Hello I was wondering if I can program custom made board containing k10 uc using FRDM-K20D50M's open SDA or TWR-K20D50M's OSJTAG?
please refer this link:
Yes, you can with and of the FRDM boards. But not with the original P&E OpenSDA Firmware. You need to use a different firmware (e.g. CMSIS-DAP, USBDM or Segger).
See
Debug External Processors with USBDM and Freedom Board | MCU on Eclipse
http://mcuoneclipse.com/2013/05/16/freedom-board-with-segger-opensda-debug-firmware/
Using the FRDM-KL25Z with CMSIS-DAP to program non-Freescale ARM Microcontrollers | MCU on Eclipse
CMSIS-DAP with IAR and the KL25Z Freedom Board | MCU on Eclipse
HI Erich
I was trying for USBDM and tried to folllow the steps provided in the tutorial but now I am having a problem for driver. Presently I am using windows 8.0 and I don't think we have driver for that. So is there any way to get through this ? I also tried with the latest software USBDM - Browse /Version 4.10.6 at SourceForge.net but the driver issue was not resolved.
Amit Kumar
Hello, Amit,
I am also trying to do same, want to program and debug an external board which had MK10DN64 using TWRK20D50M. Can you give information on how to do it.
Thanks :smileyhappy: I will try and will let u all know if I face any problem
Amit Kumar
