NFC_LDD seems to ignore LUN in calculating total size?
bowerymarc
it seems the total size calc doesn't account for multiple LUNS (see attached image) but total pages is OK.  Will this actually affect the functionality?
Petr_H
Yes you are right. There is a bug in the Total memory size calculation. This value is for information only and is not used in generated code so as a workaround please ignore the displayed value.
We are sorry for an inconvenience, it will be fixed in the next releases.
Thanks for the information.
best regards
Petr Hradsky
Processor Expert Support Team
vfilip
you can find the hot-fix to this issue in this thread: NFC_LDD ECC asking for too many bytes?
Vojtech Filip
