how to interface dongle in sololite evk
thangameenaraje
hi i am working in i.mx sololite evk board.. i need to  use dongle to use internet.
I am using jelly bean 4.3  from git source. using(android user guide).
i configured pid vid  in drivers/usb/serial/ .
in my bootlog is showing huawei mass storage ..
but  in dev/ folder i cant found ttyUSB0
kindly help me how to configure in kernel.
Labels (2)
lyfsci
Hi Thangameena,
How you added the vid/pid in the source code itself or through sysfs entry ?
Usually dongles will be enumerated as mass storage until the driver is loaded. Once the driver is loaded then the serial AT ports will be open and well it depends on the vendor. Some dongles don't have such requirements and it could be accessed easily.
thangameenaraje
i added vid pid in  drivers/usb/serial/option.c..
i didnt find driver  for my tata photon plus(huawei).
Hi THANGAMEENA
please look at below link where similar problem was solved
Re: Re: wifi binding on imx6sl evk based board
