Dear all,
Recenlty I have started using MMA6813BKW dual axis SPI sensor. I need to calculate the g-value out of this sensor and I am trying to configure it as below.
I have configured the sensor according to the details given in the data sheet page num: 45, sec: 4.1. I requested the raw acceleration data out from x-axis, unsigned and with odd parity. based on the above configuration I send the SPI MOSIcommand as 0x3004 (I send only this command 4times, no other configuration made) as a response MISO I am getting only 0x0E00, even if I move the sensor in all directions. Can you please support me on the following topics,
Thanks in advance.
Best Regards
Here is another thread which might give you some clues.
It talks about configuring the device.
community.freescale.com/thread/301952
Can you explain what the "center plate" you are refering to when you explain how you connected the reference pins?
