Hi.
May i know how many display BG and overlay framebuffer is available on the imx6 SOLO?
In below page:
https://support.bluetechnix.at/wiki/Linux_Software_User_Manual_%28i.MX6%29
section 8.13 Display Interface,
It stated that imx6 SOLO only has 2 BG framebuffer and 1 overlay framebuffer.
Just want to confirm whether this is true? I did not see any description on this in the reference manual.
Thank you.
Zhen Cong Tee
Hi Zhen
yes this is true, i.MX6S has only one IPU,
some details are provided by IPU expert below
chip
Hi Chip,
Yes. I understand that i.mx6S only has one IPU.
But this one IPU has how many BG framebuffer and overlay framebuffer? I dun see this information in the page you attached.
Thank you.
Zhen Cong Tee
Hi Zhen,
expert answer:
"the hardware IPU by default doesn't support it. It can only support 2-layer(BG, FG)."
chip
Hi Chip,
If this is the case, does it means that for dual display (as supported by the IPU),
i have 2x2layer(BG,FG) framebuffer?
zhen Cong Tee
Hi Zhen,
I think yes.
chip
Hi Chip,
Is there any document that i can refer to so that i can documented it down and present to my management?
Thank you.
Zhen Cong tee
Hi Zhen,
probably you can look through FTF2014 presentations
http://www.freescale.com/webapp/sps/site/overview.jsp?code=DWFREESCALE_OLL
chip
