biggest bus clock ?
When i select 30MHZ or 50 MHZ "Internal bus clock " , when build , there is no error ,while , when debug , it show
Could you tell me what's wrong with me .
And when i select 20 MHZ bus clock , it can work well .
Thank !
I don't understand why you opened a new topic when there is the same question in the existing one:
