This may seem like a basic question, but i am opening a socket connection and then listing for a telnet connection which works great.
Now i want to add http to the mix, of course when i call httpd_server_init/httpd_server_run is will fail because the socket call has already been made.
Is there way to feed the https calls the socket connection i already have open to the httpd calls ?
Solved! Go to Solution.
Hi WTI,
Please let me know if the answer here: https://community.freescale.com/thread/301503
helps you.
Garabo
Hi WTI,
helps you.
Garabo
