Hello there,
I've a serious problem building my ltib. (for an analogue of the imx53 qsb)
The problem is the elftosb-11.09.01.tar.gz.md5 package which is not available online anymore.
I already tried working my way around it by using the source package for imx6 which has a 10.0.01 version of elftosb but to no avail.
Maybe there is someone with this package still somewhere or a different approach to it.
Error:
Try elftosb-11.09.01.tar.gz.md5 from the GPP
http://bitshrine.org/gpp/elftosb-11.09.01.tar.gz.md5:
16:42:21 ERROR 404: Not Found.
Try elftosb-11.09.01.tar.gz from the GPP
http://bitshrine.org/gpp/elftosb-11.09.01.tar.gz:
16:42:22 ERROR 404: Not Found.
Can't get: elftosb-11.09.01.tar.gz at ./ltib line 790.
Died at ./ltib line 1380.
traceback:
main::build_host_rpms:1380
main::host_checks:1435
main:542
Solved! Go to Solution.
Thank you, I eventually got it working with the 12.04LTIB
