Hi. I need help to solve my problem - i've configured boot logo display during kernel boot, but kernel still prints console output over logo and login prompt. My console configured to ttymxc0 in u-boot.
If i disable framebuffer console in kernel, boot logo don't show.
How can i fix it? Thank you.
Look here for the proper solution (the one that worked for me).
I wound up adding the following file and directory /lib/systemd/system/getty@.service.d/noclear.conf
with the content of the noclear.conf:
[Service]
TTYVTDisallocate=no
https://community.nxp.com/docs/DOC-98109 will do some help for you.
Which i.MX6 series are you using and which version BSP are you using?
