iMX6Q: How to control alpha and color-key in fb1 & fb3
egremillion
My current board setup appears to use an alpha value of about 0.5 for video that goes into /dev/fb1 or /dev/fb3.  Is there any way to change this without using an ioctl?  I found this "Alpha Test on iMX6Q" post which looks like what I want to do - is this the only way to do it?  I'm using Yocto Dora if that's important or helps...  Thanks!
Labels (2)
egremillion
In the end, the patches didn't work for us (we are using a 24 bpp monitor depth).  So we recompiled the kernel with framebuffer support and used ioctl.
LeonardoSandova
Specialist I
what is the reason you want to avoid ioctl?
egremillion
Hi - any update or info on this?  It would be nice to know if this is possible or not.  Thanks!
EricNelson
Senior Contributor II
Hi Ernie,
Here are some patches for the mfw_v4lsink plugin that add global-alpha and color-key properties.
These only seem to function with a 32bpp frame-buffer, though, and I haven't spent any time digging into why.
egremillion
Thanks, Eric. I'll give these a try and report back how they work out for me.
egremillion
Two reasons:
1. I'd like to do a quick test/proof-of-concept using gst-launch
2. The system I'm using doesn't appear to have Linux framebuffer support included and I don't want to have to add it if I don't have to
Ernie
