Hi all,
I am working with imx6 quad sabrelite board ,default uboot.bin file boot from NOR-FLASH option and now i want to change this boot option from NOR flash to SD card boot without using NOR-Flash support . let me know the procedure for mx6 Quad in SD card boot from SD card only without using the NOR-Flash support. .
We are in very critical situation kindly update this Sd card support boot .
By,
Venkat.
Hi Venkatesh ,
Yung-Wen Tsao have replied to you in another threadIMX6 Quad sabre lite Boot option with SD card boot and without using NOR flash support
Please check. Hope this can help you~~
Best Regards
Dan
