How to solve "unhandled interrupt" in LCD Task running eGUI ?
robroz
I'm getting "unhandled interrupt" error in LCD Task that runs eGUI and displays on color touchscreen (320x240).
When looking at MQX-Check for errors under IAR, I see no useful information. I've read that I should run "_int_install_unexpected_isr();"
at the start, but still I don't get any info about vector and type of error that occured...
Do I have to enable something else too? Any documents on how to increase level of debugging to solve this problem ?
Thanks in advance,
Bulek.
c0170
Senior Contributor III
Hello robroz,
this thread might help:
TCP/IP ==> MQX_UNHANDLED_INTERRUPT (0x0041)
There's one document which is now published ! Please read it.
Trackdown the exceptions in MQX
Let us know if you solve your problem :smileywink:
c0170
c0170
Hello robroz,
c0170
