I tried to port the DAC_ADC application in K20d72m of "CW MCU v10.5\MCU\CodeWarrior_Examples\Processor_Expert\Kinetis\TWR-K20D72M" to K60D100m to generate the DAC signals for playing audio. I am using PE generated code along with MQX 4.0
But I was not able to get any output in DAC0.
Please find attached the PE generated code for the above.
Kindly help me to sort out the issue. The code warrior version I am using is 10.5
Annie
