The IMX8MM board configuration fsl-imx8mm-evk.dts file is configured to mipi ov5640 camera.
I am using high defination HDMI camera and using bridge IC converting from HDMI to MIPI data. The MIPI has three data lane and clock is generated from the source itself. so how to modify this for my application
(Camera and Bridge IC datasheet attached)
The current setting in fsl-imx8mm-evk.dts for mipi ov5640 camera are as below.
&mipi_csi_1 {
#address-cells = <1>;
#size-cells = <0>;
status = "okay";
port {
mipi1_sensor_ep: endpoint1 {
remote-endpoint = <&ov5640_mipi1_ep>;
data-lanes = <2>;
csis-hs-settle = <13>;
csis-clk-settle = <2>;
csis-wclk;
csi1_mipi_ep: endpoint2 {
remote-endpoint = <&csi1_ep>;
ov5640_mipi: ov5640_mipi@3c {
compatible = "ovti,ov5640_mipi";
reg = <0x3c>;
status = "okay";
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_csi_pwn>, <&pinctrl_csi_rst>;
clocks = <&clk IMX8MM_CLK_CLKO1_DIV>;
clock-names = "csi_mclk";
assigned-clocks = <&clk IMX8MM_CLK_CLKO1_SRC>,
assigned-clock-parents = <&clk IMX8MM_CLK_24M>;
assigned-clock-rates = <0>, <24000000>;
csi_id = <0>;
pwn-gpios = <&gpio1 7 GPIO_ACTIVE_HIGH>;
mclk = <24000000>;
mclk_source = <0>;
port {
ov5640_mipi1_ep: endpoint {
remote-endpoint = <&mipi1_sensor_ep>;
Hi @santhosh2 ,
We are stuck in a similar situation as you had faced with another cam.
Could you please guide us the way you resolved this issue?
Thanks.
Hi Santhosh
for new camera driver adaptions one can look at below links
https://community.nxp.com/message/1342163?commentID=1342163#comment-1342163
https://community.nxp.com/message/1312444?commentID=1312444#comment-1312444
Thanks igor,
In the fsl-imx8mm-evk.dts is configured such that the processor generates the clock. But in our case Our Camera will be generating the clock signal. Do let me know what changes i need to do in the below configuration for setting the clock as external clock
reg = <0x3c>;
status = "okay";
csi_id = <0>;
mclk = <24000000>;
mclk_source = <0>;
port {
