I have looked at the other i.MX6 schematic elements uploaded in other questions, but have not found any that match the version of the i.MX6 we are using.
I am using Altium Designer 14.
I have been successful in importing a library in a DSN file. I have had no success in opening OrCAD files due to a lack of an OrCAD licence. I have had little success in opening BRD files. I'm not sure why.
Thanks!
Solved! Go to Solution.
Try to edit your earlier reply ,then you can see attachment button
Hi David
Freescale does not provide i.MX6 Altium libraries, however
you can find helpful links below
https://community.freescale.com/message/330148#330148
https://community.freescale.com/thread/302275
Hi David
please post this on links below
chip
I would, but again don't see how to upload the files. Am I just overlooking the attachment button?
Thanks, ChipExpert. I have looked at those and downloaded some of the files. The i.MX6Q looks to have the same pins, just different ball assignments. I think I am going to have to update the ball assignments in those schematic elements and create the footprint. Not hard, just time consuming.
