QorIQ P2020 software restart
hcs
How can I restart system from linux in case no watchdog is on. I mean - when I send shutdown -r now I want to real system restart. Is there some special register or special sequence of registers writing for restart CPU like hard reset by power switch on?
marius_grigoras
You should use the POR signal from CPLD registers. Something similar with this [1]. These details can be found in the board/CPLD manual.
Marius
[1] https://community.freescale.com/message/351257#351257
