MPC5121 FEC Multicast issue
hamzehachem
I am experiencing the same issue as described here: UDP Multicast with MPC5121 FEC . I cannot apply the proposed patch since the code to edit does not exist on my system. After researching, I found out that I simply need to download the source code then apply the patch. I would appreciate it, if someone could point me to the location of the source code. Please bear with me, I only have basic linux skills.
Here are some information I was able to extract from my system:
/ # cat /proc/cpuinfo
processor       : 0
cpu             : e300c4
clock           : 220.000000MHz
revision        : 1.0 (pvr 8086 2010)
bogomips        : 54.88
timebase        : 27500000
platform        : MPC5121 ADS
/sys/devices/80000000.soc/80002800.ethernet # cat uevent
DRIVER=fs_enet
PHYSDEVBUS=of_platform
PHYSDEVDRIVER=fs_enet
OF_NAME=ethernet
OF_TYPE=network
OF_COMPATIBLE_0=fsl,mpc5121-fec
OF_COMPATIBLE_N=1
MODALIAS=of:NethernetTnetworkCfsl,mpc5121-fec
Thank you in advance
Tags (2)
hamzehachem
Freescale's support is as useless as their products. Congrats Freescale, you just lost a customer. Never again!
hamzehachem
