How to change SDIO clock in i.MX6 SABRE-SD
petertseng
I have download android_kk4.4.2_1.0.0-ga BSP and build for my i.MX6Q SABRESD board.
But, I need to change SDIO clock to test our WIFI modules.
How to change SDIO clock in i.MX6 SABRE-SD?
Peter.
Hi Peter
I think most easy to change sd divider
CSCDR1: usdhc1_podf with memtool
How to confirm a Register value on AndroidKK4.4.2 for MX6-SABRE-SD
petertseng
Hi igor,
I did not find memetool in my AndroidKK4.4.2 BSP directory.
How to get memtool?
Peter.
Hi Peter
had you checked suggested link ?
It shows how to get memtool.
petertseng
Hi igor,
I can find the patch at this link, but it does not provide any patch to add memtool source code.
In my AndroidKK4.4.2 BSP does not have "/test/memtool/" folders.
Peter.
Hi Peter
as far as I understand it just adds linux memtool package
to build Android.mk (Android is based on Linux):
LOCAL_MODULE := memtool
after that one needs to rebuild Android.
