Issue about OpenSDA debugger adapter on KDS
wendersonolivei
Hi all,
I'm using the KDS to build some things on FRDM-KL25Z, and I've followed that configuration for debug Video Tutorial: Project creation and debugging with FRDM-KL25Z.
But, I see that is not possible to add global variables at the Variables window.
It's a eclipse configuration or a KSD/OpenSDA bug?
Tags (3)
BlackNight
This is a general problem (or feature?) of Eclipse Kepler. Eclipse changed the way how global variables are exposed, for good and bad.
See Variable Debugging with Eclipse Kepler | MCU on Eclipse
I hope this helps,
Erich
BlackNight
I hope this helps,
Erich
wendersonolivei
Hi Erich,
It's really helpful!
I'm using the "Expressions" to show my Global Variables. Thanks again.
Wenderson
