AnsweredAssumed Answered
How to set client_port in GStreamer ?
Question asked by toanjunifer@gmail.com on Jul 31, 2020
Latest reply on Jul 31, 2020 by toanjunifer@gmail.com
I'm using iMX6S and I'm trying to stream (RTSP- Real Time Stream Protocol) over internet by GStreamer. When I push stream video to server, I got this error from server:
ERR: transport header does not have valid client ports ([RTP/AVP/UDP;unicast;client_port=0-0;mode=RECORD])
I also try many way to configure client ports but It's does work.
With client side, I use this element:
rtspclientsink location=rtsp://<IP Public of Server>:<Opened PORT>/stream
UPDATE: This is log from client:
Progress: (open) Opening Stream
Progress: (connect) Connecting to rtsp://<IP>:<PORT>/stream
Progress: (open) Retrieving server options
Progress: (open) Opened Stream
Setting pipeline to PLAYING ...
New clock: GstSystemClock
[INFO] ringBufferEnable 0, chromaInterleave 0, mapType 0, linear2TiledEnable 0
[WARN] VPU iram is less than needed, some parts don't use iram
Progress: (request) Sending RECORD request
Progress: (record) Sending server stream info
Progress: (request) SETUP stream 0
ERROR: from element /GstPipeline:pipeline0/GstRTSPClientSink:rtspclientsink0: Could not write to resource.
Did I missing something ?
What should I do ?
Thank you,
Toan
Outcomes
