We are looking for ways to reduce power consumption.
gyosunshim
LS1043A is a system used without FAN, and is looking for a way to reduce power consumption.
I first answered the question by answering the link below.
Is it possible to reduce power consumption by disabling the CPU Core?
Two additional questions.
First,
Does SWLPM20 mode disable all cores?
Or can I disable individual cores?
I want to run only one core. If you can do that, you would expect a saving of 0.2 x 3 = 0.6 watt.
The second,
Is there a way to do core-specific power gating?
Thank you,
Best regards.
Gyosun.
ufedor
Yes, in SWLPM20 clocks for all cores and platform clocks are disabled.
Only PW15.
gyosunshim
Hi ufedor,
Thank you for quick response.
Is there any way to reduce power consumption with software other than lowering PW15 and clock frequency?
Thank you,
Best regards.
Gyosun.
ufedor
There are no other methods.
ufedor
Only PW15.
