Trying to upgrade from MQX 3.8 to MQX 4.1.1 what replaces _rtc_sync_with_mqx() ?
For reference for others who might have similar problems. I lifted the API from MQX 3.8 and included into my application - the parts I needed were only about 4 lines.
This just required combing through the MQX 3.8 code to find the API-
Hi David,
This funtion is no longer in the MQX version. This is removed and the way to synchronize the RTC with the MQX time is different.
Please check the below thread:
mcc_recv_nocopy never timeouts
Sol
