i.Mx6 Parallel CSI0 16bit bus width
alessandroinnoc
Hi to all !
I am interfacing an ADV7403 to iMX6 DUAL using CSI0 port at 16bit bus width, but I also get
I always get the following kernel error message:
ERROR: v4l2 capture: mxc_v4l_dqueue timeout enc_counter 0.
Does anyone have any experience on such interfacing ?
Best Regards
Alessandro Innocenti
alessandroinnoc
Hi chip
we solved using CSI0 with a bus 8 bit wide and doubling the pixel clock.
Many thanks
ALessandro Innocenti
Hi Alessandro
seems this configuration is not supported in kernel,
one can look at similar post below
How to fix the camera timeout error ?
In general new camera needs some support code, for
example ADV7180 below
https://community.freescale.com/message/314760#314760
chip
alessandroinnoc
Hi chip
Many thanks
